sunnymorning
am able to connect to servers but no Ip
ive connected to serpentis , orionis , lepronis and non give me an ip i cant use the internet , ive had to remove the comodo firewall rule in order to use my original ip to open up this thread -.-
p.s> please fix the damned already connected message on the airvpn vpn client
this is strange comodo with airvpn client or open vpn works fine , you have to go in comodo "define a new trusted application " and add air vpn client or open vpn , if you do not make that you have no internet .........
Can you please send us the connection logs and your Comodo rules?
It was fixed. If you still have issues they are most probably on the client side. The logs will help troubleshooting.
You say the problems with the client are fixed? That's awesome news...gonna switch to the AirClient right away...hope not to be disappointed
8/23/2012 - 12:02 PM AirVPN client version: 1.7
8/23/2012 - 12:02 PM Reading options from C:\extra\Program Files Portable\AirVPN\AirVPN.xml
8/23/2012 - 12:03 PM OpenVPN bundle version: OpenVPN 2.2.2
8/23/2012 - 12:03 PM OpenVPN current version: OpenVPN 2.2.2
8/23/2012 - 12:03 PM OpenVPN is already under execution.
8/23/2012 - 12:04 PM OpenVPN is already under execution.
8/23/2012 - 6:26 PM OpenVPN is already under execution.
8/23/2012 - 6:28 PM Login...
8/23/2012 - 6:28 PM Login success.
8/23/2012 - 6:28 PM Contacting service...
8/23/2012 - 6:28 PM Connecting...
8/23/2012 - 6:28 PM OpenVPN 2.2.2 Win32-MSVC++ [sSL] [LZO2] [PKCS11] built on Dec 15 2011
8/23/2012 - 6:28 PM NOTE: OpenVPN 2.1 requires '--script-security 2' or higher to call user-defined scripts or executables
8/23/2012 - 6:28 PM LZO compression initialized
8/23/2012 - 6:28 PM Control Channel MTU parms [ L:1558 D:138 EF:38 EB:0 ET:0 EL:0 ]
8/23/2012 - 6:28 PM Socket Buffers: R=[8192->8192] S=[8192->8192]
8/23/2012 - 6:28 PM Data Channel MTU parms [ L:1558 D:1450 EF:58 EB:135 ET:0 EL:0 AF:3/1 ]
8/23/2012 - 6:28 PM Local Options hash (VER=V4): '22188c5b'
8/23/2012 - 6:28 PM Expected Remote Options hash (VER=V4): 'a8f55717'
8/23/2012 - 6:28 PM UDPv4 link local: [undef]
8/23/2012 - 6:28 PM UDPv4 link remote: 178.248.30.131:443
8/23/2012 - 6:28 PM TLS: Initial packet from 178.248.30.131:443, sid=47c58a8a 46f57570
8/23/2012 - 6:28 PM VERIFY OK: depth=1, /C=IT/ST=IT/L=Perugia/O=airvpn.org/CN=airvpn.org_CA/emailAddress=info@airvpn.org
8/23/2012 - 6:28 PM VERIFY OK: nsCertType=SERVER
8/23/2012 - 6:28 PM VERIFY OK: depth=0, /C=IT/ST=IT/L=Perugia/O=airvpn.org/CN=server/emailAddress=info@airvpn.org
8/23/2012 - 6:29 PM Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
8/23/2012 - 6:29 PM Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
8/23/2012 - 6:29 PM Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
8/23/2012 - 6:29 PM Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
8/23/2012 - 6:29 PM Control Channel: TLSv1, cipher TLSv1/SSLv3 DHE-RSA-AES256-SHA, 2048 bit RSA
8/23/2012 - 6:29 PM [server] Peer Connection Initiated with 178.248.30.131:443
8/23/2012 - 6:29 PM SENT CONTROL [server]: 'PUSH_REQUEST' (status=1)
8/23/2012 - 6:29 PM PUSH: Received control message: 'PUSH_REPLY,redirect-gateway def1,dhcp-option DNS 10.4.0.1,comp-lzo no,route 10.4.0.1,topology net30,ping 10,ping-restart 120,ifconfig 10.4.3.150 10.4.3.149'
8/23/2012 - 6:29 PM OPTIONS IMPORT: timers and/or timeouts modified
8/23/2012 - 6:29 PM OPTIONS IMPORT: LZO parms modified
8/23/2012 - 6:29 PM OPTIONS IMPORT: --ifconfig/up options modified
8/23/2012 - 6:29 PM OPTIONS IMPORT: route options modified
8/23/2012 - 6:29 PM OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified
8/23/2012 - 6:29 PM ROUTE default_gateway=10.1.1.0
8/23/2012 - 6:29 PM TAP-WIN32 device [AirVpn] opened: \\.\Global\{AB764FBA-5FCB-4932-B12F-A9172E1C32C7}.tap
8/23/2012 - 6:29 PM TAP-Win32 Driver Version 9.9
8/23/2012 - 6:29 PM TAP-Win32 MTU=1500
8/23/2012 - 6:29 PM Notified TAP-Win32 driver to set a DHCP IP/netmask of 10.4.3.150/255.255.255.252 on interface {AB764FBA-5FCB-4932-B12F-A9172E1C32C7} [DHCP-serv: 10.4.3.149, lease-time: 31536000]
8/23/2012 - 6:29 PM Successful ARP Flush on interface [15] {AB764FBA-5FCB-4932-B12F-A9172E1C32C7}
8/23/2012 - 6:29 PM TEST ROUTES: 2/2 succeeded len=1 ret=1 a=0 u/d=up
8/23/2012 - 6:29 PM C:\WINDOWS\system32\route.exe ADD 178.248.30.131 MASK 255.255.255.255 10.1.1.0
8/23/2012 - 6:29 PM ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=10 and dwForwardType=4
8/23/2012 - 6:29 PM Route addition via IPAPI succeeded [adaptive]
8/23/2012 - 6:29 PM C:\WINDOWS\system32\route.exe ADD 0.0.0.0 MASK 128.0.0.0 10.4.3.149
8/23/2012 - 6:29 PM ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=30 and dwForwardType=4
8/23/2012 - 6:29 PM C:\WINDOWS\system32\route.exe ADD 128.0.0.0 MASK 128.0.0.0 10.4.3.149
8/23/2012 - 6:29 PM C:\WINDOWS\system32\route.exe ADD 10.4.0.1 MASK 255.255.255.255 10.4.3.149
8/23/2012 - 6:29 PM Initialization Sequence Completed
8/23/2012 - 6:29 PM Starting Management Interface...
8/23/2012 - 6:29 PM Checking...
8/23/2012 - 6:29 PM Retrieve statistics...
8/23/2012 - 6:29 PM Connected.
8/23/2012 - 6:33 PM Disconnecting...
8/23/2012 - 6:33 PM SIGTERM received, sending exit notification to peer
8/23/2012 - 6:33 PM TCP/UDP: Closing socket
8/23/2012 - 6:33 PM Disconnected.
8/23/2012 - 6:33 PM C:\WINDOWS\system32\route.exe DELETE 10.4.0.1 MASK 255.255.255.255 10.4.3.149
8/23/2012 - 6:33 PM Route deletion via IPAPI succeeded [adaptive]
8/23/2012 - 6:33 PM C:\WINDOWS\system32\route.exe DELETE 178.248.30.131 MASK 255.255.255.255 10.1.1.0
8/23/2012 - 6:33 PM C:\WINDOWS\system32\route.exe DELETE 0.0.0.0 MASK 128.0.0.0 10.4.3.149
8/23/2012 - 6:33 PM C:\WINDOWS\system32\route.exe DELETE 128.0.0.0 MASK 128.0.0.0 10.4.3.149
8/23/2012 - 6:33 PM Closing TUN/TAP interface
8/23/2012 - 6:33 PM SIGTERM[hard,] received, process exiting
8/23/2012 - 6:37 PM Login...
8/23/2012 - 6:37 PM Login success.
8/23/2012 - 6:37 PM Contacting service...
8/23/2012 - 6:37 PM Connecting...
8/23/2012 - 6:37 PM OpenVPN 2.2.2 Win32-MSVC++ [sSL] [LZO2] [PKCS11] built on Dec 15 2011
8/23/2012 - 6:37 PM NOTE: OpenVPN 2.1 requires '--script-security 2' or higher to call user-defined scripts or executables
8/23/2012 - 6:37 PM LZO compression initialized
8/23/2012 - 6:37 PM Control Channel MTU parms [ L:1558 D:138 EF:38 EB:0 ET:0 EL:0 ]
8/23/2012 - 6:37 PM Socket Buffers: R=[8192->8192] S=[8192->8192]
8/23/2012 - 6:37 PM Data Channel MTU parms [ L:1558 D:1450 EF:58 EB:135 ET:0 EL:0 AF:3/1 ]
8/23/2012 - 6:37 PM Local Options hash (VER=V4): '22188c5b'
8/23/2012 - 6:37 PM Expected Remote Options hash (VER=V4): 'a8f55717'
8/23/2012 - 6:37 PM UDPv4 link local: [undef]
8/23/2012 - 6:37 PM UDPv4 link remote: 178.248.30.131:443
8/23/2012 - 6:37 PM TLS: Initial packet from 178.248.30.131:443, sid=433528b0 8a35d1b5
8/23/2012 - 6:37 PM VERIFY OK: depth=1, /C=IT/ST=IT/L=Perugia/O=airvpn.org/CN=airvpn.org_CA/emailAddress=info@airvpn.org
8/23/2012 - 6:37 PM VERIFY OK: nsCertType=SERVER
8/23/2012 - 6:37 PM VERIFY OK: depth=0, /C=IT/ST=IT/L=Perugia/O=airvpn.org/CN=server/emailAddress=info@airvpn.org
8/23/2012 - 6:37 PM Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
8/23/2012 - 6:37 PM Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
8/23/2012 - 6:37 PM Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
8/23/2012 - 6:37 PM Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
8/23/2012 - 6:37 PM Control Channel: TLSv1, cipher TLSv1/SSLv3 DHE-RSA-AES256-SHA, 2048 bit RSA
8/23/2012 - 6:37 PM [server] Peer Connection Initiated with 178.248.30.131:443
8/23/2012 - 6:37 PM SENT CONTROL [server]: 'PUSH_REQUEST' (status=1)
8/23/2012 - 6:37 PM PUSH: Received control message: 'PUSH_REPLY,redirect-gateway def1,dhcp-option DNS 10.4.0.1,comp-lzo no,route 10.4.0.1,topology net30,ping 10,ping-restart 120,ifconfig 10.4.3.150 10.4.3.149'
8/23/2012 - 6:37 PM OPTIONS IMPORT: timers and/or timeouts modified
8/23/2012 - 6:37 PM OPTIONS IMPORT: LZO parms modified
8/23/2012 - 6:37 PM OPTIONS IMPORT: --ifconfig/up options modified
8/23/2012 - 6:37 PM OPTIONS IMPORT: route options modified
8/23/2012 - 6:37 PM OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified
8/23/2012 - 6:37 PM ROUTE default_gateway=10.1.1.0
8/23/2012 - 6:37 PM TAP-WIN32 device [AirVpn] opened: \\.\Global\{AB764FBA-5FCB-4932-B12F-A9172E1C32C7}.tap
8/23/2012 - 6:37 PM TAP-Win32 Driver Version 9.9
8/23/2012 - 6:37 PM TAP-Win32 MTU=1500
8/23/2012 - 6:37 PM Notified TAP-Win32 driver to set a DHCP IP/netmask of 10.4.3.150/255.255.255.252 on interface {AB764FBA-5FCB-4932-B12F-A9172E1C32C7} [DHCP-serv: 10.4.3.149, lease-time: 31536000]
8/23/2012 - 6:37 PM Successful ARP Flush on interface [15] {AB764FBA-5FCB-4932-B12F-A9172E1C32C7}
8/23/2012 - 6:37 PM TEST ROUTES: 2/2 succeeded len=1 ret=1 a=0 u/d=up
8/23/2012 - 6:37 PM C:\WINDOWS\system32\route.exe ADD 178.248.30.131 MASK 255.255.255.255 10.1.1.0
8/23/2012 - 6:37 PM ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=10 and dwForwardType=4
8/23/2012 - 6:37 PM Route addition via IPAPI succeeded [adaptive]
8/23/2012 - 6:37 PM C:\WINDOWS\system32\route.exe ADD 0.0.0.0 MASK 128.0.0.0 10.4.3.149
8/23/2012 - 6:37 PM ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=30 and dwForwardType=4
8/23/2012 - 6:37 PM C:\WINDOWS\system32\route.exe ADD 128.0.0.0 MASK 128.0.0.0 10.4.3.149
8/23/2012 - 6:37 PM C:\WINDOWS\system32\route.exe ADD 10.4.0.1 MASK 255.255.255.255 10.4.3.149
8/23/2012 - 6:37 PM Initialization Sequence Completed
8/23/2012 - 6:37 PM Starting Management Interface...
8/23/2012 - 6:37 PM Checking...
8/23/2012 - 6:37 PM Retrieve statistics...
8/23/2012 - 6:38 PM Connected.
8/23/2012 - 6:43 PM [server] Inactivity timeout (--ping-restart), restarting
8/23/2012 - 6:43 PM TCP/UDP: Closing socket
8/23/2012 - 6:43 PM Re-connecting...
8/23/2012 - 6:43 PM C:\WINDOWS\system32\route.exe DELETE 10.4.0.1 MASK 255.255.255.255 10.4.3.149
8/23/2012 - 6:43 PM Route deletion via IPAPI succeeded [adaptive]
8/23/2012 - 6:43 PM C:\WINDOWS\system32\route.exe DELETE 178.248.30.131 MASK 255.255.255.255 10.1.1.0
8/23/2012 - 6:43 PM C:\WINDOWS\system32\route.exe DELETE 0.0.0.0 MASK 128.0.0.0 10.4.3.149
8/23/2012 - 6:43 PM C:\WINDOWS\system32\route.exe DELETE 128.0.0.0 MASK 128.0.0.0 10.4.3.149
8/23/2012 - 6:43 PM Closing TUN/TAP interface
8/23/2012 - 6:43 PM SIGUSR1[soft,ping-restart] received, process restarting
8/23/2012 - 6:43 PM Restart pause, 2 second(s)
8/23/2012 - 6:43 PM NOTE: OpenVPN 2.1 requires '--script-security 2' or higher to call user-defined scripts or executables
8/23/2012 - 6:43 PM LZO compression initialized
8/23/2012 - 6:43 PM Control Channel MTU parms [ L:1558 D:138 EF:38 EB:0 ET:0 EL:0 ]
8/23/2012 - 6:43 PM Socket Buffers: R=[8192->8192] S=[8192->8192]
8/23/2012 - 6:43 PM Data Channel MTU parms [ L:1558 D:1450 EF:58 EB:135 ET:0 EL:0 AF:3/1 ]
8/23/2012 - 6:43 PM Local Options hash (VER=V4): '22188c5b'
8/23/2012 - 6:43 PM Expected Remote Options hash (VER=V4): 'a8f55717'
8/23/2012 - 6:43 PM UDPv4 link local: [undef]
8/23/2012 - 6:43 PM UDPv4 link remote: 178.248.30.131:443
8/23/2012 - 6:43 PM TLS: Initial packet from 178.248.30.131:443, sid=77a75b95 a440971e
8/23/2012 - 6:43 PM VERIFY OK: depth=1, /C=IT/ST=IT/L=Perugia/O=airvpn.org/CN=airvpn.org_CA/emailAddress=info@airvpn.org
8/23/2012 - 6:43 PM VERIFY OK: nsCertType=SERVER
8/23/2012 - 6:43 PM VERIFY OK: depth=0, /C=IT/ST=IT/L=Perugia/O=airvpn.org/CN=server/emailAddress=info@airvpn.org
8/23/2012 - 6:43 PM Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
8/23/2012 - 6:43 PM Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
8/23/2012 - 6:43 PM Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
8/23/2012 - 6:43 PM Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
8/23/2012 - 6:43 PM Control Channel: TLSv1, cipher TLSv1/SSLv3 DHE-RSA-AES256-SHA, 2048 bit RSA
8/23/2012 - 6:43 PM [server] Peer Connection Initiated with 178.248.30.131:443
8/23/2012 - 6:43 PM SENT CONTROL [server]: 'PUSH_REQUEST' (status=1)
8/23/2012 - 6:43 PM PUSH: Received control message: 'PUSH_REPLY,redirect-gateway def1,dhcp-option DNS 10.4.0.1,comp-lzo no,route 10.4.0.1,topology net30,ping 10,ping-restart 120,ifconfig 10.4.3.150 10.4.3.149'
8/23/2012 - 6:43 PM OPTIONS IMPORT: timers and/or timeouts modified
8/23/2012 - 6:43 PM OPTIONS IMPORT: LZO parms modified
8/23/2012 - 6:43 PM OPTIONS IMPORT: --ifconfig/up options modified
8/23/2012 - 6:43 PM OPTIONS IMPORT: route options modified
8/23/2012 - 6:43 PM OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified
8/23/2012 - 6:43 PM ROUTE default_gateway=10.1.1.0
8/23/2012 - 6:43 PM TAP-WIN32 device [AirVpn] opened: \\.\Global\{AB764FBA-5FCB-4932-B12F-A9172E1C32C7}.tap
8/23/2012 - 6:43 PM TAP-Win32 Driver Version 9.9
8/23/2012 - 6:43 PM TAP-Win32 MTU=1500
8/23/2012 - 6:43 PM Notified TAP-Win32 driver to set a DHCP IP/netmask of 10.4.3.150/255.255.255.252 on interface {AB764FBA-5FCB-4932-B12F-A9172E1C32C7} [DHCP-serv: 10.4.3.149, lease-time: 31536000]
8/23/2012 - 6:43 PM Successful ARP Flush on interface [15] {AB764FBA-5FCB-4932-B12F-A9172E1C32C7}
8/23/2012 - 6:44 PM TEST ROUTES: 2/2 succeeded len=1 ret=1 a=0 u/d=up
8/23/2012 - 6:44 PM C:\WINDOWS\system32\route.exe ADD 178.248.30.131 MASK 255.255.255.255 10.1.1.0
8/23/2012 - 6:44 PM ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=10 and dwForwardType=4
8/23/2012 - 6:44 PM Route addition via IPAPI succeeded [adaptive]
8/23/2012 - 6:44 PM C:\WINDOWS\system32\route.exe ADD 0.0.0.0 MASK 128.0.0.0 10.4.3.149
8/23/2012 - 6:44 PM ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=30 and dwForwardType=4
8/23/2012 - 6:44 PM C:\WINDOWS\system32\route.exe ADD 128.0.0.0 MASK 128.0.0.0 10.4.3.149
8/23/2012 - 6:44 PM C:\WINDOWS\system32\route.exe ADD 10.4.0.1 MASK 255.255.255.255 10.4.3.149
8/23/2012 - 6:44 PM Initialization Sequence Completed
8/23/2012 - 6:44 PM Starting Management Interface...
8/23/2012 - 6:44 PM Checking...
8/23/2012 - 6:44 PM Unable to connect to the remote server
its very odd cause i can connect to tor while connected to sirius and others but not to the regular internet or utorrent or my email client, just about anything with 127.0.0.1 i guess, very odd have no freakin idea what ive did in order to do this -.-, since it works perfect on my other pc
p.s> good to know the already connected issue has been resolved,airvpn is whitelisted in comodo and after a while i get unable to connect to server too
Can you please send us the total set of your Comodo rules on the machine that has issues? Does something change if you set Comodo firewall security to "Disabled"?
no it does not change if i set comodo firewall to disabled , anyhow ill reinstall my os and double check then come back to you perhaps its another something gone wrong somewhere somehow wich is very unusual since i havent had problems this has only started since draconis got removed , no idea and my wifi ip is set to static not auto thou as said havent had problems as you know ever since ive started using air until the removal of draconis , thanks
https://airvpn.org/media/kunena/attachments/47686/airvpncomodo.JPG
only thing that changed is block rule 178.248.29.132 to 178.248.30.131 aka sirius , odd indeed
UPDATE! i have no idea what yall did but it works again just checked my main pc again like a minute ago it succesfully connects to the open webz not just tor , YES and i thought i messed up something even thou i didnt do anything at all except for shut down my pc that was where draconis was still on the server list hmmm....
only thing that changed is block rule 178.248.29.132 to 178.248.30.131 aka sirius ' date=' odd indeed
That was Draconis, not Sirius (just a side note).
Thank you for the information! We did not change anything... perhaps Windows messed up the network and a reboot fixed the issue.
