sapience 0 Posted ... I disabled network lock, logged out eddie. Since then when I try to login to eddie i get the following error: --------------------------- Eddie --------------------------- Cannot login. (curl: (7) Failed to connect to 127.0.0.1 port 8080: Connection refused) --------------------------- OK --------------------------- Logs below. Please help . 2020.02.05 17:52:19 - Eddie version: 2.16.3 / windows_x64, System: Windows, Name: Windows 10 Home, Version: Microsoft Windows NT 10.0.17134.0, Mono/.Net: v4.0.30319 . 2020.02.05 17:52:19 - Reading options from C:\Users\Server\AppData\Local\AirVPN\default.xml . 2020.02.05 17:52:19 - Command line arguments (1): path="home" . 2020.02.05 17:52:19 - Profile path: C:\Users\Server\AppData\Local\AirVPN\default.xml . 2020.02.05 17:52:23 - OpenVPN Driver - TAP-Windows Adapter V9, version 9.23.3 . 2020.02.05 17:52:23 - OpenVPN - Version: 2.4.6 - OpenSSL 1.1.0h 27 Mar 2018, LZO 2.10 (C:\Program Files\AirVPN\openvpn.exe) . 2020.02.05 17:52:23 - SSH - Version: plink 0.67 (C:\Program Files\AirVPN\plink.exe) . 2020.02.05 17:52:23 - SSL - Version: stunnel 5.40 (C:\Program Files\AirVPN\stunnel.exe) . 2020.02.05 17:52:23 - curl - Version: 7.68.0 (C:\Program Files\AirVPN\curl.exe) . 2020.02.05 17:52:23 - Certification Authorities: C:\Program Files\AirVPN\res\cacert.pem . 2020.02.05 17:52:25 - Updating systems & servers data ... I 2020.02.05 17:52:25 - Ready . 2020.02.05 17:52:30 - Cannot retrieve systems & servers data. (curl: (7) Failed to connect to 127.0.0.1 port 8080: Connection refused) . 2020.02.05 17:52:32 - Updating systems & servers data ... . 2020.02.05 17:52:37 - Cannot retrieve systems & servers data. (curl: (7) Failed to connect to 127.0.0.1 port 8080: Connection refused) . 2020.02.05 17:52:41 - Updating systems & servers data ... . 2020.02.05 17:52:46 - Cannot retrieve systems & servers data. (curl: (7) Failed to connect to 127.0.0.1 port 8080: Connection refused) . 2020.02.05 17:52:49 - Updating systems & servers data ... . 2020.02.05 17:52:54 - Cannot retrieve systems & servers data. (curl: (7) Failed to connect to 127.0.0.1 port 8080: Connection refused) . 2020.02.05 17:52:56 - Updating systems & servers data ... . 2020.02.05 17:53:01 - Cannot retrieve systems & servers data. (curl: (7) Failed to connect to 127.0.0.1 port 8080: Connection refused) . 2020.02.05 17:53:03 - Updating systems & servers data ... . 2020.02.05 17:53:08 - Cannot retrieve systems & servers data. (curl: (7) Failed to connect to 127.0.0.1 port 8080: Connection refused) . 2020.02.05 17:53:11 - Updating systems & servers data ... . 2020.02.05 17:53:16 - Cannot retrieve systems & servers data. (curl: (7) Failed to connect to 127.0.0.1 port 8080: Connection refused) Quote Share this post Link to post
Tech Jedi Alex 1571 Posted ... Does it work after a reboot? Quote Hide Tech Jedi Alex's signature Hide all signatures NOT AN AIRVPN TEAM MEMBER. USE TICKETS FOR PROFESSIONAL SUPPORT. LZ1's New User Guide to AirVPN « Plenty of stuff for advanced users, too! Want to contact me directly? All relevant methods are on my About me page. Share this post Link to post
Staff 10639 Posted ... @sapience Hello! What do you have listening to port 8080 of localhost (127.0.0.1)? According to the log, connection to it is refused. It seems that Eddie is configured to connect to a local proxy listening to port 8080, but that proxy refuses connections (or it is not running?), or a firewall blocks curl packets to your proxy. Can you also post a system report generated by Eddie? Kind regards Quote Share this post Link to post
sapience 0 Posted ... Thanks for the response, Nothing is listening to port 8080. And I dont use a proxy. Other VPN like ExpressVPN and ProtonVPN connects without problem. Where do I find the system report generated by Eddie? Quote Share this post Link to post
Staff 10639 Posted ... @sapience If nothing listens to port 8080 of your localhost, it's strange that you have forced Eddie to connect to it. A system report will let us see the complete Eddie configuration to confirm or not that it has been misconfigured and possibly it will provide us with more clues to understand the source of the issue. To generate a system report please click "Logs" from Eddie's main window, click the LIFE BELT icon, click the Copy all icon; then send the report to us by pasting into your message. Please make sure to generate the system report after the problem has just occurred. Kind regards Quote Share this post Link to post
sapience 0 Posted ... (edited) Please find the complete system report below: Eddie System/Environment Report - 2/8/2020 8:03 PM UTC Eddie version: 2.16.3 Eddie OS build: windows_x64 Eddie architecture: x64 OS type: Windows OS name: Windows 10 Home OS version: Microsoft Windows NT 10.0.17134.0 OS architecture: x64 Mono /.Net Framework: v4.0.30319 OpenVPN driver: TAP-Windows Adapter V9, version 9.23.3 OpenVPN: 2.4.6 - OpenSSL 1.1.0h 27 Mar 2018, LZO 2.10 (C:\Program Files\AirVPN\openvpn.exe) SSH: plink 0.67 (C:\Program Files\AirVPN\plink.exe) SSL: stunnel 5.40 (C:\Program Files\AirVPN\stunnel.exe) curl: 7.68.0 (C:\Program Files\AirVPN\curl.exe) Profile path: C:\Users\Server\AppData\Local\AirVPN\default.xml Data path: C:\Users\Server\AppData\Local\AirVPN Application path: C:\Program Files\AirVPN Executable path: C:\Program Files\AirVPN\Eddie-UI.exe Command line arguments: (1 args) path="home" Network Lock Active: No Connected to VPN: No Detected DNS: 172.16.3.1, 192.168.0.1 Test DNS IPv4: Failed Test DNS IPv6: Failed Test Ping IPv4: -1 ms Test Ping IPv6: -1 ms Test HTTP IPv4: Error:curl: (7) Failed to connect to 127.0.0.1 port 8080: Connection refused Test HTTP IPv6: Error:curl: (7) Failed to connect to 127.0.0.1 port 8080: Connection refused Test HTTPS: Error:curl: (6) Could not resolve host: eddie.website ---------------------------- Important options not at defaults: login: (omissis) password: (omissis) remember: True advanced.expert: True ---------------------------- Logs: . 2020.02.08 15:02:05 - Eddie version: 2.16.3 / windows_x64, System: Windows, Name: Windows 10 Home, Version: Microsoft Windows NT 10.0.17134.0, Mono/.Net: v4.0.30319 . 2020.02.08 15:02:05 - Reading options from C:\Users\Server\AppData\Local\AirVPN\default.xml . 2020.02.08 15:02:05 - Command line arguments (1): path="home" . 2020.02.08 15:02:05 - Profile path: C:\Users\Server\AppData\Local\AirVPN\default.xml . 2020.02.08 15:02:08 - OpenVPN Driver - TAP-Windows Adapter V9, version 9.23.3 . 2020.02.08 15:02:08 - OpenVPN - Version: 2.4.6 - OpenSSL 1.1.0h 27 Mar 2018, LZO 2.10 (C:\Program Files\AirVPN\openvpn.exe) . 2020.02.08 15:02:08 - SSH - Version: plink 0.67 (C:\Program Files\AirVPN\plink.exe) . 2020.02.08 15:02:08 - SSL - Version: stunnel 5.40 (C:\Program Files\AirVPN\stunnel.exe) . 2020.02.08 15:02:08 - curl - Version: 7.68.0 (C:\Program Files\AirVPN\curl.exe) . 2020.02.08 15:02:08 - Certification Authorities: C:\Program Files\AirVPN\res\cacert.pem . 2020.02.08 15:02:09 - Updating systems & servers data ... I 2020.02.08 15:02:09 - Ready . 2020.02.08 15:02:10 - Updating systems & servers data ..., 1° try failed (curl: (7) Failed to connect to 127.0.0.1 port 8080: Connection refused) . 2020.02.08 15:02:12 - Updating systems & servers data ..., 2° try failed (curl: (7) Failed to connect to 127.0.0.1 port 8080: Connection refused) . 2020.02.08 15:02:13 - Updating systems & servers data ..., 3° try failed (curl: (7) Failed to connect to 127.0.0.1 port 8080: Connection refused) . 2020.02.08 15:02:14 - Updating systems & servers data ..., 4° try failed (curl: (7) Failed to connect to 127.0.0.1 port 8080: Connection refused) . 2020.02.08 15:02:14 - Cannot retrieve systems & servers data. (curl: (7) Failed to connect to 127.0.0.1 port 8080: Connection refused) . 2020.02.08 15:02:17 - Updating systems & servers data ... . 2020.02.08 15:02:18 - Updating systems & servers data ..., 1° try failed (curl: (7) Failed to connect to 127.0.0.1 port 8080: Connection refused) . 2020.02.08 15:02:19 - Updating systems & servers data ..., 2° try failed (curl: (7) Failed to connect to 127.0.0.1 port 8080: Connection refused) . 2020.02.08 15:02:20 - Updating systems & servers data ..., 3° try failed (curl: (7) Failed to connect to 127.0.0.1 port 8080: Connection refused) . 2020.02.08 15:02:22 - Updating systems & servers data ..., 4° try failed (curl: (7) Failed to connect to 127.0.0.1 port 8080: Connection refused) . 2020.02.08 15:02:22 - Cannot retrieve systems & servers data. (curl: (7) Failed to connect to 127.0.0.1 port 8080: Connection refused) . 2020.02.08 15:02:37 - Updating systems & servers data ... . 2020.02.08 15:02:39 - Updating systems & servers data ..., 1° try failed (curl: (7) Failed to connect to 127.0.0.1 port 8080: Connection refused) I 2020.02.08 15:02:40 - Checking login ... . 2020.02.08 15:02:40 - Updating systems & servers data ..., 2° try failed (curl: (7) Failed to connect to 127.0.0.1 port 8080: Connection refused) . 2020.02.08 15:02:41 - Checking login ..., 1° try failed (curl: (7) Failed to connect to 127.0.0.1 port 8080: Connection refused) . 2020.02.08 15:02:41 - Updating systems & servers data ..., 3° try failed (curl: (7) Failed to connect to 127.0.0.1 port 8080: Connection refused) . 2020.02.08 15:02:42 - Checking login ..., 2° try failed (curl: (7) Failed to connect to 127.0.0.1 port 8080: Connection refused) . 2020.02.08 15:02:43 - Updating systems & servers data ..., 4° try failed (curl: (7) Failed to connect to 127.0.0.1 port 8080: Connection refused) . 2020.02.08 15:02:43 - Cannot retrieve systems & servers data. (curl: (7) Failed to connect to 127.0.0.1 port 8080: Connection refused) . 2020.02.08 15:02:44 - Checking login ..., 3° try failed (curl: (7) Failed to connect to 127.0.0.1 port 8080: Connection refused) . 2020.02.08 15:02:44 - Updating systems & servers data ... . 2020.02.08 15:02:45 - Checking login ..., 4° try failed (curl: (7) Failed to connect to 127.0.0.1 port 8080: Connection refused) F 2020.02.08 15:02:45 - Cannot login. (curl: (7) Failed to connect to 127.0.0.1 port 8080: Connection refused) . 2020.02.08 15:02:46 - Updating systems & servers data ..., 1° try failed (curl: (7) Failed to connect to 127.0.0.1 port 8080: Connection refused) . 2020.02.08 15:02:49 - Updating systems & servers data ..., 2° try failed (curl: (7) Failed to connect to 127.0.0.1 port 8080: Connection refused) . 2020.02.08 15:02:52 - Updating systems & servers data ..., 3° try failed (curl: (7) Failed to connect to 127.0.0.1 port 8080: Connection refused) . 2020.02.08 15:02:54 - Updating systems & servers data ..., 4° try failed (curl: (7) Failed to connect to 127.0.0.1 port 8080: Connection refused) . 2020.02.08 15:02:54 - Cannot retrieve systems & servers data. (curl: (7) Failed to connect to 127.0.0.1 port 8080: Connection refused) . 2020.02.08 15:02:56 - Updating systems & servers data ... . 2020.02.08 15:02:57 - Updating systems & servers data ..., 1° try failed (curl: (7) Failed to connect to 127.0.0.1 port 8080: Connection refused) . 2020.02.08 15:03:00 - Updating systems & servers data ..., 2° try failed (curl: (7) Failed to connect to 127.0.0.1 port 8080: Connection refused) . 2020.02.08 15:03:01 - Updating systems & servers data ..., 3° try failed (curl: (7) Failed to connect to 127.0.0.1 port 8080: Connection refused) . 2020.02.08 15:03:03 - Updating systems & servers data ..., 4° try failed (curl: (7) Failed to connect to 127.0.0.1 port 8080: Connection refused) . 2020.02.08 15:03:03 - Cannot retrieve systems & servers data. (curl: (7) Failed to connect to 127.0.0.1 port 8080: Connection refused) ---------------------------- Network Interfaces and Routes: { "support_ipv4": true, "support_ipv6": true, "routes": [ { "address": "0.0.0.0\/0", "interface": "{10CA0AE9-1765-4D2F-A8C9-FFD02BBD45C1}", "gateway": "192.168.0.1", "metric": "40" }, { "address": "10.0.0.0\/8", "interface": "{10CA0AE9-1765-4D2F-A8C9-FFD02BBD45C1}", "gateway": "192.168.0.1", "metric": "296" }, { "address": "127.0.0.0\/8", "interface": "{92779E6B-D2D9-11E7-8AA3-806E6F6E6963}", "gateway": "link", "metric": "331" }, { "address": "127.0.0.1", "interface": "{92779E6B-D2D9-11E7-8AA3-806E6F6E6963}", "gateway": "link", "metric": "331" }, { "address": "127.255.255.255", "interface": "{92779E6B-D2D9-11E7-8AA3-806E6F6E6963}", "gateway": "link", "metric": "331" }, { "address": "172.16.0.0\/12", "interface": "{10CA0AE9-1765-4D2F-A8C9-FFD02BBD45C1}", "gateway": "192.168.0.1", "metric": "296" }, { "address": "192.168.0.0\/16", "interface": "{10CA0AE9-1765-4D2F-A8C9-FFD02BBD45C1}", "gateway": "192.168.0.1", "metric": "296" }, { "address": "192.168.0.0\/24", "interface": "{10CA0AE9-1765-4D2F-A8C9-FFD02BBD45C1}", "gateway": "link", "metric": "296" }, { "address": "192.168.0.110", "interface": "{10CA0AE9-1765-4D2F-A8C9-FFD02BBD45C1}", "gateway": "link", "metric": "296" }, { "address": "192.168.0.255", "interface": "{10CA0AE9-1765-4D2F-A8C9-FFD02BBD45C1}", "gateway": "link", "metric": "296" }, { "address": "192.168.111.0\/24", "interface": "{399016C9-B615-4165-B959-2A2B40D02EDD}", "gateway": "link", "metric": "291" }, { "address": "192.168.111.1", "interface": "{399016C9-B615-4165-B959-2A2B40D02EDD}", "gateway": "link", "metric": "291" }, { "address": "192.168.111.255", "interface": "{399016C9-B615-4165-B959-2A2B40D02EDD}", "gateway": "link", "metric": "291" }, { "address": "192.168.206.0\/24", "interface": "{46F1F7F3-4159-4A8B-9602-98644F19EC06}", "gateway": "link", "metric": "291" }, { "address": "192.168.206.1", "interface": "{46F1F7F3-4159-4A8B-9602-98644F19EC06}", "gateway": "link", "metric": "291" }, { "address": "192.168.206.255", "interface": "{46F1F7F3-4159-4A8B-9602-98644F19EC06}", "gateway": "link", "metric": "291" }, { "address": "224.0.0.0\/4", "interface": "{92779E6B-D2D9-11E7-8AA3-806E6F6E6963}", "gateway": "link", "metric": "331" }, { "address": "224.0.0.0\/4", "interface": "{399016C9-B615-4165-B959-2A2B40D02EDD}", "gateway": "link", "metric": "291" }, { "address": "224.0.0.0\/4", "interface": "{46F1F7F3-4159-4A8B-9602-98644F19EC06}", "gateway": "link", "metric": "291" }, { "address": "224.0.0.0\/4", "interface": "{10CA0AE9-1765-4D2F-A8C9-FFD02BBD45C1}", "gateway": "link", "metric": "296" }, { "address": "255.255.255.255", "interface": "{92779E6B-D2D9-11E7-8AA3-806E6F6E6963}", "gateway": "link", "metric": "331" }, { "address": "255.255.255.255", "interface": "{399016C9-B615-4165-B959-2A2B40D02EDD}", "gateway": "link", "metric": "291" }, { "address": "255.255.255.255", "interface": "{46F1F7F3-4159-4A8B-9602-98644F19EC06}", "gateway": "link", "metric": "291" }, { "address": "255.255.255.255", "interface": "{10CA0AE9-1765-4D2F-A8C9-FFD02BBD45C1}", "gateway": "link", "metric": "296" }, { "address": "::1", "interface": "{92779E6B-D2D9-11E7-8AA3-806E6F6E6963}", "gateway": "link", "metric": "331" }, { "address": "ff00::\/8", "interface": "{92779E6B-D2D9-11E7-8AA3-806E6F6E6963}", "gateway": "link", "metric": "331" }, { "address": "2001:ac8:31:5c:327:6f84:20d:805e", "gateway": "fde6:7a:7d20:dfe::1", "metric": "4294967295" }, { "address": "2a01:a500:320:52a4:c626:3328:bc3c:1a5f", "gateway": "fde6:7a:7d20:136::1", "metric": "4294967295" }, { "address": "2001:ac8:31:4:1ce5:5dfc:8948:fb43", "gateway": "fde6:7a:7d20:62e::1", "metric": "4294967295" } ], "interfaces": [ { "friendly": "Ethernet 3", "id": "{570FE35D-0F67-4D8D-8C9A-A10FAD1C9A2E}", "name": "Ethernet 3", "description": "TAP-Windows Adapter V9", "type": "Ethernet", "status": "Down", "bytes_received": "0", "bytes_sent": "0", "support_ipv4": true, "support_ipv6": false, "ips": [ "169.254.65.80" ], "gateways": [], "bind": true, "dns4": "", "dns6": null }, { "friendly": "Ethernet 4", "id": "{751147EC-D3E3-43F4-82C1-F72E6CC5DADE}", "name": "Ethernet 4", "description": "TAP-ProtonVPN Windows Adapter V9", "type": "Ethernet", "status": "Down", "bytes_received": "0", "bytes_sent": "0", "support_ipv4": true, "support_ipv6": false, "ips": [ "169.254.171.183" ], "gateways": [], "bind": true, "dns4": "", "dns6": null }, { "friendly": "Local Area Connection* 2", "id": "{694B6215-8C40-4412-96A7-451EE1001768}", "name": "Local Area Connection* 2", "description": "Microsoft Wi-Fi Direct Virtual Adapter", "type": "Wireless80211", "status": "Down", "bytes_received": "0", "bytes_sent": "0", "support_ipv4": true, "support_ipv6": false, "ips": [ "169.254.192.146" ], "gateways": [], "bind": true, "dns4": "", "dns6": null }, { "friendly": "Local Area Connection* 3", "id": "{B75A8602-9D39-41F6-8F5B-E8BC05CF5037}", "name": "Local Area Connection* 3", "description": "Microsoft Wi-Fi Direct Virtual Adapter #3", "type": "Wireless80211", "status": "Down", "bytes_received": "0", "bytes_sent": "0", "support_ipv4": true, "support_ipv6": false, "ips": [ "169.254.56.87" ], "gateways": [], "bind": true, "dns4": "", "dns6": null }, { "friendly": "VMware Network Adapter VMnet1", "id": "{46F1F7F3-4159-4A8B-9602-98644F19EC06}", "name": "VMware Network Adapter VMnet1", "description": "VMware Virtual Ethernet Adapter for VMnet1", "type": "Ethernet", "status": "Up", "bytes_received": "46", "bytes_sent": "81038", "support_ipv4": true, "support_ipv6": false, "ips": [ "192.168.206.1" ], "gateways": [], "bind": true, "dns4": "172.16.3.1", "dns6": null }, { "friendly": "VMware Network Adapter VMnet8", "id": "{399016C9-B615-4165-B959-2A2B40D02EDD}", "name": "VMware Network Adapter VMnet8", "description": "VMware Virtual Ethernet Adapter for VMnet8", "type": "Ethernet", "status": "Up", "bytes_received": "47", "bytes_sent": "93671", "support_ipv4": true, "support_ipv6": false, "ips": [ "192.168.111.1" ], "gateways": [], "bind": true, "dns4": "172.16.3.1", "dns6": null }, { "friendly": "Wi-Fi", "id": "{10CA0AE9-1765-4D2F-A8C9-FFD02BBD45C1}", "name": "Wi-Fi", "description": "Intel(R) Dual Band Wireless-AC 7265", "type": "Wireless80211", "status": "Up", "bytes_received": "355796357", "bytes_sent": "107412602", "support_ipv4": true, "support_ipv6": false, "ips": [ "192.168.0.110" ], "gateways": [ "192.168.0.1" ], "bind": true, "dns4": "", "dns6": null }, { "friendly": "Loopback Pseudo-Interface 1", "id": "{92779E6B-D2D9-11E7-8AA3-806E6F6E6963}", "name": "Loopback Pseudo-Interface 1", "description": "Software Loopback Interface 1", "type": "Loopback", "status": "Up", "bytes_received": "0", "bytes_sent": "0", "support_ipv4": true, "support_ipv6": true, "ips": [ "::1", "127.0.0.1" ], "gateways": [], "bind": true, "dns4": "", "dns6": null } ], "ipv4-default-gateway": "192.168.0.1", "ipv4-default-interface": "{10CA0AE9-1765-4D2F-A8C9-FFD02BBD45C1}" } ---------------------------- ipconfig /all: Windows IP Configuration Host Name . . . . . . . . . . . . : DESKTOP-B76JJFH Primary Dns Suffix . . . . . . . : Node Type . . . . . . . . . . . . : Hybrid IP Routing Enabled. . . . . . . . : No WINS Proxy Enabled. . . . . . . . : No Ethernet adapter Ethernet 3: Media State . . . . . . . . . . . : Media disconnected Connection-specific DNS Suffix . : Description . . . . . . . . . . . : TAP-Windows Adapter V9 Physical Address. . . . . . . . . : 00-FF-57-0F-E3-5D DHCP Enabled. . . . . . . . . . . : Yes Autoconfiguration Enabled . . . . : Yes Ethernet adapter Ethernet 4: Media State . . . . . . . . . . . : Media disconnected Connection-specific DNS Suffix . : Description . . . . . . . . . . . : TAP-ProtonVPN Windows Adapter V9 Physical Address. . . . . . . . . : 00-FF-75-11-47-EC DHCP Enabled. . . . . . . . . . . : Yes Autoconfiguration Enabled . . . . : Yes Wireless LAN adapter Local Area Connection* 2: Media State . . . . . . . . . . . : Media disconnected Connection-specific DNS Suffix . : Description . . . . . . . . . . . : Microsoft Wi-Fi Direct Virtual Adapter Physical Address. . . . . . . . . : D0-57-7B-8D-E5-0B DHCP Enabled. . . . . . . . . . . : Yes Autoconfiguration Enabled . . . . : Yes Wireless LAN adapter Local Area Connection* 3: Media State . . . . . . . . . . . : Media disconnected Connection-specific DNS Suffix . : Description . . . . . . . . . . . : Microsoft Wi-Fi Direct Virtual Adapter #3 Physical Address. . . . . . . . . : D2-57-7B-8D-E5-0A DHCP Enabled. . . . . . . . . . . : Yes Autoconfiguration Enabled . . . . : Yes Ethernet adapter VMware Network Adapter VMnet1: Connection-specific DNS Suffix . : Description . . . . . . . . . . . : VMware Virtual Ethernet Adapter for VMnet1 Physical Address. . . . . . . . . : 00-50-56-C0-00-01 DHCP Enabled. . . . . . . . . . . : Yes Autoconfiguration Enabled . . . . : Yes IPv4 Address. . . . . . . . . . . : 192.168.206.1(Preferred) Subnet Mask . . . . . . . . . . . : 255.255.255.0 Lease Obtained. . . . . . . . . . : Saturday, February 8, 2020 9:27:12 AM Lease Expires . . . . . . . . . . : Saturday, February 8, 2020 3:27:15 PM Default Gateway . . . . . . . . . : DHCP Server . . . . . . . . . . . : 192.168.206.254 DNS Servers . . . . . . . . . . . : 172.16.3.1 NetBIOS over Tcpip. . . . . . . . : Enabled Ethernet adapter VMware Network Adapter VMnet8: Connection-specific DNS Suffix . : Description . . . . . . . . . . . : VMware Virtual Ethernet Adapter for VMnet8 Physical Address. . . . . . . . . : 00-50-56-C0-00-08 DHCP Enabled. . . . . . . . . . . : Yes Autoconfiguration Enabled . . . . : Yes IPv4 Address. . . . . . . . . . . : 192.168.111.1(Preferred) Subnet Mask . . . . . . . . . . . : 255.255.255.0 Lease Obtained. . . . . . . . . . : Saturday, February 8, 2020 9:27:12 AM Lease Expires . . . . . . . . . . : Saturday, February 8, 2020 3:27:15 PM Default Gateway . . . . . . . . . : DHCP Server . . . . . . . . . . . : 192.168.111.254 DNS Servers . . . . . . . . . . . : 172.16.3.1 Primary WINS Server . . . . . . . : 192.168.111.2 NetBIOS over Tcpip. . . . . . . . : Enabled Wireless LAN adapter Wi-Fi: Connection-specific DNS Suffix . : Description . . . . . . . . . . . : Intel(R) Dual Band Wireless-AC 7265 Physical Address. . . . . . . . . : B2-9C-BF-70-B6-9D DHCP Enabled. . . . . . . . . . . : Yes Autoconfiguration Enabled . . . . : Yes IPv4 Address. . . . . . . . . . . : 192.168.0.110(Preferred) Subnet Mask . . . . . . . . . . . : 255.255.255.0 Lease Obtained. . . . . . . . . . : Saturday, February 8, 2020 11:24:48 AM Lease Expires . . . . . . . . . . : Saturday, February 8, 2020 5:03:22 PM Default Gateway . . . . . . . . . : 192.168.0.1 DHCP Server . . . . . . . . . . . : 192.168.0.1 DNS Servers . . . . . . . . . . . : 192.168.0.1 NetBIOS over Tcpip. . . . . . . . : Enabled Edited ... by giganerd Apply LOG formatting to logs Quote Share this post Link to post
Staff 10639 Posted ... @sapience Nothing wrong with Eddie configuration, so it remains unexplained why Eddie tells curl.exe to download AirVPN data from localhost. Try the following: - make sure that Eddie is not running - rename C:\Users\Server\AppData\Local\AirVPN\default.xml to default.xml.old (it's Eddie's configuration file) - re-run Eddie. When Eddie does not find the configuration file, it creates a new one with default settings - try a connection and check whether the problem persists or not If the problem persists, please test Eddie 2.18 beta 7, please see here to download it:https://airvpn.org/forums/topic/45326-eddie-desktop-218beta-released/ Kind regards Quote Share this post Link to post
sapience 0 Posted ... I tried Eddie 2.18 beta 7. It is the same problem --------------------------- Eddie --------------------------- Cannot login. (curl: (7) Failed to connect to 127.0.0.1 port 8080: Connection refused) --------------------------- OK --------------------------- I even tried the portable version. Same thing. Quote Share this post Link to post
