dYu784jseDsJ 5 Posted ... Hi there. VPN by itself works great. Thanks TOR by itself works, both using the TBB and using 127.0.0.1:9050 (SOCKS5) in all other browsers/software. However, when I put that info into AirVPN, I get "fails to connect". I've seen some others post this problem, but without much debug info. But here's mine: AirVPN Logs: 10/24/2012 - 1:58 AM OpenVPN current version: OpenVPN 2.2.2 10/24/2012 - 1:58 AM Ready. 10/24/2012 - 1:58 AM Login... 10/24/2012 - 1:58 AM Login success. 10/24/2012 - 1:58 AM Contacting service... 10/24/2012 - 1:58 AM Connecting... 10/24/2012 - 1:58 AM OpenVPN 2.2.2 Win32-MSVC++ [sSL] [LZO2] [PKCS11] built on Dec 15 2011 10/24/2012 - 1:58 AM NOTE: OpenVPN 2.1 requires '--script-security 2' or higher to call user-defined scripts or executables 10/24/2012 - 1:58 AM LZO compression initialized 10/24/2012 - 1:58 AM Control Channel MTU parms [ L:1558 D:138 EF:38 EB:0 ET:0 EL:10 ] 10/24/2012 - 1:58 AM Socket Buffers: R=[8192->8192] S=[8192->8192] 10/24/2012 - 1:58 AM Data Channel MTU parms [ L:1558 D:1450 EF:58 EB:135 ET:0 EL:10 AF:3/1 ] 10/24/2012 - 1:58 AM Local Options hash (VER=V4): '22188c5b' 10/24/2012 - 1:58 AM Expected Remote Options hash (VER=V4): 'a8f55717' 10/24/2012 - 1:58 AM Attempting to establish TCP connection with 127.0.0.1:9050 10/24/2012 - 1:58 AM TCP connection established with 127.0.0.1:9050 10/24/2012 - 1:58 AM recv_socks_reply: Socks proxy returned bad reply 10/24/2012 - 1:58 AM TCP/UDP: Closing socket 10/24/2012 - 1:58 AM SIGTERM[soft,init_instance] received, process exiting 10/24/2012 - 1:58 AM Failed to start. And from TOR's perspective, the connection attempt from AirVPN above adds this to its logs: Oct 24 01:58:47.060 [warn] socks5: command 3 not recognized. Rejecting. Oct 24 01:58:47.060 [warn] Fetching socks handshake failed. Closing. Help?! Quote Share this post Link to post
Staff 10488 Posted ... Hello! Quite difficult to figure it out... anyway, can you please make sure that the proxy types match? OpenVPN supports connections over both http and socks proxies, but it must know in advance which proxy type it will meet. Perhaps OpenVPN is expecting a http proxy instead of a socks one. Kind regards Quote Share this post Link to post
dYu784jseDsJ 5 Posted ... Yeah, selected SOCKS in AirVPN's settings. Quote Share this post Link to post
Staff 10488 Posted ... Hello! Can you please try with OpenVPN or OpenVPN GUI directly? The generator for the files you need is available in menu "Member Area"->"Access Without Our Client". After that, please send us again the OpenVPN logs and your configuration file. Kind regards Quote Share this post Link to post
latitude 0 Posted ... Ive been having this same exact problem with the same error codes. Interesting. Quote Share this post Link to post
dYu784jseDsJ 5 Posted ... I spent an hour fooling around yet couldn't get OpenVPN working directly. Can't test it over TOR until I figure out how to get it working directly. I think I was successful the last time I tried it, but this time it says connected, yet my connection remains direct. :dry: Quote Share this post Link to post
petersday 0 Posted ... I'm having the exact same problem. I'm running Vidalia Tor bundle, configured AirVpn to use SOCKS on 127.0.0.1 on 9050 I'm wondering if Openvpn uses a different version of the SOCKS protocol when communicating with Tor. As I have this message in the Tor logs: [sat 15. Dec 12:33:41 2012] Unknown SOCKS Protocol - One of your applications tried to establish a connection through Tor using a protocol that Tor does not understand. Please ensure you configure your applications to use only SOCKS4a or SOCKS5 with remote hostname resolution. I'll try and investigate further to see what version it uses by default - and get back to you if it is any different. Here are the logs for AirVPN 15/12/2012 - 14:57 AirVPN client version: 1.7 15/12/2012 - 14:57 Reading options from C:\Users\Kristin\AppData\Roaming\AirVPN\Air\1.0.0.0\AirVPN.xml 15/12/2012 - 14:57 OpenVPN bundle version: OpenVPN 2.2.2 15/12/2012 - 14:57 OpenVPN current version: OpenVPN 2.2.2 15/12/2012 - 14:57 Ready. 15/12/2012 - 14:57 Login... 15/12/2012 - 14:57 Login success. 15/12/2012 - 14:58 Contacting service... 15/12/2012 - 14:58 Connecting... 15/12/2012 - 14:58 OpenVPN 2.2.2 Win32-MSVC++ [sSL] [LZO2] [PKCS11] built on Dec 15 2011 15/12/2012 - 14:58 NOTE: OpenVPN 2.1 requires '--script-security 2' or higher to call user-defined scripts or executables 15/12/2012 - 14:58 LZO compression initialized 15/12/2012 - 14:58 Control Channel MTU parms [ L:1558 D:138 EF:38 EB:0 ET:0 EL:10 ] 15/12/2012 - 14:58 Socket Buffers: R=[8192->8192] S=[8192->8192] 15/12/2012 - 14:58 Data Channel MTU parms [ L:1558 D:1450 EF:58 EB:135 ET:0 EL:10 AF:3/1 ] 15/12/2012 - 14:58 Local Options hash (VER=V4): '22188c5b' 15/12/2012 - 14:58 Expected Remote Options hash (VER=V4): 'a8f55717' 15/12/2012 - 14:58 Attempting to establish TCP connection with 127.0.0.1:9050 15/12/2012 - 14:58 TCP connection established with 127.0.0.1:9050 15/12/2012 - 14:58 recv_socks_reply: Socks proxy returned bad reply 15/12/2012 - 14:58 TCP/UDP: Closing socket 15/12/2012 - 14:58 SIGTERM[soft,init_instance] received, process exiting 15/12/2012 - 14:58 Failed to start. Quote Share this post Link to post
petersday 0 Posted ... It's taken me a while, but I think I have it working, but could someone's advice to make sure. I had set up Comodo firewall following the guide on the forum, so that if the OpenVPN dies then all apps are blocked. However to get OpenVPN talking to TOR I had to allow access to port 443 otherwise I got the errors stated before. I've tried OpenVPN using the Openvpn gui on with configs for ports 53 and another for 443, and had TOR setup to allow 53 within it's allowed ports. But this too was only able to connect on 443. On the face of it the end point IP in TOR is the start point for the VPN, so it seems to be doing the right thing. However, what risks to me in terms of P2P by exposing port 443? I've a feeling there is a better way of doing this. Quote Share this post Link to post
bubblebobble 2 Posted ... Tor cannot forward UDP packets, only TCP. Check the mode tab to ensure TCP protocol is selected. Quote Share this post Link to post
