sdkseusx 0 Posted ... Hi all. I'm using a bit of a different setup. I want to be using AirVPN at all times on my Linux box. Unfortunately OpenVPN will not cooperate. /etc/issue Ubuntu 10.04.4 LTS \n \l /etc/openvpn/airvpn.conf remote 69.163.36.66 443 proto tcp client ca /etc/openvpn/certs/ca.crt cert /etc/openvpn/certs/client.crt key /etc/openvpn/certs/client.key down /etc/openvpn/scripts/downscript.sh up /etc/openvpn/scripts/upscript.sh dev tun resolv-retry infinite nobind persist-key persist-tun ns-cert-type server cipher AES-256-CBC comp-lzo verb 3 keepalive 5 30 /etc/openvpn/scripts/downscript.sh #!/bin/bash logger OpenVPN tunnel DOWN: Device=[$1] TunMTU=[$2] LinkMTU=[$3] LocalIP=[$4] RemoteIPOrNetmask=[$5] Call=[$6] iptables -F iptables -X iptables -t nat -F iptables -t nat -X iptables -t mangle -F iptables -t mangle -X iptables -P INPUT ACCEPT iptables -P FORWARD ACCEPT iptables -P OUTPUT ACCEPT iptables -I OUTPUT -d 69.163.36.66 -p udp -j ACCEPT iptables -I OUTPUT -d 69.163.36.66 -p tdp -j ACCEPT iptables -I INPUT -s 69.163.36.66 -p ucp -j ACCEPT iptables -I INPUT -s 69.163.36.66 -p tcp -j ACCEPT iptables -A INPUT -d 192.168.1.0/24 -p tcp -j ACCEPT iptables -A INPUT -d 192.168.1.0/24 -p udp -j ACCEPT iptables -I INPUT REJECT iptables -I OUTPUT REJECT sleep 15s service openvpn restart /etc/openvpn/scripts/upscript.sh #!/bin/bash logger OpenVPN tunnel UP: Device=[$1] TunMTU=[$2] LinkMTU=[$3] LocalIP=[$4] RemoteIPOrNetmask=[$5] Call=[$6] iptables -F iptables -X iptables -t nat -F iptables -t nat -X iptables -t mangle -F iptables -t mangle -X iptables -P INPUT ACCEPT iptables -P FORWARD ACCEPT iptables -P OUTPUT ACCEPT iptables -A INPUT -j ACCEPT -d 192.168.1.0/24 -p tcp iptables -A INPUT -j ACCEPT -d 192.168.1.0/24 -p udp iptables -A OUTPUT -j ACCEPT -d 192.168.1.0/24 -p tcp iptables -A OUTPUT -j ACCEPT -d 192.168.1.0/24 -p udp iptables -A INPUT -j REJECT -p tcp --destination-port 139 iptables -A INPUT -j REJECT -p tcp --destination-port 445 iptables -A INPUT -j REJECT -p tcp --destination-port 631 iptables -A INPUT -j REJECT -p udp --destination-port 139 iptables -A INPUT -j REJECT -p udp --destination-port 445 iptables -A INPUT -j REJECT -p udp --destination-port 631 iptables -A INPUT -j REJECT -p tcp --destination-port 5800 iptables -A INPUT -j REJECT -p tcp --destination-port 5900 /usr/sbin/ddclient -syslog -use=web Problem is, it just... drops out. Doesn't reconnect despite my down directive to restart the service. I used to have it ping out once every 5 minutes, and after any failure, reboot. That got annoying fast. Any ideas? I don't want tun0 to drop and leave me exposed without notice. Note - not using networkmanager because it always seems to cause more problems than it's worth. Just straight openvpn. Quote Share this post Link to post
Staff 10483 Posted ... Hello! Please check your iptables rules. In the downscript.sh the line "iptables -I OUTPUT -d 69.163.36.66 -p tdp -j ACCEPT" is wrong (replace "tdp" with "tcp"). Furthermore, apparently no proper masquerading is foreseen in your rules. Please compare your rules with: https://airvpn.org/index.php?option=com_kunena&func=view&catid=3&id=1713&limit=6&limitstart=30&Itemid=142#2010 Once you have fixed iptables, please send us the connection logs. Also, please try different servers. Kind regards Quote Share this post Link to post
sdkseusx 0 Posted ... I've not yet tried another server, about to try one now. Here's the tail of my daemon.log showing drops. Jul 23 13:26:53 vpnbox ovpn-airvpn[20845]: Socket Buffers: R=[87380->131072] S=[16384->131072] Jul 23 13:26:53 vpnbox ovpn-airvpn[20845]: Data Channel MTU parms [ L:1560 D:1450 EF:60 EB:135 ET:0 EL:0 AF:3/1 ] Jul 23 13:26:53 vpnbox ovpn-airvpn[20845]: Local Options hash (VER=V4): '958c5492' Jul 23 13:26:53 vpnbox ovpn-airvpn[20845]: Expected Remote Options hash (VER=V4): '79ef4284' Jul 23 13:26:53 vpnbox ovpn-airvpn[20845]: Attempting to establish TCP connection with [AF_INET]69.163.36.66:443 [nonblock] Jul 23 13:26:54 vpnbox ovpn-airvpn[20845]: TCP connection established with [AF_INET]69.163.36.66:443 Jul 23 13:26:54 vpnbox ovpn-airvpn[20845]: TCPv4_CLIENT link local: [undef] Jul 23 13:26:54 vpnbox ovpn-airvpn[20845]: TCPv4_CLIENT link remote: [AF_INET]69.163.36.66:443 Jul 23 13:26:54 vpnbox ovpn-airvpn[20845]: TLS: Initial packet from [AF_INET]69.163.36.66:443, sid=f1750e67 904f9dae Jul 23 13:26:54 vpnbox ovpn-airvpn[20845]: VERIFY OK: depth=1, /C=IT/ST=IT/L=Perugia/O=airvpn.org/CN=airvpn.org_CA/emailAddress=info@airvpn.org Jul 23 13:26:54 vpnbox ovpn-airvpn[20845]: VERIFY OK: nsCertType=SERVER Jul 23 13:26:54 vpnbox ovpn-airvpn[20845]: VERIFY OK: depth=0, /C=IT/ST=IT/L=Perugia/O=airvpn.org/CN=server/emailAddress=info@airvpn.org Jul 23 13:26:57 vpnbox ovpn-airvpn[20845]: Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key Jul 23 13:26:57 vpnbox ovpn-airvpn[20845]: Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication Jul 23 13:26:57 vpnbox ovpn-airvpn[20845]: Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key Jul 23 13:26:57 vpnbox ovpn-airvpn[20845]: Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication Jul 23 13:26:57 vpnbox ovpn-airvpn[20845]: Control Channel: TLSv1, cipher TLSv1/SSLv3 DHE-RSA-AES256-SHA, 2048 bit RSA Jul 23 13:26:57 vpnbox ovpn-airvpn[20845]: [server] Peer Connection Initiated with [AF_INET]69.163.36.66:443 Jul 23 13:26:59 vpnbox ovpn-airvpn[20845]: SENT CONTROL [server]: 'PUSH_REQUEST' (status=1) Jul 23 13:27:00 vpnbox ovpn-airvpn[20845]: AUTH: Received AUTH_FAILED control message Jul 23 13:27:00 vpnbox ovpn-airvpn[20845]: TCP/UDP: Closing socket Jul 23 13:27:00 vpnbox ovpn-airvpn[20845]: /sbin/route del -net 10.5.0.1 netmask 255.255.255.255 Jul 23 13:27:00 vpnbox ovpn-airvpn[20845]: /sbin/route del -net 69.163.36.66 netmask 255.255.255.255 Jul 23 13:27:00 vpnbox ovpn-airvpn[20845]: /sbin/route del -net 0.0.0.0 netmask 128.0.0.0 Jul 23 13:27:00 vpnbox ovpn-airvpn[20845]: /sbin/route del -net 128.0.0.0 netmask 128.0.0.0 Jul 23 13:27:00 vpnbox ovpn-airvpn[20845]: Closing TUN/TAP interface Jul 23 13:27:00 vpnbox ovpn-airvpn[20845]: /sbin/ifconfig tun0 0.0.0.0 Jul 23 13:27:00 vpnbox ovpn-airvpn[20845]: /etc/openvpn/scripts/downscript.sh tun0 1500 1560 10.5.3.6 10.5.3.5 init Jul 23 13:27:17 vpnbox ovpn-airvpn[21031]: OpenVPN 2.1.3 x86_64-pc-linux-gnu [sSL] [LZO2] [EPOLL] [PKCS11] [MH] [PF_INET6] [eurephia] built on Mar 29 2011 Jul 23 13:27:17 vpnbox ovpn-airvpn[21031]: NOTE: the current --script-security setting may allow this configuration to call user-defined scripts Jul 23 13:27:17 vpnbox ovpn-airvpn[21031]: /usr/bin/openssl-vulnkey -q -b 2048 -m <modulus omitted> Jul 23 13:27:17 vpnbox ovpn-airvpn[21031]: LZO compression initialized Jul 23 13:27:17 vpnbox ovpn-airvpn[21031]: Control Channel MTU parms [ L:1560 D:140 EF:40 EB:0 ET:0 EL:0 ] Jul 23 13:27:17 vpnbox ovpn-airvpn[21031]: Socket Buffers: R=[87380->131072] S=[16384->131072] Jul 23 13:27:17 vpnbox ovpn-airvpn[21031]: Data Channel MTU parms [ L:1560 D:1450 EF:60 EB:135 ET:0 EL:0 AF:3/1 ] Jul 23 13:27:17 vpnbox ovpn-airvpn[21031]: Local Options hash (VER=V4): '958c5492' Jul 23 13:27:17 vpnbox ovpn-airvpn[21031]: Expected Remote Options hash (VER=V4): '79ef4284' Jul 23 13:27:17 vpnbox ovpn-airvpn[21033]: Attempting to establish TCP connection with [AF_INET]69.163.36.66:443 [nonblock] Jul 23 13:27:17 vpnbox ovpn-airvpn[20845]: SIGTERM[soft,auth-failure] received, process exiting Jul 23 13:27:18 vpnbox ovpn-airvpn[21033]: TCP connection established with [AF_INET]69.163.36.66:443 Jul 23 13:27:18 vpnbox ovpn-airvpn[21033]: TCPv4_CLIENT link local: [undef] Jul 23 13:27:18 vpnbox ovpn-airvpn[21033]: TCPv4_CLIENT link remote: [AF_INET]69.163.36.66:443 Jul 23 13:27:18 vpnbox ovpn-airvpn[21033]: TLS: Initial packet from [AF_INET]69.163.36.66:443, sid=9c3ea07e 31f37e01 Jul 23 13:27:19 vpnbox ovpn-airvpn[21033]: VERIFY OK: depth=1, /C=IT/ST=IT/L=Perugia/O=airvpn.org/CN=airvpn.org_CA/emailAddress=info@airvpn.org Jul 23 13:27:19 vpnbox ovpn-airvpn[21033]: VERIFY OK: nsCertType=SERVER Jul 23 13:27:19 vpnbox ovpn-airvpn[21033]: VERIFY OK: depth=0, /C=IT/ST=IT/L=Perugia/O=airvpn.org/CN=server/emailAddress=info@airvpn.org Jul 23 13:27:20 vpnbox ovpn-airvpn[21033]: Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key Jul 23 13:27:20 vpnbox ovpn-airvpn[21033]: Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication Jul 23 13:27:20 vpnbox ovpn-airvpn[21033]: Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key Jul 23 13:27:20 vpnbox ovpn-airvpn[21033]: Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication Jul 23 13:27:20 vpnbox ovpn-airvpn[21033]: Control Channel: TLSv1, cipher TLSv1/SSLv3 DHE-RSA-AES256-SHA, 2048 bit RSA Jul 23 13:27:20 vpnbox ovpn-airvpn[21033]: [server] Peer Connection Initiated with [AF_INET]69.163.36.66:443 Jul 23 13:27:23 vpnbox ovpn-airvpn[21033]: SENT CONTROL [server]: 'PUSH_REQUEST' (status=1) Jul 23 13:27:23 vpnbox ovpn-airvpn[21033]: AUTH: Received AUTH_FAILED control message Jul 23 13:27:23 vpnbox ovpn-airvpn[21033]: TCP/UDP: Closing socket Jul 23 13:27:23 vpnbox ovpn-airvpn[21033]: SIGTERM[soft,auth-failure] received, process exiting It never came back from that drop, never called my downscript back, etc. I'm about to reboot that box, and test at another server now. Quote Share this post Link to post
