rpx
Error: SecureChannelFailure
i can´t connect to recommend server anymore since several days with both of my macs.
One is an Imac Mid2011 with OS X 10.10.5 and running Eddie 2.11.15
Here is a part of the Logfile:
. 2020.04.04 11:12:08 - DNS of a network adapter forced (Ethernet, from 10.27.4.1 to 10.10.176.1)
. 2020.04.04 11:12:08 - DNS of a network adapter forced (FireWire, from 10.27.4.1 to 10.10.176.1)
. 2020.04.04 11:12:08 - DNS of a network adapter forced (Wi-Fi, from 146.185.167.43,46.182.19.48 to 10.10.176.1)
. 2020.04.04 11:12:08 - DNS of a network adapter forced (Bluetooth PAN, from 10.27.4.1 to 10.10.176.1)
. 2020.04.04 11:12:08 - DNS of a network adapter forced (Thunderbolt Bridge, from 10.27.4.1 to 10.10.176.1)
. 2020.04.04 11:12:08 - Flushing DNS
I 2020.04.04 11:12:08 - Checking route
E 2020.04.04 11:12:08 - Error: SecureChannelFailure (The authentication or decryption has failed.)
. 2020.04.04 11:12:08 - Checking route (2° try)
E 2020.04.04 11:12:09 - Error: SecureChannelFailure (The authentication or decryption has failed.)
. 2020.04.04 11:12:09 - Checking route (3° try)
E 2020.04.04 11:12:11 - Error: SecureChannelFailure (The authentication or decryption has failed.)
E 2020.04.04 11:12:11 - Routing checking failed.
. 2020.04.04 11:12:11 - OpenVPN > MANAGEMENT: Client connected from [AF_INET]127.0.0.1:3115
! 2020.04.04 11:12:11 - Disconnecting
. 2020.04.04 11:12:11 - Management - Send 'signal SIGTERM'
. 2020.04.04 11:12:11 - OpenVpn Management > >INFO:OpenVPN Management Interface Version 1 -- type 'help' for more info
. 2020.04.04 11:12:11 - OpenVPN > MANAGEMENT: CMD 'signal SIGTERM'
. 2020.04.04 11:12:11 - OpenVPN > SIGTERM received, sending exit notification to peer
. 2020.04.04 11:12:16 - OpenVPN > /sbin/route delete -net 178.162.204.227 192.168.178.1 255.255.255.255
. 2020.04.04 11:12:16 - OpenVPN > delete net 178.162.204.227: gateway 192.168.178.1
. 2020.04.04 11:12:16 - OpenVPN > /sbin/route delete -net 0.0.0.0 10.10.176.1 128.0.0.0
. 2020.04.04 11:12:16 - Connection terminated.
. 2020.04.04 11:12:16 - DNS of a network adapter restored to original settings (Bluetooth DUN, to Automatic)
. 2020.04.04 11:12:16 - OpenVPN > delete net 0.0.0.0: gateway 10.10.176.1
. 2020.04.04 11:12:16 - OpenVPN > /sbin/route delete -net 128.0.0.0 10.10.176.1 128.0.0.0
. 2020.04.04 11:12:16 - OpenVPN > delete net 128.0.0.0: gateway 10.10.176.1
. 2020.04.04 11:12:16 - OpenVPN > Closing TUN/TAP interface
. 2020.04.04 11:12:16 - DNS of a network adapter restored to original settings (Ethernet, to 10.27.4.1)
. 2020.04.04 11:12:16 - OpenVPN > SIGTERM[soft,exit-with-notification] received, process exiting
. 2020.04.04 11:12:16 - DNS of a network adapter restored to original settings (FireWire, to 10.27.4.1)
. 2020.04.04 11:12:16 - DNS of a network adapter restored to original settings (Wi-Fi, to 146.185.167.43,46.182.19.48)
. 2020.04.04 11:12:16 - DNS of a network adapter restored to original settings (Bluetooth PAN, to 10.27.4.1)
. 2020.04.04 11:12:16 - DNS of a network adapter restored to original settings (Thunderbolt Bridge, to 10.27.4.1)
I 2020.04.04 11:12:19 - Checking authorization ...
! 2020.04.04 11:12:20 - Connecting to Ogma (Germany, Frankfurt)
. 2020.04.04 11:12:20 - OpenVPN > OpenVPN 2.4.0 x86_64-apple-darwin16.3.0 [SSL (OpenSSL)] [LZO] [LZ4] [MH/RECVDA] [AEAD] built on Jan 29 2017
. 2020.04.04 11:12:20 - OpenVPN > library versions: OpenSSL 1.0.2k  26 Jan 2017, LZO 2.09
. 2020.04.04 11:12:20 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3115
. 2020.04.04 11:12:20 - OpenVPN > Outgoing Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2020.04.04 11:12:20 - OpenVPN > Incoming Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2020.04.04 11:12:20 - OpenVPN > TCP/UDP: Preserving recently used remote address: [AF_INET]185.189.112.18:443
. 2020.04.04 11:12:20 - OpenVPN > Socket Buffers: R=[196724->196724] S=[9216->9216]
. 2020.04.04 11:12:20 - OpenVPN > UDP link local: (not bound)
. 2020.04.04 11:12:20 - OpenVPN > UDP link remote: [AF_INET]185.189.112.18:443
. 2020.04.04 11:12:20 - OpenVPN > TLS: Initial packet from [AF_INET]185.189.112.18:443, sid=d1783367 227689db
. 2020.04.04 11:12:20 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
. 2020.04.04 11:12:20 - OpenVPN > Validating certificate key usage
. 2020.04.04 11:12:20 - OpenVPN > ++ Certificate has key usage  00a0, expects 00a0
. 2020.04.04 11:12:20 - OpenVPN > VERIFY KU OK
. 2020.04.04 11:12:20 - OpenVPN > Validating certificate extended key usage
. 2020.04.04 11:12:20 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
. 2020.04.04 11:12:20 - OpenVPN > VERIFY EKU OK
. 2020.04.04 11:12:20 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=Ogma, emailAddress=info@airvpn.org
. 2020.04.04 11:12:20 - OpenVPN > Control Channel: TLSv1.2, cipher TLSv1/SSLv3 DHE-RSA-AES256-GCM-SHA384, 4096 bit RSA
. 2020.04.04 11:12:20 - OpenVPN > [Ogma] Peer Connection Initiated with [AF_INET]185.189.112.18:443
. 2020.04.04 11:12:21 - OpenVPN > SENT CONTROL [Ogma]: 'PUSH_REQUEST' (status=1)
. 2020.04.04 11:12:21 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,comp-lzo no,redirect-gateway  def1 bypass-dhcp,dhcp-option DNS 10.25.176.1,route-gateway 10.25.176.1,topology subnet,ping 10,ping-restart 60,ifconfig 10.25.176.138 255.255.255.0,peer-id 2,cipher AES-256-GCM'
. 2020.04.04 11:12:21 - OpenVPN > ifconfig: ioctl (SIOCDIFADDR): Can't assign requested address
. 2020.04.04 11:12:21 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified
. 2020.04.04 11:12:21 - OpenVPN > OPTIONS IMPORT: compression parms modified
. 2020.04.04 11:12:21 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified
. 2020.04.04 11:12:21 - OpenVPN > OPTIONS IMPORT: route options modified
. 2020.04.04 11:12:21 - OpenVPN > OPTIONS IMPORT: route-related options modified
. 2020.04.04 11:12:21 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified
. 2020.04.04 11:12:21 - OpenVPN > OPTIONS IMPORT: peer-id set
. 2020.04.04 11:12:21 - OpenVPN > OPTIONS IMPORT: adjusting link_mtu to 1625
. 2020.04.04 11:12:21 - OpenVPN > OPTIONS IMPORT: data channel crypto options modified
. 2020.04.04 11:12:21 - OpenVPN > Data Channel Encrypt: Cipher 'AES-256-GCM' initialized with 256 bit key
. 2020.04.04 11:12:21 - OpenVPN > Data Channel Decrypt: Cipher 'AES-256-GCM' initialized with 256 bit key
. 2020.04.04 11:12:21 - OpenVPN > ROUTE_GATEWAY 192.168.178.1/255.255.255.0 IFACE=en1 HWADDR=e4:ce:8f:5a:16:48
. 2020.04.04 11:12:21 - OpenVPN > Opened utun device utun0
. 2020.04.04 11:12:21 - OpenVPN > do_ifconfig, tt->did_ifconfig_ipv6_setup=0
. 2020.04.04 11:12:21 - OpenVPN > /sbin/ifconfig utun0 delete
. 2020.04.04 11:12:21 - OpenVPN > NOTE: Tried to delete pre-existing tun/tap instance -- No Problem if failure
. 2020.04.04 11:12:21 - OpenVPN > /sbin/ifconfig utun0 10.25.176.138 10.25.176.138 netmask 255.255.255.0 mtu 1500 up
. 2020.04.04 11:12:21 - OpenVPN > /sbin/route add -net 10.25.176.0 10.25.176.138 255.255.255.0
. 2020.04.04 11:12:21 - OpenVPN > add net 10.25.176.0: gateway 10.25.176.138
// snip
I hope you can help me here.
Thanks in advance and sorry for my bad english!
rpx
Hello and thank you for your choice!
Your Eddie version is very old.
Please upgrade Eddie and the problem should be resolved.
You can download Eddie latest stable release for Windows here:
https://airvpn.org/windows
You can download Eddie latest stable release for Linux here:
https://airvpn.org/linux
You can download Eddie latest stable release for Mac here:
https://airvpn.org/macos
thanks.
Now i have another error, some lib not found, please see the log:
. 2020.04.04 15:51:39 - Eddie version: 2.18.9 / macos_x64, System: MacOS, Name: macOS 10.10.5, Version: 10.10.5 (Build 14F2511), Mono/.Net: v4.0.30319
. 2020.04.04 15:51:39 - Command line arguments (0):
. 2020.04.04 15:51:39 - Raise system privileges
. 2020.04.04 15:51:45 - Profile path: /Users/netzwerk/.config/eddie/default.profile
. 2020.04.04 15:51:46 - Reading options from /Users/netzwerk/.config/eddie/default.profile
. 2020.04.04 15:51:47 - Tun Driver - Expected
. 2020.04.04 15:51:47 - OpenVPN - Version:  -  (/Applications/Eddie.app/Contents/MacOS/openvpn)
. 2020.04.04 15:51:47 - SSH - Version: OpenSSH_6.2p2, OSSLShim 0.9.8r 8 Dec 2011 (/usr/bin/ssh)
. 2020.04.04 15:51:47 - SSL - Version: stunnel 5.48 (/Applications/Eddie.app/Contents/MacOS/stunnel)
. 2020.04.04 15:51:47 - curl - Version: 7.43.0 (/usr/bin/curl)
I 2020.04.04 15:51:48 - Ready
. 2020.04.04 15:51:48 - Collect information about AirVPN completed
I 2020.04.04 15:51:49 - Session starting.
. 2020.04.04 15:51:49 - Waiting for latency tests (220 to go)
. 2020.04.04 15:51:49 - Collect information about AirVPN completed
. 2020.04.04 15:51:50 - Waiting for latency tests (170 to go)
. 2020.04.04 15:51:51 - Waiting for latency tests (137 to go)
. 2020.04.04 15:51:52 - Waiting for latency tests (95 to go)
. 2020.04.04 15:51:53 - Waiting for latency tests (73 to go)
. 2020.04.04 15:51:57 - Waiting for latency tests (70 to go)
. 2020.04.04 15:51:58 - Waiting for latency tests (24 to go)
I 2020.04.04 15:51:59 - Checking authorization ...
. 2020.04.04 15:52:00 - IPv6 disabled on network adapter (FireWire)
. 2020.04.04 15:52:00 - IPv6 disabled on network adapter (Wi-Fi)
. 2020.04.04 15:52:00 - IPv6 disabled on network adapter (Bluetooth PAN)
. 2020.04.04 15:52:00 - IPv6 disabled on network adapter (Thunderbolt Bridge)
! 2020.04.04 15:52:00 - Connecting to Alpheratz (Netherlands, Alblasserdam)
. 2020.04.04 15:52:00 - OpenVPN > dyld: Library not loaded: @executable_path/liblzo2.2.dylib
. 2020.04.04 15:52:00 - OpenVPN > Referenced from: /Applications/Eddie.app/Contents/MacOS/openvpn
. 2020.04.04 15:52:00 - OpenVPN > Reason: no suitable image found.  Did find:
. 2020.04.04 15:52:00 - OpenVPN > /Applications/Eddie.app/Contents/MacOS/liblzo2.2.dylib: code signature invalid for '/Applications/Eddie.app/Contents/MacOS/liblzo2.2.dylib'
. 2020.04.04 15:52:01 - Above log line repeated 1 times more
! 2020.04.04 15:52:01 - Disconnecting
. 2020.04.04 15:52:01 - Connection terminated.
. 2020.04.04 15:52:01 - IPv6 restored on network adapter (FireWire)
. 2020.04.04 15:52:01 - IPv6 restored on network adapter (Wi-Fi)
. 2020.04.04 15:52:01 - IPv6 restored on network adapter (Bluetooth PAN)
. 2020.04.04 15:52:01 - IPv6 restored on network adapter (Thunderbolt Bridge)
I 2020.04.04 15:52:04 - Checking authorization ...
. 2020.04.04 15:52:05 - IPv6 disabled on network adapter (FireWire)
. 2020.04.04 15:52:05 - IPv6 disabled on network adapter (Wi-Fi)
. 2020.04.04 15:52:05 - IPv6 disabled on network adapter (Bluetooth PAN)
. 2020.04.04 15:52:05 - IPv6 disabled on network adapter (Thunderbolt Bridge)
! 2020.04.04 15:52:05 - Connecting to Aljanah (Netherlands, Alblasserdam)
. 2020.04.04 15:52:05 - OpenVPN > dyld: Library not loaded: @executable_path/liblzo2.2.dylib
. 2020.04.04 15:52:05 - OpenVPN > Referenced from: /Applications/Eddie.app/Contents/MacOS/openvpn
. 2020.04.04 15:52:05 - OpenVPN > Reason: no suitable image found.  Did find:
. 2020.04.04 15:52:05 - OpenVPN > /Applications/Eddie.app/Contents/MacOS/liblzo2.2.dylib: code signature invalid for '/Applications/Eddie.app/Contents/MacOS/liblzo2.2.dylib'
. 2020.04.04 15:52:05 - Above log line repeated 1 times more
! 2020.04.04 15:52:05 - Disconnecting
. 2020.04.04 15:52:05 - Connection terminated.
. 2020.04.04 15:52:05 - IPv6 restored on network adapter (FireWire)
. 2020.04.04 15:52:05 - IPv6 restored on network adapter (Wi-Fi)
. 2020.04.04 15:52:05 - IPv6 restored on network adapter (Bluetooth PAN)
. 2020.04.04 15:52:05 - IPv6 restored on network adapter (Thunderbolt Bridge)
I 2020.04.04 15:52:08 - Cancel requested.
! 2020.04.04 15:52:08 - Session terminated.
I 2020.04.04 15:53:15 - Session starting.
I 2020.04.04 15:53:16 - Checking authorization ...
. 2020.04.04 15:53:16 - IPv6 disabled on network adapter (FireWire)
. 2020.04.04 15:53:16 - IPv6 disabled on network adapter (Wi-Fi)
. 2020.04.04 15:53:16 - IPv6 disabled on network adapter (Bluetooth PAN)
. 2020.04.04 15:53:16 - IPv6 disabled on network adapter (Thunderbolt Bridge)
! 2020.04.04 15:53:16 - Connecting to Errai (Germany, Frankfurt)
. 2020.04.04 15:53:17 - OpenVPN > dyld: Library not loaded: @executable_path/liblzo2.2.dylib
. 2020.04.04 15:53:17 - OpenVPN > Referenced from: /Applications/Eddie.app/Contents/MacOS/openvpn
. 2020.04.04 15:53:17 - OpenVPN > Reason: no suitable image found.  Did find:
. 2020.04.04 15:53:17 - OpenVPN > /Applications/Eddie.app/Contents/MacOS/liblzo2.2.dylib: code signature invalid for '/Applications/Eddie.app/Contents/MacOS/liblzo2.2.dylib'
. 2020.04.04 15:53:17 - Above log line repeated 1 times more
! 2020.04.04 15:53:17 - Disconnecting
. 2020.04.04 15:53:17 - Connection terminated.
. 2020.04.04 15:53:17 - IPv6 restored on network adapter (FireWire)
. 2020.04.04 15:53:17 - IPv6 restored on network adapter (Wi-Fi)
. 2020.04.04 15:53:17 - IPv6 restored on network adapter (Bluetooth PAN)
. 2020.04.04 15:53:17 - IPv6 restored on network adapter (Thunderbolt Bridge)
I 2020.04.04 15:53:20 - Checking authorization ...
. 2020.04.04 15:53:21 - IPv6 disabled on network adapter (FireWire)
. 2020.04.04 15:53:21 - IPv6 disabled on network adapter (Wi-Fi)
. 2020.04.04 15:53:21 - IPv6 disabled on network adapter (Bluetooth PAN)
. 2020.04.04 15:53:21 - IPv6 disabled on network adapter (Thunderbolt Bridge)
! 2020.04.04 15:53:21 - Connecting to Dubhe (Germany, Frankfurt)
. 2020.04.04 15:53:21 - OpenVPN > dyld: Library not loaded: @executable_path/liblzo2.2.dylib
. 2020.04.04 15:53:21 - OpenVPN > Referenced from: /Applications/Eddie.app/Contents/MacOS/openvpn
. 2020.04.04 15:53:21 - OpenVPN > Reason: no suitable image found.  Did find:
. 2020.04.04 15:53:21 - OpenVPN > /Applications/Eddie.app/Contents/MacOS/liblzo2.2.dylib: code signature invalid for '/Applications/Eddie.app/Contents/MacOS/liblzo2.2.dylib'
. 2020.04.04 15:53:21 - Above log line repeated 1 times more
! 2020.04.04 15:53:21 - Disconnecting
. 2020.04.04 15:53:21 - Connection terminated.
. 2020.04.04 15:53:21 - IPv6 restored on network adapter (FireWire)
. 2020.04.04 15:53:21 - IPv6 restored on network adapter (Wi-Fi)
. 2020.04.04 15:53:21 - IPv6 restored on network adapter (Bluetooth PAN)
. 2020.04.04 15:53:21 - IPv6 restored on network adapter (Thunderbolt Bridge)
I 2020.04.04 15:53:24 - Checking authorization ...
. 2020.04.04 15:53:25 - IPv6 disabled on network adapter (FireWire)
. 2020.04.04 15:53:25 - IPv6 disabled on network adapter (Wi-Fi)
. 2020.04.04 15:53:25 - IPv6 disabled on network adapter (Bluetooth PAN)
. 2020.04.04 15:53:25 - IPv6 disabled on network adapter (Thunderbolt Bridge)
! 2020.04.04 15:53:25 - Connecting to Cervantes (Germany, Frankfurt)
. 2020.04.04 15:53:25 - OpenVPN > dyld: Library not loaded: @executable_path/liblzo2.2.dylib
. 2020.04.04 15:53:25 - OpenVPN > Referenced from: /Applications/Eddie.app/Contents/MacOS/openvpn
. 2020.04.04 15:53:25 - OpenVPN > Reason: no suitable image found.  Did find:
. 2020.04.04 15:53:25 - OpenVPN > /Applications/Eddie.app/Contents/MacOS/liblzo2.2.dylib: code signature invalid for '/Applications/Eddie.app/Contents/MacOS/liblzo2.2.dylib'
. 2020.04.04 15:53:26 - Above log line repeated 1 times more
! 2020.04.04 15:53:26 - Disconnecting
. 2020.04.04 15:53:26 - Connection terminated.
. 2020.04.04 15:53:26 - IPv6 restored on network adapter (FireWire)
. 2020.04.04 15:53:26 - IPv6 restored on network adapter (Wi-Fi)
. 2020.04.04 15:53:26 - IPv6 restored on network adapter (Bluetooth PAN)
. 2020.04.04 15:53:26 - IPv6 restored on network adapter (Thunderbolt Bridge)
I 2020.04.04 15:53:28 - Cancel requested.
! 2020.04.04 15:53:28 - Session terminated.
thanks in advance, rpx
