escapement 0 Posted ... I followed the instructions to get utorrent working (forward port, turn of upnp, etc.) and everything seems to be works... Except, for some reason, I cant access the webui remotely. I can access from within my lan, so I know it is working. I was under the assumption if I take the info from AirVPN "You are visible from the Internet with IP 69.163.36.67" and attach my forwarded port after it, I should be able to see the webui. Am I misunderstanding something? I don't think it's a windows firewall issue because I shut it off and it still didn't work. Any tips would be greatly appreciated. Quote Share this post Link to post
escapement 0 Posted ... Can someone give me some advice on getting the utorrent webui working. I thought if I just forwarded a port to it I should be able to connect with http://<my external ip>:<my forwarded port>. For some reason this doesn't seem to work. Everything else is working like a champ, but not this. Thanks in advance. Quote Share this post Link to post
Staff 10493 Posted ... Can someone give me some advice on getting the utorrent webui working. I thought if I just forwarded a port to it I should be able to connect with http://:.For some reason this doesn't seem to work. Everything else is working like a champ, but not this.Thanks in advance.Hello!According to uTorrent documentation, you should be able to reach the WebUI at the following address:http://Username:Password@<Air server exit-IP>:<port>/guihttp://www.utorrent.com/help/guides/webuiKind regards Quote Share this post Link to post
