npv82
Error connecting to particular servers
I get the following error:
'curl:(35) error:1407742E:SSL
routines:SSL23_GET_SERVER_HELLO:tlsv1 alert protocol
version'
This only happens when trying to connect to servers from a particular country.
Any ideas? Thanks
I'm once again astounded by the lack of info in this post. OS? Particular country?
In the Logs tab, click on the lifebelt icon and paste the outputs here, please.
Edited ... by giganerd
Is it "about the lack of" or "by the lack of"?
I'm having the same problem. It just started out of nowhere. Running Windows 7 Home Premium. This happens when trying to connect to any servers.
AirVPN Support Report - Generated 12/24/2020 5:17 PM UTC
-- Environment --
Eddie version: 2.12.4
Eddie OS build: windows_x64
OS type: Windows
OS name: Microsoft Windows NT 6.1.7601 Service Pack 1
OS description: Microsoft Windows NT 6.1.7601 Service Pack 1
Mono /.Net Framework: v2.0.50727
OpenVPN driver: TAP-Windows Adapter V9, version 9.21.2
OpenVPN: 2.4.0 - OpenSSL 1.0.2k  26 Jan 2017, LZO 2.09 (C:\Program Files\AirVPN\openvpn.exe)
SSH: plink 0.67 (C:\Program Files\AirVPN\plink.exe)
SSL: stunnel 5.40 (C:\Program Files\AirVPN\stunnel.exe)
curl: 7.34.0 (C:\Program Files\AirVPN\curl.exe)
Profile path: C:\Users\The Dungeon\AppData\Local\AirVPN\AirVPN.xml
Data path: C:\Users\The Dungeon\AppData\Local\AirVPN
Application path: C:\Program Files\AirVPN
Executable path: C:\Program Files\AirVPN\AirVPN.exe
Command line arguments (1): path="home"
-- Important options not at defaults --
login: krytellan
password: (omissis)
remember: True
key: Dungeon
-- Logs --
I 2020.12.24 12:12:20 - Eddie client version: 2.12.4 / windows_x64, System: Windows, Name: Microsoft Windows NT 6.1.7601 Service Pack 1, Mono/.Net Framework: v2.0.50727
. 2020.12.24 12:12:20 - Reading options from C:\Users\The Dungeon\AppData\Local\AirVPN\AirVPN.xml
W 2020.12.24 12:12:20 - Special Christmas deal: save up to 68%
W 2020.12.24 12:12:20 - send a gift to a friend or give yourself the gift of privacy
. 2020.12.24 12:12:20 - Data path: C:\Users\The Dungeon\AppData\Local\AirVPN
. 2020.12.24 12:12:20 - Application path: C:\Program Files\AirVPN
. 2020.12.24 12:12:20 - Executable path: C:\Program Files\AirVPN\AirVPN.exe
. 2020.12.24 12:12:20 - Command line arguments (1): path="home"
. 2020.12.24 12:12:20 - Operating System: Microsoft Windows NT 6.1.7601 Service Pack 1
I 2020.12.24 12:12:21 - OpenVPN Driver - TAP-Windows Adapter V9, version 9.21.2
I 2020.12.24 12:12:21 - OpenVPN - Version: 2.4.0 - OpenSSL 1.0.2k  26 Jan 2017, LZO 2.09 (C:\Program Files\AirVPN\openvpn.exe)
I 2020.12.24 12:12:21 - SSH - Version: plink 0.67 (C:\Program Files\AirVPN\plink.exe)
I 2020.12.24 12:12:21 - SSL - Version: stunnel 5.40 (C:\Program Files\AirVPN\stunnel.exe)
I 2020.12.24 12:12:21 - curl - Version: 7.34.0 (C:\Program Files\AirVPN\curl.exe)
I 2020.12.24 12:12:21 - Certification Authorities: C:\Program Files\AirVPN\cacert.pem
! 2020.12.24 12:12:21 - Ready
. 2020.12.24 12:12:21 - Updating systems & servers data ...
. 2020.12.24 12:12:22 - Systems & servers data update completed
I 2020.12.24 12:14:19 - Session starting.
. 2020.12.24 12:14:19 - IPv6 disabled with packet filtering.
I 2020.12.24 12:14:19 - Checking authorization ...
! 2020.12.24 12:14:20 - Connecting to Avior (Canada, Toronto, Ontario)
. 2020.12.24 12:14:20 - OpenVPN > OpenVPN 2.4.0 x86_64-w64-mingw32 [SSL (OpenSSL)] [LZO] [LZ4] [PKCS11] [AEAD] built on Jan 29 2017
. 2020.12.24 12:14:20 - OpenVPN > Windows version 6.1 (Windows 7) 64bit
. 2020.12.24 12:14:20 - OpenVPN > library versions: OpenSSL 1.0.2k  26 Jan 2017, LZO 2.09
. 2020.12.24 12:14:20 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3100
. 2020.12.24 12:14:20 - OpenVPN > Outgoing Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2020.12.24 12:14:20 - OpenVPN > Incoming Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2020.12.24 12:14:20 - OpenVPN > TCP/UDP: Preserving recently used remote address: [AF_INET]184.75.223.234:443
. 2020.12.24 12:14:20 - OpenVPN > Socket Buffers: R=[8192->262144] S=[8192->262144]
. 2020.12.24 12:14:20 - OpenVPN > UDP link local: (not bound)
. 2020.12.24 12:14:20 - OpenVPN > UDP link remote: [AF_INET]184.75.223.234:443
. 2020.12.24 12:14:20 - OpenVPN > TLS: Initial packet from [AF_INET]184.75.223.234:443, sid=c9b1de4a 1a619641
. 2020.12.24 12:14:20 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
. 2020.12.24 12:14:20 - OpenVPN > Validating certificate key usage
. 2020.12.24 12:14:20 - OpenVPN > ++ Certificate has key usage  00a0, expects 00a0
. 2020.12.24 12:14:20 - OpenVPN > VERIFY KU OK
. 2020.12.24 12:14:20 - OpenVPN > Validating certificate extended key usage
. 2020.12.24 12:14:20 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
. 2020.12.24 12:14:20 - OpenVPN > VERIFY EKU OK
. 2020.12.24 12:14:20 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=Avior, emailAddress=info@airvpn.org
. 2020.12.24 12:14:20 - OpenVPN > Control Channel: TLSv1.2, cipher TLSv1/SSLv3 DHE-RSA-AES256-GCM-SHA384, 4096 bit RSA
. 2020.12.24 12:14:20 - OpenVPN > [Avior] Peer Connection Initiated with [AF_INET]184.75.223.234:443
. 2020.12.24 12:14:21 - OpenVPN > SENT CONTROL [Avior]: 'PUSH_REQUEST' (status=1)
. 2020.12.24 12:14:21 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,comp-lzo no,redirect-gateway  def1 bypass-dhcp,dhcp-option DNS 10.10.240.1,route-gateway 10.10.240.1,topology subnet,ping 10,ping-restart 60,ifconfig 10.10.240.246 255.255.255.0,peer-id 4,cipher AES-256-GCM'
. 2020.12.24 12:14:21 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified
. 2020.12.24 12:14:21 - OpenVPN > OPTIONS IMPORT: compression parms modified
. 2020.12.24 12:14:21 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified
. 2020.12.24 12:14:21 - OpenVPN > OPTIONS IMPORT: route options modified
. 2020.12.24 12:14:21 - OpenVPN > OPTIONS IMPORT: route-related options modified
. 2020.12.24 12:14:21 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified
. 2020.12.24 12:14:21 - OpenVPN > OPTIONS IMPORT: peer-id set
. 2020.12.24 12:14:21 - OpenVPN > OPTIONS IMPORT: adjusting link_mtu to 1625
. 2020.12.24 12:14:21 - OpenVPN > OPTIONS IMPORT: data channel crypto options modified
. 2020.12.24 12:14:21 - OpenVPN > Data Channel Encrypt: Cipher 'AES-256-GCM' initialized with 256 bit key
. 2020.12.24 12:14:21 - OpenVPN > Data Channel Decrypt: Cipher 'AES-256-GCM' initialized with 256 bit key
. 2020.12.24 12:14:21 - OpenVPN > interactive service msg_channel=0
. 2020.12.24 12:14:21 - OpenVPN > ROUTE_GATEWAY 192.168.1.1/255.255.255.0 I=11 HWADDR=30:85:a9:9f:a5:21
. 2020.12.24 12:14:21 - OpenVPN > open_tun
. 2020.12.24 12:14:21 - OpenVPN > TAP-WIN32 device [Local Area Connection 2] opened: \\.\Global\{72D45205-5C9E-42DA-A3BC-CDAAAE4BA810}.tap
. 2020.12.24 12:14:21 - OpenVPN > TAP-Windows Driver Version 9.21
. 2020.12.24 12:14:21 - OpenVPN > Set TAP-Windows TUN subnet mode network/local/netmask = 10.10.240.0/10.10.240.246/255.255.255.0 [SUCCEEDED]
. 2020.12.24 12:14:21 - OpenVPN > Notified TAP-Windows driver to set a DHCP IP/netmask of 10.10.240.246/255.255.255.0 on interface {72D45205-5C9E-42DA-A3BC-CDAAAE4BA810} [DHCP-serv: 10.10.240.254, lease-time: 31536000]
. 2020.12.24 12:14:21 - OpenVPN > Successful ARP Flush on interface [49] {72D45205-5C9E-42DA-A3BC-CDAAAE4BA810}
. 2020.12.24 12:14:21 - OpenVPN > do_ifconfig, tt->did_ifconfig_ipv6_setup=0
. 2020.12.24 12:14:26 - OpenVPN > TEST ROUTES: 1/1 succeeded len=0 ret=1 a=0 u/d=up
. 2020.12.24 12:14:26 - OpenVPN > C:\Windows\system32\route.exe ADD 184.75.223.234 MASK 255.255.255.255 192.168.1.1
. 2020.12.24 12:14:26 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=10 and dwForwardType=4
. 2020.12.24 12:14:26 - OpenVPN > Route addition via IPAPI succeeded [adaptive]
. 2020.12.24 12:14:26 - OpenVPN > C:\Windows\system32\route.exe ADD 0.0.0.0 MASK 128.0.0.0 10.10.240.1
. 2020.12.24 12:14:26 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=20 and dwForwardType=4
. 2020.12.24 12:14:26 - OpenVPN > C:\Windows\system32\route.exe ADD 128.0.0.0 MASK 128.0.0.0 10.10.240.1
. 2020.12.24 12:14:26 - Starting Management Interface
. 2020.12.24 12:14:26 - OpenVPN > Initialization Sequence Completed
. 2020.12.24 12:14:26 - DNS leak protection with packet filtering enabled.
. 2020.12.24 12:14:26 - DNS of a network adapter forced (TAP-Windows Adapter V9, from automatic (10.10.240.1) to 10.10.240.1)
. 2020.12.24 12:14:31 - Flushing DNS
I 2020.12.24 12:14:38 - Checking route
E 2020.12.24 12:14:38 - curl: (35) error:1407742E:SSL routines:SSL23_GET_SERVER_HELLO:tlsv1 alert protocol version
. 2020.12.24 12:14:38 - Checking route (2° try)
E 2020.12.24 12:14:40 - curl: (35) error:1407742E:SSL routines:SSL23_GET_SERVER_HELLO:tlsv1 alert protocol version
. 2020.12.24 12:14:40 - Checking route (3° try)
E 2020.12.24 12:14:42 - curl: (35) error:1407742E:SSL routines:SSL23_GET_SERVER_HELLO:tlsv1 alert protocol version
E 2020.12.24 12:14:42 - Routing checking failed.
. 2020.12.24 12:14:42 - OpenVPN > MANAGEMENT: Client connected from [AF_INET]127.0.0.1:3100
! 2020.12.24 12:14:42 - Disconnecting
. 2020.12.24 12:14:42 - Management - Send 'signal SIGTERM'
. 2020.12.24 12:14:42 - OpenVPN > MANAGEMENT: CMD 'signal SIGTERM'
. 2020.12.24 12:14:42 - OpenVPN > SIGTERM received, sending exit notification to peer
. 2020.12.24 12:14:42 - OpenVpn Management > >INFO:OpenVPN Management Interface Version 1 -- type 'help' for more info
. 2020.12.24 12:14:48 - OpenVPN > C:\Windows\system32\route.exe DELETE 184.75.223.234 MASK 255.255.255.255 192.168.1.1
. 2020.12.24 12:14:48 - OpenVPN > Route deletion via IPAPI succeeded [adaptive]
. 2020.12.24 12:14:48 - OpenVPN > C:\Windows\system32\route.exe DELETE 0.0.0.0 MASK 128.0.0.0 10.10.240.1
. 2020.12.24 12:14:48 - OpenVPN > C:\Windows\system32\route.exe DELETE 128.0.0.0 MASK 128.0.0.0 10.10.240.1
. 2020.12.24 12:14:48 - OpenVPN > Closing TUN/TAP interface
. 2020.12.24 12:14:48 - OpenVPN > SIGTERM[soft,exit-with-notification] received, process exiting
. 2020.12.24 12:14:48 - Connection terminated.
. 2020.12.24 12:14:48 - DNS of a network adapter restored to original settings (TAP-Windows Adapter V9, to automatic)
. 2020.12.24 12:14:48 - DNS leak protection with packet filtering disabled.
I 2020.12.24 12:14:51 - Checking authorization ...
! 2020.12.24 12:14:51 - Connecting to Tyl (Canada, Toronto, Ontario)
. 2020.12.24 12:14:51 - OpenVPN > OpenVPN 2.4.0 x86_64-w64-mingw32 [SSL (OpenSSL)] [LZO] [LZ4] [PKCS11] [AEAD] built on Jan 29 2017
. 2020.12.24 12:14:51 - OpenVPN > Windows version 6.1 (Windows 7) 64bit
. 2020.12.24 12:14:51 - OpenVPN > library versions: OpenSSL 1.0.2k  26 Jan 2017, LZO 2.09
. 2020.12.24 12:14:51 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3100
. 2020.12.24 12:14:51 - OpenVPN > Outgoing Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2020.12.24 12:14:51 - OpenVPN > Incoming Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2020.12.24 12:14:51 - OpenVPN > TCP/UDP: Preserving recently used remote address: [AF_INET]184.75.223.202:443
. 2020.12.24 12:14:51 - OpenVPN > Socket Buffers: R=[8192->262144] S=[8192->262144]
. 2020.12.24 12:14:51 - OpenVPN > UDP link local: (not bound)
. 2020.12.24 12:14:51 - OpenVPN > UDP link remote: [AF_INET]184.75.223.202:443
. 2020.12.24 12:14:51 - OpenVPN > TLS: Initial packet from [AF_INET]184.75.223.202:443, sid=c8cec362 e1653d65
. 2020.12.24 12:14:51 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
. 2020.12.24 12:14:51 - OpenVPN > Validating certificate key usage
. 2020.12.24 12:14:51 - OpenVPN > ++ Certificate has key usage  00a0, expects 00a0
. 2020.12.24 12:14:51 - OpenVPN > VERIFY KU OK
. 2020.12.24 12:14:51 - OpenVPN > Validating certificate extended key usage
. 2020.12.24 12:14:51 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
. 2020.12.24 12:14:51 - OpenVPN > VERIFY EKU OK
. 2020.12.24 12:14:51 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=Tyl, emailAddress=info@airvpn.org
. 2020.12.24 12:14:52 - OpenVPN > Control Channel: TLSv1.2, cipher TLSv1/SSLv3 DHE-RSA-AES256-GCM-SHA384, 4096 bit RSA
. 2020.12.24 12:14:52 - OpenVPN > [Tyl] Peer Connection Initiated with [AF_INET]184.75.223.202:443
. 2020.12.24 12:14:53 - OpenVPN > SENT CONTROL [Tyl]: 'PUSH_REQUEST' (status=1)
. 2020.12.24 12:14:53 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,comp-lzo no,redirect-gateway  def1 bypass-dhcp,dhcp-option DNS 10.31.208.1,route-gateway 10.31.208.1,topology subnet,ping 10,ping-restart 60,ifconfig 10.31.208.89 255.255.255.0,peer-id 2,cipher AES-256-GCM'
. 2020.12.24 12:14:53 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified
. 2020.12.24 12:14:53 - OpenVPN > OPTIONS IMPORT: compression parms modified
. 2020.12.24 12:14:53 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified
. 2020.12.24 12:14:53 - OpenVPN > OPTIONS IMPORT: route options modified
. 2020.12.24 12:14:53 - OpenVPN > OPTIONS IMPORT: route-related options modified
. 2020.12.24 12:14:53 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified
. 2020.12.24 12:14:53 - OpenVPN > OPTIONS IMPORT: peer-id set
. 2020.12.24 12:14:53 - OpenVPN > OPTIONS IMPORT: adjusting link_mtu to 1625
. 2020.12.24 12:14:53 - OpenVPN > OPTIONS IMPORT: data channel crypto options modified
. 2020.12.24 12:14:53 - OpenVPN > Data Channel Encrypt: Cipher 'AES-256-GCM' initialized with 256 bit key
. 2020.12.24 12:14:53 - OpenVPN > Data Channel Decrypt: Cipher 'AES-256-GCM' initialized with 256 bit key
. 2020.12.24 12:14:53 - OpenVPN > interactive service msg_channel=0
. 2020.12.24 12:14:53 - OpenVPN > ROUTE_GATEWAY 192.168.1.1/255.255.255.0 I=11 HWADDR=30:85:a9:9f:a5:21
. 2020.12.24 12:14:53 - OpenVPN > open_tun
. 2020.12.24 12:14:53 - OpenVPN > TAP-WIN32 device [Local Area Connection 2] opened: \\.\Global\{72D45205-5C9E-42DA-A3BC-CDAAAE4BA810}.tap
. 2020.12.24 12:14:53 - OpenVPN > TAP-Windows Driver Version 9.21
. 2020.12.24 12:14:53 - OpenVPN > Set TAP-Windows TUN subnet mode network/local/netmask = 10.31.208.0/10.31.208.89/255.255.255.0 [SUCCEEDED]
. 2020.12.24 12:14:53 - OpenVPN > Notified TAP-Windows driver to set a DHCP IP/netmask of 10.31.208.89/255.255.255.0 on interface {72D45205-5C9E-42DA-A3BC-CDAAAE4BA810} [DHCP-serv: 10.31.208.254, lease-time: 31536000]
. 2020.12.24 12:14:53 - OpenVPN > Successful ARP Flush on interface [49] {72D45205-5C9E-42DA-A3BC-CDAAAE4BA810}
. 2020.12.24 12:14:53 - OpenVPN > do_ifconfig, tt->did_ifconfig_ipv6_setup=0
! 2020.12.24 12:14:57 - Disconnecting
. 2020.12.24 12:14:57 - Connection terminated.
I 2020.12.24 12:14:58 - Cancel requested.
. 2020.12.24 12:14:58 - IPv6 restored with packet filtering.
. 2020.12.24 12:14:58 - Flushing DNS
! 2020.12.24 12:15:07 - Session terminated.
-- System --
Network Interface: Local Area Connection 2 (TAP-Windows Adapter V9, ID:{72D45205-5C9E-42DA-A3BC-CDAAAE4BA810}) - Ethernet - Down
Network Interface: Local Area Connection 3 (AnchorFree TAP-Windows Adapter V9, ID:{7217FEC5-E4F1-4B6F-B245-7FE0AAAEC868}) - Ethernet - Down
Network Interface: Local Area Connection (Realtek PCIe GBE Family Controller, ID:{D25896F7-B117-4908-99A0-43A94A9BF9E9}) - Ethernet - Up
Network Interface: Loopback Pseudo-Interface 1 (Software Loopback Interface 1, ID:{846EE342-7039-11DE-9D20-806E6F6E6963}) - Loopback - Up
Routing:
Address: 0.0.0.0, Mask: 0.0.0.0, Gateway: 192.168.1.1, Interface: 11, Metrics: 10, Flags: , Mss: , Window: , Irtt:
Default gateways:
192.168.1.1, Realtek PCIe GBE Family Controller
-- Windows
-- ipconfig /all
Windows IP Configuration
   Host Name . . . . . . . . . . . . : TheDungeon
   Primary Dns Suffix  . . . . . . . :
   Node Type . . . . . . . . . . . . : Hybrid
   IP Routing Enabled. . . . . . . . : No
   WINS Proxy Enabled. . . . . . . . : No
Ethernet adapter Local Area Connection 2:
   Media State . . . . . . . . . . . : Media disconnected
   Connection-specific DNS Suffix  . :
   Description . . . . . . . . . . . : TAP-Windows Adapter V9
   Physical Address. . . . . . . . . : 00-FF-72-D4-52-05
   DHCP Enabled. . . . . . . . . . . : Yes
   Autoconfiguration Enabled . . . . : Yes
Ethernet adapter Local Area Connection 3:
   Description . . . . . . . . . . . : AnchorFree TAP-Windows Adapter V9
   Physical Address. . . . . . . . . : 00-FF-72-17-FE-C5
Ethernet adapter Local Area Connection:
   Description . . . . . . . . . . . : Realtek PCIe GBE Family Controller
   Physical Address. . . . . . . . . : 30-85-A9-9F-A5-21
   Link-local IPv6 Address . . . . . : fe80::3461:2aea:2c84:fc97%11(Preferred)
   IPv4 Address. . . . . . . . . . . : 192.168.1.56(Preferred)
   Subnet Mask . . . . . . . . . . . : 255.255.255.0
   Lease Obtained. . . . . . . . . . : Thursday, December 24, 2020 10:29:37 AM
   Lease Expires . . . . . . . . . . : Friday, December 25, 2020 10:29:36 AM
   Default Gateway . . . . . . . . . : 192.168.1.1
   DHCP Server . . . . . . . . . . . : 192.168.1.1
   DHCPv6 IAID . . . . . . . . . . . : 238060969
   DHCPv6 Client DUID. . . . . . . . : 00-01-00-01-19-2E-F3-F7-30-85-A9-9F-A5-21
   DNS Servers . . . . . . . . . . . : 192.168.1.1
   NetBIOS over Tcpip. . . . . . . . : Enabled
-- NetworkAdapterConfiguration
Network Adapter: [00000000] WAN Miniport (SSTP)
DNS: null
Details:
    ArpAlwaysSourceRoute: null
    ArpUseEtherSNAP: null
    Caption: [00000000] WAN Miniport (SSTP)
    DatabasePath: null
    DeadGWDetectEnabled: null
    DefaultIPGateway: null
    DefaultTOS: null
    DefaultTTL: null
    Description: WAN Miniport (SSTP)
    DHCPEnabled: false
    DHCPLeaseExpires: null
    DHCPLeaseObtained: null
    DHCPServer: null
    DNSDomain: null
    DNSDomainSuffixSearchOrder: null
    DNSEnabledForWINSResolution: null
    DNSHostName: null
    DNSServerSearchOrder: null
    DomainDNSRegistrationEnabled: null
    ForwardBufferMemory: null
    FullDNSRegistrationEnabled: null
    GatewayCostMetric: null
    IGMPLevel: null
    Index: 0
    InterfaceIndex: 2
    IPAddress: null
    IPConnectionMetric: null
    IPEnabled: false
    IPFilterSecurityEnabled: null
    IPPortSecurityEnabled: null
    IPSecPermitIPProtocols: null
    IPSecPermitTCPPorts: null
    IPSecPermitUDPPorts: null
    IPSubnet: null
    IPUseZeroBroadcast: null
    IPXAddress: null
    IPXEnabled: null
    IPXFrameType: null
    IPXMediaType: null
    IPXNetworkNumber: null
    IPXVirtualNetNumber: null
    KeepAliveInterval: null
    KeepAliveTime: null
    MACAddress: null
    MTU: null
    NumForwardPackets: null
    PMTUBHDetectEnabled: null
    PMTUDiscoveryEnabled: null
    ServiceName: RasSstp
    SettingID: {71F897D7-EB7C-4D8D-89DB-AC80D9DD2270}
    TcpipNetbiosOptions: null
    TcpMaxConnectRetransmissions: null
    TcpMaxDataRetransmissions: null
    TcpNumConnections: null
    TcpUseRFC1122UrgentPointer: null
    TcpWindowSize: null
    WINSEnableLMHostsLookup: null
    WINSHostLookupFile: null
    WINSPrimaryServer: null
    WINSScopeID: null
    WINSSecondaryServer: null
Network Adapter: [00000001] WAN Miniport (IKEv2)
DNS: null
Details:
    Caption: [00000001] WAN Miniport (IKEv2)
    DatabasePath: null
    DefaultTOS: null
    DefaultTTL: null
    Description: WAN Miniport (IKEv2)
    DHCPEnabled: false
    DHCPServer: null
    DNSDomain: null
    DNSHostName: null
    IGMPLevel: null
    Index: 1
    InterfaceIndex: 10
    IPAddress: null
    IPEnabled: false
    IPSubnet: null
    IPXAddress: null
    IPXEnabled: null
    IPXFrameType: null
    IPXMediaType: null
    KeepAliveTime: null
    MACAddress: null
    MTU: null
    ServiceName: RasAgileVpn
    SettingID: {29898C9D-B0A4-4FEF-BDB6-57A562022CEE}
    TcpWindowSize: null
    WINSScopeID: null
Network Adapter: [00000002] WAN Miniport (L2TP)
DNS: null
Details:
    Caption: [00000002] WAN Miniport (L2TP)
    DatabasePath: null
    DefaultTOS: null
    DefaultTTL: null
    Description: WAN Miniport (L2TP)
    DHCPEnabled: false
    DHCPServer: null
    DNSDomain: null
    DNSHostName: null
    IGMPLevel: null
    Index: 2
    InterfaceIndex: 3
    IPAddress: null
    IPEnabled: false
    IPSubnet: null
    IPXAddress: null
    IPXEnabled: null
    IPXFrameType: null
    IPXMediaType: null
    KeepAliveTime: null
    MACAddress: null
    MTU: null
    ServiceName: Rasl2tp
    SettingID: {E43D242B-9EAB-4626-A952-46649FBB939A}
    TcpWindowSize: null
    WINSScopeID: null
Network Adapter: [00000003] WAN Miniport (PPTP)
DNS: null
Details:
    Caption: [00000003] WAN Miniport (PPTP)
    DatabasePath: null
    DefaultTOS: null
    DefaultTTL: null
    Description: WAN Miniport (PPTP)
    DHCPEnabled: false
    DHCPServer: null
    DNSDomain: null
    DNSHostName: null
    IGMPLevel: null
    Index: 3
    InterfaceIndex: 4
    IPAddress: null
    IPEnabled: false
    IPSubnet: null
    IPXAddress: null
    IPXEnabled: null
    IPXFrameType: null
    IPXMediaType: null
    KeepAliveTime: null
    MACAddress: null
    MTU: null
    ServiceName: PptpMiniport
    SettingID: {DF4A9D2C-8742-4EB1-8703-D395C4183F33}
    TcpWindowSize: null
    WINSScopeID: null
Network Adapter: [00000004] WAN Miniport (PPPOE)
DNS: null
Details:
    Caption: [00000004] WAN Miniport (PPPOE)
    DatabasePath: null
    DefaultTOS: null
    DefaultTTL: null
    Description: WAN Miniport (PPPOE)
    DHCPEnabled: false
    DHCPServer: null
    DNSDomain: null
    DNSHostName: null
    IGMPLevel: null
    Index: 4
    InterfaceIndex: 5
    IPAddress: null
    IPEnabled: false
    IPSubnet: null
    IPXAddress: null
    IPXEnabled: null
    IPXFrameType: null
    IPXMediaType: null
    KeepAliveTime: null
    MACAddress: null
    MTU: null
    ServiceName: RasPppoe
    SettingID: {8E301A52-AFFA-4F49-B9CA-C79096A1A056}
    TcpWindowSize: null
    WINSScopeID: null
Network Adapter: [00000005] WAN Miniport (IPv6)
DNS: null
Details:
    Caption: [00000005] WAN Miniport (IPv6)
    DatabasePath: null
    DefaultTOS: null
    DefaultTTL: null
    Description: WAN Miniport (IPv6)
    DHCPEnabled: false
    DHCPServer: null
    DNSDomain: null
    DNSHostName: null
    IGMPLevel: null
    Index: 5
    InterfaceIndex: 6
    IPAddress: null
    IPEnabled: false
    IPSubnet: null
    IPXAddress: null
    IPXEnabled: null
    IPXFrameType: null
    IPXMediaType: null
    KeepAliveTime: null
    MACAddress: null
    MTU: null
    ServiceName: NdisWan
    SettingID: {9A399D81-2EAD-4F23-BCDD-637FC13DCD51}
    TcpWindowSize: null
    WINSScopeID: null
Network Adapter: [00000006] WAN Miniport (Network Monitor)
DNS: null
Details:
    Caption: [00000006] WAN Miniport (Network Monitor)
    DatabasePath: null
    DefaultTOS: null
    DefaultTTL: null
    Description: WAN Miniport (Network Monitor)
    DHCPEnabled: false
    DHCPServer: null
    DNSDomain: null
    DNSHostName: null
    IGMPLevel: null
    Index: 6
    InterfaceIndex: 7
    IPAddress: null
    IPEnabled: false
    IPSubnet: null
    IPXAddress: null
    IPXEnabled: null
    IPXFrameType: null
    IPXMediaType: null
    KeepAliveTime: null
    MACAddress: null
    MTU: null
    SettingID: {5BF54C7E-91DA-457D-80BF-333677D7E316}
    TcpWindowSize: null
    WINSScopeID: null
Network Adapter: [00000007] Realtek PCIe GBE Family Controller
DNS: 192.168.1.1
Details:
    Caption: [00000007] Realtek PCIe GBE Family Controller
    DatabasePath: %SystemRoot%\System32\drivers\etc
    DefaultIPGateway: 192.168.1.1
    DefaultTOS: null
    DefaultTTL: null
    Description: Realtek PCIe GBE Family Controller
    DHCPEnabled: true
    DHCPLeaseExpires: 20201225102937.000000-300
    DHCPLeaseObtained: 20201224102937.000000-300
    DHCPServer: 192.168.1.1
    DNSDomain: null
    DNSEnabledForWINSResolution: false
    DNSHostName: TheDungeon
    DNSServerSearchOrder: 192.168.1.1
    DomainDNSRegistrationEnabled: false
    FullDNSRegistrationEnabled: true
    GatewayCostMetric: System.UInt16[]
    IGMPLevel: null
    Index: 7
    InterfaceIndex: 11
    IPAddress: 192.168.1.56,fe80::3461:2aea:2c84:fc97
    IPConnectionMetric: 10
    IPEnabled: true
    IPFilterSecurityEnabled: false
    IPSubnet: 255.255.255.0,64
    IPXAddress: null
    IPXEnabled: null
    IPXFrameType: null
    IPXMediaType: null
    KeepAliveTime: null
    MACAddress: 30:85:A9:9F:A5:21
    MTU: null
    ServiceName: RTL8167
    SettingID: {D25896F7-B117-4908-99A0-43A94A9BF9E9}
    TcpipNetbiosOptions: 0
    TcpWindowSize: null
    WINSEnableLMHostsLookup: true
    WINSScopeID:
Network Adapter: [00000008] WAN Miniport (IP)
DNS: null
Details:
    Caption: [00000008] WAN Miniport (IP)
    DatabasePath: null
    DefaultTOS: null
    DefaultTTL: null
    Description: WAN Miniport (IP)
    DHCPEnabled: false
    DHCPServer: null
    DNSDomain: null
    DNSHostName: null
    IGMPLevel: null
    Index: 8
    InterfaceIndex: 8
    IPAddress: null
    IPEnabled: false
    IPSubnet: null
    IPXAddress: null
    IPXEnabled: null
    IPXFrameType: null
    IPXMediaType: null
    KeepAliveTime: null
    MACAddress: null
    MTU: null
    SettingID: {2CAA64ED-BAA3-4473-B637-DEC65A14C8AA}
    TcpWindowSize: null
    WINSScopeID: null
Network Adapter: [00000009] 802.11n USB Wireless LAN Card
DNS: null
Details:
    Caption: [00000009] 802.11n USB Wireless LAN Card
    DatabasePath: null
    DefaultTOS: null
    DefaultTTL: null
    Description: 802.11n USB Wireless LAN Card
    DHCPEnabled: true
    DHCPServer: null
    DNSDomain: null
    DNSHostName: null
    IGMPLevel: null
    Index: 9
    InterfaceIndex: 23
    IPAddress: null
    IPEnabled: false
    IPSubnet: null
    IPXAddress: null
    IPXEnabled: null
    IPXFrameType: null
    IPXMediaType: null
    KeepAliveTime: null
    MACAddress: null
    MTU: null
    ServiceName: netr28ux
    SettingID: {E80BE856-A584-48CE-8D0C-F4BA17E07D6D}
    TcpWindowSize: null
    WINSScopeID: null
Network Adapter: [00000010] RAS Async Adapter
DNS: null
Details:
    Caption: [00000010] RAS Async Adapter
    DatabasePath: null
    DefaultTOS: null
    DefaultTTL: null
    Description: RAS Async Adapter
    DHCPEnabled: false
    DHCPServer: null
    DNSDomain: null
    DNSHostName: null
    IGMPLevel: null
    Index: 10
    InterfaceIndex: 9
    IPAddress: null
    IPEnabled: false
    IPSubnet: null
    IPXAddress: null
    IPXEnabled: null
    IPXFrameType: null
    IPXMediaType: null
    KeepAliveTime: null
    MACAddress: 20:41:53:59:4E:FF
    MTU: null
    ServiceName: AsyncMac
    SettingID: {78032B7E-4968-42D3-9F37-287EA86C0AAA}
    TcpWindowSize: null
    WINSScopeID: null
Network Adapter: [00000011] Microsoft Teredo Tunneling Adapter
DNS: null
Details:
    Caption: [00000011] Microsoft Teredo Tunneling Adapter
    DatabasePath: null
    DefaultTOS: null
    DefaultTTL: null
    Description: Microsoft Teredo Tunneling Adapter
    DHCPEnabled: false
    DHCPServer: null
    DNSDomain: null
    DNSHostName: null
    IGMPLevel: null
    Index: 11
    InterfaceIndex: 12
    IPAddress: null
    IPEnabled: false
    IPSubnet: null
    IPXAddress: null
    IPXEnabled: null
    IPXFrameType: null
    IPXMediaType: null
    KeepAliveTime: null
    MACAddress: null
    MTU: null
    ServiceName: tunnel
    SettingID: {E344220F-9DBE-4473-B168-7268F740B987}
    TcpWindowSize: null
    WINSScopeID: null
Network Adapter: [00000012] 802.11n USB Wireless LAN Card
DNS: null
Details:
    Caption: [00000012] 802.11n USB Wireless LAN Card
    DatabasePath: null
    DefaultTOS: null
    DefaultTTL: null
    DHCPEnabled: true
    DHCPServer: null
    DNSDomain: null
    DNSHostName: null
    IGMPLevel: null
    Index: 12
    InterfaceIndex: 20
    IPAddress: null
    IPEnabled: false
    IPSubnet: null
    IPXAddress: null
    IPXEnabled: null
    IPXFrameType: null
    IPXMediaType: null
    KeepAliveTime: null
    MACAddress: null
    MTU: null
    SettingID: {AAB48D15-CE61-47CF-A9F8-FEBED27832B4}
    TcpWindowSize: null
    WINSScopeID: null
Network Adapter: [00000013] 802.11n USB Wireless LAN Card
DNS: null
Details:
    Caption: [00000013] 802.11n USB Wireless LAN Card
    DatabasePath: null
    DefaultTOS: null
    DefaultTTL: null
    DHCPEnabled: true
    DHCPServer: null
    DNSDomain: null
    DNSHostName: null
    IGMPLevel: null
    Index: 13
    InterfaceIndex: 13
    IPAddress: null
    IPEnabled: false
    IPSubnet: null
    IPXAddress: null
    IPXEnabled: null
    IPXFrameType: null
    IPXMediaType: null
    KeepAliveTime: null
    MACAddress: null
    MTU: null
    SettingID: {8287533F-AAEB-4601-9B19-6EA8407132C6}
    TcpWindowSize: null
    WINSScopeID: null
Network Adapter: [00000014] 802.11n USB Wireless LAN Card
DNS: null
Details:
    Caption: [00000014] 802.11n USB Wireless LAN Card
    DatabasePath: null
    DefaultTOS: null
    DefaultTTL: null
    DHCPEnabled: true
    DHCPServer: null
    DNSDomain: null
    DNSHostName: null
    IGMPLevel: null
    Index: 14
    InterfaceIndex: 14
    IPAddress: null
    IPEnabled: false
    IPSubnet: null
    IPXAddress: null
    IPXEnabled: null
    IPXFrameType: null
    IPXMediaType: null
    KeepAliveTime: null
    MACAddress: null
    MTU: null
    SettingID: {3BF6846D-19B0-44AA-8FCB-58D4A2A07C5C}
    TcpWindowSize: null
    WINSScopeID: null
Network Adapter: [00000015] 802.11n USB Wireless LAN Card
DNS: null
Details:
    Caption: [00000015] 802.11n USB Wireless LAN Card
    DatabasePath: null
    DefaultTOS: null
    DefaultTTL: null
    DHCPEnabled: true
    DHCPServer: null
    DNSDomain: null
    DNSHostName: null
    IGMPLevel: null
    Index: 15
    InterfaceIndex: 15
    IPAddress: null
    IPEnabled: false
    IPSubnet: null
    IPXAddress: null
    IPXEnabled: null
    IPXFrameType: null
    IPXMediaType: null
    KeepAliveTime: null
    MACAddress: null
    MTU: null
    SettingID: {2BD5A366-A252-478D-8147-A708A4EC92E5}
    TcpWindowSize: null
    WINSScopeID: null
Network Adapter: [00000016] Microsoft Virtual WiFi Miniport Adapter
DNS: null
Details:
    Caption: [00000016] Microsoft Virtual WiFi Miniport Adapter
    DatabasePath: null
    DefaultTOS: null
    DefaultTTL: null
    Description: Microsoft Virtual WiFi Miniport Adapter
    DHCPEnabled: true
    DHCPServer: null
    DNSDomain: null
    DNSHostName: null
    IGMPLevel: null
    Index: 16
    InterfaceIndex: 16
    IPAddress: null
    IPEnabled: false
    IPSubnet: null
    IPXAddress: null
    IPXEnabled: null
    IPXFrameType: null
    IPXMediaType: null
    KeepAliveTime: null
    MACAddress: null
    MTU: null
    ServiceName: vwifimp
    SettingID: {A39C456F-B375-4B71-807D-33A8C7F24170}
    TcpWindowSize: null
    WINSScopeID: null
Network Adapter: [00000017] Microsoft Virtual WiFi Miniport Adapter
DNS: null
Details:
    Caption: [00000017] Microsoft Virtual WiFi Miniport Adapter
    DatabasePath: null
    DefaultTOS: null
    DefaultTTL: null
    DHCPEnabled: true
    DHCPServer: null
    DNSDomain: null
    DNSHostName: null
    IGMPLevel: null
    Index: 17
    InterfaceIndex: 19
    IPAddress: null
    IPEnabled: false
    IPSubnet: null
    IPXAddress: null
    IPXEnabled: null
    IPXFrameType: null
    IPXMediaType: null
    KeepAliveTime: null
    MACAddress: null
    MTU: null
    SettingID: {15A7B1DE-6EE6-4087-A142-553FB83F9FA4}
    TcpWindowSize: null
    WINSScopeID: null
Network Adapter: [00000018] 802.11n USB Wireless LAN Card
DNS: null
Details:
    Caption: [00000018] 802.11n USB Wireless LAN Card
    DatabasePath: null
    DefaultTOS: null
    DefaultTTL: null
    DHCPEnabled: true
    DHCPServer: null
    DNSDomain: null
    DNSHostName: null
    IGMPLevel: null
    Index: 18
    InterfaceIndex: 17
    IPAddress: null
    IPEnabled: false
    IPSubnet: null
    IPXAddress: null
    IPXEnabled: null
    IPXFrameType: null
    IPXMediaType: null
    KeepAliveTime: null
    MACAddress: null
    MTU: null
    SettingID: {BB77E8BD-6458-401E-9C83-BC019EA8E7E2}
    TcpWindowSize: null
    WINSScopeID: null
Network Adapter: [00000019] Microsoft Virtual WiFi Miniport Adapter
DNS: null
Details:
    Caption: [00000019] Microsoft Virtual WiFi Miniport Adapter
    DatabasePath: null
    DefaultTOS: null
    DefaultTTL: null
    DHCPEnabled: true
    DHCPServer: null
    DNSDomain: null
    DNSHostName: null
    IGMPLevel: null
    Index: 19
    InterfaceIndex: 18
    IPAddress: null
    IPEnabled: false
    IPSubnet: null
    IPXAddress: null
    IPXEnabled: null
    IPXFrameType: null
    IPXMediaType: null
    KeepAliveTime: null
    MACAddress: null
    MTU: null
    SettingID: {9668DBE0-9CD2-4256-B543-5F30A44F017D}
    TcpWindowSize: null
    WINSScopeID: null
Network Adapter: [00000020] Microsoft Virtual WiFi Miniport Adapter
DNS: null
Details:
    Caption: [00000020] Microsoft Virtual WiFi Miniport Adapter
    DatabasePath: null
    DefaultTOS: null
    DefaultTTL: null
    DHCPEnabled: true
    DHCPServer: null
    DNSDomain: null
    DNSHostName: null
    IGMPLevel: null
    Index: 20
    InterfaceIndex: 24
    IPAddress: null
    IPEnabled: false
    IPSubnet: null
    IPXAddress: null
    IPXEnabled: null
    IPXFrameType: null
    IPXMediaType: null
    KeepAliveTime: null
    MACAddress: null
    MTU: null
    SettingID: {266B4A9B-4D76-40AF-82BC-3EAF30ADC026}
    TcpWindowSize: null
    WINSScopeID: null
Network Adapter: [00000021] Microsoft Virtual WiFi Miniport Adapter
DNS: null
Details:
    Caption: [00000021] Microsoft Virtual WiFi Miniport Adapter
    DatabasePath: null
    DefaultTOS: null
    DefaultTTL: null
    DHCPEnabled: true
    DHCPServer: null
    DNSDomain: null
    DNSHostName: null
    IGMPLevel: null
    Index: 21
    InterfaceIndex: 21
    IPAddress: null
    IPEnabled: false
    IPSubnet: null
    IPXAddress: null
    IPXEnabled: null
    IPXFrameType: null
    IPXMediaType: null
    KeepAliveTime: null
    MACAddress: null
    MTU: null
    SettingID: {F5687BFE-C78E-4214-AAEF-9F3B7F42885C}
    TcpWindowSize: null
    WINSScopeID: null
Network Adapter: [00000022] Microsoft Virtual WiFi Miniport Adapter
DNS: null
Details:
    Caption: [00000022] Microsoft Virtual WiFi Miniport Adapter
    DatabasePath: null
    DefaultTOS: null
    DefaultTTL: null
    DHCPEnabled: true
    DHCPServer: null
    DNSDomain: null
    DNSHostName: null
    IGMPLevel: null
    Index: 22
    InterfaceIndex: 22
    IPAddress: null
    IPEnabled: false
    IPSubnet: null
    IPXAddress: null
    IPXEnabled: null
    IPXFrameType: null
    IPXMediaType: null
    KeepAliveTime: null
    MACAddress: null
    MTU: null
    SettingID: {3423292C-A0DF-4189-BF70-7D4984C0BF1D}
    TcpWindowSize: null
    WINSScopeID: null
Network Adapter: [00000023] 802.11n USB Wireless LAN Card
DNS: null
Details:
    Caption: [00000023] 802.11n USB Wireless LAN Card
    DatabasePath: null
    DefaultTOS: null
    DefaultTTL: null
    DHCPEnabled: true
    DHCPServer: null
    DNSDomain: null
    DNSHostName: null
    IGMPLevel: null
    Index: 23
    InterfaceIndex: 25
    IPAddress: null
    IPEnabled: false
    IPSubnet: null
    IPXAddress: null
    IPXEnabled: null
    IPXFrameType: null
    IPXMediaType: null
    KeepAliveTime: null
    MACAddress: null
    MTU: null
    SettingID: {C43913C8-6119-463B-8E55-A24CED4A3171}
    TcpWindowSize: null
    WINSScopeID: null
Network Adapter: [00000024] Microsoft Virtual WiFi Miniport Adapter
DNS: null
Details:
    Caption: [00000024] Microsoft Virtual WiFi Miniport Adapter
    DatabasePath: null
    DefaultTOS: null
    DefaultTTL: null
    DHCPEnabled: true
    DHCPServer: null
    DNSDomain: null
    DNSHostName: null
    IGMPLevel: null
    Index: 24
    InterfaceIndex: 26
    IPAddress: null
    IPEnabled: false
    IPSubnet: null
    IPXAddress: null
    IPXEnabled: null
    IPXFrameType: null
    IPXMediaType: null
    KeepAliveTime: null
    MACAddress: null
    MTU: null
    SettingID: {EF76F58D-2336-4313-A4DD-C8711A508E63}
    TcpWindowSize: null
    WINSScopeID: null
Network Adapter: [00000025] TAP-Windows Adapter V9
DNS: null
Details:
    Caption: [00000025] TAP-Windows Adapter V9
    DatabasePath: null
    DefaultTOS: null
    DefaultTTL: null
    Description: TAP-Windows Adapter V9
    DHCPEnabled: true
    DHCPServer: null
    DNSDomain: null
    DNSHostName: null
    IGMPLevel: null
    Index: 25
    InterfaceIndex: 49
    IPAddress: null
    IPEnabled: false
    IPSubnet: null
    IPXAddress: null
    IPXEnabled: null
    IPXFrameType: null
    IPXMediaType: null
    KeepAliveTime: null
    MACAddress: 00:FF:72:D4:52:05
    MTU: null
    ServiceName: tap0901
    SettingID: {72D45205-5C9E-42DA-A3BC-CDAAAE4BA810}
    TcpWindowSize: null
    WINSScopeID: null
Network Adapter: [00000026] 802.11n USB Wireless LAN Card
DNS: null
Details:
    Caption: [00000026] 802.11n USB Wireless LAN Card
    DatabasePath: null
    DefaultTOS: null
    DefaultTTL: null
    DHCPEnabled: true
    DHCPServer: null
    DNSDomain: null
    DNSHostName: null
    IGMPLevel: null
    Index: 26
    InterfaceIndex: 27
    IPAddress: null
    IPEnabled: false
    IPSubnet: null
    IPXAddress: null
    IPXEnabled: null
    IPXFrameType: null
    IPXMediaType: null
    KeepAliveTime: null
    MACAddress: null
    MTU: null
    SettingID: {67513A0E-9338-4423-A761-DD8734FE2C9B}
    TcpWindowSize: null
    WINSScopeID: null
Network Adapter: [00000027] Microsoft Virtual WiFi Miniport Adapter
DNS: null
Details:
    Caption: [00000027] Microsoft Virtual WiFi Miniport Adapter
    DatabasePath: null
    DefaultTOS: null
    DefaultTTL: null
    DHCPEnabled: true
    DHCPServer: null
    DNSDomain: null
    DNSHostName: null
    IGMPLevel: null
    Index: 27
    InterfaceIndex: 28
    IPAddress: null
    IPEnabled: false
    IPSubnet: null
    IPXAddress: null
    IPXEnabled: null
    IPXFrameType: null
    IPXMediaType: null
    KeepAliveTime: null
    MACAddress: null
    MTU: null
    SettingID: {447216BB-F4E6-46FF-AB1F-EE41BFD5B6FA}
    TcpWindowSize: null
    WINSScopeID: null
Network Adapter: [00000028] Microsoft Virtual WiFi Miniport Adapter
DNS: null
Details:
    Caption: [00000028] Microsoft Virtual WiFi Miniport Adapter
    DatabasePath: null
    DefaultTOS: null
    DefaultTTL: null
    DHCPEnabled: true
    DHCPServer: null
    DNSDomain: null
    DNSHostName: null
    IGMPLevel: null
    Index: 28
    InterfaceIndex: 29
    IPAddress: null
    IPEnabled: false
    IPSubnet: null
    IPXAddress: null
    IPXEnabled: null
    IPXFrameType: null
    IPXMediaType: null
    KeepAliveTime: null
    MACAddress: null
    MTU: null
    SettingID: {1679AD8A-78FC-4BE6-91D6-55B8E8BDD0A6}
    TcpWindowSize: null
    WINSScopeID: null
Network Adapter: [00000029] AnchorFree TAP-Windows Adapter V9
DNS: null
Details:
    Caption: [00000029] AnchorFree TAP-Windows Adapter V9
    DatabasePath: null
    DefaultTOS: null
    DefaultTTL: null
    Description: AnchorFree TAP-Windows Adapter V9
    DHCPEnabled: true
    DHCPServer: null
    DNSDomain: null
    DNSHostName: null
    IGMPLevel: null
    Index: 29
    InterfaceIndex: 30
    IPAddress: null
    IPEnabled: false
    IPSubnet: null
    IPXAddress: null
    IPXEnabled: null
    IPXFrameType: null
    IPXMediaType: null
    KeepAliveTime: null
    MACAddress: 00:FF:72:17:FE:C5
    MTU: null
    ServiceName: aftap0901
    SettingID: {7217FEC5-E4F1-4B6F-B245-7FE0AAAEC868}
    TcpWindowSize: null
    WINSScopeID: null
Network Adapter: [00000030] 802.11n USB Wireless LAN Card
DNS: null
Details:
    Caption: [00000030] 802.11n USB Wireless LAN Card
    DatabasePath: null
    DefaultTOS: null
    DefaultTTL: null
    DHCPEnabled: true
    DHCPServer: null
    DNSDomain: null
    DNSHostName: null
    IGMPLevel: null
    Index: 30
    InterfaceIndex: 31
    IPAddress: null
    IPEnabled: false
    IPSubnet: null
    IPXAddress: null
    IPXEnabled: null
    IPXFrameType: null
    IPXMediaType: null
    KeepAliveTime: null
    MACAddress: null
    MTU: null
    SettingID: {3C21D7D4-77E7-489B-AE78-5F3715E8D122}
    TcpWindowSize: null
    WINSScopeID: null
Network Adapter: [00000031] Microsoft Virtual WiFi Miniport Adapter
DNS: null
Details:
    Caption: [00000031] Microsoft Virtual WiFi Miniport Adapter
    DatabasePath: null
    DefaultTOS: null
    DefaultTTL: null
    DHCPEnabled: true
    DHCPServer: null
    DNSDomain: null
    DNSHostName: null
    IGMPLevel: null
    Index: 31
    InterfaceIndex: 32
    IPAddress: null
    IPEnabled: false
    IPSubnet: null
    IPXAddress: null
    IPXEnabled: null
    IPXFrameType: null
    IPXMediaType: null
    KeepAliveTime: null
    MACAddress: null
    MTU: null
    SettingID: {A24B1131-AE6E-4E75-83FF-C695A92FE3DE}
    TcpWindowSize: null
    WINSScopeID: null
Network Adapter: [00000033] Microsoft Virtual WiFi Miniport Adapter
DNS: null
Details:
    Caption: [00000033] Microsoft Virtual WiFi Miniport Adapter
    DatabasePath: null
    DefaultTOS: null
    DefaultTTL: null
    DHCPEnabled: true
    DHCPServer: null
    DNSDomain: null
    DNSHostName: null
    IGMPLevel: null
    Index: 33
    InterfaceIndex: 34
    IPAddress: null
    IPEnabled: false
    IPSubnet: null
    IPXAddress: null
    IPXEnabled: null
    IPXFrameType: null
    IPXMediaType: null
    KeepAliveTime: null
    MACAddress: null
    MTU: null
    SettingID: {5579909F-8C64-4FF0-86CA-D35F02DA4766}
    TcpWindowSize: null
    WINSScopeID: null
Network Adapter: [00000034] Microsoft Virtual WiFi Miniport Adapter
DNS: null
Details:
    Caption: [00000034] Microsoft Virtual WiFi Miniport Adapter
    DatabasePath: null
    DefaultTOS: null
    DefaultTTL: null
    DHCPEnabled: true
    DHCPServer: null
    DNSDomain: null
    DNSHostName: null
    IGMPLevel: null
    Index: 34
    InterfaceIndex: 36
    IPAddress: null
    IPEnabled: false
    IPSubnet: null
    IPXAddress: null
    IPXEnabled: null
    IPXFrameType: null
    IPXMediaType: null
    KeepAliveTime: null
    MACAddress: null
    MTU: null
    SettingID: {DF084EEE-30B4-4FEE-9F1A-7818B760DDE9}
    TcpWindowSize: null
    WINSScopeID: null
@krytellan
Eddie 2.12.4 is very old and is packaged with and linked against software which does not support anymore the new encryption requirements by AirVPN. Please upgrade and the problem should be resolved.
NOTE: Windows 7 is an abandoned system and latest Eddie versions are no more tested in Windows 7. If you experience issues with latest Eddie release, please run Eddie 2.16.3. To download Eddie 2.16.3:
  • browse https://airvpn.org/windows
  • click "Other versions"
  • click "2.16.3": you will be brought back to the download page, pointing this time to Eddie 2.16.3
  • select the correct system Windows 7
  • select the correct architecture (32 bit or 64 bit, please check)
  • download and install as usual
