When starting Eddie yesterday instead I got a new Eddie asking me for log on details, sever details and my settings and "routes" had gone, so I had to redo all these. Hoping this is a one off but I wonder is there a way to back up Eddie's settings? Looks like "default profile" and "recovery.xml" are the only files that have changed since installation in the AirVPN directory where Eddie sits. Will copying these files back to the directory work should I need to restore my settings again? Thanks
@bestinshow
You're right, losing settings and data should not happen during upgrades, save for when you upgrade from Eddie versions older than 2.12 to the current version. It's therefore an unexpected event.
And yes, "default.profile" (or other files, if you entered new profiles with new names on the settings) is the file keeping all the data and settings.
