bradcox5975 0 Posted ... Eddie disconnects several times a day and it seems to go into a startup loop. Im trying to figure out what is causeing it. the error that pops up says the requested protocol has not been configured into the system,or no implementation for it exist. i have tried turning off auto in protocol and manually selected different ones and all. even did a complete reinstall. im using version 2.17.2. and windows 10. Quote Share this post Link to post
Staff 10723 Posted ... Hello, can you please post a complete system report generated by Eddie? "Logs" > LIFE BELT icon > Copy All button > paste into your message (remove sensitive data if any). Kind regards Quote Share this post Link to post
bradcox5975 0 Posted ... 4 minutes ago, Staff said: Hello, can you please post a complete system report generated by Eddie? "Logs" > LIFE BELT icon > Copy All button > paste into your message (remove sensitive data if any). Kind regards Eddie System/Environment Report - 8/7/2019 10:45 AM UTC Eddie version: 2.17.2 Eddie OS build: windows_x64 Eddie architecture: x64 OS type: Windows OS name: Windows 10 Pro OS version: Microsoft Windows NT 10.0.18362.0 OS architecture: x64 Mono /.Net Framework: v4.0.30319 OpenVPN driver: TAP-Windows Adapter V9, version 9.21.2 OpenVPN: 2.4.6 - OpenSSL 1.1.0h 27 Mar 2018, LZO 2.10 (C:\Program Files\AirVPN\openvpn.exe) SSH: plink 0.67 (C:\Program Files\AirVPN\plink.exe) SSL: stunnel 5.40 (C:\Program Files\AirVPN\stunnel.exe) curl: 7.54.1 (C:\Program Files\AirVPN\curl.exe) Profile path: C:\Users\bradc\AppData\Local\AirVPN\default.xml Data path: C:\Users\bradc\AppData\Local\AirVPN Application path: C:\Program Files\AirVPN Executable path: C:\Program Files\AirVPN\Eddie-UI.exe Command line arguments: (1 args) path="home" Network Lock Active: No Connected to VPN: Yes, Ursa Detected DNS: 1.1.1.1, 8.8.8.8 Test DNS IPv4: Ok Test DNS IPv6: Failed Test Ping IPv4: 139 ms Test Ping IPv6: -1 ms Test HTTP IPv4: Ok Test HTTP IPv6: Error:curl: (7) Failed to connect to 2a03:b0c0:2:d0::11b4:6001 port 80: Network unreachable Test HTTPS: Ok ---------------------------- Important options not at defaults: login: (omissis) password: (omissis) remember: True connect: True servers.whitelist: 86deb732701bf37a98eb34fa43ec75f77e81679761acfac7d07fa15095ac451a,86bc4e7d4f0f95e92bbab6cb4366487c8e3afbf2be71d33c34c24014f28a4dbc servers.startlast: True mode.protocol: UDP mode.alt: 2 dns.servers: 8.8.8.8,1.1.1.1 dns.check: False network.entry.iface: 192.168.137.179 network.entry.iplayer: ipv4-only network.ipv6.mode: block network.ipv6.autoswitch: False ui.skip.provider.manifest.failed: True ---------------------------- Logs: . 2019.08.07 06:10:01 - Eddie version: 2.17.2 / windows_x64, System: Windows, Name: Windows 10 Pro, Version: Microsoft Windows NT 10.0.18362.0, Mono/.Net: v4.0.30319 . 2019.08.07 06:10:01 - Reading options from C:\Users\bradc\AppData\Local\AirVPN\default.xml . 2019.08.07 06:10:01 - Command line arguments (1): path="home" . 2019.08.07 06:10:01 - Profile path: C:\Users\bradc\AppData\Local\AirVPN\default.xml . 2019.08.07 06:10:04 - OpenVPN Driver - TAP-Windows Adapter V9, version 9.21.2 . 2019.08.07 06:10:04 - OpenVPN - Version: 2.4.6 - OpenSSL 1.1.0h 27 Mar 2018, LZO 2.10 (C:\Program Files\AirVPN\openvpn.exe) . 2019.08.07 06:10:04 - SSH - Version: plink 0.67 (C:\Program Files\AirVPN\plink.exe) . 2019.08.07 06:10:04 - SSL - Version: stunnel 5.40 (C:\Program Files\AirVPN\stunnel.exe) . 2019.08.07 06:10:04 - curl - Version: 7.54.1 (C:\Program Files\AirVPN\curl.exe) . 2019.08.07 06:10:04 - Certification Authorities: C:\Program Files\AirVPN\res\cacert.pem . 2019.08.07 06:10:04 - Recovery. Unexpected crash? E 2019.08.07 06:10:04 - The requested protocol has not been configured into the system, or no implementation for it exists I 2019.08.07 06:10:04 - Ready I 2019.08.07 06:10:04 - Session starting. . 2019.08.07 06:10:04 - Collect information about providers ... . 2019.08.07 06:10:06 - Collect information about AirVPN completed I 2019.08.07 06:10:06 - Checking authorization ... . 2019.08.07 06:10:06 - IPv6 disabled with packet filtering. ! 2019.08.07 06:10:06 - Connecting to Ursa (United States of America, Atlanta, Georgia) . 2019.08.07 06:10:06 - OpenVPN > OpenVPN 2.4.6 x86_64-w64-mingw32 [SSL (OpenSSL)] [LZO] [LZ4] [PKCS11] [AEAD] built on Apr 27 2018 . 2019.08.07 06:10:06 - OpenVPN > Windows version 6.2 (Windows 8 or greater) 64bit . 2019.08.07 06:10:06 - OpenVPN > library versions: OpenSSL 1.1.0h 27 Mar 2018, LZO 2.10 . 2019.08.07 06:10:06 - Connection to OpenVPN Management Interface . 2019.08.07 06:10:06 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3100 . 2019.08.07 06:10:06 - OpenVPN > Outgoing Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key . 2019.08.07 06:10:06 - OpenVPN > Outgoing Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication . 2019.08.07 06:10:06 - OpenVPN > Incoming Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key . 2019.08.07 06:10:06 - OpenVPN > Incoming Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication . 2019.08.07 06:10:06 - OpenVPN > TCP/UDP: Preserving recently used remote address: [AF_INET]64.42.179.53:443 . 2019.08.07 06:10:06 - OpenVPN > Socket Buffers: R=[65536->262144] S=[65536->262144] . 2019.08.07 06:10:06 - OpenVPN > UDP link local (bound): [AF_INET]192.168.137.179:1194 . 2019.08.07 06:10:06 - OpenVPN > UDP link remote: [AF_INET]64.42.179.53:443 . 2019.08.07 06:10:06 - OpenVPN > TLS: Initial packet from [AF_INET]64.42.179.53:443, sid=72bf35c5 c540020f . 2019.08.07 06:10:06 - OpenVPN > MANAGEMENT: Client connected from [AF_INET]127.0.0.1:3100 . 2019.08.07 06:10:06 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org . 2019.08.07 06:10:06 - OpenVPN > VERIFY KU OK . 2019.08.07 06:10:06 - OpenVPN > Validating certificate extended key usage . 2019.08.07 06:10:06 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication . 2019.08.07 06:10:06 - OpenVPN > VERIFY EKU OK . 2019.08.07 06:10:06 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=Ursa, emailAddress=info@airvpn.org . 2019.08.07 06:10:07 - OpenVPN > Control Channel: TLSv1.2, cipher TLSv1.2 DHE-RSA-AES256-GCM-SHA384, 4096 bit RSA . 2019.08.07 06:10:07 - OpenVPN > [Ursa] Peer Connection Initiated with [AF_INET]64.42.179.53:443 . 2019.08.07 06:10:08 - OpenVPN > SENT CONTROL [Ursa]: 'PUSH_REQUEST' (status=1) . 2019.08.07 06:10:08 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,comp-lzo no,redirect-gateway ipv6 def1 bypass-dhcp,dhcp-option DNS 10.23.158.1,dhcp-option DNS6 fde6:7a:7d20:139e::1,tun-ipv6,route-gateway 10.23.158.1,topology subnet,ping 10,ping-restart 60,ifconfig-ipv6 fde6:7a:7d20:139e::103d/64 fde6:7a:7d20:139e::1,ifconfig 10.23.158.63 255.255.255.0,peer-id 1,cipher AES-256-GCM' . 2019.08.07 06:10:08 - OpenVPN > Pushed option removed by filter: 'redirect-gateway ipv6 def1 bypass-dhcp' . 2019.08.07 06:10:08 - OpenVPN > Pushed option removed by filter: 'dhcp-option DNS6 fde6:7a:7d20:139e::1' . 2019.08.07 06:10:08 - OpenVPN > Pushed option removed by filter: 'tun-ipv6' . 2019.08.07 06:10:08 - OpenVPN > Pushed option removed by filter: 'ifconfig-ipv6 fde6:7a:7d20:139e::103d/64 fde6:7a:7d20:139e::1' . 2019.08.07 06:10:08 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified . 2019.08.07 06:10:08 - OpenVPN > OPTIONS IMPORT: compression parms modified . 2019.08.07 06:10:08 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified . 2019.08.07 06:10:08 - OpenVPN > OPTIONS IMPORT: route-related options modified . 2019.08.07 06:10:08 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified . 2019.08.07 06:10:08 - OpenVPN > OPTIONS IMPORT: peer-id set . 2019.08.07 06:10:08 - OpenVPN > OPTIONS IMPORT: adjusting link_mtu to 1625 . 2019.08.07 06:10:08 - OpenVPN > OPTIONS IMPORT: data channel crypto options modified . 2019.08.07 06:10:08 - OpenVPN > Data Channel: using negotiated cipher 'AES-256-GCM' . 2019.08.07 06:10:08 - OpenVPN > Outgoing Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key . 2019.08.07 06:10:08 - OpenVPN > Incoming Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key . 2019.08.07 06:10:08 - OpenVPN > interactive service msg_channel=0 . 2019.08.07 06:10:08 - OpenVPN > ROUTE_GATEWAY 192.168.137.1/255.255.255.0 I=15 HWADDR=ec:b1:d7:42:2f:f2 . 2019.08.07 06:10:08 - OpenVPN > open_tun . 2019.08.07 06:10:08 - OpenVPN > TAP-WIN32 device [Ethernet 2] opened: \\.\Global\{7EF2D7EC-2D87-4D34-942F-39AAEDCB8886}.tap . 2019.08.07 06:10:08 - OpenVPN > TAP-Windows Driver Version 9.21 . 2019.08.07 06:10:08 - OpenVPN > Set TAP-Windows TUN subnet mode network/local/netmask = 10.23.158.0/10.23.158.63/255.255.255.0 [SUCCEEDED] . 2019.08.07 06:10:08 - OpenVPN > Notified TAP-Windows driver to set a DHCP IP/netmask of 10.23.158.63/255.255.255.0 on interface {7EF2D7EC-2D87-4D34-942F-39AAEDCB8886} [DHCP-serv: 10.23.158.254, lease-time: 31536000] . 2019.08.07 06:10:08 - OpenVPN > Successful ARP Flush on interface [10] {7EF2D7EC-2D87-4D34-942F-39AAEDCB8886} . 2019.08.07 06:10:08 - OpenVPN > do_ifconfig, tt->did_ifconfig_ipv6_setup=0 . 2019.08.07 06:10:13 - OpenVPN > TEST ROUTES: 1/1 succeeded len=0 ret=1 a=0 u/d=up . 2019.08.07 06:10:13 - OpenVPN > C:\Windows\system32\route.exe ADD 64.42.179.53 MASK 255.255.255.255 192.168.137.1 . 2019.08.07 06:10:13 - OpenVPN > ROUTE: route addition failed using CreateIpForwardEntry: The object already exists. [status=5010 if_index=15] . 2019.08.07 06:10:13 - OpenVPN > Route addition via IPAPI failed [adaptive] . 2019.08.07 06:10:13 - OpenVPN > Route addition fallback to route.exe . 2019.08.07 06:10:13 - OpenVPN > env_block: add PATH=C:\Windows\System32;C:\Windows;C:\Windows\System32\Wbem . 2019.08.07 06:10:13 - OpenVPN > C:\Windows\system32\route.exe ADD 0.0.0.0 MASK 128.0.0.0 10.23.158.1 . 2019.08.07 06:10:13 - OpenVPN > ROUTE: route addition failed using CreateIpForwardEntry: The object already exists. [status=5010 if_index=10] . 2019.08.07 06:10:13 - OpenVPN > Route addition via IPAPI failed [adaptive] . 2019.08.07 06:10:13 - OpenVPN > Route addition fallback to route.exe . 2019.08.07 06:10:13 - OpenVPN > env_block: add PATH=C:\Windows\System32;C:\Windows;C:\Windows\System32\Wbem . 2019.08.07 06:10:13 - OpenVPN > C:\Windows\system32\route.exe ADD 128.0.0.0 MASK 128.0.0.0 10.23.158.1 . 2019.08.07 06:10:13 - OpenVPN > ROUTE: route addition failed using CreateIpForwardEntry: The object already exists. [status=5010 if_index=10] . 2019.08.07 06:10:13 - OpenVPN > Route addition via IPAPI failed [adaptive] . 2019.08.07 06:10:13 - OpenVPN > Route addition fallback to route.exe . 2019.08.07 06:10:13 - OpenVPN > env_block: add PATH=C:\Windows\System32;C:\Windows;C:\Windows\System32\Wbem . 2019.08.07 06:10:13 - Interface Ethernet 2 metric changed from Automatic to 3, layer IPv4 . 2019.08.07 06:10:13 - DNS leak protection with packet filtering enabled. . 2019.08.07 06:10:14 - DNS IPv4 of a network adapter forced (Ethernet 2, from automatic to 1.1.1.1, 8.8.8.8) . 2019.08.07 06:10:14 - Routes, added a new route, 64.42.179.51 for gateway 10.23.158.1 . 2019.08.07 06:10:14 - Unable to compute route for 2605:9f80:6000:79:291f:295e:3def:54a8: IPv6 VPN gateway not available. . 2019.08.07 06:10:14 - Flushing DNS I 2019.08.07 06:10:17 - Checking route IPv4 ! 2019.08.07 06:10:17 - Connected. . 2019.08.07 06:10:17 - OpenVPN > Initialization Sequence Completed . 2019.08.07 06:40:13 - Collect information about AirVPN completed ---------------------------- Network Interfaces and Routes: { "support_ipv4": true, "support_ipv6": true, "routes": [ { "address": "0.0.0.0\/0", "interface": "{E73061E5-9DFB-4A46-ABC4-2D9D37A120F0}", "gateway": "192.168.137.1", "metric": "281" }, { "address": "0.0.0.0\/1", "interface": "{7EF2D7EC-2D87-4D34-942F-39AAEDCB8886}", "gateway": "10.23.158.1", "metric": "3" }, { "address": "10.23.158.0\/24", "interface": "{7EF2D7EC-2D87-4D34-942F-39AAEDCB8886}", "gateway": "link", "metric": "259" }, { "address": "10.23.158.63", "interface": "{7EF2D7EC-2D87-4D34-942F-39AAEDCB8886}", "gateway": "link", "metric": "259" }, { "address": "10.23.158.255", "interface": "{7EF2D7EC-2D87-4D34-942F-39AAEDCB8886}", "gateway": "link", "metric": "259" }, { "address": "64.42.179.51", "interface": "{7EF2D7EC-2D87-4D34-942F-39AAEDCB8886}", "gateway": "10.23.158.1", "metric": "4" }, { "address": "64.42.179.53", "interface": "{E73061E5-9DFB-4A46-ABC4-2D9D37A120F0}", "gateway": "192.168.137.1", "metric": "25" }, { "address": "127.0.0.0\/8", "interface": "{037E5458-9089-11E9-9BCD-806E6F6E6963}", "gateway": "link", "metric": "331" }, { "address": "127.0.0.1", "interface": "{037E5458-9089-11E9-9BCD-806E6F6E6963}", "gateway": "link", "metric": "331" }, { "address": "127.255.255.255", "interface": "{037E5458-9089-11E9-9BCD-806E6F6E6963}", "gateway": "link", "metric": "331" }, { "address": "128.0.0.0\/1", "interface": "{7EF2D7EC-2D87-4D34-942F-39AAEDCB8886}", "gateway": "10.23.158.1", "metric": "3" }, { "address": "192.168.137.0\/24", "interface": "{E73061E5-9DFB-4A46-ABC4-2D9D37A120F0}", "gateway": "link", "metric": "281" }, { "address": "192.168.137.179", "interface": "{E73061E5-9DFB-4A46-ABC4-2D9D37A120F0}", "gateway": "link", "metric": "281" }, { "address": "192.168.137.255", "interface": "{E73061E5-9DFB-4A46-ABC4-2D9D37A120F0}", "gateway": "link", "metric": "281" }, { "address": "224.0.0.0\/4", "interface": "{037E5458-9089-11E9-9BCD-806E6F6E6963}", "gateway": "link", "metric": "331" }, { "address": "224.0.0.0\/4", "interface": "{7EF2D7EC-2D87-4D34-942F-39AAEDCB8886}", "gateway": "link", "metric": "259" }, { "address": "224.0.0.0\/4", "interface": "{E73061E5-9DFB-4A46-ABC4-2D9D37A120F0}", "gateway": "link", "metric": "281" }, { "address": "255.255.255.255", "interface": "{037E5458-9089-11E9-9BCD-806E6F6E6963}", "gateway": "link", "metric": "331" }, { "address": "255.255.255.255", "interface": "{7EF2D7EC-2D87-4D34-942F-39AAEDCB8886}", "gateway": "link", "metric": "259" }, { "address": "255.255.255.255", "interface": "{E73061E5-9DFB-4A46-ABC4-2D9D37A120F0}", "gateway": "link", "metric": "281" }, { "address": "::1", "interface": "{037E5458-9089-11E9-9BCD-806E6F6E6963}", "gateway": "link", "metric": "331" }, { "address": "ff00::\/8", "interface": "{037E5458-9089-11E9-9BCD-806E6F6E6963}", "gateway": "link", "metric": "331" }, { "address": "2605:9f80:6000:77:3824:245d:eb3b:b055", "gateway": "fde6:7a:7d20:1356::1", "metric": "4294967295" }, { "address": "2605:9f80:6000:79:291f:295e:3def:54a8", "gateway": "fde6:7a:7d20:1386::1", "metric": "4294967295" }, { "address": "2605:9f80:6000:77:3824:245d:eb3b:b055", "gateway": "fde6:7a:7d20:1342::1", "metric": "4294967295" }, { "address": "2605:9f80:6000:78:848d:e3b5:8bc8:34f", "gateway": "fde6:7a:7d20:1326::1", "metric": "4294967295" }, { "address": "2605:9f80:6000:79:291f:295e:3def:54a8", "gateway": "fde6:7a:7d20:1382::1", "metric": "4294967295" }, { "address": "2605:9f80:6000:79:291f:295e:3def:54a8", "gateway": "fde6:7a:7d20:138e::1", "metric": "4294967295" } ], "interfaces": [ { "friendly": "Ethernet 2", "id": "{7EF2D7EC-2D87-4D34-942F-39AAEDCB8886}", "name": "Ethernet 2", "description": "TAP-Windows Adapter V9", "type": "Ethernet", "status": "Up", "bytes_received": "129585600", "bytes_sent": "164542665", "support_ipv4": true, "support_ipv6": false, "ips": [ "10.23.158.63" ], "gateways": [ "10.23.158.1" ], "bind": true, "dns4": "8.8.8.8,1.1.1.1", "dns6": null }, { "friendly": "Ethernet", "id": "{E73061E5-9DFB-4A46-ABC4-2D9D37A120F0}", "name": "Ethernet", "description": "Intel(R) Ethernet Connection I217-LM", "type": "Ethernet", "status": "Up", "bytes_received": "2062380085052", "bytes_sent": "50258705073", "support_ipv4": true, "support_ipv6": false, "ips": [ "192.168.137.179" ], "gateways": [ "192.168.137.1" ], "bind": true, "dns4": "1.1.1.1,8.8.8.8", "dns6": null }, { "friendly": "Loopback Pseudo-Interface 1", "id": "{037E5458-9089-11E9-9BCD-806E6F6E6963}", "name": "Loopback Pseudo-Interface 1", "description": "Software Loopback Interface 1", "type": "Loopback", "status": "Up", "bytes_received": "0", "bytes_sent": "0", "support_ipv4": true, "support_ipv6": true, "ips": [ "::1", "127.0.0.1" ], "gateways": [], "bind": true, "dns4": "", "dns6": null } ], "ipv4-default-gateway": "10.23.158.1", "ipv4-default-interface": "{7EF2D7EC-2D87-4D34-942F-39AAEDCB8886}" } ---------------------------- ipconfig /all: Windows IP Configuration Host Name . . . . . . . . . . . . : DESKTOP-KTA54BV Primary Dns Suffix . . . . . . . : Node Type . . . . . . . . . . . . : Hybrid IP Routing Enabled. . . . . . . . : No WINS Proxy Enabled. . . . . . . . : No Ethernet adapter Ethernet 2: Connection-specific DNS Suffix . : Description . . . . . . . . . . . : TAP-Windows Adapter V9 Physical Address. . . . . . . . . : 00-FF-7E-F2-D7-EC DHCP Enabled. . . . . . . . . . . : Yes Autoconfiguration Enabled . . . . : Yes IPv4 Address. . . . . . . . . . . : 10.23.158.63(Preferred) Subnet Mask . . . . . . . . . . . : 255.255.255.0 Lease Obtained. . . . . . . . . . : Wednesday, August 7, 2019 6:10:08 AM Lease Expires . . . . . . . . . . : Thursday, August 6, 2020 6:10:08 AM Default Gateway . . . . . . . . . : DHCP Server . . . . . . . . . . . : 10.23.158.254 DNS Servers . . . . . . . . . . . : 8.8.8.8 1.1.1.1 NetBIOS over Tcpip. . . . . . . . : Enabled Ethernet adapter Ethernet: Connection-specific DNS Suffix . : Description . . . . . . . . . . . : Intel(R) Ethernet Connection I217-LM Physical Address. . . . . . . . . : EC-B1-D7-42-2F-F2 DHCP Enabled. . . . . . . . . . . : No Autoconfiguration Enabled . . . . : Yes IPv4 Address. . . . . . . . . . . : 192.168.137.179(Preferred) Subnet Mask . . . . . . . . . . . : 255.255.255.0 Default Gateway . . . . . . . . . : 192.168.137.1 DNS Servers . . . . . . . . . . . : 1.1.1.1 8.8.8.8 NetBIOS over Tcpip. . . . . . . . : Enabled Quote Share this post Link to post
Flx 81 Posted ... On 8/7/2019 at 6:49 AM, bradcox5975 said: Detected DNS: 1.1.1.1, 8.8.8.8 @bradcox5975 Why are you using Google DNS & CloudFlare DNS on your VPN adapter/connection? Any particular reason for this?Use OpenNIC or UncensoredDNS. On 8/7/2019 at 6:49 AM, bradcox5975 said: IPv4 Address. . . . . . . . . . . : 192.168.137.179(Preferred) That IP is used for Virtual mode. Quote Hide Flx's signature Hide all signatures Guide - EMBY Block ALL interfaces except tap/vpn Windows OS - Configuring your operating system Windows OS - Multi Session/Tunnel Share this post Link to post
bradcox5975 0 Posted ... 19 minutes ago, Flx said: @bradcox5975 Why are you using Google DNS & CloudFlare DNS on your VPN adapter/connection? Any particular reason for this?Use OpenNIC or UncensoredDNS. That IP is used for Virtual mode. No reason on the google/cloudflare. My whole network is 192.168.137. should i change it? Im using a erx router. On this box i also am running blueiris software for my ip cameras. Quote Share this post Link to post
Flx 81 Posted ... 17 minutes ago, bradcox5975 said: should i change it? Im using a erx router. From Amazon....Duckduckgo search--->>https://duckduckgo.com/?q=erx+router&t=ffab&atb=v180-4_j&ia=web --------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------- So, in summary the EdgeRouter X is a great router for most applications today, but it apparently can't process data at gigabit data rates. --------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------- 6) Save settings and reboot the router 7) Plug PC into ETH1 while router is rebooting 😎 Plug modem into ETH0 while router is rebooting 9) Set PC back to DHCP, automatic IP address 10) Let ERX boot back up and reconnect, sometimes I had to disable and re enable LAN connection in windows 10 in order to connect back to 192.168.1.1 --------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------- Quote Hide Flx's signature Hide all signatures Guide - EMBY Block ALL interfaces except tap/vpn Windows OS - Configuring your operating system Windows OS - Multi Session/Tunnel Share this post Link to post
bradcox5975 0 Posted ... 13 minutes ago, Flx said: From Amazon: --------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------- So, in summary the EdgeRouter X is a great router for most applications today, but it apparently can't process data at gigabit data rates. --------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------- 6) Save settings and reboot the router 7) Plug PC into ETH1 while router is rebooting 😎 Plug modem into ETH0 while router is rebooting 9) Set PC back to DHCP, automatic IP address 10) Let ERX boot back up and reconnect, sometimes I had to disable and re enable LAN connection in windows 10 in order to connect back to 192.168.1.1 --------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------- I only have a att lte connection so no gigabit. I only have 35-40mbps internet. what dns should i use? Quote Share this post Link to post
Flx 81 Posted ... 2 minutes ago, bradcox5975 said: what dns should i use? I prefer Uncensoreddns -->> https://blog.uncensoreddns.org/dns-servers/ I now use 2 routers(dd-wrt/tomato AirVPN connected) for DNS. Quote Hide Flx's signature Hide all signatures Guide - EMBY Block ALL interfaces except tap/vpn Windows OS - Configuring your operating system Windows OS - Multi Session/Tunnel Share this post Link to post
bradcox5975 0 Posted ... ok i changed the ip router to 192.168.1.1 and my whole network. but im still getting disconnects and the same error i also tried to restore defaults and it still didnt help. im going to remove the drive for the tap adapter and try that next. any other thoughts? Quote Share this post Link to post
Flx 81 Posted ... 8 hours ago, bradcox5975 said: any other thoughts? Use native OpenVPN if Eddie app doesn't work for you. Sad but it does happen.https://openvpn.net/community-downloads/ Install Comodo A/V & Firewall.https://www.comodo.com/home/internet-security/firewall.php?track=14594&af=14594 Install 9.23.x for Windows 10.tap-windows-9.23.3-I601-Win10.exe.zip Grab the Comodo Configuration File(Below). You will have to change IP/MAC addresses etc. as per your OS config. *Disable Windows Firewall Private/Public.*Close/Shutdown your torrent client while your doing the above* Quote Hide Flx's signature Hide all signatures Guide - EMBY Block ALL interfaces except tap/vpn Windows OS - Configuring your operating system Windows OS - Multi Session/Tunnel Share this post Link to post
Flx 81 Posted ... On 8/8/2019 at 6:52 PM, Flx said: I prefer Uncensoreddns -->> https://blog.uncensoreddns.org/dns-servers/ I now use 2 routers(dd-wrt/tomato AirVPN connected) for DNS. I use UncensoredDNS on the road. The 2 routers for the home network.Google DNS Cloudflare DNS or OpenDNS NOT RECOMMENDED. I'd rather let you decide on the DNS provider. Regards, Flx Quote Hide Flx's signature Hide all signatures Guide - EMBY Block ALL interfaces except tap/vpn Windows OS - Configuring your operating system Windows OS - Multi Session/Tunnel Share this post Link to post
