hardknox 0 Posted ... (edited) I have a little HP T620 thinclient that I'm using to connect to AirVPN via Linux CLI and it's not getting great speed. I'm getting a max of ~140 mbps on average. I was wondering if anyone had any suggestions on how to improve speeds on this machine? I suspect the CPU may be limiting speeds, though it does support AES-NI, which is why I thought it would work well. Thanks bluetit.rc: # bootserver <ip|url> # rsaexponent <value> # rsamodulus <value> airconnectatboot server networklockpersist on airusername XXXXXXXXXX airpassword XXXXXXXXXX # airkey <airvpn_user_key> airserver XXXXX # aircountry <airvpn_country_name> airproto udp airport 443 aircipher AES-128-GCM airipv6 off air6to4 off # manifestupdateinterval <minutes> # airwhiteserverlist <server list> # airblackserverlist <server list> # airwhitecountrylist <server list> # airblackcountrylist <server list> # country <ISO code> # remote <ip|url list> # proto <udp|tcp> # port <port> tunpersist yes # cipher AES-128-CBC # maxconnretries <number> # tcpqueuelimit <value> ncpdisable yes networklock on # ignorednspush <yes|no> # timeout <seconds> compress no # tlsversionmin <disabled|default|tls_1_x> # proxyhost <ip|url> # proxyport <port> # proxyusername <username> # proxypassword <password> # proxybasic <yes|no> Edited ... by hardknox Quote Share this post Link to post
Tech Jedi Alex 1560 Posted ... Be advised, the current settings may not honor the cipher you enter, as aircipher is only used with the automatic boot option. If you want to set the cipher for all manual connections, use cipher instead. So, try setting cipher to CHACHA20-POLY1305. If no luck, comment out cipher, aircipher, airproto and ncpdisable, then try setting proto to tcp. Quote Hide Tech Jedi Alex's signature Hide all signatures NOT AN AIRVPN TEAM MEMBER. USE TICKETS FOR PROFESSIONAL SUPPORT. LZ1's New User Guide to AirVPN « Plenty of stuff for advanced users, too! Want to contact me directly? All relevant methods are on my About me page. Share this post Link to post
Staff 10561 Posted ... @hardknox Hello! Whereas you have set connectatboot server in bluetit.rc, when started Bluetit will propound the aircipher specified AES-128-GCM cipher, which is supported by all of our servers, for the OpenVPN Data Channel. If you want to try CHACHA20-POLY1305 just change aircipher into CHACHA20-POLY1305 and re-start Bluetit, or use Goldcrest with the proper options to disconnect and start a new connection. However, if your system does support AES New Instructions, you may lose performance with CHACHA20. Not all systems take advantage of AES-NI, even when they are implemented in the CPU, thus a test with CHACHA20 is worth its time. Furthermore, please make sure to test different servers in various locations, in order to maximize likelihood of good peering between our and your transit providers. If performance remains low, test TCP, according to @OpenSourcerer suggestion, just in case your ISP enforces some cap on UDP. Just change airproto into tcp and restart Bluetit. Kind regards Quote Share this post Link to post
hardknox 0 Posted ... (edited) On 8/9/2021 at 4:20 AM, OpenSourcerer said: Be advised, the current settings may not honor the cipher you enter, as aircipher is only used with the automatic boot option. If you want to set the cipher for all manual connections, use cipher instead. So, try setting cipher to CHACHA20-POLY1305. If no luck, comment out cipher, aircipher, airproto and ncpdisable, then try setting proto to tcp. When I try to set cipher to CHACHA20-POLY1305 I get this error: Aug 10 18:47:56 T620 bluetit[13634]: ERROR: cipher algorithm 'AES-256-GCM' is not allowed by Bluetit policy. Here's my current bluetit.rc: # airkey <airvpn_user_key> airserver Cursa # aircountry <airvpn_country_name> airproto udp airport 443 # aircipher AES-128-GCM airipv6 off air6to4 off # manifestupdateinterval <minutes> # airwhiteserverlist <server list> # airblackserverlist <server list> # airwhitecountrylist <server list> # airblackcountrylist <server list> # country <ISO code> # remote <ip|url list> proto udp # port <port> tunpersist yes cipher CHACHA20-POLY1305 # maxconnretries <number> # tcpqueuelimit <value> ncpdisable yes networklock on # ignorednspush <yes|no> # timeout <seconds> compress no # tlsversionmin <disabled|default|tls_1_x> # proxyhost <ip|url> # proxyport <port> # proxyusername <username> # proxypassword <password> # proxybasic <yes|no> Edit: I fiddled with all the settings without much luck and switched servers where I saw a very small increase (~180 mbit). So I fired up Eddie on my laptop to test what speeds I got through it: ~700 mbit. Seems to me the problem is the T620's CPU, so I'll be looking to upgrade that. Edited ... by hardknox Quote Share this post Link to post
