ghostp
UDP connection with AirVPN fail
I can't connect to Air server through UDP. I tried every variant of available UDP connection in Eddie (Netherlands and Norway) but Eddie stop at "checking route iP4....".  I also generated bunch of ovpn files with UDP (3 and 4 Entry) to run straight in OpenVPN. The connection is being established successfully but I can't open any website. I add curl.exe into fw rules, no success. I also disabled Windows defender + Firewall, same result. As a final step I've rented my own vps server and installed OpenVPN on it and I'm able to successfully establish a UDP connection and visit any website, everything work perfect!
I'm out of ideas why the same doesn't work with Air servers. Maybe someone from here has an idea?
Close Eddie if still opened and reopen. Try a connection and let the error happen, then in Logs tab click the lifebelt icon on the right side of the logs and upload/paste the output here.
Thank you for your quick response. I'm attaching the report below. I hope you'll find a solution for my problem.
report.txt
@ghostp
Can you please test the following connection mode:
  • protocol TCP
  • port 443
  • entry-IP address THREE
and check whether the problem remains the same or not?
You can change connection mode in Eddie "Preferences" > "Protocols" window: uncheck "Automatic", select the proper line (it will be highlighted) and click "Save".
5 hours ago, Staff said:
@ghostp
  • protocol TCP
  • port 443
TCP connections works perfect, all servers, all ports and all entry-IP adresses, was never an issue. Only UDP connections fail. But with OpenVPN I'm able to connct with UDP but can't open any website.
I wish you all happy new year!
Try running a command prompt as admin:
netstat -an | find "UDP" | more
If nothing shows as open, then it's possible UDP ports are being blocked either by your ISP or by a firewall somewhere. Use TCP when connecting to AirDNS servers on that computer.  That's the solution to your problem; there's nothing wrong with using TCP instead of UDP. I have one PC (behind a university firewall) that has to use TCP.
