Aronos
Eddie constantly restarting or getting stuck on IPv4
I've been using Eddie for a couple of months. I work at a hospital and primarily use the VPN on my laptop when I'm at work. However, the last couple of days I've had a lot of issues. When I'm on the hospital wifi, Eddie constantly restarts. When I connect to my 5G Mobile hotspot, it gets stuck connecting or checking IPv4/DNS."
I have tried flushing my dns, restarting both the client and my pc, unchecking automatic under protocols and selecting UDP/TCP/SSH 443, none of them work. I also tried disabling Check AirVPN status under DNS settings. I have no routes setup under Routes either.
Here are my logs from the last little while:
Eddie System/Environment Report - 2/9/2021 - 6:13 AM UTC
Eddie version: 2.19.7
Eddie OS build: windows_x64
Eddie architecture: x64
OS type: Windows
OS name: Windows 10 Pro
OS version: Microsoft Windows NT 10.0.19041.0
OS architecture: x64
Mono /.Net Framework: v4.0.30319
TUN driver: 0901: 9.24.2; wintun: Not found
OpenVPN: 2.5.0 - OpenSSL 1.1.1h  22 Sep 2020, LZO 2.10 (C:\Program Files\AirVPN\openvpn.exe)
Hummingbird:  ()
SSH:
plink 0.73
Build platform: 64-bit x86 Windows
Compiler: clang 7.0.0 (tags/RELEASE_700/final), emulating Visual Studio 2013 (12.0), _MSC_VER=1800
Source commit: 745ed3ad3beaf52fc623827e770b3a068b238dd5 (C:\Program Files\AirVPN\plink.exe)
SSL: stunnel 5.56 (C:\Program Files\AirVPN\stunnel.exe)
Profile path: C:\Users\arono\AppData\Local\Eddie\default.profile
Data path: C:\Users\arono\AppData\Local\Eddie
Application path: C:\Program Files\AirVPN
Executable path: C:\Program Files\AirVPN\Eddie-UI.exe
Command line arguments: (0 args)
Network Lock Active: No
Connected to VPN: No
Detected DNS: 172.16.0.123, 172.16.0.124
Test DNS IPv4: Ok
Test DNS IPv6: Failed
Test Ping IPv4: 112 ms
Test Ping IPv6: Failed
Test HTTP IPv4: Ok
Test HTTP IPv6: Error: Fetch url error:Couldn't connect to server
Test HTTPS: Ok
login: (omissis)
password: (omissis)
remember: True
servers.whitelist: ef97a66f04394990d341c2a51eab11d6490d90f92318b50cc02988bd5fde0d88,0e47e9b4d7672c40279d5fb0666709d9a7d7b1325c3309264dbfa96ed0352183,2023bb247b5e7154a872a877de417189d5c2f61651ca258a94195744b5f3c9c0,dec6969cb7e9ee63c7320e9b97eea6956e2ad3a4dfda5454ee4c62415baa708a
servers.blacklist: 3858a066dafe1ecd6f5e898755e88ab035aa6ba80664cdc19c18c1465fae95c6
servers.scoretype: Latency
mode.protocol: UDP
mode.alt: 1
dns.check: False
network.entry.iplayer: ipv6-ipv4
openvpn.sndbuf: -1
openvpn.rcvbuf: -1
Logs:
. 2021.02.09 00:12:38 - Eddie version: 2.19.7 / windows_x64, System: Windows, Name: Windows 10 Pro, Version: Microsoft Windows NT 10.0.19041.0, Mono/.Net: v4.0.30319
. 2021.02.09 00:12:38 - Command line arguments (0):
. 2021.02.09 00:12:39 - Profile path: C:\Users\arono\AppData\Local\Eddie\default.profile
. 2021.02.09 00:12:39 - Reading options from C:\Users\arono\AppData\Local\Eddie\default.profile
. 2021.02.09 00:12:42 - Tun Driver - 0901: 9.24.2; wintun: Not found
. 2021.02.09 00:12:42 - OpenVPN - Version: 2.5.0 - OpenSSL 1.1.1h  22 Sep 2020, LZO 2.10 (C:\Program Files\AirVPN\openvpn.exe)
. 2021.02.09 00:12:42 - SSH - Version: plink 0.73
. 2021.02.09 00:12:42 -     Build platform: 64-bit x86 Windows
. 2021.02.09 00:12:42 -     Compiler: clang 7.0.0 (tags/RELEASE_700/final), emulating Visual Studio 2013 (12.0), _MSC_VER=1800
. 2021.02.09 00:12:42 -     Source commit: 745ed3ad3beaf52fc623827e770b3a068b238dd5 (C:\Program Files\AirVPN\plink.exe)
. 2021.02.09 00:12:42 - SSL - Version: stunnel 5.56 (C:\Program Files\AirVPN\stunnel.exe)
I 2021.02.09 00:12:43 - Ready
. 2021.02.09 00:12:48 - Collect information about AirVPN completed
I 2021.02.09 00:12:49 - Session starting.
I 2021.02.09 00:12:49 - Checking authorization ...
! 2021.02.09 00:12:50 - Connecting to Hercules (United States of America, Atlanta, Georgia)
. 2021.02.09 00:12:50 - OpenVPN > OpenVPN 2.5.0 x86_64-w64-mingw32 [SSL (OpenSSL)] [LZO] [LZ4] [PKCS11] [AEAD] built on Oct 28 2020
. 2021.02.09 00:12:50 - OpenVPN > Windows version 10.0 (Windows 10 or greater) 64bit
. 2021.02.09 00:12:50 - OpenVPN > library versions: OpenSSL 1.1.1h  22 Sep 2020, LZO 2.10
. 2021.02.09 00:12:50 - OpenVPN > Outgoing Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2021.02.09 00:12:50 - OpenVPN > Incoming Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2021.02.09 00:12:50 - OpenVPN > TCP/UDP: Preserving recently used remote address: [AF_INET6]2605:9f80:6000:80:ecab:28fe:d9d8:5bd0:443
. 2021.02.09 00:12:50 - OpenVPN > Socket Buffers: R=[65536->65536] S=[65536->65536]
. 2021.02.09 00:12:50 - OpenVPN > UDPv6 link local: (not bound)
. 2021.02.09 00:12:50 - OpenVPN > UDPv6 link remote: [AF_INET6]2605:9f80:6000:80:ecab:28fe:d9d8:5bd0:443
. 2021.02.09 00:12:53 - OpenVPN > write UDPv6: Unknown error (code=10051)
. 2021.02.09 00:13:20 - Above log line repeated 2 times more
. 2021.02.09 00:13:20 - ping 1
. 2021.02.09 00:13:20 - ping 2 W
. 2021.02.09 00:13:20 - ping 2 WE
. 2021.02.09 00:13:20 - OpenVPN > write UDPv6: Unknown error (code=10051)
Network Interfaces and Routes:
    "support_ipv4": true,
    "support_ipv6": true,
    "routes": [
            "address": "0.0.0.0\/0",
            "interface": "{590519E2-1B7A-462D-99DA-98911F5854DE}",
            "gateway": "10.200.224.1",
            "metric": "40"
            "address": "10.200.224.0\/21",
            "gateway": "link",
            "metric": "296"
            "address": "10.200.224.99",
            "gateway": "link",
            "metric": "296"
            "address": "10.200.231.255",
            "gateway": "link",
            "metric": "296"
            "address": "127.0.0.0\/8",
            "interface": "{2721633D-555B-11E7-86B3-806E6F6E6963}",
            "gateway": "link",
            "metric": "331"
            "address": "127.0.0.1",
            "gateway": "link",
            "metric": "331"
            "address": "127.255.255.255",
            "gateway": "link",
            "metric": "331"
            "address": "224.0.0.0\/4",
            "gateway": "link",
            "metric": "331"
            "gateway": "link",
            "metric": "296"
            "address": "255.255.255.255",
            "gateway": "link",
            "metric": "331"
            "gateway": "link",
            "metric": "296"
            "address": "::1",
            "gateway": "link",
            "metric": "331"
            "address": "fe80::\/64",
            "gateway": "link",
            "metric": "296"
            "address": "fe80::692c:48d5:eb21:1862",
            "gateway": "link",
            "metric": "296"
            "address": "ff00::\/8",
            "gateway": "link",
            "metric": "331"
            "gateway": "link",
            "metric": "296"
    "interfaces": [
            "friendly": "Local Area Connection 2",
            "id": "{C08F2B39-6B49-47C9-B994-D5F695969509}",
            "name": "Local Area Connection 2",
            "description": "TAP-Windows Adapter V9",
            "type": "Virtual",
            "status": "Down",
            "bytes_received": "6207581",
            "bytes_sent": "2732096",
            "ips": [
                "fe80::24d9:8d53:2978:69a9",
                "169.254.105.169"
            "gateways": [],
            "bind": true,
            "dns4": "",
            "dns6": null
            "friendly": "Local Area Connection* 1",
            "id": "{B0027418-A133-4DE7-8CD5-DCA5EED65DAE}",
            "name": "Local Area Connection* 1",
            "description": "Microsoft Wi-Fi Direct Virtual Adapter",
            "type": "Wireless80211",
            "status": "Down",
            "bytes_received": "0",
            "bytes_sent": "0",
            "ips": [
                "fe80::c56:9716:9e37:7963",
                "169.254.121.99"
            "gateways": [],
            "bind": true,
            "dns4": "",
            "dns6": null
            "friendly": "Local Area Connection* 2",
            "id": "{782343E8-02F9-494A-9466-6CAF832C2815}",
            "name": "Local Area Connection* 2",
            "description": "Microsoft Wi-Fi Direct Virtual Adapter #2",
            "status": "Down",
            "bytes_sent": "0",
            "ips": [
                "fe80::ddb8:ad80:639b:aee9",
                "169.254.174.233"
            "gateways": [],
            "bind": true,
            "dns4": "",
            "dns6": null
            "friendly": "Wi-Fi",
            "id": "{590519E2-1B7A-462D-99DA-98911F5854DE}",
            "name": "Wi-Fi",
            "description": "Marvell AVASTAR Wireless-AC Network Controller",
            "status": "Up",
            "bytes_received": "36711117",
            "bytes_sent": "3579940",
            "ips": [
                "10.200.224.99"
            "gateways": [
                "10.200.224.1"
            "bind": true,
            "dns4": "",
            "dns6": null
            "friendly": "Bluetooth Network Connection",
            "id": "{A6CE4D83-C43F-4A0E-A55E-DFD3A8BFA7CD}",
            "name": "Bluetooth Network Connection",
            "description": "Bluetooth Device (Personal Area Network)",
            "type": "Ethernet",
            "status": "Down",
            "bytes_sent": "0",
            "ips": [
                "fe80::2173:b236:44ea:4dad",
                "169.254.77.173"
            "gateways": [],
            "bind": true,
            "dns4": "",
            "dns6": null
            "friendly": "Loopback Pseudo-Interface 1",
            "id": "{2721633D-555B-11E7-86B3-806E6F6E6963}",
            "name": "Loopback Pseudo-Interface 1",
            "description": "Software Loopback Interface 1",
            "type": "Loopback",
            "status": "Up",
            "bytes_sent": "0",
            "ips": [
                "::1",
                "127.0.0.1"
            "gateways": [],
            "bind": true,
            "dns4": "",
            "dns6": null
    "ipv4-default-gateway": "10.200.224.1",
    "ipv4-default-interface": "{590519E2-1B7A-462D-99DA-98911F5854DE}"
ipconfig /all:
Windows IP Configuration
   Host Name . . . . . . . . . . . . : DESKTOP-NN1Q1KJ
   Primary Dns Suffix  . . . . . . . :
   Node Type . . . . . . . . . . . . : Hybrid
   IP Routing Enabled. . . . . . . . : No
   WINS Proxy Enabled. . . . . . . . : No
   DNS Suffix Search List. . . . . . : the-med.org
Unknown adapter Local Area Connection 2:
   Media State . . . . . . . . . . . : Media disconnected
   Connection-specific DNS Suffix  . :
   Description . . . . . . . . . . . : TAP-Windows Adapter V9
   Physical Address. . . . . . . . . : 00-FF-C0-8F-2B-39
   DHCP Enabled. . . . . . . . . . . : Yes
   Autoconfiguration Enabled . . . . : Yes
Wireless LAN adapter Local Area Connection* 1:
   Description . . . . . . . . . . . : Microsoft Wi-Fi Direct Virtual Adapter
   Physical Address. . . . . . . . . : B6-AE-2B-D6-3C-13
Wireless LAN adapter Local Area Connection* 2:
   Description . . . . . . . . . . . : Microsoft Wi-Fi Direct Virtual Adapter #2
   Physical Address. . . . . . . . . : B6-AE-2B-D6-39-13
Wireless LAN adapter Wi-Fi:
   Connection-specific DNS Suffix  . : the-med.org
   Description . . . . . . . . . . . : Marvell AVASTAR Wireless-AC Network Controller
   Physical Address. . . . . . . . . : B4-AE-2B-D6-3D-12
   Link-local IPv6 Address . . . . . : fe80::692c:48d5:eb21:1862%5(Preferred)
   IPv4 Address. . . . . . . . . . . : 10.200.224.99(Preferred)
   Subnet Mask . . . . . . . . . . . : 255.255.248.0
   Lease Obtained. . . . . . . . . . : Tuesday, February 09, 2021 12:11:42 AM
   Lease Expires . . . . . . . . . . : Tuesday, February 09, 2021 1:11:42 AM
   Default Gateway . . . . . . . . . : 10.200.224.1
   DHCP Server . . . . . . . . . . . : 10.200.103.56
   DHCPv6 IAID . . . . . . . . . . . : 45395499
   DHCPv6 Client DUID. . . . . . . . : 00-01-00-01-26-73-F2-0E-B4-AE-2B-D6-3D-12
   DNS Servers . . . . . . . . . . . : 172.16.0.123
                                       172.16.0.124
   Primary WINS Server . . . . . . . : 10.200.100.123
   Secondary WINS Server . . . . . . : 10.200.100.124
   NetBIOS over Tcpip. . . . . . . . : Enabled
Ethernet adapter Bluetooth Network Connection:
   Description . . . . . . . . . . . : Bluetooth Device (Personal Area Network)
   Physical Address. . . . . . . . . : B4-AE-2B-D6-3D-13
Edited ... by Aronos
Let's upload a system report instead. Try a connection, then Logs tab > lifebelt icon. Paste/upload the output here.
Gives everyone more info to work with. :)
Hey, thanks for the reply. I've replaced the original log that I had with the one you requested.
Thanks for looking into this.
I think I may have found the issue. In windows, "Reputation based protection" is a setting I stumbled across a few days ago and I recently enabled it. After disabling it, I think it is what was causing the sudden night/day difference in my ability to connect with OpenVPN. As soon as I disabled it, I was able to connect without issue.
Perhaps you can review the logs I posted and see if there are any additional issues that you might see. If there are any optimizations you might recommend, please let me know as well. I would love to know what it is that this Window's setting does that impedes AirVPN's ability to operate and why my connection appeared to get stuck at different points when using a public wifi connection and my mobile 5g hotspot.
I'm still having a lot of problems with Eddie, gettind disconnected every minute or so while my connection is constantly restarting or getting stuck checking IPv6. Even after disabling IPv6, it's still trying to check said route.
I have tried different protocols (between UDP, TCP, SSH and SSL 443), disabling IPv6, changing my networking bitrate from the default down to 64kb.  I've restarted my PC, reinstalled Eddie and I'm not running any virus protection besides Microsoft's Firewall and Window's Defender.
Eddie System/Environment Report - 2/10/2021 - 6:38 AM UTC
OS type: Windows
Hummingbird:  ()
SSH:
plink 0.73
Test DNS IPv4: Ok
Test Ping IPv4: 113 ms
Test HTTP IPv4: Ok
Test HTTPS: Ok
login: (omissis)
password: (omissis)
remember: True
mode.protocol: TCP
mode.alt: 2
dns.check: False
network.entry.iplayer: ipv4-only
openvpn.sndbuf: 65536
openvpn.rcvbuf: 65536
Logs:
. 2021.02.10 00:27:08 - OpenVPN > tap-windows6 device [Local Area Connection 2] opened
. 2021.02.10 00:27:08 - OpenVPN > TAP-Windows Driver Version 9.24
. 2021.02.10 00:27:08 - OpenVPN > Set TAP-Windows TUN subnet mode network/local/netmask = 10.30.163.0/10.30.163.16/255.255.255.0 [SUCCEEDED]
. 2021.02.10 00:27:08 - OpenVPN > Notified TAP-Windows driver to set a DHCP IP/netmask of 10.30.163.16/255.255.255.0 on interface {C08F2B39-6B49-47C9-B994-D5F695969509} [DHCP-serv: 10.30.163.254, lease-time: 31536000]
. 2021.02.10 00:27:08 - OpenVPN > Successful ARP Flush on interface [16] {C08F2B39-6B49-47C9-B994-D5F695969509}
. 2021.02.10 00:27:08 - OpenVPN > IPv4 MTU set to 1500 on interface 16 using SetIpInterfaceEntry()
. 2021.02.10 00:27:08 - OpenVPN > NETSH: C:\WINDOWS\system32\netsh.exe interface ipv6 set address 16 fde6:7a:7d20:1aa3::100e/128 store=active
. 2021.02.10 00:27:08 - OpenVPN > add_route_ipv6(fde6:7a:7d20:1aa3::/64 -> fde6:7a:7d20:1aa3::100e metric 0) dev Local Area Connection 2
. 2021.02.10 00:27:08 - OpenVPN > C:\WINDOWS\system32\netsh.exe interface ipv6 add route fde6:7a:7d20:1aa3::/64 16 fe80::8 store=active
. 2021.02.10 00:27:08 - OpenVPN > env_block: add PATH=C:\WINDOWS\System32;C:\WINDOWS;C:\WINDOWS\System32\Wbem
. 2021.02.10 00:27:09 - OpenVPN > NETSH: C:\WINDOWS\system32\netsh.exe interface ipv6 delete dns 16 all
. 2021.02.10 00:27:11 - OpenVPN > NETSH: C:\WINDOWS\system32\netsh.exe interface ipv6 set dns 16 static fde6:7a:7d20:1aa3::1 validate=no
. 2021.02.10 00:27:11 - OpenVPN > IPv6 MTU set to 1500 on interface 16 using SetIpInterfaceEntry()
. 2021.02.10 00:27:16 - OpenVPN > TEST ROUTES: 1/1 succeeded len=0 ret=1 a=0 u/d=up
. 2021.02.10 00:27:16 - OpenVPN > C:\WINDOWS\system32\route.exe ADD 68.235.52.38 MASK 255.255.255.255 10.200.224.1
. 2021.02.10 00:27:16 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=50 and dwForwardType=4
. 2021.02.10 00:27:16 - OpenVPN > Route addition via IPAPI succeeded [adaptive]
. 2021.02.10 00:27:16 - OpenVPN > C:\WINDOWS\system32\route.exe ADD 10.200.103.56 MASK 255.255.255.255 10.200.224.1
. 2021.02.10 00:27:16 - OpenVPN > C:\WINDOWS\system32\route.exe ADD 0.0.0.0 MASK 128.0.0.0 10.30.163.1
. 2021.02.10 00:27:16 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=25 and dwForwardType=4
. 2021.02.10 00:27:16 - OpenVPN > C:\WINDOWS\system32\route.exe ADD 128.0.0.0 MASK 128.0.0.0 10.30.163.1
. 2021.02.10 00:27:16 - OpenVPN > add_route_ipv6(::/3 -> fde6:7a:7d20:1aa3::1 metric -1) dev Local Area Connection 2
. 2021.02.10 00:27:16 - OpenVPN > C:\WINDOWS\system32\netsh.exe interface ipv6 add route ::/3 16 fe80::8 store=active
. 2021.02.10 00:27:16 - OpenVPN > env_block: add PATH=C:\WINDOWS\System32;C:\WINDOWS;C:\WINDOWS\System32\Wbem
E 2021.02.10 00:27:16 - OpenVPN > ERROR: Windows route add ipv6 command failed: returned error code 1
. 2021.02.10 00:27:16 - OpenVPN > add_route_ipv6(2000::/4 -> fde6:7a:7d20:1aa3::1 metric -1) dev Local Area Connection 2
. 2021.02.10 00:27:16 - OpenVPN > C:\WINDOWS\system32\netsh.exe interface ipv6 add route 2000::/4 16 fe80::8 store=active
E 2021.02.10 00:27:17 - OpenVPN > ERROR: Windows route add ipv6 command failed: returned error code 1
. 2021.02.10 00:27:17 - OpenVPN > add_route_ipv6(3000::/4 -> fde6:7a:7d20:1aa3::1 metric -1) dev Local Area Connection 2
. 2021.02.10 00:27:17 - OpenVPN > C:\WINDOWS\system32\netsh.exe interface ipv6 add route 3000::/4 16 fe80::8 store=active
. 2021.02.10 00:27:17 - OpenVPN > env_block: add PATH=C:\WINDOWS\System32;C:\WINDOWS;C:\WINDOWS\System32\Wbem
. 2021.02.10 00:27:17 - OpenVPN > add_route_ipv6(fc00::/7 -> fde6:7a:7d20:1aa3::1 metric -1) dev Local Area Connection 2
. 2021.02.10 00:27:17 - OpenVPN > C:\WINDOWS\system32\netsh.exe interface ipv6 add route fc00::/7 16 fe80::8 store=active
. 2021.02.10 00:27:17 - Interface Local Area Connection 2 metric changed from Automatic to 3, layer IPv4
. 2021.02.10 00:27:17 - Interface Local Area Connection 2 metric changed from Automatic to 3, layer IPv6
. 2021.02.10 00:27:17 - DNS leak protection with packet filtering enabled.
. 2021.02.10 00:27:17 - DNS IPv4 of a network adapter forced (Local Area Connection 2, from automatic to 10.30.163.1)
. 2021.02.10 00:27:17 - DNS IPv6 of a network adapter forced (Local Area Connection 2, from automatic to fde6:7a:7d20:1aa3::1)
. 2021.02.10 00:27:18 - Routes, added a new route, 68.235.52.36 for gateway 10.30.163.1
. 2021.02.10 00:27:18 - Routes, added a new route, 2607:9000:0:3:36a4:cf80:2f7b:6990 for gateway fde6:7a:7d20:1aa3::1
. 2021.02.10 00:27:18 - Flushing DNS
I 2021.02.10 00:27:18 - Checking route IPv4
I 2021.02.10 00:27:18 - Checking route IPv6
. 2021.02.10 00:27:40 - Fetch url error:Timeout was reached
. 2021.02.10 00:27:40 - Checking route (2° try)
. 2021.02.10 00:28:02 - Fetch url error:Timeout was reached
. 2021.02.10 00:28:02 - Checking route (3° try)
. 2021.02.10 00:28:26 - Fetch url error:Timeout was reached
E 2021.02.10 00:28:26 - Checking route IPv6 failed.
. 2021.02.10 00:28:26 - OpenVPN > Initialization Sequence Completed
! 2021.02.10 00:28:26 - Disconnecting
. 2021.02.10 00:28:26 - Routes, removed a route previously added, 68.235.52.36 for gateway 10.30.163.1
. 2021.02.10 00:28:26 - Routes, removed a route previously added, 2607:9000:0:3:36a4:cf80:2f7b:6990 for gateway fde6:7a:7d20:1aa3::1
. 2021.02.10 00:28:26 - Sending soft termination signal
. 2021.02.10 00:28:29 - Connection terminated.
. 2021.02.10 00:28:29 - DNS IPv4 of a network adapter restored to original settings (Local Area Connection 2, to automatic)
. 2021.02.10 00:28:29 - DNS IPv6 of a network adapter restored to original settings (Local Area Connection 2, to automatic)
. 2021.02.10 00:28:29 - DNS leak protection with packet filtering disabled.
. 2021.02.10 00:28:29 - Interface Local Area Connection 2 metric restored from 3 to Automatic, layer IPv4
. 2021.02.10 00:28:29 - Interface Local Area Connection 2 metric restored from 3 to Automatic, layer IPv6
. 2021.02.10 00:28:29 - OpenVPN > C:\WINDOWS\system32\route.exe DELETE 68.235.52.38 MASK 255.255.255.255 10.200.224.1
. 2021.02.10 00:28:29 - OpenVPN > Route deletion via IPAPI succeeded [adaptive]
. 2021.02.10 00:28:29 - OpenVPN > C:\WINDOWS\system32\route.exe DELETE 10.200.103.56 MASK 255.255.255.255 10.200.224.1
. 2021.02.10 00:28:29 - OpenVPN > C:\WINDOWS\system32\route.exe DELETE 0.0.0.0 MASK 128.0.0.0 10.30.163.1
. 2021.02.10 00:28:29 - OpenVPN > C:\WINDOWS\system32\route.exe DELETE 128.0.0.0 MASK 128.0.0.0 10.30.163.1
. 2021.02.10 00:28:29 - OpenVPN > Closing TUN/TAP interface
. 2021.02.10 00:28:29 - OpenVPN > NETSH: C:\WINDOWS\system32\netsh.exe interface ipv6 delete dns 16 all
. 2021.02.10 00:28:29 - OpenVPN > delete_route_ipv6(fde6:7a:7d20:1aa3::/64)
. 2021.02.10 00:28:29 - OpenVPN > C:\WINDOWS\system32\netsh.exe interface ipv6 delete route fde6:7a:7d20:1aa3::/64 16 fe80::8 store=active
. 2021.02.10 00:28:29 - OpenVPN > NETSH: C:\WINDOWS\system32\netsh.exe interface ipv6 delete address 16 fde6:7a:7d20:1aa3::100e store=active
. 2021.02.10 00:28:29 - OpenVPN > TAP: DHCP address released
. 2021.02.10 00:28:29 - OpenVPN > SIGTERM[hard,] received, process exiting
I 2021.02.10 00:28:32 - Checking authorization ...
! 2021.02.10 00:28:33 - Connecting to Hercules (United States of America, Atlanta, Georgia)
. 2021.02.10 00:28:33 - OpenVPN > OpenVPN 2.5.0 x86_64-w64-mingw32 [SSL (OpenSSL)] [LZO] [LZ4] [PKCS11] [AEAD] built on Oct 28 2020
. 2021.02.10 00:28:33 - OpenVPN > Windows version 10.0 (Windows 10 or greater) 64bit
. 2021.02.10 00:28:33 - OpenVPN > library versions: OpenSSL 1.1.1h  22 Sep 2020, LZO 2.10
. 2021.02.10 00:28:33 - OpenVPN > Outgoing Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key
. 2021.02.10 00:28:33 - OpenVPN > Outgoing Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication
. 2021.02.10 00:28:33 - OpenVPN > Incoming Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key
. 2021.02.10 00:28:33 - OpenVPN > Incoming Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication
. 2021.02.10 00:28:33 - OpenVPN > TCP/UDP: Preserving recently used remote address: [AF_INET]64.42.179.61:443
. 2021.02.10 00:28:33 - OpenVPN > Socket Buffers: R=[65536->65536] S=[65536->65536]
. 2021.02.10 00:28:33 - OpenVPN > Attempting to establish TCP connection with [AF_INET]64.42.179.61:443 [nonblock]
. 2021.02.10 00:28:33 - OpenVPN > TCP connection established with [AF_INET]64.42.179.61:443
. 2021.02.10 00:28:33 - OpenVPN > TCP_CLIENT link local: (not bound)
. 2021.02.10 00:28:33 - OpenVPN > TCP_CLIENT link remote: [AF_INET]64.42.179.61:443
. 2021.02.10 00:28:33 - OpenVPN > TLS: Initial packet from [AF_INET]64.42.179.61:443, sid=5b59bd07 c71da1c3
. 2021.02.10 00:28:34 - OpenVPN > VERIFY KU OK
. 2021.02.10 00:28:34 - OpenVPN > Validating certificate extended key usage
. 2021.02.10 00:28:34 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
. 2021.02.10 00:28:34 - OpenVPN > VERIFY EKU OK
. 2021.02.10 00:28:34 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=Hercules, emailAddress=info@airvpn.org
. 2021.02.10 00:28:34 - OpenVPN > Control Channel: TLSv1.3, cipher TLSv1.3 TLS_CHACHA20_POLY1305_SHA256, 4096 bit RSA
. 2021.02.10 00:28:34 - OpenVPN > [Hercules] Peer Connection Initiated with [AF_INET]64.42.179.61:443
. 2021.02.10 00:28:34 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,comp-lzo no,redirect-gateway ipv6 def1 bypass-dhcp,dhcp-option DNS 10.22.227.1,dhcp-option DNS6 fde6:7a:7d20:12e3::1,tun-ipv6,route-gateway 10.22.227.1,topology subnet,ping 10,ping-restart 60,ifconfig-ipv6 fde6:7a:7d20:12e3::1010/64 fde6:7a:7d20:12e3::1,ifconfig 10.22.227.18 255.255.255.0,peer-id 0,cipher AES-256-GCM'
. 2021.02.10 00:28:34 - OpenVPN > Pushed option removed by filter: 'redirect-gateway ipv6 def1 bypass-dhcp'
. 2021.02.10 00:28:34 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified
. 2021.02.10 00:28:34 - OpenVPN > OPTIONS IMPORT: compression parms modified
. 2021.02.10 00:28:34 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified
. 2021.02.10 00:28:34 - OpenVPN > OPTIONS IMPORT: route-related options modified
. 2021.02.10 00:28:34 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified
. 2021.02.10 00:28:34 - OpenVPN > OPTIONS IMPORT: peer-id set
. 2021.02.10 00:28:34 - OpenVPN > OPTIONS IMPORT: adjusting link_mtu to 1627
. 2021.02.10 00:28:34 - OpenVPN > OPTIONS IMPORT: data channel crypto options modified
. 2021.02.10 00:28:34 - OpenVPN > Data Channel: using negotiated cipher 'AES-256-GCM'
. 2021.02.10 00:28:34 - OpenVPN > Outgoing Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key
. 2021.02.10 00:28:34 - OpenVPN > Incoming Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key
. 2021.02.10 00:28:34 - OpenVPN > interactive service msg_channel=0
. 2021.02.10 00:28:34 - OpenVPN > ROUTE_GATEWAY 10.200.224.1/255.255.248.0 I=5 HWADDR=b4:ae:2b:d6:3d:12
. 2021.02.10 00:28:34 - OpenVPN > ROUTE: bypass_host_route[0]=10.200.103.56
. 2021.02.10 00:28:34 - OpenVPN > GDG6: remote_host_ipv6=n/a
. 2021.02.10 00:28:34 - OpenVPN > GetBestInterfaceEx() returned if=16
. 2021.02.10 00:28:34 - OpenVPN > GDG6: II=16 DP=::/3 NH=fe80::8
. 2021.02.10 00:28:34 - OpenVPN > GDG6: Metric=256, Loopback=0, AA=1, I=0
. 2021.02.10 00:28:34 - OpenVPN > ROUTE6_GATEWAY fe80::8 I=16
. 2021.02.10 00:28:34 - OpenVPN > open_tun
. 2021.02.10 00:28:34 - OpenVPN > tap-windows6 device [Local Area Connection 2] opened
. 2021.02.10 00:28:34 - OpenVPN > TAP-Windows Driver Version 9.24
. 2021.02.10 00:28:34 - OpenVPN > Set TAP-Windows TUN subnet mode network/local/netmask = 10.22.227.0/10.22.227.18/255.255.255.0 [SUCCEEDED]
. 2021.02.10 00:28:34 - OpenVPN > Notified TAP-Windows driver to set a DHCP IP/netmask of 10.22.227.18/255.255.255.0 on interface {C08F2B39-6B49-47C9-B994-D5F695969509} [DHCP-serv: 10.22.227.254, lease-time: 31536000]
. 2021.02.10 00:28:34 - OpenVPN > Successful ARP Flush on interface [16] {C08F2B39-6B49-47C9-B994-D5F695969509}
. 2021.02.10 00:28:34 - OpenVPN > IPv4 MTU set to 1500 on interface 16 using SetIpInterfaceEntry()
. 2021.02.10 00:28:35 - OpenVPN > NETSH: C:\WINDOWS\system32\netsh.exe interface ipv6 set address 16 fde6:7a:7d20:12e3::1010/128 store=active
. 2021.02.10 00:28:35 - OpenVPN > add_route_ipv6(fde6:7a:7d20:12e3::/64 -> fde6:7a:7d20:12e3::1010 metric 0) dev Local Area Connection 2
. 2021.02.10 00:28:35 - OpenVPN > C:\WINDOWS\system32\netsh.exe interface ipv6 add route fde6:7a:7d20:12e3::/64 16 fe80::8 store=active
. 2021.02.10 00:28:35 - OpenVPN > env_block: add PATH=C:\WINDOWS\System32;C:\WINDOWS;C:\WINDOWS\System32\Wbem
. 2021.02.10 00:28:36 - OpenVPN > NETSH: C:\WINDOWS\system32\netsh.exe interface ipv6 delete dns 16 all
. 2021.02.10 00:28:38 - OpenVPN > NETSH: C:\WINDOWS\system32\netsh.exe interface ipv6 set dns 16 static fde6:7a:7d20:12e3::1 validate=no
. 2021.02.10 00:28:38 - OpenVPN > IPv6 MTU set to 1500 on interface 16 using SetIpInterfaceEntry()
. 2021.02.10 00:28:43 - OpenVPN > TEST ROUTES: 1/1 succeeded len=0 ret=1 a=0 u/d=up
. 2021.02.10 00:28:43 - OpenVPN > C:\WINDOWS\system32\route.exe ADD 64.42.179.61 MASK 255.255.255.255 10.200.224.1
. 2021.02.10 00:28:43 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=50 and dwForwardType=4
. 2021.02.10 00:28:43 - OpenVPN > Route addition via IPAPI succeeded [adaptive]
. 2021.02.10 00:28:43 - OpenVPN > C:\WINDOWS\system32\route.exe ADD 10.200.103.56 MASK 255.255.255.255 10.200.224.1
. 2021.02.10 00:28:43 - OpenVPN > C:\WINDOWS\system32\route.exe ADD 0.0.0.0 MASK 128.0.0.0 10.22.227.1
. 2021.02.10 00:28:43 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=25 and dwForwardType=4
. 2021.02.10 00:28:43 - OpenVPN > C:\WINDOWS\system32\route.exe ADD 128.0.0.0 MASK 128.0.0.0 10.22.227.1
. 2021.02.10 00:28:43 - OpenVPN > add_route_ipv6(::/3 -> fde6:7a:7d20:12e3::1 metric -1) dev Local Area Connection 2
. 2021.02.10 00:28:43 - OpenVPN > C:\WINDOWS\system32\netsh.exe interface ipv6 add route ::/3 16 fe80::8 store=active
. 2021.02.10 00:28:43 - OpenVPN > env_block: add PATH=C:\WINDOWS\System32;C:\WINDOWS;C:\WINDOWS\System32\Wbem
E 2021.02.10 00:28:43 - OpenVPN > ERROR: Windows route add ipv6 command failed: returned error code 1
. 2021.02.10 00:28:43 - OpenVPN > add_route_ipv6(2000::/4 -> fde6:7a:7d20:12e3::1 metric -1) dev Local Area Connection 2
. 2021.02.10 00:28:43 - OpenVPN > C:\WINDOWS\system32\netsh.exe interface ipv6 add route 2000::/4 16 fe80::8 store=active
. 2021.02.10 00:28:43 - OpenVPN > add_route_ipv6(3000::/4 -> fde6:7a:7d20:12e3::1 metric -1) dev Local Area Connection 2
. 2021.02.10 00:28:43 - OpenVPN > C:\WINDOWS\system32\netsh.exe interface ipv6 add route 3000::/4 16 fe80::8 store=active
. 2021.02.10 00:28:43 - OpenVPN > add_route_ipv6(fc00::/7 -> fde6:7a:7d20:12e3::1 metric -1) dev Local Area Connection 2
. 2021.02.10 00:28:43 - OpenVPN > C:\WINDOWS\system32\netsh.exe interface ipv6 add route fc00::/7 16 fe80::8 store=active
. 2021.02.10 00:28:43 - Interface Local Area Connection 2 metric changed from Automatic to 3, layer IPv4
. 2021.02.10 00:28:43 - Interface Local Area Connection 2 metric changed from Automatic to 3, layer IPv6
. 2021.02.10 00:28:43 - DNS leak protection with packet filtering enabled.
. 2021.02.10 00:28:44 - DNS IPv4 of a network adapter forced (Local Area Connection 2, from automatic to 10.22.227.1)
. 2021.02.10 00:28:44 - DNS IPv6 of a network adapter forced (Local Area Connection 2, from automatic to fde6:7a:7d20:12e3::1)
. 2021.02.10 00:28:44 - Routes, added a new route, 64.42.179.59 for gateway 10.22.227.1
. 2021.02.10 00:28:44 - Routes, added a new route, 2605:9f80:6000:80:fc8c:43ee:267e:97ab for gateway fde6:7a:7d20:12e3::1
. 2021.02.10 00:28:44 - Flushing DNS
I 2021.02.10 00:28:44 - Checking route IPv4
I 2021.02.10 00:28:44 - Checking route IPv6
. 2021.02.10 00:29:06 - Fetch url error:Timeout was reached
. 2021.02.10 00:29:06 - Checking route (2° try)
. 2021.02.10 00:29:28 - Fetch url error:Timeout was reached
. 2021.02.10 00:29:28 - Checking route (3° try)
. 2021.02.10 00:29:52 - Fetch url error:Timeout was reached
E 2021.02.10 00:29:52 - Checking route IPv6 failed.
. 2021.02.10 00:29:52 - OpenVPN > Initialization Sequence Completed
! 2021.02.10 00:29:52 - Disconnecting
. 2021.02.10 00:29:52 - Routes, removed a route previously added, 64.42.179.59 for gateway 10.22.227.1
. 2021.02.10 00:29:52 - Routes, removed a route previously added, 2605:9f80:6000:80:fc8c:43ee:267e:97ab for gateway fde6:7a:7d20:12e3::1
. 2021.02.10 00:29:52 - Sending soft termination signal
. 2021.02.10 00:29:55 - Connection terminated.
. 2021.02.10 00:29:55 - DNS IPv4 of a network adapter restored to original settings (Local Area Connection 2, to automatic)
. 2021.02.10 00:29:55 - DNS IPv6 of a network adapter restored to original settings (Local Area Connection 2, to automatic)
. 2021.02.10 00:29:55 - DNS leak protection with packet filtering disabled.
. 2021.02.10 00:29:55 - Interface Local Area Connection 2 metric restored from 3 to Automatic, layer IPv4
. 2021.02.10 00:29:55 - Interface Local Area Connection 2 metric restored from 3 to Automatic, layer IPv6
. 2021.02.10 00:29:55 - OpenVPN > C:\WINDOWS\system32\route.exe DELETE 64.42.179.61 MASK 255.255.255.255 10.200.224.1
. 2021.02.10 00:29:55 - OpenVPN > Route deletion via IPAPI succeeded [adaptive]
. 2021.02.10 00:29:55 - OpenVPN > C:\WINDOWS\system32\route.exe DELETE 10.200.103.56 MASK 255.255.255.255 10.200.224.1
. 2021.02.10 00:29:55 - OpenVPN > C:\WINDOWS\system32\route.exe DELETE 0.0.0.0 MASK 128.0.0.0 10.22.227.1
. 2021.02.10 00:29:55 - OpenVPN > C:\WINDOWS\system32\route.exe DELETE 128.0.0.0 MASK 128.0.0.0 10.22.227.1
. 2021.02.10 00:29:55 - OpenVPN > Closing TUN/TAP interface
. 2021.02.10 00:29:55 - OpenVPN > NETSH: C:\WINDOWS\system32\netsh.exe interface ipv6 delete dns 16 all
. 2021.02.10 00:29:55 - OpenVPN > delete_route_ipv6(fde6:7a:7d20:12e3::/64)
. 2021.02.10 00:29:55 - OpenVPN > C:\WINDOWS\system32\netsh.exe interface ipv6 delete route fde6:7a:7d20:12e3::/64 16 fe80::8 store=active
. 2021.02.10 00:29:55 - OpenVPN > NETSH: C:\WINDOWS\system32\netsh.exe interface ipv6 delete address 16 fde6:7a:7d20:12e3::1010 store=active
. 2021.02.10 00:29:55 - OpenVPN > TAP: DHCP address released
. 2021.02.10 00:29:55 - OpenVPN > SIGTERM[hard,] received, process exiting
I 2021.02.10 00:29:58 - Checking authorization ...
! 2021.02.10 00:29:59 - Connecting to Pegasus (United States of America, Dallas, Texas)
. 2021.02.10 00:29:59 - OpenVPN > OpenVPN 2.5.0 x86_64-w64-mingw32 [SSL (OpenSSL)] [LZO] [LZ4] [PKCS11] [AEAD] built on Oct 28 2020
. 2021.02.10 00:29:59 - OpenVPN > Windows version 10.0 (Windows 10 or greater) 64bit
. 2021.02.10 00:29:59 - OpenVPN > library versions: OpenSSL 1.1.1h  22 Sep 2020, LZO 2.10
. 2021.02.10 00:29:59 - OpenVPN > Outgoing Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key
. 2021.02.10 00:29:59 - OpenVPN > Outgoing Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication
. 2021.02.10 00:29:59 - OpenVPN > Incoming Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key
. 2021.02.10 00:29:59 - OpenVPN > Incoming Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication
. 2021.02.10 00:29:59 - OpenVPN > TCP/UDP: Preserving recently used remote address: [AF_INET]199.249.230.19:443
. 2021.02.10 00:29:59 - OpenVPN > Socket Buffers: R=[65536->65536] S=[65536->65536]
. 2021.02.10 00:29:59 - OpenVPN > Attempting to establish TCP connection with [AF_INET]199.249.230.19:443 [nonblock]
. 2021.02.10 00:29:59 - OpenVPN > TCP connection established with [AF_INET]199.249.230.19:443
. 2021.02.10 00:29:59 - OpenVPN > TCP_CLIENT link local: (not bound)
. 2021.02.10 00:29:59 - OpenVPN > TCP_CLIENT link remote: [AF_INET]199.249.230.19:443
. 2021.02.10 00:29:59 - OpenVPN > TLS: Initial packet from [AF_INET]199.249.230.19:443, sid=1786bcb4 7d1e906d
. 2021.02.10 00:29:59 - OpenVPN > VERIFY KU OK
. 2021.02.10 00:29:59 - OpenVPN > Validating certificate extended key usage
. 2021.02.10 00:29:59 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
. 2021.02.10 00:29:59 - OpenVPN > VERIFY EKU OK
. 2021.02.10 00:29:59 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=Pegasus, emailAddress=info@airvpn.org
. 2021.02.10 00:29:59 - OpenVPN > Control Channel: TLSv1.3, cipher TLSv1.3 TLS_CHACHA20_POLY1305_SHA256, 4096 bit RSA
. 2021.02.10 00:29:59 - OpenVPN > [Pegasus] Peer Connection Initiated with [AF_INET]199.249.230.19:443
. 2021.02.10 00:30:00 - OpenVPN > SENT CONTROL [Pegasus]: 'PUSH_REQUEST' (status=1)
. 2021.02.10 00:30:00 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,comp-lzo no,redirect-gateway ipv6 def1 bypass-dhcp,dhcp-option DNS 10.26.67.1,dhcp-option DNS6 fde6:7a:7d20:1643::1,tun-ipv6,route-gateway 10.26.67.1,topology subnet,ping 10,ping-restart 60,ifconfig-ipv6 fde6:7a:7d20:1643::1012/64 fde6:7a:7d20:1643::1,ifconfig 10.26.67.20 255.255.255.0,peer-id 0,cipher AES-256-GCM'
. 2021.02.10 00:30:00 - OpenVPN > Pushed option removed by filter: 'redirect-gateway ipv6 def1 bypass-dhcp'
. 2021.02.10 00:30:00 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified
. 2021.02.10 00:30:00 - OpenVPN > OPTIONS IMPORT: compression parms modified
. 2021.02.10 00:30:00 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified
. 2021.02.10 00:30:00 - OpenVPN > OPTIONS IMPORT: route-related options modified
. 2021.02.10 00:30:00 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified
. 2021.02.10 00:30:00 - OpenVPN > OPTIONS IMPORT: peer-id set
. 2021.02.10 00:30:00 - OpenVPN > OPTIONS IMPORT: adjusting link_mtu to 1627
. 2021.02.10 00:30:00 - OpenVPN > OPTIONS IMPORT: data channel crypto options modified
. 2021.02.10 00:30:00 - OpenVPN > Data Channel: using negotiated cipher 'AES-256-GCM'
. 2021.02.10 00:30:00 - OpenVPN > Outgoing Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key
. 2021.02.10 00:30:00 - OpenVPN > Incoming Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key
. 2021.02.10 00:30:00 - OpenVPN > interactive service msg_channel=0
. 2021.02.10 00:30:00 - OpenVPN > ROUTE_GATEWAY 10.200.224.1/255.255.248.0 I=5 HWADDR=b4:ae:2b:d6:3d:12
. 2021.02.10 00:30:00 - OpenVPN > ROUTE: bypass_host_route[0]=10.200.103.56
. 2021.02.10 00:30:00 - OpenVPN > GDG6: remote_host_ipv6=n/a
. 2021.02.10 00:30:00 - OpenVPN > GetBestInterfaceEx() returned if=16
. 2021.02.10 00:30:00 - OpenVPN > GDG6: II=16 DP=::/3 NH=fe80::8
. 2021.02.10 00:30:00 - OpenVPN > GDG6: Metric=256, Loopback=0, AA=1, I=0
. 2021.02.10 00:30:00 - OpenVPN > ROUTE6_GATEWAY fe80::8 I=16
. 2021.02.10 00:30:00 - OpenVPN > open_tun
. 2021.02.10 00:30:00 - OpenVPN > tap-windows6 device [Local Area Connection 2] opened
. 2021.02.10 00:30:00 - OpenVPN > TAP-Windows Driver Version 9.24
. 2021.02.10 00:30:00 - OpenVPN > Set TAP-Windows TUN subnet mode network/local/netmask = 10.26.67.0/10.26.67.20/255.255.255.0 [SUCCEEDED]
. 2021.02.10 00:30:00 - OpenVPN > Notified TAP-Windows driver to set a DHCP IP/netmask of 10.26.67.20/255.255.255.0 on interface {C08F2B39-6B49-47C9-B994-D5F695969509} [DHCP-serv: 10.26.67.254, lease-time: 31536000]
. 2021.02.10 00:30:00 - OpenVPN > Successful ARP Flush on interface [16] {C08F2B39-6B49-47C9-B994-D5F695969509}
. 2021.02.10 00:30:00 - OpenVPN > IPv4 MTU set to 1500 on interface 16 using SetIpInterfaceEntry()
. 2021.02.10 00:30:01 - OpenVPN > NETSH: C:\WINDOWS\system32\netsh.exe interface ipv6 set address 16 fde6:7a:7d20:1643::1012/128 store=active
. 2021.02.10 00:30:01 - OpenVPN > add_route_ipv6(fde6:7a:7d20:1643::/64 -> fde6:7a:7d20:1643::1012 metric 0) dev Local Area Connection 2
. 2021.02.10 00:30:01 - OpenVPN > C:\WINDOWS\system32\netsh.exe interface ipv6 add route fde6:7a:7d20:1643::/64 16 fe80::8 store=active
. 2021.02.10 00:30:01 - OpenVPN > env_block: add PATH=C:\WINDOWS\System32;C:\WINDOWS;C:\WINDOWS\System32\Wbem
. 2021.02.10 00:30:02 - OpenVPN > NETSH: C:\WINDOWS\system32\netsh.exe interface ipv6 delete dns 16 all
. 2021.02.10 00:30:03 - OpenVPN > NETSH: C:\WINDOWS\system32\netsh.exe interface ipv6 set dns 16 static fde6:7a:7d20:1643::1 validate=no
. 2021.02.10 00:30:03 - OpenVPN > IPv6 MTU set to 1500 on interface 16 using SetIpInterfaceEntry()
. 2021.02.10 00:30:08 - OpenVPN > TEST ROUTES: 1/1 succeeded len=0 ret=1 a=0 u/d=up
. 2021.02.10 00:30:08 - OpenVPN > C:\WINDOWS\system32\route.exe ADD 199.249.230.19 MASK 255.255.255.255 10.200.224.1
. 2021.02.10 00:30:08 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=50 and dwForwardType=4
. 2021.02.10 00:30:08 - OpenVPN > Route addition via IPAPI succeeded [adaptive]
. 2021.02.10 00:30:08 - OpenVPN > C:\WINDOWS\system32\route.exe ADD 10.200.103.56 MASK 255.255.255.255 10.200.224.1
. 2021.02.10 00:30:08 - OpenVPN > C:\WINDOWS\system32\route.exe ADD 0.0.0.0 MASK 128.0.0.0 10.26.67.1
. 2021.02.10 00:30:08 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=25 and dwForwardType=4
. 2021.02.10 00:30:08 - OpenVPN > C:\WINDOWS\system32\route.exe ADD 128.0.0.0 MASK 128.0.0.0 10.26.67.1
. 2021.02.10 00:30:08 - OpenVPN > add_route_ipv6(::/3 -> fde6:7a:7d20:1643::1 metric -1) dev Local Area Connection 2
. 2021.02.10 00:30:08 - OpenVPN > C:\WINDOWS\system32\netsh.exe interface ipv6 add route ::/3 16 fe80::8 store=active
. 2021.02.10 00:30:08 - OpenVPN > env_block: add PATH=C:\WINDOWS\System32;C:\WINDOWS;C:\WINDOWS\System32\Wbem
E 2021.02.10 00:30:08 - OpenVPN > ERROR: Windows route add ipv6 command failed: returned error code 1
. 2021.02.10 00:30:08 - OpenVPN > add_route_ipv6(2000::/4 -> fde6:7a:7d20:1643::1 metric -1) dev Local Area Connection 2
. 2021.02.10 00:30:08 - OpenVPN > C:\WINDOWS\system32\netsh.exe interface ipv6 add route 2000::/4 16 fe80::8 store=active
. 2021.02.10 00:30:08 - OpenVPN > add_route_ipv6(3000::/4 -> fde6:7a:7d20:1643::1 metric -1) dev Local Area Connection 2
. 2021.02.10 00:30:08 - OpenVPN > C:\WINDOWS\system32\netsh.exe interface ipv6 add route 3000::/4 16 fe80::8 store=active
. 2021.02.10 00:30:08 - OpenVPN > add_route_ipv6(fc00::/7 -> fde6:7a:7d20:1643::1 metric -1) dev Local Area Connection 2
. 2021.02.10 00:30:08 - OpenVPN > C:\WINDOWS\system32\netsh.exe interface ipv6 add route fc00::/7 16 fe80::8 store=active
. 2021.02.10 00:30:08 - Interface Local Area Connection 2 metric changed from Automatic to 3, layer IPv4
. 2021.02.10 00:30:08 - Interface Local Area Connection 2 metric changed from Automatic to 3, layer IPv6
. 2021.02.10 00:30:08 - DNS leak protection with packet filtering enabled.
. 2021.02.10 00:30:09 - DNS IPv4 of a network adapter forced (Local Area Connection 2, from automatic to 10.26.67.1)
. 2021.02.10 00:30:09 - DNS IPv6 of a network adapter forced (Local Area Connection 2, from automatic to fde6:7a:7d20:1643::1)
. 2021.02.10 00:30:09 - Routes, added a new route, 199.249.230.17 for gateway 10.26.67.1
. 2021.02.10 00:30:09 - Routes, added a new route, 2620:7:6001:4e52:a86b:24a6:b8b7:c4dd for gateway fde6:7a:7d20:1643::1
. 2021.02.10 00:30:09 - Flushing DNS
I 2021.02.10 00:30:09 - Checking route IPv4
I 2021.02.10 00:30:10 - Checking route IPv6
. 2021.02.10 00:30:31 - Fetch url error:Timeout was reached
. 2021.02.10 00:30:31 - Checking route (2° try)
. 2021.02.10 00:30:54 - Fetch url error:Timeout was reached
. 2021.02.10 00:30:54 - Checking route (3° try)
. 2021.02.10 00:31:17 - Fetch url error:Timeout was reached
E 2021.02.10 00:31:17 - Checking route IPv6 failed.
. 2021.02.10 00:31:17 - OpenVPN > Initialization Sequence Completed
! 2021.02.10 00:31:17 - Disconnecting
. 2021.02.10 00:31:17 - Routes, removed a route previously added, 199.249.230.17 for gateway 10.26.67.1
. 2021.02.10 00:31:17 - Routes, removed a route previously added, 2620:7:6001:4e52:a86b:24a6:b8b7:c4dd for gateway fde6:7a:7d20:1643::1
. 2021.02.10 00:31:17 - Sending soft termination signal
. 2021.02.10 00:31:21 - Connection terminated.
. 2021.02.10 00:31:21 - DNS IPv4 of a network adapter restored to original settings (Local Area Connection 2, to automatic)
. 2021.02.10 00:31:21 - DNS IPv6 of a network adapter restored to original settings (Local Area Connection 2, to automatic)
. 2021.02.10 00:31:21 - DNS leak protection with packet filtering disabled.
. 2021.02.10 00:31:21 - Interface Local Area Connection 2 metric restored from 3 to Automatic, layer IPv4
. 2021.02.10 00:31:21 - Interface Local Area Connection 2 metric restored from 3 to Automatic, layer IPv6
. 2021.02.10 00:31:21 - OpenVPN > C:\WINDOWS\system32\route.exe DELETE 199.249.230.19 MASK 255.255.255.255 10.200.224.1
. 2021.02.10 00:31:21 - OpenVPN > Route deletion via IPAPI succeeded [adaptive]
. 2021.02.10 00:31:21 - OpenVPN > C:\WINDOWS\system32\route.exe DELETE 10.200.103.56 MASK 255.255.255.255 10.200.224.1
. 2021.02.10 00:31:21 - OpenVPN > C:\WINDOWS\system32\route.exe DELETE 0.0.0.0 MASK 128.0.0.0 10.26.67.1
. 2021.02.10 00:31:21 - OpenVPN > C:\WINDOWS\system32\route.exe DELETE 128.0.0.0 MASK 128.0.0.0 10.26.67.1
. 2021.02.10 00:31:21 - OpenVPN > Closing TUN/TAP interface
. 2021.02.10 00:31:21 - OpenVPN > NETSH: C:\WINDOWS\system32\netsh.exe interface ipv6 delete dns 16 all
. 2021.02.10 00:31:21 - OpenVPN > delete_route_ipv6(fde6:7a:7d20:1643::/64)
. 2021.02.10 00:31:21 - OpenVPN > C:\WINDOWS\system32\netsh.exe interface ipv6 delete route fde6:7a:7d20:1643::/64 16 fe80::8 store=active
. 2021.02.10 00:31:21 - OpenVPN > NETSH: C:\WINDOWS\system32\netsh.exe interface ipv6 delete address 16 fde6:7a:7d20:1643::1012 store=active
. 2021.02.10 00:31:21 - OpenVPN > TAP: DHCP address released
. 2021.02.10 00:31:21 - OpenVPN > SIGTERM[hard,] received, process exiting
I 2021.02.10 00:31:24 - Checking authorization ...
! 2021.02.10 00:31:25 - Connecting to Acamar (United States of America, Miami)
. 2021.02.10 00:31:25 - OpenVPN > OpenVPN 2.5.0 x86_64-w64-mingw32 [SSL (OpenSSL)] [LZO] [LZ4] [PKCS11] [AEAD] built on Oct 28 2020
. 2021.02.10 00:31:25 - OpenVPN > Windows version 10.0 (Windows 10 or greater) 64bit
. 2021.02.10 00:31:25 - OpenVPN > library versions: OpenSSL 1.1.1h  22 Sep 2020, LZO 2.10
. 2021.02.10 00:31:25 - OpenVPN > Outgoing Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key
. 2021.02.10 00:31:25 - OpenVPN > Outgoing Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication
. 2021.02.10 00:31:25 - OpenVPN > Incoming Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key
. 2021.02.10 00:31:25 - OpenVPN > Incoming Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication
. 2021.02.10 00:31:25 - OpenVPN > TCP/UDP: Preserving recently used remote address: [AF_INET]173.44.55.157:443
. 2021.02.10 00:31:25 - OpenVPN > Socket Buffers: R=[65536->65536] S=[65536->65536]
. 2021.02.10 00:31:25 - OpenVPN > Attempting to establish TCP connection with [AF_INET]173.44.55.157:443 [nonblock]
. 2021.02.10 00:31:25 - OpenVPN > TCP connection established with [AF_INET]173.44.55.157:443
. 2021.02.10 00:31:25 - OpenVPN > TCP_CLIENT link local: (not bound)
. 2021.02.10 00:31:25 - OpenVPN > TCP_CLIENT link remote: [AF_INET]173.44.55.157:443
. 2021.02.10 00:31:25 - OpenVPN > TLS: Initial packet from [AF_INET]173.44.55.157:443, sid=493f38bf 5bcad500
. 2021.02.10 00:31:25 - OpenVPN > VERIFY KU OK
. 2021.02.10 00:31:25 - OpenVPN > Validating certificate extended key usage
. 2021.02.10 00:31:25 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
. 2021.02.10 00:31:25 - OpenVPN > VERIFY EKU OK
. 2021.02.10 00:31:25 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=Acamar, emailAddress=info@airvpn.org
. 2021.02.10 00:31:25 - OpenVPN > Control Channel: TLSv1.3, cipher TLSv1.3 TLS_CHACHA20_POLY1305_SHA256, 4096 bit RSA
. 2021.02.10 00:31:25 - OpenVPN > [Acamar] Peer Connection Initiated with [AF_INET]173.44.55.157:443
. 2021.02.10 00:31:26 - OpenVPN > SENT CONTROL [Acamar]: 'PUSH_REQUEST' (status=1)
. 2021.02.10 00:31:26 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,comp-lzo no,redirect-gateway ipv6 def1 bypass-dhcp,dhcp-option DNS 10.4.67.1,dhcp-option DNS6 fde6:7a:7d20:43::1,tun-ipv6,route-gateway 10.4.67.1,topology subnet,ping 10,ping-restart 60,ifconfig-ipv6 fde6:7a:7d20:43::1021/64 fde6:7a:7d20:43::1,ifconfig 10.4.67.35 255.255.255.0,peer-id 0,cipher AES-256-GCM'
. 2021.02.10 00:31:26 - OpenVPN > Pushed option removed by filter: 'redirect-gateway ipv6 def1 bypass-dhcp'
. 2021.02.10 00:31:26 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified
. 2021.02.10 00:31:26 - OpenVPN > OPTIONS IMPORT: compression parms modified
. 2021.02.10 00:31:26 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified
. 2021.02.10 00:31:26 - OpenVPN > OPTIONS IMPORT: route-related options modified
. 2021.02.10 00:31:26 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified
. 2021.02.10 00:31:26 - OpenVPN > OPTIONS IMPORT: peer-id set
. 2021.02.10 00:31:26 - OpenVPN > OPTIONS IMPORT: adjusting link_mtu to 1627
. 2021.02.10 00:31:26 - OpenVPN > OPTIONS IMPORT: data channel crypto options modified
. 2021.02.10 00:31:26 - OpenVPN > Data Channel: using negotiated cipher 'AES-256-GCM'
. 2021.02.10 00:31:26 - OpenVPN > Outgoing Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key
. 2021.02.10 00:31:26 - OpenVPN > Incoming Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key
. 2021.02.10 00:31:26 - OpenVPN > interactive service msg_channel=0
. 2021.02.10 00:31:26 - OpenVPN > ROUTE_GATEWAY 10.200.224.1/255.255.248.0 I=5 HWADDR=b4:ae:2b:d6:3d:12
. 2021.02.10 00:31:26 - OpenVPN > ROUTE: bypass_host_route[0]=10.200.103.56
. 2021.02.10 00:31:26 - OpenVPN > GDG6: remote_host_ipv6=n/a
. 2021.02.10 00:31:26 - OpenVPN > GetBestInterfaceEx() returned if=16
. 2021.02.10 00:31:26 - OpenVPN > GDG6: II=16 DP=::/3 NH=fe80::8
. 2021.02.10 00:31:26 - OpenVPN > GDG6: Metric=256, Loopback=0, AA=1, I=0
. 2021.02.10 00:31:26 - OpenVPN > ROUTE6_GATEWAY fe80::8 I=16
. 2021.02.10 00:31:26 - OpenVPN > open_tun
. 2021.02.10 00:31:26 - OpenVPN > tap-windows6 device [Local Area Connection 2] opened
. 2021.02.10 00:31:26 - OpenVPN > TAP-Windows Driver Version 9.24
. 2021.02.10 00:31:26 - OpenVPN > Set TAP-Windows TUN subnet mode network/local/netmask = 10.4.67.0/10.4.67.35/255.255.255.0 [SUCCEEDED]
. 2021.02.10 00:31:26 - OpenVPN > Notified TAP-Windows driver to set a DHCP IP/netmask of 10.4.67.35/255.255.255.0 on interface {C08F2B39-6B49-47C9-B994-D5F695969509} [DHCP-serv: 10.4.67.254, lease-time: 31536000]
. 2021.02.10 00:31:26 - OpenVPN > Successful ARP Flush on interface [16] {C08F2B39-6B49-47C9-B994-D5F695969509}
. 2021.02.10 00:31:26 - OpenVPN > IPv4 MTU set to 1500 on interface 16 using SetIpInterfaceEntry()
. 2021.02.10 00:31:27 - OpenVPN > NETSH: C:\WINDOWS\system32\netsh.exe interface ipv6 set address 16 fde6:7a:7d20:43::1021/128 store=active
. 2021.02.10 00:31:27 - OpenVPN > add_route_ipv6(fde6:7a:7d20:43::/64 -> fde6:7a:7d20:43::1021 metric 0) dev Local Area Connection 2
. 2021.02.10 00:31:27 - OpenVPN > C:\WINDOWS\system32\netsh.exe interface ipv6 add route fde6:7a:7d20:43::/64 16 fe80::8 store=active
. 2021.02.10 00:31:27 - OpenVPN > env_block: add PATH=C:\WINDOWS\System32;C:\WINDOWS;C:\WINDOWS\System32\Wbem
. 2021.02.10 00:31:28 - OpenVPN > NETSH: C:\WINDOWS\system32\netsh.exe interface ipv6 delete dns 16 all
. 2021.02.10 00:31:29 - OpenVPN > NETSH: C:\WINDOWS\system32\netsh.exe interface ipv6 set dns 16 static fde6:7a:7d20:43::1 validate=no
. 2021.02.10 00:31:29 - OpenVPN > IPv6 MTU set to 1500 on interface 16 using SetIpInterfaceEntry()
. 2021.02.10 00:31:34 - OpenVPN > TEST ROUTES: 1/1 succeeded len=0 ret=1 a=0 u/d=up
. 2021.02.10 00:31:34 - OpenVPN > C:\WINDOWS\system32\route.exe ADD 173.44.55.157 MASK 255.255.255.255 10.200.224.1
. 2021.02.10 00:31:34 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=50 and dwForwardType=4
. 2021.02.10 00:31:34 - OpenVPN > Route addition via IPAPI succeeded [adaptive]
. 2021.02.10 00:31:34 - OpenVPN > C:\WINDOWS\system32\route.exe ADD 10.200.103.56 MASK 255.255.255.255 10.200.224.1
. 2021.02.10 00:31:34 - OpenVPN > C:\WINDOWS\system32\route.exe ADD 0.0.0.0 MASK 128.0.0.0 10.4.67.1
. 2021.02.10 00:31:34 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=25 and dwForwardType=4
. 2021.02.10 00:31:34 - OpenVPN > C:\WINDOWS\system32\route.exe ADD 128.0.0.0 MASK 128.0.0.0 10.4.67.1
. 2021.02.10 00:31:34 - OpenVPN > add_route_ipv6(::/3 -> fde6:7a:7d20:43::1 metric -1) dev Local Area Connection 2
. 2021.02.10 00:31:34 - OpenVPN > C:\WINDOWS\system32\netsh.exe interface ipv6 add route ::/3 16 fe80::8 store=active
. 2021.02.10 00:31:34 - OpenVPN > env_block: add PATH=C:\WINDOWS\System32;C:\WINDOWS;C:\WINDOWS\System32\Wbem
E 2021.02.10 00:31:34 - OpenVPN > ERROR: Windows route add ipv6 command failed: returned error code 1
. 2021.02.10 00:31:34 - OpenVPN > add_route_ipv6(2000::/4 -> fde6:7a:7d20:43::1 metric -1) dev Local Area Connection 2
. 2021.02.10 00:31:34 - OpenVPN > C:\WINDOWS\system32\netsh.exe interface ipv6 add route 2000::/4 16 fe80::8 store=active
. 2021.02.10 00:31:34 - OpenVPN > add_route_ipv6(3000::/4 -> fde6:7a:7d20:43::1 metric -1) dev Local Area Connection 2
. 2021.02.10 00:31:34 - OpenVPN > C:\WINDOWS\system32\netsh.exe interface ipv6 add route 3000::/4 16 fe80::8 store=active
. 2021.02.10 00:31:34 - OpenVPN > add_route_ipv6(fc00::/7 -> fde6:7a:7d20:43::1 metric -1) dev Local Area Connection 2
. 2021.02.10 00:31:34 - OpenVPN > C:\WINDOWS\system32\netsh.exe interface ipv6 add route fc00::/7 16 fe80::8 store=active
. 2021.02.10 00:31:34 - Interface Local Area Connection 2 metric changed from Automatic to 3, layer IPv4
. 2021.02.10 00:31:34 - Interface Local Area Connection 2 metric changed from Automatic to 3, layer IPv6
. 2021.02.10 00:31:34 - DNS leak protection with packet filtering enabled.
. 2021.02.10 00:31:35 - DNS IPv4 of a network adapter forced (Local Area Connection 2, from automatic to 10.4.67.1)
. 2021.02.10 00:31:35 - DNS IPv6 of a network adapter forced (Local Area Connection 2, from automatic to fde6:7a:7d20:43::1)
. 2021.02.10 00:31:35 - Routes, added a new route, 173.44.55.155 for gateway 10.4.67.1
. 2021.02.10 00:31:35 - Routes, added a new route, 2607:ff48:aa81:200:89bd:a0e5:6626:b661 for gateway fde6:7a:7d20:43::1
. 2021.02.10 00:31:35 - Flushing DNS
I 2021.02.10 00:31:35 - Checking route IPv4
I 2021.02.10 00:31:36 - Checking route IPv6
. 2021.02.10 00:31:57 - Fetch url error:Timeout was reached
. 2021.02.10 00:31:57 - Checking route (2° try)
. 2021.02.10 00:32:19 - Fetch url error:Timeout was reached
. 2021.02.10 00:32:19 - Checking route (3° try)
. 2021.02.10 00:32:43 - Fetch url error:Timeout was reached
E 2021.02.10 00:32:43 - Checking route IPv6 failed.
. 2021.02.10 00:32:43 - OpenVPN > Initialization Sequence Completed
! 2021.02.10 00:32:43 - Disconnecting
. 2021.02.10 00:32:43 - Routes, removed a route previously added, 173.44.55.155 for gateway 10.4.67.1
. 2021.02.10 00:32:43 - Routes, removed a route previously added, 2607:ff48:aa81:200:89bd:a0e5:6626:b661 for gateway fde6:7a:7d20:43::1
. 2021.02.10 00:32:43 - Sending soft termination signal
. 2021.02.10 00:32:46 - Connection terminated.
. 2021.02.10 00:32:46 - DNS IPv4 of a network adapter restored to original settings (Local Area Connection 2, to automatic)
. 2021.02.10 00:32:46 - DNS IPv6 of a network adapter restored to original settings (Local Area Connection 2, to automatic)
. 2021.02.10 00:32:46 - DNS leak protection with packet filtering disabled.
. 2021.02.10 00:32:46 - Interface Local Area Connection 2 metric restored from 3 to Automatic, layer IPv4
. 2021.02.10 00:32:46 - Interface Local Area Connection 2 metric restored from 3 to Automatic, layer IPv6
. 2021.02.10 00:32:46 - OpenVPN > C:\WINDOWS\system32\route.exe DELETE 173.44.55.157 MASK 255.255.255.255 10.200.224.1
. 2021.02.10 00:32:46 - OpenVPN > Route deletion via IPAPI succeeded [adaptive]
. 2021.02.10 00:32:46 - OpenVPN > C:\WINDOWS\system32\route.exe DELETE 10.200.103.56 MASK 255.255.255.255 10.200.224.1
. 2021.02.10 00:32:46 - OpenVPN > C:\WINDOWS\system32\route.exe DELETE 0.0.0.0 MASK 128.0.0.0 10.4.67.1
. 2021.02.10 00:32:46 - OpenVPN > C:\WINDOWS\system32\route.exe DELETE 128.0.0.0 MASK 128.0.0.0 10.4.67.1
. 2021.02.10 00:32:46 - OpenVPN > Closing TUN/TAP interface
. 2021.02.10 00:32:46 - OpenVPN > NETSH: C:\WINDOWS\system32\netsh.exe interface ipv6 delete dns 16 all
. 2021.02.10 00:32:46 - OpenVPN > delete_route_ipv6(fde6:7a:7d20:43::/64)
. 2021.02.10 00:32:46 - OpenVPN > C:\WINDOWS\system32\netsh.exe interface ipv6 delete route fde6:7a:7d20:43::/64 16 fe80::8 store=active
. 2021.02.10 00:32:46 - OpenVPN > NETSH: C:\WINDOWS\system32\netsh.exe interface ipv6 delete address 16 fde6:7a:7d20:43::1021 store=active
. 2021.02.10 00:32:46 - OpenVPN > TAP: DHCP address released
. 2021.02.10 00:32:46 - OpenVPN > SIGTERM[hard,] received, process exiting
. 2021.02.10 00:32:50 - Waiting for latency tests (4 to go)
I 2021.02.10 00:32:51 - Checking authorization ...
! 2021.02.10 00:32:51 - Connecting to Sneden (United States of America, Chicago, Illinois)
. 2021.02.10 00:32:51 - OpenVPN > OpenVPN 2.5.0 x86_64-w64-mingw32 [SSL (OpenSSL)] [LZO] [LZ4] [PKCS11] [AEAD] built on Oct 28 2020
. 2021.02.10 00:32:51 - OpenVPN > Windows version 10.0 (Windows 10 or greater) 64bit
. 2021.02.10 00:32:51 - OpenVPN > library versions: OpenSSL 1.1.1h  22 Sep 2020, LZO 2.10
. 2021.02.10 00:32:51 - OpenVPN > Outgoing Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key
. 2021.02.10 00:32:51 - OpenVPN > Outgoing Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication
. 2021.02.10 00:32:51 - OpenVPN > Incoming Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key
. 2021.02.10 00:32:51 - OpenVPN > Incoming Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication
. 2021.02.10 00:32:51 - OpenVPN > TCP/UDP: Preserving recently used remote address: [AF_INET]68.235.52.38:443
. 2021.02.10 00:32:51 - OpenVPN > Socket Buffers: R=[65536->65536] S=[65536->65536]
. 2021.02.10 00:32:51 - OpenVPN > Attempting to establish TCP connection with [AF_INET]68.235.52.38:443 [nonblock]
. 2021.02.10 00:32:51 - OpenVPN > TCP connection established with [AF_INET]68.235.52.38:443
. 2021.02.10 00:32:51 - OpenVPN > TCP_CLIENT link local: (not bound)
. 2021.02.10 00:32:51 - OpenVPN > TCP_CLIENT link remote: [AF_INET]68.235.52.38:443
. 2021.02.10 00:32:51 - OpenVPN > TLS: Initial packet from [AF_INET]68.235.52.38:443, sid=fe7ec22b 218c7f7c
. 2021.02.10 00:32:52 - OpenVPN > VERIFY KU OK
. 2021.02.10 00:32:52 - OpenVPN > Validating certificate extended key usage
. 2021.02.10 00:32:52 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
. 2021.02.10 00:32:52 - OpenVPN > VERIFY EKU OK
. 2021.02.10 00:32:52 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=Sneden, emailAddress=info@airvpn.org
. 2021.02.10 00:32:52 - OpenVPN > Control Channel: TLSv1.3, cipher TLSv1.3 TLS_CHACHA20_POLY1305_SHA256, 4096 bit RSA
. 2021.02.10 00:32:52 - OpenVPN > [Sneden] Peer Connection Initiated with [AF_INET]68.235.52.38:443
. 2021.02.10 00:32:52 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,comp-lzo no,redirect-gateway ipv6 def1 bypass-dhcp,dhcp-option DNS 10.30.163.1,dhcp-option DNS6 fde6:7a:7d20:1aa3::1,tun-ipv6,route-gateway 10.30.163.1,topology subnet,ping 10,ping-restart 60,ifconfig-ipv6 fde6:7a:7d20:1aa3::100e/64 fde6:7a:7d20:1aa3::1,ifconfig 10.30.163.16 255.255.255.0,peer-id 0,cipher AES-256-GCM'
. 2021.02.10 00:32:52 - OpenVPN > Pushed option removed by filter: 'redirect-gateway ipv6 def1 bypass-dhcp'
. 2021.02.10 00:32:52 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified
. 2021.02.10 00:32:52 - OpenVPN > OPTIONS IMPORT: compression parms modified
. 2021.02.10 00:32:52 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified
. 2021.02.10 00:32:52 - OpenVPN > OPTIONS IMPORT: route-related options modified
. 2021.02.10 00:32:52 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified
. 2021.02.10 00:32:52 - OpenVPN > OPTIONS IMPORT: peer-id set
. 2021.02.10 00:32:52 - OpenVPN > OPTIONS IMPORT: adjusting link_mtu to 1627
. 2021.02.10 00:32:52 - OpenVPN > OPTIONS IMPORT: data channel crypto options modified
. 2021.02.10 00:32:52 - OpenVPN > Data Channel: using negotiated cipher 'AES-256-GCM'
. 2021.02.10 00:32:52 - OpenVPN > Outgoing Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key
. 2021.02.10 00:32:52 - OpenVPN > Incoming Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key
. 2021.02.10 00:32:52 - OpenVPN > interactive service msg_channel=0
. 2021.02.10 00:32:52 - OpenVPN > ROUTE_GATEWAY 10.200.224.1/255.255.248.0 I=5 HWADDR=b4:ae:2b:d6:3d:12
. 2021.02.10 00:32:52 - OpenVPN > ROUTE: bypass_host_route[0]=10.200.103.56
. 2021.02.10 00:32:52 - OpenVPN > GDG6: remote_host_ipv6=n/a
. 2021.02.10 00:32:52 - OpenVPN > GetBestInterfaceEx() returned if=16
. 2021.02.10 00:32:52 - OpenVPN > GDG6: II=16 DP=::/3 NH=fe80::8
. 2021.02.10 00:32:52 - OpenVPN > GDG6: Metric=256, Loopback=0, AA=1, I=0
. 2021.02.10 00:32:52 - OpenVPN > ROUTE6_GATEWAY fe80::8 I=16
. 2021.02.10 00:32:52 - OpenVPN > open_tun
. 2021.02.10 00:32:52 - OpenVPN > tap-windows6 device [Local Area Connection 2] opened
. 2021.02.10 00:32:52 - OpenVPN > TAP-Windows Driver Version 9.24
. 2021.02.10 00:32:52 - OpenVPN > Set TAP-Windows TUN subnet mode network/local/netmask = 10.30.163.0/10.30.163.16/255.255.255.0 [SUCCEEDED]
. 2021.02.10 00:32:52 - OpenVPN > Notified TAP-Windows driver to set a DHCP IP/netmask of 10.30.163.16/255.255.255.0 on interface {C08F2B39-6B49-47C9-B994-D5F695969509} [DHCP-serv: 10.30.163.254, lease-time: 31536000]
. 2021.02.10 00:32:52 - OpenVPN > Successful ARP Flush on interface [16] {C08F2B39-6B49-47C9-B994-D5F695969509}
. 2021.02.10 00:32:52 - OpenVPN > IPv4 MTU set to 1500 on interface 16 using SetIpInterfaceEntry()
. 2021.02.10 00:32:53 - OpenVPN > NETSH: C:\WINDOWS\system32\netsh.exe interface ipv6 set address 16 fde6:7a:7d20:1aa3::100e/128 store=active
. 2021.02.10 00:32:53 - OpenVPN > add_route_ipv6(fde6:7a:7d20:1aa3::/64 -> fde6:7a:7d20:1aa3::100e metric 0) dev Local Area Connection 2
. 2021.02.10 00:32:53 - OpenVPN > C:\WINDOWS\system32\netsh.exe interface ipv6 add route fde6:7a:7d20:1aa3::/64 16 fe80::8 store=active
. 2021.02.10 00:32:53 - OpenVPN > env_block: add PATH=C:\WINDOWS\System32;C:\WINDOWS;C:\WINDOWS\System32\Wbem
. 2021.02.10 00:32:54 - OpenVPN > NETSH: C:\WINDOWS\system32\netsh.exe interface ipv6 delete dns 16 all
. 2021.02.10 00:32:55 - OpenVPN > NETSH: C:\WINDOWS\system32\netsh.exe interface ipv6 set dns 16 static fde6:7a:7d20:1aa3::1 validate=no
. 2021.02.10 00:32:56 - OpenVPN > IPv6 MTU set to 1500 on interface 16 using SetIpInterfaceEntry()
. 2021.02.10 00:33:01 - OpenVPN > TEST ROUTES: 1/1 succeeded len=0 ret=1 a=0 u/d=up
. 2021.02.10 00:33:01 - OpenVPN > C:\WINDOWS\system32\route.exe ADD 68.235.52.38 MASK 255.255.255.255 10.200.224.1
. 2021.02.10 00:33:01 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=50 and dwForwardType=4
. 2021.02.10 00:33:01 - OpenVPN > Route addition via IPAPI succeeded [adaptive]
. 2021.02.10 00:33:01 - OpenVPN > C:\WINDOWS\system32\route.exe ADD 10.200.103.56 MASK 255.255.255.255 10.200.224.1
. 2021.02.10 00:33:01 - OpenVPN > C:\WINDOWS\system32\route.exe ADD 0.0.0.0 MASK 128.0.0.0 10.30.163.1
. 2021.02.10 00:33:01 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=25 and dwForwardType=4
. 2021.02.10 00:33:01 - OpenVPN > C:\WINDOWS\system32\route.exe ADD 128.0.0.0 MASK 128.0.0.0 10.30.163.1
. 2021.02.10 00:33:01 - OpenVPN > add_route_ipv6(::/3 -> fde6:7a:7d20:1aa3::1 metric -1) dev Local Area Connection 2
. 2021.02.10 00:33:01 - OpenVPN > C:\WINDOWS\system32\netsh.exe interface ipv6 add route ::/3 16 fe80::8 store=active
. 2021.02.10 00:33:01 - OpenVPN > env_block: add PATH=C:\WINDOWS\System32;C:\WINDOWS;C:\WINDOWS\System32\Wbem
E 2021.02.10 00:33:01 - OpenVPN > ERROR: Windows route add ipv6 command failed: returned error code 1
. 2021.02.10 00:33:01 - OpenVPN > add_route_ipv6(2000::/4 -> fde6:7a:7d20:1aa3::1 metric -1) dev Local Area Connection 2
. 2021.02.10 00:33:01 - OpenVPN > C:\WINDOWS\system32\netsh.exe interface ipv6 add route 2000::/4 16 fe80::8 store=active
. 2021.02.10 00:33:01 - OpenVPN > add_route_ipv6(3000::/4 -> fde6:7a:7d20:1aa3::1 metric -1) dev Local Area Connection 2
. 2021.02.10 00:33:01 - OpenVPN > C:\WINDOWS\system32\netsh.exe interface ipv6 add route 3000::/4 16 fe80::8 store=active
. 2021.02.10 00:33:01 - OpenVPN > add_route_ipv6(fc00::/7 -> fde6:7a:7d20:1aa3::1 metric -1) dev Local Area Connection 2
. 2021.02.10 00:33:01 - OpenVPN > C:\WINDOWS\system32\netsh.exe interface ipv6 add route fc00::/7 16 fe80::8 store=active
. 2021.02.10 00:33:01 - Interface Local Area Connection 2 metric changed from Automatic to 3, layer IPv4
. 2021.02.10 00:33:01 - Interface Local Area Connection 2 metric changed from Automatic to 3, layer IPv6
. 2021.02.10 00:33:01 - DNS leak protection with packet filtering enabled.
. 2021.02.10 00:33:02 - DNS IPv4 of a network adapter forced (Local Area Connection 2, from automatic to 10.30.163.1)
. 2021.02.10 00:33:02 - DNS IPv6 of a network adapter forced (Local Area Connection 2, from automatic to fde6:7a:7d20:1aa3::1)
. 2021.02.10 00:33:02 - Routes, added a new route, 68.235.52.36 for gateway 10.30.163.1
. 2021.02.10 00:33:02 - Routes, added a new route, 2607:9000:0:3:36a4:cf80:2f7b:6990 for gateway fde6:7a:7d20:1aa3::1
. 2021.02.10 00:33:02 - Flushing DNS
I 2021.02.10 00:33:02 - Checking route IPv4
I 2021.02.10 00:33:03 - Checking route IPv6
. 2021.02.10 00:33:24 - Fetch url error:Timeout was reached
. 2021.02.10 00:33:24 - Checking route (2° try)
. 2021.02.10 00:33:47 - Fetch url error:Timeout was reached
. 2021.02.10 00:33:47 - Checking route (3° try)
. 2021.02.10 00:34:10 - Fetch url error:Timeout was reached
E 2021.02.10 00:34:10 - Checking route IPv6 failed.
. 2021.02.10 00:34:10 - OpenVPN > Initialization Sequence Completed
! 2021.02.10 00:34:10 - Disconnecting
. 2021.02.10 00:34:10 - Routes, removed a route previously added, 68.235.52.36 for gateway 10.30.163.1
. 2021.02.10 00:34:10 - Routes, removed a route previously added, 2607:9000:0:3:36a4:cf80:2f7b:6990 for gateway fde6:7a:7d20:1aa3::1
. 2021.02.10 00:34:10 - Sending soft termination signal
. 2021.02.10 00:34:13 - Connection terminated.
. 2021.02.10 00:34:14 - DNS IPv4 of a network adapter restored to original settings (Local Area Connection 2, to automatic)
. 2021.02.10 00:34:14 - DNS IPv6 of a network adapter restored to original settings (Local Area Connection 2, to automatic)
. 2021.02.10 00:34:14 - DNS leak protection with packet filtering disabled.
. 2021.02.10 00:34:14 - Interface Local Area Connection 2 metric restored from 3 to Automatic, layer IPv4
. 2021.02.10 00:34:14 - Interface Local Area Connection 2 metric restored from 3 to Automatic, layer IPv6
. 2021.02.10 00:34:14 - OpenVPN > C:\WINDOWS\system32\route.exe DELETE 68.235.52.38 MASK 255.255.255.255 10.200.224.1
. 2021.02.10 00:34:14 - OpenVPN > Route deletion via IPAPI succeeded [adaptive]
. 2021.02.10 00:34:14 - OpenVPN > C:\WINDOWS\system32\route.exe DELETE 10.200.103.56 MASK 255.255.255.255 10.200.224.1
. 2021.02.10 00:34:14 - OpenVPN > C:\WINDOWS\system32\route.exe DELETE 0.0.0.0 MASK 128.0.0.0 10.30.163.1
. 2021.02.10 00:34:14 - OpenVPN > C:\WINDOWS\system32\route.exe DELETE 128.0.0.0 MASK 128.0.0.0 10.30.163.1
. 2021.02.10 00:34:14 - OpenVPN > Closing TUN/TAP interface
. 2021.02.10 00:34:14 - OpenVPN > NETSH: C:\WINDOWS\system32\netsh.exe interface ipv6 delete dns 16 all
. 2021.02.10 00:34:14 - OpenVPN > delete_route_ipv6(fde6:7a:7d20:1aa3::/64)
. 2021.02.10 00:34:14 - OpenVPN > C:\WINDOWS\system32\netsh.exe interface ipv6 delete route fde6:7a:7d20:1aa3::/64 16 fe80::8 store=active
. 2021.02.10 00:34:14 - OpenVPN > NETSH: C:\WINDOWS\system32\netsh.exe interface ipv6 delete address 16 fde6:7a:7d20:1aa3::100e store=active
. 2021.02.10 00:34:14 - OpenVPN > TAP: DHCP address released
. 2021.02.10 00:34:14 - OpenVPN > SIGTERM[hard,] received, process exiting
I 2021.02.10 00:34:17 - Checking authorization ...
! 2021.02.10 00:34:17 - Connecting to Hercules (United States of America, Atlanta, Georgia)
. 2021.02.10 00:34:18 - OpenVPN > OpenVPN 2.5.0 x86_64-w64-mingw32 [SSL (OpenSSL)] [LZO] [LZ4] [PKCS11] [AEAD] built on Oct 28 2020
. 2021.02.10 00:34:18 - OpenVPN > Windows version 10.0 (Windows 10 or greater) 64bit
. 2021.02.10 00:34:18 - OpenVPN > library versions: OpenSSL 1.1.1h  22 Sep 2020, LZO 2.10
. 2021.02.10 00:34:18 - OpenVPN > Outgoing Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key
. 2021.02.10 00:34:18 - OpenVPN > Outgoing Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication
. 2021.02.10 00:34:18 - OpenVPN > Incoming Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key
. 2021.02.10 00:34:18 - OpenVPN > Incoming Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication
. 2021.02.10 00:34:18 - OpenVPN > TCP/UDP: Preserving recently used remote address: [AF_INET]64.42.179.61:443
. 2021.02.10 00:34:18 - OpenVPN > Socket Buffers: R=[65536->65536] S=[65536->65536]
. 2021.02.10 00:34:18 - OpenVPN > Attempting to establish TCP connection with [AF_INET]64.42.179.61:443 [nonblock]
. 2021.02.10 00:34:18 - OpenVPN > TCP connection established with [AF_INET]64.42.179.61:443
. 2021.02.10 00:34:18 - OpenVPN > TCP_CLIENT link local: (not bound)
. 2021.02.10 00:34:18 - OpenVPN > TCP_CLIENT link remote: [AF_INET]64.42.179.61:443
. 2021.02.10 00:34:18 - OpenVPN > TLS: Initial packet from [AF_INET]64.42.179.61:443, sid=b08fc11d 3c3ac47a
. 2021.02.10 00:34:18 - OpenVPN > VERIFY KU OK
. 2021.02.10 00:34:18 - OpenVPN > Validating certificate extended key usage
. 2021.02.10 00:34:18 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
. 2021.02.10 00:34:18 - OpenVPN > VERIFY EKU OK
. 2021.02.10 00:34:18 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=Hercules, emailAddress=info@airvpn.org
. 2021.02.10 00:34:18 - OpenVPN > Control Channel: TLSv1.3, cipher TLSv1.3 TLS_CHACHA20_POLY1305_SHA256, 4096 bit RSA
. 2021.02.10 00:34:18 - OpenVPN > [Hercules] Peer Connection Initiated with [AF_INET]64.42.179.61:443
. 2021.02.10 00:34:18 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,comp-lzo no,redirect-gateway ipv6 def1 bypass-dhcp,dhcp-option DNS 10.22.227.1,dhcp-option DNS6 fde6:7a:7d20:12e3::1,tun-ipv6,route-gateway 10.22.227.1,topology subnet,ping 10,ping-restart 60,ifconfig-ipv6 fde6:7a:7d20:12e3::1010/64 fde6:7a:7d20:12e3::1,ifconfig 10.22.227.18 255.255.255.0,peer-id 0,cipher AES-256-GCM'
. 2021.02.10 00:34:18 - OpenVPN > Pushed option removed by filter: 'redirect-gateway ipv6 def1 bypass-dhcp'
. 2021.02.10 00:34:18 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified
. 2021.02.10 00:34:18 - OpenVPN > OPTIONS IMPORT: compression parms modified
. 2021.02.10 00:34:18 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified
. 2021.02.10 00:34:18 - OpenVPN > OPTIONS IMPORT: route-related options modified
. 2021.02.10 00:34:18 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified
. 2021.02.10 00:34:18 - OpenVPN > OPTIONS IMPORT: peer-id set
. 2021.02.10 00:34:18 - OpenVPN > OPTIONS IMPORT: adjusting link_mtu to 1627
. 2021.02.10 00:34:18 - OpenVPN > OPTIONS IMPORT: data channel crypto options modified
. 2021.02.10 00:34:18 - OpenVPN > Data Channel: using negotiated cipher 'AES-256-GCM'
. 2021.02.10 00:34:18 - OpenVPN > Outgoing Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key
. 2021.02.10 00:34:18 - OpenVPN > Incoming Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key
. 2021.02.10 00:34:18 - OpenVPN > interactive service msg_channel=0
. 2021.02.10 00:34:18 - OpenVPN > ROUTE_GATEWAY 10.200.224.1/255.255.248.0 I=5 HWADDR=b4:ae:2b:d6:3d:12
. 2021.02.10 00:34:18 - OpenVPN > ROUTE: bypass_host_route[0]=10.200.103.56
. 2021.02.10 00:34:18 - OpenVPN > GDG6: remote_host_ipv6=n/a
. 2021.02.10 00:34:18 - OpenVPN > GetBestInterfaceEx() returned if=16
. 2021.02.10 00:34:18 - OpenVPN > GDG6: II=16 DP=::/3 NH=fe80::8
. 2021.02.10 00:34:18 - OpenVPN > GDG6: Metric=256, Loopback=0, AA=1, I=0
. 2021.02.10 00:34:18 - OpenVPN > ROUTE6_GATEWAY fe80::8 I=16
. 2021.02.10 00:34:18 - OpenVPN > open_tun
. 2021.02.10 00:34:19 - OpenVPN > tap-windows6 device [Local Area Connection 2] opened
. 2021.02.10 00:34:19 - OpenVPN > TAP-Windows Driver Version 9.24
. 2021.02.10 00:34:19 - OpenVPN > Set TAP-Windows TUN subnet mode network/local/netmask = 10.22.227.0/10.22.227.18/255.255.255.0 [SUCCEEDED]
. 2021.02.10 00:34:19 - OpenVPN > Notified TAP-Windows driver to set a DHCP IP/netmask of 10.22.227.18/255.255.255.0 on interface {C08F2B39-6B49-47C9-B994-D5F695969509} [DHCP-serv: 10.22.227.254, lease-time: 31536000]
. 2021.02.10 00:34:19 - OpenVPN > Successful ARP Flush on interface [16] {C08F2B39-6B49-47C9-B994-D5F695969509}
. 2021.02.10 00:34:19 - OpenVPN > IPv4 MTU set to 1500 on interface 16 using SetIpInterfaceEntry()
. 2021.02.10 00:34:19 - OpenVPN > NETSH: C:\WINDOWS\system32\netsh.exe interface ipv6 set address 16 fde6:7a:7d20:12e3::1010/128 store=active
. 2021.02.10 00:34:20 - OpenVPN > add_route_ipv6(fde6:7a:7d20:12e3::/64 -> fde6:7a:7d20:12e3::1010 metric 0) dev Local Area Connection 2
. 2021.02.10 00:34:20 - OpenVPN > C:\WINDOWS\system32\netsh.exe interface ipv6 add route fde6:7a:7d20:12e3::/64 16 fe80::8 store=active
. 2021.02.10 00:34:20 - OpenVPN > env_block: add PATH=C:\WINDOWS\System32;C:\WINDOWS;C:\WINDOWS\System32\Wbem
. 2021.02.10 00:34:21 - OpenVPN > NETSH: C:\WINDOWS\system32\netsh.exe interface ipv6 delete dns 16 all
. 2021.02.10 00:34:22 - OpenVPN > NETSH: C:\WINDOWS\system32\netsh.exe interface ipv6 set dns 16 static fde6:7a:7d20:12e3::1 validate=no
. 2021.02.10 00:34:22 - OpenVPN > IPv6 MTU set to 1500 on interface 16 using SetIpInterfaceEntry()
. 2021.02.10 00:34:27 - OpenVPN > TEST ROUTES: 1/1 succeeded len=0 ret=1 a=0 u/d=up
. 2021.02.10 00:34:27 - OpenVPN > C:\WINDOWS\system32\route.exe ADD 64.42.179.61 MASK 255.255.255.255 10.200.224.1
. 2021.02.10 00:34:27 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=50 and dwForwardType=4
. 2021.02.10 00:34:27 - OpenVPN > Route addition via IPAPI succeeded [adaptive]
. 2021.02.10 00:34:27 - OpenVPN > C:\WINDOWS\system32\route.exe ADD 10.200.103.56 MASK 255.255.255.255 10.200.224.1
. 2021.02.10 00:34:27 - OpenVPN > C:\WINDOWS\system32\route.exe ADD 0.0.0.0 MASK 128.0.0.0 10.22.227.1
. 2021.02.10 00:34:27 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=25 and dwForwardType=4
. 2021.02.10 00:34:27 - OpenVPN > C:\WINDOWS\system32\route.exe ADD 128.0.0.0 MASK 128.0.0.0 10.22.227.1
. 2021.02.10 00:34:27 - OpenVPN > add_route_ipv6(::/3 -> fde6:7a:7d20:12e3::1 metric -1) dev Local Area Connection 2
. 2021.02.10 00:34:27 - OpenVPN > C:\WINDOWS\system32\netsh.exe interface ipv6 add route ::/3 16 fe80::8 store=active
. 2021.02.10 00:34:27 - OpenVPN > env_block: add PATH=C:\WINDOWS\System32;C:\WINDOWS;C:\WINDOWS\System32\Wbem
E 2021.02.10 00:34:27 - OpenVPN > ERROR: Windows route add ipv6 command failed: returned error code 1
. 2021.02.10 00:34:27 - OpenVPN > add_route_ipv6(2000::/4 -> fde6:7a:7d20:12e3::1 metric -1) dev Local Area Connection 2
. 2021.02.10 00:34:27 - OpenVPN > C:\WINDOWS\system32\netsh.exe interface ipv6 add route 2000::/4 16 fe80::8 store=active
E 2021.02.10 00:34:28 - OpenVPN > ERROR: Windows route add ipv6 command failed: returned error code 1
. 2021.02.10 00:34:28 - OpenVPN > add_route_ipv6(3000::/4 -> fde6:7a:7d20:12e3::1 metric -1) dev Local Area Connection 2
. 2021.02.10 00:34:28 - OpenVPN > C:\WINDOWS\system32\netsh.exe interface ipv6 add route 3000::/4 16 fe80::8 store=active
. 2021.02.10 00:34:28 - OpenVPN > env_block: add PATH=C:\WINDOWS\System32;C:\WINDOWS;C:\WINDOWS\System32\Wbem
. 2021.02.10 00:34:28 - OpenVPN > add_route_ipv6(fc00::/7 -> fde6:7a:7d20:12e3::1 metric -1) dev Local Area Connection 2
. 2021.02.10 00:34:28 - OpenVPN > C:\WINDOWS\system32\netsh.exe interface ipv6 add route fc00::/7 16 fe80::8 store=active
. 2021.02.10 00:34:28 - Interface Local Area Connection 2 metric changed from Automatic to 3, layer IPv4
. 2021.02.10 00:34:28 - Interface Local Area Connection 2 metric changed from Automatic to 3, layer IPv6
. 2021.02.10 00:34:28 - DNS leak protection with packet filtering enabled.
. 2021.02.10 00:34:28 - DNS IPv4 of a network adapter forced (Local Area Connection 2, from automatic to 10.22.227.1)
. 2021.02.10 00:34:28 - DNS IPv6 of a network adapter forced (Local Area Connection 2, from automatic to fde6:7a:7d20:12e3::1)
. 2021.02.10 00:34:28 - Routes, added a new route, 64.42.179.59 for gateway 10.22.227.1
. 2021.02.10 00:34:28 - Routes, added a new route, 2605:9f80:6000:80:fc8c:43ee:267e:97ab for gateway fde6:7a:7d20:12e3::1
. 2021.02.10 00:34:28 - Flushing DNS
I 2021.02.10 00:34:29 - Checking route IPv4
I 2021.02.10 00:34:29 - Checking route IPv6
. 2021.02.10 00:34:50 - Fetch url error:Timeout was reached
. 2021.02.10 00:34:50 - Checking route (2° try)
. 2021.02.10 00:35:13 - Fetch url error:Timeout was reached
. 2021.02.10 00:35:13 - Checking route (3° try)
. 2021.02.10 00:35:36 - Fetch url error:Timeout was reached
E 2021.02.10 00:35:36 - Checking route IPv6 failed.
. 2021.02.10 00:35:36 - OpenVPN > Initialization Sequence Completed
! 2021.02.10 00:35:36 - Disconnecting
. 2021.02.10 00:35:36 - Routes, removed a route previously added, 64.42.179.59 for gateway 10.22.227.1
. 2021.02.10 00:35:36 - Routes, removed a route previously added, 2605:9f80:6000:80:fc8c:43ee:267e:97ab for gateway fde6:7a:7d20:12e3::1
. 2021.02.10 00:35:36 - Sending soft termination signal
. 2021.02.10 00:35:39 - Connection terminated.
. 2021.02.10 00:35:40 - DNS IPv4 of a network adapter restored to original settings (Local Area Connection 2, to automatic)
. 2021.02.10 00:35:40 - DNS IPv6 of a network adapter restored to original settings (Local Area Connection 2, to automatic)
. 2021.02.10 00:35:40 - DNS leak protection with packet filtering disabled.
. 2021.02.10 00:35:40 - Interface Local Area Connection 2 metric restored from 3 to Automatic, layer IPv4
. 2021.02.10 00:35:40 - Interface Local Area Connection 2 metric restored from 3 to Automatic, layer IPv6
. 2021.02.10 00:35:40 - OpenVPN > C:\WINDOWS\system32\route.exe DELETE 64.42.179.61 MASK 255.255.255.255 10.200.224.1
. 2021.02.10 00:35:40 - OpenVPN > Route deletion via IPAPI succeeded [adaptive]
. 2021.02.10 00:35:40 - OpenVPN > C:\WINDOWS\system32\route.exe DELETE 10.200.103.56 MASK 255.255.255.255 10.200.224.1
. 2021.02.10 00:35:40 - OpenVPN > C:\WINDOWS\system32\route.exe DELETE 0.0.0.0 MASK 128.0.0.0 10.22.227.1
. 2021.02.10 00:35:40 - OpenVPN > C:\WINDOWS\system32\route.exe DELETE 128.0.0.0 MASK 128.0.0.0 10.22.227.1
. 2021.02.10 00:35:40 - OpenVPN > Closing TUN/TAP interface
. 2021.02.10 00:35:40 - OpenVPN > NETSH: C:\WINDOWS\system32\netsh.exe interface ipv6 delete dns 16 all
. 2021.02.10 00:35:40 - OpenVPN > delete_route_ipv6(fde6:7a:7d20:12e3::/64)
. 2021.02.10 00:35:40 - OpenVPN > C:\WINDOWS\system32\netsh.exe interface ipv6 delete route fde6:7a:7d20:12e3::/64 16 fe80::8 store=active
. 2021.02.10 00:35:40 - OpenVPN > NETSH: C:\WINDOWS\system32\netsh.exe interface ipv6 delete address 16 fde6:7a:7d20:12e3::1010 store=active
. 2021.02.10 00:35:40 - OpenVPN > TAP: DHCP address released
. 2021.02.10 00:35:40 - OpenVPN > SIGTERM[hard,] received, process exiting
I 2021.02.10 00:35:43 - Checking authorization ...
! 2021.02.10 00:35:44 - Connecting to Pegasus (United States of America, Dallas, Texas)
. 2021.02.10 00:35:44 - OpenVPN > OpenVPN 2.5.0 x86_64-w64-mingw32 [SSL (OpenSSL)] [LZO] [LZ4] [PKCS11] [AEAD] built on Oct 28 2020
. 2021.02.10 00:35:44 - OpenVPN > Windows version 10.0 (Windows 10 or greater) 64bit
. 2021.02.10 00:35:44 - OpenVPN > library versions: OpenSSL 1.1.1h  22 Sep 2020, LZO 2.10
. 2021.02.10 00:35:44 - OpenVPN > Outgoing Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key
. 2021.02.10 00:35:44 - OpenVPN > Outgoing Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication
. 2021.02.10 00:35:44 - OpenVPN > Incoming Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key
. 2021.02.10 00:35:44 - OpenVPN > Incoming Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication
. 2021.02.10 00:35:44 - OpenVPN > TCP/UDP: Preserving recently used remote address: [AF_INET]199.249.230.19:443
. 2021.02.10 00:35:44 - OpenVPN > Socket Buffers: R=[65536->65536] S=[65536->65536]
. 2021.02.10 00:35:44 - OpenVPN > Attempting to establish TCP connection with [AF_INET]199.249.230.19:443 [nonblock]
. 2021.02.10 00:35:44 - OpenVPN > TCP connection established with [AF_INET]199.249.230.19:443
. 2021.02.10 00:35:44 - OpenVPN > TCP_CLIENT link local: (not bound)
. 2021.02.10 00:35:44 - OpenVPN > TCP_CLIENT link remote: [AF_INET]199.249.230.19:443
. 2021.02.10 00:35:44 - OpenVPN > TLS: Initial packet from [AF_INET]199.249.230.19:443, sid=38cfcb2d be987c77
. 2021.02.10 00:35:44 - OpenVPN > VERIFY KU OK
. 2021.02.10 00:35:44 - OpenVPN > Validating certificate extended key usage
. 2021.02.10 00:35:44 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
. 2021.02.10 00:35:44 - OpenVPN > VERIFY EKU OK
. 2021.02.10 00:35:44 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=Pegasus, emailAddress=info@airvpn.org
. 2021.02.10 00:35:44 - OpenVPN > Control Channel: TLSv1.3, cipher TLSv1.3 TLS_CHACHA20_POLY1305_SHA256, 4096 bit RSA
. 2021.02.10 00:35:44 - OpenVPN > [Pegasus] Peer Connection Initiated with [AF_INET]199.249.230.19:443
. 2021.02.10 00:35:45 - OpenVPN > SENT CONTROL [Pegasus]: 'PUSH_REQUEST' (status=1)
. 2021.02.10 00:35:45 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,comp-lzo no,redirect-gateway ipv6 def1 bypass-dhcp,dhcp-option DNS 10.26.67.1,dhcp-option DNS6 fde6:7a:7d20:1643::1,tun-ipv6,route-gateway 10.26.67.1,topology subnet,ping 10,ping-restart 60,ifconfig-ipv6 fde6:7a:7d20:1643::1012/64 fde6:7a:7d20:1643::1,ifconfig 10.26.67.20 255.255.255.0,peer-id 0,cipher AES-256-GCM'
. 2021.02.10 00:35:45 - OpenVPN > Pushed option removed by filter: 'redirect-gateway ipv6 def1 bypass-dhcp'
. 2021.02.10 00:35:45 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified
. 2021.02.10 00:35:45 - OpenVPN > OPTIONS IMPORT: compression parms modified
. 2021.02.10 00:35:45 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified
. 2021.02.10 00:35:45 - OpenVPN > OPTIONS IMPORT: route-related options modified
. 2021.02.10 00:35:45 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified
. 2021.02.10 00:35:45 - OpenVPN > OPTIONS IMPORT: peer-id set
. 2021.02.10 00:35:45 - OpenVPN > OPTIONS IMPORT: adjusting link_mtu to 1627
. 2021.02.10 00:35:45 - OpenVPN > OPTIONS IMPORT: data channel crypto options modified
. 2021.02.10 00:35:45 - OpenVPN > Data Channel: using negotiated cipher 'AES-256-GCM'
. 2021.02.10 00:35:45 - OpenVPN > Outgoing Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key
. 2021.02.10 00:35:45 - OpenVPN > Incoming Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key
. 2021.02.10 00:35:45 - OpenVPN > interactive service msg_channel=0
. 2021.02.10 00:35:45 - OpenVPN > ROUTE_GATEWAY 10.200.224.1/255.255.248.0 I=5 HWADDR=b4:ae:2b:d6:3d:12
. 2021.02.10 00:35:45 - OpenVPN > ROUTE: bypass_host_route[0]=10.200.103.56
. 2021.02.10 00:35:45 - OpenVPN > GDG6: remote_host_ipv6=n/a
. 2021.02.10 00:35:45 - OpenVPN > GetBestInterfaceEx() returned if=16
. 2021.02.10 00:35:45 - OpenVPN > GDG6: II=16 DP=::/3 NH=fe80::8
. 2021.02.10 00:35:45 - OpenVPN > GDG6: Metric=256, Loopback=0, AA=1, I=0
. 2021.02.10 00:35:45 - OpenVPN > ROUTE6_GATEWAY fe80::8 I=16
. 2021.02.10 00:35:45 - OpenVPN > open_tun
. 2021.02.10 00:35:45 - OpenVPN > tap-windows6 device [Local Area Connection 2] opened
. 2021.02.10 00:35:45 - OpenVPN > TAP-Windows Driver Version 9.24
. 2021.02.10 00:35:45 - OpenVPN > Set TAP-Windows TUN subnet mode network/local/netmask = 10.26.67.0/10.26.67.20/255.255.255.0 [SUCCEEDED]
. 2021.02.10 00:35:45 - OpenVPN > Notified TAP-Windows driver to set a DHCP IP/netmask of 10.26.67.20/255.255.255.0 on interface {C08F2B39-6B49-47C9-B994-D5F695969509} [DHCP-serv: 10.26.67.254, lease-time: 31536000]
. 2021.02.10 00:35:45 - OpenVPN > Successful ARP Flush on interface [16] {C08F2B39-6B49-47C9-B994-D5F695969509}
. 2021.02.10 00:35:45 - OpenVPN > IPv4 MTU set to 1500 on interface 16 using SetIpInterfaceEntry()
. 2021.02.10 00:35:46 - OpenVPN > NETSH: C:\WINDOWS\system32\netsh.exe interface ipv6 set address 16 fde6:7a:7d20:1643::1012/128 store=active
. 2021.02.10 00:35:46 - OpenVPN > add_route_ipv6(fde6:7a:7d20:1643::/64 -> fde6:7a:7d20:1643::1012 metric 0) dev Local Area Connection 2
. 2021.02.10 00:35:46 - OpenVPN > C:\WINDOWS\system32\netsh.exe interface ipv6 add route fde6:7a:7d20:1643::/64 16 fe80::8 store=active
. 2021.02.10 00:35:46 - OpenVPN > env_block: add PATH=C:\WINDOWS\System32;C:\WINDOWS;C:\WINDOWS\System32\Wbem
. 2021.02.10 00:35:47 - OpenVPN > NETSH: C:\WINDOWS\system32\netsh.exe interface ipv6 delete dns 16 all
. 2021.02.10 00:35:48 - OpenVPN > NETSH: C:\WINDOWS\system32\netsh.exe interface ipv6 set dns 16 static fde6:7a:7d20:1643::1 validate=no
. 2021.02.10 00:35:48 - OpenVPN > IPv6 MTU set to 1500 on interface 16 using SetIpInterfaceEntry()
. 2021.02.10 00:35:53 - OpenVPN > TEST ROUTES: 1/1 succeeded len=0 ret=1 a=0 u/d=up
. 2021.02.10 00:35:53 - OpenVPN > C:\WINDOWS\system32\route.exe ADD 199.249.230.19 MASK 255.255.255.255 10.200.224.1
. 2021.02.10 00:35:53 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=50 and dwForwardType=4
. 2021.02.10 00:35:53 - OpenVPN > Route addition via IPAPI succeeded [adaptive]
. 2021.02.10 00:35:53 - OpenVPN > C:\WINDOWS\system32\route.exe ADD 10.200.103.56 MASK 255.255.255.255 10.200.224.1
. 2021.02.10 00:35:53 - OpenVPN > C:\WINDOWS\system32\route.exe ADD 0.0.0.0 MASK 128.0.0.0 10.26.67.1
. 2021.02.10 00:35:53 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=25 and dwForwardType=4
. 2021.02.10 00:35:53 - OpenVPN > C:\WINDOWS\system32\route.exe ADD 128.0.0.0 MASK 128.0.0.0 10.26.67.1
. 2021.02.10 00:35:53 - OpenVPN > add_route_ipv6(::/3 -> fde6:7a:7d20:1643::1 metric -1) dev Local Area Connection 2
. 2021.02.10 00:35:53 - OpenVPN > C:\WINDOWS\system32\netsh.exe interface ipv6 add route ::/3 16 fe80::8 store=active
. 2021.02.10 00:35:53 - OpenVPN > env_block: add PATH=C:\WINDOWS\System32;C:\WINDOWS;C:\WINDOWS\System32\Wbem
E 2021.02.10 00:35:54 - OpenVPN > ERROR: Windows route add ipv6 command failed: returned error code 1
. 2021.02.10 00:35:54 - OpenVPN > add_route_ipv6(2000::/4 -> fde6:7a:7d20:1643::1 metric -1) dev Local Area Connection 2
. 2021.02.10 00:35:54 - OpenVPN > C:\WINDOWS\system32\netsh.exe interface ipv6 add route 2000::/4 16 fe80::8 store=active
. 2021.02.10 00:35:54 - OpenVPN > env_block: add PATH=C:\WINDOWS\System32;C:\WINDOWS;C:\WINDOWS\System32\Wbem
. 2021.02.10 00:35:54 - OpenVPN > add_route_ipv6(3000::/4 -> fde6:7a:7d20:1643::1 metric -1) dev Local Area Connection 2
. 2021.02.10 00:35:54 - OpenVPN > C:\WINDOWS\system32\netsh.exe interface ipv6 add route 3000::/4 16 fe80::8 store=active
. 2021.02.10 00:35:54 - OpenVPN > add_route_ipv6(fc00::/7 -> fde6:7a:7d20:1643::1 metric -1) dev Local Area Connection 2
. 2021.02.10 00:35:54 - OpenVPN > C:\WINDOWS\system32\netsh.exe interface ipv6 add route fc00::/7 16 fe80::8 store=active
. 2021.02.10 00:35:54 - Interface Local Area Connection 2 metric changed from Automatic to 3, layer IPv4
. 2021.02.10 00:35:54 - Interface Local Area Connection 2 metric changed from Automatic to 3, layer IPv6
. 2021.02.10 00:35:54 - DNS leak protection with packet filtering enabled.
. 2021.02.10 00:35:54 - DNS IPv4 of a network adapter forced (Local Area Connection 2, from automatic to 10.26.67.1)
. 2021.02.10 00:35:54 - DNS IPv6 of a network adapter forced (Local Area Connection 2, from automatic to fde6:7a:7d20:1643::1)
. 2021.02.10 00:35:54 - Routes, added a new route, 199.249.230.17 for gateway 10.26.67.1
. 2021.02.10 00:35:55 - Routes, added a new route, 2620:7:6001:4e52:a86b:24a6:b8b7:c4dd for gateway fde6:7a:7d20:1643::1
. 2021.02.10 00:35:55 - Flushing DNS
I 2021.02.10 00:35:55 - Checking route IPv4
I 2021.02.10 00:35:55 - Checking route IPv6
. 2021.02.10 00:36:16 - Fetch url error:Timeout was reached
. 2021.02.10 00:36:16 - Checking route (2° try)
. 2021.02.10 00:36:39 - Fetch url error:Timeout was reached
. 2021.02.10 00:36:39 - Checking route (3° try)
. 2021.02.10 00:37:02 - Fetch url error:Timeout was reached
E 2021.02.10 00:37:02 - Checking route IPv6 failed.
. 2021.02.10 00:37:02 - OpenVPN > Initialization Sequence Completed
! 2021.02.10 00:37:02 - Disconnecting
. 2021.02.10 00:37:02 - Routes, removed a route previously added, 199.249.230.17 for gateway 10.26.67.1
. 2021.02.10 00:37:03 - Routes, removed a route previously added, 2620:7:6001:4e52:a86b:24a6:b8b7:c4dd for gateway fde6:7a:7d20:1643::1
. 2021.02.10 00:37:03 - Sending soft termination signal
. 2021.02.10 00:37:06 - Connection terminated.
. 2021.02.10 00:37:06 - DNS IPv4 of a network adapter restored to original settings (Local Area Connection 2, to automatic)
. 2021.02.10 00:37:06 - DNS IPv6 of a network adapter restored to original settings (Local Area Connection 2, to automatic)
. 2021.02.10 00:37:06 - DNS leak protection with packet filtering disabled.
. 2021.02.10 00:37:06 - Interface Local Area Connection 2 metric restored from 3 to Automatic, layer IPv4
. 2021.02.10 00:37:06 - Interface Local Area Connection 2 metric restored from 3 to Automatic, layer IPv6
. 2021.02.10 00:37:06 - OpenVPN > C:\WINDOWS\system32\route.exe DELETE 199.249.230.19 MASK 255.255.255.255 10.200.224.1
. 2021.02.10 00:37:06 - OpenVPN > Route deletion via IPAPI succeeded [adaptive]
. 2021.02.10 00:37:06 - OpenVPN > C:\WINDOWS\system32\route.exe DELETE 10.200.103.56 MASK 255.255.255.255 10.200.224.1
. 2021.02.10 00:37:06 - OpenVPN > C:\WINDOWS\system32\route.exe DELETE 0.0.0.0 MASK 128.0.0.0 10.26.67.1
. 2021.02.10 00:37:06 - OpenVPN > C:\WINDOWS\system32\route.exe DELETE 128.0.0.0 MASK 128.0.0.0 10.26.67.1
. 2021.02.10 00:37:06 - OpenVPN > Closing TUN/TAP interface
. 2021.02.10 00:37:06 - OpenVPN > NETSH: C:\WINDOWS\system32\netsh.exe interface ipv6 delete dns 16 all
. 2021.02.10 00:37:06 - OpenVPN > delete_route_ipv6(fde6:7a:7d20:1643::/64)
. 2021.02.10 00:37:06 - OpenVPN > C:\WINDOWS\system32\netsh.exe interface ipv6 delete route fde6:7a:7d20:1643::/64 16 fe80::8 store=active
. 2021.02.10 00:37:06 - OpenVPN > NETSH: C:\WINDOWS\system32\netsh.exe interface ipv6 delete address 16 fde6:7a:7d20:1643::1012 store=active
. 2021.02.10 00:37:06 - OpenVPN > TAP: DHCP address released
. 2021.02.10 00:37:06 - OpenVPN > SIGTERM[hard,] received, process exiting
I 2021.02.10 00:37:09 - Checking authorization ...
! 2021.02.10 00:37:10 - Connecting to Acamar (United States of America, Miami)
. 2021.02.10 00:37:10 - OpenVPN > OpenVPN 2.5.0 x86_64-w64-mingw32 [SSL (OpenSSL)] [LZO] [LZ4] [PKCS11] [AEAD] built on Oct 28 2020
. 2021.02.10 00:37:10 - OpenVPN > Windows version 10.0 (Windows 10 or greater) 64bit
. 2021.02.10 00:37:10 - OpenVPN > library versions: OpenSSL 1.1.1h  22 Sep 2020, LZO 2.10
. 2021.02.10 00:37:10 - OpenVPN > Outgoing Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key
. 2021.02.10 00:37:10 - OpenVPN > Outgoing Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication
. 2021.02.10 00:37:10 - OpenVPN > Incoming Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key
. 2021.02.10 00:37:10 - OpenVPN > Incoming Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication
. 2021.02.10 00:37:10 - OpenVPN > TCP/UDP: Preserving recently used remote address: [AF_INET]173.44.55.157:443
. 2021.02.10 00:37:10 - OpenVPN > Socket Buffers: R=[65536->65536] S=[65536->65536]
. 2021.02.10 00:37:10 - OpenVPN > Attempting to establish TCP connection with [AF_INET]173.44.55.157:443 [nonblock]
. 2021.02.10 00:37:10 - OpenVPN > TCP connection established with [AF_INET]173.44.55.157:443
. 2021.02.10 00:37:10 - OpenVPN > TCP_CLIENT link local: (not bound)
. 2021.02.10 00:37:10 - OpenVPN > TCP_CLIENT link remote: [AF_INET]173.44.55.157:443
. 2021.02.10 00:37:10 - OpenVPN > TLS: Initial packet from [AF_INET]173.44.55.157:443, sid=81a75eba e67f379f
. 2021.02.10 00:37:10 - OpenVPN > VERIFY KU OK
. 2021.02.10 00:37:10 - OpenVPN > Validating certificate extended key usage
. 2021.02.10 00:37:10 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
. 2021.02.10 00:37:10 - OpenVPN > VERIFY EKU OK
. 2021.02.10 00:37:10 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=Acamar, emailAddress=info@airvpn.org
. 2021.02.10 00:37:10 - OpenVPN > Control Channel: TLSv1.3, cipher TLSv1.3 TLS_CHACHA20_POLY1305_SHA256, 4096 bit RSA
. 2021.02.10 00:37:10 - OpenVPN > [Acamar] Peer Connection Initiated with [AF_INET]173.44.55.157:443
. 2021.02.10 00:37:11 - OpenVPN > SENT CONTROL [Acamar]: 'PUSH_REQUEST' (status=1)
. 2021.02.10 00:37:11 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,comp-lzo no,redirect-gateway ipv6 def1 bypass-dhcp,dhcp-option DNS 10.4.67.1,dhcp-option DNS6 fde6:7a:7d20:43::1,tun-ipv6,route-gateway 10.4.67.1,topology subnet,ping 10,ping-restart 60,ifconfig-ipv6 fde6:7a:7d20:43::1021/64 fde6:7a:7d20:43::1,ifconfig 10.4.67.35 255.255.255.0,peer-id 0,cipher AES-256-GCM'
. 2021.02.10 00:37:11 - OpenVPN > Pushed option removed by filter: 'redirect-gateway ipv6 def1 bypass-dhcp'
. 2021.02.10 00:37:11 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified
. 2021.02.10 00:37:11 - OpenVPN > OPTIONS IMPORT: compression parms modified
. 2021.02.10 00:37:11 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified
. 2021.02.10 00:37:11 - OpenVPN > OPTIONS IMPORT: route-related options modified
. 2021.02.10 00:37:11 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified
. 2021.02.10 00:37:11 - OpenVPN > OPTIONS IMPORT: peer-id set
. 2021.02.10 00:37:11 - OpenVPN > OPTIONS IMPORT: adjusting link_mtu to 1627
. 2021.02.10 00:37:11 - OpenVPN > OPTIONS IMPORT: data channel crypto options modified
. 2021.02.10 00:37:11 - OpenVPN > Data Channel: using negotiated cipher 'AES-256-GCM'
. 2021.02.10 00:37:11 - OpenVPN > Outgoing Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key
. 2021.02.10 00:37:11 - OpenVPN > Incoming Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key
. 2021.02.10 00:37:11 - OpenVPN > interactive service msg_channel=0
. 2021.02.10 00:37:11 - OpenVPN > ROUTE_GATEWAY 10.200.224.1/255.255.248.0 I=5 HWADDR=b4:ae:2b:d6:3d:12
. 2021.02.10 00:37:11 - OpenVPN > ROUTE: bypass_host_route[0]=10.200.103.56
. 2021.02.10 00:37:11 - OpenVPN > GDG6: remote_host_ipv6=n/a
. 2021.02.10 00:37:11 - OpenVPN > GetBestInterfaceEx() returned if=16
. 2021.02.10 00:37:11 - OpenVPN > GDG6: II=16 DP=::/3 NH=fe80::8
. 2021.02.10 00:37:11 - OpenVPN > GDG6: Metric=256, Loopback=0, AA=1, I=0
. 2021.02.10 00:37:11 - OpenVPN > ROUTE6_GATEWAY fe80::8 I=16
. 2021.02.10 00:37:11 - OpenVPN > open_tun
. 2021.02.10 00:37:11 - OpenVPN > tap-windows6 device [Local Area Connection 2] opened
. 2021.02.10 00:37:11 - OpenVPN > TAP-Windows Driver Version 9.24
. 2021.02.10 00:37:11 - OpenVPN > Set TAP-Windows TUN subnet mode network/local/netmask = 10.4.67.0/10.4.67.35/255.255.255.0 [SUCCEEDED]
. 2021.02.10 00:37:11 - OpenVPN > Notified TAP-Windows driver to set a DHCP IP/netmask of 10.4.67.35/255.255.255.0 on interface {C08F2B39-6B49-47C9-B994-D5F695969509} [DHCP-serv: 10.4.67.254, lease-time: 31536000]
. 2021.02.10 00:37:11 - OpenVPN > Successful ARP Flush on interface [16] {C08F2B39-6B49-47C9-B994-D5F695969509}
. 2021.02.10 00:37:11 - OpenVPN > IPv4 MTU set to 1500 on interface 16 using SetIpInterfaceEntry()
. 2021.02.10 00:37:12 - OpenVPN > NETSH: C:\WINDOWS\system32\netsh.exe interface ipv6 set address 16 fde6:7a:7d20:43::1021/128 store=active
. 2021.02.10 00:37:12 - OpenVPN > add_route_ipv6(fde6:7a:7d20:43::/64 -> fde6:7a:7d20:43::1021 metric 0) dev Local Area Connection 2
. 2021.02.10 00:37:12 - OpenVPN > C:\WINDOWS\system32\netsh.exe interface ipv6 add route fde6:7a:7d20:43::/64 16 fe80::8 store=active
. 2021.02.10 00:37:12 - OpenVPN > env_block: add PATH=C:\WINDOWS\System32;C:\WINDOWS;C:\WINDOWS\System32\Wbem
. 2021.02.10 00:37:13 - OpenVPN > NETSH: C:\WINDOWS\system32\netsh.exe interface ipv6 delete dns 16 all
. 2021.02.10 00:37:14 - OpenVPN > NETSH: C:\WINDOWS\system32\netsh.exe interface ipv6 set dns 16 static fde6:7a:7d20:43::1 validate=no
. 2021.02.10 00:37:14 - OpenVPN > IPv6 MTU set to 1500 on interface 16 using SetIpInterfaceEntry()
. 2021.02.10 00:37:19 - OpenVPN > TEST ROUTES: 1/1 succeeded len=0 ret=1 a=0 u/d=up
. 2021.02.10 00:37:19 - OpenVPN > C:\WINDOWS\system32\route.exe ADD 173.44.55.157 MASK 255.255.255.255 10.200.224.1
. 2021.02.10 00:37:19 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=50 and dwForwardType=4
. 2021.02.10 00:37:19 - OpenVPN > Route addition via IPAPI succeeded [adaptive]
. 2021.02.10 00:37:19 - OpenVPN > C:\WINDOWS\system32\route.exe ADD 10.200.103.56 MASK 255.255.255.255 10.200.224.1
. 2021.02.10 00:37:19 - OpenVPN > C:\WINDOWS\system32\route.exe ADD 0.0.0.0 MASK 128.0.0.0 10.4.67.1
. 2021.02.10 00:37:19 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=25 and dwForwardType=4
. 2021.02.10 00:37:19 - OpenVPN > C:\WINDOWS\system32\route.exe ADD 128.0.0.0 MASK 128.0.0.0 10.4.67.1
. 2021.02.10 00:37:19 - OpenVPN > add_route_ipv6(::/3 -> fde6:7a:7d20:43::1 metric -1) dev Local Area Connection 2
. 2021.02.10 00:37:19 - OpenVPN > C:\WINDOWS\system32\netsh.exe interface ipv6 add route ::/3 16 fe80::8 store=active
. 2021.02.10 00:37:19 - OpenVPN > env_block: add PATH=C:\WINDOWS\System32;C:\WINDOWS;C:\WINDOWS\System32\Wbem
E 2021.02.10 00:37:19 - OpenVPN > ERROR: Windows route add ipv6 command failed: returned error code 1
. 2021.02.10 00:37:19 - OpenVPN > add_route_ipv6(2000::/4 -> fde6:7a:7d20:43::1 metric -1) dev Local Area Connection 2
. 2021.02.10 00:37:19 - OpenVPN > C:\WINDOWS\system32\netsh.exe interface ipv6 add route 2000::/4 16 fe80::8 store=active
. 2021.02.10 00:37:19 - OpenVPN > add_route_ipv6(3000::/4 -> fde6:7a:7d20:43::1 metric -1) dev Local Area Connection 2
. 2021.02.10 00:37:19 - OpenVPN > C:\WINDOWS\system32\netsh.exe interface ipv6 add route 3000::/4 16 fe80::8 store=active
. 2021.02.10 00:37:19 - OpenVPN > add_route_ipv6(fc00::/7 -> fde6:7a:7d20:43::1 metric -1) dev Local Area Connection 2
. 2021.02.10 00:37:19 - OpenVPN > C:\WINDOWS\system32\netsh.exe interface ipv6 add route fc00::/7 16 fe80::8 store=active
. 2021.02.10 00:37:19 - Interface Local Area Connection 2 metric changed from Automatic to 3, layer IPv4
. 2021.02.10 00:37:19 - Interface Local Area Connection 2 metric changed from Automatic to 3, layer IPv6
. 2021.02.10 00:37:19 - DNS leak protection with packet filtering enabled.
. 2021.02.10 00:37:20 - DNS IPv4 of a network adapter forced (Local Area Connection 2, from automatic to 10.4.67.1)
. 2021.02.10 00:37:20 - DNS IPv6 of a network adapter forced (Local Area Connection 2, from automatic to fde6:7a:7d20:43::1)
. 2021.02.10 00:37:20 - Routes, added a new route, 173.44.55.155 for gateway 10.4.67.1
. 2021.02.10 00:37:20 - Routes, added a new route, 2607:ff48:aa81:200:89bd:a0e5:6626:b661 for gateway fde6:7a:7d20:43::1
. 2021.02.10 00:37:20 - Flushing DNS
I 2021.02.10 00:37:20 - Checking route IPv4
I 2021.02.10 00:37:21 - Checking route IPv6
. 2021.02.10 00:37:42 - Fetch url error:Timeout was reached
. 2021.02.10 00:37:42 - Checking route (2° try)
. 2021.02.10 00:38:04 - Fetch url error:Timeout was reached
. 2021.02.10 00:38:04 - Checking route (3° try)
. 2021.02.10 00:38:14 - ping 1
. 2021.02.10 00:38:14 - ping 2 W
. 2021.02.10 00:38:19 - ping 2 WE
. 2021.02.10 00:38:28 - Fetch url error:Timeout was reached
E 2021.02.10 00:38:28 - Checking route IPv6 failed.
. 2021.02.10 00:38:28 - OpenVPN > Initialization Sequence Completed
! 2021.02.10 00:38:28 - Disconnecting
. 2021.02.10 00:38:28 - Routes, removed a route previously added, 173.44.55.155 for gateway 10.4.67.1
. 2021.02.10 00:38:28 - Routes, removed a route previously added, 2607:ff48:aa81:200:89bd:a0e5:6626:b661 for gateway fde6:7a:7d20:43::1
. 2021.02.10 00:38:28 - Sending soft termination signal
. 2021.02.10 00:38:31 - Connection terminated.
. 2021.02.10 00:38:31 - DNS IPv4 of a network adapter restored to original settings (Local Area Connection 2, to automatic)
. 2021.02.10 00:38:32 - DNS IPv6 of a network adapter restored to original settings (Local Area Connection 2, to automatic)
. 2021.02.10 00:38:32 - DNS leak protection with packet filtering disabled.
. 2021.02.10 00:38:32 - Interface Local Area Connection 2 metric restored from 3 to Automatic, layer IPv4
. 2021.02.10 00:38:32 - Interface Local Area Connection 2 metric restored from 3 to Automatic, layer IPv6
. 2021.02.10 00:38:32 - OpenVPN > C:\WINDOWS\system32\route.exe DELETE 173.44.55.157 MASK 255.255.255.255 10.200.224.1
. 2021.02.10 00:38:32 - OpenVPN > Route deletion via IPAPI succeeded [adaptive]
. 2021.02.10 00:38:32 - OpenVPN > C:\WINDOWS\system32\route.exe DELETE 10.200.103.56 MASK 255.255.255.255 10.200.224.1
. 2021.02.10 00:38:32 - OpenVPN > C:\WINDOWS\system32\route.exe DELETE 0.0.0.0 MASK 128.0.0.0 10.4.67.1
. 2021.02.10 00:38:32 - OpenVPN > C:\WINDOWS\system32\route.exe DELETE 128.0.0.0 MASK 128.0.0.0 10.4.67.1
. 2021.02.10 00:38:32 - OpenVPN > Closing TUN/TAP interface
. 2021.02.10 00:38:32 - OpenVPN > NETSH: C:\WINDOWS\system32\netsh.exe interface ipv6 delete dns 16 all
. 2021.02.10 00:38:32 - OpenVPN > delete_route_ipv6(fde6:7a:7d20:43::/64)
. 2021.02.10 00:38:32 - OpenVPN > C:\WINDOWS\system32\netsh.exe interface ipv6 delete route fde6:7a:7d20:43::/64 16 fe80::8 store=active
. 2021.02.10 00:38:32 - OpenVPN > NETSH: C:\WINDOWS\system32\netsh.exe interface ipv6 delete address 16 fde6:7a:7d20:43::1021 store=active
. 2021.02.10 00:38:32 - OpenVPN > TAP: DHCP address released
. 2021.02.10 00:38:32 - OpenVPN > SIGTERM[hard,] received, process exiting
. 2021.02.10 00:38:33 - ping 1
. 2021.02.10 00:38:33 - ping 2 W
. 2021.02.10 00:38:33 - ping 2 WE
I 2021.02.10 00:38:35 - Checking authorization ...
Network Interfaces and Routes:
    "support_ipv4": true,
    "support_ipv6": true,
    "routes": [
            "address": "0.0.0.0\/0",
            "interface": "{590519E2-1B7A-462D-99DA-98911F5854DE}",
            "gateway": "10.200.224.1",
            "metric": "50"
            "address": "10.200.224.0\/21",
            "gateway": "link",
            "metric": "306"
            "address": "10.200.225.136",
            "gateway": "link",
            "metric": "306"
            "address": "10.200.231.255",
            "gateway": "link",
            "metric": "306"
            "address": "127.0.0.0\/8",
            "interface": "{2721633D-555B-11E7-86B3-806E6F6E6963}",
            "gateway": "link",
            "metric": "331"
            "address": "127.0.0.1",
            "gateway": "link",
            "metric": "331"
            "address": "127.255.255.255",
            "gateway": "link",
            "metric": "331"
            "address": "224.0.0.0\/4",
            "gateway": "link",
            "metric": "331"
            "gateway": "link",
            "metric": "306"
            "address": "255.255.255.255",
            "gateway": "link",
            "metric": "331"
            "gateway": "link",
            "metric": "306"
            "address": "::\/3",
            "interface": "{C08F2B39-6B49-47C9-B994-D5F695969509}",
            "gateway": "fe80::8",
            "metric": "281"
            "address": "::1",
            "gateway": "link",
            "metric": "331"
            "address": "2000::\/4",
            "metric": "281"
            "address": "3000::\/4",
            "metric": "281"
            "address": "fc00::\/7",
            "metric": "281"
            "address": "fde6:7a:7d20:12ee::\/64",
            "metric": "281"
            "address": "fde6:7a:7d20:12ee::1038",
            "gateway": "link",
            "metric": "281"
            "address": "fe80::\/64",
            "gateway": "link",
            "metric": "281"
            "gateway": "link",
            "metric": "306"
            "address": "fe80::24d9:8d53:2978:69a9",
            "gateway": "link",
            "metric": "281"
            "address": "fe80::692c:48d5:eb21:1862",
            "gateway": "link",
            "metric": "306"
            "address": "ff00::\/8",
            "gateway": "link",
            "metric": "331"
            "gateway": "link",
            "metric": "281"
            "gateway": "link",
            "metric": "306"
    "interfaces": [
            "friendly": "Local Area Connection 2",
            "id": "{C08F2B39-6B49-47C9-B994-D5F695969509}",
            "name": "Local Area Connection 2",
            "description": "TAP-Windows Adapter V9",
            "type": "Virtual",
            "status": "Up",
            "bytes_received": "6067011992",
            "bytes_sent": "231164468",
            "ips": [
                "10.30.163.16"
            "gateways": [
                "fe80::8"
            "bind": true,
            "dns4": "",
            "dns6": null
            "friendly": "Local Area Connection* 1",
            "id": "{B0027418-A133-4DE7-8CD5-DCA5EED65DAE}",
            "name": "Local Area Connection* 1",
            "description": "Microsoft Wi-Fi Direct Virtual Adapter",
            "type": "Wireless80211",
            "status": "Down",
            "bytes_received": "0",
            "bytes_sent": "0",
            "ips": [
                "fe80::c56:9716:9e37:7963",
                "169.254.121.99"
            "gateways": [],
            "bind": true,
            "dns4": "",
            "dns6": null
            "friendly": "Local Area Connection* 2",
            "id": "{782343E8-02F9-494A-9466-6CAF832C2815}",
            "name": "Local Area Connection* 2",
            "description": "Microsoft Wi-Fi Direct Virtual Adapter #2",
            "status": "Down",
            "bytes_sent": "0",
            "ips": [
                "fe80::ddb8:ad80:639b:aee9",
                "169.254.174.233"
            "gateways": [],
            "bind": true,
            "dns4": "",
            "dns6": null
            "friendly": "Wi-Fi",
            "id": "{590519E2-1B7A-462D-99DA-98911F5854DE}",
            "name": "Wi-Fi",
            "description": "Marvell AVASTAR Wireless-AC Network Controller",
            "status": "Up",
            "bytes_received": "260350362",
            "bytes_sent": "60506701",
            "ips": [
                "10.200.225.136"
            "gateways": [
                "10.200.224.1"
            "bind": true,
            "dns4": "",
            "dns6": null
            "friendly": "Bluetooth Network Connection",
            "id": "{A6CE4D83-C43F-4A0E-A55E-DFD3A8BFA7CD}",
            "name": "Bluetooth Network Connection",
            "description": "Bluetooth Device (Personal Area Network)",
            "type": "Ethernet",
            "status": "Down",
            "bytes_sent": "0",
            "ips": [
                "fe80::2173:b236:44ea:4dad",
                "169.254.77.173"
            "gateways": [],
            "bind": true,
            "dns4": "",
            "dns6": null
            "friendly": "Loopback Pseudo-Interface 1",
            "id": "{2721633D-555B-11E7-86B3-806E6F6E6963}",
            "name": "Loopback Pseudo-Interface 1",
            "description": "Software Loopback Interface 1",
            "type": "Loopback",
            "status": "Up",
            "bytes_sent": "0",
            "ips": [
                "::1",
                "127.0.0.1"
            "gateways": [],
            "bind": true,
            "dns4": "",
            "dns6": null
    "ipv6-default-gateway": "fe80::8",
    "ipv6-default-interface": "{C08F2B39-6B49-47C9-B994-D5F695969509}",
    "ipv4-default-gateway": "10.200.224.1",
    "ipv4-default-interface": "{590519E2-1B7A-462D-99DA-98911F5854DE}"
ipconfig /all:
Windows IP Configuration
   Host Name . . . . . . . . . . . . : DESKTOP-NN1Q1KJ
   Primary Dns Suffix  . . . . . . . :
   Node Type . . . . . . . . . . . . : Hybrid
   IP Routing Enabled. . . . . . . . : No
   WINS Proxy Enabled. . . . . . . . : No
   DNS Suffix Search List. . . . . . : the-med.org
Unknown adapter Local Area Connection 2:
   Connection-specific DNS Suffix  . :
   Description . . . . . . . . . . . : TAP-Windows Adapter V9
   Physical Address. . . . . . . . . : 00-FF-C0-8F-2B-39
   DHCP Enabled. . . . . . . . . . . : Yes
   Autoconfiguration Enabled . . . . : Yes
   IPv6 Address. . . . . . . . . . . : fde6:7a:7d20:12ee::1038(Preferred)
   Link-local IPv6 Address . . . . . : fe80::24d9:8d53:2978:69a9%16(Preferred)
   IPv4 Address. . . . . . . . . . . : 10.30.163.16(Preferred)
   Subnet Mask . . . . . . . . . . . : 255.255.255.0
   Lease Obtained. . . . . . . . . . : Wednesday, February 10, 2021 12:38:36 AM
   Lease Expires . . . . . . . . . . : Thursday, February 10, 2022 12:38:36 AM
   Default Gateway . . . . . . . . . :
   DHCP Server . . . . . . . . . . . : 10.30.163.254
   DHCPv6 IAID . . . . . . . . . . . : 704708544
   DHCPv6 Client DUID. . . . . . . . : 00-01-00-01-26-73-F2-0E-B4-AE-2B-D6-3D-12
   DNS Servers . . . . . . . . . . . : 10.30.163.1
   NetBIOS over Tcpip. . . . . . . . : Enabled
Wireless LAN adapter Local Area Connection* 1:
   Media State . . . . . . . . . . . : Media disconnected
   Description . . . . . . . . . . . : Microsoft Wi-Fi Direct Virtual Adapter
   Physical Address. . . . . . . . . : B6-AE-2B-D6-3C-13
Wireless LAN adapter Local Area Connection* 2:
   Description . . . . . . . . . . . : Microsoft Wi-Fi Direct Virtual Adapter #2
   Physical Address. . . . . . . . . : B6-AE-2B-D6-39-13
Wireless LAN adapter Wi-Fi:
   Connection-specific DNS Suffix  . : the-med.org
   Description . . . . . . . . . . . : Marvell AVASTAR Wireless-AC Network Controller
   Physical Address. . . . . . . . . : B4-AE-2B-D6-3D-12
   Link-local IPv6 Address . . . . . : fe80::692c:48d5:eb21:1862%5(Preferred)
   IPv4 Address. . . . . . . . . . . : 10.200.225.136(Preferred)
   Subnet Mask . . . . . . . . . . . : 255.255.248.0
   Lease Obtained. . . . . . . . . . : Wednesday, February 10, 2021 12:19:19 AM
   Lease Expires . . . . . . . . . . : Wednesday, February 10, 2021 10:19:31 AM
   Default Gateway . . . . . . . . . : 10.200.224.1
   DHCP Server . . . . . . . . . . . : 10.200.103.56
   DHCPv6 IAID . . . . . . . . . . . : 45395499
   DNS Servers . . . . . . . . . . . : 172.16.0.123
                                       172.16.0.124
   Primary WINS Server . . . . . . . : 10.200.100.123
   Secondary WINS Server . . . . . . : 10.200.100.124
Ethernet adapter Bluetooth Network Connection:
   Description . . . . . . . . . . . : Bluetooth Device (Personal Area Network)
   Physical Address. . . . . . . . . : B4-AE-2B-D6-3D-13
Edited ... by Aronos
@Aronos
By disabling IPv6 in your Wireless LAN adapter Wi-Fi you made Eddie and OpenVPN unable to connect.
The IPv6 layer combo box has not been set to "Block", according to the system report you kindly included. We see that you set "Internet protocol for connection" to "IPv4 only", but that's a different thing.
Please open "Preferences" > "Networking" window and set the "IPv6 layer" combo box to "Block", then click "Save" and try again. Alternatively, make sure that IPv6 is enabled in your network interfaces.
