kbps
ANSWERED Eddie Android will not change connection port.
I have changed the settings to use a different port other than 443, however using quick connect it still always connects to 443.
There's also a setting in Settings > AirVPN > Quick connection mode. It's either Automatic or Use default options only, the latter being the options you set above.
Thanks, works. I missed that setting, I think because I was expecting a toggle switch rather than clicking again to select.
