JamesDean 10 Posted ... I'm on Castor right now, and the other servers exhibited no problems either, but Serpentis is giving me the following error: Wed Sep 12 16:40:31 2012 OpenVPN 2.2.2 Win32-MSVC++ [sSL] [LZO2] [PKCS11] built on Dec 15 2011 Wed Sep 12 16:40:31 2012 NOTE: OpenVPN 2.1 requires '--script-security 2' or higher to call user-defined scripts or executables Wed Sep 12 16:40:31 2012 LZO compression initialized Wed Sep 12 16:40:31 2012 Control Channel MTU parms [ L:1558 D:138 EF:38 EB:0 ET:0 EL:0 ] Wed Sep 12 16:40:31 2012 Socket Buffers: R=[8192->8192] S=[8192->8192] Wed Sep 12 16:40:31 2012 Data Channel MTU parms [ L:1558 D:1450 EF:58 EB:135 ET:0 EL:0 AF:3/1 ] Wed Sep 12 16:40:31 2012 Local Options hash (VER=V4): '22188c5b' Wed Sep 12 16:40:31 2012 Expected Remote Options hash (VER=V4): 'a8f55717' Wed Sep 12 16:40:31 2012 UDPv4 link local: [undef] Wed Sep 12 16:40:31 2012 UDPv4 link remote: 178.248.30.131:53 Wed Sep 12 16:40:31 2012 TLS: Initial packet from 178.248.30.131:53, sid=09de80e1 21c5afdd Wed Sep 12 16:40:41 2012 VERIFY OK: depth=1, /C=IT/ST=IT/L=Perugia/O=airvpn.org/CN=airvpn.org_CA/emailAddress=info@airvpn.org Wed Sep 12 16:40:41 2012 VERIFY OK: nsCertType=SERVER Wed Sep 12 16:40:41 2012 VERIFY OK: depth=0, /C=IT/ST=IT/L=Perugia/O=airvpn.org/CN=server/emailAddress=info@airvpn.org Wed Sep 12 16:41:31 2012 TLS Error: TLS key negotiation failed to occur within 60 seconds (check your network connectivity) Wed Sep 12 16:41:31 2012 TLS Error: TLS handshake failed Wed Sep 12 16:41:31 2012 TCP/UDP: Closing socket Wed Sep 12 16:41:31 2012 SIGUSR1[soft,tls-error] received, process restarting Wed Sep 12 16:41:31 2012 Restart pause, 2 second(s) Wed Sep 12 16:41:33 2012 NOTE: OpenVPN 2.1 requires '--script-security 2' or higher to call user-defined scripts or executables Wed Sep 12 16:41:33 2012 LZO compression initialized Wed Sep 12 16:41:33 2012 Control Channel MTU parms [ L:1558 D:138 EF:38 EB:0 ET:0 EL:0 ] Wed Sep 12 16:41:33 2012 Socket Buffers: R=[8192->8192] S=[8192->8192] Wed Sep 12 16:41:33 2012 Data Channel MTU parms [ L:1558 D:1450 EF:58 EB:135 ET:0 EL:0 AF:3/1 ] Wed Sep 12 16:41:33 2012 Local Options hash (VER=V4): '22188c5b' Wed Sep 12 16:41:33 2012 Expected Remote Options hash (VER=V4): 'a8f55717' Wed Sep 12 16:41:33 2012 UDPv4 link local: [undef] Wed Sep 12 16:41:33 2012 UDPv4 link remote: 178.248.30.131:53 Wed Sep 12 16:41:33 2012 TLS: Initial packet from 178.248.30.131:53, sid=be24a5f3 d95da2c5 Wed Sep 12 16:41:53 2012 SIGTERM received, sending exit notification to peer Wed Sep 12 16:41:58 2012 TCP/UDP: Closing socket Wed Sep 12 16:41:58 2012 SIGTERM[soft,exit-with-notification] received, process exiting It's been this way for a couple days. Using UDP 53, 80, or 443. JD Quote Share this post Link to post
Staff 10394 Posted ... I'm on Castor right now, and the other servers exhibited no problems either, but Serpentis is giving me the following error:Wed Sep 12 16:41:31 2012 TLS Error: TLS key negotiation failed to occur within 60 seconds (check your network connectivity)Wed Sep 12 16:41:31 2012 TLS Error: TLS handshake failedIt's been this way for a couple days. Using UDP 53, 80, or 443.JDHello!We don't detect any problem on any Serpentis port. All the monitoring & supervision systems show that Serpentis is up and running, listening to and accepting connections on all the designed ports. Is anybody else facing the same problem?Kind regards Quote Share this post Link to post
Willowz 0 Posted ... Same here. On port 80 I can't connect sometimes and so on 53 both ofr UDP. The connection speed is much slower and response time. Quote Share this post Link to post
archi 0 Posted ... I can't connect to serpentis using UDP Port 443 as well. Connection on TCP/80 is working fine. Quote Share this post Link to post
Staff 10394 Posted ... Hello! When Serpentis is under flood / DDoS attacks, the hardware firewall in front of it drops UDP packets [EDIT: correction, it shapes UDP traffic against flooding] in order to let Serpentis continue providing the service on TCP ports. Kind regards Quote Share this post Link to post
JamesDean 10 Posted ... OK, so that was the problem - DDOS? I'll download the TCP config. Is there anyway to have a section that alerts to which servers are being attacked, when it happens? Sad that idiots (or the RIAA/MPAA) DDOS VPNs. PD Quote Share this post Link to post
Staff 10394 Posted ... OK, so that was the problem - DDOS? I'll download the TCP config. Is there anyway to have a section that alerts to which servers are being attacked, when it happens? Sad that idiots (or the RIAA/MPAA) DDOS VPNs.PDHello!Yes, a new servers real time monitor which will provide you with more information is almost ready.Kind regards Quote Share this post Link to post
JamesDean 10 Posted ... My poor Swedish beauty is still sick on UDP. Is it still under attack? JD Quote Share this post Link to post
sunnymorning 1 Posted ... same here , still gotta use a netherland server atm -.- , i was hoping theyd get more swedish servers but apparently its taking a while Quote Share this post Link to post
Staff 10394 Posted ... Hello! We've warned the provider about the issue. We will keep you informed. Kind regards Quote Share this post Link to post
Staff 10394 Posted ... Hello! The problem looks solved. Can you please check and report at your convenience? Kind regards Quote Share this post Link to post
