mrbert
How can I test my DNS performance for 10.4.0.1
Hi I have the VPN client activated in my asus RT-AC86U router with merlin firmware.
The client is running and IPleak does not show leaks and actually only the Airvpn dns.
I entert 194.36.144.87 as secndaruy DNS
Now quite ofthen I observe quite a delay when opening websites sometime a few seconds.
It lookt like there is some timeout before the page loads
Could this be a problem with the airvpn dns?. How could I check this
I tried pinging  10.4.0.1 from PC but then I get time out.
Dead giveaway. ;) Are you sure you are truly connected? Check ipleak.net for this.
@staff OK so that is why the ping is dead.
But How can I test if it works? Is there a working solution for testing this performance?
Without the VPN actvated the websites seem to start loading much quicker.
And just tested with the 2nd PC where I enterend that this PC does connect via WAN
Some websites do not open on my first PC but open normally on the 2nd PC
What I also observe is that when I add an other 2nd DNS is that some of those pages open much faster without noticable delay
When I enter two time the same DNS address the client can not connect anymore.
As I wrote in my post I checked with IPleak
Yes, overlooked that.
Did you enable DNS filter lists by any chance?
no I do not have anything blocked. No deed to do so and did not even know this is possible
@staff
I even cannot acces my own bank website when I do not add 8.8.8.8 as 2nd dnd. Not verry private when my DNS request goes straigt to google?
@mrbert
Unfortunately we don't understand the issue, therefore we recommend you open a ticket. About your last question, the DNS query should be tunneled so it should not go straight to Google, but anyway make sure that Network Lock is enabled. Anyway, you should not pick Google DNS in any case. Good DNS which respect your privacy are OpenNIC https://www.opennic.org and Quad9 (9.9.9.9).
