Not connected, Your IP: 216.73.216.47
EduardStoo
ANSWERED EDDIE 2.16.3 Just Hanging/Re-Starting Constantly
Hi -
Was wondering if anyone could help me on this. EDDIE was taking about 12 attempts to connect each time previously, citing the 'IPv6 is disabled at OS level' message repeatedly, BUT it would eventually connect. I have since upgraded to 2.16.3 but must've done something to the settings, as now it just hangs and hangs, re-starting from server to server.
I cannot connect to the internet either through EDDIE or outside of EDDIE, regardless of network lock status?
Latest attempt logs show this:
. 2019.04.06 16:53:22 - Eddie version: 2.16.3 / windows_x64, System: Windows, Name: Windows 10 Home, Version: Microsoft Windows NT 10.0.17134.0, Mono/.Net: v4.0.30319
. 2019.04.06 16:53:22 - Reading options from C:\Program Files\AirVPN\default.xml
. 2019.04.06 16:53:22 - Command line arguments (0):
. 2019.04.06 16:53:22 - Profile path: C:\Program Files\AirVPN\default.xml
. 2019.04.06 16:53:25 - OpenVPN Driver - TAP-Windows Adapter V9, version 9.21.2
. 2019.04.06 16:53:25 - OpenVPN - Version: 2.4.6 - OpenSSL 1.1.0h  27 Mar 2018, LZO 2.10 (C:\Program Files\AirVPN\openvpn.exe)
. 2019.04.06 16:53:25 - SSH - Version: plink 0.67 (C:\Program Files\AirVPN\plink.exe)
. 2019.04.06 16:53:25 - SSL - Version: stunnel 5.40 (C:\Program Files\AirVPN\stunnel.exe)
. 2019.04.06 16:53:25 - curl - Version: 7.54.1 (C:\Program Files\AirVPN\curl.exe)
. 2019.04.06 16:53:25 - Certification Authorities: C:\Program Files\AirVPN\res\cacert.pem
. 2019.04.06 16:53:26 - Updating systems & servers data ...
I 2019.04.06 16:53:27 - Ready
. 2019.04.06 16:53:27 - Systems & servers data update completed
! 2019.04.06 16:53:33 - Activation of Network Lock - Windows Filtering Platform
I 2019.04.06 16:53:34 - Session starting.
I 2019.04.06 16:53:35 - Checking authorization ...
. 2019.04.06 16:53:36 - IPv6 disabled with packet filtering.
! 2019.04.06 16:53:36 - Connecting to Capricornus (Belgium, Brussels)
. 2019.04.06 16:53:36 - OpenVPN > OpenVPN 2.4.6 x86_64-w64-mingw32 [sSL (OpenSSL)] [LZO] [LZ4] [PKCS11] [AEAD] built on Apr 27 2018
. 2019.04.06 16:53:36 - OpenVPN > Windows version 6.2 (Windows 8 or greater) 64bit
. 2019.04.06 16:53:36 - OpenVPN > library versions: OpenSSL 1.1.0h  27 Mar 2018, LZO 2.10
. 2019.04.06 16:53:36 - Connection to OpenVPN Management Interface
. 2019.04.06 16:53:36 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3100
. 2019.04.06 16:53:36 - OpenVPN > Outgoing Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key
. 2019.04.06 16:53:36 - OpenVPN > Outgoing Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication
. 2019.04.06 16:53:36 - OpenVPN > Incoming Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key
. 2019.04.06 16:53:36 - OpenVPN > Incoming Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication
. 2019.04.06 16:53:36 - OpenVPN > TCP/UDP: Preserving recently used remote address: [AF_INET]194.187.251.93:443
. 2019.04.06 16:53:36 - OpenVPN > Socket Buffers: R=[65536->262144] S=[65536->262144]
. 2019.04.06 16:53:36 - OpenVPN > UDP link local: (not bound)
. 2019.04.06 16:53:36 - OpenVPN > UDP link remote: [AF_INET]194.187.251.93:443
. 2019.04.06 16:53:36 - OpenVPN > MANAGEMENT: Client connected from [AF_INET]127.0.0.1:3100
. 2019.04.06 16:54:08 - OpenVPN > [uNDEF] Inactivity timeout (--ping-exit), exiting
. 2019.04.06 16:54:08 - OpenVPN > SIGTERM received, sending exit notification to peer
. 2019.04.06 16:54:13 - OpenVPN > SIGTERM[soft,exit-with-notification] received, process exiting
! 2019.04.06 16:54:13 - Disconnecting
. 2019.04.06 16:54:13 - Connection terminated.
. 2019.04.06 16:54:13 - IPv6 restored with packet filtering.
I 2019.04.06 16:54:16 - Checking authorization ...
. 2019.04.06 16:54:17 - IPv6 disabled with packet filtering.
! 2019.04.06 16:54:17 - Connecting to Mebsuta (Belgium, Brussels)
. 2019.04.06 16:54:17 - OpenVPN > OpenVPN 2.4.6 x86_64-w64-mingw32 [sSL (OpenSSL)] [LZO] [LZ4] [PKCS11] [AEAD] built on Apr 27 2018
. 2019.04.06 16:54:17 - OpenVPN > Windows version 6.2 (Windows 8 or greater) 64bit
. 2019.04.06 16:54:17 - OpenVPN > library versions: OpenSSL 1.1.0h  27 Mar 2018, LZO 2.10
. 2019.04.06 16:54:17 - Connection to OpenVPN Management Interface
. 2019.04.06 16:54:17 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3100
. 2019.04.06 16:54:17 - OpenVPN > Outgoing Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key
. 2019.04.06 16:54:17 - OpenVPN > Outgoing Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication
. 2019.04.06 16:54:17 - OpenVPN > Incoming Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key
. 2019.04.06 16:54:17 - OpenVPN > Incoming Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication
. 2019.04.06 16:54:17 - OpenVPN > TCP/UDP: Preserving recently used remote address: [AF_INET]194.187.251.157:443
. 2019.04.06 16:54:17 - OpenVPN > Socket Buffers: R=[65536->262144] S=[65536->262144]
. 2019.04.06 16:54:17 - OpenVPN > UDP link local: (not bound)
. 2019.04.06 16:54:17 - OpenVPN > UDP link remote: [AF_INET]194.187.251.157:443
. 2019.04.06 16:54:17 - OpenVPN > MANAGEMENT: Client connected from [AF_INET]127.0.0.1:3100
. 2019.04.06 16:54:49 - OpenVPN > [uNDEF] Inactivity timeout (--ping-exit), exiting
. 2019.04.06 16:54:49 - OpenVPN > SIGTERM received, sending exit notification to peer
. 2019.04.06 16:54:54 - OpenVPN > SIGTERM[soft,exit-with-notification] received, process exiting
! 2019.04.06 16:54:54 - Disconnecting
. 2019.04.06 16:54:54 - Connection terminated.
. 2019.04.06 16:54:54 - IPv6 restored with packet filtering.
I 2019.04.06 16:54:57 - Checking authorization ...
. 2019.04.06 16:54:57 - IPv6 disabled with packet filtering.
! 2019.04.06 16:54:57 - Connecting to Tarazed (Netherlands, Alblasserdam)
. 2019.04.06 16:54:57 - OpenVPN > OpenVPN 2.4.6 x86_64-w64-mingw32 [sSL (OpenSSL)] [LZO] [LZ4] [PKCS11] [AEAD] built on Apr 27 2018
. 2019.04.06 16:54:57 - OpenVPN > Windows version 6.2 (Windows 8 or greater) 64bit
. 2019.04.06 16:54:57 - OpenVPN > library versions: OpenSSL 1.1.0h  27 Mar 2018, LZO 2.10
. 2019.04.06 16:54:57 - Connection to OpenVPN Management Interface
. 2019.04.06 16:54:57 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3100
. 2019.04.06 16:54:57 - OpenVPN > Outgoing Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key
. 2019.04.06 16:54:57 - OpenVPN > Outgoing Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication
. 2019.04.06 16:54:57 - OpenVPN > Incoming Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key
. 2019.04.06 16:54:57 - OpenVPN > Incoming Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication
. 2019.04.06 16:54:57 - OpenVPN > TCP/UDP: Preserving recently used remote address: [AF_INET]213.152.161.135:443
. 2019.04.06 16:54:57 - OpenVPN > Socket Buffers: R=[65536->262144] S=[65536->262144]
. 2019.04.06 16:54:57 - OpenVPN > UDP link local: (not bound)
. 2019.04.06 16:54:57 - OpenVPN > UDP link remote: [AF_INET]213.152.161.135:443
. 2019.04.06 16:54:57 - OpenVPN > MANAGEMENT: Client connected from [AF_INET]127.0.0.1:3100
. 2019.04.06 16:55:29 - OpenVPN > [uNDEF] Inactivity timeout (--ping-exit), exiting
. 2019.04.06 16:55:29 - OpenVPN > SIGTERM received, sending exit notification to peer
. 2019.04.06 16:55:34 - OpenVPN > SIGTERM[soft,exit-with-notification] received, process exiting
! 2019.04.06 16:55:34 - Disconnecting
. 2019.04.06 16:55:34 - Connection terminated.
. 2019.04.06 16:55:34 - IPv6 restored with packet filtering.
I 2019.04.06 16:55:37 - Checking authorization ...
. 2019.04.06 16:55:38 - IPv6 disabled with packet filtering.
! 2019.04.06 16:55:38 - Connecting to Diadema (Belgium, Brussels)
. 2019.04.06 16:55:38 - OpenVPN > OpenVPN 2.4.6 x86_64-w64-mingw32 [sSL (OpenSSL)] [LZO] [LZ4] [PKCS11] [AEAD] built on Apr 27 2018
. 2019.04.06 16:55:38 - OpenVPN > Windows version 6.2 (Windows 8 or greater) 64bit
. 2019.04.06 16:55:38 - OpenVPN > library versions: OpenSSL 1.1.0h  27 Mar 2018, LZO 2.10
. 2019.04.06 16:55:38 - Connection to OpenVPN Management Interface
. 2019.04.06 16:55:38 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3100
. 2019.04.06 16:55:38 - OpenVPN > Outgoing Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key
. 2019.04.06 16:55:38 - OpenVPN > Outgoing Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication
. 2019.04.06 16:55:38 - OpenVPN > Incoming Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key
. 2019.04.06 16:55:38 - OpenVPN > Incoming Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication
. 2019.04.06 16:55:38 - OpenVPN > TCP/UDP: Preserving recently used remote address: [AF_INET]194.187.251.165:443
. 2019.04.06 16:55:38 - OpenVPN > Socket Buffers: R=[65536->262144] S=[65536->262144]
. 2019.04.06 16:55:38 - OpenVPN > UDP link local: (not bound)
. 2019.04.06 16:55:38 - OpenVPN > UDP link remote: [AF_INET]194.187.251.165:443
. 2019.04.06 16:55:38 - OpenVPN > MANAGEMENT: Client connected from [AF_INET]127.0.0.1:3100
. 2019.04.06 16:56:11 - OpenVPN > [uNDEF] Inactivity timeout (--ping-exit), exiting
. 2019.04.06 16:56:11 - OpenVPN > SIGTERM received, sending exit notification to peer
. 2019.04.06 16:56:16 - OpenVPN > SIGTERM[soft,exit-with-notification] received, process exiting
! 2019.04.06 16:56:16 - Disconnecting
. 2019.04.06 16:56:16 - Connection terminated.
. 2019.04.06 16:56:16 - IPv6 restored with packet filtering.
I 2019.04.06 16:56:19 - Checking authorization ...
. 2019.04.06 16:56:19 - IPv6 disabled with packet filtering.
! 2019.04.06 16:56:19 - Connecting to Skat (Netherlands, Alblasserdam)
. 2019.04.06 16:56:19 - OpenVPN > OpenVPN 2.4.6 x86_64-w64-mingw32 [sSL (OpenSSL)] [LZO] [LZ4] [PKCS11] [AEAD] built on Apr 27 2018
. 2019.04.06 16:56:19 - OpenVPN > Windows version 6.2 (Windows 8 or greater) 64bit
. 2019.04.06 16:56:19 - OpenVPN > library versions: OpenSSL 1.1.0h  27 Mar 2018, LZO 2.10
. 2019.04.06 16:56:19 - Connection to OpenVPN Management Interface
. 2019.04.06 16:56:19 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3100
. 2019.04.06 16:56:19 - OpenVPN > Outgoing Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key
. 2019.04.06 16:56:19 - OpenVPN > Outgoing Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication
. 2019.04.06 16:56:19 - OpenVPN > Incoming Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key
. 2019.04.06 16:56:19 - OpenVPN > Incoming Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication
. 2019.04.06 16:56:19 - OpenVPN > TCP/UDP: Preserving recently used remote address: [AF_INET]213.152.161.76:443
. 2019.04.06 16:56:19 - OpenVPN > Socket Buffers: R=[65536->262144] S=[65536->262144]
. 2019.04.06 16:56:19 - OpenVPN > UDP link local: (not bound)
. 2019.04.06 16:56:19 - OpenVPN > UDP link remote: [AF_INET]213.152.161.76:443
. 2019.04.06 16:56:20 - OpenVPN > MANAGEMENT: Client connected from [AF_INET]127.0.0.1:3100
. 2019.04.06 16:56:51 - OpenVPN > [uNDEF] Inactivity timeout (--ping-exit), exiting
. 2019.04.06 16:56:51 - OpenVPN > SIGTERM received, sending exit notification to peer
. 2019.04.06 16:56:56 - OpenVPN > SIGTERM[soft,exit-with-notification] received, process exiting
! 2019.04.06 16:56:56 - Disconnecting
. 2019.04.06 16:56:56 - Connection terminated.
. 2019.04.06 16:56:56 - IPv6 restored with packet filtering.
I 2019.04.06 16:56:59 - Checking authorization ...
W 2019.04.06 16:57:00 - The server supports IPv6, but IPv6 is disabled at OS level. You need to re-enable it manually (reboot is required) or disable this warning by setting Preferences > Networking > Layer IPv6: Block.
W 2019.04.06 16:57:00 - 'Preferences > Networking > Layer IPv6' automatically switched to 'Block'.
. 2019.04.06 16:57:00 - IPv6 disabled with packet filtering.
! 2019.04.06 16:57:00 - Connecting to Canis (Netherlands, Alblasserdam)
. 2019.04.06 16:57:00 - OpenVPN > OpenVPN 2.4.6 x86_64-w64-mingw32 [sSL (OpenSSL)] [LZO] [LZ4] [PKCS11] [AEAD] built on Apr 27 2018
. 2019.04.06 16:57:00 - OpenVPN > Windows version 6.2 (Windows 8 or greater) 64bit
. 2019.04.06 16:57:00 - OpenVPN > library versions: OpenSSL 1.1.0h  27 Mar 2018, LZO 2.10
. 2019.04.06 16:57:00 - Connection to OpenVPN Management Interface
. 2019.04.06 16:57:00 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3100
. 2019.04.06 16:57:00 - OpenVPN > Outgoing Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key
. 2019.04.06 16:57:00 - OpenVPN > Outgoing Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication
. 2019.04.06 16:57:00 - OpenVPN > Incoming Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key
. 2019.04.06 16:57:00 - OpenVPN > Incoming Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication
. 2019.04.06 16:57:00 - OpenVPN > TCP/UDP: Preserving recently used remote address: [AF_INET]213.152.161.221:443
. 2019.04.06 16:57:00 - OpenVPN > Socket Buffers: R=[65536->262144] S=[65536->262144]
. 2019.04.06 16:57:00 - OpenVPN > UDP link local: (not bound)
. 2019.04.06 16:57:00 - OpenVPN > UDP link remote: [AF_INET]213.152.161.221:443
. 2019.04.06 16:57:00 - OpenVPN > MANAGEMENT: Client connected from [AF_INET]127.0.0.1:3100
. 2019.04.06 16:57:32 - OpenVPN > [uNDEF] Inactivity timeout (--ping-exit), exiting
. 2019.04.06 16:57:32 - OpenVPN > SIGTERM received, sending exit notification to peer
. 2019.04.06 16:57:38 - OpenVPN > SIGTERM[soft,exit-with-notification] received, process exiting
! 2019.04.06 16:57:38 - Disconnecting
. 2019.04.06 16:57:38 - Connection terminated.
. 2019.04.06 16:57:38 - IPv6 restored with packet filtering.
I 2019.04.06 16:57:41 - Checking authorization ...
. 2019.04.06 16:57:41 - IPv6 disabled with packet filtering.
! 2019.04.06 16:57:41 - Connecting to Subra (Netherlands, Alblasserdam)
. 2019.04.06 16:57:42 - OpenVPN > OpenVPN 2.4.6 x86_64-w64-mingw32 [sSL (OpenSSL)] [LZO] [LZ4] [PKCS11] [AEAD] built on Apr 27 2018
. 2019.04.06 16:57:42 - OpenVPN > Windows version 6.2 (Windows 8 or greater) 64bit
. 2019.04.06 16:57:42 - OpenVPN > library versions: OpenSSL 1.1.0h  27 Mar 2018, LZO 2.10
. 2019.04.06 16:57:42 - Connection to OpenVPN Management Interface
. 2019.04.06 16:57:42 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3100
. 2019.04.06 16:57:42 - OpenVPN > Outgoing Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key
. 2019.04.06 16:57:42 - OpenVPN > Outgoing Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication
. 2019.04.06 16:57:42 - OpenVPN > Incoming Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key
. 2019.04.06 16:57:42 - OpenVPN > Incoming Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication
. 2019.04.06 16:57:42 - OpenVPN > TCP/UDP: Preserving recently used remote address: [AF_INET]213.152.162.101:443
. 2019.04.06 16:57:42 - OpenVPN > Socket Buffers: R=[65536->262144] S=[65536->262144]
. 2019.04.06 16:57:42 - OpenVPN > UDP link local: (not bound)
. 2019.04.06 16:57:42 - OpenVPN > UDP link remote: [AF_INET]213.152.162.101:443
. 2019.04.06 16:57:42 - OpenVPN > MANAGEMENT: Client connected from [AF_INET]127.0.0.1:3100
. 2019.04.06 16:58:13 - OpenVPN > [uNDEF] Inactivity timeout (--ping-exit), exiting
. 2019.04.06 16:58:13 - OpenVPN > SIGTERM received, sending exit notification to peer
. 2019.04.06 16:58:18 - OpenVPN > SIGTERM[soft,exit-with-notification] received, process exiting
! 2019.04.06 16:58:18 - Disconnecting
. 2019.04.06 16:58:18 - Connection terminated.
. 2019.04.06 16:58:18 - IPv6 restored with packet filtering.
I 2019.04.06 16:58:21 - Checking authorization ...
. 2019.04.06 16:58:23 - IPv6 disabled with packet filtering.
! 2019.04.06 16:58:23 - Connecting to Sheliak (Netherlands, Alblasserdam)
. 2019.04.06 16:58:23 - OpenVPN > OpenVPN 2.4.6 x86_64-w64-mingw32 [sSL (OpenSSL)] [LZO] [LZ4] [PKCS11] [AEAD] built on Apr 27 2018
. 2019.04.06 16:58:23 - OpenVPN > Windows version 6.2 (Windows 8 or greater) 64bit
. 2019.04.06 16:58:23 - OpenVPN > library versions: OpenSSL 1.1.0h  27 Mar 2018, LZO 2.10
. 2019.04.06 16:58:23 - Connection to OpenVPN Management Interface
. 2019.04.06 16:58:23 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3100
. 2019.04.06 16:58:23 - OpenVPN > Outgoing Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key
. 2019.04.06 16:58:23 - OpenVPN > Outgoing Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication
. 2019.04.06 16:58:23 - OpenVPN > Incoming Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key
. 2019.04.06 16:58:23 - OpenVPN > Incoming Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication
. 2019.04.06 16:58:23 - OpenVPN > TCP/UDP: Preserving recently used remote address: [AF_INET]213.152.162.116:443
. 2019.04.06 16:58:23 - OpenVPN > Socket Buffers: R=[65536->262144] S=[65536->262144]
. 2019.04.06 16:58:23 - OpenVPN > UDP link local: (not bound)
. 2019.04.06 16:58:23 - OpenVPN > UDP link remote: [AF_INET]213.152.162.116:443
. 2019.04.06 16:58:23 - OpenVPN > MANAGEMENT: Client connected from [AF_INET]127.0.0.1:3100
Connection is via WIFI, but has always been this way and usually works.
I have tried various configurations/DNS details, but doesn't seem to make any difference, so I just reset to automatic?
I have tried several re-starts of both EDDIE, its settings, and Windows.
If anyone can shed any light I'd very much appreciate it?
Hello
I have got a couple of things you can try:
First: Go to eddie settings - Networkings - layer IPV6 switch to "Block"
If it doesnt work try this
2nd: ( Note: this will delete all eddie settings and your login info)
Delete this file:
C:\Users\%USERNAME%\AppData\Local\AirVPN\default.xml
If this doesnt work also try the following then:
3rd:
Close Eddie
Go to device manager and delete the "TAP Driver"
Open Eddie again and try to connect, it will install the TAP driver then it will try to connect
Last thing i can think of is to install the experimental version of eddie (2.17 beta)
Hope these solve your problem
Thanks Mad_Max -
Unfortunately, I've tried all of the above and exact same issue keeps repeating. The key point seems to be the:
"OpenVPN > SIGTERM[soft,exit-with-notification] received, process exiting"
I've also noticed that it doesn't seem to be beginning with a list of 'latency checks' where it counts down from 150-ish items prior to connecting? It usually does this when it does work/connects?
I might reset my internet connection, though not sure if that's going to change anything, as other items (phones etc) work OK on WiFi?
Check here:
. 2019.04.06 16:58:13 - OpenVPN > [UNDEF] Inactivity timeout (--ping-exit), exiting
It seems that UDP or OpenVPN packets are blocked: you might like to check for antivirus/HIPS/firewall on your system and QoS/packet filtering tools on your router.
If you suspect that it's your ISP the one to enforce blocks against UDP or OpenVPN, please try a connection to port 443 of entry-IP address 3 (THREE) with TCP. You can change connection mode in Eddie's window "Preferences" > "Protocols" (untick "Automatic" to unlock your choices).
Thanks - have tried a few of the TCP options but shows a similar activity / cycle of non-connections.
Here's a latest log of this helps:
. 2019.04.08 17:59:49 - Eddie version: 2.16.3 / windows_x64, System: Windows, Name: Windows 10 Home, Version: Microsoft Windows NT 10.0.17134.0, Mono/.Net: v4.0.30319
. 2019.04.08 17:59:49 - Reading options from C:\Users\Stuart\AppData\Local\AirVPN\default.xml
. 2019.04.08 17:59:50 - Command line arguments (1): path="home"
. 2019.04.08 17:59:50 - Profile path: C:\Users\Stuart\AppData\Local\AirVPN\default.xml
. 2019.04.08 17:59:52 - Cannot find tunnel adapter.
E 2019.04.08 17:59:52 - OpenVPN Driver - Not available - Will be installed at next connection.
. 2019.04.08 17:59:52 - OpenVPN - Version: 2.4.6 - OpenSSL 1.1.0h  27 Mar 2018, LZO 2.10 (C:\Program Files\AirVPN\openvpn.exe)
. 2019.04.08 17:59:52 - SSH - Version: plink 0.67 (C:\Program Files\AirVPN\plink.exe)
. 2019.04.08 17:59:52 - SSL - Version: stunnel 5.40 (C:\Program Files\AirVPN\stunnel.exe)
. 2019.04.08 17:59:52 - curl - Version: 7.54.1 (C:\Program Files\AirVPN\curl.exe)
. 2019.04.08 17:59:52 - Certification Authorities: C:\Program Files\AirVPN\res\cacert.pem
. 2019.04.08 17:59:54 - Updating systems & servers data ...
I 2019.04.08 17:59:54 - Ready
. 2019.04.08 17:59:54 - Systems & servers data update completed
. 2019.04.08 17:59:55 - Cannot find tunnel adapter.
. 2019.04.08 18:00:53 - Above log line repeated 1 times more
I 2019.04.08 18:00:53 - Checking login ...
. 2019.04.08 18:00:53 - Checking login ..., 1° try failed (curl: (7) Failed to connect to 63.33.78.166 port 80: Bad access)
! 2019.04.08 18:00:53 - Logged in.
! 2019.04.08 18:00:56 - Activation of Network Lock - Windows Filtering Platform
I 2019.04.08 18:00:58 - Session starting.
. 2019.04.08 18:00:58 - Cannot find tunnel adapter.
! 2019.04.08 18:00:58 - Installing tunnel driver
I 2019.04.08 18:01:03 - Checking authorization ...
. 2019.04.08 18:01:03 - Checking authorization ..., 1° try failed (curl: (7) Failed to connect to 63.33.78.166 port 80: Bad access)
W 2019.04.08 18:01:04 - The server supports IPv6, but IPv6 is disabled at OS level. You need to re-enable it manually (reboot is required) or disable this warning by setting Preferences > Networking > Layer IPv6: Block.
W 2019.04.08 18:01:04 - 'Preferences > Networking > Layer IPv6' automatically switched to 'Block'.
. 2019.04.08 18:01:04 - IPv6 disabled with packet filtering.
! 2019.04.08 18:01:04 - Connecting to Hydrus (Netherlands, Alblasserdam)
. 2019.04.08 18:01:04 - OpenVPN > OpenVPN 2.4.6 x86_64-w64-mingw32 [sSL (OpenSSL)] [LZO] [LZ4] [PKCS11] [AEAD] built on Apr 27 2018
. 2019.04.08 18:01:04 - OpenVPN > Windows version 6.2 (Windows 8 or greater) 64bit
. 2019.04.08 18:01:04 - OpenVPN > library versions: OpenSSL 1.1.0h  27 Mar 2018, LZO 2.10
. 2019.04.08 18:01:04 - Connection to OpenVPN Management Interface
. 2019.04.08 18:01:04 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3100
. 2019.04.08 18:01:04 - OpenVPN > Outgoing Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key
. 2019.04.08 18:01:04 - OpenVPN > Outgoing Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication
. 2019.04.08 18:01:04 - OpenVPN > Incoming Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key
. 2019.04.08 18:01:04 - OpenVPN > Incoming Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication
. 2019.04.08 18:01:04 - OpenVPN > TCP/UDP: Preserving recently used remote address: [AF_INET]213.152.162.12:443
. 2019.04.08 18:01:04 - OpenVPN > Socket Buffers: R=[65536->262144] S=[65536->262144]
. 2019.04.08 18:01:04 - OpenVPN > UDP link local: (not bound)
. 2019.04.08 18:01:04 - OpenVPN > UDP link remote: [AF_INET]213.152.162.12:443
. 2019.04.08 18:01:04 - OpenVPN > MANAGEMENT: Client connected from [AF_INET]127.0.0.1:3100
. 2019.04.08 18:01:37 - OpenVPN > [uNDEF] Inactivity timeout (--ping-exit), exiting
. 2019.04.08 18:01:37 - OpenVPN > SIGTERM received, sending exit notification to peer
. 2019.04.08 18:01:43 - OpenVPN > SIGTERM[soft,exit-with-notification] received, process exiting
! 2019.04.08 18:01:43 - Disconnecting
. 2019.04.08 18:01:43 - Connection terminated.
. 2019.04.08 18:01:43 - IPv6 restored with packet filtering.
I 2019.04.08 18:01:46 - Checking authorization ...
. 2019.04.08 18:01:46 - Checking authorization ..., 1° try failed (curl: (7) Failed to connect to 63.33.78.166 port 80: Bad access)
. 2019.04.08 18:01:46 - IPv6 disabled with packet filtering.
! 2019.04.08 18:01:46 - Connecting to Castor (Belgium, Brussels)
. 2019.04.08 18:01:47 - OpenVPN > OpenVPN 2.4.6 x86_64-w64-mingw32 [sSL (OpenSSL)] [LZO] [LZ4] [PKCS11] [AEAD] built on Apr 27 2018
. 2019.04.08 18:01:47 - OpenVPN > Windows version 6.2 (Windows 8 or greater) 64bit
. 2019.04.08 18:01:47 - OpenVPN > library versions: OpenSSL 1.1.0h  27 Mar 2018, LZO 2.10
. 2019.04.08 18:01:47 - Connection to OpenVPN Management Interface
. 2019.04.08 18:01:47 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3100
. 2019.04.08 18:01:47 - OpenVPN > Outgoing Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key
. 2019.04.08 18:01:47 - OpenVPN > Outgoing Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication
. 2019.04.08 18:01:47 - OpenVPN > Incoming Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key
. 2019.04.08 18:01:47 - OpenVPN > Incoming Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication
. 2019.04.08 18:01:47 - OpenVPN > TCP/UDP: Preserving recently used remote address: [AF_INET]91.207.57.117:443
. 2019.04.08 18:01:47 - OpenVPN > Socket Buffers: R=[65536->262144] S=[65536->262144]
. 2019.04.08 18:01:47 - OpenVPN > UDP link local: (not bound)
. 2019.04.08 18:01:47 - OpenVPN > UDP link remote: [AF_INET]91.207.57.117:443
. 2019.04.08 18:01:47 - OpenVPN > MANAGEMENT: Client connected from [AF_INET]127.0.0.1:3100
. 2019.04.08 18:02:20 - OpenVPN > [uNDEF] Inactivity timeout (--ping-exit), exiting
. 2019.04.08 18:02:20 - OpenVPN > SIGTERM received, sending exit notification to peer
. 2019.04.08 18:02:25 - OpenVPN > SIGTERM[soft,exit-with-notification] received, process exiting
! 2019.04.08 18:02:25 - Disconnecting
. 2019.04.08 18:02:25 - Connection terminated.
. 2019.04.08 18:02:25 - IPv6 restored with packet filtering.
I 2019.04.08 18:02:28 - Checking authorization ...
. 2019.04.08 18:02:28 - IPv6 disabled with packet filtering.
! 2019.04.08 18:02:28 - Connecting to Diphda (Netherlands, Alblasserdam)
. 2019.04.08 18:02:29 - OpenVPN > OpenVPN 2.4.6 x86_64-w64-mingw32 [sSL (OpenSSL)] [LZO] [LZ4] [PKCS11] [AEAD] built on Apr 27 2018
. 2019.04.08 18:02:29 - OpenVPN > Windows version 6.2 (Windows 8 or greater) 64bit
. 2019.04.08 18:02:29 - OpenVPN > library versions: OpenSSL 1.1.0h  27 Mar 2018, LZO 2.10
. 2019.04.08 18:02:29 - Connection to OpenVPN Management Interface
. 2019.04.08 18:02:29 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3100
. 2019.04.08 18:02:29 - OpenVPN > Outgoing Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key
. 2019.04.08 18:02:29 - OpenVPN > Outgoing Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication
. 2019.04.08 18:02:29 - OpenVPN > Incoming Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key
. 2019.04.08 18:02:29 - OpenVPN > Incoming Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication
. 2019.04.08 18:02:29 - OpenVPN > TCP/UDP: Preserving recently used remote address: [AF_INET]213.152.161.167:443
. 2019.04.08 18:02:29 - OpenVPN > Socket Buffers: R=[65536->262144] S=[65536->262144]
. 2019.04.08 18:02:29 - OpenVPN > UDP link local: (not bound)
. 2019.04.08 18:02:29 - OpenVPN > UDP link remote: [AF_INET]213.152.161.167:443
. 2019.04.08 18:02:29 - OpenVPN > MANAGEMENT: Client connected from [AF_INET]127.0.0.1:3100
. 2019.04.08 18:03:01 - OpenVPN > [uNDEF] Inactivity timeout (--ping-exit), exiting
. 2019.04.08 18:03:01 - OpenVPN > SIGTERM received, sending exit notification to peer
. 2019.04.08 18:03:06 - OpenVPN > SIGTERM[soft,exit-with-notification] received, process exiting
! 2019.04.08 18:03:06 - Disconnecting
. 2019.04.08 18:03:06 - Connection terminated.
. 2019.04.08 18:03:06 - IPv6 restored with packet filtering.
I 2019.04.08 18:03:09 - Checking authorization ...
. 2019.04.08 18:03:10 - IPv6 disabled with packet filtering.
! 2019.04.08 18:03:10 - Connecting to Miram (Netherlands, Alblasserdam)
. 2019.04.08 18:03:10 - OpenVPN > OpenVPN 2.4.6 x86_64-w64-mingw32 [sSL (OpenSSL)] [LZO] [LZ4] [PKCS11] [AEAD] built on Apr 27 2018
. 2019.04.08 18:03:10 - OpenVPN > Windows version 6.2 (Windows 8 or greater) 64bit
. 2019.04.08 18:03:10 - OpenVPN > library versions: OpenSSL 1.1.0h  27 Mar 2018, LZO 2.10
. 2019.04.08 18:03:10 - Connection to OpenVPN Management Interface
. 2019.04.08 18:03:10 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3100
. 2019.04.08 18:03:10 - OpenVPN > Outgoing Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key
. 2019.04.08 18:03:10 - OpenVPN > Outgoing Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication
. 2019.04.08 18:03:10 - OpenVPN > Incoming Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key
. 2019.04.08 18:03:10 - OpenVPN > Incoming Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication
. 2019.04.08 18:03:10 - OpenVPN > TCP/UDP: Preserving recently used remote address: [AF_INET]213.152.162.91:443
. 2019.04.08 18:03:10 - OpenVPN > Socket Buffers: R=[65536->262144] S=[65536->262144]
. 2019.04.08 18:03:10 - OpenVPN > UDP link local: (not bound)
. 2019.04.08 18:03:10 - OpenVPN > UDP link remote: [AF_INET]213.152.162.91:443
. 2019.04.08 18:03:10 - OpenVPN > MANAGEMENT: Client connected from [AF_INET]127.0.0.1:3100
. 2019.04.08 18:03:42 - OpenVPN > [uNDEF] Inactivity timeout (--ping-exit), exiting
. 2019.04.08 18:03:42 - OpenVPN > SIGTERM received, sending exit notification to peer
. 2019.04.08 18:03:47 - OpenVPN > SIGTERM[soft,exit-with-notification] received, process exiting
! 2019.04.08 18:03:47 - Disconnecting
. 2019.04.08 18:03:47 - Connection terminated.
. 2019.04.08 18:03:47 - IPv6 restored with packet filtering.
I 2019.04.08 18:03:50 - Checking authorization ...
. 2019.04.08 18:03:50 - IPv6 disabled with packet filtering.
! 2019.04.08 18:03:50 - Connecting to Kajam (Netherlands, Alblasserdam)
. 2019.04.08 18:03:51 - OpenVPN > OpenVPN 2.4.6 x86_64-w64-mingw32 [sSL (OpenSSL)] [LZO] [LZ4] [PKCS11] [AEAD] built on Apr 27 2018
. 2019.04.08 18:03:51 - OpenVPN > Windows version 6.2 (Windows 8 or greater) 64bit
. 2019.04.08 18:03:51 - OpenVPN > library versions: OpenSSL 1.1.0h  27 Mar 2018, LZO 2.10
. 2019.04.08 18:03:51 - Connection to OpenVPN Management Interface
. 2019.04.08 18:03:51 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3100
. 2019.04.08 18:03:51 - OpenVPN > Outgoing Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key
. 2019.04.08 18:03:51 - OpenVPN > Outgoing Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication
. 2019.04.08 18:03:51 - OpenVPN > Incoming Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key
. 2019.04.08 18:03:51 - OpenVPN > Incoming Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication
. 2019.04.08 18:03:51 - OpenVPN > TCP/UDP: Preserving recently used remote address: [AF_INET]213.152.161.87:443
. 2019.04.08 18:03:51 - OpenVPN > Socket Buffers: R=[65536->262144] S=[65536->262144]
. 2019.04.08 18:03:51 - OpenVPN > UDP link local: (not bound)
. 2019.04.08 18:03:51 - OpenVPN > UDP link remote: [AF_INET]213.152.161.87:443
. 2019.04.08 18:03:51 - OpenVPN > MANAGEMENT: Client connected from [AF_INET]127.0.0.1:3100
. 2019.04.08 18:04:23 - OpenVPN > [uNDEF] Inactivity timeout (--ping-exit), exiting
. 2019.04.08 18:04:23 - OpenVPN > SIGTERM received, sending exit notification to peer
. 2019.04.08 18:04:28 - OpenVPN > SIGTERM[soft,exit-with-notification] received, process exiting
! 2019.04.08 18:04:28 - Disconnecting
. 2019.04.08 18:04:28 - Connection terminated.
. 2019.04.08 18:04:28 - IPv6 restored with packet filtering.
I 2019.04.08 18:04:31 - Checking authorization ...
. 2019.04.08 18:04:31 - IPv6 disabled with packet filtering.
! 2019.04.08 18:04:31 - Connecting to Canis (Netherlands, Alblasserdam)
. 2019.04.08 18:04:32 - OpenVPN > OpenVPN 2.4.6 x86_64-w64-mingw32 [sSL (OpenSSL)] [LZO] [LZ4] [PKCS11] [AEAD] built on Apr 27 2018
. 2019.04.08 18:04:32 - OpenVPN > Windows version 6.2 (Windows 8 or greater) 64bit
. 2019.04.08 18:04:32 - OpenVPN > library versions: OpenSSL 1.1.0h  27 Mar 2018, LZO 2.10
. 2019.04.08 18:04:32 - Connection to OpenVPN Management Interface
. 2019.04.08 18:04:32 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3100
. 2019.04.08 18:04:32 - OpenVPN > Outgoing Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key
. 2019.04.08 18:04:32 - OpenVPN > Outgoing Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication
. 2019.04.08 18:04:32 - OpenVPN > Incoming Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key
. 2019.04.08 18:04:32 - OpenVPN > Incoming Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication
. 2019.04.08 18:04:32 - OpenVPN > TCP/UDP: Preserving recently used remote address: [AF_INET]213.152.161.221:443
. 2019.04.08 18:04:32 - OpenVPN > Socket Buffers: R=[65536->262144] S=[65536->262144]
. 2019.04.08 18:04:32 - OpenVPN > UDP link local: (not bound)
. 2019.04.08 18:04:32 - OpenVPN > UDP link remote: [AF_INET]213.152.161.221:443
. 2019.04.08 18:04:32 - OpenVPN > MANAGEMENT: Client connected from [AF_INET]127.0.0.1:3100
. 2019.04.08 18:05:04 - OpenVPN > [uNDEF] Inactivity timeout (--ping-exit), exiting
. 2019.04.08 18:05:04 - OpenVPN > SIGTERM received, sending exit notification to peer
. 2019.04.08 18:05:09 - OpenVPN > SIGTERM[soft,exit-with-notification] received, process exiting
! 2019.04.08 18:05:09 - Disconnecting
. 2019.04.08 18:05:09 - Connection terminated.
. 2019.04.08 18:05:09 - IPv6 restored with packet filtering.
I 2019.04.08 18:05:12 - Checking authorization ...
. 2019.04.08 18:05:13 - IPv6 disabled with packet filtering.
! 2019.04.08 18:05:13 - Connecting to Cygnus (Netherlands, Alblasserdam)
. 2019.04.08 18:05:13 - OpenVPN > OpenVPN 2.4.6 x86_64-w64-mingw32 [sSL (OpenSSL)] [LZO] [LZ4] [PKCS11] [AEAD] built on Apr 27 2018
. 2019.04.08 18:05:13 - OpenVPN > Windows version 6.2 (Windows 8 or greater) 64bit
. 2019.04.08 18:05:13 - OpenVPN > library versions: OpenSSL 1.1.0h  27 Mar 2018, LZO 2.10
. 2019.04.08 18:05:13 - Connection to OpenVPN Management Interface
. 2019.04.08 18:05:13 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3100
. 2019.04.08 18:05:13 - OpenVPN > Outgoing Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key
. 2019.04.08 18:05:13 - OpenVPN > Outgoing Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication
. 2019.04.08 18:05:13 - OpenVPN > Incoming Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key
. 2019.04.08 18:05:13 - OpenVPN > Incoming Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication
. 2019.04.08 18:05:13 - OpenVPN > TCP/UDP: Preserving recently used remote address: [AF_INET]213.152.161.246:443
. 2019.04.08 18:05:13 - OpenVPN > Socket Buffers: R=[65536->262144] S=[65536->262144]
. 2019.04.08 18:05:13 - OpenVPN > UDP link local: (not bound)
. 2019.04.08 18:05:13 - OpenVPN > UDP link remote: [AF_INET]213.152.161.246:443
. 2019.04.08 18:05:13 - OpenVPN > MANAGEMENT: Client connected from [AF_INET]127.0.0.1:3100
. 2019.04.08 18:05:45 - OpenVPN > [uNDEF] Inactivity timeout (--ping-exit), exiting
. 2019.04.08 18:05:45 - OpenVPN > SIGTERM received, sending exit notification to peer
. 2019.04.08 18:05:50 - OpenVPN > SIGTERM[soft,exit-with-notification] received, process exiting
! 2019.04.08 18:05:50 - Disconnecting
. 2019.04.08 18:05:50 - Connection terminated.
. 2019.04.08 18:05:50 - IPv6 restored with packet filtering.
I 2019.04.08 18:05:53 - Checking authorization ...
. 2019.04.08 18:05:54 - IPv6 disabled with packet filtering.
! 2019.04.08 18:05:54 - Connecting to Salm (Netherlands, Alblasserdam)
. 2019.04.08 18:05:54 - OpenVPN > OpenVPN 2.4.6 x86_64-w64-mingw32 [sSL (OpenSSL)] [LZO] [LZ4] [PKCS11] [AEAD] built on Apr 27 2018
. 2019.04.08 18:05:54 - OpenVPN > Windows version 6.2 (Windows 8 or greater) 64bit
. 2019.04.08 18:05:54 - OpenVPN > library versions: OpenSSL 1.1.0h  27 Mar 2018, LZO 2.10
. 2019.04.08 18:05:54 - Connection to OpenVPN Management Interface
. 2019.04.08 18:05:54 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3100
. 2019.04.08 18:05:54 - OpenVPN > Outgoing Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key
. 2019.04.08 18:05:54 - OpenVPN > Outgoing Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication
. 2019.04.08 18:05:54 - OpenVPN > Incoming Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key
. 2019.04.08 18:05:54 - OpenVPN > Incoming Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication
. 2019.04.08 18:05:54 - OpenVPN > TCP/UDP: Preserving recently used remote address: [AF_INET]213.152.161.22:443
. 2019.04.08 18:05:54 - OpenVPN > Socket Buffers: R=[65536->262144] S=[65536->262144]
. 2019.04.08 18:05:54 - OpenVPN > UDP link local: (not bound)
. 2019.04.08 18:05:54 - OpenVPN > UDP link remote: [AF_INET]213.152.161.22:443
. 2019.04.08 18:05:54 - OpenVPN > MANAGEMENT: Client connected from [AF_INET]127.0.0.1:3100
. 2019.04.08 18:06:26 - OpenVPN > [uNDEF] Inactivity timeout (--ping-exit), exiting
. 2019.04.08 18:06:26 - OpenVPN > SIGTERM received, sending exit notification to peer
. 2019.04.08 18:06:31 - OpenVPN > SIGTERM[soft,exit-with-notification] received, process exiting
! 2019.04.08 18:06:31 - Disconnecting
. 2019.04.08 18:06:31 - Connection terminated.
. 2019.04.08 18:06:31 - IPv6 restored with packet filtering.
I 2019.04.08 18:06:34 - Checking authorization ...
. 2019.04.08 18:06:34 - IPv6 disabled with packet filtering.
! 2019.04.08 18:06:34 - Connecting to Matar (Netherlands, Alblasserdam)
. 2019.04.08 18:06:34 - OpenVPN > OpenVPN 2.4.6 x86_64-w64-mingw32 [sSL (OpenSSL)] [LZO] [LZ4] [PKCS11] [AEAD] built on Apr 27 2018
. 2019.04.08 18:06:34 - OpenVPN > Windows version 6.2 (Windows 8 or greater) 64bit
. 2019.04.08 18:06:34 - OpenVPN > library versions: OpenSSL 1.1.0h  27 Mar 2018, LZO 2.10
. 2019.04.08 18:06:34 - Connection to OpenVPN Management Interface
. 2019.04.08 18:06:34 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3100
. 2019.04.08 18:06:34 - OpenVPN > Outgoing Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key
. 2019.04.08 18:06:34 - OpenVPN > Outgoing Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication
. 2019.04.08 18:06:34 - OpenVPN > Incoming Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key
. 2019.04.08 18:06:34 - OpenVPN > Incoming Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication
. 2019.04.08 18:06:34 - OpenVPN > TCP/UDP: Preserving recently used remote address: [AF_INET]109.232.227.140:443
. 2019.04.08 18:06:34 - OpenVPN > Socket Buffers: R=[65536->262144] S=[65536->262144]
. 2019.04.08 18:06:34 - OpenVPN > UDP link local: (not bound)
. 2019.04.08 18:06:34 - OpenVPN > UDP link remote: [AF_INET]109.232.227.140:443
. 2019.04.08 18:06:35 - OpenVPN > MANAGEMENT: Client connected from [AF_INET]127.0.0.1:3100
! 2019.04.08 18:06:38 - Disconnecting
. 2019.04.08 18:06:38 - Sending management termination signal
. 2019.04.08 18:06:38 - Management - Send 'signal SIGTERM'
. 2019.04.08 18:06:38 - OpenVPN > MANAGEMENT: CMD 'signal SIGTERM'
. 2019.04.08 18:06:38 - OpenVPN > SIGTERM received, sending exit notification to peer
. 2019.04.08 18:06:44 - OpenVPN > SIGTERM[soft,exit-with-notification] received, process exiting
. 2019.04.08 18:06:44 - Connection terminated.
. 2019.04.08 18:06:44 - IPv6 restored with packet filtering.
I 2019.04.08 18:06:44 - Cancel requested.
! 2019.04.08 18:06:44 - Session terminated.
I 2019.04.08 18:06:46 - Session starting.
I 2019.04.08 18:06:47 - Checking authorization ...
. 2019.04.08 18:06:47 - IPv6 disabled with packet filtering.
! 2019.04.08 18:06:47 - Connecting to Merga (Netherlands, Alblasserdam)
. 2019.04.08 18:06:47 - OpenVPN > OpenVPN 2.4.6 x86_64-w64-mingw32 [sSL (OpenSSL)] [LZO] [LZ4] [PKCS11] [AEAD] built on Apr 27 2018
. 2019.04.08 18:06:47 - OpenVPN > Windows version 6.2 (Windows 8 or greater) 64bit
. 2019.04.08 18:06:47 - OpenVPN > library versions: OpenSSL 1.1.0h  27 Mar 2018, LZO 2.10
. 2019.04.08 18:06:47 - Connection to OpenVPN Management Interface
. 2019.04.08 18:06:47 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3100
. 2019.04.08 18:06:47 - OpenVPN > Outgoing Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key
. 2019.04.08 18:06:47 - OpenVPN > Outgoing Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication
. 2019.04.08 18:06:47 - OpenVPN > Incoming Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key
. 2019.04.08 18:06:47 - OpenVPN > Incoming Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication
. 2019.04.08 18:06:47 - OpenVPN > TCP/UDP: Preserving recently used remote address: [AF_INET]213.152.161.32:443
. 2019.04.08 18:06:47 - OpenVPN > Socket Buffers: R=[65536->262144] S=[65536->262144]
. 2019.04.08 18:06:47 - OpenVPN > Attempting to establish TCP connection with [AF_INET]213.152.161.32:443 [nonblock]
. 2019.04.08 18:06:47 - OpenVPN > MANAGEMENT: Client connected from [AF_INET]127.0.0.1:3100
. 2019.04.08 18:08:47 - OpenVPN > TCP: connect to [AF_INET]213.152.161.32:443 failed: Unknown error
. 2019.04.08 18:08:47 - OpenVPN > SIGUSR1[connection failed(soft),init_instance] received, process restarting
. 2019.04.08 18:08:47 - OpenVPN > Restart pause, 5 second(s)
! 2019.04.08 18:08:47 - Disconnecting
. 2019.04.08 18:08:47 - Sending management termination signal
. 2019.04.08 18:08:47 - Management - Send 'signal SIGTERM'
. 2019.04.08 18:08:47 - OpenVPN > MANAGEMENT: CMD 'a0899d5c105c434f7adbc5ec8c3a3311928d5da016085eb0fb1a3fa8b7efd11a'
. 2019.04.08 18:08:52 - OpenVPN > MANAGEMENT: Client disconnected
. 2019.04.08 18:08:52 - OpenVPN > All connections have been connect-retry-max (1) times unsuccessful, exiting
. 2019.04.08 18:08:52 - OpenVPN > Exiting due to fatal error
. 2019.04.08 18:08:52 - Connection terminated.
. 2019.04.08 18:08:52 - IPv6 restored with packet filtering.
I 2019.04.08 18:08:55 - Checking authorization ...
. 2019.04.08 18:08:56 - IPv6 disabled with packet filtering.
! 2019.04.08 18:08:56 - Connecting to Matar (Netherlands, Alblasserdam)
. 2019.04.08 18:08:56 - OpenVPN > OpenVPN 2.4.6 x86_64-w64-mingw32 [sSL (OpenSSL)] [LZO] [LZ4] [PKCS11] [AEAD] built on Apr 27 2018
. 2019.04.08 18:08:56 - OpenVPN > Windows version 6.2 (Windows 8 or greater) 64bit
. 2019.04.08 18:08:56 - OpenVPN > library versions: OpenSSL 1.1.0h  27 Mar 2018, LZO 2.10
. 2019.04.08 18:08:56 - Connection to OpenVPN Management Interface
. 2019.04.08 18:08:56 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3100
. 2019.04.08 18:08:56 - OpenVPN > Outgoing Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key
. 2019.04.08 18:08:56 - OpenVPN > Outgoing Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication
. 2019.04.08 18:08:56 - OpenVPN > Incoming Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key
. 2019.04.08 18:08:56 - OpenVPN > Incoming Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication
. 2019.04.08 18:08:56 - OpenVPN > TCP/UDP: Preserving recently used remote address: [AF_INET]109.232.227.140:443
. 2019.04.08 18:08:56 - OpenVPN > Socket Buffers: R=[65536->262144] S=[65536->262144]
. 2019.04.08 18:08:56 - OpenVPN > Attempting to establish TCP connection with [AF_INET]109.232.227.140:443 [nonblock]
. 2019.04.08 18:08:56 - OpenVPN > MANAGEMENT: Client connected from [AF_INET]127.0.0.1:3100
. 2019.04.08 18:09:58 - Updating systems & servers data ...
. 2019.04.08 18:09:59 - Systems & servers data update completed
. 2019.04.08 18:10:56 - OpenVPN > TCP: connect to [AF_INET]109.232.227.140:443 failed: Unknown error
. 2019.04.08 18:10:56 - OpenVPN > SIGUSR1[connection failed(soft),init_instance] received, process restarting
. 2019.04.08 18:10:56 - OpenVPN > Restart pause, 5 second(s)
! 2019.04.08 18:10:56 - Disconnecting
. 2019.04.08 18:10:56 - Sending management termination signal
. 2019.04.08 18:10:56 - Management - Send 'signal SIGTERM'
. 2019.04.08 18:10:56 - OpenVPN > MANAGEMENT: CMD 'a687c3cb8ffd9a74a7a6acbc6245e3932f4262e94dbf480defb086ad8795f382'
. 2019.04.08 18:11:01 - OpenVPN > MANAGEMENT: Client disconnected
. 2019.04.08 18:11:01 - OpenVPN > All connections have been connect-retry-max (1) times unsuccessful, exiting
. 2019.04.08 18:11:01 - OpenVPN > Exiting due to fatal error
. 2019.04.08 18:11:01 - Connection terminated.
. 2019.04.08 18:11:01 - IPv6 restored with packet filtering.
I 2019.04.08 18:11:04 - Checking authorization ...
. 2019.04.08 18:11:05 - IPv6 disabled with packet filtering.
! 2019.04.08 18:11:05 - Connecting to Maasym (Netherlands, Alblasserdam)
. 2019.04.08 18:11:05 - OpenVPN > OpenVPN 2.4.6 x86_64-w64-mingw32 [sSL (OpenSSL)] [LZO] [LZ4] [PKCS11] [AEAD] built on Apr 27 2018
. 2019.04.08 18:11:05 - OpenVPN > Windows version 6.2 (Windows 8 or greater) 64bit
. 2019.04.08 18:11:05 - OpenVPN > library versions: OpenSSL 1.1.0h  27 Mar 2018, LZO 2.10
. 2019.04.08 18:11:05 - Connection to OpenVPN Management Interface
. 2019.04.08 18:11:05 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3100
. 2019.04.08 18:11:05 - OpenVPN > Outgoing Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key
. 2019.04.08 18:11:05 - OpenVPN > Outgoing Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication
. 2019.04.08 18:11:05 - OpenVPN > Incoming Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key
. 2019.04.08 18:11:05 - OpenVPN > Incoming Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication
. 2019.04.08 18:11:05 - OpenVPN > TCP/UDP: Preserving recently used remote address: [AF_INET]213.152.162.106:443
. 2019.04.08 18:11:05 - OpenVPN > Socket Buffers: R=[65536->262144] S=[65536->262144]
. 2019.04.08 18:11:05 - OpenVPN > Attempting to establish TCP connection with [AF_INET]213.152.162.106:443 [nonblock]
. 2019.04.08 18:11:05 - OpenVPN > MANAGEMENT: Client connected from [AF_INET]127.0.0.1:3100
. 2019.04.08 18:13:05 - OpenVPN > TCP: connect to [AF_INET]213.152.162.106:443 failed: Unknown error
. 2019.04.08 18:13:05 - OpenVPN > SIGUSR1[connection failed(soft),init_instance] received, process restarting
. 2019.04.08 18:13:05 - OpenVPN > Restart pause, 5 second(s)
! 2019.04.08 18:13:05 - Disconnecting
. 2019.04.08 18:13:05 - Sending management termination signal
. 2019.04.08 18:13:05 - Management - Send 'signal SIGTERM'
. 2019.04.08 18:13:05 - OpenVPN > MANAGEMENT: CMD '712d50f11c67d685664053b603a2d4120ed591d56141db82108c686fc317fa79'
. 2019.04.08 18:13:10 - OpenVPN > MANAGEMENT: Client disconnected
. 2019.04.08 18:13:10 - OpenVPN > All connections have been connect-retry-max (1) times unsuccessful, exiting
. 2019.04.08 18:13:10 - OpenVPN > Exiting due to fatal error
. 2019.04.08 18:13:10 - Connection terminated.
. 2019.04.08 18:13:10 - IPv6 restored with packet filtering.
I 2019.04.08 18:13:13 - Checking authorization ...
. 2019.04.08 18:13:14 - IPv6 disabled with packet filtering.
! 2019.04.08 18:13:14 - Connecting to Tarazed (Netherlands, Alblasserdam)
. 2019.04.08 18:13:14 - OpenVPN > OpenVPN 2.4.6 x86_64-w64-mingw32 [sSL (OpenSSL)] [LZO] [LZ4] [PKCS11] [AEAD] built on Apr 27 2018
. 2019.04.08 18:13:14 - OpenVPN > Windows version 6.2 (Windows 8 or greater) 64bit
. 2019.04.08 18:13:14 - OpenVPN > library versions: OpenSSL 1.1.0h  27 Mar 2018, LZO 2.10
. 2019.04.08 18:13:14 - Connection to OpenVPN Management Interface
. 2019.04.08 18:13:14 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3100
. 2019.04.08 18:13:14 - OpenVPN > Outgoing Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key
. 2019.04.08 18:13:14 - OpenVPN > Outgoing Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication
. 2019.04.08 18:13:14 - OpenVPN > Incoming Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key
. 2019.04.08 18:13:14 - OpenVPN > Incoming Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication
. 2019.04.08 18:13:14 - OpenVPN > TCP/UDP: Preserving recently used remote address: [AF_INET]213.152.161.135:443
. 2019.04.08 18:13:14 - OpenVPN > Socket Buffers: R=[65536->262144] S=[65536->262144]
. 2019.04.08 18:13:14 - OpenVPN > Attempting to establish TCP connection with [AF_INET]213.152.161.135:443 [nonblock]
. 2019.04.08 18:13:14 - OpenVPN > MANAGEMENT: Client connected from [AF_INET]127.0.0.1:3100
Wondering if this is linked to the general issue of the internet not connecting either with or without EDDIE.
Can't see anything obvious in the Windows firewall etc settings?
Hi All -
Sorted it thanks.
It was simply (I say simply, it wasn't immediately obvious), confliction between wireless network card driver and firewall. Closed firewall, got internet back, removed and re-installed latest driver, flushed all the commands such as DNS in CMD, turned everything back on and hey presto.
This has sorted both standard no-AIRVPN and active EDDIE connections.
