r34lity23
iptables & bluetit
Hi all,
I am trying to setup a VM to block all internet that is not tunnelled through the VPN. I have the following iptables rules:
-P INPUT DROP
-P FORWARD DROP
-P OUTPUT DROP
-N logging
-A INPUT -i lo -j ACCEPT
-A INPUT -s 255.255.255.255/32 -j ACCEPT
-A INPUT -s 192.168.1.0/24 -d 192.168.1.0/24 -j ACCEPT
-A INPUT -m state --state RELATED,ESTABLISHED -j ACCEPT
-A INPUT -i tun+ -j ACCEPT
-A INPUT -j DROP
-A INPUT -j logging
-A FORWARD -i tun+ -j ACCEPT
-A FORWARD -o tun+ -j ACCEPT
-A FORWARD -j DROP
-A OUTPUT -p udp -m udp --dport 443 -m comment --comment "Allow VPN connection" -j ACCEPT
-A OUTPUT -o lo -j ACCEPT
-A OUTPUT -d 255.255.255.255/32 -j ACCEPT
-A OUTPUT -s 192.168.1.0/24 -d 192.168.1.0/24 -j ACCEPT
-A OUTPUT -o tun+ -j ACCEPT
-A OUTPUT -j DROP
-A OUTPUT -j logging
-A logging -m limit --limit 2/min -j LOG --log-prefix "IPTables general: " --log-level 7
-A logging -j DROP
This seems to work fine if enabled after the VPN has already connected but appears to block the VPN from connecting if it has dropped for some reason. I was hoping that someone more knowledgeable about iptables could see a reason for it being unable to connect. The output from bluetit is as follows:
Jan 19 18:50:03 vpn1 bluetit[18500]: IPv6 is available in this system
Jan 19 18:50:03 vpn1 bluetit[18500]: System country set to XX by Bluetit policy.
Jan 19 18:50:03 vpn1 bluetit[18500]: Bluetit successfully initialized and ready
Jan 19 18:50:03 vpn1 bluetit[18500]: Starting AirVPN boot connection
Jan 19 18:50:03 vpn1 bluetit[18500]: Waiting for a valid AirVPN Manifest to be available
Jan 19 18:50:03 vpn1 bluetit[18500]: AirVPN Manifest updater thread started
Jan 19 18:50:03 vpn1 bluetit[18500]: AirVPN Manifest update interval is 15 minutes
Jan 19 18:50:03 vpn1 bluetit[18500]: Updating AirVPN Manifest
Jan 19 18:50:23 vpn1 bluetit[18500]: ERROR: Cannot start AirVPN Connection. AirVPN Manifest not available.
Jan 19 18:51:03 vpn1 bluetit[18500]: AirVPN Manifest successfully retrieved from local instance
Thanks for any help!
