UnevenSeven 0 Posted ... I find it odd that I always get the same exit IP address when connecting to Castor (haven't checked the other servers). I expected different addresses. What am I missing here? Thanks. Quote Share this post Link to post
Staff 10488 Posted ... I find it odd that I always get the same exit IP address when connecting to Castor (haven't checked the other servers). I expected different addresses.What am I missing here?Thanks.Hello!It's correct, each server has one, shared exit-IP address.Kind regards Quote Share this post Link to post
UnevenSeven 0 Posted ... So you know where to send that packet back via MAC address? Thanks again Regards Laurence. Quote Share this post Link to post
Staff 10488 Posted ... So you know where to send that packet back via MAC address?Hello!AirVPN is based on OpenVPN in routing mode. The TUN device handles layer 3, IP packets, not Ethernet frames. MAC addresses are not part of IP packets at all. In order to route packets correctly OpenVPN performs "NATting". Of course there are additional rules in order to allow correct port forwarding to all clients that require it.Kind regards Quote Share this post Link to post
UnevenSeven 0 Posted ... So if someone wanted to run an FTP server on the VPN, where would an FTP client connect to? Thanks, regards Quote Share this post Link to post
Staff 10488 Posted ... So if someone wanted to run an FTP server on the VPN, where would an FTP client connect to?Thanks, regardsHello!You can find all the relevant information (especially for an FTP server behind a VPN server) here:https://airvpn.org/index.php?option=com_kunena&func=view&catid=3&id=1700&Itemid=142#1702Kind regards Quote Share this post Link to post
