hadge
Not connected?
Hi there
I am new to VPN/ proxy server so probably my inexperience.
Followed instructions - opened a session and connected but still showing my IP. Could be problem with my router - Using NetgeaR WGR614 V9
Log;
02/10/2012 - 20:05 AirVPN client version: 1.7
02/10/2012 - 20:05 Reading options from C:\Documents and Settings\John Harrison\Application Data\AirVPN\Air\1.0.0.0\AirVPN.xml
02/10/2012 - 20:05 OpenVPN bundle version: OpenVPN 2.2.2
02/10/2012 - 20:05 OpenVPN current version: OpenVPN 2.2.2
02/10/2012 - 20:05 Ready.
02/10/2012 - 20:05 Login...
02/10/2012 - 20:06 Login success.
02/10/2012 - 20:06 Contacting service...
02/10/2012 - 20:06 Connecting...
02/10/2012 - 20:06 OpenVPN 2.2.2 Win32-MSVC++ [sSL] [LZO2] [PKCS11] built on Dec 15 2011
02/10/2012 - 20:06 NOTE: OpenVPN 2.1 requires '--script-security 2' or higher to call user-defined scripts or executables
02/10/2012 - 20:06 LZO compression initialized
02/10/2012 - 20:06 Control Channel MTU parms [ L:1560 D:140 EF:40 EB:0 ET:0 EL:0 ]
02/10/2012 - 20:06 Socket Buffers: R=[8192->8192] S=[64512->64512]
02/10/2012 - 20:06 Data Channel MTU parms [ L:1560 D:1450 EF:60 EB:135 ET:0 EL:0 AF:3/1 ]
02/10/2012 - 20:06 Local Options hash (VER=V4): '958c5492'
02/10/2012 - 20:06 Expected Remote Options hash (VER=V4): '79ef4284'
02/10/2012 - 20:06 Attempting to establish TCP connection with 89.149.226.185:443
02/10/2012 - 20:06 TCP connection established with 89.149.226.185:443
02/10/2012 - 20:06 TCPv4_CLIENT link local: [undef]
02/10/2012 - 20:06 TCPv4_CLIENT link remote: 89.149.226.185:443
02/10/2012 - 20:06 TLS: Initial packet from 89.149.226.185:443, sid=57770e3e 858a3ecb
02/10/2012 - 20:06 VERIFY OK: depth=1, /C=IT/ST=IT/L=Perugia/O=airvpn.org/CN=airvpn.org_CA/emailAddress=info@airvpn.org
02/10/2012 - 20:06 VERIFY OK: nsCertType=SERVER
02/10/2012 - 20:06 VERIFY OK: depth=0, /C=IT/ST=IT/L=Perugia/O=airvpn.org/CN=server/emailAddress=info@airvpn.org
02/10/2012 - 20:06 Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
02/10/2012 - 20:06 Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
02/10/2012 - 20:06 Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
02/10/2012 - 20:06 Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
02/10/2012 - 20:06 Control Channel: TLSv1, cipher TLSv1/SSLv3 DHE-RSA-AES256-SHA, 2048 bit RSA
02/10/2012 - 20:06 [server] Peer Connection Initiated with 89.149.226.185:443
02/10/2012 - 20:06 SENT CONTROL [server]: 'PUSH_REQUEST' (status=1)
02/10/2012 - 20:06 PUSH: Received control message: 'PUSH_REPLY,redirect-gateway def1,dhcp-option DNS 10.5.0.1,comp-lzo no,route 10.5.0.1,topology net30,ping 10,ping-restart 120,ifconfig 10.5.6.42 10.5.6.41'
02/10/2012 - 20:06 OPTIONS IMPORT: timers and/or timeouts modified
02/10/2012 - 20:06 OPTIONS IMPORT: LZO parms modified
02/10/2012 - 20:06 OPTIONS IMPORT: --ifconfig/up options modified
02/10/2012 - 20:06 OPTIONS IMPORT: route options modified
02/10/2012 - 20:06 OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified
02/10/2012 - 20:06 ROUTE default_gateway=192.168.1.1
02/10/2012 - 20:06 TAP-WIN32 device [Local Area Connection 3] opened: \\.\Global\{69A70FB0-C25F-4FA6-B5E8-FE74499A1C01}.tap
02/10/2012 - 20:06 TAP-Win32 Driver Version 9.9
02/10/2012 - 20:06 TAP-Win32 MTU=1500
02/10/2012 - 20:06 Notified TAP-Win32 driver to set a DHCP IP/netmask of 10.5.6.42/255.255.255.252 on interface {69A70FB0-C25F-4FA6-B5E8-FE74499A1C01} [DHCP-serv: 10.5.6.41, lease-time: 31536000]
02/10/2012 - 20:06 Successful ARP Flush on interface [65540] {69A70FB0-C25F-4FA6-B5E8-FE74499A1C01}
02/10/2012 - 20:06 TEST ROUTES: 0/0 succeeded len=1 ret=0 a=0 u/d=down
02/10/2012 - 20:06 Route: Waiting for TUN/TAP interface to come up...
02/10/2012 - 20:07 TEST ROUTES: 0/0 succeeded len=1 ret=0 a=0 u/d=down
02/10/2012 - 20:07 Route: Waiting for TUN/TAP interface to come up...
02/10/2012 - 20:07 C:\WINDOWS\system32\route.exe ADD 89.149.226.185 MASK 255.255.255.255 192.168.1.1
02/10/2012 - 20:07 Route addition via IPAPI succeeded [adaptive]
02/10/2012 - 20:07 C:\WINDOWS\system32\route.exe ADD 0.0.0.0 MASK 128.0.0.0 10.5.6.41
02/10/2012 - 20:07 Warning: route gateway is not reachable on any active network adapters: 10.5.6.41
02/10/2012 - 20:07 Route addition via IPAPI failed [adaptive]
02/10/2012 - 20:07 Route addition fallback to route.exe
02/10/2012 - 20:07 C:\WINDOWS\system32\route.exe ADD 128.0.0.0 MASK 128.0.0.0 10.5.6.41
02/10/2012 - 20:07 C:\WINDOWS\system32\route.exe ADD 10.5.0.1 MASK 255.255.255.255 10.5.6.41
02/10/2012 - 20:07 SYSTEM ROUTING TABLE
02/10/2012 - 20:07 .1 p=0 i=2 t=4 pr=3 a=35162 h=0 m=20/-1/-1/-1/-1
02/10/2012 - 20:07 5.255 192.168.1.1 p=0 i=2 t=4 pr=3 a=1 h=0 m=1/-1/-1/-1/-1
02/10/2012 - 20:07 .0.1 p=0 i=1 t=3 pr=2 a=35182 h=0 m=1/-1/-1/-1/-1
02/10/2012 - 20:07 192.168.1.3 p=0 i=2 t=3 pr=2 a=35165 h=0 m=20/-1/-1/-1/-1
02/10/2012 - 20:07 55 127.0.0.1 p=0 i=1 t=3 pr=2 a=35165 h=0 m=20/-1/-1/-1/-1
02/10/2012 - 20:07 .255 192.168.1.3 p=0 i=2 t=3 pr=2 a=35165 h=0 m=20/-1/-1/-1/-1
02/10/2012 - 20:07 68.1.3 p=0 i=2 t=3 pr=2 a=35165 h=0 m=20/-1/-1/-1/-1
02/10/2012 - 20:07 55.255 192.168.1.3 p=0 i=65540 t=3 pr=2 a=1177 h=0 m=1/-1/-1/-1/-1
02/10/2012 - 20:07 55.255 192.168.1.3 p=0 i=2 t=3 pr=2 a=35182 h=0 m=1/-1/-1/-1/-1
02/10/2012 - 20:07 SYSTEM ADAPTER LIST
02/10/2012 - 20:07 cket Scheduler Miniport
02/10/2012 - 20:07 Index = 65540
02/10/2012 - 20:07 FA6-B5E8-FE74499A1C01}
02/10/2012 - 20:07 IP = 0.0.0.0/0.0.0.0
02/10/2012 - 20:07 MAC = 00:ff:69:a7:0f:b0
02/10/2012 - 20:07 GATEWAY =
02/10/2012 - 20:07 ue Oct 02 19:51:44 2012
02/10/2012 - 20:07 hu Jan 01 00:00:00 1970
02/10/2012 - 20:07 DNS SERV =
02/10/2012 - 20:07 rk Connection - Packet Scheduler Miniport
02/10/2012 - 20:07 Index = 2
02/10/2012 - 20:07 8C7-B951-C6719BC47550}
02/10/2012 - 20:07 5.255.0
02/10/2012 - 20:07 MAC = 00:13:72:e5:3e:9b
02/10/2012 - 20:07 .0.0.0
02/10/2012 - 20:07
02/10/2012 - 20:07 ue Oct 02 10:21:02 2012
02/10/2012 - 20:07 DNS SERV = 192.168.1.1
02/10/2012 - 20:07 Initialization Sequence Completed With Errors ( see http://openvpn.net/faq.html#dhcpclientserv )
02/10/2012 - 20:07 Starting Management Interface...
02/10/2012 - 20:07 Checking...
02/10/2012 - 20:07 Retrieve statistics...
02/10/2012 - 20:07 Connected.
Advice would be useful....cheers
Thanks for your help - it was a problem with TAP-win32 v9 - however, did not resolve until disabling a legacy peer block program.
