XV-8774 0 Posted ... Hello I have the same problem as jayinwww. I have tried some non-default settings in Eddie but with no effect. Do you have any idea how to solve this issue? Here is my log: Quote Eddie for Android 2.4 Version Code 26 --- App and device information --- Eddie Version Code: 26 Eddie Version Name: 2.4 Eddie Library 1.3.2 - 22 March 2019 Eddie Library API level: 6 Architecture: armeabi-v7a (Arm 32 bit) Platform: Android Manufacturer: samsung Model: SM-J600FN Device: j6lte Board: exynos7870 Brand: samsung Product: j6ltexx Hardware: samsungexynos7870 Supported ABIs: armeabi-v7a armeabi Host: SWDH2810 ID: QP1A.190711.020 Display: QP1A.190711.020.J600FNXXUACUD1 Android API Level: 29 Android Codename: REL Android Version Release: 10 Android Version Incremental: J600FNXXUACUD1 Fingerprint: samsung/j6ltexx/j6lte:10/QP1A.190711.020/J600FNXXUACUD1:user/release-keys Type: user Tags: release-keys User: dpi Language: pl Rooted device: false Network: MOBILE Screen Width: 720 Screen Height: 1384 Screen Density: 2 Screen Density DPI: 320 Screen XDPI: 295 Screen YDPI: 294 Total RAM: 2811 Mb Free RAM: 877 Mb Threshold Memory: 97 Mb Low Memory: false App Total Memory: 13 Mb App Max Memory: 192 Mb App Free Memory: 6 Mb Bootloader: J600FNXXUACUD1 --- Settings dump --- airvpn_default_protocol: UDP airvpn_protocol: UDP airvpn_default_port: 443 airvpn_port: 443 airvpn_default_ip_version: IPv4 airvpn_ip_version: IPv4 airvpn_default_tls_mode: tls-crypt airvpn_tls_mode: tls-crypt airvpn_quick_connect_mode: auto airvpn_cipher: SERVER airvpn_forbid_quick_connection_to_user_country: true airvpn_custom_bootstrap_servers: airvpn_server_whitelist: airvpn_server_blacklist: airvpn_country_whitelist: airvpn_country_blacklist: system_vpn_lock: true system_vpn_reconnect: false system_vpn_reconnect_retries: 5 system_dns_override_enable: false system_dns_custom: system_proxy_enable: false system_persistent_notification: true system_notification_sound: true system_show_message_dialogs: true system_forced_mtu: system_application_filter_type: 0 system_application_filter: system_application_language: system_first_run: true system_restore_last_profile: true system_last_profile_is_connected: false system_exclude_local_networks: false system_pause_vpn_when_screen_is_off: true system_airvpn_remember_me: true ovpn3_tls_version_min: tls_1_0 ovpn3_protocol: tcp ovpn3_ipv6: ovpn3_timeout: 60 ovpn3_tun_persist: true ovpn3_compression_mode: yes ovpn3_synchronous_dns_lookup: false ovpn3_autologin_sessions: true ovpn3_disable_client_cert: false ovpn3_ssl_debug_level: 0 ovpn3_default_key_direction: -1 ovpn3_force_aes_cbc_ciphersuites: false ovpn3_tls_cert_profile: ovpn3_proxy_host: ovpn3_proxy_port: ovpn3_proxy_allow_cleartext_auth: false ovpn3_custom_directives: --- Log dump --- 17 lis 2021 19:58:22 UTC [Info] Eddie Version Code: 26 17 lis 2021 19:58:22 UTC [Info] Eddie Version Name: 2.4 17 lis 2021 19:58:22 UTC [Info] Initializing Eddie library 17 lis 2021 19:58:22 UTC [Info] Eddie Library 1.3.2 - 22 March 2019 17 lis 2021 19:58:22 UTC [Info] Eddie Library API level: 6 17 lis 2021 19:58:22 UTC [Info] Architecture: armeabi-v7a (Arm 32 bit) 17 lis 2021 19:58:22 UTC [Info] Platform: Android 17 lis 2021 19:58:22 UTC [Info] Manufacturer: samsung 17 lis 2021 19:58:22 UTC [Info] Model: SM-J600FN 17 lis 2021 19:58:22 UTC [Info] Device: j6lte 17 lis 2021 19:58:22 UTC [Info] Brand: samsung 17 lis 2021 19:58:22 UTC [Info] Product: j6ltexx 17 lis 2021 19:58:22 UTC [Info] Display: QP1A.190711.020.J600FNXXUACUD1 17 lis 2021 19:58:22 UTC [Info] Android API Level: 29 17 lis 2021 19:58:22 UTC [Info] Android Version Release: 10 17 lis 2021 19:58:22 UTC [Info] Fingerprint: samsung/j6ltexx/j6lte:10/QP1A.190711.020/J600FNXXUACUD1:user/release-keys 17 lis 2021 19:58:22 UTC [Info] Tags: release-keys 17 lis 2021 19:58:22 UTC [Info] Rooted device: false 17 lis 2021 19:58:22 UTC [Info] Eddie Library: OpenVPN initialization succeeded 17 lis 2021 19:58:22 UTC [Info] Requesting user IP and country to AirVPN ipleak.net via secure connection 17 lis 2021 19:58:22 UTC [Info] Setting manifest to default instance 17 lis 2021 19:58:22 UTC [Info] AirVPN ipleak.net: User IP is 2a00:f41:c33:1290:b9ac:97d0:ffa2:41de 17 lis 2021 19:58:22 UTC [Info] AirVPN ipleak.net: User country is PL 17 lis 2021 19:58:22 UTC [Info] Requesting user IP and country to AirVPN ipleak.net via secure connection 17 lis 2021 19:58:22 UTC [Info] AirVPN ipleak.net: User IP is 2a00:f41:c33:1290:b9ac:97d0:ffa2:41de 17 lis 2021 19:58:22 UTC [Info] AirVPN ipleak.net: User country is PL 17 lis 2021 19:58:23 UTC [Info] Requesting manifest document to AirVPN 17 lis 2021 19:58:25 UTC [Info] Successfully received manifest document from AirVPN 17 lis 2021 19:58:25 UTC [Info] Setting manifest to the instance downloaded from AirVPN server 17 lis 2021 19:58:49 UTC [Info] Requesting user document to AirVPN 17 lis 2021 19:58:50 UTC [Info] Successfully received user document from AirVPN 17 lis 2021 19:58:50 UTC [Info] Requesting user document to AirVPN 17 lis 2021 19:58:50 UTC [Info] Setting user profile to the instance downloaded from AirVPN server 17 lis 2021 19:58:50 UTC [Info] Logged in to AirVPN as user services899@protonmail.com 17 lis 2021 19:58:50 UTC [Info] Successfully received user document from AirVPN 17 lis 2021 19:58:50 UTC [Info] Requesting manifest document to AirVPN 17 lis 2021 19:58:50 UTC [Info] Setting user profile to the instance downloaded from AirVPN server 17 lis 2021 19:58:50 UTC [Info] Logged in to AirVPN as user services899@protonmail.com 17 lis 2021 19:58:53 UTC [Info] Successfully received manifest document from AirVPN 17 lis 2021 19:58:53 UTC [Info] Requesting manifest document to AirVPN 17 lis 2021 19:58:53 UTC [Info] Setting manifest to the instance downloaded from AirVPN server 17 lis 2021 19:58:56 UTC [Info] Trying to quick connect AirVPN server Aspidiske at Alblasserdam, Netherlands - Protocol UDP, Port 443 17 lis 2021 19:58:56 UTC [Info] VPN Lock is enabled 17 lis 2021 19:58:56 UTC [Info] Local networks are tunneled into the VPN 17 lis 2021 19:58:56 UTC [Info] Network is connected to MOBILE internetipv6 (LTE) 17 lis 2021 19:58:56 UTC [Debug] VPNService.networkStatusChanged() action: 'SYSTEM_RESUME' 17 lis 2021 19:58:56 UTC [Info] Eddie Library: Successfully created a new OpenVPN client 17 lis 2021 19:58:56 UTC [Info] Eddie Library: OpenVPN client: option 'tls_version_min' set to 'tls_1_0' 17 lis 2021 19:58:56 UTC [Info] Eddie Library: OpenVPN client: option 'protocol' set to 'tcp' 17 lis 2021 19:58:56 UTC [Info] Eddie Library: OpenVPN client: option 'ipv6' set to '' 17 lis 2021 19:58:56 UTC [Info] Eddie Library: OpenVPN client: option 'timeout' set to '60' 17 lis 2021 19:58:56 UTC [Info] Eddie Library: OpenVPN client: option 'tun_persist' set to 'true' 17 lis 2021 19:58:56 UTC [Info] Eddie Library: OpenVPN client: option 'compression_mode' set to 'yes' 17 lis 2021 19:58:56 UTC [Info] Eddie Library: OpenVPN client: option 'synchronous_dns_lookup' set to 'false' 17 lis 2021 19:58:56 UTC [Info] Eddie Library: OpenVPN client: option 'autologin_sessions' set to 'true' 17 lis 2021 19:58:56 UTC [Info] Eddie Library: OpenVPN client: option 'disable_client_cert' set to 'false' 17 lis 2021 19:58:56 UTC [Info] Eddie Library: OpenVPN client: option 'ssl_debug_level' set to '0' 17 lis 2021 19:58:56 UTC [Info] Eddie Library: OpenVPN client: option 'default_key_direction' set to '-1' 17 lis 2021 19:58:56 UTC [Info] Eddie Library: OpenVPN client: option 'force_aes_cbc_ciphersuites' set to 'false' 17 lis 2021 19:58:56 UTC [Info] Eddie Library: OpenVPN client: option 'tls_cert_profile' set to '' 17 lis 2021 19:58:56 UTC [Info] Starting VPN thread 17 lis 2021 19:58:56 UTC [Info] Eddie Library: starting openVPNClient 17 lis 2021 19:58:56 UTC [Info] Eddie Library: Client::start(): Loading profile 17 lis 2021 19:58:56 UTC [Info] Eddie Library: config.protoOverride: tcp 17 lis 2021 19:58:56 UTC [Info] Eddie Library: config.connTimeout: 60 17 lis 2021 19:58:56 UTC [Info] Eddie Library: config.compressionMode: yes 17 lis 2021 19:58:56 UTC [Info] Eddie Library: config.ipv6: 17 lis 2021 19:58:56 UTC [Info] Eddie Library: config.tlsVersionMinOverride: tls_1_0 17 lis 2021 19:58:56 UTC [Info] Eddie Library: config.tlsCertProfileOverride: 17 lis 2021 19:58:56 UTC [Info] Eddie Library: config.disableClientCert: false 17 lis 2021 19:58:56 UTC [Info] Eddie Library: config.proxyHost: 17 lis 2021 19:58:56 UTC [Info] Eddie Library: config.proxyPort: 17 lis 2021 19:58:56 UTC [Info] Eddie Library: config.proxyAllowCleartextAuth: false 17 lis 2021 19:58:56 UTC [Info] Eddie Library: config.defaultKeyDirection: -1 17 lis 2021 19:58:56 UTC [Info] Eddie Library: config.forceAesCbcCiphersuites: false 17 lis 2021 19:58:56 UTC [Info] Eddie Library: config.sslDebugLevel: 0 17 lis 2021 19:58:56 UTC [Info] Eddie Library: config.autologinSessions: true 17 lis 2021 19:58:56 UTC [Info] Eddie Library: config.tunPersist: true 17 lis 2021 19:58:56 UTC [Info] Eddie Library: config.synchronousDnsLookup: false 17 lis 2021 19:58:56 UTC [Info] Eddie Library: Client::start(): Profile loaded. Connecting to server 17 lis 2021 19:58:56 UTC [Info] Eddie Library: OpenVPN core 3.3 AirVPN android armv7a thumb2 32-bit 17 lis 2021 19:58:56 UTC [Info] Eddie Library: connect_attach() 17 lis 2021 19:58:56 UTC [Debug] OpenVPNTunnel.onConnectAttach() 17 lis 2021 19:58:56 UTC [Info] Eddie Library: Frame=512/2048/512 mssfix-ctrl=1250 17 lis 2021 19:58:56 UTC [Debug] OpenVPN Event: type: 4, name: RESOLVE, info: 17 lis 2021 19:58:56 UTC [Info] Eddie Library: connect_pre_run() 17 lis 2021 19:58:56 UTC [Debug] OpenVPNTunnel.onConnectPreRun() 17 lis 2021 19:58:56 UTC [Info] Eddie Library: connect_run() 17 lis 2021 19:58:56 UTC [Info] Eddie Library: Contacting 134.19.179.197:443 via UDP 17 lis 2021 19:58:56 UTC [Debug] OpenVPN Event: type: 5, name: WAIT, info: 17 lis 2021 19:58:56 UTC [Info] Eddie Library: socket_protect(socket=78) 17 lis 2021 19:58:56 UTC [Debug] OpenVPNTunnel.onSocketProtect(socket: 78) 17 lis 2021 19:58:56 UTC [Info] Eddie Library: Connecting to [134.19.179.197]:443 (134.19.179.197) via UDPv4 17 lis 2021 19:58:56 UTC [Debug] OpenVPN Event: type: 7, name: CONNECTING, info: 17 lis 2021 19:58:56 UTC [Info] Eddie Library: Tunnel Options:V4,dev-type tun,link-mtu 1522,tun-mtu 1500,proto UDPv4,comp-lzo,cipher AES-256-GCM,auth SHA512,keysize 256,key-method 2,tls-client 17 lis 2021 19:58:56 UTC [Info] Eddie Library: Peer Info: IV_GUI_VER=Eddie Library 1.3.2 IV_VER=3.3 AirVPN IV_PLAT=android IV_NCP=2 IV_TCPNL=1 IV_PROTO=2 IV_LZO=1 IV_LZO_SWAP=1 IV_LZ4=1 IV_LZ4v2=1 IV_COMP_STUB=1 IV_COMP_STUBv2=1 IV_AUTO_SESS=1 17 lis 2021 19:58:56 UTC [Info] Eddie Library: VERIFY OK : depth=1 cert. version : 3 serial number : 8C:D8:43:EF:E4:5F:20:03 issuer name : C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org subject name : C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org issued on : 2021-10-06 11:54:48 expires on : 2121-09-12 11:54:48 signed using : RSA with SHA-512 RSA key size : 4096 bits basic constraints : CA=true 17 lis 2021 19:58:56 UTC [Info] Eddie Library: VERIFY OK : depth=0 cert. version : 3 serial number : 01:6E issuer name : C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org subject name : C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=Aspidiske, emailAddress=info@airvpn.org issued on : 2019-03-01 17:38:47 expires on : 2029-02-26 17:38:47 signed using : RSA with SHA-512 RSA key size : 4096 bits basic constraints : CA=false cert. type : SSL Server key usage : Digital Signature, Key Encipherment ext key usage : TLS Web Server Authentication 17 lis 2021 19:58:58 UTC [Info] Eddie Library: SSL Handshake: TLSv1.2/TLS-DHE-RSA-WITH-CHACHA20-POLY1305-SHA256 17 lis 2021 19:58:58 UTC [Info] Eddie Library: Session is ACTIVE 17 lis 2021 19:58:58 UTC [Debug] OpenVPN Event: type: 8, name: GET_CONFIG, info: 17 lis 2021 19:58:58 UTC [Info] Eddie Library: Sending PUSH_REQUEST to server... 17 lis 2021 19:58:58 UTC [Info] Eddie Library: OPTIONS: 0 [comp-lzo] [no] 1 [redirect-gateway] [ipv6] [def1] [bypass-dhcp] 2 [dhcp-option] [DNS] [10.33.146.1] 3 [dhcp-option] [DNS6] [fde6:7a:7d20:1d92::1] 4 [tun-ipv6] 5 [route-gateway] [10.33.146.1] 6 [topology] [subnet] 7 [ping] [10] 8 [ping-restart] [60] 9 [ifconfig-ipv6] [fde6:7a:7d20:1d92::1062/64] [fde6:7a:7d20:1d92::1] 10 [ifconfig] [10.33.146.100] [255.255.255.0] 11 [peer-id] [3] 12 [cipher] [AES-256-GCM] 17 lis 2021 19:58:58 UTC [Info] Eddie Library: PROTOCOL OPTIONS: cipher: AES-256-GCM digest: SHA512 ncp enabled: yes compress: LZO_STUB peer ID: 3 17 lis 2021 19:58:58 UTC [Info] Eddie Library: tun_builder_new() 17 lis 2021 19:58:58 UTC [Debug] OpenVPNTunnel.onTunBuilderNew() 17 lis 2021 19:58:58 UTC [Debug] OpenVPN Event: type: 9, name: ASSIGN_IP, info: 17 lis 2021 19:58:58 UTC [Info] Eddie Library: tun_builder_add_address(address=10.33.146.100, prefix_length=24, gateway=10.33.146.1, ipv6=false, net30=false) 17 lis 2021 19:58:58 UTC [Debug] OpenVPNTunnel.onTunBuilderAddAddress(address: 10.33.146.100, prefix_length: 24, gateway: 10.33.146.1, ipv6: false, net30: false) 17 lis 2021 19:58:58 UTC [Info] Eddie Library: tun_builder_add_address(address=fde6:7a:7d20:1d92::1062, prefix_length=64, gateway=fde6:7a:7d20:1d92::1, ipv6=true, net30=false) 17 lis 2021 19:58:58 UTC [Debug] OpenVPNTunnel.onTunBuilderAddAddress(address: fde6:7a:7d20:1d92::1062, prefix_length: 64, gateway: fde6:7a:7d20:1d92::1, ipv6: true, net30: false) 17 lis 2021 19:58:58 UTC [Info] Eddie Library: tun_builder_add_route(address=0.0.0.0, prefix_length=0, metric=-1, ipv6=false) 17 lis 2021 19:58:58 UTC [Debug] OpenVPNTunnel.onTunBuilderAddRoute(address: 0.0.0.0, prefix_length: 0, metric: -1, ipv6: false) 17 lis 2021 19:58:58 UTC [Info] Eddie Library: tun_builder_add_route(address=::, prefix_length=0, metric=-1, ipv6=true) 17 lis 2021 19:58:58 UTC [Debug] OpenVPNTunnel.onTunBuilderAddRoute(address: ::, prefix_length: 0, metric: -1, ipv6: true) 17 lis 2021 19:58:58 UTC [Info] Eddie Library: tun_builder_add_dns_server(address=10.33.146.1, ipv6=false) 17 lis 2021 19:58:58 UTC [Debug] OpenVPNTunnel.onTunBuilderAddDNSServer(address: 10.33.146.1, ipv6: false) 17 lis 2021 19:58:58 UTC [Debug] VPNContext.doAddDNS(): Adding DNS server '10.33.146.1' 17 lis 2021 19:58:58 UTC [Info] Eddie Library: tun_builder_add_dns_server(address=fde6:7a:7d20:1d92::1, ipv6=true) 17 lis 2021 19:58:58 UTC [Debug] OpenVPNTunnel.onTunBuilderAddDNSServer(address: fde6:7a:7d20:1d92::1, ipv6: true) 17 lis 2021 19:58:58 UTC [Debug] VPNContext.doAddDNS(): Adding DNS server 'fde6:7a:7d20:1d92::1' 17 lis 2021 19:58:58 UTC [Info] Eddie Library: tun_builder_set_block_ipv6(block_ipv6=false) 17 lis 2021 19:58:58 UTC [Debug] OpenVPNTunnel.onTunBuilderSetBlockIPV6(block_ipv6: false) 17 lis 2021 19:58:58 UTC [Info] Eddie Library: tun_builder_set_remote_address(address=134.19.179.197, ipv6=false) 17 lis 2021 19:58:58 UTC [Debug] OpenVPNTunnel.onTunBuilderSetRemoteAddress(address: 134.19.179.197, ipv6: false) 17 lis 2021 19:58:58 UTC [Info] Eddie Library: tun_builder_set_layer(layer=3) 17 lis 2021 19:58:58 UTC [Debug] OpenVPNTunnel.onTunBuilderSetLayer(layer: 3) 17 lis 2021 19:58:58 UTC [Info] Eddie Library: tun_builder_set_session_name(name=134.19.179.197) 17 lis 2021 19:58:58 UTC [Debug] OpenVPNTunnel.onTunBuilderSetSessionName(name: 134.19.179.197) 17 lis 2021 19:58:58 UTC [Info] Eddie Library: tun_builder_establish() 17 lis 2021 19:58:58 UTC [Debug] OpenVPNTunnel.onTunBuilderEstablish() 17 lis 2021 19:58:58 UTC [Info] Eddie Library: TunPersist: saving tun context: Session Name: 134.19.179.197 Layer: OSI_LAYER_3 Remote Address: 134.19.179.197 Tunnel Addresses: 10.33.146.100/24 -> 10.33.146.1 fde6:7a:7d20:1d92::1062/64 -> fde6:7a:7d20:1d92::1 [IPv6] Reroute Gateway: IPv4=1 IPv6=1 flags=[ ENABLE REROUTE_GW DEF1 BYPASS_DHCP IPv4 IPv6 ] Block IPv6: no Add Routes: Exclude Routes: DNS Servers: 10.33.146.1 fde6:7a:7d20:1d92::1 [IPv6] Search Domains: 17 lis 2021 19:58:58 UTC [Info] Eddie Library: Connected via tun 17 lis 2021 19:58:58 UTC [Info] Eddie Library: LZO init swap=0 asym=1 17 lis 2021 19:58:58 UTC [Info] Eddie Library: Comp-stub init swap=0 17 lis 2021 19:58:58 UTC [Info] CONNECTED to VPN (AirVPN server Aspidiske - Alblasserdam, Netherlands) Defined: 1 User: Server Host: 134.19.179.197 Server Port: 443 Server Protocol: UDPv4 Server IP: 134.19.179.197 VPN IPv4: 10.33.146.100 VPN IPv6: fde6:7a:7d20:1d92::1062 Gateway IPv4: 10.33.146.1 Gateway IPv6: fde6:7a:7d20:1d92::1 Tunnel Name: tun Quote Share this post Link to post
Tech Jedi Alex 1522 Posted ... @XV-8774 Don't be confused, I split your post from where you posted before. Please open your own topics for your own issues in the future because issues don't need to be "same". They can show similar symptoms but can have different causes. I don't see any problems in the log on first glance. I notice that your LTE provider is using v6 already, so it could be that v4 is provided with CG-NAT. Some people reported that it causes problems in the past. You could try the connection via IPv6 (Settings > AirVPN > Default IP version: IPv6). Since you're running Android 10, it could also be that DNS over HTTPS is enabled in Android's connection settings. Though this should theoretically be routed through the VPN, check if the problems still persist when you disable that. The setting should be called "Secure DNS" or similar. A few other recommendations because of the version: Settings > VPN > Disable VPN lock. A much better solution is Android's own VPN lock also found in the connection settings somewhere. Settings > System > Disable Pause VPN when screen is off. I don't know why this is still enabled by default, but it causes problems with connectivity everytime one turns off the screen and turns it on again. I'd go as far as calling this an anti-feature. Quote Hide Tech Jedi Alex's signature Hide all signatures NOT AN AIRVPN TEAM MEMBER. USE TICKETS FOR PROFESSIONAL SUPPORT. LZ1's New User Guide to AirVPN « Plenty of stuff for advanced users, too! Want to contact me directly? All relevant methods are on my About me page. Share this post Link to post
Staff 10421 Posted ... @XV-8774 Hello! We have detected the same problem on a few Samsung devices running Android 10 and 11. Although the cause of the lack of "traffic-through" is currently unknown, (and we don't know why only certain Samsung devices are affected) we verified that Eddie 2.5 alpha 3 resolves the problem. Please see here to download the apk (you need to uninstall Eddie 2.4 first, and then side-load Eddie 2.5 alpha 3):https://airvpn.org/forums/topic/49705-eddie-android-edition-25-alpha-is-available/ Eddie 2.5 beta 1 public availability is imminent, currently we are testing it internally. Please let us know whether Eddie 2.5 resolves the problem for you too. Kind regards 1 Tech Jedi Alex reacted to this Quote Share this post Link to post
