Not connected, Your IP: 216.73.216.169
kgramster
How to set up uTorrent with AirVPN?
I was wondering if the admins or the community would be able to do a step by step on how to set up AirVPN with uTorrent. I am trying to find a good VPN service and when I heard of this I thought I would give it a shot. However, I am a bit hesitant to sign up unless I know specifically how to get started. I am computer savvy but not technically savvy in this area and so I am a bit lost in how to get everything going. Any tips and suggestions would be helpful.
Firstly, it would be a good idea to search the forum first!
Secondly, it's the easiest thing in the world.
1. Connect to air with the client with your Username/pw
2. Start utorrent
- done -
for better performance: 3. Go to member area - forwarded ports - set your port you wanna use in utorrent.
-DONE-
- for better security -
4. Block utorrent when not connected to air
Can't think of anything else
good luck
In addition to FPyro post, you can also find a step by step tutorial on the FAQ https://airvpn.org/faq
i want to use u torrent over AirVPN.
Is blocking all Connection except IP Range 10.4.0.0 - 10.9.255.255 from
my Network adapter in Comodo Firewall the only thing i have to do,
to be save?
to be save?
Please see the permanent links in the announcements section of the forum in order to secure your connection according to your OS. We provide instructions for Comodo (Windows), pf (*BSD, Mac OS X), ipfw (*BSD, Mac OS X), iptables (Linux).
I read the Instructions for Comodo Firewall to prevent DNS Leaks.
Is it necessary to define all these Rules?
Can i use u torrent,like Fpyro wrote in his Post?
