milkaca 1 Posted ... Hi, I am using Hummingbird v1.2.0 on my Debian 11 machine and start it with this command:sudo ./hummingbird --ignore-dns-push --network-lock on your_openvpn_file.ovpn Recently I installed Docker and added Home Assistant OS (hassio) and Portainer containers. When I start the VPN by running the above command, my Home Assistant container is not having Internet connection any longer and Portainer web UI is not even accessible. If I disable network lock by setting it to off it all works fine. Can someone please explain why my docker cannot use VPN connection to access the Internet when using Network lock, are there any rules I need to add in addition to allow it? Thank you in advance. Quote Share this post Link to post
fHzpCOkf 0 Posted ... I have the same issue. Did you ever come across a solution? Quote Share this post Link to post
Shack 0 Posted ... Have the same problem with Debian 12.10 and Eddie V2.24.6 When you enable AirVPN, it will move /etc/resolv.conf and replaces it with it's own. It does this also without Network Log. If you use AirVPN without Network Log, after disabling AirVPN, it will not revert this file, so wenn disabling, Docker will still not work. /etc/resolv.conf AirVPN on: nameserver 10.128.0.1 nameserver fd7d:76ee:e68f:a993::1 AirVPN off: nameserver 9.9.9.9 nameserver 149.112.112.112 I'm still troubleshooting how I can get Docker run with AirVPN, so that Docker containers get an internet connection. Quote Share this post Link to post
Staff 10510 Posted ... 9 hours ago, Shack said: When you enable AirVPN, it will move /etc/resolv.conf and replaces it with it's own. It does this also without Network Log. Hello! Please note that this feature, which is mandatory to query VPN DNS, is opt-out. In Eddie's "Preferences" > "DNS" window you can configure your own DNS and tell Eddie not to check DNS. 9 hours ago, Shack said: If you use AirVPN without Network Log, after disabling AirVPN, it will not revert this file It will, it restores the previous one. If that doesn't happen something weird is going on (a bug?), feel free to open a ticket. 9 hours ago, Shack said: I'm still troubleshooting how I can get Docker run with AirVPN Maybe this info can be useful: consider that GlueTun supports AirVPN out of the box and offers a good level of integration with countries, locations, specific servers and inbound remote port forwarding. https://github.com/qdm12/gluetun-wiki/blob/main/setup/providers/airvpn.md Kind regards Quote Share this post Link to post
