Ailurophobic
2.21.6 - Denylist additions not being saved
Hi, recently updated from beta to 2.21.6, and I'm finding that when I add countries to the denylist, on reboot they're back in the connection list. Was fine in previous versions. Anyone got any suggestions?
9 hours ago, OpenSourcerer said:
What is the way you close Eddie?
Normally, disconnect from server and then shut down computer. Sometimes I'll shut down eddie before shutting down the pc. Occasionally Windows complains about eddie still running, not always though (something that has also started happening since updating to latest).
Shut down Eddie first to give it a chance to save changed settings, then shutdown Windows.
i’m having the same issue on macOS. i always quit eddie manually, but my denylist is never saved.
Yes, this problem was reported on 2.21.6, as the OP correctly specified. Do you still experience this problem on 2.21.8 and/or 2.23.2?
