lanfear 0 Posted ... Everything seems to work and the VPN is up, but the log contains many disconnect errors. Here's the log right after startup. Serverlog Clientlog 20120811 23:54:31 I OpenVPN 2.1.3 mipsel-unknown-linux-gnu [sSL] [LZO2] [EPOLL] built on Apr 9 2011 20120811 23:54:31 MANAGEMENT: TCP Socket listening on 127.0.0.1:5001 20120811 23:54:32 W WARNING: file '/tmp/openvpncl/client.key' is group or others accessible 20120811 23:54:32 I LZO compression initialized 20120811 23:54:32 Control Channel MTU parms [ L:1558 D:138 EF:38 EB:0 ET:0 EL:0 ] 20120811 23:54:32 Socket Buffers: R=[114688->131072] S=[114688->131072] 20120811 23:54:32 Data Channel MTU parms [ L:1558 D:1450 EF:58 EB:135 ET:0 EL:0 AF:3/1 ] 20120811 23:54:32 I UDPv4 link local: [undef] 20120811 23:54:32 I UDPv4 link remote: 108.59.8.147:443 20120811 23:54:32 TLS: Initial packet from 108.59.8.147:443 sid=20e35d5d 149c2a83 20120811 23:54:32 VERIFY OK: depth=1 /C=IT/ST=IT/L=Perugia/O=airvpn.org/CN=airvpn.org_CA/emailAddress=info@airvpn.org 20120811 23:54:32 VERIFY OK: nsCertType=SERVER 20120811 23:54:32 VERIFY OK: depth=0 /C=IT/ST=IT/L=Perugia/O=airvpn.org/CN=server/emailAddress=info@airvpn.org 20120811 23:54:34 Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key 20120811 23:54:34 NOTE: --mute triggered... 20120811 23:54:34 4 variation(s) on previous 5 message(s) suppressed by --mute 20120811 23:54:34 I [server] Peer Connection Initiated with 108.59.8.147:443 20120811 23:54:36 SENT CONTROL [server]: 'PUSH_REQUEST' (status=1) 20120811 23:54:36 PUSH: Received control message: 'PUSH_REPLY redirect-gateway def1 dhcp-option DNS 10.4.0.1 comp-lzo no route 10.4.0.1 topology net30 ping 10 ping-restart 120 ifconfig 10.4.13.162 10.4.13.161' 20120811 23:54:36 OPTIONS IMPORT: timers and/or timeouts modified 20120811 23:54:36 OPTIONS IMPORT: LZO parms modified 20120811 23:54:36 OPTIONS IMPORT: --ifconfig/up options modified 20120811 23:54:36 NOTE: --mute triggered... 20120811 23:54:36 2 variation(s) on previous 5 message(s) suppressed by --mute 20120811 23:54:36 I TUN/TAP device tun1 opened 20120811 23:54:36 TUN/TAP TX queue length set to 100 20120811 23:54:36 I /sbin/ifconfig tun1 10.4.13.162 pointopoint 10.4.13.161 mtu 1500 20120811 23:54:36 /sbin/route add -net 108.59.8.147 netmask 255.255.255.255 gw 192.168.1.254 20120811 23:54:36 /sbin/route add -net 0.0.0.0 netmask 128.0.0.0 gw 10.4.13.161 20120811 23:54:36 /sbin/route add -net 128.0.0.0 netmask 128.0.0.0 gw 10.4.13.161 20120811 23:54:36 /sbin/route add -net 10.4.0.1 netmask 255.255.255.255 gw 10.4.13.161 20120811 23:54:36 I Initialization Sequence Completed 20120811 23:54:49 MANAGEMENT: Client connected from 127.0.0.1:5001 20120811 23:54:49 D MANAGEMENT: CMD 'state' 20120811 23:54:49 MANAGEMENT: Client disconnected 20120811 23:54:49 MANAGEMENT: Client connected from 127.0.0.1:5001 20120811 23:54:49 D MANAGEMENT: CMD 'state' 20120811 23:54:49 MANAGEMENT: Client disconnected 20120811 23:54:50 MANAGEMENT: Client connected from 127.0.0.1:5001 20120811 23:54:50 D MANAGEMENT: CMD 'state' 20120811 23:54:50 MANAGEMENT: Client disconnected 20120811 23:54:50 MANAGEMENT: Client connected from 127.0.0.1:5001 20120811 23:54:50 D MANAGEMENT: CMD 'state' 20120811 23:54:50 MANAGEMENT: Client disconnected 20120811 23:54:50 MANAGEMENT: Client connected from 127.0.0.1:5001 20120811 23:54:50 D MANAGEMENT: CMD 'state' 20120811 23:54:50 MANAGEMENT: Client disconnected 20120811 23:54:51 MANAGEMENT: Client connected from 127.0.0.1:5001 20120811 23:54:51 D MANAGEMENT: CMD 'log 500' 19700101 00:00:00 After this it will give more of these errors, but I can't find the cause of them. Is this important? Quote Share this post Link to post
Staff 10200 Posted ... Hello! If the VPN is continuously up and there's no leak, you might ignore that, but it would be safer to investigate. We'll look into this apparent problem as soon as possible, you might also like to report it in the DD-WRT support forum. Kind regards Quote Share this post Link to post
lanfear 0 Posted ... If I use dnsleaktest.com I can see the name servers from before the VPN as well. Is that what you mean by leak? It seems to do this "client disconnect" thing a few times per minute, but the connection is never really lost it seems. Quote Share this post Link to post
Staff 10200 Posted ... If I use dnsleaktest.com I can see the name servers from before the VPN as well. Is that what you mean by leak?It seems to do this "client disconnect" thing a few times per minute, but the connection is never really lost it seems.Hello!Yes, apparently you have a DNS leak. In order to prevent it, please see here (please read also the EDIT in the bottom):https://airvpn.org/index.php?option=com_kunena&func=view&catid=3&id=2377&Itemid=142#2377Kind regards Quote Share this post Link to post
lanfear 0 Posted ... Adding that last line to the iptables definitely does something. I can't access the router of course unless I reboot it, in addition I can access this webpage for example , but I can access very few other ones. No google.com for example. Something is still off about the DNS, am I forgetting something obvious? Quote Share this post Link to post
Tamarrano 4 Posted ... HI I have the same problem .... Serverlog Clientlog 20120813 15:58:28 I OpenVPN 2.2.1 mips-linux [sSL] [LZO2] built on Mar 19 2012 20120813 15:58:28 MANAGEMENT: TCP Socket listening on 127.0.0.1:5001 20120813 15:58:28 W NOTE: the current --script-security setting may allow this configuration to call user-defined scripts 20120813 15:58:28 W WARNING: file '/tmp/openvpncl/client.key' is group or others accessible 20120813 15:58:28 I LZO compression initialized 20120813 15:58:28 Control Channel MTU parms [ L:1558 D:138 EF:38 EB:0 ET:0 EL:0 ] 20120813 15:58:28 Socket Buffers: R=[163840->131072] S=[163840->131072] 20120813 15:58:28 Data Channel MTU parms [ L:1558 D:1450 EF:58 EB:135 ET:0 EL:0 AF:3/1 ] 20120813 15:58:28 Local Options String: 'V4 dev-type tun link-mtu 1558 tun-mtu 1500 proto UDPv4 comp-lzo cipher AES-256-CBC auth SHA1 keysize 256 key-method 2 tls-client' 20120813 15:58:28 Expected Remote Options String: 'V4 dev-type tun link-mtu 1558 tun-mtu 1500 proto UDPv4 comp-lzo cipher AES-256-CBC auth SHA1 keysize 256 key-method 2 tls-server' 20120813 15:58:28 Local Options hash (VER=V4): '22188c5b' 20120813 15:58:28 Expected Remote Options hash (VER=V4): 'a8f55717' 20120813 15:58:28 I UDPv4 link local: [undef] 20120813 15:58:28 I UDPv4 link remote: 178.248.29.132:443 20120813 15:58:28 TLS: Initial packet from 178.248.29.132:443 sid=47de7ecd 71b5534b 20120813 15:58:28 VERIFY OK: depth=1 /C=IT/ST=IT/L=Perugia/O=airvpn.org/CN=airvpn.org_CA/emailAddress=info@airvpn.org 20120813 15:58:29 VERIFY OK: nsCertType=SERVER 20120813 15:58:29 VERIFY OK: depth=0 /C=IT/ST=IT/L=Perugia/O=airvpn.org/CN=server/emailAddress=info@airvpn.org 20120813 15:58:30 Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key 20120813 15:58:30 NOTE: --mute triggered... 20120813 15:58:30 4 variation(s) on previous 5 message(s) suppressed by --mute 20120813 15:58:30 I [server] Peer Connection Initiated with 178.248.29.132:443 20120813 15:58:32 SENT CONTROL [server]: 'PUSH_REQUEST' (status=1) 20120813 15:58:32 PUSH: Received control message: 'PUSH_REPLY redirect-gateway def1 dhcp-option DNS 10.4.0.1 comp-lzo no route 10.4.0.1 topology net30 ping 10 ping-restart 120 ifconfig 10.4.24.150 10.4.24.149' 20120813 15:58:32 OPTIONS IMPORT: timers and/or timeouts modified 20120813 15:58:32 OPTIONS IMPORT: LZO parms modified 20120813 15:58:32 OPTIONS IMPORT: --ifconfig/up options modified 20120813 15:58:32 NOTE: --mute triggered... 20120813 15:58:32 2 variation(s) on previous 5 message(s) suppressed by --mute 20120813 15:58:32 I TUN/TAP device tun1 opened 20120813 15:58:32 TUN/TAP TX queue length set to 100 20120813 15:58:32 I /sbin/ifconfig tun1 10.4.24.150 pointopoint 10.4.24.149 mtu 1500 20120813 15:58:32 /sbin/route add -net 178.248.29.132 netmask 255.255.255.255 gw 192.168.1.3 20120813 15:58:32 /sbin/route add -net 0.0.0.0 netmask 128.0.0.0 gw 10.4.24.149 20120813 15:58:32 /sbin/route add -net 128.0.0.0 netmask 128.0.0.0 gw 10.4.24.149 20120813 15:58:32 /sbin/route add -net 10.4.0.1 netmask 255.255.255.255 gw 10.4.24.149 20120813 15:58:32 I Initialization Sequence Completed 20120813 15:58:46 Replay-window backtrack occurred [1] 20120813 15:59:03 MANAGEMENT: Client connected from 127.0.0.1:5001 20120813 15:59:03 D MANAGEMENT: CMD 'state' 20120813 15:59:03 MANAGEMENT: Client disconnected 20120813 15:59:03 MANAGEMENT: Client connected from 127.0.0.1:5001 20120813 15:59:03 D MANAGEMENT: CMD 'state' 20120813 15:59:03 MANAGEMENT: Client disconnected 20120813 15:59:03 MANAGEMENT: Client connected from 127.0.0.1:5001 20120813 15:59:03 D MANAGEMENT: CMD 'state' 20120813 15:59:03 MANAGEMENT: Client disconnected 20120813 15:59:03 MANAGEMENT: Client connected from 127.0.0.1:5001 20120813 15:59:03 D MANAGEMENT: CMD 'log 500' 19700101 00:00:00 but all works fine and I add this dsn 80.67.0.2 if I make a test from http://www.dnsleaktest.com/ I get the correct dsn 80.67.0.2 please post router name and ddwrt version I have a TP-Link TL-WR1043ND DD-WRT v24-sp2 (03/19/12) std - build 18777 if all works fine should I worry about it ? it seems all works fine ,,,,,, please let me know about it regards Quote Share this post Link to post
Tamarrano 4 Posted ... now that I am doing more tests I saw on the log that I get a lots of (eplay-window backtrack occurred [2] ) 20120813 15:59:03 D MANAGEMENT: CMD 'state' 20120813 15:59:03 MANAGEMENT: Client disconnected 20120813 15:59:03 MANAGEMENT: Client connected from 127.0.0.1:5001 20120813 15:59:03 D MANAGEMENT: CMD 'log 500' 20120813 15:59:03 MANAGEMENT: Client disconnected 20120813 16:01:19 Replay-window backtrack occurred [2] 20120813 16:06:42 Replay-window backtrack occurred [3] 20120813 16:08:05 Replay-window backtrack occurred [8] 20120813 16:08:11 Replay-window backtrack occurred [17] 20120813 16:08:22 Replay-window backtrack occurred [18] 20120813 16:08:24 NOTE: --mute triggered... 20120813 16:09:17 1 variation(s) on previous 5 message(s) suppressed by --mute 20120813 16:09:17 MANAGEMENT: Client connected from 127.0.0.1:5001 20120813 16:09:17 D MANAGEMENT: CMD 'state' 20120813 16:09:17 MANAGEMENT: Client disconnected 20120813 16:09:17 MANAGEMENT: Client connected from 127.0. what does it means ? Quote Share this post Link to post
Tamarrano 4 Posted ... again me !! I have all this kind of logs mistakes but the internet works perfect , I do not see any problems while I download or I surf but I would like to know from an expert if it is normal and I do not need to worry about it regards Quote Share this post Link to post
Staff 10200 Posted ... Hello! Network congestion and latency may cause the UDP to drop packets. When this happens you can see a 'Replay window backtrack occurred' in the OpenVPN log. Unless you completely lose connectivity, this is only a overhead issue, because the OpenVPN server is able to resend lost packets even with UDP, that's why your connection works just fine. One solution is to switch to TCP if the errors become so frequent to cause a disconnection from the VPN server(s). See also: http://openvpn.net/archive/openvpn-users/2004-09/msg00068.html Kind regards Quote Share this post Link to post
