Indigo35
Unable to connect -- please help
I signed up for a one month service and I can't get it working. I"m on a Mac, using TunnelBlick. I imported the config files, it tries to connect then just refuses. Says my password is wrong?
It doesn't prompt me to enter a password -- I thought the generator page on the website exported all of this?
Here is my log. Can someone please help me?
Thank you.
2012-10-20 17:19:52 *Tunnelblick: OS X 10.8.2; Tunnelblick 3.2.8 (build 2891.3099)
2012-10-20 17:19:52 *Tunnelblick: Attempting connection with AirVPN US Sirius - UDP 443; Set nameserver = 1; monitoring connection
2012-10-20 17:19:52 *Tunnelblick: /Applications/Tunnelblick.app/Contents/Resources/openvpnstart start AirVPN\ US\ Sirius\ -\ UDP\ 443.ovpn 1337 1 0 0 0 49 -atDASNGWrdasngw
2012-10-20 17:19:52 *Tunnelblick: openvpnstart: /Applications/Tunnelblick.app/Contents/Resources/openvpn/openvpn-2.2.1/openvpn --cd /Users/daniel/Library/Application Support/Tunnelblick/Configurations --daemon --management 127.0.0.1 1337 --config /Users/daniel/Library/Application Support/Tunnelblick/Configurations/AirVPN US Sirius - UDP 443.ovpn --log /Library/Application Support/Tunnelblick/Logs/-SUsers-Sdaniel-SLibrary-SApplication Support-STunnelblick-SConfigurations-SAirVPN US Sirius -- UDP 443.ovpn.1_0_0_0_49.1337.openvpn.log --management-query-passwords --management-hold --script-security 2 --up /Applications/Tunnelblick.app/Contents/Resources/client.up.tunnelblick.sh -m -w -d -atDASNGWrdasngw --down /Applications/Tunnelblick.app/Contents/Resources/client.down.tunnelblick.sh -m -w -d -atDASNGWrdasngw --up-restart
2012-10-20 17:19:53 *Tunnelblick: openvpnstart message: Loading tun.kext
2012-10-20 17:19:53 *Tunnelblick: Established communication with OpenVPN
2012-10-20 17:19:53 OpenVPN 2.2.1 i386-apple-darwin10.8.0 [sSL] [LZO2] [PKCS11] [eurephia] built on Aug 10 2012
2012-10-20 17:19:53 MANAGEMENT: TCP Socket listening on 127.0.0.1:1337
2012-10-20 17:19:53 Need hold release from management interface, waiting...
2012-10-20 17:19:53 MANAGEMENT: Client connected from 127.0.0.1:1337
2012-10-20 17:19:53 MANAGEMENT: CMD 'pid'
2012-10-20 17:19:53 MANAGEMENT: CMD 'state on'
2012-10-20 17:19:53 MANAGEMENT: CMD 'state'
2012-10-20 17:19:53 MANAGEMENT: CMD 'hold release'
2012-10-20 17:19:53 NOTE: the current --script-security setting may allow this configuration to call user-defined scripts
2012-10-20 17:19:53 LZO compression initialized
2012-10-20 17:19:53 Control Channel MTU parms [ L:1558 D:138 EF:38 EB:0 ET:0 EL:0 ]
2012-10-20 17:19:53 Socket Buffers: R=[196724->65536] S=[9216->65536]
2012-10-20 17:19:53 Data Channel MTU parms [ L:1558 D:1450 EF:58 EB:135 ET:0 EL:0 AF:3/1 ]
2012-10-20 17:19:53 Local Options hash (VER=V4): '22188c5b'
2012-10-20 17:19:53 Expected Remote Options hash (VER=V4): 'a8f55717'
2012-10-20 17:19:53 UDPv4 link local: [undef]
2012-10-20 17:19:53 UDPv4 link remote: 108.59.8.147:443
2012-10-20 17:19:53 MANAGEMENT: >STATE:1350767993,WAIT,,,
2012-10-20 17:19:53 MANAGEMENT: >STATE:1350767993,AUTH,,,
2012-10-20 17:19:53 TLS: Initial packet from 108.59.8.147:443, sid=a00166f7 ddb7956f
2012-10-20 17:19:53 VERIFY OK: depth=1, /C=IT/ST=IT/L=Perugia/O=airvpn.org/CN=airvpn.org_CA/emailAddress=info@airvpn.org
2012-10-20 17:19:53 VERIFY OK: nsCertType=SERVER
2012-10-20 17:19:53 VERIFY OK: depth=0, /C=IT/ST=IT/L=Perugia/O=airvpn.org/CN=server/emailAddress=info@airvpn.org
2012-10-20 17:19:56 Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
2012-10-20 17:19:56 Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
2012-10-20 17:19:56 Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
2012-10-20 17:19:56 Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
2012-10-20 17:19:56 Control Channel: TLSv1, cipher TLSv1/SSLv3 DHE-RSA-AES256-SHA, 2048 bit RSA
2012-10-20 17:19:56 [server] Peer Connection Initiated with 108.59.8.147:443
2012-10-20 17:19:57 MANAGEMENT: >STATE:1350767997,GET_CONFIG,,,
2012-10-20 17:19:58 SENT CONTROL [server]: 'PUSH_REQUEST' (status=1)
2012-10-20 17:19:58 PUSH: Received control message: 'PUSH_REPLY,redirect-gateway def1,dhcp-option DNS 10.4.0.1,comp-lzo no,route 10.4.0.1,topology net30,ping 10,ping-restart 120,ifconfig 10.4.0.14 10.4.0.13'
2012-10-20 17:19:58 OPTIONS IMPORT: timers and/or timeouts modified
2012-10-20 17:19:58 OPTIONS IMPORT: LZO parms modified
2012-10-20 17:19:58 OPTIONS IMPORT: --ifconfig/up options modified
2012-10-20 17:19:58 OPTIONS IMPORT: route options modified
2012-10-20 17:19:58 OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified
2012-10-20 17:19:58 ROUTE default_gateway=192.168.1.1
2012-10-20 17:19:58 TUN/TAP device /dev/tun0 opened
2012-10-20 17:19:58 MANAGEMENT: >STATE:1350767998,ASSIGN_IP,,10.4.0.14,
2012-10-20 17:19:58 /sbin/ifconfig tun0 delete
ifconfig: ioctl (SIOCDIFADDR): Can't assign requested address
2012-10-20 17:19:58 NOTE: Tried to delete pre-existing tun/tap instance -- No Problem if failure
2012-10-20 17:19:58 /sbin/ifconfig tun0 10.4.0.14 10.4.0.13 mtu 1500 netmask 255.255.255.255 up
2012-10-20 17:19:58 /Applications/Tunnelblick.app/Contents/Resources/client.up.tunnelblick.sh -m -w -d -atDASNGWrdasngw tun0 1500 1558 10.4.0.14 10.4.0.13 init
No such key
2012-10-20 17:20:00 *Tunnelblick: Flushed the DNS cache
2012-10-20 17:20:00 /sbin/route add -net 108.59.8.147 192.168.1.1 255.255.255.255
add net 108.59.8.147: gateway 192.168.1.1
2012-10-20 17:20:00 /sbin/route add -net 0.0.0.0 10.4.0.13 128.0.0.0
add net 0.0.0.0: gateway 10.4.0.13
2012-10-20 17:20:00 /sbin/route add -net 128.0.0.0 10.4.0.13 128.0.0.0
add net 128.0.0.0: gateway 10.4.0.13
2012-10-20 17:20:00 MANAGEMENT: >STATE:1350768000,ADD_ROUTES,,,
2012-10-20 17:20:00 /sbin/route add -net 10.4.0.1 10.4.0.13 255.255.255.255
add net 10.4.0.1: gateway 10.4.0.13
2012-10-20 17:20:00 Initialization Sequence Completed
2012-10-20 17:20:00 MANAGEMENT: >STATE:1350768000,CONNECTED,SUCCESS,10.4.0.14,108.59.8.147
2012-10-20 17:20:00 *Tunnelblick client.up.tunnelblick.sh: Retrieved name server(s) [ 10.4.0.1 ] and WINS server(s) [ ] and using default domain name [ openvpn ]
2012-10-20 17:20:00 *Tunnelblick client.up.tunnelblick.sh: Up to two 'No such key' warnings are normal and may be ignored
2012-10-20 17:20:00 *Tunnelblick client.up.tunnelblick.sh: Saved the DNS and WINS configurations for later use
2012-10-20 17:20:00 *Tunnelblick client.up.tunnelblick.sh: Set up to monitor system configuration with process-network-changes
2012-10-20 17:20:06 *Tunnelblick process-network-changes: ServerAddresses changed from
* to (pre-VPN)
* <array> {
* 0 : 192.168.1.1
2012-10-20 17:20:06 *Tunnelblick process-network-changes: SearchDomains changed from
* to
* <array> {
* 0 : openvpn
* pre-VPN was
2012-10-20 17:20:06 *Tunnelblick process-network-changes: DomainName changed from
* openvpn
* to (pre-VPN)
* hsd1.pa.comcast.net
2012-10-20 17:20:06 *Tunnelblick process-network-changes: SearchDomains changed; sending USR1 to OpenVPN (process ID 21301) to restart the connection.
2012-10-20 17:20:07 event_wait : Interrupted system call (code=4)
2012-10-20 17:20:07 TCP/UDP: Closing socket
2012-10-20 17:20:07 /sbin/route delete -net 10.4.0.1 10.4.0.13 255.255.255.255
delete net 10.4.0.1: gateway 10.4.0.13
2012-10-20 17:20:07 /sbin/route delete -net 108.59.8.147 192.168.1.1 255.255.255.255
delete net 108.59.8.147: gateway 192.168.1.1
2012-10-20 17:20:07 /sbin/route delete -net 0.0.0.0 10.4.0.13 128.0.0.0
delete net 0.0.0.0: gateway 10.4.0.13
2012-10-20 17:20:07 /sbin/route delete -net 128.0.0.0 10.4.0.13 128.0.0.0
delete net 128.0.0.0: gateway 10.4.0.13
2012-10-20 17:20:07 Closing TUN/TAP interface
2012-10-20 17:20:07 /Applications/Tunnelblick.app/Contents/Resources/client.down.tunnelblick.sh -m -w -d -atDASNGWrdasngw tun0 1500 1558 10.4.0.14 10.4.0.13 init
2012-10-20 17:20:07 SIGUSR1[hard,] received, process restarting
2012-10-20 17:20:07 MANAGEMENT: >STATE:1350768007,RECONNECTING,SIGUSR1,,
2012-10-20 17:20:07 *Tunnelblick client.down.tunnelblick.sh: Cancelled monitoring of system configuration changes
2012-10-20 17:20:07 *Tunnelblick client.down.tunnelblick.sh: Restored the DNS and WINS configurations
2012-10-20 17:20:08 MANAGEMENT: CMD 'hold release'
2012-10-20 17:20:08 NOTE: the current --script-security setting may allow this configuration to call user-defined scripts
2012-10-20 17:20:08 LZO compression initialized
2012-10-20 17:20:08 Control Channel MTU parms [ L:1558 D:138 EF:38 EB:0 ET:0 EL:0 ]
2012-10-20 17:20:08 Socket Buffers: R=[196724->65536] S=[9216->65536]
2012-10-20 17:20:08 Data Channel MTU parms [ L:1558 D:1450 EF:58 EB:135 ET:0 EL:0 AF:3/1 ]
2012-10-20 17:20:08 Local Options hash (VER=V4): '22188c5b'
2012-10-20 17:20:08 Expected Remote Options hash (VER=V4): 'a8f55717'
2012-10-20 17:20:08 UDPv4 link local: [undef]
2012-10-20 17:20:08 UDPv4 link remote: 108.59.8.147:443
2012-10-20 17:20:08 MANAGEMENT: >STATE:1350768008,WAIT,,,
2012-10-20 17:20:08 MANAGEMENT: >STATE:1350768008,AUTH,,,
2012-10-20 17:20:08 TLS: Initial packet from 108.59.8.147:443, sid=70f0d1ec 4aacb955
2012-10-20 17:20:09 VERIFY OK: depth=1, /C=IT/ST=IT/L=Perugia/O=airvpn.org/CN=airvpn.org_CA/emailAddress=info@airvpn.org
2012-10-20 17:20:09 VERIFY OK: nsCertType=SERVER
2012-10-20 17:20:09 VERIFY OK: depth=0, /C=IT/ST=IT/L=Perugia/O=airvpn.org/CN=server/emailAddress=info@airvpn.org
2012-10-20 17:20:09 Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
2012-10-20 17:20:09 Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
2012-10-20 17:20:09 Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
2012-10-20 17:20:09 Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
2012-10-20 17:20:09 Control Channel: TLSv1, cipher TLSv1/SSLv3 DHE-RSA-AES256-SHA, 2048 bit RSA
2012-10-20 17:20:09 [server] Peer Connection Initiated with 108.59.8.147:443
2012-10-20 17:20:11 MANAGEMENT: >STATE:1350768011,GET_CONFIG,,,
2012-10-20 17:20:12 SENT CONTROL [server]: 'PUSH_REQUEST' (status=1)
2012-10-20 17:20:12 AUTH: Received AUTH_FAILED control message
2012-10-20 17:20:12 SIGTERM received, sending exit notification to peer
2012-10-20 17:20:14 *Tunnelblick: Disconnecting; user cancelled authorization or there was an error obtaining authorization
2012-10-20 17:20:14 *Tunnelblick: Flushed the DNS cache
2012-10-20 17:20:14 event_wait : Interrupted system call (code=4)
2012-10-20 17:20:14 TCP/UDP: Closing socket
2012-10-20 17:20:14 SIGTERM[hard,] received, process exiting
2012-10-20 17:20:14 MANAGEMENT: >STATE:1350768014,EXITING,SIGTERM,,
Thank you.
Tunnelblick 3.2.8 is not compatible with Mac OS X 10.8.2. Please upgrade to the appropriate release (at the time of writing 3.3beta21a):
http://code.google.com/p/tunnelblick/wiki/DownloadsEntry?tm=2
Sorry about using the wrong version. After using the beta of TB, I'm able to connect just fine.
Now, another issue I'm having is that when connected to the VPN, it fails a DNS leak test.
Any suggestions? MUCH appreciated
Fine, we're very glad to know it.
Any suggestions? MUCH appreciated :)
You can force on your network cards 10.4.0.1 as primary DNS, see also https://airvpn.org/specs
Furthermore, you might like to secure your connection against leaks in case of unexpected VPN disconnection:
https://airvpn.org/index.php?option=com_kunena&func=view&catid=3&id=1713&limit=6&limitstart=36&Itemid=142#2532
I'm not sure I understand how to do either of those two things.
About changing DNS servers:
http://www.plus.net/support/software/dns/changing_dns_mac.shtml
About setting up rules for pf (an OpenBSD very powerful packet filtering tool and firewall): just follow the linked guide and do not hesitate to contact us if you get stuck at some step. pf is already installed by default on your OS X version.
