Not connected, Your IP: 216.73.216.169
jm12
[SOLVED]Unidentified Network when I connect to air
Hi I never noticed this before and don't know if this is normal. When I connect to airvpn I see multiple networks in network and sharing center.
one is home network the other is an unidentified network that shows no internet access and shows up as public network!
is this normal? I am worried especially since it says its public...
when I disconnect from airvpn it disappears.
if I check my ip in firefox it says the airvpn ip and not my own.
thx
thx
This is totally normal and it's related to how Windows checks network "access".
Additionally, you might secure your connection against leaks in case of unexpected VPN disconnection. As you probably have already seen, we have a complete guide for Comodo for Windows to achieve this purpose.
oh ok. thank you for getting back to me. I will check out the comodo guide as well. Never used comodo but heard good things
Do not expect something with the power and versatility of iptables or pf, anyway Comodo is the best (and sadly the only reliable one) software firewall available for Windows.
