ArchieP 0 Posted ... My ISP does not allow port forwarding at all. Does this mean that I can't enjoy 100 percent privacy/anonymity if I use AirVPN? Kindly enlighten me. Quote Share this post Link to post
Staff 10488 Posted ... My ISP does not allow port forwarding at all. Does this mean that I can't enjoy 100 percent privacy/anonymity if I use AirVPN?Kindly enlighten me.Hello!Thank you for your inquiry.It's not a problem. The anonymity layer is just the same regardless of your ISP allowing or not port forwarding (in some cases, your ISP NOT allowing port forwarding is an additional security). It's important to note that AirVPN will let you bypass this limitation, i.e. you can remotely forward ports on our system and finally be able to receive incoming connections from the outside, if you wish so.Kind regards Quote Share this post Link to post
