Guest Posted ... Hi AirPVN team, I wonder when we can expect a stable Eddie client for Wireguard? The recent beta is leaking memory every now and then, and with Wireguard's own client I cannot block traffic outside the tunnel because I am dependent on iSCSI running local.. Quote Share this post Link to post
Staff 10491 Posted ... @Karmatron Hello and thank you for your tests! Bug causing memory leaks was found out and fixed. Memory leaks should not occur anymore in Eddie 2.21.3 (available since a few days ago) according to thorough tests, can you please test too? Keep us posted in the main thread! You can expect a stable release when all reported bugs have been solved and no new bugs emerge in a given time frame decided by the developer. As you can see, the latest version is much closer to a stable release. Kind regards Quote Share this post Link to post
Guest Posted ... Will do, keep you posted! 1 Staff reacted to this Quote Share this post Link to post
Guest Posted ... No more memory leaks on my side. 1 Staff reacted to this Quote Share this post Link to post
gougou 0 Posted ... (edited) i will test too if you agree on macOS 11.6 Edited ... by gougou Quote Share this post Link to post
