singh124
Port forwarding on 2 clients at the same time
Hello, I have 2 clients that I would like to both have port forwarding. On the port forwarding screen, both clients show up under both ports, but only 1 client is able to access both ports. Is there a way for me to bind a specific port to a specific client so they both get 1 port each?
You can use all ports from every and each connection slot provided that you make sure that each connection ends up to a different VPN server, i.e. you must not connect more than one device to the same VPN server.
