telemus
Internal servers, used for double-hop - seeking explanation
Hello
I've searched the forum (and am clearly using wrong search terms) - but I would be grateful if someone could explain the the "Routing - Internal servers, used for double-hop to avoid geolocation censorship. Not available for direct connections" entry on https://airvpn.org/status/, and how to use these servers.
Thanks heaps.
T.
