Not connected, Your IP: 216.73.216.14
Tank
dd-wrt wndr3700 cant connect
this is my log file
erverlog Clientlog 20121004 17:41:39 I OpenVPN 2.2.1 mips-linux [sSL] [LZO2] built on Jul 20 2012
20121004 17:41:39 MANAGEMENT: TCP Socket listening on 127.0.0.1:5001
20121004 17:41:39 W NOTE: the current --script-security setting may allow this configuration to call user-defined scripts
20121004 17:41:39 W WARNING: file '/tmp/openvpncl/client.key' is group or others accessible
20121004 17:41:39 I LZO compression initialized
20121004 17:41:39 Control Channel MTU parms [ L:1558 D:138 EF:38 EB:0 ET:0 EL:0 ]
20121004 17:41:39 Socket Buffers: R=[163840->131072] S=[163840->131072]
20121004 17:41:39 Data Channel MTU parms [ L:1558 D:1450 EF:58 EB:135 ET:0 EL:0 AF:3/1 ]
20121004 17:41:39 Local Options String: 'V4 dev-type tun link-mtu 1558 tun-mtu 1500 proto UDPv4 comp-lzo cipher AES-256-CBC auth SHA1 keysize 256 key-method 2 tls-client'
20121004 17:41:39 Expected Remote Options String: 'V4 dev-type tun link-mtu 1558 tun-mtu 1500 proto UDPv4 comp-lzo cipher AES-256-CBC auth SHA1 keysize 256 key-method 2 tls-server'
20121004 17:41:39 Local Options hash (VER=V4): '22188c5b'
20121004 17:41:39 Expected Remote Options hash (VER=V4): 'a8f55717'
20121004 17:41:39 I UDPv4 link local: [undef]
20121004 17:41:39 I UDPv4 link remote: 198.15.111.162:443
20121004 17:41:39 TLS: Initial packet from 198.15.111.162:443 sid=b79212a1 9b2ea5b5
20121004 17:41:39 VERIFY OK: depth=1 /C=IT/ST=IT/L=Perugia/O=airvpn.org/CN=airvpn.org_CA/emailAddress=info@airvpn.org
20121004 17:41:39 VERIFY OK: nsCertType=SERVER
20121004 17:41:39 VERIFY OK: depth=0 /C=IT/ST=IT/L=Perugia/O=airvpn.org/CN=server/emailAddress=info@airvpn.org
20121004 17:41:44 MANAGEMENT: Client connected from 127.0.0.1:5001
20121004 17:41:44 D MANAGEMENT: CMD 'state'
20121004 17:41:44 MANAGEMENT: Client disconnected
20121004 17:41:44 D MANAGEMENT: CMD 'log 500'
19700101 00:00:00
site says not connected at the bottom in red and it says connected in current session statistics
You are currently connected to Arietis server, located in United States, since 1m 29s ago.
You are visible from the Internet with IP 198.15.111.163 (Server Exit-IP).
You are connected to IP 198.15.111.162 (Server Entry-IP) through udp, port 443.
During the current session, you downloaded 6 kB and uploaded 4 kB.
Current speed: 0 B in download, 0 B in upload (0 seconds average).
We see your connection coming from CH.AN.GE.D:53609. Note: We inevitably know it. Any reference will be deleted when the connection is closed.
19700101 00:00:00
Unfortunately this looks like a known DD-WRT firmware bug:
https://airvpn.org/index.php?option=com_kunena&func=view&catid=3&id=4292&limit=6&limitstart=6&Itemid=142#4358
The challenge is finding for your router the last working firmware version. You can probably find precious indications on the provided link.
This is because the router really establishes a connection, but then starts "messing up" and does not tunnel anything from the devices, while at the same time it keeps the connection alive.
down graded to 18777 which someone else said they were using openvpn on and looks like i get the same thing in my logs
Serverlog Clientlog 20121004 18:21:58 I OpenVPN 2.2.1 mips-linux [sSL] [LZO2] built on Mar 19 2012
20121004 18:21:58 MANAGEMENT: TCP Socket listening on 127.0.0.1:5001
20121004 18:21:58 W NOTE: the current --script-security setting may allow this configuration to call user-defined scripts
20121004 18:21:58 W WARNING: file '/tmp/openvpncl/client.key' is group or others accessible
20121004 18:21:58 I LZO compression initialized
20121004 18:21:58 Control Channel MTU parms [ L:1558 D:138 EF:38 EB:0 ET:0 EL:0 ]
20121004 18:21:58 Socket Buffers: R=[163840->131072] S=[163840->131072]
20121004 18:21:58 Data Channel MTU parms [ L:1558 D:1450 EF:58 EB:135 ET:0 EL:0 AF:3/1 ]
20121004 18:21:58 Local Options String: 'V4 dev-type tun link-mtu 1558 tun-mtu 1500 proto UDPv4 comp-lzo cipher AES-256-CBC auth SHA1 keysize 256 key-method 2 tls-client'
20121004 18:21:58 Expected Remote Options String: 'V4 dev-type tun link-mtu 1558 tun-mtu 1500 proto UDPv4 comp-lzo cipher AES-256-CBC auth SHA1 keysize 256 key-method 2 tls-server'
20121004 18:21:58 Local Options hash (VER=V4): '22188c5b'
20121004 18:21:58 Expected Remote Options hash (VER=V4): 'a8f55717'
20121004 18:21:58 I UDPv4 link local: [undef]
20121004 18:21:58 I UDPv4 link remote: 198.15.111.162:443
20121004 18:21:58 TLS: Initial packet from 198.15.111.162:443 sid=c88e0935 e235cfdb
20121004 18:21:59 VERIFY OK: depth=1 /C=IT/ST=IT/L=Perugia/O=airvpn.org/CN=airvpn.org_CA/emailAddress=info@airvpn.org
20121004 18:21:59 VERIFY OK: nsCertType=SERVER
20121004 18:21:59 VERIFY OK: depth=0 /C=IT/ST=IT/L=Perugia/O=airvpn.org/CN=server/emailAddress=info@airvpn.org
20121004 18:22:03 MANAGEMENT: Client connected from 127.0.0.1:5001
20121004 18:22:03 D MANAGEMENT: CMD 'state'
20121004 18:22:03 MANAGEMENT: Client disconnected
20121004 18:22:03 D MANAGEMENT: CMD 'log 500'
19700101 00:00:00
changed and here is log
Setup
Wireless
Services
Security
Access Restrictions
NAT / QoS
Administration
Status
Router
WAN
LAN
Wireless
OpenVPN
Bandwidth
Sys-Info
State Server: : Local Address: Remote Address: Client: GET_CONFIG: Local Address: Remote Address:
Status
Log Serverlog Clientlog 20121004 18:34:27 I OpenVPN 2.2.1 mips-linux [sSL] [LZO2] built on Mar 19 2012
20121004 18:34:27 MANAGEMENT: TCP Socket listening on 127.0.0.1:5001
20121004 18:34:27 W NOTE: the current --script-security setting may allow this configuration to call user-defined scripts
20121004 18:34:27 W WARNING: file '/tmp/openvpncl/client.key' is group or others accessible
20121004 18:34:27 I LZO compression initialized
20121004 18:34:27 Control Channel MTU parms [ L:1558 D:138 EF:38 EB:0 ET:0 EL:0 ]
20121004 18:34:27 Socket Buffers: R=[163840->131072] S=[163840->131072]
20121004 18:34:27 Data Channel MTU parms [ L:1558 D:1450 EF:58 EB:135 ET:0 EL:0 AF:3/1 ]
20121004 18:34:27 Local Options String: 'V4 dev-type tun link-mtu 1558 tun-mtu 1500 proto UDPv4 comp-lzo cipher AES-256-CBC auth SHA1 keysize 256 key-method 2 tls-client'
20121004 18:34:27 Expected Remote Options String: 'V4 dev-type tun link-mtu 1558 tun-mtu 1500 proto UDPv4 comp-lzo cipher AES-256-CBC auth SHA1 keysize 256 key-method 2 tls-server'
20121004 18:34:27 Local Options hash (VER=V4): '22188c5b'
20121004 18:34:27 Expected Remote Options hash (VER=V4): 'a8f55717'
20121004 18:34:27 I UDPv4 link local: [undef]
20121004 18:34:27 I UDPv4 link remote: 69.163.36.66:443
20121004 18:34:27 TLS: Initial packet from 69.163.36.66:443 sid=e76036d1 f86642a6
20121004 18:34:27 VERIFY OK: depth=1 /C=IT/ST=IT/L=Perugia/O=airvpn.org/CN=airvpn.org_CA/emailAddress=info@airvpn.org
20121004 18:34:27 VERIFY OK: nsCertType=SERVER
20121004 18:34:27 VERIFY OK: depth=0 /C=IT/ST=IT/L=Perugia/O=airvpn.org/CN=server/emailAddress=info@airvpn.org
20121004 18:34:29 Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
20121004 18:34:29 NOTE: --mute triggered...
20121004 18:34:29 4 variation(s) on previous 5 message(s) suppressed by --mute
20121004 18:34:29 I [server] Peer Connection Initiated with 69.163.36.66:443
20121004 18:34:30 MANAGEMENT: Client connected from 127.0.0.1:5001
20121004 18:34:30 D MANAGEMENT: CMD 'state'
20121004 18:34:30 MANAGEMENT: Client disconnected
20121004 18:34:30 D MANAGEMENT: CMD 'log 500'
19700101 00:00:00
ok, connected now, but new problem, cant connect to any sites other than airvpn
Serverlog Clientlog 20121004 19:07:49 Control Channel MTU parms [ L:1558 D:138 EF:38 EB:0 ET:0 EL:0 ]
20121004 19:07:49 Socket Buffers: R=[163840->131072] S=[163840->131072]
20121004 19:07:49 Data Channel MTU parms [ L:1558 D:1450 EF:58 EB:135 ET:0 EL:0 AF:3/1 ]
20121004 19:07:49 Local Options String: 'V4 dev-type tun link-mtu 1558 tun-mtu 1500 proto UDPv4 comp-lzo cipher AES-256-CBC auth SHA1 keysize 256 key-method 2 tls-client'
20121004 19:07:49 Expected Remote Options String: 'V4 dev-type tun link-mtu 1558 tun-mtu 1500 proto UDPv4 comp-lzo cipher AES-256-CBC auth SHA1 keysize 256 key-method 2 tls-server'
20121004 19:07:49 Local Options hash (VER=V4): '22188c5b'
20121004 19:07:49 Expected Remote Options hash (VER=V4): 'a8f55717'
20121004 19:07:49 I UDPv4 link local: [undef]
20121004 19:07:49 I UDPv4 link remote: 69.163.36.66:443
20121004 19:07:49 TLS: Initial packet from 69.163.36.66:443 sid=bf43cf69 700b22be
20121004 19:07:50 VERIFY OK: depth=1 /C=IT/ST=IT/L=Perugia/O=airvpn.org/CN=airvpn.org_CA/emailAddress=info@airvpn.org
20121004 19:07:50 VERIFY OK: nsCertType=SERVER
20121004 19:07:50 VERIFY OK: depth=0 /C=IT/ST=IT/L=Perugia/O=airvpn.org/CN=server/emailAddress=info@airvpn.org
20121004 19:07:51 Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
20121004 19:07:51 NOTE: --mute triggered...
20121004 19:07:51 4 variation(s) on previous 5 message(s) suppressed by --mute
20121004 19:07:51 I [server] Peer Connection Initiated with 69.163.36.66:443
20121004 19:07:53 SENT CONTROL [server]: 'PUSH_REQUEST' (status=1)
20121004 19:07:53 PUSH: Received control message: 'PUSH_REPLY redirect-gateway def1 dhcp-option DNS 10.4.0.1 comp-lzo no route 10.4.0.1 topology net30 ping 10 ping-restart 120 ifconfig 10.4.0.6 10.4.0.5'
20121004 19:07:53 OPTIONS IMPORT: timers and/or timeouts modified
20121004 19:07:53 OPTIONS IMPORT: LZO parms modified
20121004 19:07:53 OPTIONS IMPORT: --ifconfig/up options modified
20121004 19:07:53 NOTE: --mute triggered...
20121004 19:07:53 2 variation(s) on previous 5 message(s) suppressed by --mute
20121004 19:07:53 I TUN/TAP device tun1 opened
20121004 19:07:53 TUN/TAP TX queue length set to 100
20121004 19:07:53 I /sbin/ifconfig tun1 10.4.0.6 pointopoint 10.4.0.5 mtu 1500
20121004 19:07:53 /sbin/route add -net 69.163.36.66 netmask 255.255.255.255 gw 24.156.90.1
20121004 19:07:53 /sbin/route add -net 0.0.0.0 netmask 128.0.0.0 gw 10.4.0.5
20121004 19:07:53 /sbin/route add -net 128.0.0.0 netmask 128.0.0.0 gw 10.4.0.5
20121004 19:07:53 /sbin/route add -net 10.4.0.1 netmask 255.255.255.255 gw 10.4.0.5
20121004 19:07:53 I Initialization Sequence Completed
20121004 19:08:28 N write UDPv4 [EMSGSIZE Path-MTU=900]: Message too long (code=97)
20121004 19:08:29 N write UDPv4 [EMSGSIZE Path-MTU=900]: Message too long (code=97)
20121004 19:08:30 N write UDPv4 [EMSGSIZE Path-MTU=900]: Message too long (code=97)
20121004 19:09:16 N write UDPv4 [EMSGSIZE Path-MTU=900]: Message too long (code=97)
20121004 19:09:16 NOTE: --mute triggered...
20121004 19:11:39 110 variation(s) on previous 5 message(s) suppressed by --mute
20121004 19:11:39 MANAGEMENT: Client connected from 127.0.0.1:5001
20121004 19:11:39 D MANAGEMENT: CMD 'state'
20121004 19:11:39 MANAGEMENT: Client disconnected
20121004 19:11:39 D MANAGEMENT: CMD 'log 500'
19700101 00:00:00
managed to solve this some how, everytihng appears to work just fine...thank you
Thank you very much for the information. We're very glad to know that you managed to solve the problem.
In order to help possible other customers with the same router model, can you please publish your solution at your convenience?
Thanks in advance.
dont really know what the solution was, tried every american server a few times with the same results (no being able to load any pages) then as i was on about my 10th try it was working lol. but my router in wndr3700v1 on firmware 18777
