Airystocrat 0 Posted ... (edited) Hello, My system is firewalled, What are the incoming / outgoing ports and protocols that eddie needs access to. I am using AirVPN with Tor. Like so PC -> Tor -> AirVPN -> Internet I have entered the Tor settings in Preferences > PRoxy/Tor -> and selected Tor here. I click the Test button and it was success! When i connect using "Connect to recommended server" Eddie goes in a loop and keeps disconnecting and reconnecting. Edit: In hindsight it appears that I shouldn't be needed to open any ports because I'm using Tor as a proxy. so the Eddie client would connect to a local instance of Tor , and should only need access to localhost. Is this correct? Why then does the client keep disconnecting. Edited ... by Airystocrat Quote Share this post Link to post
Tech Jedi Alex 1524 Posted ... 17 hours ago, Airystocrat said: When i connect using "Connect to recommended server" Eddie goes in a loop and keeps disconnecting and reconnecting. Difficult to say anything without logs. Try a connection, then in Logs tab click the lifebelt icon and paste/upload the output. Quote Hide Tech Jedi Alex's signature Hide all signatures NOT AN AIRVPN TEAM MEMBER. USE TICKETS FOR PROFESSIONAL SUPPORT. LZ1's New User Guide to AirVPN « Plenty of stuff for advanced users, too! Want to contact me directly? All relevant methods are on my About me page. Share this post Link to post
Airystocrat 0 Posted ... (edited) I got it working by unchecking DNS -> Check AirVPN DNS and Advanced -> "Check if the Tunnel works" Then the Eddie client connected to the recommended server. I now realise that I didn't frame my question correctly. I am using AirVPN in PC- Tor - VPN - Internet mode. I want to prevent IP leaks in this mode if VPN drops. I see that PrivateVPN had a post where they manually configure the Tor "Guard Node" IP into OpenVPN client, and then they also have a kill swich feature they claim that works with this mode. Can we do similar config with AirVPN, with or without Eddie client. The PrivateVPN page link is herehttps://privatevpn.com/blog/guides/80/how-to-connect-to-privatevpn's-openvpn-servers-over-tor Basic kill switch for Windows that will prevent IP leaks.https://privatevpnsupportguy.github.io/Setup manual kill switch for OpenVPN GUI on Windows.html Edited ... by Airystocrat Quote Share this post Link to post
Staff 10432 Posted ... @Airystocrat Hello! Eddie's Network Lock now works even for OpenVPN over Tor mode, but only in Windows. Eddie 2.18 or higher version is required. The feature is currently undocumented. Eddie developer may clarify the matter. In other systems, if you can't rely on virtualization, we would recommend Tor over OpenVPN for a 100% safe leaks prevention. Tor over OpenVPN, in terms of anonymity layer, is better than OpenVPN over Tor, because the Tor "circuit" is free and re-built at each stream, and not indefinitely fixed for the unique OpenVPN stream. Moreover you can run OpenVPN over UDP. However the final service will see that your traffic comes from Tor. Kind regards 1 Airystocrat reacted to this Quote Share this post Link to post
