Not connected, Your IP: 3.147.64.87
billycryptokid
Tunnel Direct not found
When loading AIRVPN on Raspberry Pi 4, I am randomly getting a "Tunnel Direct not found and cant be installed." anyone have some insight to this? I feel i've tried quite a few things with no resolution.
Do you run Eddie or Hummingbird? What is the installed distribution, Raspbian 32 bit or some Linux 64 bit?
RunningEddie, and  Raspbian 32bit
I've tried a apt-get --purge remove eddie-ui , and then install as normal, however Im not familiar with a dependency called "Tunnel Direct." Is there a package I need to install for Tunnel Direct?
Please make sure that you have Raspbian 10 or higher version, then can you please check what happens with Hummingbird for Raspbian? Hummingbird is a stand alone binary. If any issue persists, feel free to post the log, both from Eddie and Hummingbird.
https://airvpn.org/linux/#Hummingbird
