Staff 10395 Posted ... Hello! We're very glad to inform you that we have just released Hummingbird 1.1.0, featuring: both SystemV-style init and systemd support for Linux update to the latest OpenVPN3-AirVPN and asio libraries Hummingbird is AirVPN's free and open source OpenVPN 3 client based on AirVPN's OpenVPN 3 library fork. Hummingbird is available for: Linux x86-64 (reasonably recent distribution on par with Debian 9 libraries and kernel is required) Linux ARM 32 (example: Raspbian for Raspberry Pi) Linux ARM 64 (example: Ubuntu 19 and 20 for Raspberry Pi) macOS (Mojave or higher version required - please read important notes for Mac users at the end of the announcement) Main features: Lightweight and stand alone binary No heavy framework required, no GUI Tiny RAM footprint Lightning fast Based on OpenVPN 3 library fork by AirVPN with tons of critical bug fixes from the main branch, new ciphers support and never seen before features ChaCha20-Poly1305 cipher support on both Control and Data Channel providing great performance boost on ARM, Raspberry PI and any Linux-based platform not supporting AES-NI. Note: ChaCha20 support for Android had been already implemented in our free and open source Eddie Android edition robust leaks prevention through Network Lock based either on iptables, nftables or pf through automatic detection proper handling of DNS push by VPN servers, working with resolv.conf as well as any operational mode of systemd-resolved additional features For a thorough Hummingbird overview please consult https://airvpn.org/hummingbird/readme/ Hummingbird 1.1.0 adds support to Linux systems based on SystemV-style init https://en.wikipedia.org/wiki/Init#SYSV too, while the previous versions supported Linux systemd based systems only.Therefore, we gladly achieve compatibility with 35 additional Linux distributions:https://distrowatch.com/search.php?ostype=All&category=All&origin=All&basedon=All¬basedon=None&desktop=All&architecture=All&package=All&rolling=All&isosize=All&netinstall=All&language=All&defaultinit=SysV&status=Active#simple We think it's important to support Init Freedom:https://devuan.org/os/init-freedom because systemd is POSIX incompatible and because, as the UNIX Veteran Admin collective noticed in 2014 when they announced a Debian fork: This situation prospects a lock in systemd dependencies which is de-facto threatening freedom of development and has serious consequences for Debian, its upstream and its downstream. You can download Hummingbird for Linux (all flavors) and macOS respectively here:https://airvpn.org/linux and here:http://airvpn.org/macos Important notes for macOS users From now on we provide both a signed, code-hardened, notarized version and a non-notarized version of Hummingbird for macOS. The notarized version is available essentially for those users who prefer it, but it is not recommended. The notarized version will run without blocks by Apple's Gatekeeper, but will let Apple correlate your real IP address, Apple ID and other data potentially disclosing your identity to the fact that you run, and when you did it for the first time, an application by AirVPN. If that's not acceptable for you, just download the tarball package .tar.gz (it is NOT notarized and NOT signed with our Apple developer ID on purpose) and include it in the exceptions to run non-notarized programs. In the future this could not be allowed anymore, but at the moment it is. For a more thorough explanations on important privacy issues caused by Apple and notarization please see for example here https://lapcatsoftware.com/articles/notarization-privacy.html and here https://lapcatsoftware.com/articles/catalina-executables.html Kind regards & datalove AirVPN Staff 2 1 eburom, fiverair and colorman reacted to this Quote Share this post Link to post
Maggie144 12 Posted ... I implemented version 1.1.0 into Eddie 2.19.4 on macOS 10.15.6, since then I don't get long disconnects. But every hour Hummingbird is collecting information from AIR and when I'm downloading a file while this check-up happens I get this error in the log - with a short disconnect (indicated by the short greying out of the Eddie icon) E 2020.07.16 20:34:30 - Hummingbird > ERROR: N_KEV_EXPIRE if there is no active dl I don't get anything indicating a disconnect - just curious, before I start torrenting with Hummingbird here is the log dating back 2h . 2020.07.16 18:34:30 - Hummingbird > Tunnel Options:V4,dev-type tun,link-mtu 1602,tun-mtu 1500,proto UDPv4,comp-lzo,cipher AES-256-CBC,auth SHA512,keysize 256,key-method 2,tls-client . 2020.07.16 18:34:30 - Hummingbird > Peer Info: . 2020.07.16 18:34:30 - Hummingbird > IV_VER=3.6.4 AirVPN . 2020.07.16 18:34:30 - Hummingbird > IV_PLAT=mac . 2020.07.16 18:34:30 - Hummingbird > IV_NCP=2 . 2020.07.16 18:34:30 - Hummingbird > IV_TCPNL=1 . 2020.07.16 18:34:30 - Hummingbird > IV_PROTO=2 . 2020.07.16 18:34:30 - Hummingbird > IV_CIPHERS=AES-256-GCM:AES-128-GCM:CHACHA20-POLY1305 . 2020.07.16 18:34:30 - Hummingbird > IV_LZO_STUB=1 . 2020.07.16 18:34:30 - Hummingbird > IV_COMP_STUB=1 . 2020.07.16 18:34:30 - Hummingbird > IV_COMP_STUBv2=1 . 2020.07.16 18:34:30 - Hummingbird > IV_GUI_VER=Eddie2.19.4 . 2020.07.16 18:34:30 - Hummingbird > VERIFY OK : depth=1 . 2020.07.16 18:34:30 - Hummingbird > cert. version : 3 . 2020.07.16 18:34:30 - Hummingbird > serial number : 8C:D8:43:EF:E4:5F:20:03 . 2020.07.16 18:34:30 - Hummingbird > issuer name : C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org . 2020.07.16 18:34:30 - Hummingbird > subject name : C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org . 2020.07.16 18:34:30 - Hummingbird > issued on : 2014-04-11 10:15:45 . 2020.07.16 18:34:30 - Hummingbird > expires on : 2024-04-08 10:15:45 . 2020.07.16 18:34:30 - Hummingbird > signed using : RSA with SHA1 . 2020.07.16 18:34:30 - Hummingbird > RSA key size : 4096 bits . 2020.07.16 18:34:30 - Hummingbird > basic constraints : CA=true . 2020.07.16 18:34:30 - Hummingbird > VERIFY OK : depth=0 . 2020.07.16 18:34:30 - Hummingbird > cert. version : 3 . 2020.07.16 18:34:30 - Hummingbird > serial number : 0D . 2020.07.16 18:34:30 - Hummingbird > issuer name : C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org . 2020.07.16 18:34:30 - Hummingbird > subject name : C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=Camelopardalis, emailAddress=info@airvpn.org . 2020.07.16 18:34:30 - Hummingbird > issued on : 2016-12-02 16:45:09 . 2020.07.16 18:34:30 - Hummingbird > expires on : 2026-11-30 16:45:09 . 2020.07.16 18:34:30 - Hummingbird > signed using : RSA with SHA-512 . 2020.07.16 18:34:30 - Hummingbird > RSA key size : 4096 bits . 2020.07.16 18:34:30 - Hummingbird > basic constraints : CA=false . 2020.07.16 18:34:30 - Hummingbird > cert. type : SSL Server . 2020.07.16 18:34:30 - Hummingbird > key usage : Digital Signature, Key Encipherment . 2020.07.16 18:34:30 - Hummingbird > ext key usage : TLS Web Server Authentication . 2020.07.16 18:34:31 - Hummingbird > SSL Handshake: TLSv1.2/TLS-DHE-RSA-WITH-AES-256-GCM-SHA384 . 2020.07.16 18:34:31 - Hummingbird > LZO-ASYM init swap=0 asym=1 . 2020.07.16 18:34:31 - Hummingbird > Comp-stub init swap=0 . 2020.07.16 19:19:35 - Collect information about AirVPN completed . 2020.07.16 19:34:31 - Above log line repeated 1 times more . 2020.07.16 19:34:31 - Hummingbird > Tunnel Options:V4,dev-type tun,link-mtu 1602,tun-mtu 1500,proto UDPv4,comp-lzo,cipher AES-256-CBC,auth SHA512,keysize 256,key-method 2,tls-client . 2020.07.16 19:34:31 - Hummingbird > Peer Info: . 2020.07.16 19:34:31 - Hummingbird > IV_VER=3.6.4 AirVPN . 2020.07.16 19:34:31 - Hummingbird > IV_PLAT=mac . 2020.07.16 19:34:31 - Hummingbird > IV_NCP=2 . 2020.07.16 19:34:31 - Hummingbird > IV_TCPNL=1 . 2020.07.16 19:34:31 - Hummingbird > IV_PROTO=2 . 2020.07.16 19:34:31 - Hummingbird > IV_CIPHERS=AES-256-GCM:AES-128-GCM:CHACHA20-POLY1305 . 2020.07.16 19:34:31 - Hummingbird > IV_LZO_STUB=1 . 2020.07.16 19:34:31 - Hummingbird > IV_COMP_STUB=1 . 2020.07.16 19:34:31 - Hummingbird > IV_COMP_STUBv2=1 . 2020.07.16 19:34:31 - Hummingbird > IV_GUI_VER=Eddie2.19.4 . 2020.07.16 19:34:31 - Hummingbird > VERIFY OK : depth=1 . 2020.07.16 19:34:31 - Hummingbird > cert. version : 3 . 2020.07.16 19:34:31 - Hummingbird > serial number : 8C:D8:43:EF:E4:5F:20:03 . 2020.07.16 19:34:31 - Hummingbird > issuer name : C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org . 2020.07.16 19:34:31 - Hummingbird > subject name : C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org . 2020.07.16 19:34:31 - Hummingbird > issued on : 2014-04-11 10:15:45 . 2020.07.16 19:34:31 - Hummingbird > expires on : 2024-04-08 10:15:45 . 2020.07.16 19:34:31 - Hummingbird > signed using : RSA with SHA1 . 2020.07.16 19:34:31 - Hummingbird > RSA key size : 4096 bits . 2020.07.16 19:34:31 - Hummingbird > basic constraints : CA=true . 2020.07.16 19:34:31 - Hummingbird > VERIFY OK : depth=0 . 2020.07.16 19:34:31 - Hummingbird > cert. version : 3 . 2020.07.16 19:34:31 - Hummingbird > serial number : 0D . 2020.07.16 19:34:31 - Hummingbird > issuer name : C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org . 2020.07.16 19:34:31 - Hummingbird > subject name : C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=Camelopardalis, emailAddress=info@airvpn.org . 2020.07.16 19:34:31 - Hummingbird > issued on : 2016-12-02 16:45:09 . 2020.07.16 19:34:31 - Hummingbird > expires on : 2026-11-30 16:45:09 . 2020.07.16 19:34:31 - Hummingbird > signed using : RSA with SHA-512 . 2020.07.16 19:34:31 - Hummingbird > RSA key size : 4096 bits . 2020.07.16 19:34:31 - Hummingbird > basic constraints : CA=false . 2020.07.16 19:34:31 - Hummingbird > cert. type : SSL Server . 2020.07.16 19:34:31 - Hummingbird > key usage : Digital Signature, Key Encipherment . 2020.07.16 19:34:31 - Hummingbird > ext key usage : TLS Web Server Authentication . 2020.07.16 19:34:31 - Hummingbird > SSL Handshake: TLSv1.2/TLS-DHE-RSA-WITH-AES-256-GCM-SHA384 . 2020.07.16 19:34:31 - Hummingbird > LZO-ASYM init swap=0 asym=1 . 2020.07.16 19:34:31 - Hummingbird > Comp-stub init swap=0 . 2020.07.16 20:20:49 - Collect information about AirVPN completed E 2020.07.16 20:34:30 - Hummingbird > ERROR: N_KEV_EXPIRE . 2020.07.16 20:34:30 - Hummingbird > Tunnel Options:V4,dev-type tun,link-mtu 1602,tun-mtu 1500,proto UDPv4,comp-lzo,cipher AES-256-CBC,auth SHA512,keysize 256,key-method 2,tls-client . 2020.07.16 20:34:30 - Hummingbird > Peer Info: . 2020.07.16 20:34:30 - Hummingbird > IV_VER=3.6.4 AirVPN . 2020.07.16 20:34:30 - Hummingbird > IV_PLAT=mac . 2020.07.16 20:34:30 - Hummingbird > IV_NCP=2 . 2020.07.16 20:34:30 - Hummingbird > IV_TCPNL=1 . 2020.07.16 20:34:30 - Hummingbird > IV_PROTO=2 . 2020.07.16 20:34:30 - Hummingbird > IV_CIPHERS=AES-256-GCM:AES-128-GCM:CHACHA20-POLY1305 . 2020.07.16 20:34:30 - Hummingbird > IV_LZO_STUB=1 . 2020.07.16 20:34:30 - Hummingbird > IV_COMP_STUB=1 . 2020.07.16 20:34:30 - Hummingbird > IV_COMP_STUBv2=1 . 2020.07.16 20:34:30 - Hummingbird > IV_GUI_VER=Eddie2.19.4 . 2020.07.16 20:34:30 - Hummingbird > VERIFY OK : depth=1 . 2020.07.16 20:34:30 - Hummingbird > cert. version : 3 . 2020.07.16 20:34:30 - Hummingbird > serial number : 8C:D8:43:EF:E4:5F:20:03 . 2020.07.16 20:34:30 - Hummingbird > issuer name : C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org . 2020.07.16 20:34:30 - Hummingbird > subject name : C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org . 2020.07.16 20:34:30 - Hummingbird > issued on : 2014-04-11 10:15:45 . 2020.07.16 20:34:30 - Hummingbird > expires on : 2024-04-08 10:15:45 . 2020.07.16 20:34:30 - Hummingbird > signed using : RSA with SHA1 . 2020.07.16 20:34:30 - Hummingbird > RSA key size : 4096 bits . 2020.07.16 20:34:30 - Hummingbird > basic constraints : CA=true . 2020.07.16 20:34:30 - Hummingbird > VERIFY OK : depth=0 . 2020.07.16 20:34:30 - Hummingbird > cert. version : 3 . 2020.07.16 20:34:30 - Hummingbird > serial number : 0D . 2020.07.16 20:34:30 - Hummingbird > issuer name : C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org . 2020.07.16 20:34:30 - Hummingbird > subject name : C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=Camelopardalis, emailAddress=info@airvpn.org . 2020.07.16 20:34:30 - Hummingbird > issued on : 2016-12-02 16:45:09 . 2020.07.16 20:34:30 - Hummingbird > expires on : 2026-11-30 16:45:09 . 2020.07.16 20:34:30 - Hummingbird > signed using : RSA with SHA-512 . 2020.07.16 20:34:30 - Hummingbird > RSA key size : 4096 bits . 2020.07.16 20:34:30 - Hummingbird > basic constraints : CA=false . 2020.07.16 20:34:30 - Hummingbird > cert. type : SSL Server . 2020.07.16 20:34:30 - Hummingbird > key usage : Digital Signature, Key Encipherment . 2020.07.16 20:34:30 - Hummingbird > ext key usage : TLS Web Server Authentication . 2020.07.16 20:34:31 - Hummingbird > SSL Handshake: TLSv1.2/TLS-DHE-RSA-WITH-AES-256-GCM-SHA384 . 2020.07.16 20:34:31 - Hummingbird > LZO-ASYM init swap=0 asym=1 . 2020.07.16 20:34:31 - Hummingbird > Comp-stub init swap=0 Quote Share this post Link to post
Staff 10395 Posted ... @Maggie144 Hello! Can you please check whether: running Hummingbird alone resolves the problem or not running Hummingbird (both alone and through Eddie) with the additional directive reneg-sec 1000 resolves the problem or not Kind regards Quote Share this post Link to post
Maggie144 12 Posted ... How to go about adding the additional directive "reneg-sec 1000" in Eddie? Adding it to the "OVPN directives" under custom, does not solve the Error E 2020.07.17 17:44:59 - Hummingbird > ERROR: N_KEV_EXPIRE For using Hummingbird alone I'd have to read into it first Quote Share this post Link to post
Staff 10395 Posted ... @Maggie144 Hello! Please see here to run Hummingbird on its own:https://airvpn.org/hummingbird/readme/ Kind regards Quote Share this post Link to post
Maggie144 12 Posted ... thanks for the link - I managed to run Hummingbird alone, after some start-up issues (apparently only port 443 is supported, tried a config with 41185 at first and got Sat Jul 18 19:11:45.720 2020 OpenVPN core 3.6.4 AirVPN mac x86_64 64-bit Sat Jul 18 19:11:45.720 2020 Frame=512/2048/512 mssfix-ctrl=1250 Sat Jul 18 19:11:45.721 2020 OpenVPN3 CONNECT ERROR: route_gateway_error: GDG: problem writing to routing socket Sat Jul 18 19:11:45.721 2020 Thread finished I did deviate from the standard Port in Eddie 2.19.4 also while using Hummingbird, but there was no Error in the logs concerning this. Is the selected Protocol automatically overwritten? Side question; If one creates a ovpn-profile with a country (containing multiple Servers) is there any way for Hummingbird to automatically connect to the one with the lowest latency? No strange disconnects until now. it's lightning fast and I'd like to use it as my main driver until Eddie get's more stable. Kind regards Quote Share this post Link to post
Staff 10395 Posted ... 6 minutes ago, Maggie144 said: Side question; If one creates a ovpn-profile with a country (containing multiple Servers) is there any way for Hummingbird to automatically connect to the one with the lowest latency? Hello! Currently not, we're sorry. 7 minutes ago, Maggie144 said: thanks for the link - I managed to run Hummingbird alone, after some start-up issues (apparently only port 443 is supported, tried a config with 41185 at first and got It's the server that must listen to specific ports, it's not a client task. Maybe some server does not respond properly on port 41185, can you please give us the server(s) name(s)? 8 minutes ago, Maggie144 said: No strange disconnects until now. it's lightning fast and I'd like to use it as my main driver until Eddie get's more stable. Excellent! We're glad to know it. Stay tuned for future developments for macOS. Kind regards Quote Share this post Link to post
Maggie144 12 Posted ... 7 minutes ago, Staff said: It's the server that must listen to specific ports, it's not a client task. Maybe some server does not respond properly on port 41185, can you please give us the server(s) name(s)? The Server in question is Baiten_Swiss 1 Staff reacted to this Quote Share this post Link to post
Maggie144 12 Posted ... wtfismyip still says I'm in Switzerland - while I get these Errors (last 50 lines) on repeat Sat Jul 18 20:17:26.968 2020 System DNS 10.11.94.1 is now rejected by the network filter Sat Jul 18 21:17:26.063 2020 Tunnel Options:V4,dev-type tun,link-mtu 1558,tun-mtu 1500,proto UDPv4,comp-lzo,keydir 1,cipher AES-256-CBC,auth SHA1,keysize 256,tls-auth,key-method 2,tls-client Sat Jul 18 21:17:26.063 2020 Peer Info: IV_VER=3.6.4 AirVPN IV_PLAT=mac IV_NCP=2 IV_TCPNL=1 IV_PROTO=2 IV_CIPHERS=AES-256-GCM:AES-128-GCM:CHACHA20-POLY1305 IV_LZO_STUB=1 IV_COMP_STUB=1 IV_COMP_STUBv2=1 UV_IPV6=yes IV_GUI_VER=Hummingbird - AirVPN OpenVPN 3 Client 1.1.0 IV_HWADDR=18:65:90:d6:c1:dd IV_SSL=mbed TLS 2.16.6 Sat Jul 18 21:17:26.133 2020 VERIFY OK : depth=1 cert. version : 3 serial number : 8C:D8:43:EF:E4:5F:20:03 issuer name : C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org subject name : C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org issued on : 2014-04-11 10:15:45 expires on : 2024-04-08 10:15:45 signed using : RSA with SHA1 RSA key size : 4096 bits basic constraints : CA=true Sat Jul 18 21:17:26.133 2020 VERIFY OK : depth=0 cert. version : 3 serial number : 9C issuer name : C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org subject name : C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=Baiten, emailAddress=info@airvpn.org issued on : 2016-12-28 14:02:35 expires on : 2026-12-26 14:02:35 signed using : RSA with SHA-512 RSA key size : 4096 bits basic constraints : CA=false cert. type : SSL Server key usage : Digital Signature, Key Encipherment ext key usage : TLS Web Server Authentication Sat Jul 18 21:17:26.327 2020 ERROR: KEY_STATE_ERROR Sat Jul 18 21:17:26.357 2020 ERROR: KEY_STATE_ERROR Sat Jul 18 21:17:26.357 2020 ERROR: KEY_STATE_ERROR Sat Jul 18 21:17:28.325 2020 ERROR: KEY_STATE_ERROR Sat Jul 18 21:17:32.331 2020 ERROR: KEY_STATE_ERROR Sat Jul 18 21:17:40.331 2020 ERROR: KEY_STATE_ERROR Sat Jul 18 21:17:56.339 2020 ERROR: KEY_STATE_ERROR Sat Jul 18 21:18:26.300 2020 ERROR: KEV_NEGOTIATE_ERROR Sat Jul 18 21:18:26.300 2020 ERROR: HANDSHAKE_TIMEOUT Sat Jul 18 21:18:41.335 2020 ERROR: CC_ERROR Sat Jul 18 21:18:43.334 2020 ERROR: CC_ERROR Sat Jul 18 21:18:47.062 2020 ERROR: CC_ERROR Sat Jul 18 21:18:55.347 2020 ERROR: CC_ERROR Sat Jul 18 21:19:11.364 2020 ERROR: CC_ERROR Sat Jul 18 21:19:26.300 2020 ERROR: KEV_NEGOTIATE_ERROR Sat Jul 18 21:19:26.300 2020 ERROR: HANDSHAKE_TIMEOUT Sat Jul 18 21:19:56.352 2020 ERROR: CC_ERROR Sat Jul 18 21:19:58.352 2020 ERROR: CC_ERROR Sat Jul 18 21:20:02.357 2020 ERROR: CC_ERROR Sat Jul 18 21:20:10.362 2020 ERROR: CC_ERROR Sat Jul 18 21:20:26.302 2020 ERROR: KEV_NEGOTIATE_ERROR Sat Jul 18 21:20:26.302 2020 ERROR: HANDSHAKE_TIMEOUT Sat Jul 18 21:20:26.329 2020 ERROR: CC_ERROR Sat Jul 18 21:21:11.354 2020 ERROR: CC_ERROR Sat Jul 18 21:21:13.353 2020 ERROR: CC_ERROR Sat Jul 18 21:21:17.356 2020 ERROR: CC_ERROR Sat Jul 18 21:21:25.364 2020 ERROR: CC_ERROR Sat Jul 18 21:21:26.304 2020 ERROR: KEV_NEGOTIATE_ERROR Sat Jul 18 21:21:26.304 2020 ERROR: HANDSHAKE_TIMEOUT Sat Jul 18 21:21:41.346 2020 ERROR: CC_ERROR Sat Jul 18 21:22:26.097 2020 ERROR: CC_ERROR Sat Jul 18 21:22:26.304 2020 ERROR: KEV_NEGOTIATE_ERROR Sat Jul 18 21:22:26.304 2020 ERROR: HANDSHAKE_TIMEOUT Sat Jul 18 21:22:28.329 2020 ERROR: CC_ERROR Sat Jul 18 21:22:32.335 2020 ERROR: CC_ERROR Sat Jul 18 21:22:40.343 2020 ERROR: CC_ERROR Sat Jul 18 21:22:56.351 2020 ERROR: CC_ERROR Sat Jul 18 21:23:26.304 2020 ERROR: KEV_NEGOTIATE_ERROR Sat Jul 18 21:23:26.304 2020 ERROR: HANDSHAKE_TIMEOUT Sat Jul 18 21:23:41.339 2020 ERROR: CC_ERROR Sat Jul 18 21:23:43.343 2020 ERROR: CC_ERROR Sat Jul 18 21:23:47.343 2020 ERROR: CC_ERROR Sat Jul 18 21:23:55.345 2020 ERROR: CC_ERROR Sat Jul 18 21:24:11.355 2020 ERROR: CC_ERROR Sat Jul 18 21:24:26.304 2020 ERROR: KEV_NEGOTIATE_ERROR Sat Jul 18 21:24:26.304 2020 ERROR: HANDSHAKE_TIMEOUT Sat Jul 18 21:24:56.351 2020 ERROR: CC_ERROR Sat Jul 18 21:24:58.355 2020 ERROR: CC_ERROR Sat Jul 18 21:25:02.358 2020 ERROR: CC_ERROR Sat Jul 18 21:25:10.362 2020 ERROR: CC_ERROR Quote Share this post Link to post
Maggie144 12 Posted ... I didn't CTRL + C Hummingbird since there was no disconnect, the Error msgs continued until Sat Jul 18 22:15:26.341 2020 ERROR: KEV_NEGOTIATE_ERROR Sat Jul 18 22:15:26.341 2020 ERROR: HANDSHAKE_TIMEOUT Sat Jul 18 22:16:11.389 2020 ERROR: CC_ERROR Sat Jul 18 22:16:13.391 2020 ERROR: CC_ERROR Sat Jul 18 22:16:17.393 2020 ERROR: CC_ERROR Sat Jul 18 22:16:25.033 2020 ERROR: CC_ERROR Sat Jul 18 22:16:26.341 2020 ERROR: KEV_NEGOTIATE_ERROR Sat Jul 18 22:16:26.341 2020 ERROR: HANDSHAKE_TIMEOUT Sat Jul 18 22:16:41.059 2020 ERROR: CC_ERROR Sat Jul 18 22:17:26.178 2020 ERROR: CC_ERROR Sat Jul 18 22:17:26.212 2020 ERROR: N_KEV_EXPIRE Sat Jul 18 22:17:26.212 2020 ERROR: N_KEV_EXPIRE Sat Jul 18 22:17:26.341 2020 ERROR: KEV_NEGOTIATE_ERROR Sat Jul 18 22:17:26.341 2020 ERROR: HANDSHAKE_TIMEOUT Sat Jul 18 22:17:26.342 2020 Session invalidated: KEV_NEGOTIATE_ERROR Sat Jul 18 22:17:26.342 2020 Client terminated, restarting in 2000 ms... Sat Jul 18 22:17:26.368 2020 DSDict: updated Setup:/Network/Service/8CF1D2F5-D39B-412B-A093-F29779992684/DNS Sat Jul 18 22:17:26.368 2020 DSDict: removed State:/Network/Service/OpenVPNConnect/Info Sat Jul 18 22:17:26.368 2020 MacDNS: RESETDNS 19.6.0 *** DSDict State:/Network/Global/IPv4 ORIG { PrimaryInterface = en0; PrimaryService = "8CF1D2F5-D39B-412B-A093-F29779992684"; Router = "192.168.178.1"; } *** DSDict State:/Network/Service/OpenVPNConnect/Info ORIG { PrimaryService = "8CF1D2F5-D39B-412B-A093-F29779992684"; } *** DSDict State:/Network/Service/OpenVPNConnect/DNS ORIG { } *** DSDict Setup:/Network/Service/8CF1D2F5-D39B-412B-A093-F29779992684/DNS ORIG { OpenVPNConnectOrigSearchDomains = OpenVPNConnectDeleteValue; OpenVPNConnectOrigSearchOrder = OpenVPNConnectDeleteValue; OpenVPNConnectOrigServerAddresses = ( "10.11.94.1" ); SearchOrder = 5000; ServerAddresses = ( "10.11.88.1", "fde6:7a:7d20:758::1" ); } MODIFIED { ServerAddresses = ( "10.11.94.1" ); } Sat Jul 18 22:17:26.369 2020 /usr/bin/dscacheutil -flushcache Sat Jul 18 22:17:26.379 2020 /usr/bin/killall -HUP mDNSResponder Sat Jul 18 22:17:26.394 2020 DSDict: SCDynamicStoreNotifyValue Setup:/Network/Global/IPv4 Sat Jul 18 22:17:26.394 2020 /sbin/route delete -net 10.11.88.0 -netmask 255.255.255.0 10.11.88.151 delete net 10.11.88.0: gateway 10.11.88.151 /sbin/route delete -net -inet6 fde6:7a:7d20:758:: -prefixlen 64 -iface utun2 delete net fde6:7a:7d20:758::: gateway utun2 /sbin/route delete -net 185.156.175.50 -netmask 255.255.255.255 192.168.178.1 delete net 185.156.175.50: gateway 192.168.178.1 /sbin/route delete -net 0.0.0.0 -netmask 128.0.0.0 10.11.88.1 delete net 0.0.0.0: gateway 10.11.88.1 /sbin/route delete -net 128.0.0.0 -netmask 128.0.0.0 10.11.88.1 delete net 128.0.0.0: gateway 10.11.88.1 /sbin/route delete -net -inet6 :: -prefixlen 1 -iface utun2 delete net ::: gateway utun2 /sbin/route delete -net -inet6 8000:: -prefixlen 1 -iface utun2 delete net 8000::: gateway utun2 /sbin/ifconfig utun2 down MacDNSAction: FLAGS=F Sat Jul 18 22:17:28.341 2020 EVENT: RECONNECTING Sat Jul 18 22:17:28.344 2020 Successfully restored system DNS. No ALTQ support in kernel ALTQ related functions disabled rules cleared nat cleared dummynet cleared 0 tables deleted. 12 states cleared source tracking entries cleared pf: statistics cleared pf: interface flags reset pfctl: Use of -f option, could result in flushing of rules present in the main ruleset added by the system at startup. See /etc/pf.conf for further details. No ALTQ support in kernel ALTQ related functions disabled Sat Jul 18 22:17:28.363 2020 Network filter successfully restored Sat Jul 18 22:17:28.363 2020 ERROR: N_RECONNECT Sat Jul 18 22:17:28.363 2020 EVENT: RESOLVE Sat Jul 18 22:17:28.364 2020 Network filter and lock is using pf No ALTQ support in kernel ALTQ related functions disabled pfctl: pf already enabled Sat Jul 18 22:17:28.367 2020 Network filter successfully initialized Sat Jul 18 22:17:28.367 2020 Local IPv6 address fe80::1 Sat Jul 18 22:17:28.367 2020 Local IPv4 address 192.168.178.30 Sat Jul 18 22:17:28.367 2020 Local IPv6 address fe80::c23:38f5:2893:e67c Sat Jul 18 22:17:28.367 2020 Local IPv6 address 2a02:810d:340:75e0:1830:8061:8ae4:7112 Sat Jul 18 22:17:28.367 2020 Local IPv6 address 2a02:810d:340:75e0:9cbf:7143:f1e1:96b9 Sat Jul 18 22:17:28.367 2020 Local IPv6 address fe80::d438:27ff:fe31:79ae Sat Jul 18 22:17:28.367 2020 Local IPv6 address fe80::d438:27ff:fe31:79ae Sat Jul 18 22:17:28.367 2020 Local IPv6 address fe80::45a4:97d8:5c69:67d1 Sat Jul 18 22:17:28.368 2020 Local IPv6 address fe80::cafe:8a90:b36d:f71c Sat Jul 18 22:17:28.368 2020 Local interface gif0 Sat Jul 18 22:17:28.368 2020 Local interface stf0 Sat Jul 18 22:17:28.368 2020 Local interface en0 Sat Jul 18 22:17:28.368 2020 Local interface p2p0 Sat Jul 18 22:17:28.368 2020 Local interface awdl0 Sat Jul 18 22:17:28.368 2020 Local interface llw0 Sat Jul 18 22:17:28.368 2020 Local interface en1 Sat Jul 18 22:17:28.368 2020 Local interface en2 Sat Jul 18 22:17:28.368 2020 Local interface bridge0 Sat Jul 18 22:17:28.368 2020 Local interface utun0 Sat Jul 18 22:17:28.368 2020 Local interface utun1 Sat Jul 18 22:17:28.368 2020 Setting up network filter and lock Sat Jul 18 22:17:28.368 2020 Allowing system DNS 10.11.94.1 to pass through the network filter Sat Jul 18 22:17:28.368 2020 Adding IPv4 server 185.156.175.50 to network filter No ALTQ support in kernel ALTQ related functions disabled rules cleared nat cleared dummynet cleared 0 tables deleted. 0 states cleared source tracking entries cleared pf: statistics cleared pf: interface flags reset pfctl: Use of -f option, could result in flushing of rules present in the main ruleset added by the system at startup. See /etc/pf.conf for further details. No ALTQ support in kernel ALTQ related functions disabled Sat Jul 18 22:17:28.385 2020 Network filter and lock successfully activated Sat Jul 18 22:17:28.386 2020 Contacting 185.156.175.50:443 via UDP Sat Jul 18 22:17:28.386 2020 EVENT: WAIT Sat Jul 18 22:17:28.386 2020 Sat Jul 18 22:17:28.386 2020 Connecting to [185.156.175.50]:443 (185.156.175.50) via UDPv4 Sat Jul 18 22:17:28.411 2020 EVENT: CONNECTING Sat Jul 18 22:17:28.411 2020 Tunnel Options:V4,dev-type tun,link-mtu 1558,tun-mtu 1500,proto UDPv4,comp-lzo,keydir 1,cipher AES-256-CBC,auth SHA1,keysize 256,tls-auth,key-method 2,tls-client Sat Jul 18 22:17:28.411 2020 Peer Info: IV_VER=3.6.4 AirVPN IV_PLAT=mac IV_NCP=2 IV_TCPNL=1 IV_PROTO=2 IV_CIPHERS=AES-256-GCM:AES-128-GCM:CHACHA20-POLY1305 IV_LZO_STUB=1 IV_COMP_STUB=1 IV_COMP_STUBv2=1 UV_IPV6=yes IV_GUI_VER=Hummingbird - AirVPN OpenVPN 3 Client 1.1.0 IV_HWADDR=18:65:90:d6:c1:dd IV_SSL=mbed TLS 2.16.6 Sat Jul 18 22:17:28.490 2020 VERIFY OK : depth=1 cert. version : 3 serial number : 8C:D8:43:EF:E4:5F:20:03 issuer name : C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org subject name : C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org issued on : 2014-04-11 10:15:45 expires on : 2024-04-08 10:15:45 signed using : RSA with SHA1 RSA key size : 4096 bits basic constraints : CA=true Sat Jul 18 22:17:28.490 2020 VERIFY OK : depth=0 cert. version : 3 serial number : 9C issuer name : C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org subject name : C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=Baiten, emailAddress=info@airvpn.org issued on : 2016-12-28 14:02:35 expires on : 2026-12-26 14:02:35 signed using : RSA with SHA-512 RSA key size : 4096 bits basic constraints : CA=false cert. type : SSL Server key usage : Digital Signature, Key Encipherment ext key usage : TLS Web Server Authentication Sat Jul 18 22:17:28.744 2020 SSL Handshake: TLSv1.2/TLS-DHE-RSA-WITH-AES-256-GCM-SHA384 Sat Jul 18 22:17:28.744 2020 Session is ACTIVE Sat Jul 18 22:17:28.744 2020 EVENT: GET_CONFIG Sat Jul 18 22:17:28.745 2020 Sending PUSH_REQUEST to server... Sat Jul 18 22:17:28.882 2020 OPTIONS: 0 [comp-lzo] [no] 1 [redirect-gateway] [ipv6] [def1] [bypass-dhcp] 2 [dhcp-option] [DNS] [10.11.88.1] 3 [dhcp-option] [DNS6] [fde6:7a:7d20:758::1] 4 [tun-ipv6] 5 [route-gateway] [10.11.88.1] 6 [topology] [subnet] 7 [ping] [10] 8 [ping-restart] [60] 9 [ifconfig-ipv6] [fde6:7a:7d20:758::1096/64] [fde6:7a:7d20:758::1] 10 [ifconfig] [10.11.88.152] [255.255.255.0] 11 [peer-id] [8] 12 [cipher] [AES-256-GCM] Sat Jul 18 22:17:28.882 2020 PROTOCOL OPTIONS: cipher: AES-256-GCM digest: NONE ncp enabled: yes compress: LZO_STUB peer ID: 8 Sat Jul 18 22:17:28.883 2020 EVENT: ASSIGN_IP Sat Jul 18 22:17:28.883 2020 VPN Server has pushed IPv4 DNS server 10.11.88.1 No ALTQ support in kernel ALTQ related functions disabled nat cleared No ALTQ support in kernel ALTQ related functions disabled No ALTQ support in kernel ALTQ related functions disabled rules cleared No ALTQ support in kernel ALTQ related functions disabled 0 tables deleted. pfctl: Use of -f option, could result in flushing of rules present in the main ruleset added by the system at startup. See /etc/pf.conf for further details. No ALTQ support in kernel ALTQ related functions disabled Sat Jul 18 22:17:28.913 2020 VPN Server has pushed IPv6 DNS server fde6:7a:7d20:758::1 No ALTQ support in kernel ALTQ related functions disabled nat cleared No ALTQ support in kernel ALTQ related functions disabled No ALTQ support in kernel ALTQ related functions disabled rules cleared No ALTQ support in kernel ALTQ related functions disabled 0 tables deleted. pfctl: Use of -f option, could result in flushing of rules present in the main ruleset added by the system at startup. See /etc/pf.conf for further details. No ALTQ support in kernel ALTQ related functions disabled ERROR: cannot detect IPv6 default gateway /sbin/ifconfig utun2 down /sbin/ifconfig utun2 10.11.88.152 10.11.88.1 netmask 255.255.255.0 mtu 1500 up /sbin/route add -net 10.11.88.0 -netmask 255.255.255.0 10.11.88.152 add net 10.11.88.0: gateway 10.11.88.152 /sbin/ifconfig utun2 inet6 fde6:7a:7d20:758::1096/64 up /sbin/route add -net -inet6 fde6:7a:7d20:758:: -prefixlen 64 -iface utun2 route: writing to routing socket: File exists add net fde6:7a:7d20:758::: gateway utun2: File exists /sbin/route add -net 185.156.175.50 -netmask 255.255.255.255 192.168.178.1 add net 185.156.175.50: gateway 192.168.178.1 /sbin/route add -net 0.0.0.0 -netmask 128.0.0.0 10.11.88.1 add net 0.0.0.0: gateway 10.11.88.1 /sbin/route add -net 128.0.0.0 -netmask 128.0.0.0 10.11.88.1 add net 128.0.0.0: gateway 10.11.88.1 /sbin/route add -net -inet6 :: -prefixlen 1 -iface utun2 add net ::: gateway utun2 /sbin/route add -net -inet6 8000:: -prefixlen 1 -iface utun2 add net 8000::: gateway utun2 MacDNSAction: FLAGS=F RD=1 SO=5000 DNS=10.11.88.1,fde6:7a:7d20:758::1,10.11.88.1,fde6:7a:7d20:758::1 DOM= ADS= Sat Jul 18 22:17:28.971 2020 DSDict: updated Setup:/Network/Service/8CF1D2F5-D39B-412B-A093-F29779992684/DNS Sat Jul 18 22:17:28.972 2020 DSDict: updated State:/Network/Service/OpenVPNConnect/Info Sat Jul 18 22:17:28.972 2020 MacDNS: SETDNS 19.6.0 *** DSDict State:/Network/Global/IPv4 ORIG { PrimaryInterface = en0; PrimaryService = "8CF1D2F5-D39B-412B-A093-F29779992684"; Router = "192.168.178.1"; } *** DSDict State:/Network/Service/OpenVPNConnect/Info ORIG { } MODIFIED { PrimaryService = "8CF1D2F5-D39B-412B-A093-F29779992684"; } *** DSDict State:/Network/Service/OpenVPNConnect/DNS ORIG { } *** DSDict Setup:/Network/Service/8CF1D2F5-D39B-412B-A093-F29779992684/DNS ORIG { ServerAddresses = ( "10.11.94.1" ); } MODIFIED { OpenVPNConnectOrigSearchDomains = OpenVPNConnectDeleteValue; OpenVPNConnectOrigSearchOrder = OpenVPNConnectDeleteValue; OpenVPNConnectOrigServerAddresses = ( "10.11.94.1" ); SearchOrder = 5000; ServerAddresses = ( "10.11.88.1", "fde6:7a:7d20:758::1", "10.11.88.1", "fde6:7a:7d20:758::1" ); } Sat Jul 18 22:17:28.972 2020 /usr/bin/dscacheutil -flushcache Sat Jul 18 22:17:28.981 2020 /usr/bin/killall -HUP mDNSResponder Sat Jul 18 22:17:28.994 2020 DSDict: SCDynamicStoreNotifyValue Setup:/Network/Global/IPv4 open utun2 SUCCEEDED Sat Jul 18 22:17:28.994 2020 Connected via tun Sat Jul 18 22:17:28.995 2020 LZO-ASYM init swap=0 asym=1 Sat Jul 18 22:17:28.995 2020 Comp-stub init swap=0 Sat Jul 18 22:17:28.995 2020 EVENT: CONNECTED 185.156.175.50:443 (185.156.175.50) via /UDPv4 on tun/10.11.88.152/fde6:7a:7d20:758::1096 gw=[10.11.88.1/fde6:7a:7d20:758::1] Sat Jul 18 22:17:28.995 2020 Server has pushed its own DNS. Removing system DNS from network filter. No ALTQ support in kernel ALTQ related functions disabled nat cleared No ALTQ support in kernel ALTQ related functions disabled No ALTQ support in kernel ALTQ related functions disabled rules cleared No ALTQ support in kernel ALTQ related functions disabled 0 tables deleted. pfctl: Use of -f option, could result in flushing of rules present in the main ruleset added by the system at startup. See /etc/pf.conf for further details. No ALTQ support in kernel ALTQ related functions disabled Sat Jul 18 22:17:29.022 2020 System DNS 10.11.94.1 is now rejected by the network filter That's when the connection was broken and I had to abort to reconnect - here are the resulting stats STATS: BYTES_IN : 10473829 BYTES_OUT : 1638725 PACKETS_IN : 13791 PACKETS_OUT : 16906 TUN_BYTES_IN : 1195500 TUN_BYTES_OUT : 10164704 TUN_PACKETS_IN : 13202 TUN_PACKETS_OUT : 13445 CC_ERROR : 236 HANDSHAKE_TIMEOUT : 60 N_RECONNECT : 1 KEY_STATE_ERROR : 7 KEV_NEGOTIATE_ERROR : 60 N_KEV_EXPIRE : 2 T Quote Share this post Link to post
Staff 10395 Posted ... @Maggie144 Hello! Is reneg-sec 1000 (or something similar) included in your profile? Kind regards Quote Share this post Link to post
Maggie144 12 Posted ... Forgot it by the time I created the profile.. Today I created some new - with the custom directive - and now there is no disconnect happening for over 7h. Re-Negotiating a new Handshake every 1000s seems to do the trick. Thank you. Sporadically the Error N_KEV_EXPIRE does show up, nevertheless Sun Jul 19 14:59:43.299 2020 SSL Handshake: TLSv1.2/TLS-DHE-RSA-WITH-AES-256-GCM-SHA384 Sun Jul 19 14:59:43.300 2020 LZO-ASYM init swap=0 asym=1 Sun Jul 19 14:59:43.300 2020 Comp-stub init swap=0 Sun Jul 19 15:16:22.952 2020 ERROR: N_KEV_EXPIRE Sun Jul 19 15:16:22.976 2020 Tunnel Options:V4,dev-type tun,link-mtu 1558,tun-mtu 1500,proto UDPv4,comp-lzo,keydir 1,cipher AES-256-CBC,auth SHA1,keysize 256,tls-auth,key-method 2,tls-client Sun Jul 19 15:16:22.976 2020 Peer Info: IV_VER=3.6.4 AirVPN IV_PLAT=mac IV_NCP=2 IV_TCPNL=1 IV_PROTO=2 IV_CIPHERS=AES-256-GCM:AES-128-GCM:CHACHA20-POLY1305 IV_LZO_STUB=1 IV_COMP_STUB=1 IV_COMP_STUBv2=1 UV_IPV6=yes IV_GUI_VER=Hummingbird - AirVPN OpenVPN 3 Client 1.1.0 IV_HWADDR=18:65:90:d6:c1:dd IV_SSL=mbed TLS 2.16.6 Sun Jul 19 15:16:23.039 2020 VERIFY OK : depth=1 cert. version : 3 serial number : 8C:D8:43:EF:E4:5F:20:03 issuer name : C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org subject name : C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org issued on : 2014-04-11 10:15:45 expires on : 2024-04-08 10:15:45 signed using : RSA with SHA1 RSA key size : 4096 bits basic constraints : CA=true Sun Jul 19 15:16:23.039 2020 VERIFY OK : depth=0 cert. version : 3 serial number : 01:30 issuer name : C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org subject name : C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=Achernar, emailAddress=info@airvpn.org issued on : 2016-12-28 14:55:42 expires on : 2026-12-26 14:55:42 signed using : RSA with SHA-512 RSA key size : 4096 bits basic constraints : CA=false cert. type : SSL Server key usage : Digital Signature, Key Encipherment ext key usage : TLS Web Server Authentication Sun Jul 19 15:16:23.300 2020 SSL Handshake: TLSv1.2/TLS-DHE-RSA-WITH-AES-256-GCM-SHA384 Sun Jul 19 15:16:23.301 2020 LZO-ASYM init swap=0 asym=1 Sun Jul 19 15:16:23.301 2020 Comp-stub init swap=0 Sun Jul 19 15:33:02.978 2020 Tunnel Options:V4,dev-type tun,link-mtu 1558,tun-mtu 1500,proto UDPv4,comp-lzo,keydir 1,cipher AES-256-CBC,auth SHA1,keysize 256,tls-auth,key-method 2,tls-client Sun Jul 19 15:33:02.979 2020 Peer Info: IV_VER=3.6.4 AirVPN IV_PLAT=mac IV_NCP=2 IV_TCPNL=1 IV_PROTO=2 IV_CIPHERS=AES-256-GCM:AES-128-GCM:CHACHA20-POLY1305 IV_LZO_STUB=1 IV_COMP_STUB=1 IV_COMP_STUBv2=1 UV_IPV6=yes IV_GUI_VER=Hummingbird - AirVPN OpenVPN 3 Client 1.1.0 IV_HWADDR=18:65:90:d6:c1:dd IV_SSL=mbed TLS 2.16.6 Sun Jul 19 15:33:03.061 2020 VERIFY OK : depth=1 cert. version : 3 serial number : 8C:D8:43:EF:E4:5F:20:03 issuer name : C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org subject name : C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org issued on : 2014-04-11 10:15:45 expires on : 2024-04-08 10:15:45 signed using : RSA with SHA1 RSA key size : 4096 bits basic constraints : CA=true Sun Jul 19 15:33:03.062 2020 VERIFY OK : depth=0 cert. version : 3 serial number : 01:30 issuer name : C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org subject name : C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=Achernar, emailAddress=info@airvpn.org issued on : 2016-12-28 14:55:42 expires on : 2026-12-26 14:55:42 signed using : RSA with SHA-512 RSA key size : 4096 bits basic constraints : CA=false cert. type : SSL Server key usage : Digital Signature, Key Encipherment ext key usage : TLS Web Server Authentication Sun Jul 19 15:33:03.324 2020 SSL Handshake: TLSv1.2/TLS-DHE-RSA-WITH-AES-256-GCM-SHA384 Sun Jul 19 15:33:03.324 2020 LZO-ASYM init swap=0 asym=1 Sun Jul 19 15:33:03.324 2020 Comp-stub init swap=0 Sun Jul 19 15:49:42.980 2020 Tunnel Options:V4,dev-type tun,link-mtu 1558,tun-mtu 1500,proto UDPv4,comp-lzo,keydir 1,cipher AES-256-CBC,auth SHA1,keysize 256,tls-auth,key-method 2,tls-client Sun Jul 19 15:49:42.980 2020 Peer Info: IV_VER=3.6.4 AirVPN IV_PLAT=mac IV_NCP=2 IV_TCPNL=1 IV_PROTO=2 IV_CIPHERS=AES-256-GCM:AES-128-GCM:CHACHA20-POLY1305 IV_LZO_STUB=1 IV_COMP_STUB=1 IV_COMP_STUBv2=1 UV_IPV6=yes IV_GUI_VER=Hummingbird - AirVPN OpenVPN 3 Client 1.1.0 IV_HWADDR=18:65:90:d6:c1:dd IV_SSL=mbed TLS 2.16.6 Sun Jul 19 15:49:43.059 2020 VERIFY OK : depth=1 cert. version : 3 serial number : 8C:D8:43:EF:E4:5F:20:03 issuer name : C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org subject name : C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org issued on : 2014-04-11 10:15:45 expires on : 2024-04-08 10:15:45 signed using : RSA with SHA1 RSA key size : 4096 bits basic constraints : CA=true Sun Jul 19 15:49:43.059 2020 VERIFY OK : depth=0 cert. version : 3 serial number : 01:30 issuer name : C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org subject name : C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=Achernar, emailAddress=info@airvpn.org issued on : 2016-12-28 14:55:42 expires on : 2026-12-26 14:55:42 signed using : RSA with SHA-512 RSA key size : 4096 bits basic constraints : CA=false cert. type : SSL Server key usage : Digital Signature, Key Encipherment ext key usage : TLS Web Server Authentication Sun Jul 19 15:49:43.336 2020 SSL Handshake: TLSv1.2/TLS-DHE-RSA-WITH-AES-256-GCM-SHA384 Sun Jul 19 15:49:43.337 2020 LZO-ASYM init swap=0 asym=1 Sun Jul 19 15:49:43.337 2020 Comp-stub init swap=0 Sun Jul 19 16:06:22.952 2020 ERROR: N_KEV_EXPIRE Sun Jul 19 16:06:22.983 2020 Tunnel Options:V4,dev-type tun,link-mtu 1558,tun-mtu 1500,proto UDPv4,comp-lzo,keydir 1,cipher AES-256-CBC,auth SHA1,keysize 256,tls-auth,key-method 2,tls-client Sun Jul 19 16:06:22.983 2020 Peer Info: IV_VER=3.6.4 AirVPN IV_PLAT=mac IV_NCP=2 IV_TCPNL=1 IV_PROTO=2 IV_CIPHERS=AES-256-GCM:AES-128-GCM:CHACHA20-POLY1305 IV_LZO_STUB=1 IV_COMP_STUB=1 IV_COMP_STUBv2=1 UV_IPV6=yes IV_GUI_VER=Hummingbird - AirVPN OpenVPN 3 Client 1.1.0 IV_HWADDR=18:65:90:d6:c1:dd IV_SSL=mbed TLS 2.16.6 Sun Jul 19 16:06:23.053 2020 VERIFY OK : depth=1 cert. version : 3 serial number : 8C:D8:43:EF:E4:5F:20:03 issuer name : C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org subject name : C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org issued on : 2014-04-11 10:15:45 expires on : 2024-04-08 10:15:45 signed using : RSA with SHA1 RSA key size : 4096 bits basic constraints : CA=true Sun Jul 19 16:06:23.053 2020 VERIFY OK : depth=0 cert. version : 3 serial number : 01:30 issuer name : C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org subject name : C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=Achernar, emailAddress=info@airvpn.org issued on : 2016-12-28 14:55:42 expires on : 2026-12-26 14:55:42 signed using : RSA with SHA-512 RSA key size : 4096 bits basic constraints : CA=false cert. type : SSL Server key usage : Digital Signature, Key Encipherment ext key usage : TLS Web Server Authentication Sun Jul 19 16:06:23.307 2020 SSL Handshake: TLSv1.2/TLS-DHE-RSA-WITH-AES-256-GCM-SHA384 Sun Jul 19 16:06:23.307 2020 LZO-ASYM init swap=0 asym=1 Sun Jul 19 16:06:23.307 2020 Comp-stub init swap=0 Sun Jul 19 16:23:02.954 2020 ERROR: N_KEV_EXPIRE Sun Jul 19 16:23:02.987 2020 Tunnel Options:V4,dev-type tun,link-mtu 1558,tun-mtu 1500,proto UDPv4,comp-lzo,keydir 1,cipher AES-256-CBC,auth SHA1,keysize 256,tls-auth,key-method 2,tls-client Sun Jul 19 16:23:02.987 2020 Peer Info: IV_VER=3.6.4 AirVPN IV_PLAT=mac IV_NCP=2 IV_TCPNL=1 IV_PROTO=2 IV_CIPHERS=AES-256-GCM:AES-128-GCM:CHACHA20-POLY1305 IV_LZO_STUB=1 IV_COMP_STUB=1 IV_COMP_STUBv2=1 UV_IPV6=yes IV_GUI_VER=Hummingbird - AirVPN OpenVPN 3 Client 1.1.0 IV_HWADDR=18:65:90:d6:c1:dd IV_SSL=mbed TLS 2.16.6 Sun Jul 19 16:23:03.051 2020 VERIFY OK : depth=1 cert. version : 3 serial number : 8C:D8:43:EF:E4:5F:20:03 issuer name : C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org subject name : C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org issued on : 2014-04-11 10:15:45 expires on : 2024-04-08 10:15:45 signed using : RSA with SHA1 RSA key size : 4096 bits basic constraints : CA=true Sun Jul 19 16:23:03.051 2020 VERIFY OK : depth=0 cert. version : 3 serial number : 01:30 issuer name : C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org subject name : C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=Achernar, emailAddress=info@airvpn.org issued on : 2016-12-28 14:55:42 expires on : 2026-12-26 14:55:42 signed using : RSA with SHA-512 RSA key size : 4096 bits basic constraints : CA=false cert. type : SSL Server key usage : Digital Signature, Key Encipherment ext key usage : TLS Web Server Authentication Sun Jul 19 16:23:03.297 2020 SSL Handshake: TLSv1.2/TLS-DHE-RSA-WITH-AES-256-GCM-SHA384 Sun Jul 19 16:23:03.298 2020 LZO-ASYM init swap=0 asym=1 Sun Jul 19 16:23:03.298 2020 Comp-stub init swap=0 Sun Jul 19 16:39:42.985 2020 Tunnel Options:V4,dev-type tun,link-mtu 1558,tun-mtu 1500,proto UDPv4,comp-lzo,keydir 1,cipher AES-256-CBC,auth SHA1,keysize 256,tls-auth,key-method 2,tls-client Sun Jul 19 16:39:42.986 2020 Peer Info: IV_VER=3.6.4 AirVPN IV_PLAT=mac IV_NCP=2 IV_TCPNL=1 IV_PROTO=2 IV_CIPHERS=AES-256-GCM:AES-128-GCM:CHACHA20-POLY1305 IV_LZO_STUB=1 IV_COMP_STUB=1 IV_COMP_STUBv2=1 UV_IPV6=yes IV_GUI_VER=Hummingbird - AirVPN OpenVPN 3 Client 1.1.0 IV_HWADDR=18:65:90:d6:c1:dd IV_SSL=mbed TLS 2.16.6 Sun Jul 19 16:39:43.049 2020 VERIFY OK : depth=1 cert. version : 3 serial number : 8C:D8:43:EF:E4:5F:20:03 issuer name : C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org subject name : C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org issued on : 2014-04-11 10:15:45 expires on : 2024-04-08 10:15:45 signed using : RSA with SHA1 RSA key size : 4096 bits basic constraints : CA=true Sun Jul 19 16:39:43.049 2020 VERIFY OK : depth=0 cert. version : 3 serial number : 01:30 issuer name : C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org subject name : C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=Achernar, emailAddress=info@airvpn.org issued on : 2016-12-28 14:55:42 expires on : 2026-12-26 14:55:42 signed using : RSA with SHA-512 RSA key size : 4096 bits basic constraints : CA=false cert. type : SSL Server key usage : Digital Signature, Key Encipherment ext key usage : TLS Web Server Authentication Sun Jul 19 16:39:43.306 2020 SSL Handshake: TLSv1.2/TLS-DHE-RSA-WITH-AES-256-GCM-SHA384 Sun Jul 19 16:39:43.307 2020 LZO-ASYM init swap=0 asym=1 Sun Jul 19 16:39:43.307 2020 Comp-stub init swap=0 Sun Jul 19 16:56:22.956 2020 ERROR: N_KEV_EXPIRE Sun Jul 19 16:56:22.990 2020 Tunnel Options:V4,dev-type tun,link-mtu 1558,tun-mtu 1500,proto UDPv4,comp-lzo,keydir 1,cipher AES-256-CBC,auth SHA1,keysize 256,tls-auth,key-method 2,tls-client Sun Jul 19 16:56:22.990 2020 Peer Info: IV_VER=3.6.4 AirVPN IV_PLAT=mac IV_NCP=2 IV_TCPNL=1 IV_PROTO=2 IV_CIPHERS=AES-256-GCM:AES-128-GCM:CHACHA20-POLY1305 IV_LZO_STUB=1 IV_COMP_STUB=1 IV_COMP_STUBv2=1 UV_IPV6=yes IV_GUI_VER=Hummingbird - AirVPN OpenVPN 3 Client 1.1.0 IV_HWADDR=18:65:90:d6:c1:dd IV_SSL=mbed TLS 2.16.6 Sun Jul 19 16:56:23.054 2020 VERIFY OK : depth=1 cert. version : 3 serial number : 8C:D8:43:EF:E4:5F:20:03 issuer name : C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org subject name : C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org issued on : 2014-04-11 10:15:45 expires on : 2024-04-08 10:15:45 signed using : RSA with SHA1 RSA key size : 4096 bits basic constraints : CA=true Sun Jul 19 16:56:23.055 2020 VERIFY OK : depth=0 cert. version : 3 serial number : 01:30 issuer name : C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org subject name : C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=Achernar, emailAddress=info@airvpn.org issued on : 2016-12-28 14:55:42 expires on : 2026-12-26 14:55:42 signed using : RSA with SHA-512 RSA key size : 4096 bits basic constraints : CA=false cert. type : SSL Server key usage : Digital Signature, Key Encipherment ext key usage : TLS Web Server Authentication Sun Jul 19 16:56:23.308 2020 SSL Handshake: TLSv1.2/TLS-DHE-RSA-WITH-AES-256-GCM-SHA384 Sun Jul 19 16:56:23.308 2020 LZO-ASYM init swap=0 asym=1 Sun Jul 19 16:56:23.308 2020 Comp-stub init swap=0 Quote Share this post Link to post
Maggie144 12 Posted ... Still using the ovpn-profiles with reneg-sec 1000, but the time until I encounter a disruptive connection KEY_STATE_ERROR is between a few hours to max 23h Quote Share this post Link to post
Staff 10395 Posted ... @Maggie144 Hello! If it's a generic line problem you should see the same disconnections (even though with different error message, possibly) with OpenVPN 2. Can you please test for a discernment? If the connection is stable with OpenVPN 2 (you should keep it active more than 23 hours) we can safely assume that the problem is OpenVPN3-AirVPN related. Kind regards Quote Share this post Link to post
Maggie144 12 Posted ... The last 72h there was no KEY_STATE_ERROR - so no forced disconnect on my side. Really glad, I do enjoy the lightning speed of v3 1 Staff reacted to this Quote Share this post Link to post
Maggie144 12 Posted ... I noticed some new lines in log - the connection was not disturbed, ipleak.net confirms no leaks - just curious what that is about Sun Aug 9 07:58:07.153 2020 SSL Handshake: TLSv1.2/TLS-DHE-RSA-WITH-AES-256-GCM-SHA384 Sun Aug 9 07:58:07.154 2020 LZO-ASYM init swap=0 asym=1 Sun Aug 9 07:58:07.154 2020 Comp-stub init swap=0 Sun Aug 9 07:59:50.346 2020 UDP send exception: send: No buffer space available Sun Aug 9 07:59:50.346 2020 ERROR: NETWORK_SEND_ERROR Sun Aug 9 08:11:47.524 2020 UDP send exception: send: No buffer space available Sun Aug 9 08:11:47.524 2020 ERROR: NETWORK_SEND_ERROR Sun Aug 9 08:11:47.626 2020 UDP send exception: send: No buffer space available Sun Aug 9 08:11:47.626 2020 ERROR: NETWORK_SEND_ERROR Sun Aug 9 08:14:46.964 2020 Tunnel Options:V4,dev-type tun,link-mtu 1558,tun-mtu 1500,proto UDPv4,comp-lzo,keydir 1,cipher AES-256-CBC,auth SHA1,keysize 256,tls-auth,key-method 2,tls-client Sun Aug 9 08:14:46.965 2020 Peer Info: IV_VER=3.6.4 AirVPN IV_PLAT=mac IV_NCP=2 IV_TCPNL=1 IV_PROTO=2 IV_CIPHERS=AES-256-GCM:AES-128-GCM:CHACHA20-POLY1305 IV_LZO_STUB=1 IV_COMP_STUB=1 IV_COMP_STUBv2=1 UV_IPV6=yes IV_GUI_VER=Hummingbird - AirVPN OpenVPN 3 Client 1.1.0 IV_HWADDR=18:65:90:d6:c1:dd IV_SSL=mbed TLS 2.16.6 Sun Aug 9 08:14:47.061 2020 VERIFY OK : depth=1 cert. version : 3 serial number : 8C:D8:43:EF:E4:5F:20:03 issuer name : C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org subject name : C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org issued on : 2014-04-11 10:15:45 expires on : 2024-04-08 10:15:45 signed using : RSA with SHA1 RSA key size : 4096 bits basic constraints : CA=true Sun Aug 9 08:14:47.061 2020 VERIFY OK : depth=0 cert. version : 3 serial number : 01:30 issuer name : C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org subject name : C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=Achernar, emailAddress=info@airvpn.org issued on : 2016-12-28 14:55:42 expires on : 2026-12-26 14:55:42 signed using : RSA with SHA-512 RSA key size : 4096 bits basic constraints : CA=false cert. type : SSL Server key usage : Digital Signature, Key Encipherment ext key usage : TLS Web Server Authentication Sun Aug 9 08:14:47.379 2020 SSL Handshake: TLSv1.2/TLS-DHE-RSA-WITH-AES-256-GCM-SHA384 Sun Aug 9 08:14:47.380 2020 LZO-ASYM init swap=0 asym=1 Sun Aug 9 08:14:47.380 2020 Comp-stub init swap=0 Sun Aug 9 08:31:26.808 2020 Tunnel Options:V4,dev-type tun,link-mtu 1558,tun-mtu 1500,proto UDPv4,comp-lzo,keydir 1,cipher AES-256-CBC,auth SHA1,keysize 256,tls-auth,key-method 2,tls-client Sun Aug 9 08:31:26.808 2020 Peer Info: IV_VER=3.6.4 AirVPN IV_PLAT=mac IV_NCP=2 IV_TCPNL=1 IV_PROTO=2 IV_CIPHERS=AES-256-GCM:AES-128-GCM:CHACHA20-POLY1305 IV_LZO_STUB=1 IV_COMP_STUB=1 IV_COMP_STUBv2=1 UV_IPV6=yes IV_GUI_VER=Hummingbird - AirVPN OpenVPN 3 Client 1.1.0 IV_HWADDR=18:65:90:d6:c1:dd IV_SSL=mbed TLS 2.16.6 Sun Aug 9 08:31:26.892 2020 VERIFY OK : depth=1 cert. version : 3 serial number : 8C:D8:43:EF:E4:5F:20:03 issuer name : C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org subject name : C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org issued on : 2014-04-11 10:15:45 expires on : 2024-04-08 10:15:45 signed using : RSA with SHA1 RSA key size : 4096 bits basic constraints : CA=true Sun Aug 9 08:31:26.893 2020 VERIFY OK : depth=0 cert. version : 3 serial number : 01:30 issuer name : C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org subject name : C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=Achernar, emailAddress=info@airvpn.org issued on : 2016-12-28 14:55:42 expires on : 2026-12-26 14:55:42 signed using : RSA with SHA-512 RSA key size : 4096 bits basic constraints : CA=false cert. type : SSL Server key usage : Digital Signature, Key Encipherment ext key usage : TLS Web Server Authentication Sun Aug 9 08:31:27.350 2020 SSL Handshake: TLSv1.2/TLS-DHE-RSA-WITH-AES-256-GCM-SHA384 Sun Aug 9 08:31:27.350 2020 LZO-ASYM init swap=0 asym=1 Sun Aug 9 08:31:27.350 2020 Comp-stub init swap=0 Sun Aug 9 08:48:06.900 2020 Tunnel Options:V4,dev-type tun,link-mtu 1558,tun-mtu 1500,proto UDPv4,comp-lzo,keydir 1,cipher AES-256-CBC,auth SHA1,keysize 256,tls-auth,key-method 2,tls-client Sun Aug 9 08:48:06.901 2020 Peer Info: IV_VER=3.6.4 AirVPN IV_PLAT=mac IV_NCP=2 IV_TCPNL=1 IV_PROTO=2 IV_CIPHERS=AES-256-GCM:AES-128-GCM:CHACHA20-POLY1305 IV_LZO_STUB=1 IV_COMP_STUB=1 IV_COMP_STUBv2=1 UV_IPV6=yes IV_GUI_VER=Hummingbird - AirVPN OpenVPN 3 Client 1.1.0 IV_HWADDR=18:65:90:d6:c1:dd IV_SSL=mbed TLS 2.16.6 Sun Aug 9 08:48:06.977 2020 VERIFY OK : depth=1 cert. version : 3 serial number : 8C:D8:43:EF:E4:5F:20:03 issuer name : C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org subject name : C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org issued on : 2014-04-11 10:15:45 expires on : 2024-04-08 10:15:45 signed using : RSA with SHA1 RSA key size : 4096 bits basic constraints : CA=true Sun Aug 9 08:48:06.977 2020 VERIFY OK : depth=0 cert. version : 3 serial number : 01:30 issuer name : C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org subject name : C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=Achernar, emailAddress=info@airvpn.org issued on : 2016-12-28 14:55:42 expires on : 2026-12-26 14:55:42 signed using : RSA with SHA-512 RSA key size : 4096 bits basic constraints : CA=false cert. type : SSL Server key usage : Digital Signature, Key Encipherment ext key usage : TLS Web Server Authentication Sun Aug 9 08:48:07.233 2020 SSL Handshake: TLSv1.2/TLS-DHE-RSA-WITH-AES-256-GCM-SHA384 Sun Aug 9 08:48:07.233 2020 LZO-ASYM init swap=0 asym=1 Sun Aug 9 08:48:07.233 2020 Comp-stub init swap=0 Sun Aug 9 08:52:06.629 2020 UDP send exception: send: No buffer space available Sun Aug 9 08:52:06.629 2020 ERROR: NETWORK_SEND_ERROR Sun Aug 9 08:52:06.629 2020 UDP send exception: send: No buffer space available Sun Aug 9 08:52:06.629 2020 ERROR: NETWORK_SEND_ERROR Sun Aug 9 08:52:06.629 2020 UDP send exception: send: No buffer space available Sun Aug 9 08:52:06.629 2020 ERROR: NETWORK_SEND_ERROR Sun Aug 9 08:52:06.629 2020 UDP send exception: send: No buffer space available Sun Aug 9 08:52:06.629 2020 ERROR: NETWORK_SEND_ERROR Sun Aug 9 08:52:06.629 2020 UDP send exception: send: No buffer space available Sun Aug 9 08:52:06.629 2020 ERROR: NETWORK_SEND_ERROR Sun Aug 9 08:52:06.629 2020 UDP send exception: send: No buffer space available Sun Aug 9 08:52:06.630 2020 ERROR: NETWORK_SEND_ERROR Sun Aug 9 08:52:06.630 2020 UDP send exception: send: No buffer space available Sun Aug 9 08:52:06.630 2020 ERROR: NETWORK_SEND_ERROR Sun Aug 9 08:52:06.630 2020 UDP send exception: send: No buffer space available Sun Aug 9 08:52:06.630 2020 ERROR: NETWORK_SEND_ERROR Sun Aug 9 08:52:06.630 2020 UDP send exception: send: No buffer space available Sun Aug 9 08:52:06.630 2020 ERROR: NETWORK_SEND_ERROR Sun Aug 9 08:52:06.630 2020 UDP send exception: send: No buffer space available Sun Aug 9 08:52:06.630 2020 ERROR: NETWORK_SEND_ERROR Sun Aug 9 08:52:06.630 2020 UDP send exception: send: No buffer space available Sun Aug 9 08:52:06.630 2020 ERROR: NETWORK_SEND_ERROR Sun Aug 9 08:52:06.630 2020 UDP send exception: send: No buffer space available Sun Aug 9 08:52:06.630 2020 ERROR: NETWORK_SEND_ERROR Sun Aug 9 08:52:06.630 2020 UDP send exception: send: No buffer space available Sun Aug 9 08:52:06.630 2020 ERROR: NETWORK_SEND_ERROR Sun Aug 9 08:52:06.630 2020 UDP send exception: send: No buffer space available Sun Aug 9 08:52:06.630 2020 ERROR: NETWORK_SEND_ERROR Sun Aug 9 08:58:37.731 2020 UDP send exception: send: No buffer space available Sun Aug 9 08:58:37.731 2020 ERROR: NETWORK_SEND_ERROR Sun Aug 9 08:58:37.731 2020 UDP send exception: send: No buffer space available Sun Aug 9 08:58:37.731 2020 ERROR: NETWORK_SEND_ERROR Sun Aug 9 08:58:37.731 2020 UDP send exception: send: No buffer space available Sun Aug 9 08:58:37.731 2020 ERROR: NETWORK_SEND_ERROR Sun Aug 9 08:58:37.731 2020 UDP send exception: send: No buffer space available Sun Aug 9 08:58:37.731 2020 ERROR: NETWORK_SEND_ERROR Sun Aug 9 08:58:37.731 2020 UDP send exception: send: No buffer space available Sun Aug 9 08:58:37.731 2020 ERROR: NETWORK_SEND_ERROR Sun Aug 9 08:58:37.731 2020 UDP send exception: send: No buffer space available Sun Aug 9 08:58:37.731 2020 ERROR: NETWORK_SEND_ERROR Sun Aug 9 08:58:37.731 2020 UDP send exception: send: No buffer space available Sun Aug 9 08:58:37.731 2020 ERROR: NETWORK_SEND_ERROR Sun Aug 9 09:00:58.218 2020 UDP send exception: send: No buffer space available Sun Aug 9 09:00:58.218 2020 ERROR: NETWORK_SEND_ERROR Sun Aug 9 09:00:58.219 2020 UDP send exception: send: No buffer space available Sun Aug 9 09:00:58.219 2020 ERROR: NETWORK_SEND_ERROR Sun Aug 9 09:00:58.219 2020 UDP send exception: send: No buffer space available Sun Aug 9 09:00:58.219 2020 ERROR: NETWORK_SEND_ERROR Sun Aug 9 09:00:58.219 2020 UDP send exception: send: No buffer space available Sun Aug 9 09:00:58.219 2020 ERROR: NETWORK_SEND_ERROR Sun Aug 9 09:00:58.219 2020 UDP send exception: send: No buffer space available Sun Aug 9 09:00:58.219 2020 ERROR: NETWORK_SEND_ERROR Sun Aug 9 09:04:46.839 2020 Tunnel Options:V4,dev-type tun,link-mtu 1558,tun-mtu 1500,proto UDPv4,comp-lzo,keydir 1,cipher AES-256-CBC,auth SHA1,keysize 256,tls-auth,key-method 2,tls-client Sun Aug 9 09:04:46.839 2020 Peer Info: IV_VER=3.6.4 AirVPN IV_PLAT=mac IV_NCP=2 IV_TCPNL=1 IV_PROTO=2 IV_CIPHERS=AES-256-GCM:AES-128-GCM:CHACHA20-POLY1305 IV_LZO_STUB=1 IV_COMP_STUB=1 IV_COMP_STUBv2=1 UV_IPV6=yes IV_GUI_VER=Hummingbird - AirVPN OpenVPN 3 Client 1.1.0 IV_HWADDR=18:65:90:d6:c1:dd IV_SSL=mbed TLS 2.16.6 Sun Aug 9 09:04:46.915 2020 VERIFY OK : depth=1 cert. version : 3 serial number : 8C:D8:43:EF:E4:5F:20:03 issuer name : C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org subject name : C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org issued on : 2014-04-11 10:15:45 expires on : 2024-04-08 10:15:45 signed using : RSA with SHA1 RSA key size : 4096 bits basic constraints : CA=true Sun Aug 9 09:04:46.915 2020 VERIFY OK : depth=0 cert. version : 3 serial number : 01:30 issuer name : C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org subject name : C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=Achernar, emailAddress=info@airvpn.org issued on : 2016-12-28 14:55:42 expires on : 2026-12-26 14:55:42 signed using : RSA with SHA-512 RSA key size : 4096 bits basic constraints : CA=false cert. type : SSL Server key usage : Digital Signature, Key Encipherment ext key usage : TLS Web Server Authentication Sun Aug 9 09:04:47.231 2020 SSL Handshake: TLSv1.2/TLS-DHE-RSA-WITH-AES-256-GCM-SHA384 Sun Aug 9 09:04:47.232 2020 LZO-ASYM init swap=0 asym=1 Sun Aug 9 09:04:47.232 2020 Comp-stub init swap=0 Sun Aug 9 09:15:02.312 2020 UDP send exception: send: No buffer space available Sun Aug 9 09:15:02.312 2020 ERROR: NETWORK_SEND_ERROR Sun Aug 9 09:15:02.312 2020 UDP send exception: send: No buffer space available Sun Aug 9 09:15:02.312 2020 ERROR: NETWORK_SEND_ERROR Sun Aug 9 09:21:26.809 2020 Tunnel Options:V4,dev-type tun,link-mtu 1558,tun-mtu 1500,proto UDPv4,comp-lzo,keydir 1,cipher AES-256-CBC,auth SHA1,keysize 256,tls-auth,key-method 2,tls-client Sun Aug 9 09:21:26.809 2020 Peer Info: IV_VER=3.6.4 AirVPN IV_PLAT=mac IV_NCP=2 IV_TCPNL=1 IV_PROTO=2 IV_CIPHERS=AES-256-GCM:AES-128-GCM:CHACHA20-POLY1305 IV_LZO_STUB=1 IV_COMP_STUB=1 IV_COMP_STUBv2=1 UV_IPV6=yes IV_GUI_VER=Hummingbird - AirVPN OpenVPN 3 Client 1.1.0 IV_HWADDR=18:65:90:d6:c1:dd IV_SSL=mbed TLS 2.16.6 Sun Aug 9 09:21:26.884 2020 VERIFY OK : depth=1 cert. version : 3 serial number : 8C:D8:43:EF:E4:5F:20:03 issuer name : C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org subject name : C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org issued on : 2014-04-11 10:15:45 expires on : 2024-04-08 10:15:45 signed using : RSA with SHA1 RSA key size : 4096 bits basic constraints : CA=true Sun Aug 9 09:21:26.884 2020 VERIFY OK : depth=0 cert. version : 3 serial number : 01:30 issuer name : C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org subject name : C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=Achernar, emailAddress=info@airvpn.org issued on : 2016-12-28 14:55:42 expires on : 2026-12-26 14:55:42 signed using : RSA with SHA-512 RSA key size : 4096 bits basic constraints : CA=false cert. type : SSL Server key usage : Digital Signature, Key Encipherment ext key usage : TLS Web Server Authentication Sun Aug 9 09:21:27.231 2020 SSL Handshake: TLSv1.2/TLS-DHE-RSA-WITH-AES-256-GCM-SHA384 Sun Aug 9 09:21:27.232 2020 LZO-ASYM init swap=0 asym=1 Sun Aug 9 09:21:27.232 2020 Comp-stub init swap=0 Sun Aug 9 09:31:28.992 2020 UDP send exception: send: No buffer space available Sun Aug 9 09:31:28.992 2020 ERROR: NETWORK_SEND_ERROR Sun Aug 9 09:31:28.992 2020 UDP send exception: send: No buffer space available Sun Aug 9 09:31:28.992 2020 ERROR: NETWORK_SEND_ERROR Sun Aug 9 09:31:28.992 2020 UDP send exception: send: No buffer space available Sun Aug 9 09:31:28.992 2020 ERROR: NETWORK_SEND_ERROR Sun Aug 9 09:31:28.992 2020 UDP send exception: send: No buffer space available Sun Aug 9 09:31:28.992 2020 ERROR: NETWORK_SEND_ERROR Sun Aug 9 09:31:28.993 2020 UDP send exception: send: No buffer space available Sun Aug 9 09:31:28.993 2020 ERROR: NETWORK_SEND_ERROR Sun Aug 9 09:31:28.993 2020 UDP send exception: send: No buffer space available Sun Aug 9 09:31:28.993 2020 ERROR: NETWORK_SEND_ERROR Sun Aug 9 09:31:28.993 2020 UDP send exception: send: No buffer space available Sun Aug 9 09:31:28.994 2020 ERROR: NETWORK_SEND_ERROR Sun Aug 9 09:31:28.994 2020 UDP send exception: send: No buffer space available Sun Aug 9 09:31:28.994 2020 ERROR: NETWORK_SEND_ERROR Sun Aug 9 09:31:28.994 2020 UDP send exception: send: No buffer space available Sun Aug 9 09:31:28.994 2020 ERROR: NETWORK_SEND_ERROR Sun Aug 9 09:31:28.994 2020 UDP send exception: send: No buffer space available Sun Aug 9 09:31:28.994 2020 ERROR: NETWORK_SEND_ERROR Sun Aug 9 09:31:28.994 2020 UDP send exception: send: No buffer space available Sun Aug 9 09:31:28.994 2020 ERROR: NETWORK_SEND_ERROR Sun Aug 9 09:31:28.994 2020 UDP send exception: send: No buffer space available Sun Aug 9 09:31:28.994 2020 ERROR: NETWORK_SEND_ERROR Sun Aug 9 09:31:28.994 2020 UDP send exception: send: No buffer space available Sun Aug 9 09:31:28.994 2020 ERROR: NETWORK_SEND_ERROR Sun Aug 9 09:31:28.995 2020 UDP send exception: send: No buffer space available Sun Aug 9 09:31:28.995 2020 ERROR: NETWORK_SEND_ERROR Sun Aug 9 09:31:28.995 2020 UDP send exception: send: No buffer space available Sun Aug 9 09:31:28.995 2020 ERROR: NETWORK_SEND_ERROR Sun Aug 9 09:31:28.995 2020 UDP send exception: send: No buffer space available Sun Aug 9 09:31:28.995 2020 ERROR: NETWORK_SEND_ERROR Sun Aug 9 09:31:28.995 2020 UDP send exception: send: No buffer space available Sun Aug 9 09:31:28.995 2020 ERROR: NETWORK_SEND_ERROR Sun Aug 9 09:31:28.995 2020 UDP send exception: send: No buffer space available Sun Aug 9 09:31:28.995 2020 ERROR: NETWORK_SEND_ERROR Sun Aug 9 09:31:28.995 2020 UDP send exception: send: No buffer space available Sun Aug 9 09:31:28.995 2020 ERROR: NETWORK_SEND_ERROR Sun Aug 9 09:31:28.995 2020 UDP send exception: send: No buffer space available Sun Aug 9 09:31:28.995 2020 ERROR: NETWORK_SEND_ERROR Sun Aug 9 09:31:28.995 2020 UDP send exception: send: No buffer space available Sun Aug 9 09:31:28.995 2020 ERROR: NETWORK_SEND_ERROR Sun Aug 9 09:31:28.995 2020 UDP send exception: send: No buffer space available Sun Aug 9 09:31:28.995 2020 ERROR: NETWORK_SEND_ERROR Sun Aug 9 09:31:28.995 2020 UDP send exception: send: No buffer space available Sun Aug 9 09:31:28.995 2020 ERROR: NETWORK_SEND_ERROR Sun Aug 9 09:31:28.995 2020 UDP send exception: send: No buffer space available Sun Aug 9 09:31:28.995 2020 ERROR: NETWORK_SEND_ERROR Sun Aug 9 09:31:28.996 2020 UDP send exception: send: No buffer space available Sun Aug 9 09:31:28.996 2020 ERROR: NETWORK_SEND_ERROR Sun Aug 9 09:31:28.996 2020 UDP send exception: send: No buffer space available Sun Aug 9 09:31:28.996 2020 ERROR: NETWORK_SEND_ERROR Sun Aug 9 09:31:28.996 2020 UDP send exception: send: No buffer space available Sun Aug 9 09:31:28.996 2020 ERROR: NETWORK_SEND_ERROR Sun Aug 9 09:34:57.671 2020 UDP send exception: send: No buffer space available Sun Aug 9 09:34:57.671 2020 ERROR: NETWORK_SEND_ERROR Sun Aug 9 09:34:57.672 2020 UDP send exception: send: No buffer space available Sun Aug 9 09:34:57.672 2020 ERROR: NETWORK_SEND_ERROR Sun Aug 9 09:34:57.672 2020 UDP send exception: send: No buffer space available Sun Aug 9 09:34:57.672 2020 ERROR: NETWORK_SEND_ERROR Sun Aug 9 09:34:57.672 2020 UDP send exception: send: No buffer space available Sun Aug 9 09:34:57.672 2020 ERROR: NETWORK_SEND_ERROR Sun Aug 9 09:34:57.672 2020 UDP send exception: send: No buffer space available Sun Aug 9 09:34:57.672 2020 ERROR: NETWORK_SEND_ERROR Sun Aug 9 09:34:57.672 2020 UDP send exception: send: No buffer space available Sun Aug 9 09:34:57.672 2020 ERROR: NETWORK_SEND_ERROR Sun Aug 9 09:34:57.672 2020 UDP send exception: send: No buffer space available Sun Aug 9 09:34:57.672 2020 ERROR: NETWORK_SEND_ERROR Sun Aug 9 09:34:57.672 2020 UDP send exception: send: No buffer space available Sun Aug 9 09:34:57.672 2020 ERROR: NETWORK_SEND_ERROR Sun Aug 9 09:34:57.672 2020 UDP send exception: send: No buffer space available Sun Aug 9 09:34:57.672 2020 ERROR: NETWORK_SEND_ERROR Sun Aug 9 09:34:57.672 2020 UDP send exception: send: No buffer space available Sun Aug 9 09:34:57.673 2020 ERROR: NETWORK_SEND_ERROR Sun Aug 9 09:34:57.673 2020 UDP send exception: send: No buffer space available Sun Aug 9 09:34:57.673 2020 ERROR: NETWORK_SEND_ERROR Sun Aug 9 09:34:57.673 2020 UDP send exception: send: No buffer space available Sun Aug 9 09:34:57.673 2020 ERROR: NETWORK_SEND_ERROR Sun Aug 9 09:34:57.673 2020 UDP send exception: send: No buffer space available Sun Aug 9 09:34:57.673 2020 ERROR: NETWORK_SEND_ERROR Sun Aug 9 09:34:57.673 2020 UDP send exception: send: No buffer space available Sun Aug 9 09:34:57.673 2020 ERROR: NETWORK_SEND_ERROR Sun Aug 9 09:34:57.673 2020 UDP send exception: send: No buffer space available Sun Aug 9 09:34:57.673 2020 ERROR: NETWORK_SEND_ERROR Sun Aug 9 09:34:57.673 2020 UDP send exception: send: No buffer space available Sun Aug 9 09:34:57.673 2020 ERROR: NETWORK_SEND_ERROR Sun Aug 9 09:34:57.673 2020 UDP send exception: send: No buffer space available Sun Aug 9 09:34:57.673 2020 ERROR: NETWORK_SEND_ERROR Sun Aug 9 09:34:57.673 2020 UDP send exception: send: No buffer space available Sun Aug 9 09:34:57.673 2020 ERROR: NETWORK_SEND_ERROR Sun Aug 9 09:38:06.820 2020 Tunnel Options:V4,dev-type tun,link-mtu 1558,tun-mtu 1500,proto UDPv4,comp-lzo,keydir 1,cipher AES-256-CBC,auth SHA1,keysize 256,tls-auth,key-method 2,tls-client Sun Aug 9 09:38:06.820 2020 Peer Info: IV_VER=3.6.4 AirVPN IV_PLAT=mac IV_NCP=2 IV_TCPNL=1 IV_PROTO=2 IV_CIPHERS=AES-256-GCM:AES-128-GCM:CHACHA20-POLY1305 IV_LZO_STUB=1 IV_COMP_STUB=1 IV_COMP_STUBv2=1 UV_IPV6=yes IV_GUI_VER=Hummingbird - AirVPN OpenVPN 3 Client 1.1.0 IV_HWADDR=18:65:90:d6:c1:dd IV_SSL=mbed TLS 2.16.6 Sun Aug 9 09:38:06.901 2020 VERIFY OK : depth=1 cert. version : 3 serial number : 8C:D8:43:EF:E4:5F:20:03 issuer name : C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org subject name : C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org issued on : 2014-04-11 10:15:45 expires on : 2024-04-08 10:15:45 signed using : RSA with SHA1 RSA key size : 4096 bits basic constraints : CA=true Sun Aug 9 09:38:06.901 2020 VERIFY OK : depth=0 cert. version : 3 serial number : 01:30 issuer name : C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org subject name : C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=Achernar, emailAddress=info@airvpn.org issued on : 2016-12-28 14:55:42 expires on : 2026-12-26 14:55:42 signed using : RSA with SHA-512 RSA key size : 4096 bits basic constraints : CA=false cert. type : SSL Server key usage : Digital Signature, Key Encipherment ext key usage : TLS Web Server Authentication Sun Aug 9 09:38:07.181 2020 SSL Handshake: TLSv1.2/TLS-DHE-RSA-WITH-AES-256-GCM-SHA384 Sun Aug 9 09:38:07.181 2020 LZO-ASYM init swap=0 asym=1 Sun Aug 9 09:38:07.182 2020 Comp-stub init swap=0 Sun Aug 9 09:38:59.764 2020 UDP send exception: send: No buffer space available Sun Aug 9 09:38:59.764 2020 ERROR: NETWORK_SEND_ERROR Sun Aug 9 09:38:59.765 2020 UDP send exception: send: No buffer space available Sun Aug 9 09:38:59.765 2020 ERROR: NETWORK_SEND_ERROR Sun Aug 9 09:38:59.765 2020 UDP send exception: send: No buffer space available Sun Aug 9 09:38:59.765 2020 ERROR: NETWORK_SEND_ERROR Sun Aug 9 09:38:59.766 2020 UDP send exception: send: No buffer space available Sun Aug 9 09:38:59.766 2020 ERROR: NETWORK_SEND_ERROR Sun Aug 9 09:38:59.766 2020 UDP send exception: send: No buffer space available Sun Aug 9 09:38:59.766 2020 ERROR: NETWORK_SEND_ERROR Sun Aug 9 09:38:59.767 2020 UDP send exception: send: No buffer space available Sun Aug 9 09:38:59.767 2020 ERROR: NETWORK_SEND_ERROR Sun Aug 9 09:38:59.768 2020 UDP send exception: send: No buffer space available Sun Aug 9 09:38:59.768 2020 ERROR: NETWORK_SEND_ERROR Sun Aug 9 09:38:59.768 2020 UDP send exception: send: No buffer space available Sun Aug 9 09:38:59.768 2020 ERROR: NETWORK_SEND_ERROR Sun Aug 9 09:38:59.768 2020 UDP send exception: send: No buffer space available Sun Aug 9 09:38:59.768 2020 ERROR: NETWORK_SEND_ERROR Sun Aug 9 09:38:59.769 2020 UDP send exception: send: No buffer space available Sun Aug 9 09:38:59.769 2020 ERROR: NETWORK_SEND_ERROR Sun Aug 9 09:38:59.769 2020 UDP send exception: send: No buffer space available Sun Aug 9 09:38:59.769 2020 ERROR: NETWORK_SEND_ERROR Sun Aug 9 09:38:59.769 2020 UDP send exception: send: No buffer space available Sun Aug 9 09:38:59.769 2020 ERROR: NETWORK_SEND_ERROR Sun Aug 9 09:38:59.770 2020 UDP send exception: send: No buffer space available Sun Aug 9 09:38:59.770 2020 ERROR: NETWORK_SEND_ERROR Sun Aug 9 09:38:59.770 2020 UDP send exception: send: No buffer space available Sun Aug 9 09:38:59.770 2020 ERROR: NETWORK_SEND_ERROR Sun Aug 9 09:38:59.770 2020 UDP send exception: send: No buffer space available Sun Aug 9 09:38:59.771 2020 ERROR: NETWORK_SEND_ERROR Sun Aug 9 09:38:59.771 2020 UDP send exception: send: No buffer space available Sun Aug 9 09:38:59.771 2020 ERROR: NETWORK_SEND_ERROR Sun Aug 9 09:38:59.772 2020 UDP send exception: send: No buffer space available Sun Aug 9 09:38:59.772 2020 ERROR: NETWORK_SEND_ERROR Sun Aug 9 09:38:59.772 2020 UDP send exception: send: No buffer space available Sun Aug 9 09:38:59.772 2020 ERROR: NETWORK_SEND_ERROR Sun Aug 9 09:38:59.772 2020 UDP send exception: send: No buffer space available Sun Aug 9 09:38:59.772 2020 ERROR: NETWORK_SEND_ERROR Sun Aug 9 09:38:59.773 2020 UDP send exception: send: No buffer space available Sun Aug 9 09:38:59.773 2020 ERROR: NETWORK_SEND_ERROR Sun Aug 9 09:38:59.773 2020 UDP send exception: send: No buffer space available Sun Aug 9 09:38:59.773 2020 ERROR: NETWORK_SEND_ERROR Sun Aug 9 09:38:59.773 2020 UDP send exception: send: No buffer space available Sun Aug 9 09:38:59.773 2020 ERROR: NETWORK_SEND_ERROR Sun Aug 9 09:38:59.773 2020 UDP send exception: send: No buffer space available Sun Aug 9 09:38:59.773 2020 ERROR: NETWORK_SEND_ERROR Sun Aug 9 09:38:59.773 2020 UDP send exception: send: No buffer space available Sun Aug 9 09:38:59.773 2020 ERROR: NETWORK_SEND_ERROR Sun Aug 9 09:38:59.773 2020 UDP send exception: send: No buffer space available Sun Aug 9 09:38:59.774 2020 ERROR: NETWORK_SEND_ERROR Sun Aug 9 09:38:59.774 2020 UDP send exception: send: No buffer space available Sun Aug 9 09:38:59.774 2020 ERROR: NETWORK_SEND_ERROR Sun Aug 9 09:38:59.774 2020 UDP send exception: send: No buffer space available Sun Aug 9 09:38:59.774 2020 ERROR: NETWORK_SEND_ERROR Sun Aug 9 09:38:59.774 2020 UDP send exception: send: No buffer space available Sun Aug 9 09:38:59.774 2020 ERROR: NETWORK_SEND_ERROR Sun Aug 9 09:38:59.775 2020 UDP send exception: send: No buffer space available Sun Aug 9 09:38:59.775 2020 ERROR: NETWORK_SEND_ERROR Sun Aug 9 09:38:59.775 2020 UDP send exception: send: No buffer space available Sun Aug 9 09:38:59.775 2020 ERROR: NETWORK_SEND_ERROR Sun Aug 9 09:38:59.775 2020 UDP send exception: send: No buffer space available Sun Aug 9 09:38:59.775 2020 ERROR: NETWORK_SEND_ERROR Sun Aug 9 09:38:59.775 2020 UDP send exception: send: No buffer space available Sun Aug 9 09:38:59.775 2020 ERROR: NETWORK_SEND_ERROR Sun Aug 9 09:46:59.046 2020 UDP send exception: send: No buffer space available Sun Aug 9 09:46:59.046 2020 ERROR: NETWORK_SEND_ERROR Sun Aug 9 09:46:59.046 2020 UDP send exception: send: No buffer space available Sun Aug 9 09:46:59.046 2020 ERROR: NETWORK_SEND_ERROR Sun Aug 9 09:46:59.047 2020 UDP send exception: send: No buffer space available Sun Aug 9 09:46:59.047 2020 ERROR: NETWORK_SEND_ERROR Sun Aug 9 09:46:59.047 2020 UDP send exception: send: No buffer space available Sun Aug 9 09:46:59.047 2020 ERROR: NETWORK_SEND_ERROR Sun Aug 9 09:46:59.047 2020 UDP send exception: send: No buffer space available Sun Aug 9 09:46:59.047 2020 ERROR: NETWORK_SEND_ERROR Sun Aug 9 09:46:59.047 2020 UDP send exception: send: No buffer space available Sun Aug 9 09:46:59.047 2020 ERROR: NETWORK_SEND_ERROR Sun Aug 9 09:46:59.047 2020 UDP send exception: send: No buffer space available Sun Aug 9 09:46:59.047 2020 ERROR: NETWORK_SEND_ERROR Sun Aug 9 09:46:59.047 2020 UDP send exception: send: No buffer space available Sun Aug 9 09:46:59.047 2020 ERROR: NETWORK_SEND_ERROR Sun Aug 9 09:46:59.047 2020 UDP send exception: send: No buffer space available Sun Aug 9 09:46:59.047 2020 ERROR: NETWORK_SEND_ERROR Sun Aug 9 09:46:59.047 2020 UDP send exception: send: No buffer space available Sun Aug 9 09:46:59.047 2020 ERROR: NETWORK_SEND_ERROR Sun Aug 9 09:46:59.047 2020 UDP send exception: send: No buffer space available Sun Aug 9 09:46:59.047 2020 ERROR: NETWORK_SEND_ERROR Sun Aug 9 09:46:59.047 2020 UDP send exception: send: No buffer space available Sun Aug 9 09:46:59.047 2020 ERROR: NETWORK_SEND_ERROR Sun Aug 9 09:46:59.047 2020 UDP send exception: send: No buffer space available Sun Aug 9 09:46:59.047 2020 ERROR: NETWORK_SEND_ERROR Sun Aug 9 09:46:59.048 2020 UDP send exception: send: No buffer space available Sun Aug 9 09:46:59.048 2020 ERROR: NETWORK_SEND_ERROR Sun Aug 9 09:54:46.810 2020 Tunnel Options:V4,dev-type tun,link-mtu 1558,tun-mtu 1500,proto UDPv4,comp-lzo,keydir 1,cipher AES-256-CBC,auth SHA1,keysize 256,tls-auth,key-method 2,tls-client Sun Aug 9 09:54:46.810 2020 Peer Info: Quote Share this post Link to post
Fezenari 1 Posted ... This version (unlike 1.0.3) now can connect via ipv6 for me. It successfully connects and works for about a minute, and then it silently stops working. Quote Share this post Link to post
jeuia3e9x74uxu6wk0r2u9kdos 30 Posted ... (edited) --solved-- Edited ... by jeuia3e9x74uxu6wk0r2u9kdos solved Quote Share this post Link to post
Monotremata 22 Posted ... Ive got it running in Eddie 2.19.4/macOS 10.15.6 now too (thanks for the tips in the beta thread @Maggie144) but I think Im getting the same error.. It hasn't disconnected on me yet this morning (but when I woke up it was disconnected because of it), but right now its popping these up every couple of minutes: E 2020.08.22 11:10:52 - Hummingbird > ERROR: KEV_NEGOTIATE_ERROR E 2020.08.22 11:10:52 - Hummingbird > ERROR: HANDSHAKE_TIMEOUT E 2020.08.22 11:11:22 - Hummingbird > ERROR: KEY_STATE_ERROR Im never here when it disconnects, but I just started running Hummingbird two days ago, so hopefully Ill catch it since Im not at work today. Nice work though, Hummingbird inside Eddie connects about 1000x faster than the standard way. Had to jump through some permissions fixes to get it to run but after that no problems other than these weird errors above. Quote Share this post Link to post
jeuia3e9x74uxu6wk0r2u9kdos 30 Posted ... 39 minutes ago, Monotremata said: Ive got it running in Eddie 2.19.4/macOS 10.15.6 now too (thanks for the tips in the beta thread @Maggie144) but I think Im getting the same error.. It hasn't disconnected on me yet this morning (but when I woke up it was disconnected because of it), but right now its popping these up every couple of minutes: E 2020.08.22 11:10:52 - Hummingbird > ERROR: KEV_NEGOTIATE_ERROR E 2020.08.22 11:10:52 - Hummingbird > ERROR: HANDSHAKE_TIMEOUT E 2020.08.22 11:11:22 - Hummingbird > ERROR: KEY_STATE_ERROR Im never here when it disconnects, but I just started running Hummingbird two days ago, so hopefully Ill catch it since Im not at work today. Nice work though, Hummingbird inside Eddie connects about 1000x faster than the standard way. Had to jump through some permissions fixes to get it to run but after that no problems other than these weird errors above. Hi! I had your exact same error and Staff told me this: Please try to add the following custom directive in "Preferences" > "OVPN Directives": reneg-sec 1500 (it forces key renegotiation every 1500 seconds from client side, instead of waiting for server) and the problem should be greatly mitigated or even resolved. Hope this can help! 1 Monotremata reacted to this Quote Share this post Link to post
Monotremata 22 Posted ... 12 hours ago, jeuia3e9x74uxu6wk0r2u9kdos said: Hi! I had your exact same error and Staff told me this: Please try to add the following custom directive in "Preferences" > "OVPN Directives": reneg-sec 1500 (it forces key renegotiation every 1500 seconds from client side, instead of waiting for server) and the problem should be greatly mitigated or even resolved. Hope this can help! That seemed to do the trick. I saw that above but it never said where to put it in Eddie so thank you for the preference location hah! Two hours now and not a single error. Quote Share this post Link to post
8s8s8wem3x 0 Posted ... (edited) Hi, two questions regarding reneg-sec... I am trying to add reneg-sec 1500 to the Hummingbird - AirVPN OpenVPN 3 Client 1.1.0... because after one hour initial connection I also get that annoying "ERROR: KEY_STATE_ERROR" ... What is the proper way to do this? Should I append this to the Hummingbird executable like that? sudo ./hummingbird Air_xxxx.ovpn reneg-sec=1500 or can I write it into the *.ovpn file? And if that setting is set, shouldn't I see action in the Hummingbird console window after 25minutes (1500)? I ask because I tried to set this attribute but I don't see any action after 25minutes, just the regular action after one hour... so I ask myself if I invoke "reneg-sec" the wrong way... Edited ... by 8s8s8wem3x formatting Quote Share this post Link to post
eburom 16 Posted ... Hi @8s8s8wem3x. I would say the proper way of doing this is to add that line to your ovpn file. And I would expect to see some key renegotiation messages to print out to the console after 25 min as well. Quote Share this post Link to post
shaunography 0 Posted ... Hi, Hummingbird breaks DNS when using systemd-resolved. The symlink that gets created by systemd-resolved on Ubuntu (/etc/resolv.conf -> /run/systemd/resolve/resolv.conf) is deleted and replaced with a new resolve.conf file as pushed by the vpn server. However when the VPN connection is then closed and the symlink restored the contents of the systemd-resolved controlled resolv.conf file at /run/systemd/resolve/resolv.conf is not restored, it still contains the pushed DNS server ip addresses. Quote Share this post Link to post
Staff 10395 Posted ... @183aTr78f9o@shaunography Hello! Can you post your Hummingbird log taken just after the problem has occurred? Kind regards Quote Share this post Link to post
