sfo
Remote port forwarding per device
I have looked at the Remote Port Forwarding feature of AirVPN (which is great to have by the way!).
I have several devices that I connect to AirVPN directly from the devices' network settings (not via a router). I would like to forward a remote port for only one of these devices.
I see that it is possible to have separate device keys, in the Client Area. Is it possible to specify that a remote port should be forwarded for only a specific device, according to the keys used to connect?
I would rather avoid having the remote port open for every device that connects through my account, as this is a potential security risk.
Thanks very much,
That is not possible: packets will be accepted and forwarded to your final node IP address from all the servers your account is connected to. It's not a big deal anyway (see below).
Thanks very much,
Why? Just make sure that the port does not exist in the proper machines, that's all.
