Not connected, Your IP: 216.73.216.169
Tank
bypass vpn for certain ip address
finally got everything running fine with the vpn on dd-wrt
now i want to know if there is a way to use bypass the vpn for like my xbox and my microcell, i have static ip's on both of them
Yes, DD-WRT supports Policy Based Routing with multiple routing tables:
http://www.dd-wrt.com/wiki/index.php/Policy_Based_Routing
So you might say, for example, that 192.168.1.101 uses the tunnel, while 192.168.1.102 does not.
Is there a way to allow a connection to my XBOX while connected to Air without dd-wrt? Also when I have my firewall (Comodo) blocking all traffic not through Air, how do I allow my XBOX and computer to communicate? I tried allowing all local to local but it is not working. Thanks!
As far as we know it's not possible to run OpenVPN on a Xbox, but you might connect the Xbox with an Ethernet cable to a computer which acts as a gateway. The computer establishes the connection to an Air server, then allows Internet sharing to the Xbox.
Please determine the Xbox IP address in your network if it's static or tell us whether it accepts a DHCP-pushed IP from the router and send us your Comodo rules, Network Zones and how your local network is defined.
We're looking forward to hearing from you.
so just to be clear im doing this right before i do it, i would do somthing like this
ip rule add from 192.168.1.101 table 200
ip route add default via [gateway] dev [interface] table 200
ip route flush cache
and i get gateway from status-wan page
and get interface from setup-networking and at the bottom its says wan port assignment eth1
does that look correct
