Flx 81 Posted ... Anyone else encountered this yet? Thx Quote Hide Flx's signature Hide all signatures Guide - EMBY Block ALL interfaces except tap/vpn Windows OS - Configuring your operating system Windows OS - Multi Session/Tunnel Share this post Link to post
Tech Jedi Alex 1583 Posted ... Elaborate. What do you mean by "disrupting"? Quote Hide Tech Jedi Alex's signature Hide all signatures NOT AN AIRVPN TEAM MEMBER. USE TICKETS FOR PROFESSIONAL SUPPORT. LZ1's New User Guide to AirVPN « Plenty of stuff for advanced users, too! Want to contact me directly? All relevant methods are on my About me page. Share this post Link to post
Flx 81 Posted ... 11 minutes ago, giganerd said: Elaborate. What do you mean by "disrupting"? After the "go" on speedtest.net all sessions "drop"....Reconnecting process starts up once more for each tunnel and get reconnected. On some magic socket error I did not see until today. Browsers: Chrome and Firefox. Here: 2020-08-09 05:50:32 SIGHUP[hard,init_instance] received, process restarting 2020-08-09 05:50:32 MANAGEMENT: >STATE:1596966632,RECONNECTING,init_instance,,,,, 2020-08-09 05:50:32 OpenVPN 2.5_git x86_64-w64-mingw32 [SSL (OpenSSL)] [LZO] [LZ4] [PKCS11] [AEAD] built on Jul 15 2020 2020-08-09 05:50:32 Windows version 6.2 (Windows 8 or greater) 64bit 2020-08-09 05:50:32 library versions: OpenSSL 1.1.0l 10 Sep 2019, LZO 2.10 2020-08-09 05:50:32 Restart pause, 2 second(s) 2020-08-09 05:50:34 Outgoing Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key 2020-08-09 05:50:34 Outgoing Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication 2020-08-09 05:50:34 Incoming Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key 2020-08-09 05:50:34 Incoming Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication 2020-08-09 05:50:34 TCP/UDP: Preserving recently used remote address: [AF_INET]184.75.223.221:2018 2020-08-09 05:50:34 Socket Buffers: R=[65536->562144] S=[65536->562144] 2020-08-09 05:50:34 Attempting to establish TCP connection with [AF_INET]184.75.223.221:2018 [nonblock] 2020-08-09 05:50:34 MANAGEMENT: >STATE:1596966634,TCP_CONNECT,,,,,, 2020-08-09 05:50:35 TCP connection established with [AF_INET]184.75.223.221:2018 2020-08-09 05:50:35 TCP_CLIENT link local: (not bound) 2020-08-09 05:50:35 TCP_CLIENT link remote: [AF_INET]184.75.223.221:2018 2020-08-09 05:50:35 MANAGEMENT: >STATE:1596966635,WAIT,,,,,, 2020-08-09 05:50:35 MANAGEMENT: >STATE:1596966635,AUTH,,,,,, 2020-08-09 05:50:35 TLS: Initial packet from [AF_INET]184.75.223.221:2018, sid=f2deae18 cb9cdef4 2020-08-09 05:50:35 VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org 2020-08-09 05:50:35 VERIFY KU OK 2020-08-09 05:50:35 Validating certificate extended key usage 2020-08-09 05:50:35 ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication 2020-08-09 05:50:35 VERIFY EKU OK 2020-08-09 05:50:35 VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=Mintaka, emailAddress=info@airvpn.org 2020-08-09 05:50:35 Control Channel: TLSv1.2, cipher TLSv1.2 DHE-RSA-AES256-GCM-SHA384, 4096 bit RSA 2020-08-09 05:50:35 [Mintaka] Peer Connection Initiated with [AF_INET]184.75.223.221:2018 2020-08-09 05:50:36 MANAGEMENT: >STATE:1596966636,GET_CONFIG,,,,,, 2020-08-09 05:50:36 SENT CONTROL [Mintaka]: 'PUSH_REQUEST' (status=1) 2020-08-09 05:50:36 PUSH: Received control message: 'PUSH_REPLY,comp-lzo no,redirect-gateway ipv6 def1 bypass-dhcp,dhcp-option DNS 10.24.7.1,tun-ipv6,route-gateway 10.24.7.1,topology subnet,ping 10,ping-restart 60,ifconfig-ipv6 fde6:7a:7d20:1407::1031/64 fde6:7a:7d20:1407::1,ifconfig 10.24.7.51 255.255.255.0,peer-id 0,cipher AES-256-GCM' 2020-08-09 05:50:36 OPTIONS IMPORT: timers and/or timeouts modified 2020-08-09 05:50:36 OPTIONS IMPORT: compression parms modified 2020-08-09 05:50:36 OPTIONS IMPORT: --ifconfig/up options modified 2020-08-09 05:50:36 OPTIONS IMPORT: route options modified 2020-08-09 05:50:36 OPTIONS IMPORT: route-related options modified 2020-08-09 05:50:36 OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified 2020-08-09 05:50:36 OPTIONS IMPORT: peer-id set 2020-08-09 05:50:36 OPTIONS IMPORT: adjusting link_mtu to 1627 2020-08-09 05:50:36 OPTIONS IMPORT: data channel crypto options modified 2020-08-09 05:50:36 Data Channel: using negotiated cipher 'AES-256-GCM' 2020-08-09 05:50:36 Outgoing Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key 2020-08-09 05:50:36 Incoming Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key 2020-08-09 05:50:36 interactive service msg_channel=0 2020-08-09 05:50:36 ROUTE_GATEWAY 192.168.2.1/255.255.255.0 I=19 HWADDR=18:66:da:2e:b2:08 2020-08-09 05:50:36 GDG6: remote_host_ipv6=n/a 2020-08-09 05:50:36 NOTE: GetBestInterfaceEx returned error: Element not found. (code=1168) 2020-08-09 05:50:36 ROUTE6: default_gateway=UNDEF 2020-08-09 05:50:36 open_tun 2020-08-09 05:50:36 CreateFile failed on wintun device: 2020-08-09 05:50:36 CreateFile failed on wintun device: 2020-08-09 05:50:36 Adapter {5130DFE7-38B7-4082-AF90-A4C36713DDE0} is already in use 2020-08-09 05:50:36 Failed to register {5130DFE7-38B7-4082-AF90-A4C36713DDE0} adapter ring buffers 2020-08-09 05:50:36 wintun device [Local Area Connection 6] opened 2020-08-09 05:50:36 MANAGEMENT: >STATE:1596966636,ASSIGN_IP,,10.24.7.51,,,,,fde6:7a:7d20:1407::1031 2020-08-09 05:50:37 NETSH: C:\WINDOWS\system32\netsh.exe interface ip set address Local Area Connection 6 static 10.24.7.51 255.255.255.0 2020-08-09 05:50:38 NETSH: C:\WINDOWS\system32\netsh.exe interface ip delete dns Local Area Connection 6 all 2020-08-09 05:50:39 NETSH: C:\WINDOWS\system32\netsh.exe interface ip set dns Local Area Connection 6 static 10.24.7.1 validate=no 2020-08-09 05:50:41 NETSH: C:\WINDOWS\system32\netsh.exe interface ip delete wins Local Area Connection 6 all 2020-08-09 05:50:42 IPv4 MTU set to 1500 on interface 25 using SetIpInterfaceEntry() 2020-08-09 05:50:43 NETSH: C:\WINDOWS\system32\netsh.exe interface ipv6 set address interface=25 fde6:7a:7d20:1407::1031 store=active 2020-08-09 05:50:43 add_route_ipv6(fde6:7a:7d20:1407::/64 -> fde6:7a:7d20:1407::1031 metric 0) dev Local Area Connection 6 2020-08-09 05:50:43 C:\WINDOWS\system32\netsh.exe interface ipv6 add route fde6:7a:7d20:1407::/64 interface=25 fe80::8 store=active 2020-08-09 05:50:43 env_block: add PATH=C:\WINDOWS\System32;C:\WINDOWS;C:\WINDOWS\System32\Wbem 2020-08-09 05:50:43 IPv6 MTU set to 1500 on interface 25 using SetIpInterfaceEntry() 2020-08-09 05:50:43 C:\WINDOWS\system32\route.exe ADD 184.75.223.221 MASK 255.255.255.255 192.168.2.1 2020-08-09 05:50:43 ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=25 and dwForwardType=4 2020-08-09 05:50:43 Route addition via IPAPI succeeded [adaptive] 2020-08-09 05:50:43 C:\WINDOWS\system32\route.exe ADD 0.0.0.0 MASK 128.0.0.0 10.24.7.1 2020-08-09 05:50:43 ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=5 and dwForwardType=4 2020-08-09 05:50:43 Route addition via IPAPI succeeded [adaptive] 2020-08-09 05:50:43 C:\WINDOWS\system32\route.exe ADD 128.0.0.0 MASK 128.0.0.0 10.24.7.1 2020-08-09 05:50:43 ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=5 and dwForwardType=4 2020-08-09 05:50:43 Route addition via IPAPI succeeded [adaptive] 2020-08-09 05:50:43 add_route_ipv6(::/3 -> fde6:7a:7d20:1407::1 metric -1) dev Local Area Connection 6 2020-08-09 05:50:43 C:\WINDOWS\system32\netsh.exe interface ipv6 add route ::/3 interface=25 fe80::8 store=active 2020-08-09 05:50:43 env_block: add PATH=C:\WINDOWS\System32;C:\WINDOWS;C:\WINDOWS\System32\Wbem 2020-08-09 05:50:43 add_route_ipv6(2000::/4 -> fde6:7a:7d20:1407::1 metric -1) dev Local Area Connection 6 2020-08-09 05:50:43 C:\WINDOWS\system32\netsh.exe interface ipv6 add route 2000::/4 interface=25 fe80::8 store=active 2020-08-09 05:50:43 env_block: add PATH=C:\WINDOWS\System32;C:\WINDOWS;C:\WINDOWS\System32\Wbem 2020-08-09 05:50:43 add_route_ipv6(3000::/4 -> fde6:7a:7d20:1407::1 metric -1) dev Local Area Connection 6 2020-08-09 05:50:43 C:\WINDOWS\system32\netsh.exe interface ipv6 add route 3000::/4 interface=25 fe80::8 store=active 2020-08-09 05:50:43 env_block: add PATH=C:\WINDOWS\System32;C:\WINDOWS;C:\WINDOWS\System32\Wbem 2020-08-09 05:50:44 add_route_ipv6(fc00::/7 -> fde6:7a:7d20:1407::1 metric -1) dev Local Area Connection 6 2020-08-09 05:50:44 C:\WINDOWS\system32\netsh.exe interface ipv6 add route fc00::/7 interface=25 fe80::8 store=active 2020-08-09 05:50:44 env_block: add PATH=C:\WINDOWS\System32;C:\WINDOWS;C:\WINDOWS\System32\Wbem 2020-08-09 05:50:44 Initialization Sequence Completed Quote Hide Flx's signature Hide all signatures Guide - EMBY Block ALL interfaces except tap/vpn Windows OS - Configuring your operating system Windows OS - Multi Session/Tunnel Share this post Link to post
Flx 81 Posted ... Already switched to OpenVPN over stunnel. Got to see if it happens in stunnel. The above "connection drop/connection restart" occurs in TCP/UDP ports 443/80/2018/41185. If you want the full logs I'll PM them to you or ticket this to Staff. Quote Hide Flx's signature Hide all signatures Guide - EMBY Block ALL interfaces except tap/vpn Windows OS - Configuring your operating system Windows OS - Multi Session/Tunnel Share this post Link to post
Tech Jedi Alex 1583 Posted ... I tried a test with whatever settings I could synchronize with yours, like buffer sizes, remote and port, but couldn't reproduce it. Works as intended on Linux, OpenVPN v2.4.9. Quote Hide Tech Jedi Alex's signature Hide all signatures NOT AN AIRVPN TEAM MEMBER. USE TICKETS FOR PROFESSIONAL SUPPORT. LZ1's New User Guide to AirVPN « Plenty of stuff for advanced users, too! Want to contact me directly? All relevant methods are on my About me page. Share this post Link to post
Flx 81 Posted ... 8 minutes ago, giganerd said: I tried a test with whatever settings I could synchronize with yours, like buffer sizes, remote and port, but couldn't reproduce it. Works as intended on Linux, OpenVPN v2.4.9. This is in Windows 10 [Version 10.0.19041.329] Quote Hide Flx's signature Hide all signatures Guide - EMBY Block ALL interfaces except tap/vpn Windows OS - Configuring your operating system Windows OS - Multi Session/Tunnel Share this post Link to post
Tech Jedi Alex 1583 Posted ... I know, but since it works for me, your claim about Ookla disrupting OpenVPN is less probable. Let's see what others write. Quote Hide Tech Jedi Alex's signature Hide all signatures NOT AN AIRVPN TEAM MEMBER. USE TICKETS FOR PROFESSIONAL SUPPORT. LZ1's New User Guide to AirVPN « Plenty of stuff for advanced users, too! Want to contact me directly? All relevant methods are on my About me page. Share this post Link to post
Flx 81 Posted ... 13 hours ago, giganerd said: I know, but since it works for me, your claim about Ookla disrupting OpenVPN is less probable. Let's see what others write. Alright Lets see what other members have to say! Thus far scenarios tried and speed factor: one session --- ~300-450 mbps double session --- ~500-600 mbps triple session --- ~700-750 mbps quad session --- ~800-850 mbps I remember when you said that "You are just happy with 1 session". Guess there is no harm done if more can be achieved. Quote Hide Flx's signature Hide all signatures Guide - EMBY Block ALL interfaces except tap/vpn Windows OS - Configuring your operating system Windows OS - Multi Session/Tunnel Share this post Link to post
Tech Jedi Alex 1583 Posted ... Bit off-topic, but still: What do you mean? Are you combining connections to reach more throughput? Is that even possible with OpenVPN? Quote Hide Tech Jedi Alex's signature Hide all signatures NOT AN AIRVPN TEAM MEMBER. USE TICKETS FOR PROFESSIONAL SUPPORT. LZ1's New User Guide to AirVPN « Plenty of stuff for advanced users, too! Want to contact me directly? All relevant methods are on my About me page. Share this post Link to post
Staff 10697 Posted ... 1 hour ago, giganerd said: Bit off-topic, but still: What do you mean? Are you combining connections to reach more throughput? Is that even possible with OpenVPN? Hello! It is possible. About two or three years ago, as a consequence of two requests by very advanced customers, we changed completely OpenVPN daemons subnets to make them unique across the whole infrastructure. That deep change main purpose was making multiple connections from the same system easier by preventing any chance of address conflicts. Connecting the same machine to multiple VPN servers is very beneficial for load balancing, failover and bandwidth aggregation. Please check for example the following, excellent guide:https://nguvu.org/pfsense/pfsense-multi-vpn-wan/ Kind regards 1 Flx reacted to this Quote Share this post Link to post
Flx 81 Posted ... 12 hours ago, Staff said: It is possible. About two or three years ago, as a consequence of two requests by very advanced customers, we changed completely OpenVPN daemons subnets to make them unique across the whole infrastructure. That deep change main purpose was making multiple connections from the same system easier by preventing any chance of address conflicts. Connecting the same machine to multiple VPN servers is very beneficial for load balancing, failover and bandwidth aggregation. Exactly Quote Hide Flx's signature Hide all signatures Guide - EMBY Block ALL interfaces except tap/vpn Windows OS - Configuring your operating system Windows OS - Multi Session/Tunnel Share this post Link to post
Flx 81 Posted ... 6 hours ago, Flx said: purpose was making multiple connections from the same system @StaffOne question in a triple session scenario: When connected to https://airvpn.org/ (server1:port 443) New tab Connected to https://ipx.ac/run or https://ipleak.net/ (server2:port 80) New tab Connected to http://www.utrace.de/ (server3:port 2018) Is this correct? Quote Hide Flx's signature Hide all signatures Guide - EMBY Block ALL interfaces except tap/vpn Windows OS - Configuring your operating system Windows OS - Multi Session/Tunnel Share this post Link to post
Flx 81 Posted ... (edited) Session/Daemon Restart....One of the reasons Why it happens!!!(link below).https://www.speedguide.net/port.php?port=5050 EDIT: Server-side(connected server(s)) all the above ports in the above link are "filtered" correctly. Client-Side Comodo rule for openvpn.exe and openvpn-gui.exe to fix this:https://airvpn.org/uploads/monthly_2020_08/openvpn_rule.multi.session_rule.jpg.3ef6dd9a1b13e27a11e64cf908c40b4a.jpg Edited ... by Flx DDoS only affects the openvpn process/session(s). Client-side Comodo rule should be sufficient enough. Quote Hide Flx's signature Hide all signatures Guide - EMBY Block ALL interfaces except tap/vpn Windows OS - Configuring your operating system Windows OS - Multi Session/Tunnel Share this post Link to post
