Not connected, Your IP: 216.73.216.212
hi, i recently readed about dns leaks (the page dnsleaktest.com) and how to fix it on windows but i want also a guide for fixing it on linux.
thanks!
thanks!
Linux-based systems are not affected by DNS leaks (as long as their OpenVPN client accepts the push from our OpenVPN server), since they have a global DNS. The "DNS leak" is a problem which normally torments only Windows systems which lack the concept of a global DNS.
Anyway, you might like to secure your OpenVPN connection in Linux against any leak, including leaks in case of unexpected VPN disconnections:
https://airvpn.org/index.php?option=com_kunena&func=view&catid=3&id=1713&limit=6&limitstart=30&Itemid=142#2010
