Aghinix 0 Posted ... Hey guys. I'm struggling with Eddie on Void linux, i'm trying to use portable version (i've tried appimage also). All works fine, except i can't get it minimized to tray, which i find very,very annoying. There are some libappindicator libraries missing, although i have libappindicator installed, but i guess i have a newer version. eddie-tray: error while loading shared libraries: libindicator.so.7: cannot open shared object file: No such file or directory Any idea how to fix this, ot there is another Eddie version i should try? Thanks. Quote Share this post Link to post
Tech Jedi Alex 1528 Posted ... Did you try searching for that specific file? $ xlocate -S $ xlocate libindicator.so . Quote Hide Tech Jedi Alex's signature Hide all signatures NOT AN AIRVPN TEAM MEMBER. USE TICKETS FOR PROFESSIONAL SUPPORT. LZ1's New User Guide to AirVPN « Plenty of stuff for advanced users, too! Want to contact me directly? All relevant methods are on my About me page. Share this post Link to post
Staff 10493 Posted ... @Aghinix Hello! Can you tell us whether the AppImage's eddie-tray fails with the identical error, or you get a different one? What is your current Desktop Environment? Apart from the minimization problem, is anything else fine? What is your version of libappindicator? Can you please re-check whether libindicator is available? Kind regards Quote Share this post Link to post
Aghinix 0 Posted ... With Appimage i get this error: /tmp/.mount_eddie-vunP7d/opt/eddie-ui/eddie-tray: error while loading shared libraries: libindicator.so.7: cannot open shared object file: No such file or directory I have no desktop environment, only a window manager(openbox). Apart with this minimization problem (which i resolved using an application named kdocker who can minimize any app and sending it to tray) Eddie works fine, no problems. libappindicator-12.10.0_3 libindicator-12.10.1_1 Thanks. Quote Share this post Link to post
Staff 10493 Posted ... @Aghinix Thank you! We will send this thread to Eddie developer. Kind regards Quote Share this post Link to post
