MongolMongol 1 Posted ... Hi, I have been using AirVPN since 2012 with total satisfaction but since a couple months ago I started receiving strange notices suggesting my ip is leaking, which I confirmed on ipleak. Anyway, I was wondering if AirVPN is offering some kind of proxy servers to add to the connections settings in my torrent client? Is there any other way to stop that leak? Share this post Link to post
Tech Jedi Alex 1577 Posted ... Chances are it's not only the torrent client leaking, but all applications, in which case a support file from Eddie would help. In Logs tab, click the lifebelt icon and paste or upload the output here. 1 MongolMongol reacted to this Hide Tech Jedi Alex's signature Hide all signatures NOT AN AIRVPN TEAM MEMBER. USE TICKETS FOR PROFESSIONAL SUPPORT. LZ1's New User Guide to AirVPN « Plenty of stuff for advanced users, too! Want to contact me directly? All relevant methods are on my About me page. Share this post Link to post
MongolMongol 1 Posted ... (edited) I'll follow your lead, no idea where this goes Eddie System/Environment Report - 2020-09-04 23:40 UTC Eddie version: 2.14.5 Eddie OS build: windows_x64 Eddie architecture: x64 OS type: Windows OS name: Windows 10 Pro OS version: Microsoft Windows NT 10.0.19041.0 OS architecture: x64 Mono /.Net Framework: v4.0.30319 OpenVPN driver: TAP-Windows Adapter V9, version 9.21.2 OpenVPN: 2.4.6 - OpenSSL 1.1.0h 27 Mar 2018, LZO 2.10 (C:\Program Files\AirVPN\openvpn.exe) SSH: plink 0.67 (C:\Program Files\AirVPN\plink.exe) SSL: stunnel 5.40 (C:\Program Files\AirVPN\stunnel.exe) curl: 7.54.1 (C:\Program Files\AirVPN\curl.exe) Profile path: C:\Users\steph\AppData\Local\AirVPN\AirVPN.xml Data path: C:\Users\steph\AppData\Local\AirVPN Application path: C:\Program Files\AirVPN Executable path: C:\Program Files\AirVPN\Eddie-UI.exe Command line arguments: (1 args) path="home" Network Lock Active: No Connected to VPN: Yes, Maasym Detected DNS: 10.21.36.1, 192.168.1.1, fde6:7a:7d20:1124::1 Test DNS IPv4: Ok Test DNS IPv6: Ok Test Ping IPv4: 118 ms Test Ping IPv6: 120 ms Test HTTP IPv4: Ok Test HTTP IPv6: Ok Test HTTPS: Ok ---------------------------- Important options not at defaults: login: (omissis) password: (omissis) remember: True ---------------------------- Logs: . 2020.09.04 18:17:00 - Eddie version: 2.14.5 / windows_x64, System: Windows, Name: Windows 10 Pro, Version: Microsoft Windows NT 10.0.19041.0, Mono/.Net: v4.0.30319 . 2020.09.04 18:17:00 - Reading options from C:\Users\steph\AppData\Local\AirVPN\AirVPN.xml . 2020.09.04 18:17:00 - Command line arguments (1): path="home" . 2020.09.04 18:17:02 - OpenVPN Driver - TAP-Windows Adapter V9, version 9.21.2 . 2020.09.04 18:17:02 - OpenVPN - Version: 2.4.6 - OpenSSL 1.1.0h 27 Mar 2018, LZO 2.10 (C:\Program Files\AirVPN\openvpn.exe) . 2020.09.04 18:17:02 - SSH - Version: plink 0.67 (C:\Program Files\AirVPN\plink.exe) . 2020.09.04 18:17:02 - SSL - Version: stunnel 5.40 (C:\Program Files\AirVPN\stunnel.exe) . 2020.09.04 18:17:02 - curl - Version: 7.54.1 (C:\Program Files\AirVPN\curl.exe) . 2020.09.04 18:17:02 - Certification Authorities: C:\Program Files\AirVPN\res\cacert.pem W 2020.09.04 18:17:02 - Recovery. Unexpected crash? . 2020.09.04 18:17:02 - Routes, remove 184.75.223.235 for gateway 10.4.0.1 failed: La suppression de l'itin‚raire a ‚chou‚ÿ: l‚ment introuvable . 2020.09.04 18:17:02 - Routes, remove 109.232.227.138 for gateway 10.4.0.1 failed: La suppression de l'itin‚raire a ‚chou‚ÿ: l‚ment introuvable . 2020.09.04 18:17:02 - Routes, remove 184.75.223.235 for gateway 10.4.0.1 failed: La suppression de l'itin‚raire a ‚chou‚ÿ: l‚ment introuvable . 2020.09.04 18:17:02 - Routes, remove 104.254.90.235 for gateway 10.4.0.1 failed: La suppression de l'itin‚raire a ‚chou‚ÿ: l‚ment introuvable . 2020.09.04 18:17:03 - Routes, remove 199.21.149.49 for gateway 10.4.0.1 failed: La suppression de l'itin‚raire a ‚chou‚ÿ: l‚ment introuvable . 2020.09.04 18:17:03 - Routes, remove 104.254.90.235 for gateway 10.4.0.1 failed: La suppression de l'itin‚raire a ‚chou‚ÿ: l‚ment introuvable . 2020.09.04 18:17:03 - Routes, remove 104.254.90.187 for gateway 10.28.68.1 failed: La suppression de l'itin‚raire a ‚chou‚ÿ: l‚ment introuvable . 2020.09.04 18:17:03 - Routes, remove 62.102.148.154 for gateway 10.11.36.1 failed: La suppression de l'itin‚raire a ‚chou‚ÿ: l‚ment introuvable . 2020.09.04 18:17:03 - Routes, remove 184.75.221.211 for gateway 10.9.228.1 failed: La suppression de l'itin‚raire a ‚chou‚ÿ: l‚ment introuvable . 2020.09.04 18:17:03 - Routes, remove 184.75.221.59 for gateway 10.31.228.1 failed: La suppression de l'itin‚raire a ‚chou‚ÿ: l‚ment introuvable . 2020.09.04 18:17:03 - Routes, remove 199.19.94.16 for gateway 10.6.228.1 failed: La suppression de l'itin‚raire a ‚chou‚ÿ: l‚ment introuvable . 2020.09.04 18:17:03 - Above log line repeated 2 times more . 2020.09.04 18:17:03 - Routes, remove 184.75.221.211 for gateway 10.9.228.1 failed: La suppression de l'itin‚raire a ‚chou‚ÿ: l‚ment introuvable . 2020.09.04 18:17:03 - Routes, remove 184.75.221.163 for gateway 10.9.36.1 failed: La suppression de l'itin‚raire a ‚chou‚ÿ: l‚ment introuvable . 2020.09.04 18:17:03 - Routes, remove 184.75.221.211 for gateway 10.9.228.1 failed: La suppression de l'itin‚raire a ‚chou‚ÿ: l‚ment introuvable . 2020.09.04 18:17:03 - Routes, remove 184.75.221.163 for gateway 10.9.36.1 failed: La suppression de l'itin‚raire a ‚chou‚ÿ: l‚ment introuvable . 2020.09.04 18:17:03 - Above log line repeated 1 times more . 2020.09.04 18:17:03 - Routes, remove 184.75.223.219 for gateway 10.24.4.1 failed: La suppression de l'itin‚raire a ‚chou‚ÿ: l‚ment introuvable . 2020.09.04 18:17:04 - Routes, remove 199.19.94.62 for gateway 10.20.132.1 failed: La suppression de l'itin‚raire a ‚chou‚ÿ: l‚ment introuvable . 2020.09.04 18:17:04 - Routes, remove 199.19.94.16 for gateway 10.6.228.1 failed: La suppression de l'itin‚raire a ‚chou‚ÿ: l‚ment introuvable . 2020.09.04 18:17:04 - Routes, remove 199.21.149.49 for gateway 10.15.132.1 failed: La suppression de l'itin‚raire a ‚chou‚ÿ: l‚ment introuvable . 2020.09.04 18:17:04 - Routes, remove 184.75.221.59 for gateway 10.31.228.1 failed: La suppression de l'itin‚raire a ‚chou‚ÿ: l‚ment introuvable . 2020.09.04 18:17:04 - Above log line repeated 1 times more . 2020.09.04 18:17:04 - Routes, remove 184.75.221.115 for gateway 10.8.132.1 failed: La suppression de l'itin‚raire a ‚chou‚ÿ: l‚ment introuvable . 2020.09.04 18:17:04 - Routes, remove 87.101.92.171 for gateway 10.11.4.1 failed: La suppression de l'itin‚raire a ‚chou‚ÿ: l‚ment introuvable . 2020.09.04 18:17:04 - Routes, remove 104.254.90.235 for gateway 10.14.36.1 failed: La suppression de l'itin‚raire a ‚chou‚ÿ: l‚ment introuvable . 2020.09.04 18:17:04 - Routes, remove 184.75.221.195 for gateway 10.31.100.1 failed: La suppression de l'itin‚raire a ‚chou‚ÿ: l‚ment introuvable . 2020.09.04 18:17:04 - Routes, remove 104.254.90.203 for gateway 10.8.68.1 failed: La suppression de l'itin‚raire a ‚chou‚ÿ: l‚ment introuvable . 2020.09.04 18:17:04 - Routes, remove 213.152.161.35 for gateway 10.19.68.1 failed: La suppression de l'itin‚raire a ‚chou‚ÿ: l‚ment introuvable . 2020.09.04 18:17:04 - Routes, remove 194.187.251.163 for gateway 10.15.164.1 failed: La suppression de l'itin‚raire a ‚chou‚ÿ: l‚ment introuvable . 2020.09.04 18:17:04 - Routes, remove 194.187.251.155 for gateway 10.21.132.1 failed: La suppression de l'itin‚raire a ‚chou‚ÿ: l‚ment introuvable . 2020.09.04 18:17:04 - Above log line repeated 1 times more . 2020.09.04 18:17:04 - Routes, remove 194.187.251.91 for gateway 10.12.164.1 failed: La suppression de l'itin‚raire a ‚chou‚ÿ: l‚ment introuvable . 2020.09.04 18:17:04 - Routes, remove 91.207.57.115 for gateway 10.12.228.1 failed: La suppression de l'itin‚raire a ‚chou‚ÿ: l‚ment introuvable . 2020.09.04 18:17:04 - Above log line repeated 1 times more . 2020.09.04 18:17:04 - Routes, remove 194.187.251.115 for gateway 10.14.132.1 failed: La suppression de l'itin‚raire a ‚chou‚ÿ: l‚ment introuvable . 2020.09.04 18:17:04 - Routes, remove 194.187.251.155 for gateway 10.21.132.1 failed: La suppression de l'itin‚raire a ‚chou‚ÿ: l‚ment introuvable . 2020.09.04 18:17:05 - Above log line repeated 1 times more . 2020.09.04 18:17:05 - Routes, remove 194.187.251.115 for gateway 10.14.132.1 failed: La suppression de l'itin‚raire a ‚chou‚ÿ: l‚ment introuvable . 2020.09.04 18:17:05 - Updating systems & servers data ... I 2020.09.04 18:17:05 - Ready . 2020.09.04 18:17:05 - Systems & servers data update completed I 2020.09.04 18:18:17 - Session starting. I 2020.09.04 18:18:17 - Checking authorization ... ! 2020.09.04 18:18:18 - Connecting to Maasym (Netherlands, Alblasserdam) . 2020.09.04 18:18:18 - OpenVPN > OpenVPN 2.4.6 x86_64-w64-mingw32 [SSL (OpenSSL)] [LZO] [LZ4] [PKCS11] [AEAD] built on Apr 27 2018 . 2020.09.04 18:18:18 - OpenVPN > Windows version 6.2 (Windows 8 or greater) 64bit . 2020.09.04 18:18:18 - OpenVPN > library versions: OpenSSL 1.1.0h 27 Mar 2018, LZO 2.10 . 2020.09.04 18:18:18 - Connection to OpenVPN Management Interface . 2020.09.04 18:18:18 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3100 . 2020.09.04 18:18:18 - OpenVPN > Outgoing Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication . 2020.09.04 18:18:18 - OpenVPN > Incoming Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication . 2020.09.04 18:18:18 - OpenVPN > TCP/UDP: Preserving recently used remote address: [AF_INET]213.152.162.103:443 . 2020.09.04 18:18:18 - OpenVPN > Socket Buffers: R=[65536->262144] S=[65536->262144] . 2020.09.04 18:18:18 - OpenVPN > UDP link local: (not bound) . 2020.09.04 18:18:18 - OpenVPN > UDP link remote: [AF_INET]213.152.162.103:443 . 2020.09.04 18:18:18 - OpenVPN > MANAGEMENT: Client connected from [AF_INET]127.0.0.1:3100 . 2020.09.04 18:18:18 - OpenVPN > TLS: Initial packet from [AF_INET]213.152.162.103:443, sid=e3b4efb2 72744a5f . 2020.09.04 18:18:18 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org . 2020.09.04 18:18:18 - OpenVPN > VERIFY KU OK . 2020.09.04 18:18:18 - OpenVPN > Validating certificate extended key usage . 2020.09.04 18:18:18 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication . 2020.09.04 18:18:18 - OpenVPN > VERIFY EKU OK . 2020.09.04 18:18:18 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=Maasym, emailAddress=info@airvpn.org . 2020.09.04 18:18:18 - OpenVPN > Control Channel: TLSv1.2, cipher TLSv1.2 DHE-RSA-AES256-GCM-SHA384, 4096 bit RSA . 2020.09.04 18:18:18 - OpenVPN > [Maasym] Peer Connection Initiated with [AF_INET]213.152.162.103:443 . 2020.09.04 18:18:20 - OpenVPN > SENT CONTROL [Maasym]: 'PUSH_REQUEST' (status=1) . 2020.09.04 18:18:20 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,comp-lzo no,redirect-gateway ipv6 def1 bypass-dhcp,dhcp-option DNS 10.21.36.1,dhcp-option DNS6 fde6:7a:7d20:1124::1,tun-ipv6,route-gateway 10.21.36.1,topology subnet,ping 10,ping-restart 60,ifconfig-ipv6 fde6:7a:7d20:1124::100d/64 fde6:7a:7d20:1124::1,ifconfig 10.21.36.15 255.255.255.0,peer-id 3,cipher AES-256-GCM' . 2020.09.04 18:18:20 - OpenVPN > Pushed option removed by filter: 'redirect-gateway ipv6 def1 bypass-dhcp' . 2020.09.04 18:18:20 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified . 2020.09.04 18:18:20 - OpenVPN > OPTIONS IMPORT: compression parms modified . 2020.09.04 18:18:20 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified . 2020.09.04 18:18:20 - OpenVPN > OPTIONS IMPORT: route-related options modified . 2020.09.04 18:18:20 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified . 2020.09.04 18:18:20 - OpenVPN > OPTIONS IMPORT: peer-id set . 2020.09.04 18:18:20 - OpenVPN > OPTIONS IMPORT: adjusting link_mtu to 1625 . 2020.09.04 18:18:20 - OpenVPN > OPTIONS IMPORT: data channel crypto options modified . 2020.09.04 18:18:20 - OpenVPN > Data Channel: using negotiated cipher 'AES-256-GCM' . 2020.09.04 18:18:20 - OpenVPN > Outgoing Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key . 2020.09.04 18:18:20 - OpenVPN > Incoming Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key . 2020.09.04 18:18:20 - OpenVPN > interactive service msg_channel=0 . 2020.09.04 18:18:20 - OpenVPN > ROUTE_GATEWAY 192.168.1.1/255.255.255.0 I=9 HWADDR=4c:cc:6a:6b:20:b5 . 2020.09.04 18:18:20 - OpenVPN > GDG6: remote_host_ipv6=n/a . 2020.09.04 18:18:20 - OpenVPN > NOTE: GetBestInterfaceEx returned error: �l�ment introuvable. (code=1168) . 2020.09.04 18:18:20 - OpenVPN > ROUTE6: default_gateway=UNDEF . 2020.09.04 18:18:20 - OpenVPN > open_tun . 2020.09.04 18:18:20 - OpenVPN > TAP-WIN32 device [Ethernet 2] opened: \\.\Global\{E6875F0F-CA3B-4B93-A4A7-F650500529A7}.tap . 2020.09.04 18:18:20 - OpenVPN > TAP-Windows Driver Version 9.21 . 2020.09.04 18:18:20 - OpenVPN > Set TAP-Windows TUN subnet mode network/local/netmask = 10.21.36.0/10.21.36.15/255.255.255.0 [SUCCEEDED] . 2020.09.04 18:18:20 - OpenVPN > Notified TAP-Windows driver to set a DHCP IP/netmask of 10.21.36.15/255.255.255.0 on interface {E6875F0F-CA3B-4B93-A4A7-F650500529A7} [DHCP-serv: 10.21.36.254, lease-time: 31536000] . 2020.09.04 18:18:20 - OpenVPN > Successful ARP Flush on interface [13] {E6875F0F-CA3B-4B93-A4A7-F650500529A7} . 2020.09.04 18:18:20 - OpenVPN > do_ifconfig, tt->did_ifconfig_ipv6_setup=1 . 2020.09.04 18:18:21 - OpenVPN > NETSH: C:\WINDOWS\system32\netsh.exe interface ipv6 set address interface=13 fde6:7a:7d20:1124::100d store=active . 2020.09.04 18:18:22 - OpenVPN > NETSH: C:\WINDOWS\system32\netsh.exe interface ipv6 set dns Ethernet 2 static fde6:7a:7d20:1124::1 validate=no . 2020.09.04 18:18:22 - Detected an OpenVPN bug (On-Link route on VPN range), autofix. . 2020.09.04 18:18:22 - OpenVPN > add_route_ipv6(fde6:7a:7d20:1124::/64 -> fde6:7a:7d20:1124::100d metric 0) dev Ethernet 2 . 2020.09.04 18:18:22 - OpenVPN > C:\WINDOWS\system32\netsh.exe interface ipv6 add route fde6:7a:7d20:1124::/64 interface=13 fe80::8 store=active . 2020.09.04 18:18:22 - OpenVPN > env_block: add PATH=C:\WINDOWS\System32;C:\WINDOWS;C:\WINDOWS\System32\Wbem . 2020.09.04 18:18:27 - OpenVPN > TEST ROUTES: 1/1 succeeded len=0 ret=1 a=0 u/d=up . 2020.09.04 18:18:27 - OpenVPN > C:\WINDOWS\system32\route.exe ADD 213.152.162.103 MASK 255.255.255.255 192.168.1.1 . 2020.09.04 18:18:27 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=25 and dwForwardType=4 . 2020.09.04 18:18:27 - OpenVPN > Route addition via IPAPI succeeded [adaptive] . 2020.09.04 18:18:27 - OpenVPN > C:\WINDOWS\system32\route.exe ADD 0.0.0.0 MASK 128.0.0.0 10.21.36.1 . 2020.09.04 18:18:27 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=35 and dwForwardType=4 . 2020.09.04 18:18:27 - OpenVPN > Route addition via IPAPI succeeded [adaptive] . 2020.09.04 18:18:27 - OpenVPN > C:\WINDOWS\system32\route.exe ADD 128.0.0.0 MASK 128.0.0.0 10.21.36.1 . 2020.09.04 18:18:27 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=35 and dwForwardType=4 . 2020.09.04 18:18:27 - OpenVPN > Route addition via IPAPI succeeded [adaptive] . 2020.09.04 18:18:27 - OpenVPN > add_route_ipv6(::/3 -> fde6:7a:7d20:1124::1 metric -1) dev Ethernet 2 . 2020.09.04 18:18:27 - OpenVPN > C:\WINDOWS\system32\netsh.exe interface ipv6 add route ::/3 interface=13 fe80::8 store=active . 2020.09.04 18:18:27 - OpenVPN > env_block: add PATH=C:\WINDOWS\System32;C:\WINDOWS;C:\WINDOWS\System32\Wbem . 2020.09.04 18:18:27 - OpenVPN > add_route_ipv6(2000::/4 -> fde6:7a:7d20:1124::1 metric -1) dev Ethernet 2 . 2020.09.04 18:18:27 - OpenVPN > C:\WINDOWS\system32\netsh.exe interface ipv6 add route 2000::/4 interface=13 fe80::8 store=active . 2020.09.04 18:18:27 - OpenVPN > env_block: add PATH=C:\WINDOWS\System32;C:\WINDOWS;C:\WINDOWS\System32\Wbem . 2020.09.04 18:18:27 - OpenVPN > add_route_ipv6(3000::/4 -> fde6:7a:7d20:1124::1 metric -1) dev Ethernet 2 . 2020.09.04 18:18:27 - OpenVPN > C:\WINDOWS\system32\netsh.exe interface ipv6 add route 3000::/4 interface=13 fe80::8 store=active . 2020.09.04 18:18:27 - OpenVPN > env_block: add PATH=C:\WINDOWS\System32;C:\WINDOWS;C:\WINDOWS\System32\Wbem . 2020.09.04 18:18:27 - OpenVPN > add_route_ipv6(fc00::/7 -> fde6:7a:7d20:1124::1 metric -1) dev Ethernet 2 . 2020.09.04 18:18:27 - OpenVPN > C:\WINDOWS\system32\netsh.exe interface ipv6 add route fc00::/7 interface=13 fe80::8 store=active . 2020.09.04 18:18:27 - OpenVPN > env_block: add PATH=C:\WINDOWS\System32;C:\WINDOWS;C:\WINDOWS\System32\Wbem . 2020.09.04 18:18:27 - Interface Ethernet 2 metric changed from Automatic to 3, layer IPv4 . 2020.09.04 18:18:27 - Interface Ethernet 2 metric changed from Automatic to 3, layer IPv6 . 2020.09.04 18:18:27 - DNS leak protection with packet filtering enabled. . 2020.09.04 18:18:27 - DNS IPv4 of a network adapter forced (Ethernet 2, from automatic to 10.21.36.1) . 2020.09.04 18:18:27 - Routes, added a new route, 213.152.162.104 for gateway 10.21.36.1 . 2020.09.04 18:18:28 - Routes, added a new route, 2a00:1678:2470:34:b00f:eeed:bb7f:fb66 for gateway fde6:7a:7d20:1124::1 . 2020.09.04 18:18:28 - Flushing DNS I 2020.09.04 18:18:31 - Checking route IPv4 I 2020.09.04 18:18:31 - Checking route IPv6 I 2020.09.04 18:18:35 - Checking DNS ! 2020.09.04 18:18:36 - Connected. . 2020.09.04 18:18:36 - OpenVPN > Initialization Sequence Completed . 2020.09.04 18:18:36 - OpenVpn Management > ENTER PASSWORD: . 2020.09.04 18:27:08 - Updating systems & servers data ... . 2020.09.04 18:27:10 - Systems & servers data update completed . 2020.09.04 18:37:13 - Updating systems & servers data ... . 2020.09.04 18:37:15 - Systems & servers data update completed . 2020.09.04 18:47:17 - Updating systems & servers data ... . 2020.09.04 18:47:19 - Systems & servers data update completed . 2020.09.04 18:57:22 - Updating systems & servers data ... . 2020.09.04 18:57:24 - Systems & servers data update completed . 2020.09.04 19:07:26 - Updating systems & servers data ... . 2020.09.04 19:07:28 - Systems & servers data update completed . 2020.09.04 19:17:31 - Updating systems & servers data ... . 2020.09.04 19:17:33 - Systems & servers data update completed . 2020.09.04 19:18:18 - OpenVPN > TLS: soft reset sec=0 bytes=35137810/-1 pkts=107954/0 . 2020.09.04 19:18:18 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org . 2020.09.04 19:18:18 - OpenVPN > VERIFY KU OK . 2020.09.04 19:18:18 - OpenVPN > Validating certificate extended key usage . 2020.09.04 19:18:18 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication . 2020.09.04 19:18:18 - OpenVPN > VERIFY EKU OK . 2020.09.04 19:18:18 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=Maasym, emailAddress=info@airvpn.org . 2020.09.04 19:18:18 - OpenVPN > Outgoing Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key . 2020.09.04 19:18:18 - OpenVPN > Incoming Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key . 2020.09.04 19:18:18 - OpenVPN > Control Channel: TLSv1.2, cipher TLSv1.2 DHE-RSA-AES256-GCM-SHA384, 4096 bit RSA . 2020.09.04 19:27:36 - Updating systems & servers data ... . 2020.09.04 19:27:37 - Systems & servers data update completed . 2020.09.04 19:37:40 - Updating systems & servers data ... . 2020.09.04 19:37:42 - Systems & servers data update completed ---------------------------- Network Interfaces and Routes: { "support_ipv4": true, "support_ipv6": true, "routes": [ { "address": "0.0.0.0\/0", "interface": "{957709BA-8575-41E9-B24C-B6E6B15FC8F0}", "gateway": "192.168.1.1", "metric": "25" }, { "address": "0.0.0.0\/1", "interface": "{E6875F0F-CA3B-4B93-A4A7-F650500529A7}", "gateway": "10.21.36.1", "metric": "3" }, { "address": "10.21.36.0\/24", "interface": "{E6875F0F-CA3B-4B93-A4A7-F650500529A7}", "gateway": "link", "metric": "259" }, { "address": "10.21.36.15", "interface": "{E6875F0F-CA3B-4B93-A4A7-F650500529A7}", "gateway": "link", "metric": "259" }, { "address": "10.21.36.255", "interface": "{E6875F0F-CA3B-4B93-A4A7-F650500529A7}", "gateway": "link", "metric": "259" }, { "address": "127.0.0.0\/8", "interface": "{280DF9A3-710F-11E8-B469-806E6F6E6963}", "gateway": "link", "metric": "331" }, { "address": "127.0.0.1", "interface": "{280DF9A3-710F-11E8-B469-806E6F6E6963}", "gateway": "link", "metric": "331" }, { "address": "127.255.255.255", "interface": "{280DF9A3-710F-11E8-B469-806E6F6E6963}", "gateway": "link", "metric": "331" }, { "address": "128.0.0.0\/1", "interface": "{E6875F0F-CA3B-4B93-A4A7-F650500529A7}", "gateway": "10.21.36.1", "metric": "3" }, { "address": "192.168.1.0\/24", "interface": "{957709BA-8575-41E9-B24C-B6E6B15FC8F0}", "gateway": "link", "metric": "281" }, { "address": "192.168.1.31", "interface": "{957709BA-8575-41E9-B24C-B6E6B15FC8F0}", "gateway": "link", "metric": "281" }, { "address": "192.168.1.255", "interface": "{957709BA-8575-41E9-B24C-B6E6B15FC8F0}", "gateway": "link", "metric": "281" }, { "address": "213.152.162.103", "interface": "{957709BA-8575-41E9-B24C-B6E6B15FC8F0}", "gateway": "192.168.1.1", "metric": "25" }, { "address": "213.152.162.104", "interface": "{E6875F0F-CA3B-4B93-A4A7-F650500529A7}", "gateway": "10.21.36.1", "metric": "4" }, { "address": "224.0.0.0\/4", "interface": "{280DF9A3-710F-11E8-B469-806E6F6E6963}", "gateway": "link", "metric": "331" }, { "address": "224.0.0.0\/4", "interface": "{957709BA-8575-41E9-B24C-B6E6B15FC8F0}", "gateway": "link", "metric": "281" }, { "address": "224.0.0.0\/4", "interface": "{E6875F0F-CA3B-4B93-A4A7-F650500529A7}", "gateway": "link", "metric": "259" }, { "address": "255.255.255.255", "interface": "{280DF9A3-710F-11E8-B469-806E6F6E6963}", "gateway": "link", "metric": "331" }, { "address": "255.255.255.255", "interface": "{957709BA-8575-41E9-B24C-B6E6B15FC8F0}", "gateway": "link", "metric": "281" }, { "address": "255.255.255.255", "interface": "{E6875F0F-CA3B-4B93-A4A7-F650500529A7}", "gateway": "link", "metric": "259" }, { "address": "::\/3", "interface": "{E6875F0F-CA3B-4B93-A4A7-F650500529A7}", "gateway": "fe80::8", "metric": "259" }, { "address": "::1", "interface": "{280DF9A3-710F-11E8-B469-806E6F6E6963}", "gateway": "link", "metric": "331" }, { "address": "2000::\/4", "interface": "{E6875F0F-CA3B-4B93-A4A7-F650500529A7}", "gateway": "fe80::8", "metric": "259" }, { "address": "2a00:1678:2470:34:b00f:eeed:bb7f:fb66", "interface": "{E6875F0F-CA3B-4B93-A4A7-F650500529A7}", "gateway": "fde6:7a:7d20:1124::1", "metric": "259" }, { "address": "3000::\/4", "interface": "{E6875F0F-CA3B-4B93-A4A7-F650500529A7}", "gateway": "fe80::8", "metric": "259" }, { "address": "fc00::\/7", "interface": "{E6875F0F-CA3B-4B93-A4A7-F650500529A7}", "gateway": "fe80::8", "metric": "259" }, { "address": "fde6:7a:7d20:1124::\/64", "interface": "{E6875F0F-CA3B-4B93-A4A7-F650500529A7}", "gateway": "fe80::8", "metric": "259" }, { "address": "fde6:7a:7d20:1124::100d", "interface": "{E6875F0F-CA3B-4B93-A4A7-F650500529A7}", "gateway": "link", "metric": "259" }, { "address": "fe80::\/64", "interface": "{957709BA-8575-41E9-B24C-B6E6B15FC8F0}", "gateway": "link", "metric": "281" }, { "address": "fe80::\/64", "interface": "{E6875F0F-CA3B-4B93-A4A7-F650500529A7}", "gateway": "link", "metric": "259" }, { "address": "fe80::75d3:c806:982c:ca57", "interface": "{E6875F0F-CA3B-4B93-A4A7-F650500529A7}", "gateway": "link", "metric": "259" }, { "address": "fe80::91ad:17b9:a03a:7668", "interface": "{957709BA-8575-41E9-B24C-B6E6B15FC8F0}", "gateway": "link", "metric": "281" }, { "address": "ff00::\/8", "interface": "{280DF9A3-710F-11E8-B469-806E6F6E6963}", "gateway": "link", "metric": "331" }, { "address": "ff00::\/8", "interface": "{957709BA-8575-41E9-B24C-B6E6B15FC8F0}", "gateway": "link", "metric": "281" }, { "address": "ff00::\/8", "interface": "{E6875F0F-CA3B-4B93-A4A7-F650500529A7}", "gateway": "link", "metric": "259" }, { "address": "2a00:1678:2470:34:b00f:eeed:bb7f:fb66", "gateway": "fde6:7a:7d20:1124::1", "metric": "4294967295" } ], "interfaces": [ { "friendly": "Ethernet 2", "id": "{E6875F0F-CA3B-4B93-A4A7-F650500529A7}", "name": "Ethernet 2", "description": "TAP-Windows Adapter V9", "type": "Ethernet", "status": "Up", "bytes_received": "154044360", "bytes_sent": "28497142", "support_ipv4": true, "support_ipv6": true, "ips": [ "fde6:7a:7d20:1124::100d", "fe80::75d3:c806:982c:ca57", "10.21.36.15" ], "gateways": [ "10.21.36.1", "fe80::8", "fde6:7a:7d20:1124::1" ], "bind": true, "dns4": "10.21.36.1", "dns6": "fde6:7a:7d20:1124::1" }, { "friendly": "Ethernet", "id": "{957709BA-8575-41E9-B24C-B6E6B15FC8F0}", "name": "Ethernet", "description": "Intel(R) Ethernet Connection (2) I218-V", "type": "Ethernet", "status": "Up", "bytes_received": "1778723818", "bytes_sent": "146010229", "support_ipv4": true, "support_ipv6": true, "ips": [ "fe80::91ad:17b9:a03a:7668", "192.168.1.31" ], "gateways": [ "192.168.1.1" ], "bind": true, "dns4": "", "dns6": "" }, { "friendly": "Loopback Pseudo-Interface 1", "id": "{280DF9A3-710F-11E8-B469-806E6F6E6963}", "name": "Loopback Pseudo-Interface 1", "description": "Software Loopback Interface 1", "type": "Loopback", "status": "Up", "bytes_received": "0", "bytes_sent": "0", "support_ipv4": true, "support_ipv6": true, "ips": [ "::1", "127.0.0.1" ], "gateways": [], "bind": true, "dns4": "", "dns6": null } ], "ipv4-default-gateway": "10.21.36.1", "ipv4-default-interface": "{E6875F0F-CA3B-4B93-A4A7-F650500529A7}", "ipv6-default-gateway": "fe80::8", "ipv6-default-interface": "{E6875F0F-CA3B-4B93-A4A7-F650500529A7}" } ---------------------------- ipconfig /all: Configuration IP de Windows Nom de l'h“te . . . . . . . . . . : LePCdePapa Suffixe DNS principal . . . . . . : Type de noeud. . . . . . . . . . : Hybride Routage IP activ‚ . . . . . . . . : Non Proxy WINS activ‚ . . . . . . . . : Non Carte Ethernet Ethernet 2 : Suffixe DNS propre … la connexion. . . : Description. . . . . . . . . . . . . . : TAP-Windows Adapter V9 Adresse physique . . . . . . . . . . . : 00-FF-E6-87-5F-0F DHCP activ‚. . . . . . . . . . . . . . : Oui Configuration automatique activ‚e. . . : Oui Adresse IPv6. . . . . . . . . . .ÿ. . .: fde6:7a:7d20:1124::100d(pr‚f‚r‚) Adresse IPv6 de liaison locale. . . . .: fe80::75d3:c806:982c:ca57%13(pr‚f‚r‚) Adresse IPv4. . . . . . . . . . . . . .: 10.21.36.15(pr‚f‚r‚) Masque de sous-r‚seau. . . .ÿ. . . . . : 255.255.255.0 Bail obtenu. . . . . . . . .ÿ. . . . . : 4 septembre 2020 18:18:20 Bail expirant. . . . . . . . .ÿ. . . . : 4 septembre 2021 18:18:20 Passerelle par d‚faut. . . .ÿ. . . . . : Serveur DHCP . . . . . . . . . . . . . : 10.21.36.254 IAID DHCPv6 . . . . . . . . . . . : 167837670 DUID de client DHCPv6. . . . . . . . : 00-01-00-01-22-B6-24-33-4C-CC-6A-6B-20-B5 Serveurs DNS. . . . . . . . . . . . . : fde6:7a:7d20:1124::1 10.21.36.1 NetBIOS sur Tcpip. . . . . . . . . . . : Activ‚ Carte Ethernet Ethernet : Suffixe DNS propre … la connexion. . . : Description. . . . . . . . . . . . . . : Intel(R) Ethernet Connection (2) I218-V Adresse physique . . . . . . . . . . . : 4C-CC-6A-6B-20-B5 DHCP activ‚. . . . . . . . . . . . . . : Oui Configuration automatique activ‚e. . . : Oui Adresse IPv6 de liaison locale. . . . .: fe80::91ad:17b9:a03a:7668%9(pr‚f‚r‚) Adresse IPv4. . . . . . . . . . . . . .: 192.168.1.31(pr‚f‚r‚) Masque de sous-r‚seau. . . .ÿ. . . . . : 255.255.255.0 Bail obtenu. . . . . . . . .ÿ. . . . . : 30 ao–t 2020 10:34:48 Bail expirant. . . . . . . . .ÿ. . . . : 5 septembre 2020 11:13:55 Passerelle par d‚faut. . . .ÿ. . . . . : 192.168.1.1 Serveur DHCP . . . . . . . . . . . . . : 192.168.1.1 IAID DHCPv6 . . . . . . . . . . . : 88919146 DUID de client DHCPv6. . . . . . . . : 00-01-00-01-22-B6-24-33-4C-CC-6A-6B-20-B5 Serveurs DNS. . . . . . . . . . . . . : 192.168.1.1 NetBIOS sur Tcpip. . . . . . . . . . . : Activ‚ Edited ... by giganerd Apply LOG format to logs Share this post Link to post
LZ1 685 Posted ... Hello! Quote Eddie version: 2.14.5 You can start by considering updating your client from mid-2018 to 2020 . 1 MongolMongol reacted to this Hide LZ1's signature Hide all signatures Hi there, are you new to AirVPN? Many of your questions are already answered in this guide. You may also read the Eddie Android FAQ. Moderators do not speak on behalf of AirVPN. Only the Official Staff account does. Please also do not run Tor Exit Servers behind AirVPN, thank you. Did you make a guide or how-to for something? Then contact me to get it listed in my new user guide's Guides Section, so that the community can find it more easily. Share this post Link to post
MongolMongol 1 Posted ... Ok, this was awkward.... I did. Rebooted. Still leaking. Eddie System/Environment Report - 2020-09-05 - 15:46 UTC Eddie version: 2.18.9 Eddie OS build: windows_x64 Eddie architecture: x64 OS type: Windows OS name: Windows 10 Pro OS version: Microsoft Windows NT 10.0.19041.0 OS architecture: x64 Mono /.Net Framework: v4.0.30319 TUN driver: 0901: 9.24.2; wintun: Not found OpenVPN: 2.4.8 - OpenSSL 1.1.0l 10 Sep 2019, LZO 2.10 (C:\Program Files\AirVPN\openvpn.exe) Hummingbird: () SSH: plink 0.67 (C:\Program Files\AirVPN\plink.exe) SSL: stunnel 5.40 (C:\Program Files\AirVPN\stunnel.exe) curl: 7.68.0 (C:\Program Files\AirVPN\curl.exe) Profile path: C:\Users\steph\AppData\Local\Eddie\default.profile Data path: C:\Users\steph\AppData\Local\Eddie Application path: C:\Program Files\AirVPN Executable path: C:\Program Files\AirVPN\Eddie-UI.exe Command line arguments: (1 args) path="home" Network Lock Active: No Connected to VPN: Yes, Caph Detected DNS: 10.12.134.1, 192.168.1.1, fde6:7a:7d20:886::1 Test DNS IPv4: Ok Test DNS IPv6: Ok Test Ping IPv4: 126 ms Test Ping IPv6: 120 ms Test HTTP IPv4: Ok Test HTTP IPv6: Ok Test HTTPS: Ok ---------------------------- Important options not at defaults: login: (omissis) password: (omissis) remember: True ---------------------------- Logs: . 2020.09.05 11:43:52 - Eddie version: 2.18.9 / windows_x64, System: Windows, Name: Windows 10 Pro, Version: Microsoft Windows NT 10.0.19041.0, Mono/.Net: v4.0.30319 . 2020.09.05 11:43:52 - Command line arguments (1): path="home" . 2020.09.05 11:43:54 - Profile path: C:\Users\steph\AppData\Local\Eddie\default.profile . 2020.09.05 11:43:54 - Reading options from C:\Users\steph\AppData\Local\Eddie\default.profile . 2020.09.05 11:43:57 - Tun Driver - 0901: 9.24.2; wintun: Not found . 2020.09.05 11:43:57 - OpenVPN - Version: 2.4.8 - OpenSSL 1.1.0l 10 Sep 2019, LZO 2.10 (C:\Program Files\AirVPN\openvpn.exe) . 2020.09.05 11:43:57 - SSH - Version: plink 0.67 (C:\Program Files\AirVPN\plink.exe) . 2020.09.05 11:43:57 - SSL - Version: stunnel 5.40 (C:\Program Files\AirVPN\stunnel.exe) . 2020.09.05 11:43:57 - curl - Version: 7.68.0 (C:\Program Files\AirVPN\curl.exe) I 2020.09.05 11:43:58 - Ready . 2020.09.05 11:43:59 - Collect information about AirVPN completed I 2020.09.05 11:44:07 - Session starting. I 2020.09.05 11:44:08 - Checking authorization ... ! 2020.09.05 11:44:09 - Connecting to Caph (Netherlands, Alblasserdam) . 2020.09.05 11:44:09 - OpenVPN > OpenVPN 2.4.8 i686-w64-mingw32 [SSL (OpenSSL)] [LZO] [LZ4] [PKCS11] [AEAD] built on Oct 31 2019 . 2020.09.05 11:44:09 - OpenVPN > Windows version 6.2 (Windows 8 or greater) 64bit . 2020.09.05 11:44:09 - OpenVPN > library versions: OpenSSL 1.1.0l 10 Sep 2019, LZO 2.10 . 2020.09.05 11:44:09 - OpenVPN > Outgoing Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key . 2020.09.05 11:44:09 - OpenVPN > Outgoing Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication . 2020.09.05 11:44:09 - OpenVPN > Incoming Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key . 2020.09.05 11:44:09 - OpenVPN > Incoming Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication . 2020.09.05 11:44:09 - OpenVPN > TCP/UDP: Preserving recently used remote address: [AF_INET]213.152.162.172:443 . 2020.09.05 11:44:09 - OpenVPN > Socket Buffers: R=[65536->262144] S=[65536->262144] . 2020.09.05 11:44:09 - OpenVPN > UDP link local: (not bound) . 2020.09.05 11:44:09 - OpenVPN > UDP link remote: [AF_INET]213.152.162.172:443 . 2020.09.05 11:44:09 - OpenVPN > TLS: Initial packet from [AF_INET]213.152.162.172:443, sid=ef06a645 6acbe2ea . 2020.09.05 11:44:09 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org . 2020.09.05 11:44:09 - OpenVPN > VERIFY KU OK . 2020.09.05 11:44:09 - OpenVPN > Validating certificate extended key usage . 2020.09.05 11:44:09 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication . 2020.09.05 11:44:09 - OpenVPN > VERIFY EKU OK . 2020.09.05 11:44:09 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=Caph, emailAddress=info@airvpn.org . 2020.09.05 11:44:10 - OpenVPN > Control Channel: TLSv1.2, cipher TLSv1.2 DHE-RSA-AES256-GCM-SHA384, 4096 bit RSA . 2020.09.05 11:44:10 - OpenVPN > [Caph] Peer Connection Initiated with [AF_INET]213.152.162.172:443 . 2020.09.05 11:44:11 - OpenVPN > SENT CONTROL [Caph]: 'PUSH_REQUEST' (status=1) . 2020.09.05 11:44:11 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,comp-lzo no,redirect-gateway ipv6 def1 bypass-dhcp,dhcp-option DNS 10.12.134.1,dhcp-option DNS6 fde6:7a:7d20:886::1,tun-ipv6,route-gateway 10.12.134.1,topology subnet,ping 10,ping-restart 60,ifconfig-ipv6 fde6:7a:7d20:886::10e4/64 fde6:7a:7d20:886::1,ifconfig 10.12.134.230 255.255.255.0,peer-id 1,cipher AES-256-GCM' . 2020.09.05 11:44:11 - OpenVPN > Pushed option removed by filter: 'redirect-gateway ipv6 def1 bypass-dhcp' . 2020.09.05 11:44:11 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified . 2020.09.05 11:44:11 - OpenVPN > OPTIONS IMPORT: compression parms modified . 2020.09.05 11:44:11 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified . 2020.09.05 11:44:11 - OpenVPN > OPTIONS IMPORT: route-related options modified . 2020.09.05 11:44:11 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified . 2020.09.05 11:44:11 - OpenVPN > OPTIONS IMPORT: peer-id set . 2020.09.05 11:44:11 - OpenVPN > OPTIONS IMPORT: adjusting link_mtu to 1625 . 2020.09.05 11:44:11 - OpenVPN > OPTIONS IMPORT: data channel crypto options modified . 2020.09.05 11:44:11 - OpenVPN > Data Channel: using negotiated cipher 'AES-256-GCM' . 2020.09.05 11:44:11 - OpenVPN > Outgoing Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key . 2020.09.05 11:44:11 - OpenVPN > Incoming Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key . 2020.09.05 11:44:11 - OpenVPN > interactive service msg_channel=0 . 2020.09.05 11:44:11 - OpenVPN > ROUTE_GATEWAY 192.168.1.1/255.255.255.0 I=10 HWADDR=4c:cc:6a:6b:20:b5 . 2020.09.05 11:44:11 - OpenVPN > GDG6: remote_host_ipv6=n/a . 2020.09.05 11:44:11 - OpenVPN > NOTE: GetBestInterfaceEx returned error: �l�ment introuvable. (code=1168) . 2020.09.05 11:44:11 - OpenVPN > ROUTE6: default_gateway=UNDEF . 2020.09.05 11:44:11 - OpenVPN > open_tun . 2020.09.05 11:44:11 - OpenVPN > TAP-WIN32 device [Connexion au réseau local] opened: \\.\Global\{1255CA32-8BD2-4AEB-8AF4-3ACA710B779C}.tap . 2020.09.05 11:44:11 - OpenVPN > TAP-Windows Driver Version 9.24 . 2020.09.05 11:44:11 - OpenVPN > Set TAP-Windows TUN subnet mode network/local/netmask = 10.12.134.0/10.12.134.230/255.255.255.0 [SUCCEEDED] . 2020.09.05 11:44:11 - OpenVPN > Notified TAP-Windows driver to set a DHCP IP/netmask of 10.12.134.230/255.255.255.0 on interface {1255CA32-8BD2-4AEB-8AF4-3ACA710B779C} [DHCP-serv: 10.12.134.254, lease-time: 31536000] . 2020.09.05 11:44:11 - OpenVPN > Successful ARP Flush on interface [4] {1255CA32-8BD2-4AEB-8AF4-3ACA710B779C} . 2020.09.05 11:44:12 - OpenVPN > NETSH: C:\WINDOWS\system32\netsh.exe interface ipv6 set address interface=4 fde6:7a:7d20:886::10e4 store=active . 2020.09.05 11:44:13 - OpenVPN > NETSH: C:\WINDOWS\system32\netsh.exe interface ipv6 set dns Connexion au réseau local static fde6:7a:7d20:886::1 validate=no . 2020.09.05 11:44:13 - OpenVPN > add_route_ipv6(fde6:7a:7d20:886::/64 -> fde6:7a:7d20:886::10e4 metric 0) dev Connexion au réseau local . 2020.09.05 11:44:13 - OpenVPN > C:\WINDOWS\system32\netsh.exe interface ipv6 add route fde6:7a:7d20:886::/64 interface=4 fe80::8 store=active . 2020.09.05 11:44:13 - OpenVPN > env_block: add PATH=C:\WINDOWS\System32;C:\WINDOWS;C:\WINDOWS\System32\Wbem . 2020.09.05 11:44:18 - OpenVPN > TEST ROUTES: 1/1 succeeded len=0 ret=1 a=0 u/d=up . 2020.09.05 11:44:18 - OpenVPN > C:\WINDOWS\system32\route.exe ADD 213.152.162.172 MASK 255.255.255.255 192.168.1.1 . 2020.09.05 11:44:18 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=25 and dwForwardType=4 . 2020.09.05 11:44:18 - OpenVPN > Route addition via IPAPI succeeded [adaptive] . 2020.09.05 11:44:18 - OpenVPN > C:\WINDOWS\system32\route.exe ADD 0.0.0.0 MASK 128.0.0.0 10.12.134.1 . 2020.09.05 11:44:18 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=25 and dwForwardType=4 . 2020.09.05 11:44:18 - OpenVPN > Route addition via IPAPI succeeded [adaptive] . 2020.09.05 11:44:18 - OpenVPN > C:\WINDOWS\system32\route.exe ADD 128.0.0.0 MASK 128.0.0.0 10.12.134.1 . 2020.09.05 11:44:18 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=25 and dwForwardType=4 . 2020.09.05 11:44:18 - OpenVPN > Route addition via IPAPI succeeded [adaptive] . 2020.09.05 11:44:18 - OpenVPN > add_route_ipv6(::/3 -> fde6:7a:7d20:886::1 metric -1) dev Connexion au réseau local . 2020.09.05 11:44:18 - OpenVPN > C:\WINDOWS\system32\netsh.exe interface ipv6 add route ::/3 interface=4 fe80::8 store=active . 2020.09.05 11:44:18 - OpenVPN > env_block: add PATH=C:\WINDOWS\System32;C:\WINDOWS;C:\WINDOWS\System32\Wbem . 2020.09.05 11:44:18 - OpenVPN > add_route_ipv6(2000::/4 -> fde6:7a:7d20:886::1 metric -1) dev Connexion au réseau local . 2020.09.05 11:44:18 - OpenVPN > C:\WINDOWS\system32\netsh.exe interface ipv6 add route 2000::/4 interface=4 fe80::8 store=active . 2020.09.05 11:44:18 - OpenVPN > env_block: add PATH=C:\WINDOWS\System32;C:\WINDOWS;C:\WINDOWS\System32\Wbem . 2020.09.05 11:44:18 - OpenVPN > add_route_ipv6(3000::/4 -> fde6:7a:7d20:886::1 metric -1) dev Connexion au réseau local . 2020.09.05 11:44:18 - OpenVPN > C:\WINDOWS\system32\netsh.exe interface ipv6 add route 3000::/4 interface=4 fe80::8 store=active . 2020.09.05 11:44:18 - OpenVPN > env_block: add PATH=C:\WINDOWS\System32;C:\WINDOWS;C:\WINDOWS\System32\Wbem . 2020.09.05 11:44:18 - OpenVPN > add_route_ipv6(fc00::/7 -> fde6:7a:7d20:886::1 metric -1) dev Connexion au réseau local . 2020.09.05 11:44:18 - OpenVPN > C:\WINDOWS\system32\netsh.exe interface ipv6 add route fc00::/7 interface=4 fe80::8 store=active . 2020.09.05 11:44:18 - OpenVPN > env_block: add PATH=C:\WINDOWS\System32;C:\WINDOWS;C:\WINDOWS\System32\Wbem . 2020.09.05 11:44:18 - Interface Connexion au réseau local metric changed from Automatic to 3, layer IPv4 . 2020.09.05 11:44:18 - Interface Connexion au réseau local metric changed from Automatic to 3, layer IPv6 . 2020.09.05 11:44:18 - DNS leak protection with packet filtering enabled. . 2020.09.05 11:44:18 - Routes, added a new route, 213.152.162.170 for gateway 10.12.134.1 . 2020.09.05 11:44:18 - Routes, added a new route, 2a00:1678:2470:18:c954:55da:f018:70ff for gateway fde6:7a:7d20:886::1 . 2020.09.05 11:44:18 - Flushing DNS I 2020.09.05 11:44:18 - Checking route IPv4 I 2020.09.05 11:44:19 - Checking route IPv6 I 2020.09.05 11:44:23 - Checking DNS ! 2020.09.05 11:44:24 - Connected. . 2020.09.05 11:44:24 - OpenVPN > Initialization Sequence Completed ---------------------------- Network Interfaces and Routes: { "support_ipv4": true, "support_ipv6": true, "routes": [ { "address": "0.0.0.0\/0", "interface": "{957709BA-8575-41E9-B24C-B6E6B15FC8F0}", "gateway": "192.168.1.1", "metric": "25" }, { "address": "0.0.0.0\/1", "interface": "{1255CA32-8BD2-4AEB-8AF4-3ACA710B779C}", "gateway": "10.12.134.1", "metric": "3" }, { "address": "10.12.134.0\/24", "interface": "{1255CA32-8BD2-4AEB-8AF4-3ACA710B779C}", "gateway": "link", "metric": "259" }, { "address": "10.12.134.230", "interface": "{1255CA32-8BD2-4AEB-8AF4-3ACA710B779C}", "gateway": "link", "metric": "259" }, { "address": "10.12.134.255", "interface": "{1255CA32-8BD2-4AEB-8AF4-3ACA710B779C}", "gateway": "link", "metric": "259" }, { "address": "127.0.0.0\/8", "interface": "{280DF9A3-710F-11E8-B469-806E6F6E6963}", "gateway": "link", "metric": "331" }, { "address": "127.0.0.1", "interface": "{280DF9A3-710F-11E8-B469-806E6F6E6963}", "gateway": "link", "metric": "331" }, { "address": "127.255.255.255", "interface": "{280DF9A3-710F-11E8-B469-806E6F6E6963}", "gateway": "link", "metric": "331" }, { "address": "128.0.0.0\/1", "interface": "{1255CA32-8BD2-4AEB-8AF4-3ACA710B779C}", "gateway": "10.12.134.1", "metric": "3" }, { "address": "192.168.1.0\/24", "interface": "{957709BA-8575-41E9-B24C-B6E6B15FC8F0}", "gateway": "link", "metric": "281" }, { "address": "192.168.1.31", "interface": "{957709BA-8575-41E9-B24C-B6E6B15FC8F0}", "gateway": "link", "metric": "281" }, { "address": "192.168.1.255", "interface": "{957709BA-8575-41E9-B24C-B6E6B15FC8F0}", "gateway": "link", "metric": "281" }, { "address": "213.152.162.170", "interface": "{1255CA32-8BD2-4AEB-8AF4-3ACA710B779C}", "gateway": "10.12.134.1", "metric": "4" }, { "address": "213.152.162.172", "interface": "{957709BA-8575-41E9-B24C-B6E6B15FC8F0}", "gateway": "192.168.1.1", "metric": "25" }, { "address": "224.0.0.0\/4", "interface": "{280DF9A3-710F-11E8-B469-806E6F6E6963}", "gateway": "link", "metric": "331" }, { "address": "224.0.0.0\/4", "interface": "{1255CA32-8BD2-4AEB-8AF4-3ACA710B779C}", "gateway": "link", "metric": "259" }, { "address": "224.0.0.0\/4", "interface": "{957709BA-8575-41E9-B24C-B6E6B15FC8F0}", "gateway": "link", "metric": "281" }, { "address": "255.255.255.255", "interface": "{280DF9A3-710F-11E8-B469-806E6F6E6963}", "gateway": "link", "metric": "331" }, { "address": "255.255.255.255", "interface": "{1255CA32-8BD2-4AEB-8AF4-3ACA710B779C}", "gateway": "link", "metric": "259" }, { "address": "255.255.255.255", "interface": "{957709BA-8575-41E9-B24C-B6E6B15FC8F0}", "gateway": "link", "metric": "281" }, { "address": "::\/3", "interface": "{1255CA32-8BD2-4AEB-8AF4-3ACA710B779C}", "gateway": "fe80::8", "metric": "259" }, { "address": "::1", "interface": "{280DF9A3-710F-11E8-B469-806E6F6E6963}", "gateway": "link", "metric": "331" }, { "address": "2000::\/4", "interface": "{1255CA32-8BD2-4AEB-8AF4-3ACA710B779C}", "gateway": "fe80::8", "metric": "259" }, { "address": "2a00:1678:2470:18:c954:55da:f018:70ff", "interface": "{1255CA32-8BD2-4AEB-8AF4-3ACA710B779C}", "gateway": "fde6:7a:7d20:886::1", "metric": "259" }, { "address": "3000::\/4", "interface": "{1255CA32-8BD2-4AEB-8AF4-3ACA710B779C}", "gateway": "fe80::8", "metric": "259" }, { "address": "fc00::\/7", "interface": "{1255CA32-8BD2-4AEB-8AF4-3ACA710B779C}", "gateway": "fe80::8", "metric": "259" }, { "address": "fde6:7a:7d20:886::\/64", "interface": "{1255CA32-8BD2-4AEB-8AF4-3ACA710B779C}", "gateway": "fe80::8", "metric": "259" }, { "address": "fde6:7a:7d20:886::10e4", "interface": "{1255CA32-8BD2-4AEB-8AF4-3ACA710B779C}", "gateway": "link", "metric": "259" }, { "address": "fe80::\/64", "interface": "{1255CA32-8BD2-4AEB-8AF4-3ACA710B779C}", "gateway": "link", "metric": "259" }, { "address": "fe80::\/64", "interface": "{957709BA-8575-41E9-B24C-B6E6B15FC8F0}", "gateway": "link", "metric": "281" }, { "address": "fe80::2c39:f10f:d31d:3394", "interface": "{1255CA32-8BD2-4AEB-8AF4-3ACA710B779C}", "gateway": "link", "metric": "259" }, { "address": "fe80::91ad:17b9:a03a:7668", "interface": "{957709BA-8575-41E9-B24C-B6E6B15FC8F0}", "gateway": "link", "metric": "281" }, { "address": "ff00::\/8", "interface": "{280DF9A3-710F-11E8-B469-806E6F6E6963}", "gateway": "link", "metric": "331" }, { "address": "ff00::\/8", "interface": "{1255CA32-8BD2-4AEB-8AF4-3ACA710B779C}", "gateway": "link", "metric": "259" }, { "address": "ff00::\/8", "interface": "{957709BA-8575-41E9-B24C-B6E6B15FC8F0}", "gateway": "link", "metric": "281" }, { "address": "2a00:1678:2470:18:c954:55da:f018:70ff", "gateway": "fde6:7a:7d20:886::1", "metric": "4294967295" } ], "interfaces": [ { "friendly": "Connexion au r\u00e9seau local", "id": "{1255CA32-8BD2-4AEB-8AF4-3ACA710B779C}", "name": "Connexion au r\u00e9seau local", "description": "TAP-Windows Adapter V9", "type": "53", "status": "Up", "bytes_received": "9184130", "bytes_sent": "1611897", "support_ipv4": true, "support_ipv6": true, "ips": [ "fde6:7a:7d20:886::10e4", "fe80::2c39:f10f:d31d:3394", "10.12.134.230" ], "gateways": [ "10.12.134.1", "fe80::8", "fde6:7a:7d20:886::1" ], "bind": true, "dns4": "", "dns6": null }, { "friendly": "Ethernet", "id": "{957709BA-8575-41E9-B24C-B6E6B15FC8F0}", "name": "Ethernet", "description": "Intel(R) Ethernet Connection (2) I218-V", "type": "Ethernet", "status": "Up", "bytes_received": "48099802", "bytes_sent": "5331451", "support_ipv4": true, "support_ipv6": true, "ips": [ "fe80::91ad:17b9:a03a:7668", "192.168.1.31" ], "gateways": [ "192.168.1.1" ], "bind": true, "dns4": "", "dns6": null }, { "friendly": "Loopback Pseudo-Interface 1", "id": "{280DF9A3-710F-11E8-B469-806E6F6E6963}", "name": "Loopback Pseudo-Interface 1", "description": "Software Loopback Interface 1", "type": "Loopback", "status": "Up", "bytes_received": "0", "bytes_sent": "0", "support_ipv4": true, "support_ipv6": true, "ips": [ "::1", "127.0.0.1" ], "gateways": [], "bind": true, "dns4": "", "dns6": null } ], "ipv4-default-gateway": "10.12.134.1", "ipv4-default-interface": "{1255CA32-8BD2-4AEB-8AF4-3ACA710B779C}", "ipv6-default-gateway": "fe80::8", "ipv6-default-interface": "{1255CA32-8BD2-4AEB-8AF4-3ACA710B779C}" } ---------------------------- ipconfig /all: Configuration IP de Windows Nom de l'h“te . . . . . . . . . . : LePCdePapa Suffixe DNS principal . . . . . . : Type de noeud. . . . . . . . . . : Hybride Routage IP activ‚ . . . . . . . . : Non Proxy WINS activ‚ . . . . . . . . : Non Carte inconnue Connexion au r‚seau localÿ: Suffixe DNS propre … la connexion. . . : Description. . . . . . . . . . . . . . : TAP-Windows Adapter V9 Adresse physique . . . . . . . . . . . : 00-FF-12-55-CA-32 DHCP activ‚. . . . . . . . . . . . . . : Oui Configuration automatique activ‚e. . . : Oui Adresse IPv6. . . . . . . . . . .ÿ. . .: fde6:7a:7d20:886::10e4(pr‚f‚r‚) Adresse IPv6 de liaison locale. . . . .: fe80::2c39:f10f:d31d:3394%4(pr‚f‚r‚) Adresse IPv4. . . . . . . . . . . . . .: 10.12.134.230(pr‚f‚r‚) Masque de sous-r‚seau. . . .ÿ. . . . . : 255.255.255.0 Bail obtenu. . . . . . . . .ÿ. . . . . : 5 septembre 2020 11:44:11 Bail expirant. . . . . . . . .ÿ. . . . : 5 septembre 2021 11:44:11 Passerelle par d‚faut. . . .ÿ. . . . . : Serveur DHCP . . . . . . . . . . . . . : 10.12.134.254 IAID DHCPv6 . . . . . . . . . . . : 218169106 DUID de client DHCPv6. . . . . . . . : 00-01-00-01-22-B6-24-33-4C-CC-6A-6B-20-B5 Serveurs DNS. . . . . . . . . . . . . : fde6:7a:7d20:886::1 10.12.134.1 NetBIOS sur Tcpip. . . . . . . . . . . : Activ‚ Carte Ethernet Ethernet : Suffixe DNS propre … la connexion. . . : Description. . . . . . . . . . . . . . : Intel(R) Ethernet Connection (2) I218-V Adresse physique . . . . . . . . . . . : 4C-CC-6A-6B-20-B5 DHCP activ‚. . . . . . . . . . . . . . : Oui Configuration automatique activ‚e. . . : Oui Adresse IPv6 de liaison locale. . . . .: fe80::91ad:17b9:a03a:7668%10(pr‚f‚r‚) Adresse IPv4. . . . . . . . . . . . . .: 192.168.1.31(pr‚f‚r‚) Masque de sous-r‚seau. . . .ÿ. . . . . : 255.255.255.0 Bail obtenu. . . . . . . . .ÿ. . . . . : 5 septembre 2020 11:42:36 Bail expirant. . . . . . . . .ÿ. . . . : 6 septembre 2020 11:42:36 Passerelle par d‚faut. . . .ÿ. . . . . : 192.168.1.1 Serveur DHCP . . . . . . . . . . . . . : 192.168.1.1 IAID DHCPv6 . . . . . . . . . . . : 88919146 DUID de client DHCPv6. . . . . . . . : 00-01-00-01-22-B6-24-33-4C-CC-6A-6B-20-B5 Serveurs DNS. . . . . . . . . . . . . : 192.168.1.1 NetBIOS sur Tcpip. . . . . . . . . . . : Activ‚ Share this post Link to post
LZ1 685 Posted ... Quote Network Lock Active: No It seems you didn't turn this feature on . It'll also still be perfectly possible to torrent with this turned on. On ipleak, you can similarly download a test torrent to confirm this. 1 MongolMongol reacted to this Hide LZ1's signature Hide all signatures Hi there, are you new to AirVPN? Many of your questions are already answered in this guide. You may also read the Eddie Android FAQ. Moderators do not speak on behalf of AirVPN. Only the Official Staff account does. Please also do not run Tor Exit Servers behind AirVPN, thank you. Did you make a guide or how-to for something? Then contact me to get it listed in my new user guide's Guides Section, so that the community can find it more easily. Share this post Link to post
MongolMongol 1 Posted ... Hmm, I always thought this would simply stop all traffic from coming in or going out. Wow. Trying it now. Torrent client doesn't seem to connect to the network but I can watch Youtube. 🤷♂️ No, no, I am not a newb. 😳 Thank you for you time and attention. Share this post Link to post
Tech Jedi Alex 1577 Posted ... 5 minutes ago, MongolMongol said: Trying it now. Torrent client doesn't seem to connect to the network but I can watch Youtube. 🤷♂️ Check to which interface/IP address your torrent client binds. Set it to "Connexion au réseau local" or "TAP-Windows Adapter v9", whatever it shows up as. In qBittorrent you can set this in the Advanced section of its settings. 1 MongolMongol reacted to this Hide Tech Jedi Alex's signature Hide all signatures NOT AN AIRVPN TEAM MEMBER. USE TICKETS FOR PROFESSIONAL SUPPORT. LZ1's New User Guide to AirVPN « Plenty of stuff for advanced users, too! Want to contact me directly? All relevant methods are on my About me page. Share this post Link to post
MongolMongol 1 Posted ... aaah, yes, that did it! No more leak. Thank you so much to both of you guys! 1 Tech Jedi Alex reacted to this Share this post Link to post
