Display Name REQUIRED 0 Posted ... How I got here Home > Download > Linux > Eddie Dumps an rpm file on me with no further instructions, so I try the obvious. # rpm -i eddie-ui_2.20.0_linux_x64_fedora.rpm # eddie-ui . 2021.05.10 09:09:08 - Eddie version: 2.20.0 / linux_x64, System: Linux, Name: \SKernel \r on an \m (\l), Version: Linux linux 5.11.18-100.fc32.x86_64 #1 SMP Mon May 3 15:30:24 UTC 2021 x86_64 x86_64 x86_64 GNU/Linux, Mono/.Net: 6.6.0.166 (tarball Tue Feb 23 06:02:51 UTC 2021); Framework: v4.0.30319 . 2021.05.10 09:09:08 - Command line arguments (2): path.resources="/usr/share/eddie-ui" path.exec="/usr/bin/eddie-ui" . 2021.05.10 09:09:08 - Raise system privileges . 2021.05.10 09:09:09 - Profile path: /usr/lib/eddie-ui/default.profile . 2021.05.10 09:09:09 - Profile options not found, using defaults. . 2021.05.10 09:09:10 - Tun Driver - /dev/net/tun . 2021.05.10 09:09:10 - OpenVPN - Version: 2.4.11 - OpenSSL 1.1.1k FIPS 25 Mar 2021, LZO 2.10 (/usr/sbin/openvpn) . 2021.05.10 09:09:10 - SSH - Version: OpenSSH_8.3p1, OpenSSL 1.1.1k FIPS 25 Mar 2021 (/usr/bin/ssh) . 2021.05.10 09:09:10 - SSL - Version: Initializing (/usr/bin/stunnel) . 2021.05.10 09:09:10 - curl - Version: 7.69.1 (/usr/bin/curl) /usr/lib/eddie-ui/eddie-tray: error while loading shared libraries: libappindicator.so.1: cannot open shared object file: No such file or directory I 2021.05.10 09:09:13 - Ready . 2021.05.10 09:09:15 - Collect information about AirVPN completed I 2021.05.10 09:09:57 - Checking login ... ! 2021.05.10 09:09:59 - Logged in. I 2021.05.10 09:10:31 - Session starting. . 2021.05.10 09:10:31 - Waiting for latency tests (167 to go) . 2021.05.10 09:10:32 - Waiting for latency tests (143 to go) After 15 minutes the number of tests to go started *increasing*. I feel I wasted my three euros. Quote Share this post Link to post
Staff 10454 Posted ... @Display Name REQUIRED Hello! Eddie desktop edition sends simultaneously a lot of ICMP packets to different destinations (all the VPN servers in your white list, or all AirVPN servers if a white list is not defined). Such a behavior is sometimes forbidden by some ISPs which will block ICMP packets after a certain threshold is reached. However Eddie should not get stuck and it should go on after each request times out, so it could be a bug which deserves investigation, thank you for the report. In the meantime, try this: disable latency tests and the problem should be gone. From Eddie's main window select "Preferences" > "Advanced", then de-tick "Enable latency tests" and finally click "Save". What Eddie calls "latency tests" are a measurement of the round trip time via ping, so by disabling them you should cut out the problem roots. When you disable latency tests Eddie is not able to pick a really good server for your node (you might find its choice of a "recommended" server bizarre, because it does not know anymore the round trip time from your node to the VPN servers), so take care to define a white list of servers according to your preferences, or pick servers or countries manually. Kind regards Quote Share this post Link to post
Tech Jedi Alex 1524 Posted ... Noteworthy, partly as a replacement. 1 Staff reacted to this Quote Hide Tech Jedi Alex's signature Hide all signatures NOT AN AIRVPN TEAM MEMBER. USE TICKETS FOR PROFESSIONAL SUPPORT. LZ1's New User Guide to AirVPN « Plenty of stuff for advanced users, too! Want to contact me directly? All relevant methods are on my About me page. Share this post Link to post
