Can anyone help me how to allow only few ip addresses that can access to my computer when is connected on AirVpn.
I try with network lock and add addresses in list but that is not solution, I can access even if address is not listed.
Did you try using the Eddie>Preferences> Routes option? Then you can make certain things go outside the VPN tunnel, such as if you input a website address.
It's a bit unclear what you want.
