FPyro 2 Posted ... Hi! The openVPN gui tells me I'm connected, but I'm clearly not...this is the first time this happened. Can you help with this: Sat Sep 29 04:06:39 2012 OpenVPN 2.2.2 Win32-MSVC++ [sSL] [LZO2] [PKCS11] built on Dec 15 2011 Sat Sep 29 04:06:39 2012 NOTE: OpenVPN 2.1 requires '--script-security 2' or higher to call user-defined scripts or executables Sat Sep 29 04:06:40 2012 LZO compression initialized Sat Sep 29 04:06:40 2012 Control Channel MTU parms [ L:1558 D:138 EF:38 EB:0 ET:0 EL:0 ] Sat Sep 29 04:06:40 2012 Socket Buffers: R=[8192->8192] S=[8192->8192] Sat Sep 29 04:06:40 2012 Data Channel MTU parms [ L:1558 D:1450 EF:58 EB:135 ET:0 EL:0 AF:3/1 ] Sat Sep 29 04:06:40 2012 Local Options hash (VER=V4): '22188c5b' Sat Sep 29 04:06:40 2012 Expected Remote Options hash (VER=V4): 'a8f55717' Sat Sep 29 04:06:40 2012 UDPv4 link local: [undef] Sat Sep 29 04:06:40 2012 UDPv4 link remote: 95.211.191.33:443 Sat Sep 29 04:06:40 2012 TLS: Initial packet from 95.211.191.33:443, sid=ca9c6ae8 9e748825 Sat Sep 29 04:06:40 2012 VERIFY OK: depth=1, /C=IT/ST=IT/L=Perugia/O=airvpn.org/CN=airvpn.org_CA/emailAddress=info@airvpn.org Sat Sep 29 04:06:40 2012 VERIFY OK: nsCertType=SERVER Sat Sep 29 04:06:40 2012 VERIFY OK: depth=0, /C=IT/ST=IT/L=Perugia/O=airvpn.org/CN=server/emailAddress=info@airvpn.org Sat Sep 29 04:06:40 2012 Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key Sat Sep 29 04:06:40 2012 Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication Sat Sep 29 04:06:40 2012 Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key Sat Sep 29 04:06:40 2012 Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication Sat Sep 29 04:06:40 2012 Control Channel: TLSv1, cipher TLSv1/SSLv3 DHE-RSA-AES256-SHA, 2048 bit RSA Sat Sep 29 04:06:40 2012 [server] Peer Connection Initiated with 95.211.191.33:443 Sat Sep 29 04:06:42 2012 SENT CONTROL [server]: 'PUSH_REQUEST' (status=1) Sat Sep 29 04:06:42 2012 PUSH: Received control message: 'PUSH_REPLY,redirect-gateway def1,dhcp-option DNS 10.4.0.1,comp-lzo no,route 10.4.0.1,topology net30,ping 10,ping-restart 120,ifconfig 10.4.0.30 10.4.0.29' Sat Sep 29 04:06:42 2012 OPTIONS IMPORT: timers and/or timeouts modified Sat Sep 29 04:06:42 2012 OPTIONS IMPORT: LZO parms modified Sat Sep 29 04:06:42 2012 OPTIONS IMPORT: --ifconfig/up options modified Sat Sep 29 04:06:42 2012 OPTIONS IMPORT: route options modified Sat Sep 29 04:06:42 2012 OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified Sat Sep 29 04:06:42 2012 ROUTE default_gateway=192.168.178.1 Sat Sep 29 04:06:42 2012 TAP-WIN32 device [Local Area Connection 3] opened: \\.\Global\{7506FB69-AE75-4114-96A2-2F74D4F60180}.tap Sat Sep 29 04:06:42 2012 TAP-Win32 Driver Version 9.9 Sat Sep 29 04:06:42 2012 TAP-Win32 MTU=1500 Sat Sep 29 04:06:42 2012 Notified TAP-Win32 driver to set a DHCP IP/netmask of 10.4.0.30/255.255.255.252 on interface {7506FB69-AE75-4114-96A2-2F74D4F60180} [DHCP-serv: 10.4.0.29, lease-time: 31536000] Sat Sep 29 04:06:42 2012 NOTE: FlushIpNetTable failed on interface [48] {7506FB69-AE75-4114-96A2-2F74D4F60180} (status=5) : Access is denied. Sat Sep 29 04:06:47 2012 TEST ROUTES: 2/2 succeeded len=1 ret=1 a=0 u/d=up Sat Sep 29 04:06:47 2012 C:\WINDOWS\system32\route.exe ADD 95.211.191.33 MASK 255.255.255.255 192.168.178.1 Sat Sep 29 04:06:47 2012 ROUTE: route addition failed using CreateIpForwardEntry: Access is denied. [status=5 if_index=10] Sat Sep 29 04:06:47 2012 Route addition via IPAPI failed [adaptive] Sat Sep 29 04:06:47 2012 Route addition fallback to route.exe The requested operation requires elevation. Sat Sep 29 04:06:47 2012 ERROR: Windows route add command failed [adaptive]: returned error code 1 Sat Sep 29 04:06:47 2012 C:\WINDOWS\system32\route.exe ADD 0.0.0.0 MASK 128.0.0.0 10.4.0.29 Sat Sep 29 04:06:47 2012 ROUTE: route addition failed using CreateIpForwardEntry: Access is denied. [status=5 if_index=48] Sat Sep 29 04:06:47 2012 Route addition via IPAPI failed [adaptive] Sat Sep 29 04:06:47 2012 Route addition fallback to route.exe The requested operation requires elevation. Sat Sep 29 04:06:47 2012 ERROR: Windows route add command failed [adaptive]: returned error code 1 Sat Sep 29 04:06:47 2012 C:\WINDOWS\system32\route.exe ADD 128.0.0.0 MASK 128.0.0.0 10.4.0.29 Sat Sep 29 04:06:47 2012 ROUTE: route addition failed using CreateIpForwardEntry: Access is denied. [status=5 if_index=48] Sat Sep 29 04:06:47 2012 Route addition via IPAPI failed [adaptive] Sat Sep 29 04:06:47 2012 Route addition fallback to route.exe The requested operation requires elevation. Sat Sep 29 04:06:47 2012 ERROR: Windows route add command failed [adaptive]: returned error code 1 Sat Sep 29 04:06:47 2012 C:\WINDOWS\system32\route.exe ADD 10.4.0.1 MASK 255.255.255.255 10.4.0.29 Sat Sep 29 04:06:47 2012 ROUTE: route addition failed using CreateIpForwardEntry: Access is denied. [status=5 if_index=48] Sat Sep 29 04:06:47 2012 Route addition via IPAPI failed [adaptive] Sat Sep 29 04:06:47 2012 Route addition fallback to route.exe The requested operation requires elevation. Sat Sep 29 04:06:47 2012 ERROR: Windows route add command failed [adaptive]: returned error code 1 Sat Sep 29 04:06:47 2012 Initialization Sequence Completed Thank you Quote Share this post Link to post
Staff 10427 Posted ... Hello! Sat Sep 29 04:06:42 2012 NOTE: FlushIpNetTable failed on interface [48] {7506FB69-AE75-4114-96A2-2F74D4F60180} (status=5) : Access is denied.OpenVPN can't access the TAP-Win32 interface and can't modify the routing table. Please make sure that: - you launch OpenVPN GUI with administrator privileges - there are no other OpenVPN instances running - the TAP-Win32 adapter is enabled Kind regards Quote Share this post Link to post
GoXRUTD7k8FfZp5jmvNK4uE6 7 Posted ... I also experience similar "FlushIpNetTable failed" messages quite often when having resumed my PC from it's sleep/hibernation/suspend state. If you leave it to connect for long enough, the client will eventually claim it is connected but the connection will not be useable. Disconnecting and trying again will give "Already connected" half of the time (this can be quickly solved going to the client area's overview page and clicking "Disconnect now"). After checking you're not guilty of the cirumstances noted by Staff, how I fix this problem is not entirely clear but it consists of firstly closing the AirVPN client, disabling and re-enabling both my Ethernet adapter and the OpenVPN TAP-Win32 adapter. Now go to each adapter and do the following: right-click and choose Properties, scroll down and double-click "Internet Protocol Version 4 (TCP/IPv4)", click OK and OK again to close both popups (I find this step usually has solved the issue by now). I then also run some commands in the command prompt (cmd.exe) for good measure: ipconfig /release ipconfig /flushdns ipconfig /registerdns ipconfig /renew Now you should be able to reopen and connect with AirVPN's client successfully. How much of this is relevant I'm not sure but these steps get the client to connect without having to resort to the alternate fix of restarting the computer. The above commands can be made easier on yourself if you put them into a batch file to run from (create a new Notepad text document and save it as ipconfigcmds.bat): @ECHO off ipconfig /release ECHO. & ECHO. ipconfig /flushdns ECHO. & ECHO. ipconfig /registerdns ECHO. & ECHO. ipconfig /renew ECHO. & ECHO. PAUSE EXIT REM This script runs 4 ipconfig command options. Type ipconfig /? for help. REM More info on using the command line can be found at http://ss64.com/nt/ Quote Share this post Link to post
