lerk08
Static IPs
Hello, I'm wondering if AirVPN assigns static/dedicated IPs to users. I would like to be assigned a static IP for some things I'm trying to set up.
If you do assign static IPs, how would a user go about setting this up?
Each Air VPN server has one static exit-IP address with which clients connected to that server are "visible" on the Internet. No specific setup is necessary.
Please may I confirm: do multiple AirVPN users share one (the server's) external IP address, rather than allocating one static external IP per user?
Thank you.
Thank you.
Yes, we confirm that. Each server has one static entry-IP and one shared static exit-IP address.
