donald_duck
Problems with port forwarding
I've a problem with port forwarding. I've configured two port forwarding:
i) 27001
Protocol : TCP
Local port : 27001
ii) 27002
Protocol : UDP
Local port : 27002
I need this for Emule(kad) connection. When I've added port forwarding the check procedure reported:
27001 71 seconds ago.
Not reachable on server IP over the external port 27001, tcp protocol. Error : 110 - Connection timed out
27002 121 seconds ago.
DANGER! Reachable on real IP over the external port 27002, udp protocol.
Obv Emule doesn't work.
What's wrong?
Thanks in advance.
ps. Win7x64 - Win Fw Enabled - Win Security Essential Enable
pps. Without AirVPN I've no problems.
i) 27001
Protocol : TCP
Local port : 27001
ii) 27002
Protocol : UDP
Local port : 27002
What's wrong?
Thanks in advance.
Apparently your eMule does not listen to port 27001 TCP.
With Win7 x64, the most common cause for the problem on 27001 is the Windows Firewall, which by default does NOT authorize eMule to send out packets in different networks. Make sure that eMule is authorized (if you use the Windows Firewall) on every network.
About port 27002, please make sure that this port is NOT forwarded on your router.
Anyway, which server are you connected to?
I've checked. I've an particular router (given by my ISP) that has all port open by default and I can't do anything to change them.
What I have to do?
What I have to do?
We can confirm you that port forwarding is working correctly on our servers.
If your router does not allow to close any port, you might block the ports you have remotely forwarded with your software firewall (very easy if you use Comodo) ONLY on your physical interface in order to prevent correlation attacks.
