vector2012 0 Posted ... Got home today and tried to connect to all of the vpn servers. I am able to login successfully, but then when I attempt to connect to one of the servers, it just tries to connect forever. I have copied the logs from the client. This is the only computer that I connect with and it has worked wonderfully up until today. Please let me know what you think. This computer is quite literally only for using with Airvpn. 9/14/2012 - 11:00 PM AirVPN client version: 1.7 9/14/2012 - 11:00 PM Reading options from C:\Users\HTPC\AppData\Roaming\AirVPN\Air\1.0.0.0\AirVPN.xml 9/14/2012 - 11:00 PM OpenVPN bundle version: OpenVPN 2.2.2 9/14/2012 - 11:00 PM OpenVPN current version: OpenVPN 2.2.2 9/14/2012 - 11:00 PM Ready. 9/14/2012 - 11:00 PM Login... 9/14/2012 - 11:00 PM Login success. 9/14/2012 - 11:01 PM Contacting service... 9/14/2012 - 11:01 PM Connecting... 9/14/2012 - 11:01 PM OpenVPN 2.2.2 Win32-MSVC++ [sSL] [LZO2] [PKCS11] built on Dec 15 2011 9/14/2012 - 11:01 PM NOTE: OpenVPN 2.1 requires '--script-security 2' or higher to call user-defined scripts or executables 9/14/2012 - 11:01 PM LZO compression initialized 9/14/2012 - 11:01 PM Control Channel MTU parms [ L:1558 D:138 EF:38 EB:0 ET:0 EL:0 ] 9/14/2012 - 11:01 PM Socket Buffers: R=[8192->8192] S=[8192->8192] 9/14/2012 - 11:01 PM Data Channel MTU parms [ L:1558 D:1450 EF:58 EB:135 ET:0 EL:0 AF:3/1 ] 9/14/2012 - 11:01 PM Local Options hash (VER=V4): '22188c5b' 9/14/2012 - 11:01 PM Expected Remote Options hash (VER=V4): 'a8f55717' 9/14/2012 - 11:01 PM UDPv4 link local: [undef] 9/14/2012 - 11:01 PM UDPv4 link remote: 95.211.191.33:443 9/14/2012 - 11:01 PM TLS: Initial packet from 95.211.191.33:443, sid=5207987c 26bf36bc 9/14/2012 - 11:02 PM TLS Error: TLS key negotiation failed to occur within 60 seconds (check your network connectivity) 9/14/2012 - 11:02 PM TLS Error: TLS handshake failed 9/14/2012 - 11:02 PM TCP/UDP: Closing socket 9/14/2012 - 11:02 PM SIGUSR1[soft,tls-error] received, process restarting 9/14/2012 - 11:02 PM Restart pause, 2 second(s) 9/14/2012 - 11:02 PM NOTE: OpenVPN 2.1 requires '--script-security 2' or higher to call user-defined scripts or executables 9/14/2012 - 11:02 PM LZO compression initialized 9/14/2012 - 11:02 PM Control Channel MTU parms [ L:1558 D:138 EF:38 EB:0 ET:0 EL:0 ] 9/14/2012 - 11:02 PM Socket Buffers: R=[8192->8192] S=[8192->8192] 9/14/2012 - 11:02 PM Data Channel MTU parms [ L:1558 D:1450 EF:58 EB:135 ET:0 EL:0 AF:3/1 ] 9/14/2012 - 11:02 PM Local Options hash (VER=V4): '22188c5b' 9/14/2012 - 11:02 PM Expected Remote Options hash (VER=V4): 'a8f55717' 9/14/2012 - 11:02 PM UDPv4 link local: [undef] 9/14/2012 - 11:02 PM UDPv4 link remote: 95.211.191.33:443 9/14/2012 - 11:03 PM TLS Error: TLS key negotiation failed to occur within 60 seconds (check your network connectivity) 9/14/2012 - 11:03 PM TLS Error: TLS handshake failed 9/14/2012 - 11:03 PM TCP/UDP: Closing socket 9/14/2012 - 11:03 PM SIGUSR1[soft,tls-error] received, process restarting 9/14/2012 - 11:03 PM Restart pause, 2 second(s) 9/14/2012 - 11:03 PM NOTE: OpenVPN 2.1 requires '--script-security 2' or higher to call user-defined scripts or executables 9/14/2012 - 11:03 PM LZO compression initialized 9/14/2012 - 11:03 PM Control Channel MTU parms [ L:1558 D:138 EF:38 EB:0 ET:0 EL:0 ] 9/14/2012 - 11:03 PM Socket Buffers: R=[8192->8192] S=[8192->8192] 9/14/2012 - 11:03 PM Data Channel MTU parms [ L:1558 D:1450 EF:58 EB:135 ET:0 EL:0 AF:3/1 ] 9/14/2012 - 11:03 PM Local Options hash (VER=V4): '22188c5b' 9/14/2012 - 11:03 PM Expected Remote Options hash (VER=V4): 'a8f55717' 9/14/2012 - 11:03 PM UDPv4 link local: [undef] 9/14/2012 - 11:03 PM UDPv4 link remote: 95.211.191.33:443 9/14/2012 - 11:04 PM TLS Error: TLS key negotiation failed to occur within 60 seconds (check your network connectivity) 9/14/2012 - 11:04 PM TLS Error: TLS handshake failed 9/14/2012 - 11:04 PM TCP/UDP: Closing socket 9/14/2012 - 11:04 PM SIGUSR1[soft,tls-error] received, process restarting 9/14/2012 - 11:04 PM Restart pause, 2 second(s) 9/14/2012 - 11:04 PM NOTE: OpenVPN 2.1 requires '--script-security 2' or higher to call user-defined scripts or executables 9/14/2012 - 11:04 PM LZO compression initialized 9/14/2012 - 11:04 PM Control Channel MTU parms [ L:1558 D:138 EF:38 EB:0 ET:0 EL:0 ] 9/14/2012 - 11:04 PM Socket Buffers: R=[8192->8192] S=[8192->8192] 9/14/2012 - 11:04 PM Data Channel MTU parms [ L:1558 D:1450 EF:58 EB:135 ET:0 EL:0 AF:3/1 ] 9/14/2012 - 11:04 PM Local Options hash (VER=V4): '22188c5b' 9/14/2012 - 11:04 PM Expected Remote Options hash (VER=V4): 'a8f55717' 9/14/2012 - 11:04 PM UDPv4 link local: [undef] 9/14/2012 - 11:04 PM UDPv4 link remote: 95.211.191.33:443 Quote Share this post Link to post
plucas 0 Posted ... I seem to be having the same problem (just today) - Viscosity just gives me amber - trying to connect but no success, although I've only tried Leonis and Leoporis (never have any problems with them). Quote Share this post Link to post
Doowadiddy 0 Posted ... Same here, just recently tried connecting to Lyra and Omicron. Quote Share this post Link to post
pUag0iQc 0 Posted ... yep same here. I'm using connect without a client for Ubuntu though. Same problem. Quote Share this post Link to post
mkeluv 0 Posted ... Having identical problem (on all servers I've tried) with logs that look the same as above. Am using Tunnelblick. Any solutions would be greatly appreciated! Quote Share this post Link to post
Zeechsdd 0 Posted ... Same problem.. Except my OpenVPN logs folder is just empty and stays such have no idea how to check it sorry but it sounds exactly the same. No change to any settings, try to connect today and just sits on connecting screen. All servers. re-installed OpenVPN 2.2.2, tried the new Beta Openvpn with no change. Re-download airvpn client. Dont want to mess with much more since it was working perfectly just last night. Anyone made progress on this? Quote Share this post Link to post
Zeechsdd 0 Posted ... Worth mentioning, No activity from TAP network adapter during connecting screen EDIT: Definitely same problem. Tried all ports all protocol all servers. 9/15/2012 - 5:52 AM AirVPN client version: 1.7 9/15/2012 - 5:52 AM Reading options from XXXXXXXXXXXXXXXXXXXX 9/15/2012 - 5:52 AM OpenVPN bundle version: OpenVPN 2.2.2 9/15/2012 - 5:52 AM OpenVPN current version: OpenVPN 2.3_beta1 9/15/2012 - 5:52 AM Ready. 9/15/2012 - 5:52 AM Login... 9/15/2012 - 5:52 AM Login success. 9/15/2012 - 5:52 AM Contacting service... 9/15/2012 - 5:52 AM Connecting... 9/15/2012 - 5:52 AM OpenVPN 2.3_beta1 i686-w64-mingw32 [sSL (OpenSSL)] [LZO] [PKCS11] [eurephia] [iPv6] built on Sep 14 2012 9/15/2012 - 5:52 AM NOTE: OpenVPN 2.1 requires '--script-security 2' or higher to call user-defined scripts or executables 9/15/2012 - 5:52 AM Socket Buffers: R=[8192->8192] S=[8192->8192] 9/15/2012 - 5:52 AM UDPv4 link local: [undef] 9/15/2012 - 5:52 AM UDPv4 link remote: [AF_INET]178.248.30.131:443 9/15/2012 - 5:53 AM TLS Error: TLS key negotiation failed to occur within 60 seconds (check your network connectivity) 9/15/2012 - 5:53 AM TLS Error: TLS handshake failed 9/15/2012 - 5:53 AM SIGUSR1[soft,tls-error] received, process restarting 9/15/2012 - 5:53 AM Restart pause, 2 second(s) 9/15/2012 - 5:53 AM NOTE: OpenVPN 2.1 requires '--script-security 2' or higher to call user-defined scripts or executables 9/15/2012 - 5:53 AM Socket Buffers: R=[8192->8192] S=[8192->8192] 9/15/2012 - 5:53 AM UDPv4 link local: [undef] 9/15/2012 - 5:53 AM UDPv4 link remote: [AF_INET]178.248.30.131:443 9/15/2012 - 5:54 AM TLS Error: TLS key negotiation failed to occur within 60 seconds (check your network connectivity) 9/15/2012 - 5:54 AM TLS Error: TLS handshake failed 9/15/2012 - 5:56 AM Login... 9/15/2012 - 5:56 AM Login success. 9/15/2012 - 5:56 AM Contacting service... 9/15/2012 - 5:56 AM Connecting... 9/15/2012 - 5:56 AM OpenVPN 2.3_beta1 i686-w64-mingw32 [sSL (OpenSSL)] [LZO] [PKCS11] [eurephia] [iPv6] built on Sep 14 2012 9/15/2012 - 5:56 AM NOTE: OpenVPN 2.1 requires '--script-security 2' or higher to call user-defined scripts or executables 9/15/2012 - 5:56 AM Socket Buffers: R=[8192->8192] S=[8192->8192] 9/15/2012 - 5:56 AM UDPv4 link local: [undef] 9/15/2012 - 5:56 AM UDPv4 link remote: [AF_INET]178.248.30.131:80 9/15/2012 - 5:56 AM TLS: Initial packet from [AF_INET]178.248.30.131:80, sid=c77f3141 a97c3434 9/15/2012 - 5:57 AM TLS Error: TLS key negotiation failed to occur within 60 seconds (check your network connectivity) 9/15/2012 - 5:57 AM TLS Error: TLS handshake failed 9/15/2012 - 5:57 AM SIGUSR1[soft,tls-error] received, process restarting 9/15/2012 - 5:57 AM Restart pause, 2 second(s) ETC Quote Share this post Link to post
macca1102 0 Posted ... Same here as well.At least I know that it's not just me.I've been going crazy ,trying to figure it out for a couple of hours now.I'm getting the same TLS handshake error as the above log. Quote Share this post Link to post
Zeechsdd 0 Posted ... Tried to troubleshoot according to this post: https://airvpn.org/index.php?option=com_kunena&func=view&catid=2&id=894&Itemid=142 Best results are with TCP port 53 yet still no connection (NO PUSH REPLY ERROR), then continues on to TLS error 9/15/2012 - 6:12 AM AirVPN client version: 1.7 9/15/2012 - 6:12 AM Reading options from XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX 9/15/2012 - 6:12 AM OpenVPN bundle version: OpenVPN 2.2.2 9/15/2012 - 6:12 AM OpenVPN current version: OpenVPN 2.3_beta1 9/15/2012 - 6:12 AM Ready. 9/15/2012 - 6:12 AM Login... 9/15/2012 - 6:12 AM Login success. 9/15/2012 - 6:12 AM Contacting service... 9/15/2012 - 6:12 AM Connecting... 9/15/2012 - 6:12 AM OpenVPN 2.3_beta1 i686-w64-mingw32 [sSL (OpenSSL)] [LZO] [PKCS11] [eurephia] [iPv6] built on Sep 14 2012 9/15/2012 - 6:12 AM NOTE: OpenVPN 2.1 requires '--script-security 2' or higher to call user-defined scripts or executables 9/15/2012 - 6:12 AM Socket Buffers: R=[8192->8192] S=[8192->8192] 9/15/2012 - 6:12 AM Attempting to establish TCP connection with [AF_INET]46.165.208.65:53 9/15/2012 - 6:12 AM TCP connection established with [AF_INET]46.165.208.65:53 9/15/2012 - 6:12 AM TCPv4_CLIENT link local: [undef] 9/15/2012 - 6:12 AM TCPv4_CLIENT link remote: [AF_INET]46.165.208.65:53 9/15/2012 - 6:12 AM TLS: Initial packet from [AF_INET]46.165.208.65:53, sid=a0d2c134 a55a75f2 9/15/2012 - 6:12 AM VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org 9/15/2012 - 6:12 AM VERIFY OK: nsCertType=SERVER 9/15/2012 - 6:12 AM VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=server, emailAddress=info@airvpn.org 9/15/2012 - 6:12 AM Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key 9/15/2012 - 6:12 AM Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication 9/15/2012 - 6:12 AM Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key 9/15/2012 - 6:12 AM Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication 9/15/2012 - 6:12 AM Control Channel: TLSv1, cipher TLSv1/SSLv3 DHE-RSA-AES256-SHA, 2048 bit RSA 9/15/2012 - 6:12 AM [server] Peer Connection Initiated with [AF_INET]46.165.208.65:53 9/15/2012 - 6:12 AM SENT CONTROL [server]: 'PUSH_REQUEST' (status=1) 9/15/2012 - 6:13 AM SENT CONTROL [server]: 'PUSH_REQUEST' (status=1) 9/15/2012 - 6:13 AM SENT CONTROL [server]: 'PUSH_REQUEST' (status=1) 9/15/2012 - 6:13 AM SENT CONTROL [server]: 'PUSH_REQUEST' (status=1) 9/15/2012 - 6:13 AM SENT CONTROL [server]: 'PUSH_REQUEST' (status=1) 9/15/2012 - 6:13 AM SENT CONTROL [server]: 'PUSH_REQUEST' (status=1) 9/15/2012 - 6:13 AM SENT CONTROL [server]: 'PUSH_REQUEST' (status=1) 9/15/2012 - 6:13 AM SENT CONTROL [server]: 'PUSH_REQUEST' (status=1) 9/15/2012 - 6:13 AM SENT CONTROL [server]: 'PUSH_REQUEST' (status=1) 9/15/2012 - 6:13 AM SENT CONTROL [server]: 'PUSH_REQUEST' (status=1) 9/15/2012 - 6:13 AM SENT CONTROL [server]: 'PUSH_REQUEST' (status=1) 9/15/2012 - 6:13 AM SENT CONTROL [server]: 'PUSH_REQUEST' (status=1) 9/15/2012 - 6:13 AM No reply from server after sending 12 push requests 9/15/2012 - 6:13 AM SIGUSR1[soft,no-push-reply] received, process restarting 9/15/2012 - 6:13 AM Restart pause, 5 second(s) 9/15/2012 - 6:14 AM NOTE: OpenVPN 2.1 requires '--script-security 2' or higher to call user-defined scripts or executables 9/15/2012 - 6:14 AM Socket Buffers: R=[8192->8192] S=[8192->8192] 9/15/2012 - 6:14 AM Attempting to establish TCP connection with [AF_INET]46.165.208.65:53 9/15/2012 - 6:14 AM TCP connection established with [AF_INET]46.165.208.65:53 9/15/2012 - 6:14 AM TCPv4_CLIENT link local: [undef] 9/15/2012 - 6:14 AM TCPv4_CLIENT link remote: [AF_INET]46.165.208.65:53 9/15/2012 - 6:15 AM TLS Error: TLS key negotiation failed to occur within 60 seconds (check your network connectivity) 9/15/2012 - 6:15 AM TLS Error: TLS handshake failed 9/15/2012 - 6:15 AM Fatal TLS error (check_tls_errors_co), restarting 9/15/2012 - 6:15 AM SIGUSR1[soft,tls-error] received, process restarting 9/15/2012 - 6:15 AM Restart pause, 5 second(s) ETC Quote Share this post Link to post
jessez 3 Posted ... I'm having the same tls handshake error on all servers - TCP and UDP. The weird thing is, the status page shows a lot of users connected. https://airvpn.org/status/ Quote Share this post Link to post
Huisie 0 Posted ... I am also getting the TLS handshake error, no matter what server I try. I am using OpenVPN with .opvn files in config folder. Googling the error turned up several links suggesting that certificates needed to be updated. I downloaded the opvn files and certs again and installed them. Still no dice - same error. If it is a case of outdated certs, I find it surprising that anyone is connecting, according to the status page... Edit: I have also given the AirVPN GUI a try, but it doesn't connect either. Quote Share this post Link to post
johannes2510 0 Posted ... Same problem. No connection to any server. Quote Share this post Link to post
John__ 0 Posted ... Same problem. No connection to any server. Sep 15 09:36:03: Viscosity Mac 1.4.2 (1092) Sep 15 09:36:03: Viscosity OpenVPN Engine Started Sep 15 09:36:03: Running on Mac OS X 10.8.1 Sep 15 09:36:03: --------- Sep 15 09:36:03: Controllo la raggiungibilità della connessione… Sep 15 09:36:03: Connessione raggiungibile, inizio connessione. Sep 15 09:36:08: OpenVPN 2.3_alpha3 i386-apple-darwin10.8.0 [sSL (OpenSSL)] [LZO] [PKCS11] [MH] [PF_INET6] [iPv6 payload 20110522-1 (2.2.0)] built on Aug 6 2012 Sep 15 09:36:07: NOTE: OpenVPN 2.1 requires '--script-security 2' or higher to call user-defined scripts or executables Sep 15 09:36:08: UDPv4 link local: [undef] Sep 15 09:36:08: UDPv4 link remote: [AF_INET]46.165.208.65:443 Sep 15 09:37:08: TLS Error: TLS key negotiation failed to occur within 60 seconds (check your network connectivity) Sep 15 09:37:08: TLS Error: TLS handshake failed Sep 15 09:37:08: SIGUSR1[soft,tls-error] received, process restarting Sep 15 09:38:09: NOTE: OpenVPN 2.1 requires '--script-security 2' or higher to call user-defined scripts or executables Sep 15 09:38:09: UDPv4 link local: [undef] Sep 15 09:38:09: UDPv4 link remote: [AF_INET]46.165.208.65:443 Sep 15 09:39:09: TLS Error: TLS key negotiation failed to occur within 60 seconds (check your network connectivity) Sep 15 09:39:09: TLS Error: TLS handshake failed Sep 15 09:39:09: SIGUSR1[soft,tls-error] received, process restarting Quote Share this post Link to post
MaRkOpOlO 0 Posted ... I have the same problem however i did think at one point it was the client and i have checked on my linux (i have a dual boot PC) and it is the same error I am not sure what is going on atm but it is a server based or possibly client based but did any of you use comodo to block all other traffic that does not go through the VPN? Quote Share this post Link to post
steelth2 0 Posted ... Same problem please, no one answer us? even just to say 'we are working'! thanks Quote Share this post Link to post
MaRkOpOlO 0 Posted ... It could be a problem with ISP or certain countries aswell though. Quote Share this post Link to post
Staff 10385 Posted ... Hello! We have had a major problem on one of our backend servers. The problem did not affect already established connections or the website, but it did prevent new connections. The failover system worked only partially . The problem has been now fixed, however we are still working on the system so please do not hesitate to contact us for any further issue. Kind regards Quote Share this post Link to post
vector2012 0 Posted ... Thank you for the update. I can connect this morning. Quote Share this post Link to post
r0yal 0 Posted ... AirVPN has been working great, and for the past year I have been a paying customer, but starting yesterday, I am unable connect to any servers, and instead I receive these messages. Sat Sep 15 12:06:33 2012 SENT CONTROL [server]: 'PUSH_REQUEST' (status=1) Sat Sep 15 12:06:33 2012 AUTH: Received AUTH_FAILED control message Sat Sep 15 12:06:33 2012 SIGTERM received, sending exit notification to peer Sat Sep 15 12:06:38 2012 SENT CONTROL [server]: 'PUSH_REQUEST' (status=1) Sat Sep 15 12:06:38 2012 TCP/UDP: Closing socket Sat Sep 15 12:06:38 2012 SIGTERM[soft,exit-with-notification] received, process exiting Quote Share this post Link to post
Staff 10385 Posted ... AirVPN has been working great, and for the past year I have been a paying customer, but starting yesterday, I am unable connect to any servers, and instead I receive these messages.Sat Sep 15 12:06:33 2012 SENT CONTROL [server]: 'PUSH_REQUEST' (status=1)Sat Sep 15 12:06:33 2012 AUTH: Received AUTH_FAILED control messageSat Sep 15 12:06:33 2012 SIGTERM received, sending exit notification to peerSat Sep 15 12:06:38 2012 SENT CONTROL [server]: 'PUSH_REQUEST' (status=1)Sat Sep 15 12:06:38 2012 TCP/UDP: Closing socketSat Sep 15 12:06:38 2012 SIGTERM[soft,exit-with-notification] received, process exitingHello!Can you please try again now?Kind regards Quote Share this post Link to post
r0yal 0 Posted ... I tried using TCP and this happened the first time I tried: Sat Sep 15 15:00:38 2012 [server] Peer Connection Initiated with 108.59.11.194:443 Sat Sep 15 15:00:41 2012 SENT CONTROL [server]: 'PUSH_REQUEST' (status=1) Sat Sep 15 15:00:46 2012 SENT CONTROL [server]: 'PUSH_REQUEST' (status=1) Sat Sep 15 15:00:51 2012 SENT CONTROL [server]: 'PUSH_REQUEST' (status=1) Sat Sep 15 15:00:56 2012 SENT CONTROL [server]: 'PUSH_REQUEST' (status=1) Sat Sep 15 15:01:01 2012 SENT CONTROL [server]: 'PUSH_REQUEST' (status=1) Sat Sep 15 15:01:06 2012 SENT CONTROL [server]: 'PUSH_REQUEST' (status=1) Sat Sep 15 15:01:11 2012 SENT CONTROL [server]: 'PUSH_REQUEST' (status=1) Sat Sep 15 15:01:17 2012 SENT CONTROL [server]: 'PUSH_REQUEST' (status=1) Sat Sep 15 15:01:22 2012 SENT CONTROL [server]: 'PUSH_REQUEST' (status=1) Sat Sep 15 15:01:27 2012 SENT CONTROL [server]: 'PUSH_REQUEST' (status=1) Sat Sep 15 15:01:32 2012 SENT CONTROL [server]: 'PUSH_REQUEST' (status=1) Sat Sep 15 15:01:38 2012 SENT CONTROL [server]: 'PUSH_REQUEST' (status=1) Sat Sep 15 15:01:43 2012 SENT CONTROL [server]: 'PUSH_REQUEST' (status=1) Sat Sep 15 15:01:48 2012 SENT CONTROL [server]: 'PUSH_REQUEST' (status=1) Sat Sep 15 15:01:53 2012 SENT CONTROL [server]: 'PUSH_REQUEST' (status=1) Sat Sep 15 15:01:58 2012 SENT CONTROL [server]: 'PUSH_REQUEST' (status=1) Sat Sep 15 15:02:03 2012 SENT CONTROL [server]: 'PUSH_REQUEST' (status=1) Sat Sep 15 15:02:08 2012 SENT CONTROL [server]: 'PUSH_REQUEST' (status=1) I tried again and it worked after more errors, and then I tried UDP, and it is working now. Thanks! Quote Share this post Link to post
