thewolfman8326 0 Posted ... (edited) Short: Using OpenVPN configuration, edited config file to run update-systemd-resolved, still not seeing AirVPN dns when checking on ipleak.net. Longer: Arch Linux OpenVPN version 2.5.0 My OVPN config [me@hostname Kruger]$ cat AirVPN_US-Chicago-Illinois_Kruger_UDP-443.ovpn # -------------------------------------------------------- # Air VPN | https://airvpn.org | Sunday 3rd of January 2021 06:48:09 PM # OpenVPN Client Configuration # AirVPN_US-Chicago-Illinois_Kruger_UDP-443 # -------------------------------------------------------- client dev tun remote 68.235.35.123 443 resolv-retry infinite nobind persist-key persist-tun auth-nocache route-delay 5 verb 3 explicit-exit-notify 5 push-peer-info setenv UV_IPV6 yes ca "ca.crt" cert "user.crt" key "user.key" remote-cert-tls server comp-lzo no data-ciphers AES-256-GCM:AES-256-CBC:AES-192-GCM:AES-192-CBC:AES-128-GCM:AES-128-CBC data-ciphers-fallback AES-256-CBC proto udp tls-auth "ta.key" 1 script-security 2 setenv PATH /usr/bin up /etc/openvpn/scripts/update-systemd-resolved down /etc/openvpn/scripts/update-systemd-resolved down-pre dhcp-option DOMAIN-ROUTE Output of terminal when connecting with OpenVPN [me@hostname Kruger]$ sudo openvpn AirVPN_US-Chicago-Illinois_Kruger_UDP-443.ovpn [sudo] password for me: 2021-01-16 17:23:13 WARNING: file 'user.key' is group or others accessible 2021-01-16 17:23:13 OpenVPN 2.5.0 [git:makepkg/a73072d8f780e888+] x86_64-pc-linux-gnu [SSL (OpenSSL)] [LZO] [LZ4] [EPOLL] [PKCS11] [MH/PKTINFO] [AEAD] built on Nov 6 2020 2021-01-16 17:23:13 library versions: OpenSSL 1.1.1i 8 Dec 2020, LZO 2.10 2021-01-16 17:23:13 NOTE: the current --script-security setting may allow this configuration to call user-defined scripts 2021-01-16 17:23:13 Outgoing Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication 2021-01-16 17:23:13 Incoming Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication 2021-01-16 17:23:13 TCP/UDP: Preserving recently used remote address: [AF_INET]68.235.35.123:443 2021-01-16 17:23:13 Socket Buffers: R=[212992->212992] S=[212992->212992] 2021-01-16 17:23:13 UDP link local: (not bound) 2021-01-16 17:23:13 UDP link remote: [AF_INET]68.235.35.123:443 2021-01-16 17:23:13 TLS: Initial packet from [AF_INET]68.235.35.123:443, sid=ba9f17a5 79159312 2021-01-16 17:23:13 net_route_v4_best_gw query: dst 0.0.0.0 2021-01-16 17:23:13 net_route_v4_best_gw result: via 10.0.0.1 dev enp0s31f6 2021-01-16 17:23:13 VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org 2021-01-16 17:23:13 VERIFY KU OK 2021-01-16 17:23:13 Validating certificate extended key usage 2021-01-16 17:23:13 ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication 2021-01-16 17:23:13 VERIFY EKU OK 2021-01-16 17:23:13 VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=Kruger, emailAddress=info@airvpn.org 2021-01-16 17:23:13 Control Channel: TLSv1.3, cipher TLSv1.3 TLS_CHACHA20_POLY1305_SHA256, 4096 bit RSA 2021-01-16 17:23:13 [Kruger] Peer Connection Initiated with [AF_INET]68.235.35.123:443 2021-01-16 17:23:14 SENT CONTROL [Kruger]: 'PUSH_REQUEST' (status=1) 2021-01-16 17:23:14 PUSH: Received control message: 'PUSH_REPLY,comp-lzo no,redirect-gateway ipv6 def1 bypass-dhcp,dhcp-option DNS 10.20.136.1,dhcp-option DNS6 fde6:7a:7d20:1088::1,tun-ipv6,route-gateway 10.20.136.1,topology subnet,ping 10,ping-restart 60,ifconfig-ipv6 fde6:7a:7d20:1088::105b/64 fde6:7a:7d20:1088::1,ifconfig 10.20.136.93 255.255.255.0,peer-id 2,cipher AES-256-GCM' 2021-01-16 17:23:14 OPTIONS IMPORT: timers and/or timeouts modified 2021-01-16 17:23:14 OPTIONS IMPORT: compression parms modified 2021-01-16 17:23:14 OPTIONS IMPORT: --ifconfig/up options modified 2021-01-16 17:23:14 OPTIONS IMPORT: route options modified 2021-01-16 17:23:14 OPTIONS IMPORT: route-related options modified 2021-01-16 17:23:14 OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified 2021-01-16 17:23:14 OPTIONS IMPORT: peer-id set 2021-01-16 17:23:14 OPTIONS IMPORT: adjusting link_mtu to 1625 2021-01-16 17:23:14 OPTIONS IMPORT: data channel crypto options modified 2021-01-16 17:23:14 Data Channel: using negotiated cipher 'AES-256-GCM' 2021-01-16 17:23:14 Outgoing Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key 2021-01-16 17:23:14 Incoming Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key 2021-01-16 17:23:14 net_route_v4_best_gw query: dst 0.0.0.0 2021-01-16 17:23:14 net_route_v4_best_gw result: via 10.0.0.1 dev enp0s31f6 2021-01-16 17:23:14 ROUTE_GATEWAY 10.0.0.1/255.255.255.0 IFACE=enp0s31f6 HWADDR=4c:cc:6a:6b:95:89 2021-01-16 17:23:14 GDG6: remote_host_ipv6=n/a 2021-01-16 17:23:14 net_route_v6_best_gw query: dst :: 2021-01-16 17:23:14 net_route_v6_best_gw result: via fe80::10:18ff:fe77:60b2 dev enp0s31f6 2021-01-16 17:23:14 ROUTE6_GATEWAY fe80::10:18ff:fe77:60b2 IFACE=enp0s31f6 2021-01-16 17:23:14 TUN/TAP device tun0 opened 2021-01-16 17:23:14 net_iface_mtu_set: mtu 1500 for tun0 2021-01-16 17:23:14 net_iface_up: set tun0 up 2021-01-16 17:23:14 net_addr_v4_add: 10.20.136.93/24 dev tun0 2021-01-16 17:23:14 net_iface_mtu_set: mtu 1500 for tun0 2021-01-16 17:23:14 net_iface_up: set tun0 up 2021-01-16 17:23:14 net_addr_v6_add: fde6:7a:7d20:1088::105b/64 dev tun0 2021-01-16 17:23:14 /etc/openvpn/scripts/update-systemd-resolved tun0 1500 1553 10.20.136.93 255.255.255.0 init <14>Jan 16 17:23:14 update-systemd-resolved: Link 'tun0' coming up <14>Jan 16 17:23:14 update-systemd-resolved: Adding DNS Routed Domain DOMAIN-ROUTE <14>Jan 16 17:23:14 update-systemd-resolved: Adding IPv4 DNS Server 10.20.136.1 <14>Jan 16 17:23:14 update-systemd-resolved: Adding IPv6 DNS Server fde6:7a:7d20:1088::1 <14>Jan 16 17:23:14 update-systemd-resolved: SetLinkDNS(4 2 2 4 10 20 136 1 10 16 253 230 0 122 125 32 16 136 0 0 0 0 0 0 0 1) <14>Jan 16 17:23:14 update-systemd-resolved: SetLinkDomains(4 1 DOMAIN-ROUTE true) 2021-01-16 17:23:20 net_route_v4_add: 68.235.35.123/32 via 10.0.0.1 dev [NULL] table 0 metric -1 2021-01-16 17:23:20 net_route_v4_add: 0.0.0.0/1 via 10.20.136.1 dev [NULL] table 0 metric -1 2021-01-16 17:23:20 net_route_v4_add: 128.0.0.0/1 via 10.20.136.1 dev [NULL] table 0 metric -1 2021-01-16 17:23:20 add_route_ipv6(::/3 -> fde6:7a:7d20:1088::1 metric -1) dev tun0 2021-01-16 17:23:20 net_route_v6_add: ::/3 via :: dev tun0 table 0 metric -1 2021-01-16 17:23:20 add_route_ipv6(2000::/4 -> fde6:7a:7d20:1088::1 metric -1) dev tun0 2021-01-16 17:23:20 net_route_v6_add: 2000::/4 via :: dev tun0 table 0 metric -1 2021-01-16 17:23:20 add_route_ipv6(3000::/4 -> fde6:7a:7d20:1088::1 metric -1) dev tun0 2021-01-16 17:23:20 net_route_v6_add: 3000::/4 via :: dev tun0 table 0 metric -1 2021-01-16 17:23:20 add_route_ipv6(fc00::/7 -> fde6:7a:7d20:1088::1 metric -1) dev tun0 2021-01-16 17:23:20 net_route_v6_add: fc00::/7 via :: dev tun0 table 0 metric -1 2021-01-16 17:23:20 Initialization Sequence Completed Output of resolv.conf (does not change after connecting) [me@hostname ~]$ cat /etc/resolv.conf # Generated by NetworkManager nameserver 1.1.1.1 nameserver 8.8.8.8 Output of resolvectl status after connecting to VPN Global Protocols: +LLMNR +mDNS -DNSOverTLS DNSSEC=no/unsupported resolv.conf mode: foreign Current DNS Server: 1.1.1.1 DNS Servers: 1.1.1.1 8.8.8.8 Fallback DNS Servers: 1.1.1.1 9.9.9.10 8.8.8.8 2606:4700:4700::1111 2620:fe::10 2001:4860:4860::8888 Link 2 (enp0s31f6) Current Scopes: DNS LLMNR/IPv4 LLMNR/IPv6 Protocols: +DefaultRoute +LLMNR -mDNS -DNSOverTLS DNSSEC=no/unsupported Current DNS Server: 1.1.1.1 DNS Servers: 1.1.1.1 8.8.8.8 Link 3 (wlp0s20f0u12) Current Scopes: none Protocols: -DefaultRoute +LLMNR -mDNS -DNSOverTLS DNSSEC=no/unsupported Link 4 (tun0) Current Scopes: DNS LLMNR/IPv4 LLMNR/IPv6 Protocols: -DefaultRoute +LLMNR -mDNS -DNSOverTLS DNSSEC=no/unsupported Current DNS Server: 10.20.136.1 DNS Servers: 10.20.136.1 fde6:7a:7d20:1088::1 DNS Domain: ~DOMAIN-ROUTE After all this, the DNS from ipleak.net does not show it as a valid AirVPN DNS server. I was once able to get it working once by manually editing resolv.conf to have 10.0.4.1 (which I believe is supposed to be universal across all servers, correct?), but I have not been able to replicate this again. For clarification, I am using Network Manager for my regular connection, but am NOT using network-manager-openvpn; I use openvpn directly to connect. I'm assuming this has something to do with network manager but not sure exactly how all the inner workings connect. Thank you for any help Edited ... by thewolfman8326 Quote Share this post Link to post
Tech Jedi Alex 1527 Posted ... 20 hours ago, thewolfman8326 said: After all this, the DNS from ipleak.net does not show it as a valid AirVPN DNS server. I was once able to get it working once by manually editing resolv.conf to have 10.0.4.1 (which I believe is supposed to be universal across all servers, correct?), but I have not been able to replicate this again. Maybe because the server is 10.4.0.1 instead? 20 hours ago, thewolfman8326 said: For clarification, I am using Network Manager for my regular connection, but am NOT using network-manager-openvpn; I use openvpn directly to connect. I'm assuming this has something to do with network manager but not sure exactly how all the inner workings connect. Can't you create a separate NetworkManager profile, then change the profiles using nmcli before connection? Use nmcli connection show to show the list of connections and find out their UUIDs, copy the UUID of the AirDNS connection, then use up /usr/bin/nmcli connection up UUID in the config to change to the OpenVPN connection. Revert with the same command, using the UUID of the usually used connection profile instead. Quote Hide Tech Jedi Alex's signature Hide all signatures NOT AN AIRVPN TEAM MEMBER. USE TICKETS FOR PROFESSIONAL SUPPORT. LZ1's New User Guide to AirVPN « Plenty of stuff for advanced users, too! Want to contact me directly? All relevant methods are on my About me page. Share this post Link to post
thewolfman8326 0 Posted ... On 1/17/2021 at 2:33 PM, OpenSourcerer said: Maybe because the server is 10.4.0.1 instead? Sorry, that was a typo, I did mean 10.4.0.1! Updating original post to clarify (when I did it, ipleak showed it as an AirVPN exit node) On 1/17/2021 at 2:33 PM, OpenSourcerer said: Can't you create a separate NetworkManager profile, then change the profiles using nmcli before connection? Use nmcli connection show to show the list of connections and find out their UUIDs, copy the UUID of the AirDNS connection, then use up /usr/bin/nmcli connection up UUID in the config to change to the OpenVPN connection. Revert with the same command, using the UUID of the usually used connection profile instead. I think slight misunderstanding on one of our parts here; since I don't have the AirVPN connection setup through networkmanager, nmcli connection show doesn't list any UUID for it; only the one for my wired connection. Or did you mean create a connection through that first? However I did notice that after running the openvpn command, my resolvctl status info says my tun0 "current DNS" updates, but my wired "Current DNS" does not (see original post). When modifying my wired connection to ONLY have 10.4.0.1, it seems to work, as that gets set in my "Current DNS" for the wired connection. Somehow Firefox is taking that DNS instead of the tun0 DNS maybe? I'm unfortunately in a rush right now and can't keep troubleshooting, but I'm going to try and make a second wired connection through networkmanager that only has 10.4.0.1 as the sole DNS server option, and try that, and will report back. Thank you for your response! Quote Share this post Link to post
Tech Jedi Alex 1527 Posted ... 12 hours ago, thewolfman8326 said: Or did you mean create a connection through that first? Yes. 12 hours ago, thewolfman8326 said: Somehow Firefox is taking that DNS instead of the tun0 DNS maybe? It's all about speed. If Cloudflare DNS outside the tunnel is faster than AirDNS inside the tunnel, I can imagine Cloudflare gets the request. Quote Hide Tech Jedi Alex's signature Hide all signatures NOT AN AIRVPN TEAM MEMBER. USE TICKETS FOR PROFESSIONAL SUPPORT. LZ1's New User Guide to AirVPN « Plenty of stuff for advanced users, too! Want to contact me directly? All relevant methods are on my About me page. Share this post Link to post
Staff 10490 Posted ... @thewolfman8326 Hello! Strange, as from your reports it seems that update-systemd-resolved is no more sufficient to accept effectively DNS push for certain DNS configurations in Linux. We assume that you have systemd-resolved running in some "on link" mode, or anyway bypassing /etc/resolv.conf, is this correct or not? What is your distribution? In theory, now Bluetit and Hummingbird (they are in the AirVPN Suite software) should handle properly all the numerous "DNS methods" available in Linux to date, even the Windows-like, disgraceful ones which have been adopted lately by some distributions. Can you please test and check whether Bluetit (or Hummingbird) are able to set, during an OpenVPN session, properly DNS in your Linux box AND prevent DNS leaks, or not? See also:https://airvpn.org/forums/topic/48833-linux-airvpn-suite-100-released/ (make sure to read notes about systemd-resolved as well) Kind regards Quote Share this post Link to post
thewolfman8326 0 Posted ... Hummingbird appears to work! (I was having issues with dbus, so did not get to test bluetit; will try to resolve that another time). More details below Here is my systemd-resolved status (prior to using hummingbird). I am on Arch Linux. I couldn't find if I'm using on-link mode or not; here is my status. I saw that Fedora has it as the default, so maybe Arch does too? [me@hostname ~]$ systemctl status systemd-resolved * systemd-resolved.service - Network Name Resolution Loaded: loaded (/usr/lib/systemd/system/systemd-resolved.service; enabled; vendor preset: enabled) Active: active (running) since Fri 2021-01-22 23:35:20 EST; 17h ago Docs: man:systemd-resolved.service(8) man:org.freedesktop.resolve1(5) https://www.freedesktop.org/wiki/Software/systemd/writing-network-configuration-managers https://www.freedesktop.org/wiki/Software/systemd/writing-resolver-clients Main PID: 757 (systemd-resolve) Status: "Processing requests..." Tasks: 1 (limit: 19119) Memory: 5.7M CGroup: /system.slice/systemd-resolved.service `-757 /usr/lib/systemd/systemd-resolved Warning: some journal files were not opened due to insufficient permissions. Additionally I found this report on systemd that may or may not be related?https://github.com/systemd/systemd/issues/5755 poettering commented on Apr 25, 2017 [...]"However, in contrast to classic nss-dns we have memory: when we noticed that a DNS server didn't respond or returned some failure, or for some other reason wasn't working for us, and we skip to the next, then we remember that and the next lookup is attempted with the new one. If that one fails too, then we'll skip to the next one and the next one and so on, until we reach the end of the list and start from the beginning of the list again."[...] This almost sounds like because I had the AIrVPN dns setup all times from NetworkManager, systemd tries it, it fails (because I'm not connected to vpn), and then when I do eventually connect, it "remembers" that it failed? I could be misinterpreting this. Potential other (minor) bug in Hummingbird; it took a little finagling to get disconnects behaving properly; it appears when I disconnect, it resets my "global" DNS settings in "resolvectl status" back to how they were prior, BUT it does not reset my "Link 2" (wired connection) settings back to how they were. This is ok for my needs, since I just reconfigured my global via resolv.conf. I didn't record the logs of this, but if it's something you would like me to retrieve in case you need to adjust the Hummingbird code, I would be happy to get those logs for you. Thank you again for all the help both of you! I'll come back if I encounter any more weird scenarios. Quote Share this post Link to post
Staff 10490 Posted ... @thewolfman8326 Hello! Thanks for the report. It's possible that you have a Fedora 33-like setup, i.e. systemd-resolved configured to bypass resolv.conf, and network-manager also running. It seems that in this setup Hummingbird and Bluetit can properly handle DNS push (apart from the glitch you warn us about and which we'll take care the devs are informed about) but update-systemd-resolved script can't. We would also recommend that you run Goldcrest+Bluetit when you have resolved D-Bus issues, as the client-daemon architecture provides you with a more robust and secure solution than Hummingbird does. Kind regards Quote Share this post Link to post
