govegan3 2 Posted ... (edited) Linux Mint 20 UlyanaCinnamon 4.6.7 Desktop Eddie-UI 2.18.9 Hello, I have the above configuration. Eddie will not turn off. I can not disconnect. I can not close the GUI. I can minimize it though. sudo killall eddie-tray does not work sudo killall eddie-ui does not work logging out does not work. I can only stop Eddie by powering off my computer and turning it back on. Is there anything I can do to fix this situation? Season's Greetings. Edited ... by govegan3 Share this post Link to post
Tech Jedi Alex 1574 Posted ... Start it in a terminal so that Mono errors are printed. Once it hangs up like this, see if there are any errors. Are you doing anything to make this happen? 17 minutes ago, govegan3 said: sudo killall eddie-tray does not work sudo killall eddie-ui does not work kill, pkill and killall take a signal as an argument. It defaults to -SIGTERM or -15 if not given which is as if you clicked X. Since this doesn't work if you click X, SIGTERM will not work as well. Next time try -SIGKILL or -9 instead. # pkill -9 eddie-ui eddie-tray . Hide Tech Jedi Alex's signature Hide all signatures NOT AN AIRVPN TEAM MEMBER. USE TICKETS FOR PROFESSIONAL SUPPORT. LZ1's New User Guide to AirVPN « Plenty of stuff for advanced users, too! Want to contact me directly? All relevant methods are on my About me page. Share this post Link to post
govegan3 2 Posted ... I just tried Eddie and it closed properly. Next time I use it, I will start it from the Linux command prompt and let it run for a long time, as running it for a long time seems to be a factor. I will try sudo pkill -9 eddie-ui eddie-tray the next Eddie jams. Thank you. Share this post Link to post
Staff 10648 Posted ... @govegan3 Thank you for the report! In order to let us try and reproduce the issue, can you determine more precisely and tell us the "long time" you mention? Can you also tell us your distribution name and version? Kind regards Share this post Link to post
govegan3 2 Posted ... (edited) 6 hours ago, Staff said: @govegan3 Thank you for the report! In order to let us try and reproduce the issue, can you determine more precisely and tell us the "long time" you mention? Can you also tell us your distribution name and version? Kind regards Here are the specifics about my system that you asked for:Linux Mint 20 UlyanaCinnamon 4.6.7 Desktop Eddie-UI 2.1.8.9 The bug happened after leaving Eddie running for 5 hours on the system above. The disconnect button did not work and I could not shut off Eddie. I started Eddie in a linux terminal, here is the output of the run: Mint20UlyanaCinnamon4.6.7> /usr/bin/eddie-ui . 2020.12.30 06:15:07 - Eddie version: 2.18.9 / linux_x64, System: Linux, Name: Linux Mint 20 Ulyana \n \l, Version: Linux Godzilla 5.4.0-58-generic #64-Ubuntu SMP Wed Dec 9 08:16:25 UTC 2020 x86_64 x86_64 x86_64 GNU/Linux, Mono/.Net: 6.8.0.105 (Debian 6.8.0.105+dfsg-2 Wed Feb 26 23:23:50 UTC 2020); Framework: v4.0.30319 . 2020.12.30 06:15:07 - Command line arguments (2): path.resources="/usr/share/eddie-ui" path.exec="/usr/bin/eddie-ui" . 2020.12.30 06:15:07 - Raise system privileges . 2020.12.30 06:15:13 - Profile path: /home/steve/.config/eddie/default.profile . 2020.12.30 06:15:14 - Reading options from /home/steve/.config/eddie/default.profile . 2020.12.30 06:15:14 - Tun Driver - /dev/net/tun . 2020.12.30 06:15:14 - OpenVPN - Version: 2.4.7 - OpenSSL 1.1.1f 31 Mar 2020, LZO 2.10 (/usr/sbin/openvpn) . 2020.12.30 06:15:14 - SSH - Version: OpenSSH_8.2p1 Ubuntu-4ubuntu0.1, OpenSSL 1.1.1f 31 Mar 2020 (/usr/bin/ssh) . 2020.12.30 06:15:14 - SSL - Version: stunnel 5.56 (/usr/bin/stunnel4) . 2020.12.30 06:15:14 - curl - Version: 7.68.0 (/usr/bin/curl) . 2020.12.30 06:15:14 - Recovery. Unexpected crash? W 2020.12.30 06:15:14 - Routes, add 184.75.221.195 for gateway 10.31.102.1 failed: Exception: Cannot find device "tun0" W 2020.12.30 06:15:14 - Routes, add 2606:6080:1001:15:45d:2b31:f931:2e2 for gateway fde6:7a:7d20:1b66::1 failed: Exception: Cannot find device "tun0" I 2020.12.30 06:15:15 - Ready . 2020.12.30 06:15:16 - Collect information about AirVPN completed I 2020.12.30 06:15:26 - Session starting. . 2020.12.30 06:15:26 - Waiting for latency tests (2 to go) I 2020.12.30 06:15:28 - Checking authorization ... ! 2020.12.30 06:15:28 - Connecting to Arkab (Canada, Toronto, Ontario) . 2020.12.30 06:15:29 - OpenVPN > OpenVPN 2.4.7 x86_64-pc-linux-gnu [SSL (OpenSSL)] [LZO] [LZ4] [EPOLL] [PKCS11] [MH/PKTINFO] [AEAD] built on Sep 5 2019 . 2020.12.30 06:15:29 - OpenVPN > library versions: OpenSSL 1.1.1f 31 Mar 2020, LZO 2.10 . 2020.12.30 06:15:29 - OpenVPN > Outgoing Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key . 2020.12.30 06:15:29 - OpenVPN > Outgoing Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication . 2020.12.30 06:15:29 - OpenVPN > Incoming Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key . 2020.12.30 06:15:29 - OpenVPN > Incoming Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication . 2020.12.30 06:15:29 - OpenVPN > TCP/UDP: Preserving recently used remote address: [AF_INET]184.75.221.213:443 . 2020.12.30 06:15:29 - OpenVPN > Socket Buffers: R=[212992->212992] S=[212992->212992] . 2020.12.30 06:15:29 - OpenVPN > UDP link local: (not bound) . 2020.12.30 06:15:29 - OpenVPN > UDP link remote: [AF_INET]184.75.221.213:443 . 2020.12.30 06:15:29 - OpenVPN > TLS: Initial packet from [AF_INET]184.75.221.213:443, sid=923d6ecc 2a68b3fa . 2020.12.30 06:15:29 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org . 2020.12.30 06:15:29 - OpenVPN > VERIFY KU OK . 2020.12.30 06:15:29 - OpenVPN > Validating certificate extended key usage . 2020.12.30 06:15:29 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication . 2020.12.30 06:15:29 - OpenVPN > VERIFY EKU OK . 2020.12.30 06:15:29 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=Arkab, emailAddress=info@airvpn.org . 2020.12.30 06:15:29 - OpenVPN > Control Channel: TLSv1.3, cipher TLSv1.3 TLS_CHACHA20_POLY1305_SHA256, 4096 bit RSA . 2020.12.30 06:15:29 - OpenVPN > [Arkab] Peer Connection Initiated with [AF_INET]184.75.221.213:443 . 2020.12.30 06:15:30 - OpenVPN > SENT CONTROL [Arkab]: 'PUSH_REQUEST' (status=1) . 2020.12.30 06:15:30 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,comp-lzo no,redirect-gateway ipv6 def1 bypass-dhcp,dhcp-option DNS 10.9.230.1,dhcp-option DNS6 fde6:7a:7d20:5e6::1,tun-ipv6,route-gateway 10.9.230.1,topology subnet,ping 10,ping-restart 60,ifconfig-ipv6 fde6:7a:7d20:5e6::10a2/64 fde6:7a:7d20:5e6::1,ifconfig 10.9.230.164 255.255.255.0,peer-id 0,cipher AES-256-GCM' . 2020.12.30 06:15:30 - OpenVPN > Pushed option removed by filter: 'redirect-gateway ipv6 def1 bypass-dhcp' . 2020.12.30 06:15:30 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified . 2020.12.30 06:15:30 - OpenVPN > OPTIONS IMPORT: compression parms modified . 2020.12.30 06:15:30 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified . 2020.12.30 06:15:30 - OpenVPN > OPTIONS IMPORT: route-related options modified . 2020.12.30 06:15:30 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified . 2020.12.30 06:15:30 - OpenVPN > OPTIONS IMPORT: peer-id set . 2020.12.30 06:15:30 - OpenVPN > OPTIONS IMPORT: adjusting link_mtu to 1625 . 2020.12.30 06:15:30 - OpenVPN > OPTIONS IMPORT: data channel crypto options modified . 2020.12.30 06:15:30 - OpenVPN > Data Channel: using negotiated cipher 'AES-256-GCM' . 2020.12.30 06:15:30 - OpenVPN > Outgoing Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key . 2020.12.30 06:15:30 - OpenVPN > Incoming Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key . 2020.12.30 06:15:30 - OpenVPN > ROUTE_GATEWAY 192.168.1.1/255.255.255.0 IFACE=enp4s0 HWADDR=18:31:bf:27:32:cc . 2020.12.30 06:15:30 - OpenVPN > GDG6: remote_host_ipv6=n/a . 2020.12.30 06:15:30 - OpenVPN > ROUTE6: default_gateway=UNDEF . 2020.12.30 06:15:30 - OpenVPN > TUN/TAP device tun0 opened . 2020.12.30 06:15:30 - OpenVPN > TUN/TAP TX queue length set to 100 . 2020.12.30 06:15:30 - OpenVPN > /sbin/ip link set dev tun0 up mtu 1500 . 2020.12.30 06:15:30 - OpenVPN > /sbin/ip addr add dev tun0 10.9.230.164/24 broadcast 10.9.230.255 . 2020.12.30 06:15:30 - OpenVPN > /sbin/ip -6 addr add fde6:7a:7d20:5e6::10a2/64 dev tun0 . 2020.12.30 06:15:34 - OpenVPN > /sbin/ip route add 184.75.221.213/32 via 192.168.1.1 . 2020.12.30 06:15:34 - OpenVPN > /sbin/ip route add 0.0.0.0/1 via 10.9.230.1 . 2020.12.30 06:15:34 - OpenVPN > /sbin/ip route add 128.0.0.0/1 via 10.9.230.1 . 2020.12.30 06:15:34 - OpenVPN > add_route_ipv6(::/3 -> fde6:7a:7d20:5e6::1 metric -1) dev tun0 . 2020.12.30 06:15:34 - OpenVPN > /sbin/ip -6 route add ::/3 dev tun0 . 2020.12.30 06:15:34 - OpenVPN > add_route_ipv6(2000::/4 -> fde6:7a:7d20:5e6::1 metric -1) dev tun0 . 2020.12.30 06:15:34 - OpenVPN > /sbin/ip -6 route add 2000::/4 dev tun0 . 2020.12.30 06:15:34 - OpenVPN > add_route_ipv6(3000::/4 -> fde6:7a:7d20:5e6::1 metric -1) dev tun0 . 2020.12.30 06:15:34 - OpenVPN > /sbin/ip -6 route add 3000::/4 dev tun0 . 2020.12.30 06:15:34 - OpenVPN > add_route_ipv6(fc00::/7 -> fde6:7a:7d20:5e6::1 metric -1) dev tun0 . 2020.12.30 06:15:34 - OpenVPN > /sbin/ip -6 route add fc00::/7 dev tun0 . 2020.12.30 06:15:34 - DNS of the system updated to VPN DNS (Rename method: /etc/resolv.conf generated) . 2020.12.30 06:15:34 - Routes, added a new route, 184.75.221.211 for gateway 10.9.230.1 . 2020.12.30 06:15:34 - Routes, added a new route, 2606:6080:1001:17:9ea4:71f9:d294:d7b7 for gateway fde6:7a:7d20:5e6::1 . 2020.12.30 06:15:34 - Flushing DNS I 2020.12.30 06:15:34 - Checking route IPv4 I 2020.12.30 06:15:34 - Checking route IPv6 I 2020.12.30 06:15:35 - Checking DNS ! 2020.12.30 06:15:35 - Connected. . 2020.12.30 06:15:35 - OpenVPN > Initialization Sequence Completed . 2020.12.30 06:45:21 - Collect information about AirVPN completed . 2020.12.30 07:14:40 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org . 2020.12.30 07:14:40 - OpenVPN > VERIFY KU OK . 2020.12.30 07:14:40 - OpenVPN > Validating certificate extended key usage . 2020.12.30 07:14:40 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication . 2020.12.30 07:14:40 - OpenVPN > VERIFY EKU OK . 2020.12.30 07:14:40 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=Arkab, emailAddress=info@airvpn.org . 2020.12.30 07:14:40 - OpenVPN > Outgoing Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key . 2020.12.30 07:14:40 - OpenVPN > Incoming Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key . 2020.12.30 07:14:40 - OpenVPN > Control Channel: TLSv1.3, cipher TLSv1.3 TLS_CHACHA20_POLY1305_SHA256, 4096 bit RSA . 2020.12.30 07:15:26 - Collect information about AirVPN completed malloc(): invalid next size (unsorted) ================================================================= Native Crash Reporting ================================================================= Got a SIGABRT while executing native code. This usually indicates a fatal error in the mono runtime or one of the native libraries used by your application. ================================================================= ================================================================= Native stacktrace: ================================================================= 0x55b042e23eb5 - mono : (null) 0x55b042e24250 - mono : (null) 0x55b042dd1129 - mono : (null) 0x55b042e23467 - mono : (null) 0x7f07d6c8c3c0 - /lib/x86_64-linux-gnu/libpthread.so.0 : (null) 0x7f07d6ab018b - /lib/x86_64-linux-gnu/libc.so.6 : gsignal 0x7f07d6a8f859 - /lib/x86_64-linux-gnu/libc.so.6 : abort 0x7f07d6afa3ee - /lib/x86_64-linux-gnu/libc.so.6 : (null) 0x7f07d6b0247c - /lib/x86_64-linux-gnu/libc.so.6 : (null) 0x7f07d6b0528c - /lib/x86_64-linux-gnu/libc.so.6 : (null) 0x7f07d6b05fdf - /lib/x86_64-linux-gnu/libc.so.6 : (null) 0x7f07d6b082d6 - /lib/x86_64-linux-gnu/libc.so.6 : realloc 0x55b04309e903 - mono : monoeg_realloc 0x55b0430a2362 - mono : monoeg_g_string_set_size 0x55b042f09752 - mono : (null) 0x55b042f0af45 - mono : (null) 0x55b042f0b10e - mono : (null) 0x55b042f3d64d - mono : (null) 0x55b042f55fa8 - mono : (null) 0x41b82f08 - Unknown ================================================================= Telemetry Dumper: ================================================================= Edited ... by govegan3 1 Staff reacted to this Share this post Link to post
phettle1 0 Posted ... I am having this same issue with Eddie 2.18.9 on Ubuntu 20.04.1. Share this post Link to post
frisbee 3 Posted ... Same issue here too, Linux Mint 20.0 and 20.1, Eddie 2.18.9. Le UI freeze completely after maybe 12 hours. Tunnel is still up. Share this post Link to post
Staff 10648 Posted ... Everybody, can you please check whether the problem is resolved when you run Eddie 2.19.7? Thank you in advance. Kind regards Share this post Link to post
govegan3 2 Posted ... 18 minutes ago, Staff said: Everybody, can you please check whether the problem is resolved when you run Eddie 2.19.7? Thank you in advance. Kind regards How does one upgrade? Manually uninstall old Eddie, download and install new Eddie? Share this post Link to post
govegan3 2 Posted ... I installed Eddie 2.19.7 I ran it from the terminal to get output. I launched it about 9:30 AM. I came home at about 12:30 PM to find that it crashed. Here is my terminal output. HTH Quote Mint20UlyanaCinnamon4.6.7> /usr/bin/eddie-ui . 2021.01.23 09:28:30 - Eddie version: 2.19.7 / linux_x64, System: Linux, Name: Linux Mint 20 Ulyana \n \l, Version: Linux Godzilla 5.4.0-62-generic #70-Ubuntu SMP Tue Jan 12 12:45:47 UTC 2021 x86_64 x86_64 x86_64 GNU/Linux, Mono/.Net: 6.8.0.105 (Debian 6.8.0.105+dfsg-2 Wed Feb 26 23:23:50 UTC 2020); Framework: v4.0.30319 . 2021.01.23 09:28:30 - Command line arguments (2): path.resources="/usr/share/eddie-ui" path.exec="/usr/bin/eddie-ui" . 2021.01.23 09:28:30 - Raise system privileges . 2021.01.23 09:28:35 - Profile path: /home/steve/.config/eddie/default.profile . 2021.01.23 09:28:36 - Reading options from /home/steve/.config/eddie/default.profile . 2021.01.23 09:28:36 - Tun Driver - /dev/net/tun . 2021.01.23 09:28:36 - OpenVPN - Version: 2.4.7 - OpenSSL 1.1.1f 31 Mar 2020, LZO 2.10 (/usr/sbin/openvpn) . 2021.01.23 09:28:36 - SSH - Version: OpenSSH_8.2p1 Ubuntu-4ubuntu0.1, OpenSSL 1.1.1f 31 Mar 2020 (/usr/bin/ssh) . 2021.01.23 09:28:36 - SSL - Version: stunnel 5.56 (/usr/bin/stunnel4) . 2021.01.23 09:28:36 - curl - Version: 7.68.0 (/usr/bin/curl) I 2021.01.23 09:28:37 - Ready . 2021.01.23 09:28:38 - Collect information about AirVPN completed I 2021.01.23 09:28:40 - Session starting. I 2021.01.23 09:28:40 - Checking authorization ... ! 2021.01.23 09:28:40 - Connecting to Cephei (Canada, Toronto, Ontario) . 2021.01.23 09:28:40 - OpenVPN > OpenVPN 2.4.7 x86_64-pc-linux-gnu [SSL (OpenSSL)] [LZO] [LZ4] [EPOLL] [PKCS11] [MH/PKTINFO] [AEAD] built on Sep 5 2019 . 2021.01.23 09:28:40 - OpenVPN > library versions: OpenSSL 1.1.1f 31 Mar 2020, LZO 2.10 . 2021.01.23 09:28:40 - OpenVPN > Outgoing Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key . 2021.01.23 09:28:40 - OpenVPN > Outgoing Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication . 2021.01.23 09:28:40 - OpenVPN > Incoming Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key . 2021.01.23 09:28:40 - OpenVPN > Incoming Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication . 2021.01.23 09:28:40 - OpenVPN > TCP/UDP: Preserving recently used remote address: [AF_INET]184.75.214.165:443 . 2021.01.23 09:28:40 - OpenVPN > Socket Buffers: R=[212992->212992] S=[212992->212992] . 2021.01.23 09:28:40 - OpenVPN > UDP link local: (not bound) . 2021.01.23 09:28:40 - OpenVPN > UDP link remote: [AF_INET]184.75.214.165:443 . 2021.01.23 09:28:40 - OpenVPN > TLS: Initial packet from [AF_INET]184.75.214.165:443, sid=d6d581f2 fc885eba . 2021.01.23 09:28:40 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org . 2021.01.23 09:28:40 - OpenVPN > VERIFY KU OK . 2021.01.23 09:28:40 - OpenVPN > Validating certificate extended key usage . 2021.01.23 09:28:40 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication . 2021.01.23 09:28:40 - OpenVPN > VERIFY EKU OK . 2021.01.23 09:28:40 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=Cephei, emailAddress=info@airvpn.org . 2021.01.23 09:28:40 - OpenVPN > Control Channel: TLSv1.3, cipher TLSv1.3 TLS_CHACHA20_POLY1305_SHA256, 4096 bit RSA . 2021.01.23 09:28:40 - OpenVPN > [Cephei] Peer Connection Initiated with [AF_INET]184.75.214.165:443 . 2021.01.23 09:28:41 - OpenVPN > SENT CONTROL [Cephei]: 'PUSH_REQUEST' (status=1) . 2021.01.23 09:28:41 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,comp-lzo no,redirect-gateway ipv6 def1 bypass-dhcp,dhcp-option DNS 10.13.102.1,dhcp-option DNS6 fde6:7a:7d20:966::1,tun-ipv6,route-gateway 10.13.102.1,topology subnet,ping 10,ping-restart 60,ifconfig-ipv6 fde6:7a:7d20:966::1072/64 fde6:7a:7d20:966::1,ifconfig 10.13.102.116 255.255.255.0,peer-id 1,cipher AES-256-GCM' . 2021.01.23 09:28:41 - OpenVPN > Pushed option removed by filter: 'redirect-gateway ipv6 def1 bypass-dhcp' . 2021.01.23 09:28:41 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified . 2021.01.23 09:28:41 - OpenVPN > OPTIONS IMPORT: compression parms modified . 2021.01.23 09:28:41 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified . 2021.01.23 09:28:41 - OpenVPN > OPTIONS IMPORT: route-related options modified . 2021.01.23 09:28:41 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified . 2021.01.23 09:28:41 - OpenVPN > OPTIONS IMPORT: peer-id set . 2021.01.23 09:28:41 - OpenVPN > OPTIONS IMPORT: adjusting link_mtu to 1625 . 2021.01.23 09:28:41 - OpenVPN > OPTIONS IMPORT: data channel crypto options modified . 2021.01.23 09:28:41 - OpenVPN > Data Channel: using negotiated cipher 'AES-256-GCM' . 2021.01.23 09:28:41 - OpenVPN > Outgoing Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key . 2021.01.23 09:28:41 - OpenVPN > Incoming Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key . 2021.01.23 09:28:41 - OpenVPN > ROUTE_GATEWAY 192.168.1.1/255.255.255.0 IFACE=enp4s0 HWADDR=18:31:bf:27:32:cc . 2021.01.23 09:28:41 - OpenVPN > GDG6: remote_host_ipv6=n/a . 2021.01.23 09:28:41 - OpenVPN > ROUTE6: default_gateway=UNDEF . 2021.01.23 09:28:41 - OpenVPN > TUN/TAP device tun0 opened . 2021.01.23 09:28:41 - OpenVPN > TUN/TAP TX queue length set to 100 . 2021.01.23 09:28:41 - OpenVPN > /sbin/ip link set dev tun0 up mtu 1500 . 2021.01.23 09:28:41 - OpenVPN > /sbin/ip addr add dev tun0 10.13.102.116/24 broadcast 10.13.102.255 . 2021.01.23 09:28:41 - OpenVPN > /sbin/ip -6 addr add fde6:7a:7d20:966::1072/64 dev tun0 . 2021.01.23 09:28:46 - OpenVPN > /sbin/ip route add 184.75.214.165/32 via 192.168.1.1 . 2021.01.23 09:28:46 - OpenVPN > /sbin/ip route add 0.0.0.0/1 via 10.13.102.1 . 2021.01.23 09:28:46 - OpenVPN > /sbin/ip route add 128.0.0.0/1 via 10.13.102.1 . 2021.01.23 09:28:46 - OpenVPN > add_route_ipv6(::/3 -> fde6:7a:7d20:966::1 metric -1) dev tun0 . 2021.01.23 09:28:46 - OpenVPN > /sbin/ip -6 route add ::/3 dev tun0 . 2021.01.23 09:28:46 - OpenVPN > add_route_ipv6(2000::/4 -> fde6:7a:7d20:966::1 metric -1) dev tun0 . 2021.01.23 09:28:46 - OpenVPN > /sbin/ip -6 route add 2000::/4 dev tun0 . 2021.01.23 09:28:46 - OpenVPN > add_route_ipv6(3000::/4 -> fde6:7a:7d20:966::1 metric -1) dev tun0 . 2021.01.23 09:28:46 - OpenVPN > /sbin/ip -6 route add 3000::/4 dev tun0 . 2021.01.23 09:28:46 - OpenVPN > add_route_ipv6(fc00::/7 -> fde6:7a:7d20:966::1 metric -1) dev tun0 . 2021.01.23 09:28:46 - OpenVPN > /sbin/ip -6 route add fc00::/7 dev tun0 . 2021.01.23 09:28:46 - DNS of the system updated to VPN DNS (Rename method: /etc/resolv.conf generated) . 2021.01.23 09:28:46 - Routes, added a new route, 184.75.214.163 for gateway 10.13.102.1 . 2021.01.23 09:28:46 - Routes, added a new route, 2606:6080:1001:c:1d9a:8f36:e174:d7c5 for gateway fde6:7a:7d20:966::1 . 2021.01.23 09:28:46 - Flushing DNS I 2021.01.23 09:28:46 - Checking route IPv4 I 2021.01.23 09:28:46 - Checking route IPv6 I 2021.01.23 09:28:46 - Checking DNS ! 2021.01.23 09:28:47 - Connected. . 2021.01.23 09:28:47 - OpenVPN > Initialization Sequence Completed . 2021.01.23 09:58:43 - Collect information about AirVPN completed . 2021.01.23 10:26:11 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org . 2021.01.23 10:26:11 - OpenVPN > VERIFY KU OK . 2021.01.23 10:26:11 - OpenVPN > Validating certificate extended key usage . 2021.01.23 10:26:11 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication . 2021.01.23 10:26:11 - OpenVPN > VERIFY EKU OK . 2021.01.23 10:26:11 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=Cephei, emailAddress=info@airvpn.org . 2021.01.23 10:26:11 - OpenVPN > Outgoing Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key . 2021.01.23 10:26:11 - OpenVPN > Incoming Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key . 2021.01.23 10:26:11 - OpenVPN > Control Channel: TLSv1.3, cipher TLSv1.3 TLS_CHACHA20_POLY1305_SHA256, 4096 bit RSA . 2021.01.23 10:28:48 - Collect information about AirVPN completed . 2021.01.23 11:23:40 - Above log line repeated 1 times more . 2021.01.23 11:23:40 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org . 2021.01.23 11:23:40 - OpenVPN > VERIFY KU OK . 2021.01.23 11:23:40 - OpenVPN > Validating certificate extended key usage . 2021.01.23 11:23:40 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication . 2021.01.23 11:23:40 - OpenVPN > VERIFY EKU OK . 2021.01.23 11:23:40 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=Cephei, emailAddress=info@airvpn.org . 2021.01.23 11:23:41 - OpenVPN > Outgoing Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key . 2021.01.23 11:23:41 - OpenVPN > Incoming Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key . 2021.01.23 11:23:41 - OpenVPN > Control Channel: TLSv1.3, cipher TLSv1.3 TLS_CHACHA20_POLY1305_SHA256, 4096 bit RSA . 2021.01.23 11:28:58 - Collect information about AirVPN completed free(): invalid next size (fast) ================================================================= Native Crash Reporting ================================================================= Got a SIGABRT while executing native code. This usually indicates a fatal error in the mono runtime or one of the native libraries used by your application. ================================================================= ================================================================= Native stacktrace: ================================================================= 0x55896e26aeb5 - mono : (null) 0x55896e26b250 - mono : (null) 0x55896e218129 - mono : (null) 0x55896e26a467 - mono : (null) 0x7fa2763453c0 - /lib/x86_64-linux-gnu/libpthread.so.0 : (null) 0x7fa27616918b - /lib/x86_64-linux-gnu/libc.so.6 : gsignal 0x7fa276148859 - /lib/x86_64-linux-gnu/libc.so.6 : abort 0x7fa2761b33ee - /lib/x86_64-linux-gnu/libc.so.6 : (null) 0x7fa2761bb47c - /lib/x86_64-linux-gnu/libc.so.6 : (null) 0x7fa2761bcd2c - /lib/x86_64-linux-gnu/libc.so.6 : (null) 0x7fa27239623a - /usr/lib/libgdiplus.so.0 : GdipDeleteRegion 0x40921ad3 - Unknown ================================================================= Telemetry Dumper: ================================================================= Pkilling 0x7fa26af37700 from 0x7fa275a93700 Pkilling 0x7fa26901d700 from 0x7fa275a93700 Pkilling 0x7fa26b94d700 from 0x7fa275a93700 Pkilling 0x7fa26921e700 from 0x7fa275a93700 Pkilling 0x7fa27611e780 from 0x7fa275a93700 Could not exec mono-hang-watchdog, expected on path '/etc/../bin/mono-hang-watchdog' (errno 2) Entering thread summarizer pause from 0x7fa275a93700 Finished thread summarizer pause from 0x7fa275a93700. Waiting for dumping threads to resume ================================================================= External Debugger Dump: ================================================================= [New LWP 260026] [New LWP 260027] [New LWP 260034] [New LWP 260046] [New LWP 260065] [New LWP 260088] [Thread debugging using libthread_db enabled] Using host libthread_db library "/lib/x86_64-linux-gnu/libthread_db.so.1". 0x00007fa276238aff in __GI___poll (fds=0x7fa275544eb8, nfds=2, timeout=15) at ../sysdeps/unix/sysv/linux/poll.c:29 29 ../sysdeps/unix/sysv/linux/poll.c: No such file or directory. Id Target Id Frame * 1 Thread 0x7fa27611e780 (LWP 260025) "mono" 0x00007fa276238aff in __GI___poll (fds=0x7fa275544eb8, nfds=2, timeout=15) at ../sysdeps/unix/sysv/linux/poll.c:29 2 Thread 0x7fa2753ff700 (LWP 260026) "SGen worker" futex_wait_cancelable (private=<optimized out>, expected=0, futex_word=0x55896e65ce08) at ../sysdeps/nptl/futex-internal.h:183 3 Thread 0x7fa275a93700 (LWP 260027) "Finalizer" 0x00007fa276208dff in __GI___wait4 (pid=285082, stat_loc=0x7fa275a91594, options=0, usage=0x0) at ../sysdeps/unix/sysv/linux/wait4.c:27 4 Thread 0x7fa26b94d700 (LWP 260034) "mono" futex_abstimed_wait_cancelable (private=<optimized out>, abstime=0x7fa26b94c6c0, clockid=<optimized out>, expected=0, futex_word=0x55896e65d488) at ../sysdeps/nptl/futex-internal.h:320 5 Thread 0x7fa26921e700 (LWP 260046) "Thread Pool I/O" 0x00007fa276238aff in __GI___poll (fds=0x7fa264076860, nfds=2, timeout=-1) at ../sysdeps/unix/sysv/linux/poll.c:29 6 Thread 0x7fa26af37700 (LWP 260065) "mono" __libc_read (nbytes=4096, buf=0x7fa24932eb30, fd=16) at ../sysdeps/unix/sysv/linux/read.c:26 7 Thread 0x7fa26901d700 (LWP 260088) "mono" futex_abstimed_wait_cancelable (private=<optimized out>, abstime=0x7fa26901bea0, clockid=<optimized out>, expected=0, futex_word=0x55896e65d488) at ../sysdeps/nptl/futex-internal.h:320 Thread 7 (Thread 0x7fa26901d700 (LWP 260088)): #0 futex_abstimed_wait_cancelable (private=<optimized out>, abstime=0x7fa26901bea0, clockid=<optimized out>, expected=0, futex_word=0x55896e65d488) at ../sysdeps/nptl/futex-internal.h:320 #1 __pthread_cond_wait_common (abstime=0x7fa26901bea0, clockid=<optimized out>, mutex=0x55896e65d4a0, cond=0x55896e65d460) at pthread_cond_wait.c:520 #2 __pthread_cond_timedwait (cond=0x55896e65d460, mutex=0x55896e65d4a0, abstime=0x7fa26901bea0) at pthread_cond_wait.c:656 #3 0x000055896e4cd39e in () #4 0x000055896e4d8609 in () #5 0x000055896e410306 in () #6 0x000055896e3a1806 in () #7 0x0000000040937e5e in () #8 0x00007fa27564abb8 in () #9 0x00007fa27564acb0 in () #10 0x0000000000000000 in () Thread 6 (Thread 0x7fa26af37700 (LWP 260065)): #0 __libc_read (nbytes=4096, buf=0x7fa24932eb30, fd=16) at ../sysdeps/unix/sysv/linux/read.c:26 #1 __libc_read (fd=16, buf=0x7fa24932eb30, nbytes=4096) at ../sysdeps/unix/sysv/linux/read.c:24 #2 0x000055896e3350ed in () #3 0x000055896e3333ff in () #4 0x000055896e47a403 in () #5 0x000055896e390e78 in () #6 0x0000000040869f7e in () #7 0x0000000000000000 in () Thread 5 (Thread 0x7fa26921e700 (LWP 260046)): #0 0x00007fa276238aff in __GI___poll (fds=0x7fa264076860, nfds=2, timeout=-1) at ../sysdeps/unix/sysv/linux/poll.c:29 #1 0x000055896e4168b9 in () #2 0x000055896e417d15 in () #3 0x000055896e412f3a in () #4 0x00007fa276339609 in start_thread (arg=<optimized out>) at pthread_create.c:477 #5 0x00007fa276245293 in clone () at ../sysdeps/unix/sysv/linux/x86_64/clone.S:95 Thread 4 (Thread 0x7fa26b94d700 (LWP 260034)): #0 futex_abstimed_wait_cancelable (private=<optimized out>, abstime=0x7fa26b94c6c0, clockid=<optimized out>, expected=0, futex_word=0x55896e65d488) at ../sysdeps/nptl/futex-internal.h:320 #1 __pthread_cond_wait_common (abstime=0x7fa26b94c6c0, clockid=<optimized out>, mutex=0x55896e65d4a0, cond=0x55896e65d460) at pthread_cond_wait.c:520 #2 __pthread_cond_timedwait (cond=0x55896e65d460, mutex=0x55896e65d4a0, abstime=0x7fa26b94c6c0) at pthread_cond_wait.c:656 #3 0x000055896e4cd39e in () #4 0x000055896e4d8609 in () #5 0x000055896e410306 in () #6 0x000055896e3a1806 in () #7 0x0000000040937e5e in () #8 0x00007fa27540f920 in () #9 0x00007fa26b94c960 in () #10 0x00007fa26b1c0f68 in () #11 0x0000000000000000 in () Thread 3 (Thread 0x7fa275a93700 (LWP 260027)): #0 0x00007fa276208dff in __GI___wait4 (pid=285082, stat_loc=0x7fa275a91594, options=0, usage=0x0) at ../sysdeps/unix/sysv/linux/wait4.c:27 #1 0x000055896e26b0bf in () #2 0x000055896e26b250 in () #3 0x000055896e218129 in () #4 0x000055896e26a467 in () #5 0x00007fa2763453c0 in <signal handler called> () at /lib/x86_64-linux-gnu/libpthread.so.0 #6 __GI_raise (sig=sig@entry=6) at ../sysdeps/unix/sysv/linux/raise.c:50 #7 0x00007fa276148859 in __GI_abort () at abort.c:79 #8 0x00007fa2761b33ee in __libc_message (action=action@entry=do_abort, fmt=fmt@entry=0x7fa2762dd285 "%s\n") at ../sysdeps/posix/libc_fatal.c:155 #9 0x00007fa2761bb47c in malloc_printerr (str=str@entry=0x7fa2762df600 "free(): invalid next size (fast)") at malloc.c:5347 #10 0x00007fa2761bcd2c in _int_free (av=0x7fa27630eb80 <main_arena>, p=0x5589713434b0, have_lock=0) at malloc.c:4249 #11 0x00007fa27239623a in GdipDeleteRegion () at /usr/lib/libgdiplus.so.0 #12 0x0000000040921ad3 in () #13 0x000055896e662900 in () #14 0x00007fa275a92ca0 in () #15 0x000055896f1d63b0 in () #16 0x00007fa27243718b in () #17 0x00007fa249321bd0 in () #18 0x00007fa26c0025c0 in () #19 0x00007fa275a92c00 in () #20 0x00007fa275a92b60 in () #21 0x0000000000000000 in () Thread 2 (Thread 0x7fa2753ff700 (LWP 260026)): #0 futex_wait_cancelable (private=<optimized out>, expected=0, futex_word=0x55896e65ce08) at ../sysdeps/nptl/futex-internal.h:183 #1 __pthread_cond_wait_common (abstime=0x0, clockid=0, mutex=0x55896e65ce20, cond=0x55896e65cde0) at pthread_cond_wait.c:508 #2 __pthread_cond_wait (cond=0x55896e65cde0, mutex=0x55896e65ce20) at pthread_cond_wait.c:638 #3 0x000055896e4bfdc6 in () #4 0x00007fa276339609 in start_thread (arg=<optimized out>) at pthread_create.c:477 #5 0x00007fa276245293 in clone () at ../sysdeps/unix/sysv/linux/x86_64/clone.S:95 Thread 1 (Thread 0x7fa27611e780 (LWP 260025)): #0 0x00007fa276238aff in __GI___poll (fds=0x7fa275544eb8, nfds=2, timeout=15) at ../sysdeps/unix/sysv/linux/poll.c:29 #1 0x0000000040928ce3 in () #2 0x0000000000000002 in () #3 0x00007ffce5c15cd0 in () #4 0x00007fa275544e98 in () #5 0x00007fa26b3dc190 in () #6 0x0000000000000002 in () #7 0x00007fa26b580820 in () #8 0x000055896f1f25a0 in () #9 0x00007ffce5c15cd0 in () #10 0x00007ffce5c15270 in () #11 0x0000000000000000 in () [Inferior 1 (process 260025) detached] ================================================================= Basic Fault Address Reporting ================================================================= Memory around native instruction pointer (0x7fa27616918b):0x7fa27616917b d2 4c 89 ce bf 02 00 00 00 b8 0e 00 00 00 0f 05 .L.............. 0x7fa27616918b 48 8b 84 24 08 01 00 00 64 48 33 04 25 28 00 00 H..$....dH3.%(.. 0x7fa27616919b 00 75 26 44 89 c0 48 81 c4 18 01 00 00 c3 0f 1f .u&D..H......... 0x7fa2761691ab 80 00 00 00 00 48 8b 15 b9 4c 1a 00 f7 d8 41 b8 .....H...L....A. ================================================================= Managed Stacktrace: ================================================================= at <unknown> <0xffffffff> at System.Drawing.GDIPlus:GdipDeleteRegion <0x000a2> at System.Drawing.Region:DisposeHandle <0x00047> at System.Drawing.Region:Finalize <0x0002f> at System.Object:runtime_invoke_virtual_void__this__ <0x0008c> ================================================================= /usr/bin/eddie-ui: line 2: 260025 Aborted (core dumped) mono /usr/lib/eddie-ui/eddie-ui.exe --path.resources=/usr/share/eddie-ui --path.exec="$0" "$@" Mint20UlyanaCinnamon4.6.7> Share this post Link to post
frisbee 3 Posted ... On 1/23/2021 at 9:05 AM, Staff said: Everybody, can you please check whether the problem is resolved when you run Eddie 2.19.7? Thank you in advance. Kind regards I can confirm the issue is still present in 2.19.7. UI still freezes after maybe 12-24 hours running. Tunnel is still up. Share this post Link to post
frisbee 3 Posted ... is there anything I can provide you with to help you investigate this issue? Share this post Link to post
frisbee 3 Posted ... For anyone still experiencing the issue that Eddie freezes/is unresponsive, a workaround is to NOT minimize Eddie. It seems to crash only when minimized. The Airvpn support team has been advised and should investigate further. 1 1 Staff and Just a Fred reacted to this Share this post Link to post
nomad6lib 0 Posted ... Mine just hangs and I have to restart the program over again. Always happens when I close my macbook or it's waking from sleep mode. Share this post Link to post
Cosm1 0 Posted ... Hello, exactly same problem, on Eddie version 2.20, GUI freezes after several hours and can only minimize it, but connection to vpn server works normally. I'm using ubuntu 20.04.3 on a virtual machine, host is windows 10, cpu: I7-10700k 8 cores, assigned ram to VM between 6 and 8 GB, assigned cores 6-8. Regards. Share this post Link to post
Tech Jedi Alex 1574 Posted ... To prevent further useless "I have the same issue but I run Windows/macOS/this other distro" posts I'll lock this. If you still have this issue with the most recent Eddie version 2.20.0 or later, open your own thread and give info on your setup. Do not pollute a thread with your problem if someone else tries to get help for theirs (or, tried in this case). Hide Tech Jedi Alex's signature Hide all signatures NOT AN AIRVPN TEAM MEMBER. USE TICKETS FOR PROFESSIONAL SUPPORT. LZ1's New User Guide to AirVPN « Plenty of stuff for advanced users, too! Want to contact me directly? All relevant methods are on my About me page. Share this post Link to post
