Shiloh 0 Posted ... (edited) Hello here is my log: . 2021.01.09 11:20:57 - Eddie version: 2.18.9 / windows_x64, System: Windows, Name: Windows 10 Pro, Version: Microsoft Windows NT 10.0.19041.0, Mono/.Net: v4.0.30319 . 2021.01.09 11:20:57 - Command line arguments (1): path="home" . 2021.01.09 11:20:58 - Profile path: C:\Users\win\AppData\Local\Eddie\default.profile . 2021.01.09 11:20:59 - Reading options from C:\Users\win\AppData\Local\Eddie\default.profile . 2021.01.09 11:21:04 - Tun Driver - 0901: 9.24.2; wintun: Not found . 2021.01.09 11:21:04 - OpenVPN - Version: 2.4.8 - OpenSSL 1.1.0l 10 Sep 2019, LZO 2.10 (C:\Program Files\AirVPN\openvpn.exe) . 2021.01.09 11:21:04 - SSH - Version: plink 0.67 (C:\Program Files\AirVPN\plink.exe) . 2021.01.09 11:21:04 - SSL - Version: stunnel 5.40 (C:\Program Files\AirVPN\stunnel.exe) . 2021.01.09 11:21:04 - curl - Version: 7.68.0 (C:\Program Files\AirVPN\curl.exe) . 2021.01.09 11:21:05 - Recovery. Unexpected crash? . 2021.01.09 11:21:07 - Routes, removed an existing route, 185.206.225.59 for gateway 10.25.214.1 . 2021.01.09 11:21:07 - Routes, removed an existing route, 2001:ac8:38:4:7c0c:6c0f:4ea7:49b9 for gateway fde6:7a:7d20:15d6::1 . 2021.01.09 11:21:08 - Routes, added a new route, 185.206.225.59 for gateway 10.25.194.1 . 2021.01.09 11:21:10 - Routes, removed an existing route, 194.187.251.155 for gateway 10.21.142.1 . 2021.01.09 11:21:10 - Routes, removed an existing route, 2001:ac8:27:7:4f25:6d01:1000:2e9e for gateway fde6:7a:7d20:118e::1 I 2021.01.09 11:21:11 - Ready . 2021.01.09 11:21:13 - Collect information about AirVPN completed I 2021.01.09 11:21:19 - Session starting. . 2021.01.09 11:21:20 - Waiting for latency tests (116 to go) . 2021.01.09 11:21:22 - Waiting for latency tests (96 to go) . 2021.01.09 11:21:23 - Waiting for latency tests (81 to go) . 2021.01.09 11:21:24 - Waiting for latency tests (64 to go) . 2021.01.09 11:21:25 - Waiting for latency tests (47 to go) . 2021.01.09 11:21:26 - Waiting for latency tests (44 to go) . 2021.01.09 11:21:28 - Waiting for latency tests (34 to go) . 2021.01.09 11:21:29 - Waiting for latency tests (19 to go) . 2021.01.09 11:21:30 - Waiting for latency tests (1 to go) I 2021.01.09 11:21:31 - Checking authorization ... ! 2021.01.09 11:21:33 - Connecting to Elnath (Netherlands, Alblasserdam) . 2021.01.09 11:21:33 - OpenVPN > OpenVPN 2.4.8 i686-w64-mingw32 [SSL (OpenSSL)] [LZO] [LZ4] [PKCS11] [AEAD] built on Oct 31 2019 . 2021.01.09 11:21:33 - OpenVPN > Windows version 6.2 (Windows 8 or greater) 64bit . 2021.01.09 11:21:33 - OpenVPN > library versions: OpenSSL 1.1.0l 10 Sep 2019, LZO 2.10 . 2021.01.09 11:21:33 - OpenVPN > Outgoing Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key . 2021.01.09 11:21:33 - OpenVPN > Outgoing Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication . 2021.01.09 11:21:33 - OpenVPN > Incoming Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key . 2021.01.09 11:21:33 - OpenVPN > Incoming Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication . 2021.01.09 11:21:33 - OpenVPN > TCP/UDP: Preserving recently used remote address: [AF_INET]213.152.186.42:443 . 2021.01.09 11:21:33 - OpenVPN > Socket Buffers: R=[65536->262144] S=[65536->262144] . 2021.01.09 11:21:33 - OpenVPN > UDP link local: (not bound) . 2021.01.09 11:21:33 - OpenVPN > UDP link remote: [AF_INET]213.152.186.42:443 . 2021.01.09 11:21:33 - OpenVPN > TLS: Initial packet from [AF_INET]213.152.186.42:443, sid=ea8534c4 4759740b . 2021.01.09 11:21:34 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org . 2021.01.09 11:21:34 - OpenVPN > VERIFY KU OK . 2021.01.09 11:21:34 - OpenVPN > Validating certificate extended key usage . 2021.01.09 11:21:34 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication . 2021.01.09 11:21:34 - OpenVPN > VERIFY EKU OK . 2021.01.09 11:21:34 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=Elnath, emailAddress=info@airvpn.org . 2021.01.09 11:21:34 - OpenVPN > Control Channel: TLSv1.2, cipher TLSv1.2 DHE-RSA-CHACHA20-POLY1305, 4096 bit RSA . 2021.01.09 11:21:34 - OpenVPN > [Elnath] Peer Connection Initiated with [AF_INET]213.152.186.42:443 . 2021.01.09 11:21:35 - OpenVPN > SENT CONTROL [Elnath]: 'PUSH_REQUEST' (status=1) . 2021.01.09 11:21:36 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,comp-lzo no,redirect-gateway ipv6 def1 bypass-dhcp,dhcp-option DNS 10.16.46.1,dhcp-option DNS6 fde6:7a:7d20:c2e::1,tun-ipv6,route-gateway 10.16.46.1,topology subnet,ping 10,ping-restart 60,ifconfig-ipv6 fde6:7a:7d20:c2e::10d4/64 fde6:7a:7d20:c2e::1,ifconfig 10.16.46.214 255.255.255.0,peer-id 0,cipher AES-256-GCM' . 2021.01.09 11:21:36 - OpenVPN > Pushed option removed by filter: 'redirect-gateway ipv6 def1 bypass-dhcp' . 2021.01.09 11:21:36 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified . 2021.01.09 11:21:36 - OpenVPN > OPTIONS IMPORT: compression parms modified . 2021.01.09 11:21:36 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified . 2021.01.09 11:21:36 - OpenVPN > OPTIONS IMPORT: route-related options modified . 2021.01.09 11:21:36 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified . 2021.01.09 11:21:36 - OpenVPN > OPTIONS IMPORT: peer-id set . 2021.01.09 11:21:36 - OpenVPN > OPTIONS IMPORT: adjusting link_mtu to 1625 . 2021.01.09 11:21:36 - OpenVPN > OPTIONS IMPORT: data channel crypto options modified . 2021.01.09 11:21:36 - OpenVPN > Data Channel: using negotiated cipher 'AES-256-GCM' . 2021.01.09 11:21:36 - OpenVPN > Outgoing Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key . 2021.01.09 11:21:36 - OpenVPN > Incoming Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key . 2021.01.09 11:21:36 - OpenVPN > interactive service msg_channel=0 . 2021.01.09 11:21:36 - OpenVPN > ROUTE_GATEWAY 192.168.0.1/255.255.255.0 I=22 HWADDR=00:c0:ca:59:f0:14 . 2021.01.09 11:21:36 - OpenVPN > GDG6: remote_host_ipv6=n/a . 2021.01.09 11:21:36 - OpenVPN > NOTE: GetBestInterfaceEx returned error: Element not found. (code=1168) . 2021.01.09 11:21:36 - OpenVPN > ROUTE6: default_gateway=UNDEF . 2021.01.09 11:21:36 - OpenVPN > open_tun . 2021.01.09 11:21:36 - OpenVPN > TAP-WIN32 device [Local Area Connection] opened: \\.\Global\{3CD0A209-96E4-4CAA-B8C7-42E9F0999D67}.tap . 2021.01.09 11:21:36 - OpenVPN > TAP-Windows Driver Version 9.24 . 2021.01.09 11:21:36 - OpenVPN > Set TAP-Windows TUN subnet mode network/local/netmask = 10.16.46.0/10.16.46.214/255.255.255.0 [SUCCEEDED] . 2021.01.09 11:21:36 - OpenVPN > Notified TAP-Windows driver to set a DHCP IP/netmask of 10.16.46.214/255.255.255.0 on interface {3CD0A209-96E4-4CAA-B8C7-42E9F0999D67} [DHCP-serv: 10.16.46.254, lease-time: 31536000] . 2021.01.09 11:21:36 - OpenVPN > Successful ARP Flush on interface [12] {3CD0A209-96E4-4CAA-B8C7-42E9F0999D67} . 2021.01.09 11:21:37 - OpenVPN > NETSH: C:\WINDOWS\system32\netsh.exe interface ipv6 set address interface=12 fde6:7a:7d20:c2e::10d4 store=active . 2021.01.09 11:21:39 - OpenVPN > NETSH: C:\WINDOWS\system32\netsh.exe interface ipv6 set dns Local Area Connection static fde6:7a:7d20:c2e::1 validate=no . 2021.01.09 11:21:41 - Detected an OpenVPN bug (On-Link route on VPN range), autofix. . 2021.01.09 11:21:42 - OpenVPN > add_route_ipv6(fde6:7a:7d20:c2e::/64 -> fde6:7a:7d20:c2e::10d4 metric 0) dev Local Area Connection . 2021.01.09 11:21:42 - OpenVPN > C:\WINDOWS\system32\netsh.exe interface ipv6 add route fde6:7a:7d20:c2e::/64 interface=12 fe80::8 store=active . 2021.01.09 11:21:42 - OpenVPN > env_block: add PATH=C:\WINDOWS\System32;C:\WINDOWS;C:\WINDOWS\System32\Wbem . 2021.01.09 11:21:46 - OpenVPN > TEST ROUTES: 1/1 succeeded len=0 ret=1 a=0 u/d=up . 2021.01.09 11:21:46 - OpenVPN > C:\WINDOWS\system32\route.exe ADD 213.152.186.42 MASK 255.255.255.255 192.168.0.1 . 2021.01.09 11:21:46 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=55 and dwForwardType=4 . 2021.01.09 11:21:46 - OpenVPN > Route addition via IPAPI succeeded [adaptive] . 2021.01.09 11:21:46 - OpenVPN > C:\WINDOWS\system32\route.exe ADD 0.0.0.0 MASK 128.0.0.0 10.16.46.1 . 2021.01.09 11:21:46 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=25 and dwForwardType=4 . 2021.01.09 11:21:46 - OpenVPN > Route addition via IPAPI succeeded [adaptive] . 2021.01.09 11:21:46 - OpenVPN > C:\WINDOWS\system32\route.exe ADD 128.0.0.0 MASK 128.0.0.0 10.16.46.1 . 2021.01.09 11:21:46 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=25 and dwForwardType=4 . 2021.01.09 11:21:46 - OpenVPN > Route addition via IPAPI succeeded [adaptive] . 2021.01.09 11:21:46 - OpenVPN > add_route_ipv6(::/3 -> fde6:7a:7d20:c2e::1 metric -1) dev Local Area Connection . 2021.01.09 11:21:46 - OpenVPN > C:\WINDOWS\system32\netsh.exe interface ipv6 add route ::/3 interface=12 fe80::8 store=active . 2021.01.09 11:21:46 - OpenVPN > env_block: add PATH=C:\WINDOWS\System32;C:\WINDOWS;C:\WINDOWS\System32\Wbem . 2021.01.09 11:21:47 - OpenVPN > add_route_ipv6(2000::/4 -> fde6:7a:7d20:c2e::1 metric -1) dev Local Area Connection . 2021.01.09 11:21:47 - OpenVPN > C:\WINDOWS\system32\netsh.exe interface ipv6 add route 2000::/4 interface=12 fe80::8 store=active . 2021.01.09 11:21:47 - OpenVPN > env_block: add PATH=C:\WINDOWS\System32;C:\WINDOWS;C:\WINDOWS\System32\Wbem E 2021.01.09 11:21:47 - OpenVPN > ERROR: Windows route add ipv6 command failed: returned error code 1 . 2021.01.09 11:21:47 - OpenVPN > add_route_ipv6(3000::/4 -> fde6:7a:7d20:c2e::1 metric -1) dev Local Area Connection . 2021.01.09 11:21:47 - OpenVPN > C:\WINDOWS\system32\netsh.exe interface ipv6 add route 3000::/4 interface=12 fe80::8 store=active . 2021.01.09 11:21:47 - OpenVPN > env_block: add PATH=C:\WINDOWS\System32;C:\WINDOWS;C:\WINDOWS\System32\Wbem E 2021.01.09 11:21:49 - OpenVPN > ERROR: Windows route add ipv6 command failed: returned error code 1 . 2021.01.09 11:21:49 - OpenVPN > add_route_ipv6(fc00::/7 -> fde6:7a:7d20:c2e::1 metric -1) dev Local Area Connection . 2021.01.09 11:21:49 - OpenVPN > C:\WINDOWS\system32\netsh.exe interface ipv6 add route fc00::/7 interface=12 fe80::8 store=active . 2021.01.09 11:21:49 - OpenVPN > env_block: add PATH=C:\WINDOWS\System32;C:\WINDOWS;C:\WINDOWS\System32\Wbem E 2021.01.09 11:21:50 - OpenVPN > ERROR: Windows route add ipv6 command failed: returned error code 1 . 2021.01.09 11:21:50 - Interface Local Area Connection metric changed from Automatic to 3, layer IPv4 . 2021.01.09 11:21:50 - Interface Local Area Connection metric changed from Automatic to 3, layer IPv6 . 2021.01.09 11:21:50 - DNS leak protection with packet filtering enabled. . 2021.01.09 11:21:54 - Routes, added a new route, 213.152.186.40 for gateway 10.16.46.1 . 2021.01.09 11:21:54 - Routes, added a new route, 2a00:1678:1337:2329:5ced:54a0:7bdd:4330 for gateway fde6:7a:7d20:c2e::1 . 2021.01.09 11:21:54 - Flushing DNS I 2021.01.09 11:21:56 - Checking route IPv4 I 2021.01.09 11:21:57 - Checking route IPv6 . 2021.01.09 11:22:18 - curl: (28) Connection timed out after 20005 milliseconds . 2021.01.09 11:22:18 - Checking route (2° try) . 2021.01.09 11:22:39 - curl: (28) Connection timed out after 20005 milliseconds . 2021.01.09 11:22:39 - Checking route (3° try) . 2021.01.09 11:23:02 - curl: (28) Connection timed out after 20006 milliseconds E 2021.01.09 11:23:02 - Checking route IPv6 failed. . 2021.01.09 11:23:02 - OpenVPN > Initialization Sequence Completed . 2021.01.09 11:23:02 - OpenVPN > AEAD Decrypt error: bad packet ID (may be a replay): [ #360 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings ! 2021.01.09 11:23:02 - Disconnecting . 2021.01.09 11:23:04 - Routes, removed a route previously added, 213.152.186.40 for gateway 10.16.46.1 . 2021.01.09 11:23:05 - Routes, removed a route previously added, 2a00:1678:1337:2329:5ced:54a0:7bdd:4330 for gateway fde6:7a:7d20:c2e::1 . 2021.01.09 11:23:05 - Sending soft termination signal . 2021.01.09 11:23:08 - OpenVPN > SIGTERM received, sending exit notification to peer . 2021.01.09 11:23:11 - OpenVPN > C:\WINDOWS\system32\route.exe DELETE 213.152.186.42 MASK 255.255.255.255 192.168.0.1 . 2021.01.09 11:23:11 - OpenVPN > Route deletion via IPAPI succeeded [adaptive] . 2021.01.09 11:23:11 - OpenVPN > C:\WINDOWS\system32\route.exe DELETE 0.0.0.0 MASK 128.0.0.0 10.16.46.1 . 2021.01.09 11:23:11 - OpenVPN > Route deletion via IPAPI succeeded [adaptive] . 2021.01.09 11:23:11 - OpenVPN > C:\WINDOWS\system32\route.exe DELETE 128.0.0.0 MASK 128.0.0.0 10.16.46.1 . 2021.01.09 11:23:11 - OpenVPN > Route deletion via IPAPI succeeded [adaptive] . 2021.01.09 11:23:11 - OpenVPN > delete_route_ipv6(::/3) . 2021.01.09 11:23:11 - OpenVPN > C:\WINDOWS\system32\netsh.exe interface ipv6 delete route ::/3 interface=12 fe80::8 store=active . 2021.01.09 11:23:11 - OpenVPN > env_block: add PATH=C:\WINDOWS\System32;C:\WINDOWS;C:\WINDOWS\System32\Wbem . 2021.01.09 11:23:12 - OpenVPN > Closing TUN/TAP interface . 2021.01.09 11:23:12 - OpenVPN > delete_route_ipv6(fde6:7a:7d20:c2e::/64) . 2021.01.09 11:23:12 - OpenVPN > C:\WINDOWS\system32\netsh.exe interface ipv6 delete route fde6:7a:7d20:c2e::/64 interface=12 fe80::8 store=active . 2021.01.09 11:23:14 - OpenVPN > NETSH: C:\WINDOWS\system32\netsh.exe interface ipv6 delete address Local Area Connection fde6:7a:7d20:c2e::10d4 store=active . 2021.01.09 11:23:15 - Sending hard termination signal . 2021.01.09 11:23:15 - Connection terminated. . 2021.01.09 11:23:15 - DNS leak protection with packet filtering disabled. . 2021.01.09 11:23:15 - Interface Local Area Connection metric restored from 3 to Automatic, layer IPv4 . 2021.01.09 11:23:15 - Interface Local Area Connection metric restored from 3 to Automatic, layer IPv6 I 2021.01.09 11:23:18 - Checking authorization ... ! 2021.01.09 11:23:20 - Connecting to Anser (Netherlands, Alblasserdam) . 2021.01.09 11:23:22 - OpenVPN > OpenVPN 2.4.8 i686-w64-mingw32 [SSL (OpenSSL)] [LZO] [LZ4] [PKCS11] [AEAD] built on Oct 31 2019 . 2021.01.09 11:23:22 - OpenVPN > Windows version 6.2 (Windows 8 or greater) 64bit . 2021.01.09 11:23:22 - OpenVPN > library versions: OpenSSL 1.1.0l 10 Sep 2019, LZO 2.10 . 2021.01.09 11:23:22 - OpenVPN > Outgoing Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key . 2021.01.09 11:23:22 - OpenVPN > Outgoing Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication . 2021.01.09 11:23:22 - OpenVPN > Incoming Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key . 2021.01.09 11:23:22 - OpenVPN > Incoming Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication . 2021.01.09 11:23:22 - OpenVPN > TCP/UDP: Preserving recently used remote address: [AF_INET]213.152.186.21:443 . 2021.01.09 11:23:22 - OpenVPN > Socket Buffers: R=[65536->262144] S=[65536->262144] . 2021.01.09 11:23:22 - OpenVPN > UDP link local: (not bound) . 2021.01.09 11:23:22 - OpenVPN > UDP link remote: [AF_INET]213.152.186.21:443 . 2021.01.09 11:23:22 - OpenVPN > TLS: Initial packet from [AF_INET]213.152.186.21:443, sid=c22b62c6 b7acfea0 . 2021.01.09 11:23:22 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org . 2021.01.09 11:23:22 - OpenVPN > VERIFY KU OK . 2021.01.09 11:23:22 - OpenVPN > Validating certificate extended key usage . 2021.01.09 11:23:22 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication . 2021.01.09 11:23:22 - OpenVPN > VERIFY EKU OK . 2021.01.09 11:23:22 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=Anser, emailAddress=info@airvpn.org . 2021.01.09 11:23:23 - OpenVPN > Control Channel: TLSv1.2, cipher TLSv1.2 DHE-RSA-CHACHA20-POLY1305, 4096 bit RSA . 2021.01.09 11:23:23 - OpenVPN > [Anser] Peer Connection Initiated with [AF_INET]213.152.186.21:443 . 2021.01.09 11:23:24 - OpenVPN > SENT CONTROL [Anser]: 'PUSH_REQUEST' (status=1) . 2021.01.09 11:23:24 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,comp-lzo no,redirect-gateway ipv6 def1 bypass-dhcp,dhcp-option DNS 10.9.78.1,dhcp-option DNS6 fde6:7a:7d20:54e::1,tun-ipv6,route-gateway 10.9.78.1,topology subnet,ping 10,ping-restart 60,ifconfig-ipv6 fde6:7a:7d20:54e::1047/64 fde6:7a:7d20:54e::1,ifconfig 10.9.78.73 255.255.255.0,peer-id 0,cipher AES-256-GCM' . 2021.01.09 11:23:24 - OpenVPN > Pushed option removed by filter: 'redirect-gateway ipv6 def1 bypass-dhcp' . 2021.01.09 11:23:24 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified . 2021.01.09 11:23:24 - OpenVPN > OPTIONS IMPORT: compression parms modified . 2021.01.09 11:23:24 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified . 2021.01.09 11:23:24 - OpenVPN > OPTIONS IMPORT: route-related options modified . 2021.01.09 11:23:24 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified . 2021.01.09 11:23:24 - OpenVPN > OPTIONS IMPORT: peer-id set . 2021.01.09 11:23:24 - OpenVPN > OPTIONS IMPORT: adjusting link_mtu to 1625 . 2021.01.09 11:23:24 - OpenVPN > OPTIONS IMPORT: data channel crypto options modified . 2021.01.09 11:23:24 - OpenVPN > Data Channel: using negotiated cipher 'AES-256-GCM' . 2021.01.09 11:23:24 - OpenVPN > Outgoing Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key . 2021.01.09 11:23:24 - OpenVPN > Incoming Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key . 2021.01.09 11:23:24 - OpenVPN > interactive service msg_channel=0 . 2021.01.09 11:23:24 - OpenVPN > ROUTE_GATEWAY 192.168.0.1/255.255.255.0 I=22 HWADDR=00:c0:ca:59:f0:14 . 2021.01.09 11:23:24 - OpenVPN > GDG6: remote_host_ipv6=n/a . 2021.01.09 11:23:24 - OpenVPN > NOTE: GetBestInterfaceEx returned error: Element not found. (code=1168) . 2021.01.09 11:23:24 - OpenVPN > ROUTE6: default_gateway=UNDEF . 2021.01.09 11:23:24 - OpenVPN > open_tun . 2021.01.09 11:23:25 - OpenVPN > TAP-WIN32 device [Local Area Connection] opened: \\.\Global\{3CD0A209-96E4-4CAA-B8C7-42E9F0999D67}.tap . 2021.01.09 11:23:25 - OpenVPN > TAP-Windows Driver Version 9.24 . 2021.01.09 11:23:25 - OpenVPN > Set TAP-Windows TUN subnet mode network/local/netmask = 10.9.78.0/10.9.78.73/255.255.255.0 [SUCCEEDED] . 2021.01.09 11:23:25 - OpenVPN > Notified TAP-Windows driver to set a DHCP IP/netmask of 10.9.78.73/255.255.255.0 on interface {3CD0A209-96E4-4CAA-B8C7-42E9F0999D67} [DHCP-serv: 10.9.78.254, lease-time: 31536000] . 2021.01.09 11:23:25 - OpenVPN > Successful ARP Flush on interface [12] {3CD0A209-96E4-4CAA-B8C7-42E9F0999D67} . 2021.01.09 11:23:25 - OpenVPN > NETSH: C:\WINDOWS\system32\netsh.exe interface ipv6 set address interface=12 fde6:7a:7d20:54e::1047 store=active . 2021.01.09 11:23:27 - OpenVPN > NETSH: C:\WINDOWS\system32\netsh.exe interface ipv6 set dns Local Area Connection static fde6:7a:7d20:54e::1 validate=no . 2021.01.09 11:23:29 - OpenVPN > add_route_ipv6(fde6:7a:7d20:54e::/64 -> fde6:7a:7d20:54e::1047 metric 0) dev Local Area Connection . 2021.01.09 11:23:29 - OpenVPN > C:\WINDOWS\system32\netsh.exe interface ipv6 add route fde6:7a:7d20:54e::/64 interface=12 fe80::8 store=active . 2021.01.09 11:23:29 - OpenVPN > env_block: add PATH=C:\WINDOWS\System32;C:\WINDOWS;C:\WINDOWS\System32\Wbem . 2021.01.09 11:23:34 - OpenVPN > TEST ROUTES: 1/1 succeeded len=0 ret=1 a=0 u/d=up . 2021.01.09 11:23:34 - OpenVPN > C:\WINDOWS\system32\route.exe ADD 213.152.186.21 MASK 255.255.255.255 192.168.0.1 . 2021.01.09 11:23:34 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=55 and dwForwardType=4 . 2021.01.09 11:23:34 - OpenVPN > Route addition via IPAPI succeeded [adaptive] . 2021.01.09 11:23:34 - OpenVPN > C:\WINDOWS\system32\route.exe ADD 0.0.0.0 MASK 128.0.0.0 10.9.78.1 . 2021.01.09 11:23:34 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=25 and dwForwardType=4 . 2021.01.09 11:23:34 - OpenVPN > Route addition via IPAPI succeeded [adaptive] . 2021.01.09 11:23:34 - OpenVPN > C:\WINDOWS\system32\route.exe ADD 128.0.0.0 MASK 128.0.0.0 10.9.78.1 . 2021.01.09 11:23:34 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=25 and dwForwardType=4 . 2021.01.09 11:23:34 - OpenVPN > Route addition via IPAPI succeeded [adaptive] . 2021.01.09 11:23:34 - OpenVPN > add_route_ipv6(::/3 -> fde6:7a:7d20:54e::1 metric -1) dev Local Area Connection . 2021.01.09 11:23:34 - OpenVPN > C:\WINDOWS\system32\netsh.exe interface ipv6 add route ::/3 interface=12 fe80::8 store=active . 2021.01.09 11:23:34 - OpenVPN > env_block: add PATH=C:\WINDOWS\System32;C:\WINDOWS;C:\WINDOWS\System32\Wbem . 2021.01.09 11:23:35 - OpenVPN > add_route_ipv6(2000::/4 -> fde6:7a:7d20:54e::1 metric -1) dev Local Area Connection . 2021.01.09 11:23:35 - OpenVPN > C:\WINDOWS\system32\netsh.exe interface ipv6 add route 2000::/4 interface=12 fe80::8 store=active . 2021.01.09 11:23:35 - OpenVPN > env_block: add PATH=C:\WINDOWS\System32;C:\WINDOWS;C:\WINDOWS\System32\Wbem E 2021.01.09 11:23:37 - OpenVPN > ERROR: Windows route add ipv6 command failed: returned error code 1 . 2021.01.09 11:23:37 - OpenVPN > add_route_ipv6(3000::/4 -> fde6:7a:7d20:54e::1 metric -1) dev Local Area Connection . 2021.01.09 11:23:37 - OpenVPN > C:\WINDOWS\system32\netsh.exe interface ipv6 add route 3000::/4 interface=12 fe80::8 store=active . 2021.01.09 11:23:37 - OpenVPN > env_block: add PATH=C:\WINDOWS\System32;C:\WINDOWS;C:\WINDOWS\System32\Wbem E 2021.01.09 11:23:39 - OpenVPN > ERROR: Windows route add ipv6 command failed: returned error code 1 . 2021.01.09 11:23:39 - OpenVPN > add_route_ipv6(fc00::/7 -> fde6:7a:7d20:54e::1 metric -1) dev Local Area Connection . 2021.01.09 11:23:39 - OpenVPN > C:\WINDOWS\system32\netsh.exe interface ipv6 add route fc00::/7 interface=12 fe80::8 store=active . 2021.01.09 11:23:39 - OpenVPN > env_block: add PATH=C:\WINDOWS\System32;C:\WINDOWS;C:\WINDOWS\System32\Wbem E 2021.01.09 11:23:39 - OpenVPN > ERROR: Windows route add ipv6 command failed: returned error code 1 . 2021.01.09 11:23:39 - Interface Local Area Connection metric changed from Automatic to 3, layer IPv4 . 2021.01.09 11:23:39 - Interface Local Area Connection metric changed from Automatic to 3, layer IPv6 . 2021.01.09 11:23:40 - DNS leak protection with packet filtering enabled. . 2021.01.09 11:23:43 - Routes, added a new route, 213.152.186.19 for gateway 10.9.78.1 . 2021.01.09 11:23:44 - Routes, added a new route, 2a00:1678:1337:1911:872d:30ee:c3d0:8480 for gateway fde6:7a:7d20:54e::1 . 2021.01.09 11:23:44 - Flushing DNS I 2021.01.09 11:23:45 - Checking route IPv4 I 2021.01.09 11:23:46 - Checking route IPv6 . 2021.01.09 11:24:07 - curl: (28) Connection timed out after 20009 milliseconds . 2021.01.09 11:24:07 - Checking route (2° try) . 2021.01.09 11:24:29 - curl: (28) Connection timed out after 20008 milliseconds . 2021.01.09 11:24:29 - Checking route (3° try) . 2021.01.09 11:24:52 - curl: (28) Connection timed out after 20002 milliseconds E 2021.01.09 11:24:52 - Checking route IPv6 failed. . 2021.01.09 11:24:52 - OpenVPN > Initialization Sequence Completed . 2021.01.09 11:24:52 - OpenVPN > AEAD Decrypt error: bad packet ID (may be a replay): [ #214 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings ! 2021.01.09 11:24:52 - Disconnecting . 2021.01.09 11:24:53 - Routes, removed a route previously added, 213.152.186.19 for gateway 10.9.78.1 . 2021.01.09 11:24:54 - Routes, removed a route previously added, 2a00:1678:1337:1911:872d:30ee:c3d0:8480 for gateway fde6:7a:7d20:54e::1 . 2021.01.09 11:24:54 - Sending soft termination signal . 2021.01.09 11:24:57 - OpenVPN > SIGTERM received, sending exit notification to peer . 2021.01.09 11:24:59 - OpenVPN > C:\WINDOWS\system32\route.exe DELETE 213.152.186.21 MASK 255.255.255.255 192.168.0.1 . 2021.01.09 11:24:59 - OpenVPN > Route deletion via IPAPI succeeded [adaptive] . 2021.01.09 11:24:59 - OpenVPN > C:\WINDOWS\system32\route.exe DELETE 0.0.0.0 MASK 128.0.0.0 10.9.78.1 . 2021.01.09 11:24:59 - OpenVPN > Route deletion via IPAPI succeeded [adaptive] . 2021.01.09 11:24:59 - OpenVPN > C:\WINDOWS\system32\route.exe DELETE 128.0.0.0 MASK 128.0.0.0 10.9.78.1 . 2021.01.09 11:24:59 - OpenVPN > Route deletion via IPAPI succeeded [adaptive] . 2021.01.09 11:24:59 - OpenVPN > delete_route_ipv6(::/3) . 2021.01.09 11:24:59 - OpenVPN > C:\WINDOWS\system32\netsh.exe interface ipv6 delete route ::/3 interface=12 fe80::8 store=active . 2021.01.09 11:24:59 - OpenVPN > env_block: add PATH=C:\WINDOWS\System32;C:\WINDOWS;C:\WINDOWS\System32\Wbem . 2021.01.09 11:24:59 - OpenVPN > Closing TUN/TAP interface . 2021.01.09 11:24:59 - OpenVPN > delete_route_ipv6(fde6:7a:7d20:54e::/64) . 2021.01.09 11:24:59 - OpenVPN > C:\WINDOWS\system32\netsh.exe interface ipv6 delete route fde6:7a:7d20:54e::/64 interface=12 fe80::8 store=active . 2021.01.09 11:25:01 - OpenVPN > NETSH: C:\WINDOWS\system32\netsh.exe interface ipv6 delete address Local Area Connection fde6:7a:7d20:54e::1047 store=active . 2021.01.09 11:25:03 - Sending hard termination signal . 2021.01.09 11:25:03 - Connection terminated. . 2021.01.09 11:25:03 - DNS leak protection with packet filtering disabled. . 2021.01.09 11:25:03 - Interface Local Area Connection metric restored from 3 to Automatic, layer IPv4 . 2021.01.09 11:25:03 - Interface Local Area Connection metric restored from 3 to Automatic, layer IPv6 I 2021.01.09 11:25:06 - Checking authorization ... ! 2021.01.09 11:25:08 - Connecting to Comae (Netherlands, Alblasserdam) . 2021.01.09 11:25:08 - OpenVPN > OpenVPN 2.4.8 i686-w64-mingw32 [SSL (OpenSSL)] [LZO] [LZ4] [PKCS11] [AEAD] built on Oct 31 2019 . 2021.01.09 11:25:08 - OpenVPN > Windows version 6.2 (Windows 8 or greater) 64bit . 2021.01.09 11:25:08 - OpenVPN > library versions: OpenSSL 1.1.0l 10 Sep 2019, LZO 2.10 . 2021.01.09 11:25:08 - OpenVPN > Outgoing Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key . 2021.01.09 11:25:08 - OpenVPN > Outgoing Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication . 2021.01.09 11:25:08 - OpenVPN > Incoming Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key . 2021.01.09 11:25:08 - OpenVPN > Incoming Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication . 2021.01.09 11:25:08 - OpenVPN > TCP/UDP: Preserving recently used remote address: [AF_INET]213.152.186.165:443 . 2021.01.09 11:25:08 - OpenVPN > Socket Buffers: R=[65536->262144] S=[65536->262144] . 2021.01.09 11:25:08 - OpenVPN > UDP link local: (not bound) . 2021.01.09 11:25:08 - OpenVPN > UDP link remote: [AF_INET]213.152.186.165:443 . 2021.01.09 11:25:08 - OpenVPN > TLS: Initial packet from [AF_INET]213.152.186.165:443, sid=ea48b96b 11a171a4 . 2021.01.09 11:25:09 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org . 2021.01.09 11:25:09 - OpenVPN > VERIFY KU OK . 2021.01.09 11:25:09 - OpenVPN > Validating certificate extended key usage . 2021.01.09 11:25:09 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication . 2021.01.09 11:25:09 - OpenVPN > VERIFY EKU OK . 2021.01.09 11:25:09 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=Comae, emailAddress=info@airvpn.org . 2021.01.09 11:25:09 - OpenVPN > Control Channel: TLSv1.2, cipher TLSv1.2 DHE-RSA-CHACHA20-POLY1305, 4096 bit RSA . 2021.01.09 11:25:09 - OpenVPN > [Comae] Peer Connection Initiated with [AF_INET]213.152.186.165:443 . 2021.01.09 11:25:10 - OpenVPN > SENT CONTROL [Comae]: 'PUSH_REQUEST' (status=1) . 2021.01.09 11:25:11 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,comp-lzo no,redirect-gateway ipv6 def1 bypass-dhcp,dhcp-option DNS 10.17.46.1,dhcp-option DNS6 fde6:7a:7d20:d2e::1,tun-ipv6,route-gateway 10.17.46.1,topology subnet,ping 10,ping-restart 60,ifconfig-ipv6 fde6:7a:7d20:d2e::10af/64 fde6:7a:7d20:d2e::1,ifconfig 10.17.46.177 255.255.255.0,peer-id 2,cipher AES-256-GCM' . 2021.01.09 11:25:11 - OpenVPN > Pushed option removed by filter: 'redirect-gateway ipv6 def1 bypass-dhcp' . 2021.01.09 11:25:11 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified . 2021.01.09 11:25:11 - OpenVPN > OPTIONS IMPORT: compression parms modified . 2021.01.09 11:25:11 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified . 2021.01.09 11:25:11 - OpenVPN > OPTIONS IMPORT: route-related options modified . 2021.01.09 11:25:11 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified . 2021.01.09 11:25:11 - OpenVPN > OPTIONS IMPORT: peer-id set . 2021.01.09 11:25:11 - OpenVPN > OPTIONS IMPORT: adjusting link_mtu to 1625 . 2021.01.09 11:25:11 - OpenVPN > OPTIONS IMPORT: data channel crypto options modified . 2021.01.09 11:25:11 - OpenVPN > Data Channel: using negotiated cipher 'AES-256-GCM' . 2021.01.09 11:25:11 - OpenVPN > Outgoing Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key . 2021.01.09 11:25:11 - OpenVPN > Incoming Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key . 2021.01.09 11:25:11 - OpenVPN > interactive service msg_channel=0 . 2021.01.09 11:25:11 - OpenVPN > ROUTE_GATEWAY 192.168.0.1/255.255.255.0 I=22 HWADDR=00:c0:ca:59:f0:14 . 2021.01.09 11:25:11 - OpenVPN > GDG6: remote_host_ipv6=n/a . 2021.01.09 11:25:11 - OpenVPN > NOTE: GetBestInterfaceEx returned error: Element not found. (code=1168) . 2021.01.09 11:25:11 - OpenVPN > ROUTE6: default_gateway=UNDEF . 2021.01.09 11:25:11 - OpenVPN > open_tun . 2021.01.09 11:25:11 - OpenVPN > TAP-WIN32 device [Local Area Connection] opened: \\.\Global\{3CD0A209-96E4-4CAA-B8C7-42E9F0999D67}.tap . 2021.01.09 11:25:11 - OpenVPN > TAP-Windows Driver Version 9.24 . 2021.01.09 11:25:11 - OpenVPN > Set TAP-Windows TUN subnet mode network/local/netmask = 10.17.46.0/10.17.46.177/255.255.255.0 [SUCCEEDED] . 2021.01.09 11:25:11 - OpenVPN > Notified TAP-Windows driver to set a DHCP IP/netmask of 10.17.46.177/255.255.255.0 on interface {3CD0A209-96E4-4CAA-B8C7-42E9F0999D67} [DHCP-serv: 10.17.46.254, lease-time: 31536000] . 2021.01.09 11:25:11 - OpenVPN > Successful ARP Flush on interface [12] {3CD0A209-96E4-4CAA-B8C7-42E9F0999D67} . 2021.01.09 11:25:12 - OpenVPN > NETSH: C:\WINDOWS\system32\netsh.exe interface ipv6 set address interface=12 fde6:7a:7d20:d2e::10af store=active . 2021.01.09 11:25:15 - OpenVPN > NETSH: C:\WINDOWS\system32\netsh.exe interface ipv6 set dns Local Area Connection static fde6:7a:7d20:d2e::1 validate=no . 2021.01.09 11:25:19 - Detected an OpenVPN bug (On-Link route on VPN range), autofix. . 2021.01.09 11:25:19 - OpenVPN > add_route_ipv6(fde6:7a:7d20:d2e::/64 -> fde6:7a:7d20:d2e::10af metric 0) dev Local Area Connection . 2021.01.09 11:25:19 - OpenVPN > C:\WINDOWS\system32\netsh.exe interface ipv6 add route fde6:7a:7d20:d2e::/64 interface=12 fe80::8 store=active . 2021.01.09 11:25:19 - OpenVPN > env_block: add PATH=C:\WINDOWS\System32;C:\WINDOWS;C:\WINDOWS\System32\Wbem . 2021.01.09 11:25:22 - OpenVPN > TEST ROUTES: 1/1 succeeded len=0 ret=1 a=0 u/d=up . 2021.01.09 11:25:22 - OpenVPN > C:\WINDOWS\system32\route.exe ADD 213.152.186.165 MASK 255.255.255.255 192.168.0.1 . 2021.01.09 11:25:22 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=55 and dwForwardType=4 . 2021.01.09 11:25:22 - OpenVPN > Route addition via IPAPI succeeded [adaptive] . 2021.01.09 11:25:22 - OpenVPN > C:\WINDOWS\system32\route.exe ADD 0.0.0.0 MASK 128.0.0.0 10.17.46.1 . 2021.01.09 11:25:22 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=25 and dwForwardType=4 . 2021.01.09 11:25:22 - OpenVPN > Route addition via IPAPI succeeded [adaptive] . 2021.01.09 11:25:22 - OpenVPN > C:\WINDOWS\system32\route.exe ADD 128.0.0.0 MASK 128.0.0.0 10.17.46.1 . 2021.01.09 11:25:22 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=25 and dwForwardType=4 . 2021.01.09 11:25:22 - OpenVPN > Route addition via IPAPI succeeded [adaptive] . 2021.01.09 11:25:22 - OpenVPN > add_route_ipv6(::/3 -> fde6:7a:7d20:d2e::1 metric -1) dev Local Area Connection . 2021.01.09 11:25:22 - OpenVPN > C:\WINDOWS\system32\netsh.exe interface ipv6 add route ::/3 interface=12 fe80::8 store=active . 2021.01.09 11:25:22 - OpenVPN > env_block: add PATH=C:\WINDOWS\System32;C:\WINDOWS;C:\WINDOWS\System32\Wbem . 2021.01.09 11:25:23 - OpenVPN > add_route_ipv6(2000::/4 -> fde6:7a:7d20:d2e::1 metric -1) dev Local Area Connection . 2021.01.09 11:25:23 - OpenVPN > C:\WINDOWS\system32\netsh.exe interface ipv6 add route 2000::/4 interface=12 fe80::8 store=active . 2021.01.09 11:25:23 - OpenVPN > env_block: add PATH=C:\WINDOWS\System32;C:\WINDOWS;C:\WINDOWS\System32\Wbem E 2021.01.09 11:25:23 - OpenVPN > ERROR: Windows route add ipv6 command failed: returned error code 1 . 2021.01.09 11:25:23 - OpenVPN > add_route_ipv6(3000::/4 -> fde6:7a:7d20:d2e::1 metric -1) dev Local Area Connection . 2021.01.09 11:25:23 - OpenVPN > C:\WINDOWS\system32\netsh.exe interface ipv6 add route 3000::/4 interface=12 fe80::8 store=active . 2021.01.09 11:25:23 - OpenVPN > env_block: add PATH=C:\WINDOWS\System32;C:\WINDOWS;C:\WINDOWS\System32\Wbem E 2021.01.09 11:25:24 - OpenVPN > ERROR: Windows route add ipv6 command failed: returned error code 1 . 2021.01.09 11:25:24 - OpenVPN > add_route_ipv6(fc00::/7 -> fde6:7a:7d20:d2e::1 metric -1) dev Local Area Connection . 2021.01.09 11:25:24 - OpenVPN > C:\WINDOWS\system32\netsh.exe interface ipv6 add route fc00::/7 interface=12 fe80::8 store=active . 2021.01.09 11:25:24 - OpenVPN > env_block: add PATH=C:\WINDOWS\System32;C:\WINDOWS;C:\WINDOWS\System32\Wbem E 2021.01.09 11:25:25 - OpenVPN > ERROR: Windows route add ipv6 command failed: returned error code 1 . 2021.01.09 11:25:25 - Interface Local Area Connection metric changed from Automatic to 3, layer IPv4 . 2021.01.09 11:25:25 - Interface Local Area Connection metric changed from Automatic to 3, layer IPv6 . 2021.01.09 11:25:25 - DNS leak protection with packet filtering enabled. . 2021.01.09 11:25:30 - Routes, added a new route, 213.152.186.163 for gateway 10.17.46.1 . 2021.01.09 11:25:31 - Routes, added a new route, 2a00:1678:1337:2427:6d0d:8eb3:97af:2b12 for gateway fde6:7a:7d20:d2e::1 . 2021.01.09 11:25:31 - Flushing DNS I 2021.01.09 11:25:32 - Checking route IPv4 I 2021.01.09 11:25:33 - Checking route IPv6 . 2021.01.09 11:25:54 - curl: (28) Connection timed out after 20014 milliseconds . 2021.01.09 11:25:54 - Checking route (2° try) And here is my lifebelt info which is stuck at testing atm, so I copy paste manually: Eddie System/Environment Report - 1/9/2021 - 04:26 UTC Eddie version: 2.18.9 Eddie OS build: windows_x64 Eddie architecture: x64 OS type: Windows OS name: Windows 10 Pro OS version: Microsoft Windows NT 10.0.19041.0 OS architecture: x64 Mono /.Net Framework: v4.0.30319 TUN driver: 0901: 9.24.2; wintun: Not found OpenVPN: 2.4.8 - OpenSSL 1.1.0l 10 Sep 2019, LZO 2.10 (C:\Program Files\AirVPN\openvpn.exe) Hummingbird: () SSH: plink 0.67 (C:\Program Files\AirVPN\plink.exe) SSL: stunnel 5.40 (C:\Program Files\AirVPN\stunnel.exe) curl: 7.68.0 (C:\Program Files\AirVPN\curl.exe) Profile path: C:\Users\win\AppData\Local\Eddie\default.profile Data path: C:\Users\win\AppData\Local\Eddie Application path: C:\Program Files\AirVPN Executable path: C:\Program Files\AirVPN\Eddie-UI.exe Command line arguments: (1 args) path="home" Network Lock Active: No Connected to VPN: No Detected DNS: 10.17.46.1, 8.8.8.8, fde6:7a:7d20:d2e::1 Edited ... by OpenSourcerer Apply LOG format to logs Share this post Link to post
Tech Jedi Alex 1531 Posted ... Try again, then Logs tab > lifebelit icon > paste or upload the output. Thank you. Hide Tech Jedi Alex's signature Hide all signatures NOT AN AIRVPN TEAM MEMBER. USE TICKETS FOR PROFESSIONAL SUPPORT. LZ1's New User Guide to AirVPN « Plenty of stuff for advanced users, too! Want to contact me directly? All relevant methods are on my About me page. Share this post Link to post
Paul.Berry 0 Posted ... I have the same problem... From one day to another, no updates, no changes... Share this post Link to post
Shiloh 0 Posted ... Eddie System/Environment Report - 1/12/2021 - 09:53 UTC Eddie version: 2.18.9 Eddie OS build: windows_x64 Eddie architecture: x64 OS type: Windows OS name: Windows 10 Pro OS version: Microsoft Windows NT 10.0.19041.0 OS architecture: x64 Mono /.Net Framework: v4.0.30319 TUN driver: 0901: 9.24.2; wintun: Not found OpenVPN: 2.4.8 - OpenSSL 1.1.0l 10 Sep 2019, LZO 2.10 (C:\Program Files\AirVPN\openvpn.exe) Hummingbird: () SSH: plink 0.67 (C:\Program Files\AirVPN\plink.exe) SSL: stunnel 5.40 (C:\Program Files\AirVPN\stunnel.exe) curl: 7.68.0 (C:\Program Files\AirVPN\curl.exe) Profile path: C:\Users\win\AppData\Local\Eddie\default.profile Data path: C:\Users\win\AppData\Local\Eddie Application path: C:\Program Files\AirVPN Executable path: C:\Program Files\AirVPN\Eddie-UI.exe Command line arguments: (1 args) path="home" Network Lock Active: No Connected to VPN: No Detected DNS: 10.30.58.1, 8.8.8.8, fde6:7a:7d20:1a3a::1 Share this post Link to post
Shiloh 0 Posted ... 12 hours ago, Paul.Berry said: I have the same problem... From one day to another, no updates, no changes... So I managed to solve the problem by disabling all ipv6 options in the networking Tab. Layer Ipv6 set to Block Internet protocol used for internet set to Ipv4 only Share this post Link to post
Tazhill 0 Posted ... I have also been experiencing the same issues, what is our provider planning on doing to resolve this issue? Share this post Link to post
Staff 10510 Posted ... @Shiloh@Tazhill Hello! The most common cause of the issue is that IPv6 is not supported by system OR some network interface (virtual tun included). In both cases you have two options: 1) Enable IPv6 2) Tell Eddie to "block" IPv6 layer, i.e. the solution aopplied by Shiloh. Kind regards Share this post Link to post
Tazhill 0 Posted ... The most common cause of the issue is that IPv6 is not supported by system OR some network interface (virtual tun included). Appreciate this but everything was running up and till recently, no changes have been made my end. Of course I can't speak for the other who have raised this recent problem, curious though don't you think? Kind regards Share this post Link to post
Staff 10510 Posted ... @Tazhill Hello! Are you 100% sure that your system as well as all network interfaces have IPv6 enabled? If so, can you open a ticket to investigate the matter more thoroughly? Please include a system report ("Logs" > LIFE BELT icon > copy all icon > paste into your message) generated while the system is still connected successfully thanks to the "blocked" IPv6 layer. Kind regards Share this post Link to post
Tazhill 0 Posted ... I have been with you for quite a few years now, I have always used the GUI default settings. Admittedly I have played with the setting from time to time such as manually choosing protocol settings to see if this might have any positive impact on bandwidth. I have experimented with the buffer size but to be honest you guys know your stuff so I always tend to revert back to defaults. In all the time I have been with you there has been more or less a faultless service. The other month you had some server issues in Amsterdam I believe so I switched over to a US Server and latency times weren’t bad at all. The recent experience of the IPv6 timing out and then the looping of disconnecting then reconnecting raised a question. As I hadn’t changed any settings so I though let’s log in and see if anyone else is having similar symptoms. Your knowledge far exceeds mine, I’m sure of that. Buy I’m not a novice I have enjoyed building my own builds since the day of AMD Athlons and enjoy playing around with overclocking. Any way for the time being I can use the work around provided by Shiloh and disable IPv6. But just thought I would put it out there so see who else might be experiencing this. It’s no means a criticism or complaint, you guys do a terrific job. Share this post Link to post
Staff 10510 Posted ... @Tazhill Thanks! In order to understand the cause of the issue we need to know whether the problem occurs when some network interface has IPv6 disabled (problem is then expected and explained) or not (problem is then unexpected). The system report will show that. We also ask you to generate the system report while the system is still connected to the VPN (thanks to IPv6 layer block), so that we can see even the properties of the tun virtual network interface used by OpenVPN. Kind regards Share this post Link to post
Tazhill 0 Posted ... Hi there I’m about to move from Intel to AMD so after the rebuild and a fresh OS install let’s see where we go before pursuing this. So for the time being let’s keep things on pause please. Appreciate your responses thank you for your proactive communications. Kind regards Share this post Link to post
Tazhill 0 Posted ... Hi Please see attached, just wondered if there was any correlation between the two. Kind regards Share this post Link to post
Marvelmo 7 Posted ... I've had problems with IPv6 error as described and also Network Lock function since upgrading to 2.19.7 on Windows 10 Home. Tried thoroughly uninstalling and downgrading to an older version of Eddie but it didn't improve. Then tried uninstalling Eddie and installing OpenVPN 2.5 instead. Still had errors. Therefore Eddie was not the problem. Something in the log led me to try "Reset Network TCP/IP Stack" which I found at Open VPN's Community Wiki. It fixed my problem. Seems there are other ways to reset Window's network stack if you search for it. Below is taken from the Open VPN Wiki. Good luck! Windows Vista, 7, 8, 10 Search for Command Prompt > Run As Administrator > Enter the following commands one at a time > Restart computer. netsh winsock reset catalog netsh int ipv4 reset reset.log netsh int ipv6 reset reset.log 1 4 Stoffel, avilon, parack and 2 others reacted to this Share this post Link to post
parack 0 Posted ... (edited) On 2/20/2021 at 9:32 PM, Marvelmo said: I've had problems with IPv6 error as described and also Network Lock function since upgrading to 2.19.7 on Windows 10 Home. Tried thoroughly uninstalling and downgrading to an older version of Eddie but it didn't improve. Then tried uninstalling Eddie and installing OpenVPN 2.5 instead. Still had errors. Therefore Eddie was not the problem. Something in the log led me to try "Reset Network TCP/IP Stack" which I found at Open VPN's Community Wiki. It fixed my problem. Seems there are other ways to reset Window's network stack if you search for it. Below is taken from the Open VPN Wiki. Good luck! Windows Vista, 7, 8, 10 Search for Command Prompt > Run As Administrator > Enter the following commands one at a time > Restart computer. netsh winsock reset catalog netsh int ipv4 reset reset.log netsh int ipv6 reset reset.log This definitely worked in my case as well. The issue is more Windows-related than being Eddie-related. I can describe my situation as "waking up sorely" since I observe this problem usually when the computer wakes up from sleep. Resetting stacks is the solution, it seems. Edited ... by parack Share this post Link to post
magu2k 1 Posted ... Not a top level networking expert but I deal with a 500+ ip network on a daily basis and to me it makes no sense that something "changed" about IPV6 in windows. Granted there have been stranger things(Like a patch that is unrelated to printers nuking printers, thank you MS). I have IPV6 disabled as I do not use it and it is not currently supported by my provider. Airvpn worked perfectly fine with the install I have had for over a year. But when I resubbed I decided to upgrade. It was at this time and only this time that it stopped working. I have tried numerous settings, reinstalling, Admin/non admin, Not sure what else I can do. Symptom: Depending on settings it either fails to connect then tries to connect to another server, or it will "connect" but can not go anywhere, "appears" to have DNS servers, but when checking connection properties (Control Panel-> Network and Sharing Centre) It show sthe tunnel/vpn device as having no gateway. Have tried manually inserting it but it does not change anything. When this is happening, regardless of the specific settings, it typically takes a very logn time to "disconnect" often over a minute. ------------------------------------------------------------------------------------------------ Eddie System/Environment Report - 4/27/2021 - 3:56 AM UTC Eddie version: 2.19.7 Eddie OS build: windows_x64 Eddie architecture: x64 OS type: Windows OS name: Windows 10 Enterprise OS version: Microsoft Windows NT 10.0.18363.0 OS architecture: x64 Mono /.Net Framework: v4.0.30319 TUN driver: 0901: 9.24.2; wintun: 0.8 OpenVPN: 2.5.0 - OpenSSL 1.1.1h 22 Sep 2020, LZO 2.10 (C:\Program Files\AirVPN\openvpn.exe) Hummingbird: () ---------------------------- SSH: plink 0.73 Build platform: 64-bit x86 Windows Compiler: clang 7.0.0 (tags/RELEASE_700/final), emulating Visual Studio 2013 (12.0), _MSC_VER=1800 Source commit: 745ed3ad3beaf52fc623827e770b3a068b238dd5 (C:\Program Files\AirVPN\plink.exe) ---------------------------- SSL: stunnel 5.56 (C:\Program Files\AirVPN\stunnel.exe) Profile path: C:\Program Files\AirVPN\default.profile Data path: C:\Program Files\AirVPN Application path: C:\Program Files\AirVPN Executable path: C:\Program Files\AirVPN\Eddie-UI.exe Command line arguments: (0 args) Network Lock Active: No Connected to VPN: No Detected DNS: 192.168.46.1 Test DNS IPv4: Ok Test DNS IPv6: Failed Test Ping IPv4: 157 ms Test Ping IPv6: Failed Test HTTP IPv4: Ok Test HTTP IPv6: Error: Fetch url error:Couldn't connect to server Test HTTPS: Ok ---------------------------- Important options not at defaults: login: (omissis) password: (omissis) remember: True dns.check: False netlock.allow_dns: True network.entry.iplayer: ipv4-only network.ipv6.mode: block network.ipv6.autoswitch: False advanced.expert: True windows.dns.force_all_interfaces: True ---------------------------- Logs: . 2021.04.26 21:37:40 - Eddie version: 2.19.7 / windows_x64, System: Windows, Name: Windows 10 Enterprise, Version: Microsoft Windows NT 10.0.18363.0, Mono/.Net: v4.0.30319 . 2021.04.26 21:37:40 - Command line arguments (0): . 2021.04.26 21:37:41 - Profile path: C:\Program Files\AirVPN\default.profile . 2021.04.26 21:37:41 - Reading options from C:\Program Files\AirVPN\default.profile . 2021.04.26 21:37:42 - Tun Driver - 0901: 9.24.2; wintun: 0.8 . 2021.04.26 21:37:42 - OpenVPN - Version: 2.5.0 - OpenSSL 1.1.1h 22 Sep 2020, LZO 2.10 (C:\Program Files\AirVPN\openvpn.exe) . 2021.04.26 21:37:42 - SSH - Version: plink 0.73 . 2021.04.26 21:37:42 - Build platform: 64-bit x86 Windows . 2021.04.26 21:37:42 - Compiler: clang 7.0.0 (tags/RELEASE_700/final), emulating Visual Studio 2013 (12.0), _MSC_VER=1800 . 2021.04.26 21:37:42 - Source commit: 745ed3ad3beaf52fc623827e770b3a068b238dd5 (C:\Program Files\AirVPN\plink.exe) . 2021.04.26 21:37:42 - SSL - Version: stunnel 5.56 (C:\Program Files\AirVPN\stunnel.exe) . 2021.04.26 21:37:43 - Recovery. Unexpected crash? . 2021.04.26 21:37:43 - Routes, removed an existing route, 192.30.89.27 for gateway 10.15.226.1 I 2021.04.26 21:37:43 - Ready . 2021.04.26 21:37:45 - Collect information about AirVPN completed I 2021.04.26 21:37:52 - Session starting. I 2021.04.26 21:37:53 - Checking authorization ... . 2021.04.26 21:37:53 - IPv6 disabled with packet filtering. ! 2021.04.26 21:37:53 - Connecting to Tiaki (Netherlands, Alblasserdam) . 2021.04.26 21:37:53 - OpenVPN > OpenVPN 2.5.0 x86_64-w64-mingw32 [SSL (OpenSSL)] [LZO] [LZ4] [PKCS11] [AEAD] built on Oct 28 2020 . 2021.04.26 21:37:53 - OpenVPN > Windows version 10.0 (Windows 10 or greater) 64bit . 2021.04.26 21:37:53 - OpenVPN > library versions: OpenSSL 1.1.1h 22 Sep 2020, LZO 2.10 . 2021.04.26 21:37:53 - OpenVPN > Outgoing Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key . 2021.04.26 21:37:53 - OpenVPN > Outgoing Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication . 2021.04.26 21:37:53 - OpenVPN > Incoming Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key . 2021.04.26 21:37:53 - OpenVPN > Incoming Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication . 2021.04.26 21:37:53 - OpenVPN > TCP/UDP: Preserving recently used remote address: [AF_INET]134.19.179.237:443 . 2021.04.26 21:37:53 - OpenVPN > Socket Buffers: R=[65536->262144] S=[65536->262144] . 2021.04.26 21:37:53 - OpenVPN > UDP link local: (not bound) . 2021.04.26 21:37:53 - OpenVPN > UDP link remote: [AF_INET]134.19.179.237:443 . 2021.04.26 21:37:53 - OpenVPN > TLS: Initial packet from [AF_INET]134.19.179.237:443, sid=f9dc2af0 de0a7086 . 2021.04.26 21:37:54 - OpenVPN > VERIFY KU OK . 2021.04.26 21:37:54 - OpenVPN > Validating certificate extended key usage . 2021.04.26 21:37:54 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication . 2021.04.26 21:37:54 - OpenVPN > VERIFY EKU OK . 2021.04.26 21:37:54 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=Tiaki, emailAddress=info@airvpn.org . 2021.04.26 21:37:54 - OpenVPN > Control Channel: TLSv1.3, cipher TLSv1.3 TLS_CHACHA20_POLY1305_SHA256, 4096 bit RSA . 2021.04.26 21:37:54 - OpenVPN > [Tiaki] Peer Connection Initiated with [AF_INET]134.19.179.237:443 . 2021.04.26 21:37:54 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,comp-lzo no,redirect-gateway ipv6 def1 bypass-dhcp,dhcp-option DNS 10.34.162.1,dhcp-option DNS6 fde6:7a:7d20:1ea2::1,tun-ipv6,route-gateway 10.34.162.1,topology subnet,ping 10,ping-restart 60,ifconfig-ipv6 fde6:7a:7d20:1ea2::105b/64 fde6:7a:7d20:1ea2::1,ifconfig 10.34.162.93 255.255.255.0,peer-id 2,cipher AES-256-GCM' . 2021.04.26 21:37:54 - OpenVPN > Pushed option removed by filter: 'redirect-gateway ipv6 def1 bypass-dhcp' . 2021.04.26 21:37:54 - OpenVPN > Pushed option removed by filter: 'dhcp-option DNS6 fde6:7a:7d20:1ea2::1' . 2021.04.26 21:37:54 - OpenVPN > Pushed option removed by filter: 'tun-ipv6' . 2021.04.26 21:37:54 - OpenVPN > Pushed option removed by filter: 'ifconfig-ipv6 fde6:7a:7d20:1ea2::105b/64 fde6:7a:7d20:1ea2::1' . 2021.04.26 21:37:54 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified . 2021.04.26 21:37:54 - OpenVPN > OPTIONS IMPORT: compression parms modified . 2021.04.26 21:37:54 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified . 2021.04.26 21:37:54 - OpenVPN > OPTIONS IMPORT: route-related options modified . 2021.04.26 21:37:54 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified . 2021.04.26 21:37:54 - OpenVPN > OPTIONS IMPORT: peer-id set . 2021.04.26 21:37:54 - OpenVPN > OPTIONS IMPORT: adjusting link_mtu to 1625 . 2021.04.26 21:37:54 - OpenVPN > OPTIONS IMPORT: data channel crypto options modified . 2021.04.26 21:37:54 - OpenVPN > Data Channel: using negotiated cipher 'AES-256-GCM' . 2021.04.26 21:37:54 - OpenVPN > Outgoing Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key . 2021.04.26 21:37:54 - OpenVPN > Incoming Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key . 2021.04.26 21:37:54 - OpenVPN > interactive service msg_channel=0 . 2021.04.26 21:37:54 - OpenVPN > ROUTE_GATEWAY 192.168.46.1/255.255.255.0 I=8 HWADDR=60:45:cb:9d:89:bf . 2021.04.26 21:37:54 - OpenVPN > open_tun . 2021.04.26 21:37:54 - OpenVPN > tap-windows6 device [Local Area Connection] opened . 2021.04.26 21:37:54 - OpenVPN > TAP-Windows Driver Version 9.24 . 2021.04.26 21:37:54 - OpenVPN > Set TAP-Windows TUN subnet mode network/local/netmask = 10.34.162.0/10.34.162.93/255.255.255.0 [SUCCEEDED] . 2021.04.26 21:37:54 - OpenVPN > Notified TAP-Windows driver to set a DHCP IP/netmask of 10.34.162.93/255.255.255.0 on interface {CBD8A5E0-C167-4987-AC66-C122610B30EB} [DHCP-serv: 10.34.162.254, lease-time: 31536000] . 2021.04.26 21:37:54 - OpenVPN > Successful ARP Flush on interface [7] {CBD8A5E0-C167-4987-AC66-C122610B30EB} . 2021.04.26 21:37:54 - OpenVPN > IPv4 MTU set to 1500 on interface 7 using SetIpInterfaceEntry() . 2021.04.26 21:38:00 - OpenVPN > TEST ROUTES: 1/1 succeeded len=0 ret=1 a=0 u/d=up . 2021.04.26 21:38:00 - OpenVPN > C:\WINDOWS\system32\route.exe ADD 134.19.179.237 MASK 255.255.255.255 192.168.46.1 . 2021.04.26 21:38:00 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=25 and dwForwardType=4 . 2021.04.26 21:38:00 - OpenVPN > Route addition via IPAPI succeeded [adaptive] . 2021.04.26 21:38:00 - OpenVPN > C:\WINDOWS\system32\route.exe ADD 0.0.0.0 MASK 128.0.0.0 10.34.162.1 . 2021.04.26 21:38:00 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=25 and dwForwardType=4 . 2021.04.26 21:38:00 - OpenVPN > Route addition via IPAPI succeeded [adaptive] . 2021.04.26 21:38:00 - OpenVPN > C:\WINDOWS\system32\route.exe ADD 128.0.0.0 MASK 128.0.0.0 10.34.162.1 . 2021.04.26 21:38:00 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=25 and dwForwardType=4 . 2021.04.26 21:38:00 - OpenVPN > Route addition via IPAPI succeeded [adaptive] . 2021.04.26 21:38:00 - Interface Local Area Connection metric changed from Automatic to 3, layer IPv4 . 2021.04.26 21:39:00 - DNS leak protection with packet filtering enabled. . 2021.04.26 21:39:00 - DNS IPv4 of a network adapter forced (Local Area Connection, from automatic to 10.34.162.1) . 2021.04.26 21:39:00 - DNS IPv4 of a network adapter forced (Ethernet 1, from manual (192.168.46.1) to 10.34.162.1) . 2021.04.26 21:39:00 - Routes, added a new route, 134.19.179.235 for gateway 10.34.162.1 . 2021.04.26 21:39:00 - Unable to compute route for 2a00:1678:2470:1616:aeb9:c892:ad0d:ba5a: IPv6 VPN gateway not available. . 2021.04.26 21:39:00 - Flushing DNS I 2021.04.26 21:39:00 - Checking route IPv4 . 2021.04.26 21:39:00 - Fetch url error:Couldn't connect to server . 2021.04.26 21:39:00 - Checking route (2° try) . 2021.04.26 21:39:01 - Fetch url error:Couldn't connect to server . 2021.04.26 21:39:01 - Checking route (3° try) . 2021.04.26 21:39:03 - Fetch url error:Couldn't connect to server E 2021.04.26 21:39:03 - Checking route IPv4 failed. . 2021.04.26 21:39:03 - OpenVPN > Initialization Sequence Completed ! 2021.04.26 21:39:03 - Disconnecting . 2021.04.26 21:39:04 - Routes, removed a route previously added, 134.19.179.235 for gateway 10.34.162.1 . 2021.04.26 21:39:04 - Sending soft termination signal . 2021.04.26 21:39:07 - OpenVPN > SIGTERM received, sending exit notification to peer . 2021.04.26 21:39:09 - OpenVPN > C:\WINDOWS\system32\route.exe DELETE 134.19.179.237 MASK 255.255.255.255 192.168.46.1 . 2021.04.26 21:39:09 - OpenVPN > Route deletion via IPAPI succeeded [adaptive] . 2021.04.26 21:39:09 - OpenVPN > C:\WINDOWS\system32\route.exe DELETE 0.0.0.0 MASK 128.0.0.0 10.34.162.1 . 2021.04.26 21:39:09 - OpenVPN > Route deletion via IPAPI succeeded [adaptive] . 2021.04.26 21:39:09 - OpenVPN > C:\WINDOWS\system32\route.exe DELETE 128.0.0.0 MASK 128.0.0.0 10.34.162.1 . 2021.04.26 21:39:09 - OpenVPN > Route deletion via IPAPI succeeded [adaptive] . 2021.04.26 21:39:09 - OpenVPN > Closing TUN/TAP interface . 2021.04.26 21:39:09 - OpenVPN > TAP: DHCP address released . 2021.04.26 21:39:09 - OpenVPN > SIGTERM[soft,exit-with-notification] received, process exiting . 2021.04.26 21:39:09 - Connection terminated. . 2021.04.26 21:39:33 - ping 1 . 2021.04.26 21:39:33 - ping 2 W . 2021.04.26 21:39:33 - ping 2 WE . 2021.04.26 21:40:12 - IPv6 restored with packet filtering. . 2021.04.26 21:40:12 - DNS IPv4 of a network adapter restored to original settings (Local Area Connection, to automatic) . 2021.04.26 21:40:12 - DNS IPv4 of a network adapter restored to original settings (Ethernet 1, to 192.168.46.1) . 2021.04.26 21:40:12 - DNS leak protection with packet filtering disabled. . 2021.04.26 21:40:12 - Interface Local Area Connection metric restored from 3 to Automatic, layer IPv4 . 2021.04.26 21:40:15 - Waiting for latency tests (40 to go) . 2021.04.26 21:40:16 - Waiting for latency tests (17 to go) I 2021.04.26 21:40:19 - Checking authorization ... . 2021.04.26 21:40:20 - IPv6 disabled with packet filtering. ! 2021.04.26 21:40:20 - Connecting to Pisces (Canada, Vancouver) . 2021.04.26 21:40:20 - OpenVPN > OpenVPN 2.5.0 x86_64-w64-mingw32 [SSL (OpenSSL)] [LZO] [LZ4] [PKCS11] [AEAD] built on Oct 28 2020 . 2021.04.26 21:40:20 - OpenVPN > Windows version 10.0 (Windows 10 or greater) 64bit . 2021.04.26 21:40:20 - OpenVPN > library versions: OpenSSL 1.1.1h 22 Sep 2020, LZO 2.10 . 2021.04.26 21:40:20 - OpenVPN > Outgoing Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key . 2021.04.26 21:40:20 - OpenVPN > Outgoing Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication . 2021.04.26 21:40:20 - OpenVPN > Incoming Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key . 2021.04.26 21:40:20 - OpenVPN > Incoming Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication . 2021.04.26 21:40:20 - OpenVPN > TCP/UDP: Preserving recently used remote address: [AF_INET]192.30.89.29:443 . 2021.04.26 21:40:20 - OpenVPN > Socket Buffers: R=[65536->262144] S=[65536->262144] . 2021.04.26 21:40:20 - OpenVPN > UDP link local: (not bound) . 2021.04.26 21:40:20 - OpenVPN > UDP link remote: [AF_INET]192.30.89.29:443 . 2021.04.26 21:40:20 - OpenVPN > TLS: Initial packet from [AF_INET]192.30.89.29:443, sid=0898589b 2098e0c9 . 2021.04.26 21:40:20 - OpenVPN > VERIFY KU OK . 2021.04.26 21:40:20 - OpenVPN > Validating certificate extended key usage . 2021.04.26 21:40:20 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication . 2021.04.26 21:40:20 - OpenVPN > VERIFY EKU OK . 2021.04.26 21:40:20 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=Pisces, emailAddress=info@airvpn.org . 2021.04.26 21:40:20 - OpenVPN > Control Channel: TLSv1.3, cipher TLSv1.3 TLS_CHACHA20_POLY1305_SHA256, 4096 bit RSA . 2021.04.26 21:40:20 - OpenVPN > [Pisces] Peer Connection Initiated with [AF_INET]192.30.89.29:443 . 2021.04.26 21:40:20 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,comp-lzo no,redirect-gateway ipv6 def1 bypass-dhcp,dhcp-option DNS 10.15.226.1,dhcp-option DNS6 fde6:7a:7d20:be2::1,tun-ipv6,route-gateway 10.15.226.1,topology subnet,ping 10,ping-restart 60,ifconfig-ipv6 fde6:7a:7d20:be2::108f/64 fde6:7a:7d20:be2::1,ifconfig 10.15.226.145 255.255.255.0,peer-id 5,cipher AES-256-GCM' . 2021.04.26 21:40:20 - OpenVPN > Pushed option removed by filter: 'redirect-gateway ipv6 def1 bypass-dhcp' . 2021.04.26 21:40:20 - OpenVPN > Pushed option removed by filter: 'dhcp-option DNS6 fde6:7a:7d20:be2::1' . 2021.04.26 21:40:20 - OpenVPN > Pushed option removed by filter: 'tun-ipv6' . 2021.04.26 21:40:20 - OpenVPN > Pushed option removed by filter: 'ifconfig-ipv6 fde6:7a:7d20:be2::108f/64 fde6:7a:7d20:be2::1' . 2021.04.26 21:40:20 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified . 2021.04.26 21:40:20 - OpenVPN > OPTIONS IMPORT: compression parms modified . 2021.04.26 21:40:20 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified . 2021.04.26 21:40:20 - OpenVPN > OPTIONS IMPORT: route-related options modified . 2021.04.26 21:40:20 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified . 2021.04.26 21:40:20 - OpenVPN > OPTIONS IMPORT: peer-id set . 2021.04.26 21:40:20 - OpenVPN > OPTIONS IMPORT: adjusting link_mtu to 1625 . 2021.04.26 21:40:20 - OpenVPN > OPTIONS IMPORT: data channel crypto options modified . 2021.04.26 21:40:20 - OpenVPN > Data Channel: using negotiated cipher 'AES-256-GCM' . 2021.04.26 21:40:20 - OpenVPN > Outgoing Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key . 2021.04.26 21:40:20 - OpenVPN > Incoming Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key . 2021.04.26 21:40:20 - OpenVPN > interactive service msg_channel=0 . 2021.04.26 21:40:20 - OpenVPN > ROUTE_GATEWAY 192.168.46.1/255.255.255.0 I=8 HWADDR=60:45:cb:9d:89:bf . 2021.04.26 21:40:20 - OpenVPN > open_tun . 2021.04.26 21:40:20 - OpenVPN > tap-windows6 device [Local Area Connection] opened . 2021.04.26 21:40:20 - OpenVPN > TAP-Windows Driver Version 9.24 . 2021.04.26 21:40:20 - OpenVPN > Set TAP-Windows TUN subnet mode network/local/netmask = 10.15.226.0/10.15.226.145/255.255.255.0 [SUCCEEDED] . 2021.04.26 21:40:20 - OpenVPN > Notified TAP-Windows driver to set a DHCP IP/netmask of 10.15.226.145/255.255.255.0 on interface {CBD8A5E0-C167-4987-AC66-C122610B30EB} [DHCP-serv: 10.15.226.254, lease-time: 31536000] . 2021.04.26 21:40:20 - OpenVPN > Successful ARP Flush on interface [7] {CBD8A5E0-C167-4987-AC66-C122610B30EB} . 2021.04.26 21:40:20 - OpenVPN > IPv4 MTU set to 1500 on interface 7 using SetIpInterfaceEntry() ! 2021.04.26 21:40:21 - Disconnecting . 2021.04.26 21:40:21 - Sending soft termination signal . 2021.04.26 21:40:25 - OpenVPN > SIGTERM received, sending exit notification to peer . 2021.04.26 21:40:25 - OpenVPN > TEST ROUTES: 1/1 succeeded len=0 ret=1 a=0 u/d=up . 2021.04.26 21:40:25 - OpenVPN > C:\WINDOWS\system32\route.exe ADD 192.30.89.29 MASK 255.255.255.255 192.168.46.1 . 2021.04.26 21:40:25 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=25 and dwForwardType=4 . 2021.04.26 21:40:25 - OpenVPN > Route addition via IPAPI succeeded [adaptive] . 2021.04.26 21:40:25 - OpenVPN > C:\WINDOWS\system32\route.exe ADD 0.0.0.0 MASK 128.0.0.0 10.15.226.1 . 2021.04.26 21:40:25 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=25 and dwForwardType=4 . 2021.04.26 21:40:25 - OpenVPN > Route addition via IPAPI succeeded [adaptive] . 2021.04.26 21:40:25 - OpenVPN > C:\WINDOWS\system32\route.exe ADD 128.0.0.0 MASK 128.0.0.0 10.15.226.1 . 2021.04.26 21:40:25 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=25 and dwForwardType=4 . 2021.04.26 21:40:25 - OpenVPN > Route addition via IPAPI succeeded [adaptive] . 2021.04.26 21:40:25 - Interface Local Area Connection metric changed from Automatic to 3, layer IPv4 . 2021.04.26 21:42:31 - DNS leak protection with packet filtering enabled. . 2021.04.26 21:42:31 - DNS IPv4 of a network adapter forced (Ethernet 1, from manual (192.168.46.1) to 10.15.226.1) . 2021.04.26 21:42:31 - Routes, restored a previously deleted route, 192.30.89.27 for gateway 10.15.226.1 . 2021.04.26 21:42:31 - Unable to compute route for 2606:9580:103:a:fda7:1f4c:8c40:8c3e: IPv6 VPN gateway not available. . 2021.04.26 21:42:31 - Flushing DNS . 2021.04.26 21:42:31 - OpenVPN > Initialization Sequence Completed . 2021.04.26 21:42:31 - Connection terminated. . 2021.04.26 21:42:31 - IPv6 restored with packet filtering. . 2021.04.26 21:42:31 - DNS IPv4 of a network adapter restored to original settings (Ethernet 1, to 192.168.46.1) . 2021.04.26 21:42:31 - DNS leak protection with packet filtering disabled. . 2021.04.26 21:42:31 - Interface Local Area Connection metric restored from 3 to Automatic, layer IPv4 . 2021.04.26 21:42:31 - OpenVPN > C:\WINDOWS\system32\route.exe DELETE 192.30.89.29 MASK 255.255.255.255 192.168.46.1 . 2021.04.26 21:42:31 - OpenVPN > Route deletion via IPAPI succeeded [adaptive] . 2021.04.26 21:42:31 - OpenVPN > C:\WINDOWS\system32\route.exe DELETE 0.0.0.0 MASK 128.0.0.0 10.15.226.1 . 2021.04.26 21:42:31 - OpenVPN > Route deletion via IPAPI succeeded [adaptive] . 2021.04.26 21:42:31 - OpenVPN > C:\WINDOWS\system32\route.exe DELETE 128.0.0.0 MASK 128.0.0.0 10.15.226.1 . 2021.04.26 21:42:31 - OpenVPN > Route deletion via IPAPI succeeded [adaptive] . 2021.04.26 21:42:31 - OpenVPN > Closing TUN/TAP interface . 2021.04.26 21:42:31 - OpenVPN > TAP: DHCP address released . 2021.04.26 21:42:31 - OpenVPN > SIGTERM[soft,exit-with-notification] received, process exiting I 2021.04.26 21:42:31 - Cancel requested. ! 2021.04.26 21:42:31 - Session terminated. I 2021.04.26 21:47:24 - Session starting. I 2021.04.26 21:47:24 - Checking authorization ... . 2021.04.26 21:47:25 - IPv6 disabled with packet filtering. ! 2021.04.26 21:47:25 - Connecting to Situla (Netherlands, Alblasserdam) . 2021.04.26 21:47:25 - OpenVPN > OpenVPN 2.5.0 x86_64-w64-mingw32 [SSL (OpenSSL)] [LZO] [LZ4] [PKCS11] [AEAD] built on Oct 28 2020 . 2021.04.26 21:47:25 - OpenVPN > Windows version 10.0 (Windows 10 or greater) 64bit . 2021.04.26 21:47:25 - OpenVPN > library versions: OpenSSL 1.1.1h 22 Sep 2020, LZO 2.10 . 2021.04.26 21:47:25 - OpenVPN > Outgoing Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key . 2021.04.26 21:47:25 - OpenVPN > Outgoing Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication . 2021.04.26 21:47:25 - OpenVPN > Incoming Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key . 2021.04.26 21:47:25 - OpenVPN > Incoming Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication . 2021.04.26 21:47:25 - OpenVPN > TCP/UDP: Preserving recently used remote address: [AF_INET]213.152.161.17:443 . 2021.04.26 21:47:25 - OpenVPN > Socket Buffers: R=[65536->262144] S=[65536->262144] . 2021.04.26 21:47:25 - OpenVPN > UDP link local: (not bound) . 2021.04.26 21:47:25 - OpenVPN > UDP link remote: [AF_INET]213.152.161.17:443 . 2021.04.26 21:47:25 - OpenVPN > TLS: Initial packet from [AF_INET]213.152.161.17:443, sid=907d02bf 68ad4178 . 2021.04.26 21:47:25 - OpenVPN > VERIFY KU OK . 2021.04.26 21:47:25 - OpenVPN > Validating certificate extended key usage . 2021.04.26 21:47:25 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication . 2021.04.26 21:47:25 - OpenVPN > VERIFY EKU OK . 2021.04.26 21:47:25 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=Situla, emailAddress=info@airvpn.org . 2021.04.26 21:47:25 - OpenVPN > Control Channel: TLSv1.3, cipher TLSv1.3 TLS_CHACHA20_POLY1305_SHA256, 4096 bit RSA . 2021.04.26 21:47:25 - OpenVPN > [Situla] Peer Connection Initiated with [AF_INET]213.152.161.17:443 . 2021.04.26 21:47:26 - OpenVPN > SENT CONTROL [Situla]: 'PUSH_REQUEST' (status=1) . 2021.04.26 21:47:26 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,comp-lzo no,redirect-gateway ipv6 def1 bypass-dhcp,dhcp-option DNS 10.30.98.1,dhcp-option DNS6 fde6:7a:7d20:1a62::1,tun-ipv6,route-gateway 10.30.98.1,topology subnet,ping 10,ping-restart 60,ifconfig-ipv6 fde6:7a:7d20:1a62::10a5/64 fde6:7a:7d20:1a62::1,ifconfig 10.30.98.167 255.255.255.0,peer-id 1,cipher AES-256-GCM' . 2021.04.26 21:47:26 - OpenVPN > Pushed option removed by filter: 'redirect-gateway ipv6 def1 bypass-dhcp' . 2021.04.26 21:47:26 - OpenVPN > Pushed option removed by filter: 'dhcp-option DNS6 fde6:7a:7d20:1a62::1' . 2021.04.26 21:47:26 - OpenVPN > Pushed option removed by filter: 'tun-ipv6' . 2021.04.26 21:47:26 - OpenVPN > Pushed option removed by filter: 'ifconfig-ipv6 fde6:7a:7d20:1a62::10a5/64 fde6:7a:7d20:1a62::1' . 2021.04.26 21:47:26 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified . 2021.04.26 21:47:26 - OpenVPN > OPTIONS IMPORT: compression parms modified . 2021.04.26 21:47:26 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified . 2021.04.26 21:47:26 - OpenVPN > OPTIONS IMPORT: route-related options modified . 2021.04.26 21:47:26 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified . 2021.04.26 21:47:26 - OpenVPN > OPTIONS IMPORT: peer-id set . 2021.04.26 21:47:26 - OpenVPN > OPTIONS IMPORT: adjusting link_mtu to 1625 . 2021.04.26 21:47:26 - OpenVPN > OPTIONS IMPORT: data channel crypto options modified . 2021.04.26 21:47:26 - OpenVPN > Data Channel: using negotiated cipher 'AES-256-GCM' . 2021.04.26 21:47:26 - OpenVPN > Outgoing Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key . 2021.04.26 21:47:26 - OpenVPN > Incoming Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key . 2021.04.26 21:47:26 - OpenVPN > interactive service msg_channel=0 . 2021.04.26 21:47:26 - OpenVPN > ROUTE_GATEWAY 192.168.46.1/255.255.255.0 I=8 HWADDR=60:45:cb:9d:89:bf . 2021.04.26 21:47:26 - OpenVPN > open_tun . 2021.04.26 21:47:26 - OpenVPN > tap-windows6 device [Local Area Connection] opened . 2021.04.26 21:47:26 - OpenVPN > TAP-Windows Driver Version 9.24 . 2021.04.26 21:47:26 - OpenVPN > Set TAP-Windows TUN subnet mode network/local/netmask = 10.30.98.0/10.30.98.167/255.255.255.0 [SUCCEEDED] . 2021.04.26 21:47:26 - OpenVPN > Notified TAP-Windows driver to set a DHCP IP/netmask of 10.30.98.167/255.255.255.0 on interface {CBD8A5E0-C167-4987-AC66-C122610B30EB} [DHCP-serv: 10.30.98.254, lease-time: 31536000] . 2021.04.26 21:47:26 - OpenVPN > Successful ARP Flush on interface [7] {CBD8A5E0-C167-4987-AC66-C122610B30EB} . 2021.04.26 21:47:26 - OpenVPN > IPv4 MTU set to 1500 on interface 7 using SetIpInterfaceEntry() . 2021.04.26 21:47:31 - OpenVPN > TEST ROUTES: 1/1 succeeded len=0 ret=1 a=0 u/d=up . 2021.04.26 21:47:31 - OpenVPN > C:\WINDOWS\system32\route.exe ADD 213.152.161.17 MASK 255.255.255.255 192.168.46.1 . 2021.04.26 21:47:31 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=25 and dwForwardType=4 . 2021.04.26 21:47:31 - OpenVPN > Route addition via IPAPI succeeded [adaptive] . 2021.04.26 21:47:31 - OpenVPN > C:\WINDOWS\system32\route.exe ADD 0.0.0.0 MASK 128.0.0.0 10.30.98.1 . 2021.04.26 21:47:31 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=25 and dwForwardType=4 . 2021.04.26 21:47:31 - OpenVPN > Route addition via IPAPI succeeded [adaptive] . 2021.04.26 21:47:31 - OpenVPN > C:\WINDOWS\system32\route.exe ADD 128.0.0.0 MASK 128.0.0.0 10.30.98.1 . 2021.04.26 21:47:31 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=25 and dwForwardType=4 . 2021.04.26 21:47:31 - OpenVPN > Route addition via IPAPI succeeded [adaptive] . 2021.04.26 21:47:31 - Interface Local Area Connection metric changed from Automatic to 3, layer IPv4 . 2021.04.26 21:48:32 - DNS leak protection with packet filtering enabled. . 2021.04.26 21:48:32 - DNS IPv4 of a network adapter forced (Local Area Connection, from automatic to 10.30.98.1) . 2021.04.26 21:48:32 - DNS IPv4 of a network adapter forced (Ethernet 1, from manual (192.168.46.1) to 10.30.98.1) . 2021.04.26 21:48:32 - DNS IPv4 of a network adapter forced (Loopback Pseudo-Interface 1, from automatic to 10.30.98.1) . 2021.04.26 21:48:32 - Routes, added a new route, 213.152.161.15 for gateway 10.30.98.1 . 2021.04.26 21:48:32 - Unable to compute route for 2a00:1678:2470:39:ddf1:680c:a9e0:377a: IPv6 VPN gateway not available. . 2021.04.26 21:48:32 - Flushing DNS I 2021.04.26 21:48:32 - Checking route IPv4 . 2021.04.26 21:48:32 - Fetch url error:Couldn't connect to server . 2021.04.26 21:48:32 - Checking route (2° try) . 2021.04.26 21:48:33 - Fetch url error:Couldn't connect to server . 2021.04.26 21:48:33 - Checking route (3° try) . 2021.04.26 21:48:35 - Fetch url error:Couldn't connect to server E 2021.04.26 21:48:35 - Checking route IPv4 failed. . 2021.04.26 21:48:35 - OpenVPN > Initialization Sequence Completed ! 2021.04.26 21:48:35 - Disconnecting . 2021.04.26 21:48:36 - Routes, removed a route previously added, 213.152.161.15 for gateway 10.30.98.1 . 2021.04.26 21:48:36 - Sending soft termination signal . 2021.04.26 21:48:39 - OpenVPN > SIGTERM received, sending exit notification to peer . 2021.04.26 21:48:41 - OpenVPN > C:\WINDOWS\system32\route.exe DELETE 213.152.161.17 MASK 255.255.255.255 192.168.46.1 . 2021.04.26 21:48:41 - OpenVPN > Route deletion via IPAPI succeeded [adaptive] . 2021.04.26 21:48:41 - OpenVPN > C:\WINDOWS\system32\route.exe DELETE 0.0.0.0 MASK 128.0.0.0 10.30.98.1 . 2021.04.26 21:48:41 - OpenVPN > Route deletion via IPAPI succeeded [adaptive] . 2021.04.26 21:48:41 - OpenVPN > C:\WINDOWS\system32\route.exe DELETE 128.0.0.0 MASK 128.0.0.0 10.30.98.1 . 2021.04.26 21:48:41 - OpenVPN > Route deletion via IPAPI succeeded [adaptive] . 2021.04.26 21:48:41 - OpenVPN > Closing TUN/TAP interface . 2021.04.26 21:48:41 - OpenVPN > TAP: DHCP address released . 2021.04.26 21:48:41 - OpenVPN > SIGTERM[soft,exit-with-notification] received, process exiting . 2021.04.26 21:48:41 - Connection terminated. . 2021.04.26 21:49:44 - IPv6 restored with packet filtering. . 2021.04.26 21:49:44 - DNS IPv4 of a network adapter restored to original settings (Local Area Connection, to automatic) . 2021.04.26 21:49:44 - DNS IPv4 of a network adapter restored to original settings (Ethernet 1, to 192.168.46.1) . 2021.04.26 21:49:44 - DNS IPv4 of a network adapter restored to original settings (Loopback Pseudo-Interface 1, to automatic) . 2021.04.26 21:49:44 - DNS leak protection with packet filtering disabled. . 2021.04.26 21:49:44 - Interface Local Area Connection metric restored from 3 to Automatic, layer IPv4 I 2021.04.26 21:49:47 - Checking authorization ... . 2021.04.26 21:49:48 - IPv6 disabled with packet filtering. ! 2021.04.26 21:49:48 - Connecting to Pisces (Canada, Vancouver) . 2021.04.26 21:49:48 - OpenVPN > OpenVPN 2.5.0 x86_64-w64-mingw32 [SSL (OpenSSL)] [LZO] [LZ4] [PKCS11] [AEAD] built on Oct 28 2020 . 2021.04.26 21:49:48 - OpenVPN > Windows version 10.0 (Windows 10 or greater) 64bit . 2021.04.26 21:49:48 - OpenVPN > library versions: OpenSSL 1.1.1h 22 Sep 2020, LZO 2.10 . 2021.04.26 21:49:48 - OpenVPN > Outgoing Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key . 2021.04.26 21:49:48 - OpenVPN > Outgoing Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication . 2021.04.26 21:49:48 - OpenVPN > Incoming Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key . 2021.04.26 21:49:48 - OpenVPN > Incoming Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication . 2021.04.26 21:49:48 - OpenVPN > TCP/UDP: Preserving recently used remote address: [AF_INET]192.30.89.29:443 . 2021.04.26 21:49:48 - OpenVPN > Socket Buffers: R=[65536->262144] S=[65536->262144] . 2021.04.26 21:49:48 - OpenVPN > UDP link local: (not bound) . 2021.04.26 21:49:48 - OpenVPN > UDP link remote: [AF_INET]192.30.89.29:443 . 2021.04.26 21:49:48 - OpenVPN > TLS: Initial packet from [AF_INET]192.30.89.29:443, sid=14d3841a 3f7ad598 . 2021.04.26 21:49:48 - OpenVPN > VERIFY KU OK . 2021.04.26 21:49:48 - OpenVPN > Validating certificate extended key usage . 2021.04.26 21:49:48 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication . 2021.04.26 21:49:48 - OpenVPN > VERIFY EKU OK . 2021.04.26 21:49:48 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=Pisces, emailAddress=info@airvpn.org . 2021.04.26 21:49:48 - OpenVPN > Control Channel: TLSv1.3, cipher TLSv1.3 TLS_CHACHA20_POLY1305_SHA256, 4096 bit RSA . 2021.04.26 21:49:48 - OpenVPN > [Pisces] Peer Connection Initiated with [AF_INET]192.30.89.29:443 . 2021.04.26 21:49:49 - OpenVPN > SENT CONTROL [Pisces]: 'PUSH_REQUEST' (status=1) . 2021.04.26 21:49:49 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,comp-lzo no,redirect-gateway ipv6 def1 bypass-dhcp,dhcp-option DNS 10.15.226.1,dhcp-option DNS6 fde6:7a:7d20:be2::1,tun-ipv6,route-gateway 10.15.226.1,topology subnet,ping 10,ping-restart 60,ifconfig-ipv6 fde6:7a:7d20:be2::108f/64 fde6:7a:7d20:be2::1,ifconfig 10.15.226.145 255.255.255.0,peer-id 18,cipher AES-256-GCM' . 2021.04.26 21:49:49 - OpenVPN > Pushed option removed by filter: 'redirect-gateway ipv6 def1 bypass-dhcp' . 2021.04.26 21:49:49 - OpenVPN > Pushed option removed by filter: 'dhcp-option DNS6 fde6:7a:7d20:be2::1' . 2021.04.26 21:49:49 - OpenVPN > Pushed option removed by filter: 'tun-ipv6' . 2021.04.26 21:49:49 - OpenVPN > Pushed option removed by filter: 'ifconfig-ipv6 fde6:7a:7d20:be2::108f/64 fde6:7a:7d20:be2::1' . 2021.04.26 21:49:49 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified . 2021.04.26 21:49:49 - OpenVPN > OPTIONS IMPORT: compression parms modified . 2021.04.26 21:49:49 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified . 2021.04.26 21:49:49 - OpenVPN > OPTIONS IMPORT: route-related options modified . 2021.04.26 21:49:49 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified . 2021.04.26 21:49:49 - OpenVPN > OPTIONS IMPORT: peer-id set . 2021.04.26 21:49:49 - OpenVPN > OPTIONS IMPORT: adjusting link_mtu to 1625 . 2021.04.26 21:49:49 - OpenVPN > OPTIONS IMPORT: data channel crypto options modified . 2021.04.26 21:49:49 - OpenVPN > Data Channel: using negotiated cipher 'AES-256-GCM' . 2021.04.26 21:49:49 - OpenVPN > Outgoing Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key . 2021.04.26 21:49:49 - OpenVPN > Incoming Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key . 2021.04.26 21:49:49 - OpenVPN > interactive service msg_channel=0 . 2021.04.26 21:49:49 - OpenVPN > ROUTE_GATEWAY 192.168.46.1/255.255.255.0 I=8 HWADDR=60:45:cb:9d:89:bf . 2021.04.26 21:49:49 - OpenVPN > open_tun . 2021.04.26 21:49:49 - OpenVPN > tap-windows6 device [Local Area Connection] opened . 2021.04.26 21:49:49 - OpenVPN > TAP-Windows Driver Version 9.24 . 2021.04.26 21:49:49 - OpenVPN > Set TAP-Windows TUN subnet mode network/local/netmask = 10.15.226.0/10.15.226.145/255.255.255.0 [SUCCEEDED] . 2021.04.26 21:49:49 - OpenVPN > Notified TAP-Windows driver to set a DHCP IP/netmask of 10.15.226.145/255.255.255.0 on interface {CBD8A5E0-C167-4987-AC66-C122610B30EB} [DHCP-serv: 10.15.226.254, lease-time: 31536000] . 2021.04.26 21:49:49 - OpenVPN > Successful ARP Flush on interface [7] {CBD8A5E0-C167-4987-AC66-C122610B30EB} . 2021.04.26 21:49:49 - OpenVPN > IPv4 MTU set to 1500 on interface 7 using SetIpInterfaceEntry() ! 2021.04.26 21:49:51 - Disconnecting . 2021.04.26 21:49:51 - Sending soft termination signal . 2021.04.26 21:49:54 - OpenVPN > SIGTERM received, sending exit notification to peer . 2021.04.26 21:49:55 - OpenVPN > TEST ROUTES: 1/1 succeeded len=0 ret=1 a=0 u/d=up . 2021.04.26 21:49:55 - OpenVPN > C:\WINDOWS\system32\route.exe ADD 192.30.89.29 MASK 255.255.255.255 192.168.46.1 . 2021.04.26 21:49:55 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=25 and dwForwardType=4 . 2021.04.26 21:49:55 - OpenVPN > Route addition via IPAPI succeeded [adaptive] . 2021.04.26 21:49:55 - OpenVPN > C:\WINDOWS\system32\route.exe ADD 0.0.0.0 MASK 128.0.0.0 10.15.226.1 . 2021.04.26 21:49:55 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=25 and dwForwardType=4 . 2021.04.26 21:49:55 - OpenVPN > Route addition via IPAPI succeeded [adaptive] . 2021.04.26 21:49:55 - OpenVPN > C:\WINDOWS\system32\route.exe ADD 128.0.0.0 MASK 128.0.0.0 10.15.226.1 . 2021.04.26 21:49:55 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=25 and dwForwardType=4 . 2021.04.26 21:49:55 - OpenVPN > Route addition via IPAPI succeeded [adaptive] . 2021.04.26 21:49:55 - Interface Local Area Connection metric changed from Automatic to 3, layer IPv4 . 2021.04.26 21:52:00 - DNS leak protection with packet filtering enabled. . 2021.04.26 21:52:00 - DNS IPv4 of a network adapter forced (Ethernet 1, from manual (192.168.46.1) to 10.15.226.1) . 2021.04.26 21:52:01 - DNS IPv4 of a network adapter forced (Loopback Pseudo-Interface 1, from automatic to 10.15.226.1) . 2021.04.26 21:52:01 - Routes, added a new route, 192.30.89.27 for gateway 10.15.226.1 . 2021.04.26 21:52:01 - Unable to compute route for 2606:9580:103:a:fda7:1f4c:8c40:8c3e: IPv6 VPN gateway not available. . 2021.04.26 21:52:01 - Flushing DNS . 2021.04.26 21:52:01 - OpenVPN > Initialization Sequence Completed . 2021.04.26 21:52:01 - Connection terminated. . 2021.04.26 21:52:01 - IPv6 restored with packet filtering. . 2021.04.26 21:52:01 - DNS IPv4 of a network adapter restored to original settings (Ethernet 1, to 192.168.46.1) . 2021.04.26 21:52:01 - DNS IPv4 of a network adapter restored to original settings (Loopback Pseudo-Interface 1, to automatic) . 2021.04.26 21:52:01 - DNS leak protection with packet filtering disabled. . 2021.04.26 21:52:01 - Interface Local Area Connection metric restored from 3 to Automatic, layer IPv4 . 2021.04.26 21:52:01 - OpenVPN > C:\WINDOWS\system32\route.exe DELETE 192.30.89.29 MASK 255.255.255.255 192.168.46.1 . 2021.04.26 21:52:01 - OpenVPN > Route deletion via IPAPI succeeded [adaptive] . 2021.04.26 21:52:01 - OpenVPN > C:\WINDOWS\system32\route.exe DELETE 0.0.0.0 MASK 128.0.0.0 10.15.226.1 . 2021.04.26 21:52:01 - OpenVPN > Route deletion via IPAPI succeeded [adaptive] . 2021.04.26 21:52:01 - OpenVPN > C:\WINDOWS\system32\route.exe DELETE 128.0.0.0 MASK 128.0.0.0 10.15.226.1 . 2021.04.26 21:52:01 - OpenVPN > Route deletion via IPAPI succeeded [adaptive] . 2021.04.26 21:52:01 - OpenVPN > Closing TUN/TAP interface . 2021.04.26 21:52:01 - OpenVPN > TAP: DHCP address released . 2021.04.26 21:52:01 - OpenVPN > SIGTERM[soft,exit-with-notification] received, process exiting I 2021.04.26 21:52:01 - Cancel requested. ! 2021.04.26 21:52:01 - Session terminated. I 2021.04.26 21:52:12 - Session starting. I 2021.04.26 21:52:13 - Checking authorization ... . 2021.04.26 21:52:13 - IPv6 disabled with packet filtering. ! 2021.04.26 21:52:13 - Connecting to Tianyi (Netherlands, Alblasserdam) . 2021.04.26 21:52:13 - OpenVPN > OpenVPN 2.5.0 x86_64-w64-mingw32 [SSL (OpenSSL)] [LZO] [LZ4] [PKCS11] [AEAD] built on Oct 28 2020 . 2021.04.26 21:52:13 - OpenVPN > Windows version 10.0 (Windows 10 or greater) 64bit . 2021.04.26 21:52:13 - OpenVPN > library versions: OpenSSL 1.1.1h 22 Sep 2020, LZO 2.10 . 2021.04.26 21:52:13 - OpenVPN > Outgoing Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key . 2021.04.26 21:52:13 - OpenVPN > Outgoing Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication . 2021.04.26 21:52:13 - OpenVPN > Incoming Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key . 2021.04.26 21:52:13 - OpenVPN > Incoming Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication . 2021.04.26 21:52:13 - OpenVPN > TCP/UDP: Preserving recently used remote address: [AF_INET]213.152.186.175:443 . 2021.04.26 21:52:13 - OpenVPN > Socket Buffers: R=[65536->262144] S=[65536->262144] . 2021.04.26 21:52:13 - OpenVPN > UDP link local: (not bound) . 2021.04.26 21:52:13 - OpenVPN > UDP link remote: [AF_INET]213.152.186.175:443 . 2021.04.26 21:52:13 - OpenVPN > TLS: Initial packet from [AF_INET]213.152.186.175:443, sid=d5f68d14 0bb94a05 . 2021.04.26 21:52:14 - OpenVPN > VERIFY KU OK . 2021.04.26 21:52:14 - OpenVPN > Validating certificate extended key usage . 2021.04.26 21:52:14 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication . 2021.04.26 21:52:14 - OpenVPN > VERIFY EKU OK . 2021.04.26 21:52:14 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=Tianyi, emailAddress=info@airvpn.org . 2021.04.26 21:52:14 - OpenVPN > Control Channel: TLSv1.3, cipher TLSv1.3 TLS_CHACHA20_POLY1305_SHA256, 4096 bit RSA . 2021.04.26 21:52:14 - OpenVPN > [Tianyi] Peer Connection Initiated with [AF_INET]213.152.186.175:443 . 2021.04.26 21:52:15 - OpenVPN > SENT CONTROL [Tianyi]: 'PUSH_REQUEST' (status=1) . 2021.04.26 21:52:15 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,comp-lzo no,redirect-gateway ipv6 def1 bypass-dhcp,dhcp-option DNS 10.7.2.1,dhcp-option DNS6 fde6:7a:7d20:302::1,tun-ipv6,route-gateway 10.7.2.1,topology subnet,ping 10,ping-restart 60,ifconfig-ipv6 fde6:7a:7d20:302::10fa/64 fde6:7a:7d20:302::1,ifconfig 10.7.2.252 255.255.255.0,peer-id 1,cipher AES-256-GCM' . 2021.04.26 21:52:15 - OpenVPN > Pushed option removed by filter: 'redirect-gateway ipv6 def1 bypass-dhcp' . 2021.04.26 21:52:15 - OpenVPN > Pushed option removed by filter: 'dhcp-option DNS6 fde6:7a:7d20:302::1' . 2021.04.26 21:52:15 - OpenVPN > Pushed option removed by filter: 'tun-ipv6' . 2021.04.26 21:52:15 - OpenVPN > Pushed option removed by filter: 'ifconfig-ipv6 fde6:7a:7d20:302::10fa/64 fde6:7a:7d20:302::1' . 2021.04.26 21:52:15 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified . 2021.04.26 21:52:15 - OpenVPN > OPTIONS IMPORT: compression parms modified . 2021.04.26 21:52:15 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified . 2021.04.26 21:52:15 - OpenVPN > OPTIONS IMPORT: route-related options modified . 2021.04.26 21:52:15 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified . 2021.04.26 21:52:15 - OpenVPN > OPTIONS IMPORT: peer-id set . 2021.04.26 21:52:15 - OpenVPN > OPTIONS IMPORT: adjusting link_mtu to 1625 . 2021.04.26 21:52:15 - OpenVPN > OPTIONS IMPORT: data channel crypto options modified . 2021.04.26 21:52:15 - OpenVPN > Data Channel: using negotiated cipher 'AES-256-GCM' . 2021.04.26 21:52:15 - OpenVPN > Outgoing Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key . 2021.04.26 21:52:15 - OpenVPN > Incoming Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key . 2021.04.26 21:52:15 - OpenVPN > interactive service msg_channel=0 . 2021.04.26 21:52:15 - OpenVPN > ROUTE_GATEWAY 192.168.46.1/255.255.255.0 I=8 HWADDR=60:45:cb:9d:89:bf . 2021.04.26 21:52:15 - OpenVPN > open_tun . 2021.04.26 21:52:15 - OpenVPN > tap-windows6 device [Local Area Connection] opened . 2021.04.26 21:52:15 - OpenVPN > TAP-Windows Driver Version 9.24 . 2021.04.26 21:52:15 - OpenVPN > Set TAP-Windows TUN subnet mode network/local/netmask = 10.7.2.0/10.7.2.252/255.255.255.0 [SUCCEEDED] . 2021.04.26 21:52:15 - OpenVPN > Notified TAP-Windows driver to set a DHCP IP/netmask of 10.7.2.252/255.255.255.0 on interface {CBD8A5E0-C167-4987-AC66-C122610B30EB} [DHCP-serv: 10.7.2.254, lease-time: 31536000] . 2021.04.26 21:52:15 - OpenVPN > Successful ARP Flush on interface [7] {CBD8A5E0-C167-4987-AC66-C122610B30EB} . 2021.04.26 21:52:15 - OpenVPN > IPv4 MTU set to 1500 on interface 7 using SetIpInterfaceEntry() . 2021.04.26 21:52:20 - OpenVPN > TEST ROUTES: 1/1 succeeded len=0 ret=1 a=0 u/d=up . 2021.04.26 21:52:20 - OpenVPN > C:\WINDOWS\system32\route.exe ADD 213.152.186.175 MASK 255.255.255.255 192.168.46.1 . 2021.04.26 21:52:20 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=25 and dwForwardType=4 . 2021.04.26 21:52:20 - OpenVPN > Route addition via IPAPI succeeded [adaptive] . 2021.04.26 21:52:20 - OpenVPN > C:\WINDOWS\system32\route.exe ADD 0.0.0.0 MASK 128.0.0.0 10.7.2.1 . 2021.04.26 21:52:20 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=25 and dwForwardType=4 . 2021.04.26 21:52:20 - OpenVPN > Route addition via IPAPI succeeded [adaptive] . 2021.04.26 21:52:20 - OpenVPN > C:\WINDOWS\system32\route.exe ADD 128.0.0.0 MASK 128.0.0.0 10.7.2.1 . 2021.04.26 21:52:20 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=25 and dwForwardType=4 . 2021.04.26 21:52:20 - OpenVPN > Route addition via IPAPI succeeded [adaptive] . 2021.04.26 21:52:20 - Interface Local Area Connection metric changed from Automatic to 3, layer IPv4 . 2021.04.26 21:53:21 - DNS leak protection with packet filtering enabled. . 2021.04.26 21:53:21 - DNS IPv4 of a network adapter forced (Local Area Connection, from automatic to 10.7.2.1) . 2021.04.26 21:53:21 - DNS IPv4 of a network adapter forced (Ethernet 1, from manual (192.168.46.1) to 10.7.2.1) . 2021.04.26 21:53:21 - DNS IPv4 of a network adapter forced (Loopback Pseudo-Interface 1, from automatic to 10.7.2.1) . 2021.04.26 21:53:21 - Routes, added a new route, 213.152.186.173 for gateway 10.7.2.1 . 2021.04.26 21:53:21 - Unable to compute route for 2a00:1678:1337:2430:5879:14eb:6d99:c756: IPv6 VPN gateway not available. . 2021.04.26 21:53:21 - Flushing DNS . 2021.04.26 21:53:21 - OpenVPN > Initialization Sequence Completed ! 2021.04.26 21:53:21 - Disconnecting . 2021.04.26 21:53:21 - Routes, removed a route previously added, 213.152.186.173 for gateway 10.7.2.1 . 2021.04.26 21:53:21 - Sending soft termination signal . 2021.04.26 21:53:24 - OpenVPN > SIGTERM received, sending exit notification to peer . 2021.04.26 21:53:27 - OpenVPN > C:\WINDOWS\system32\route.exe DELETE 213.152.186.175 MASK 255.255.255.255 192.168.46.1 . 2021.04.26 21:53:27 - OpenVPN > Route deletion via IPAPI succeeded [adaptive] . 2021.04.26 21:53:27 - OpenVPN > C:\WINDOWS\system32\route.exe DELETE 0.0.0.0 MASK 128.0.0.0 10.7.2.1 . 2021.04.26 21:53:27 - OpenVPN > Route deletion via IPAPI succeeded [adaptive] . 2021.04.26 21:53:27 - OpenVPN > C:\WINDOWS\system32\route.exe DELETE 128.0.0.0 MASK 128.0.0.0 10.7.2.1 . 2021.04.26 21:53:27 - OpenVPN > Route deletion via IPAPI succeeded [adaptive] . 2021.04.26 21:53:27 - OpenVPN > Closing TUN/TAP interface . 2021.04.26 21:53:27 - OpenVPN > TAP: DHCP address released . 2021.04.26 21:53:27 - OpenVPN > SIGTERM[soft,exit-with-notification] received, process exiting . 2021.04.26 21:53:27 - Connection terminated. . 2021.04.26 21:54:27 - IPv6 restored with packet filtering. . 2021.04.26 21:54:28 - DNS IPv4 of a network adapter restored to original settings (Local Area Connection, to automatic) . 2021.04.26 21:54:28 - DNS IPv4 of a network adapter restored to original settings (Ethernet 1, to 192.168.46.1) . 2021.04.26 21:54:28 - DNS IPv4 of a network adapter restored to original settings (Loopback Pseudo-Interface 1, to automatic) . 2021.04.26 21:54:28 - DNS leak protection with packet filtering disabled. . 2021.04.26 21:54:28 - Interface Local Area Connection metric restored from 3 to Automatic, layer IPv4 I 2021.04.26 21:54:28 - Cancel requested. ! 2021.04.26 21:54:28 - Session terminated. . 2021.04.26 21:56:33 - ping 1 . 2021.04.26 21:56:33 - ping 2 W . 2021.04.26 21:56:33 - ping 2 WE ---------------------------- Network Interfaces and Routes: { "support_ipv4": true, "support_ipv6": true, "routes": [ { "address": "0.0.0.0\/0", "interface": "{C1D6F2D2-47A3-4D0E-A619-0BFC819C750F}", "gateway": "192.168.46.1", "metric": "281" }, { "address": "127.0.0.0\/8", "interface": "{6BB4F047-2706-11E5-9BBE-806E6F6E6963}", "gateway": "link", "metric": "331" }, { "address": "127.0.0.1", "interface": "{6BB4F047-2706-11E5-9BBE-806E6F6E6963}", "gateway": "link", "metric": "331" }, { "address": "127.255.255.255", "interface": "{6BB4F047-2706-11E5-9BBE-806E6F6E6963}", "gateway": "link", "metric": "331" }, { "address": "192.168.46.0\/24", "interface": "{C1D6F2D2-47A3-4D0E-A619-0BFC819C750F}", "gateway": "link", "metric": "281" }, { "address": "192.168.46.46", "interface": "{C1D6F2D2-47A3-4D0E-A619-0BFC819C750F}", "gateway": "link", "metric": "281" }, { "address": "192.168.46.255", "interface": "{C1D6F2D2-47A3-4D0E-A619-0BFC819C750F}", "gateway": "link", "metric": "281" }, { "address": "224.0.0.0\/4", "interface": "{6BB4F047-2706-11E5-9BBE-806E6F6E6963}", "gateway": "link", "metric": "331" }, { "address": "224.0.0.0\/4", "interface": "{C1D6F2D2-47A3-4D0E-A619-0BFC819C750F}", "gateway": "link", "metric": "281" }, { "address": "255.255.255.255", "interface": "{6BB4F047-2706-11E5-9BBE-806E6F6E6963}", "gateway": "link", "metric": "331" }, { "address": "255.255.255.255", "interface": "{C1D6F2D2-47A3-4D0E-A619-0BFC819C750F}", "gateway": "link", "metric": "281" }, { "address": "::1", "interface": "{6BB4F047-2706-11E5-9BBE-806E6F6E6963}", "gateway": "link", "metric": "331" }, { "address": "fe80::\/64", "interface": "{C1D6F2D2-47A3-4D0E-A619-0BFC819C750F}", "gateway": "link", "metric": "281" }, { "address": "fe80::61af:e689:92a:cbf0", "interface": "{C1D6F2D2-47A3-4D0E-A619-0BFC819C750F}", "gateway": "link", "metric": "281" }, { "address": "ff00::\/8", "interface": "{6BB4F047-2706-11E5-9BBE-806E6F6E6963}", "gateway": "link", "metric": "331" }, { "address": "ff00::\/8", "interface": "{C1D6F2D2-47A3-4D0E-A619-0BFC819C750F}", "gateway": "link", "metric": "281" } ], "interfaces": [ { "friendly": "Local Area Connection 2", "id": "{2998C9B1-EDAC-4E3A-A019-58A9C4A1755F}", "name": "Local Area Connection 2", "description": "Wintun Userspace Tunnel", "type": "Virtual", "status": "Down", "bytes_received": "1531561", "bytes_sent": "156430", "support_ipv4": true, "support_ipv6": false, "ips": [ "169.254.25.49" ], "gateways": [], "bind": true, "dns4": "", "dns6": null }, { "friendly": "Ethernet 1", "id": "{C1D6F2D2-47A3-4D0E-A619-0BFC819C750F}", "name": "Ethernet 1", "description": "Intel(R) I211 Gigabit Network Connection #2", "type": "Ethernet", "status": "Up", "bytes_received": "130375926604", "bytes_sent": "1398488106408", "support_ipv4": true, "support_ipv6": true, "ips": [ "fe80::61af:e689:92a:cbf0", "192.168.46.46" ], "gateways": [ "192.168.46.1" ], "bind": true, "dns4": "192.168.46.1", "dns6": null }, { "friendly": "Local Area Connection", "id": "{CBD8A5E0-C167-4987-AC66-C122610B30EB}", "name": "Local Area Connection", "description": "TAP-Windows Adapter V9", "type": "Virtual", "status": "Down", "bytes_received": "1568671", "bytes_sent": "409580", "support_ipv4": true, "support_ipv6": false, "ips": [ "169.254.30.20" ], "gateways": [], "bind": true, "dns4": "", "dns6": null }, { "friendly": "Ethernet 3", "id": "{54F8390A-81A4-4643-940E-6A68AB2B31A4}", "name": "Ethernet 3", "description": "Windscribe VPN", "type": "Ethernet", "status": "Down", "bytes_received": "0", "bytes_sent": "0", "support_ipv4": true, "support_ipv6": true, "ips": [ "fe80::2d35:2f20:3df6:4b09", "169.254.75.9" ], "gateways": [], "bind": true, "dns4": "", "dns6": null }, { "friendly": "Loopback Pseudo-Interface 1", "id": "{6BB4F047-2706-11E5-9BBE-806E6F6E6963}", "name": "Loopback Pseudo-Interface 1", "description": "Software Loopback Interface 1", "type": "Loopback", "status": "Up", "bytes_received": "0", "bytes_sent": "0", "support_ipv4": true, "support_ipv6": true, "ips": [ "::1", "127.0.0.1" ], "gateways": [], "bind": true, "dns4": "", "dns6": null } ], "ipv4-default-gateway": "192.168.46.1", "ipv4-default-interface": "{C1D6F2D2-47A3-4D0E-A619-0BFC819C750F}" } ---------------------------- ipconfig /all: Windows IP Configuration Host Name . . . . . . . . . . . . : mmpc46-010 Primary Dns Suffix . . . . . . . : Node Type . . . . . . . . . . . . : Hybrid IP Routing Enabled. . . . . . . . : No WINS Proxy Enabled. . . . . . . . : No Unknown adapter Local Area Connection 2: Media State . . . . . . . . . . . : Media disconnected Connection-specific DNS Suffix . : Description . . . . . . . . . . . : Wintun Userspace Tunnel Physical Address. . . . . . . . . : DHCP Enabled. . . . . . . . . . . : No Autoconfiguration Enabled . . . . : Yes Ethernet adapter Ethernet 1: Connection-specific DNS Suffix . : Description . . . . . . . . . . . : Intel(R) I211 Gigabit Network Connection #2 Physical Address. . . . . . . . . : 60-45-CB-9D-89-BF DHCP Enabled. . . . . . . . . . . : No Autoconfiguration Enabled . . . . : Yes Link-local IPv6 Address . . . . . : fe80::61af:e689:92a:cbf0%8(Preferred) IPv4 Address. . . . . . . . . . . : 192.168.46.46(Preferred) Subnet Mask . . . . . . . . . . . : 255.255.255.0 Default Gateway . . . . . . . . . : 192.168.46.1 DHCPv6 IAID . . . . . . . . . . . : 325076427 DHCPv6 Client DUID. . . . . . . . : 00-01-00-01-23-74-D4-9E-60-45-CB-9D-89-BF DNS Servers . . . . . . . . . . . : 192.168.46.1 NetBIOS over Tcpip. . . . . . . . : Enabled Unknown adapter Local Area Connection: Media State . . . . . . . . . . . : Media disconnected Connection-specific DNS Suffix . : Description . . . . . . . . . . . : TAP-Windows Adapter V9 Physical Address. . . . . . . . . : 00-FF-CB-D8-A5-E0 DHCP Enabled. . . . . . . . . . . : Yes Autoconfiguration Enabled . . . . : Yes Ethernet adapter Ethernet 3: Media State . . . . . . . . . . . : Media disconnected Connection-specific DNS Suffix . : Description . . . . . . . . . . . : Windscribe VPN Physical Address. . . . . . . . . : 00-FF-54-F8-39-0A DHCP Enabled. . . . . . . . . . . : Yes Autoconfiguration Enabled . . . . : Yes ------------------------------------------------------------------------------------------------------------------------------------------------ I 2021.04.26 21:39:00 - Checking route IPv4 . 2021.04.26 21:39:00 - Fetch url error:Couldn't connect to server . 2021.04.26 21:39:00 - Checking route (2° try) . 2021.04.26 21:39:01 - Fetch url error:Couldn't connect to server . 2021.04.26 21:39:01 - Checking route (3° try) . 2021.04.26 21:39:03 - Fetch url error:Couldn't connect to server E 2021.04.26 21:39:03 - Checking route IPv4 failed. Share this post Link to post
thestiffler 2 Posted ... On 2/20/2021 at 7:32 PM, Marvelmo said: I've had problems with IPv6 error as described and also Network Lock function since upgrading to 2.19.7 on Windows 10 Home. Tried thoroughly uninstalling and downgrading to an older version of Eddie but it didn't improve. Then tried uninstalling Eddie and installing OpenVPN 2.5 instead. Still had errors. Therefore Eddie was not the problem. Something in the log led me to try "Reset Network TCP/IP Stack" which I found at Open VPN's Community Wiki. It fixed my problem. Seems there are other ways to reset Window's network stack if you search for it. Below is taken from the Open VPN Wiki. Good luck! Windows Vista, 7, 8, 10 Search for Command Prompt > Run As Administrator > Enter the following commands one at a time > Restart computer. netsh winsock reset catalog netsh int ipv4 reset reset.log netsh int ipv6 reset reset.log Thanks for that. That helped me too 2 silaversfio and ratsratsrats reacted to this Share this post Link to post
ratsratsrats 1 Posted ... Bump. I've noticed something. Using Eddie 2.20.0 for Windows 10, I get the same error, Eddie gets stuck in checking IPv6 route. I've found that I can fix the problem without restarting the computer or entering command prompt messages, simply by: - Go to Eddie Settings -> Advanced -> Check "Use Wintun driver" - Connect to VPN, it will work this time. - Disconnect, go to settings and uncheck "Use Wintun driver" - Exit Eddie, start it again, now it connects OK. I think this is probably fixed in 2.21.x beta, but I'll wait for the stable release. Share this post Link to post
sinthome 1 Posted ... It seems this issue is still unresolved. I had the same problem this morning with the most recent version of Eddie on Win11. I did the cmd prompt reset, restarted and it is working again. Share this post Link to post
Staff 10510 Posted ... 1 hour ago, sinthome said: It seems this issue is still unresolved. I had the same problem this morning with the most recent version of Eddie on Win11. I did the cmd prompt reset, restarted and it is working again. Please open a new thread, this is outdated and caused by Windows and the TAP adapter driver, not Eddie. Specifically, the problem was partially reproducible with old Eddie version using TAP adapter driver and interface instead of the Wintun driver. If you find this problem with Windows 10 or 11 and Wintun driver chances are that it's a different issue, therefore worth of a new thread. If the problem occurs when you run Eddie 2.24 please feel free to add it on the following thread:https://airvpn.org/forums/topic/57401-eddie-desktop-224-beta-released/ Kind regards Share this post Link to post
