Not connected, Your IP: 216.73.216.63
paladinair
ANSWERED SSL_ERROR_RX_RECORD_TOO_LONG with port forward
I've been using port forwarding with AirVPN since the beginning. I've used both the same destination port and also port forwarding to a different port and both worked fine in the past.
For I few months now it doesn't work anymore.
I have a web interface in LAN with portforwarding by AirVPN. I can connect fine through local LAN, but when I try to connect from WAN with https://xxx.airdns.org:1234  I always get the error message "SSL_ERROR_RX_RECORD_TOO_LONG" I've tried with several different web UIs (bittorrent, file manager,...), nothing works anymore. The ports themselves seem to work, at least AirVPN shows ports open (green light) when I click "check".
This error indicates that you're trying to connect to a website served with HTTP using the HTTPS protocol. Can you check if http://xxx.airvpn.org:1234 works?
Thanks for the reply. I already checked, when I try http, I get ERR_INVALID_HTTP_RESPONSE (I can only try in chrome because firefox automatically changes to https; the chromer error message, when I try to use https, is: ERR_CONNECTION_CLOSED); . It is definitely https, because I can connect through https://192.168.x.x:1234 in my local lan without problems.
I've had the problem in the past with an http web ui. Firefox always changed to https and brought the "record too long" error. That's why I've searched and installed different products with https web UIs.
Thank You,
Peter
You could try connecting with curl and see if more meaningful error messages are coming back. Works best on Linux/BSD, probably on macOS, too, but on Windows, well… :) not exactly an admins' OS, I must say, but try your luck on the downloads page.
Hi, thanks for your help. Here are the reults for curl in both https and http: (name and port are sanitized)
#curl https://xxx.airdns.org:1234
curl: (35) error:140770FC:SSL routines:SSL23_GET_SERVER_HELLO:unknown protocol
#curl http://xxx.airdns.org:1234
curl: (52) Empty reply from server
If I use curl from within the LAN: curl https://192.168.x.x:1234, it works without error.
I don't know if it's important but I use openvpn on a ubitquity edgerouter x. with a destination nat from the openvpn interface to the host 192.168.x.x and port 1234.
Please do the same but with verbose switches.
$ curl -vvv http://the.website:1234
here are the results:
# curl https://xxx.airdns.org:1234 -vvv
* About to connect() to xxx.airdns.org port 1234 (#0)
*   Trying xxx.xxx.xxx.xxx...
* connected
* Connected to xxx.airdns.org (xxx.xxx.xxx.xxx) port 1234 (#0)
* successfully set certificate verify locations:
*   CAfile: none
  CApath: /etc/ssl/certs
* SSLv3, TLS handshake, Client hello (1):
* error:140770FC:SSL routines:SSL23_GET_SERVER_HELLO:unknown protocol
* Closing connection #0
# curl http://xxx.airdns.org:1234 -vvv
* connected
> GET / HTTP/1.1
> User-Agent: curl/7.26.0
> Host: xxx.airdns.org:1234
> Accept: */*
* additional stuff not fine transfer.c:1037: 0 0
the last line repeated until I pressed Ctrl-c
There must be something wrong with your configuration, it's trying to connect using SSLv3. Are you absolutely sure your ports are forwarded to that device? Can you see connection attempts on the device?
What TLS certificate is returned if you connect via AirDDNS? A quick search returned something like this could help:
openssl s_client -showcerts -connect your.website:443|openssl x509 -text|grep -A2 validity
Can you make sure you get the same output on both a local and remote attempt?
through AirDDNS I get:
connect: Connection refused
connect:errno=111
unable to load certificate
3069650128:error:0906D06C:PEM routines:PEM_read_bio:no start line:pem_lib.c:703:Expecting: TRUSTED CERTIFICATE
in my LAN I get:
depth=0 C = AT, O = xxx, CN = xxx
verify error:num=18:self signed certificate
verify return:1
verify return:1
Could this be the problem? I created a certificate myself. I wouldn't have any problems with a warning that it is no trusted certificate...
Thank You.
@paladinair
A couple of ideas coming to mind:
1) You run some curl version linked to a library that does not support the underlying cipher that your server proposes
2) You run some curl version linked to a library that does not support the TLS protocol required by your server (example: your server requires TLS 1.x and curl does not support it)
Thanks for the help. I only use curl for testing (see first posts). I want to connect (with Chrome or Firefox) through Airddns portforwarding to an https - web ui.
The web ui works fine with https from local lan and airvpn reports the forwarded port as open. But when I try to open the web ui through airddns, I get the above errors. I think it has something to do with my router. I use a ubiquiti edgerouter x with openvpn and a portforwarding (destination NAT) to my host for the web ui.
Thank You
A few router web servers, by default settings, only accept connections from IP addresses in the LAN for security reasons. That would explain why you get error 111 (connection refused) and the other SSL related issue only when the connection comes from the outside. Checking the router web server configuration is worthwhile.
It works now. I've forgotten to set a firewall rule on the router allowing this port. It's strange that the port was seen open at all.
Thank You for Your help.
